  4. js-controller 2.0 ab sofort im Latest Repo
js-controller
1.1k Beiträge 89 Kommentatoren 514.7k Aufrufe 64 Beobachtet
  • G gentlel
    Kann hier jemand helfen? Hier funktioniert nichts mehr :(
    iobroker:/opt/iobroker$ sudo npm install iobroker.js-controller@2.0.25
    > iobroker.js-controller@2.0.25 preinstall /opt/iobroker/node_modules/iobroker.js-controller
    > node lib/preinstallCheck.js
    NPM version: 6.13.0
    > iobroker.js-controller@2.0.25 install /opt/iobroker/node_modules/iobroker.js-controller
    > node iobroker.js setup first
    Cannot delete file. Not critical: Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../_service_iobroker.bat'
    Cannot delete file. Not critical: Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../iobroker.bat'
    Cannot delete file. Not critical: Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../iob.bat'
    fs.js:114
        throw err;
    Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../tmp'
        at Object.mkdirSync (fs.js:752:3)
        at Setup.setup (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:586:58)
        at processCommand (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:233:23)
        at Object.module.exports.execute (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2312:5)
        at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:86)
        at Module._compile (internal/modules/cjs/loader.js:701:30)
        at Object.Module._extensions..js (internal/modules/cjs/loader.js:712:10)
        at Module.load (internal/modules/cjs/loader.js:600:32)
        at tryModuleLoad (internal/modules/cjs/loader.js:539:12)
        at Function.Module._load (internal/modules/cjs/loader.js:531:3)
    npm WARN ELOOP: too many symbolic links encountered, stat '/opt/iobroker/node_modules/noble'
    npm WARN bl@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.4 (node_modules/osx-temperature-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm ERR! code ELIFECYCLE
    npm ERR! errno 1
    npm ERR! iobroker.js-controller@2.0.25 install: `node iobroker.js setup first`
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the iobroker.js-controller@2.0.25 install script.
    npm ERR!     /root/.npm/_logs/2020-01-17T20_16_38_051Z-debug.log
    sigi234S
    sigi234S
    #1029
    @gentlel
    Fixer mal laufen lassen?
    G 1 Antwort Letzte Antwort
    • sigi234S sigi234
      @gentlel
      G
      G
      gentlel
      #1030
      @sigi234 Ja aber der zeigt das hier an obwohl iobroker in /opt/iobroker ist 6⃣
      iobroker:~$ curl -sL https://iobroker.net/fix.sh | bash -
      library: loaded
      Library version=2020-01-13
      ioBroker is not installed in /opt/iobroker! Cannot fix anything...
      Mod-Edit: Code/Log in Code Tags gepackt. Bitte benutzt die Code Tags Funktion -> </>
      Hier gehts zur Hilfe.
      • G gentlel
        library: loaded
        sigi234S
        sigi234S
        #1031
        @gentlel sagte in js-controller 2.0 ab sofort im Latest Repo:
        library: loaded
        Was kommt bei:
        cd /opt/iobroker
        iobroker list instances
        node -v
        nodejs -v
        npm -v
        • G
          G
          gentlel
          #1032
          @sigi234 said in js-controller 2.0 ab sofort im Latest Repo:
          elmar@iobroker:/opt/iobroker$ iobroker list instances
          internal/modules/cjs/loader.js:584
              throw err;
          Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
              at Function.Module._resolveFilename (internal/modules/cjs/loader.js:582:15)
              at Function.Module._load (internal/modules/cjs/loader.js:508:25)
              at Function.Module.runMain (internal/modules/cjs/loader.js:754:12)
              at startup (internal/bootstrap/node.js:283:19)
              at bootstrapNodeJSCore (internal/bootstrap/node.js:622:3)
          node -v
          v10.15.3
          nodejs -v
          npm -v
          6.13.0
          Bis gerade eben lief iobroker ganz normal. Dann habe ich die homematic adapter upgedatet und die wollten js controller 2.0 haben :( seit dem geht nichts mehr :(
          dslraserD apollon77A 2 Antworten Letzte Antwort
          • G gentlel
                throw err;
            node -v
            v10.15.3
            nodejs -v
            npm -v
            6.13.0
            dslraserD
            dslraserD
            dslraser
            #1033
            @gentlel
            wieso diese Version ?
            • G
              G
              gentlel
              #1034
              Habe es auch nur mit js-controller versucht... gleiches Bild. 2.0.25 habe ich irgendwo im FOrum gelesen
              • G gentlel
                    throw err;
                node -v
                v10.15.3
                nodejs -v
                npm -v
                6.13.0
                apollon77A
                apollon77A
                #1035
                @gentlel dann siehe erster Post bzw faq Post. Manuell Controller per npm drüber installieren.
