  4. js-controller 2.0 ab sofort im Latest Repo
js-controller
1.1k Beiträge 89 Kommentatoren 539.0k Aufrufe 64 Beobachtet
  • NightlyN Nightly
    Hallo, beim Updaten auf js-controller 2.2.9 kommen diverse Fehlermeldungen. Nach dem Update funktioniert alles soweit, ausser dass beim Updaten von Adaptern der selbe Fehler ebenso kommt. Danke für Hinweise, was unternommen werden kann.
    root@ioBroker2:~# iobroker upgrade self
    Update js-controller from @1.5.3 to @2.2.9
    NPM version: 4.6.1
    npm install iobroker.js-controller@2.2.9 --unsafe-perm --production --save --prefix "/opt/iobroker" (System call)
    ../authenticate_pam.cc:30:31: fatal error: security/pam_appl.h: Datei oder Verzeichnis nicht gefunden
     #include <security/pam_appl.h>
    compilation terminated.
    make: *** [Release/obj.target/authenticate_pam/authenticate_pam.o] Fehler 1
    gyp ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2
    gyp ERR! stack     at ChildProcess.onExit (/root/.nvm/versions/node/v8.11.3/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:285:23)
    gyp ERR! stack     at emitTwo (events.js:126:13)
    gyp ERR! stack     at ChildProcess.emit (events.js:214:7)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12)
    gyp ERR! System Linux 4.9.0-8-amd64
    gyp ERR! command "/root/.nvm/versions/node/v8.11.3/bin/node" "/root/.nvm/versions/node/v8.11.3/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pam
    gyp ERR! node -v v8.11.3
    gyp ERR! node-gyp -v v3.6.0
    gyp ERR! not ok
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    npm WARN ws@7.2.3 requires a peer of bufferutil@^4.0.1 but none was installed.
    npm WARN ws@7.2.3 requires a peer of utf-8-validate@^5.0.2 but none was installed.
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 (node_modules/authenticate-pam):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 install: `node-gyp rebuild`
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
    Host "ioBroker2" (linux) updated
    Execute: chmod -R 777 /opt/iobroker
    Chmod finished. Restart controller
    Starting node restart.js
    Update von Adapter:
    $ ./iobroker upgrade cloud
    Update cloud from @3.0.2 to @3.0.3
    NPM version: 4.6.1
    npm install iobroker.cloud@3.0.3 --unsafe-perm --loglevel error --prefix "/opt/iobroker" (System call)
    ../authenticate_pam.cc:30:31: fatal error: security/pam_appl.h: Datei oder Verzeichnis nicht gefunden #include <security/pam_appl.h>                               ^compilation terminated.
    gyp
     ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/root/.nvm/versions/node/v8.11.3/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:285:23)gyp ERR!
     stack     at emitTwo (events.js:126:13)gyp ERR! stack     at ChildProcess.emit (events.js:214:7)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12)gyp
     ERR! System Linux 4.9.0-8-amd64gyp ERR! command "/root/.nvm/versions/node/v8.11.3/bin/node" "/root/.nvm/versions/node/v8.11.3/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd
     /opt/iobroker/node_modules/authenticate-pamgyp ERR! node -v v8.11.3gyp ERR! node-gyp -v v3.6.0gyp ERR! not ok
    upload [6] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/words.js words.js application/javascript
    Update "system.adapter.cloud.0"
    upload [5] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/index_m.html index_m.html text/html
    upload [4] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/index.html index.html text/html
    upload [3] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/cloud.png cloud.png image/png
    upload [2] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/blockly.js blockly.js application/javascript
    upload [1] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/alexalogo.png alexalogo.png image/png
    upload [0] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/actions.js actions.js application/javascript
    Adapter "cloud" updated
    process exited with code 0
    Thomas BraunT
    Thomas BraunT
    Most Active Developer
    #1038
    @Nightly Da versuchst du aber einen Sprung...
    nodejs -v
    node -v
    Und wenn du da auf einem Debian unterwegs bist: Ich bin kein Freund von root-shells...
    lsb_release -a
    NightlyN 1 Antwort Letzte Antwort
      nodejs -v
      node -v
      lsb_release -a
      NightlyN
      NightlyN
      Nightly
      #1039
      @Thomas-Braun
      root@ioBroker2:~# nodejs -v
      v8.12.0
      root@ioBroker2:~# node -v
      v8.11.3
      root@ioBroker2:~# lsb_release -a
      No LSB modules are available.
      Distributor ID:	Debian
      Description:	Debian GNU/Linux 9.5 (stretch)
      Release:	9.5
      Codename:	stretch
      • NightlyN Nightly
        @Thomas-Braun
        v8.12.0
        v8.11.3
        Release:	9.5
        Codename:	stretch
        Thomas BraunT
        Thomas BraunT
        #1040
        @Nightly node falsch installiert (und in einer zu niedrigen Version für iobroker 2.2.9, denke ich) .
        Und melde dich als root ab! Das wird als normaler user ausgeführt. (Es sei denn, das läuft im Docker ab...)