                • G gentlel
                  apollon77A
                  apollon77A
                  #1036
                  @gentlel Stable ist 2.1.1 und im Latest Test gerade die 2.2.7
                  • NightlyN
                    NightlyN
                    Nightly
                    #1037
                    Hallo, beim Updaten auf js-controller 2.2.9 kommen diverse Fehlermeldungen. Nach dem Update funktioniert alles soweit, ausser dass beim Updaten von Adaptern der selbe Fehler ebenso kommt. Danke für Hinweise, was unternommen werden kann.
                    root@ioBroker2:~# iobroker upgrade self
                    Update js-controller from @1.5.3 to @2.2.9
                    NPM version: 4.6.1
                    npm install iobroker.js-controller@2.2.9 --unsafe-perm --production --save --prefix "/opt/iobroker" (System call)
                    ../authenticate_pam.cc:30:31: fatal error: security/pam_appl.h: Datei oder Verzeichnis nicht gefunden
                     #include <security/pam_appl.h>
                    compilation terminated.
                    make: *** [Release/obj.target/authenticate_pam/authenticate_pam.o] Fehler 1
                    gyp ERR! build error
                    gyp ERR! stack Error: `make` failed with exit code: 2
                    gyp ERR! stack     at ChildProcess.onExit (/root/.nvm/versions/node/v8.11.3/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:285:23)
                    gyp ERR! stack     at emitTwo (events.js:126:13)
                    gyp ERR! stack     at ChildProcess.emit (events.js:214:7)
                    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12)
                    gyp ERR! System Linux 4.9.0-8-amd64
                    gyp ERR! command "/root/.nvm/versions/node/v8.11.3/bin/node" "/root/.nvm/versions/node/v8.11.3/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                    gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pam
                    gyp ERR! node -v v8.11.3
                    gyp ERR! node-gyp -v v3.6.0
                    gyp ERR! not ok
                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fsevents):
                    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                    npm WARN ws@7.2.3 requires a peer of bufferutil@^4.0.1 but none was installed.
                    npm WARN ws@7.2.3 requires a peer of utf-8-validate@^5.0.2 but none was installed.
                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 (node_modules/authenticate-pam):
                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 install: `node-gyp rebuild`
                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                    Host "ioBroker2" (linux) updated
                    Execute: chmod -R 777 /opt/iobroker
                    Chmod finished. Restart controller
                    Starting node restart.js
                    Update von Adapter:
                    $ ./iobroker upgrade cloud
                    Update cloud from @3.0.2 to @3.0.3
                    NPM version: 4.6.1
                    npm install iobroker.cloud@3.0.3 --unsafe-perm --loglevel error --prefix "/opt/iobroker" (System call)
                    ../authenticate_pam.cc:30:31: fatal error: security/pam_appl.h: Datei oder Verzeichnis nicht gefunden #include <security/pam_appl.h>                               ^compilation terminated.
                    gyp
                     ERR! build error
                    gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/root/.nvm/versions/node/v8.11.3/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:285:23)gyp ERR!
                     stack     at emitTwo (events.js:126:13)gyp ERR! stack     at ChildProcess.emit (events.js:214:7)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12)gyp
                     ERR! System Linux 4.9.0-8-amd64gyp ERR! command "/root/.nvm/versions/node/v8.11.3/bin/node" "/root/.nvm/versions/node/v8.11.3/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd
                     /opt/iobroker/node_modules/authenticate-pamgyp ERR! node -v v8.11.3gyp ERR! node-gyp -v v3.6.0gyp ERR! not ok
                    upload [6] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/words.js words.js application/javascript
                    Update "system.adapter.cloud.0"
                    upload [5] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/index_m.html index_m.html text/html
                    upload [4] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/index.html index.html text/html
                    upload [3] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/cloud.png cloud.png image/png
                    upload [2] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/blockly.js blockly.js application/javascript
                    upload [1] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/alexalogo.png alexalogo.png image/png
                    upload [0] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/actions.js actions.js application/javascript
                    Adapter "cloud" updated
                    process exited with code 0
                    Thomas BraunT paul53P 2 Antworten Letzte Antwort
                    • NightlyN Nightly
                      NPM version: 4.6.1
                      gyp ERR! not ok
                      Update von Adapter:
                      NPM version: 4.6.1
                      gyp
                       ERR! build error
                      Thomas BraunT
                      Thomas BraunT
                      Most Active Developer
                      #1038
                      @Nightly Da versuchst du aber einen Sprung...
                      nodejs -v
                      node -v
                      Und wenn du da auf einem Debian unterwegs bist: Ich bin kein Freund von root-shells...
                      lsb_release -a
                      NightlyN 1 Antwort Letzte Antwort
                        nodejs -v
                        node -v
                        lsb_release -a
                        NightlyN
                        NightlyN
                        Nightly
                        #1039
                        @Thomas-Braun
                        root@ioBroker2:~# nodejs -v
                        v8.12.0
                        root@ioBroker2:~# node -v
                        v8.11.3
                        root@ioBroker2:~# lsb_release -a
                        No LSB modules are available.