        • NightlyN Nightly
          NPM version: 4.6.1
          gyp ERR! not ok
          Update von Adapter:
          NPM version: 4.6.1
          gyp
           ERR! build error
          paul53P
          paul53P
          #1041
          @Nightly sagte:
          NPM version: 4.6.1
          Die Version ist sehr alt.
          Produktiv: Asus PN42: N100 / 8 GB / 500 GB; Proxmox mit 2 VM (ioBroker / openCCU)
            @Nightly sagte:
            NPM version: 4.6.1
            Thomas BraunT
            Thomas BraunT
            #1042
            @paul53 said in js-controller 2.0 ab sofort im Latest Repo:
            Nicht nur alt, sondern auch schief installiert.
              NightlyN
              NightlyN
              Nightly
              #1043
              @Thomas-Braun Was meinst du mit "falsch"/"schief" installiert? Unterschiedliche Versionen von nodejs und node? Hatte da vor einiger Zeit Probleme mit yahka Adapter, als ich zu aktuell war, und musste da mühsam zurück. Seit dann habe ich's gelassen ;)
              Bezüglich root schaue ich mir an.
              • NightlyN Nightly
                Thomas BraunT
                Thomas BraunT
                #1044
                @Nightly said in js-controller 2.0 ab sofort im Latest Repo:
                Das sieht man. Die Baustelle ist zugemüllt.
                Was gibt es dann da 'anzuschauen?
                  NightlyN
                  NightlyN
                  Nightly
                  #1045
                  @Thomas-Braun Willst du mir helfen, oder nur rummeckern? Die Frage was du mit falsch/schief meinst hast du nicht beantwortet. Das würde weiter helfen. Dankeschön.
                  • NightlyN Nightly
                    Thomas BraunT
                    Thomas BraunT
                    #1046
                    @Nightly Du kannst Hilfe bekommen:
                    Die Versionen von node und nodejs müssen übereinstimmen. Soweit zu falsch.
                    Schief ist das, weil die abweichende Version 'irgendwie' händisch in das System geknüppelt wurde.
                    Und dann ist die Version 8 zu alt für den js-controller 2.2.9.
                    Wir können das Problem angehen, dann aber auf einem 'sauberen' Grundsystem. Mit korrektem user login und nicht als 'root' eingeloggt.
                    Vermutlich kommt die schiefe Installation nämlich dadurch erst zustande.
                      NightlyN
                      NightlyN
                      Nightly
                      #1047
                      @Thomas-Braun Vielen Dank für die Klärung. Wie erwähnt musste ich da mit nodejs und node Verseionen hin und her probieren, bis yahka wieder lief. Ich schaue mir das die nächsten Tage an, wie ich in meinem Clone vorgehe, um alles geordnet upzudaten, und dass dann alles noch funktioniert.
                      Aber Version 8 ist nicht zu alt für js-controller 2x (siehe hier) :
                      • Ab der Version 2.0 des js-controllers (das Freigabedatum ist noch nicht bekannt) sind die Anpassungen so tiefgreifend, dass die Node.js-Versionen 4 und 6 nicht mehr unterstützt werden können.
                      • Ab Version 3.0 vom Controller, der gerade (Stand 24.4.2020) im Latest Repository ist, wird Nodejs 10.x Minimum sein.
                      • NightlyN Nightly
                        Thomas BraunT
                        Thomas BraunT
                        #1048
                        @Nightly Nur ist node8 schon längst obsolet. Wird nicht mehr supportet.
                        Der Eintrag von Stabilostick ist auch vom 1 Jun 2019, 02:46
                        Also mindestens 10 ist da heute angesagt.
                        https://nodejs.org/en/about/releases/
                          NightlyN
                          NightlyN
                          Nightly
                          #1049
                          @Thomas-Braun So, habe ne aktuelle buster Disti installiert und den ioBroker migriert. Ein ganzes Stück Arbeit. Insbesondere musste das gesamte Homekit auf dem Phone neu verbunden und neu konfiguriert werden, da mit den bestehender Einstellung auf dem Phone nicht zu yahka verbunden werden konnte. Werde wohl oder übel wieder einige Zeit auf diesem Stand bleiben, bis das nächste grosse Update gezwungenermassen ansteht. Danke für den Hint bez. nodejs/node Versionen. Und läuft jetzt auch im Userkontext.
                          • NightlyN Nightly
                            Thomas BraunT
                            Thomas BraunT
                            #1050
                            @Nightly Das schaut doch schon mal ganz ordentlich aus.
                            Richtig schön wäre, wenn du dich auch nicht als iobroker einloggen würdest. Das ist ein system user.
                            • MathiasJM
                              MathiasJM
                              MathiasJ
                              schrieb am zuletzt editiert von MathiasJ
                              #1051
                              Ich dachte, diese Version wäre schon Asbach Uralt?
                              Es gibt doch schon die Version 3.x oder irre ich?
                              https://forum.iobroker.net/topic/32481/js-controller-3-0-jetzt-im-latest
                              IObroker auf dem NUC als VM.
                              • MathiasJM MathiasJ
                                apollon77A
                                apollon77A
                                #1052
                                @MathiasJ der controller 3.x ist erst im Latest, aber ich denke so in 1-2 Wochen sind wir damit im Stable
                                33.2k
                                84.3k