                        Distributor ID:	Debian
                        Description:	Debian GNU/Linux 9.5 (stretch)
                        Release:	9.5
                        Codename:	stretch
                        • NightlyN Nightly
                          @Thomas-Braun
                          v8.12.0
                          v8.11.3
                          Release:	9.5
                          Codename:	stretch
                          Thomas BraunT
                          Thomas BraunT
                          #1040
                          @Nightly node falsch installiert (und in einer zu niedrigen Version für iobroker 2.2.9, denke ich) .
                          Und melde dich als root ab! Das wird als normaler user ausgeführt. (Es sei denn, das läuft im Docker ab...)
                          • NightlyN Nightly
                            NPM version: 4.6.1
                            gyp ERR! not ok
                            Update von Adapter:
                            NPM version: 4.6.1
                            gyp
                             ERR! build error
                            paul53P
                            paul53P
                            #1041
                            @Nightly sagte:
                            NPM version: 4.6.1
                            Die Version ist sehr alt.
                            Produktiv: Asus PN42: N100 / 8 GB / 500 GB; Proxmox mit 2 VM (ioBroker / openCCU)
                              @Nightly sagte:
                              NPM version: 4.6.1
                              Thomas BraunT
                              Thomas BraunT
                              #1042
                              @paul53 said in js-controller 2.0 ab sofort im Latest Repo:
                              Nicht nur alt, sondern auch schief installiert.
                                NightlyN
                                NightlyN
                                Nightly
                                #1043
                                @Thomas-Braun Was meinst du mit "falsch"/"schief" installiert? Unterschiedliche Versionen von nodejs und node? Hatte da vor einiger Zeit Probleme mit yahka Adapter, als ich zu aktuell war, und musste da mühsam zurück. Seit dann habe ich's gelassen ;)
                                Bezüglich root schaue ich mir an.
                                • NightlyN Nightly
                                  Thomas BraunT
                                  Thomas BraunT
                                  #1044
                                  @Nightly said in js-controller 2.0 ab sofort im Latest Repo:
                                  Das sieht man. Die Baustelle ist zugemüllt.
                                  Was gibt es dann da 'anzuschauen?
                                    NightlyN
                                    NightlyN
                                    Nightly
                                    #1045
                                    @Thomas-Braun Willst du mir helfen, oder nur rummeckern? Die Frage was du mit falsch/schief meinst hast du nicht beantwortet. Das würde weiter helfen. Dankeschön.
                                    • NightlyN Nightly
                                      Thomas BraunT
                                      Thomas BraunT
                                      #1046
                                      @Nightly Du kannst Hilfe bekommen:
                                      Die Versionen von node und nodejs müssen übereinstimmen. Soweit zu falsch.
                                      Schief ist das, weil die abweichende Version 'irgendwie' händisch in das System geknüppelt wurde.
                                      Und dann ist die Version 8 zu alt für den js-controller 2.2.9.
                                      Wir können das Problem angehen, dann aber auf einem 'sauberen' Grundsystem. Mit korrektem user login und nicht als 'root' eingeloggt.
                                      Vermutlich kommt die schiefe Installation nämlich dadurch erst zustande.
                                        NightlyN
                                        NightlyN
                                        Nightly
                                        #1047
                                        @Thomas-Braun Vielen Dank für die Klärung. Wie erwähnt musste ich da mit nodejs und node Verseionen hin und her probieren, bis yahka wieder lief. Ich schaue mir das die nächsten Tage an, wie ich in meinem Clone vorgehe, um alles geordnet upzudaten, und dass dann alles noch funktioniert.
                                        Aber Version 8 ist nicht zu alt für js-controller 2x (siehe hier) :
                                        • Ab der Version 2.0 des js-controllers (das Freigabedatum ist noch nicht bekannt) sind die Anpassungen so tiefgreifend, dass die Node.js-Versionen 4 und 6 nicht mehr unterstützt werden können.
                                        • Ab Version 3.0 vom Controller, der gerade (Stand 24.4.2020) im Latest Repository ist, wird Nodejs 10.x Minimum sein.
                                        • NightlyN Nightly
                                          Thomas BraunT
                                          Thomas BraunT
                                          #1048
                                          @Nightly Nur ist node8 schon längst obsolet. Wird nicht mehr supportet.
                                          Der Eintrag von Stabilostick ist auch vom 1 Jun 2019, 02:46
                                          Also mindestens 10 ist da heute angesagt.
                                          https://nodejs.org/en/about/releases/
                                          84.2k
