  4. js-controller 2.0 ab sofort im Latest Repo
js-controller
1.1k Beiträge 89 Kommentatoren 477.7k Aufrufe 64 Beobachtet
  • F
    F
    frankyboy73
    #1024
    Hi, bei mir klappt es leider nicht mit dem Update. Nach dem Update Versuch geht leider gar nichts mehr und ich muss neu aufsetzten.
    Ich habe nen Raspberry pi 4 und Raspian Buster drauf, neuste Version.
    Folgendes habe ich als Ausgabe.
    Update js-controller from @1.2.3 to @2.1.1
    npm install iobroker.js-controller@2.1.1 --unsafe-perm  --production --prefix "/opt/iobroker" (System call)
    npm WARN deprecated circular-json@0.3.3: CircularJSON is in maintenance only, flatted is its successor.
    In file included from ../src/unix_dgram.cc:5:
    ../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
    ../../nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
         , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
    In file included from ../../nan/nan.h:54,
    ../src/unix_dgram.cc: At global scope:
    /home/iobroker/.cache/node-gyp/10.18.0/include/node/node.h:573:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
           (node::addon_register_func) (regfunc),                          \
    /home/iobroker/.cache/node-gyp/10.18.0/include/node/node.h:607:3: note: in expansion of macro ‘NODE_MODULE_X’
       NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
    ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
     NODE_MODULE(unix_dgram, Initialize)
    In file included from /home/iobroker/.cache/node-gyp/10.18.0/include/node/node.h:63,
    /home/iobroker/.cache/node-gyp/10.18.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)]’:
    /home/iobroker/.cache/node-gyp/10.18.0/include/node/node_object_wrap.h:84:78:   required from here
    /home/iobroker/.cache/node-gyp/10.18.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<node::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
                    reinterpret_cast<Callback>(callback), type);
    /home/iobroker/.cache/node-gyp/10.18.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = Nan::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)]’:
    ../../nan/nan_object_wrap.h:65:61:   required from here
    /home/iobroker/.cache/node-gyp/10.18.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<Nan::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
    (node:916) UnhandledPromiseRejectionWarning: ParserError: Protocol error, got "H" as reply type byte. Please report this.
        at handleError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:190:15)
        at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:304:14)
    (node:916) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 1)
    (node:916) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
    (node:916) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 2)
    │ Manual installation of ioBroker is no longer supported  │
    │ on Linux, OSX and FreeBSD!                              │
    │ Please refer to the documentation on how to install it! │
    │ https://github.com/ioBroker/ioBroker/wiki/Installation  │
    npm WARN ajv-keywords@2.1.1 requires a peer of ajv@^5.0.0 but none is installed. You must install peer dependencies yourself.
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.4 (node_modules/osx-temperature-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm ERR! code ELIFECYCLE
    npm ERR! errno 100
    npm ERR! iobroker@2.0.3 postinstall: `node lib/install.js`
    npm ERR! Exit status 100
    npm ERR!
    npm ERR! Failed at the iobroker@2.0.3 postinstall script.
    npm ERR!     /home/iobroker/.npm/_logs/2020-01-14T16_45_21_540Z-debug.log
    host.raspberrypi Cannot install iobroker.js-controller@2.1.1: 100
    Mod-Edit: Code/Log in Code Tags gepackt. Bitte benutzt die Code Tags Funktion -> </>
    Hier gehts zur Hilfe.
    Schöne Grüße Frank
    • F
      F
      frankyboy73
      #1025
      Hi, ich habe das Problem gefunden. Ich hatte für meinen neuen PI 4 ein Backup vom Pi 3 genommen. Bei meiner Backup Variante speicher ich den Iobroker Data und den Node Modules Ordner und kopiere die für das Wiederherstellen wieder in den Iobroker Ordner. Damit habe ich dann wohl auf dem neuen System ein bisschen was vermurkst. Ich habe jetzt über mein System noch mal die Iobroker Installation drübergebügelt und es läuft alles inklusive js-controller Version 2.1.1
      Schöne Grüße Frank
      • F frankyboy73
        apollon77A
        apollon77A
        #1026
        @frankyboy73 node_modules zu kopieren ist eine extrem "blöde Idee" weil hier viel mit symbolischen Links und solchen Dingen gearbeitet wird die durch ein "Normales" copy kaputt gehen ... Aber super das Du es gelöst hast.
        PS: WOW einen js.controller 1.2.3 hat ich schon ewig nimmer gesehn ;-)
        • F
          F
          frankyboy73
          #1027
          OK, da werde ich in Zukunft wohl doch nur noch die normale Backup Methode nutzen. Der Vorteil war, das man ruck zuck alles wieder am laufen hatte.
          Lief bis jetzt alles super mit dem js-controller 1.2.3. Ich wollte nur auf größer 2 weil sonst der ALexa2 Adapter in der neuen Version nicht mehr geht.
          Danke für deine Antwort/Info
          Schöne Grüße Frank
          • G
            G
            gentlel
            #1028
            Kann hier jemand helfen? Hier funktioniert nichts mehr :(
            iobroker:/opt/iobroker$ sudo npm install iobroker.js-controller@2.0.25
            > iobroker.js-controller@2.0.25 preinstall /opt/iobroker/node_modules/iobroker.js-controller
            > node lib/preinstallCheck.js
            NPM version: 6.13.0
            > iobroker.js-controller@2.0.25 install /opt/iobroker/node_modules/iobroker.js-controller
            > node iobroker.js setup first
            Cannot delete file. Not critical: Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../_service_iobroker.bat'
            Cannot delete file. Not critical: Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../iobroker.bat'
            Cannot delete file. Not critical: Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../iob.bat'
            fs.js:114
                throw err;
            Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../tmp'
                at Object.mkdirSync (fs.js:752:3)
                at Setup.setup (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:586:58)
                at processCommand (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:233:23)
                at Object.module.exports.execute (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2312:5)
                at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:86)
                at Module._compile (internal/modules/cjs/loader.js:701:30)
                at Object.Module._extensions..js (internal/modules/cjs/loader.js:712:10)
                at Module.load (internal/modules/cjs/loader.js:600:32)
                at tryModuleLoad (internal/modules/cjs/loader.js:539:12)
                at Function.Module._load (internal/modules/cjs/loader.js:531:3)
            npm WARN ELOOP: too many symbolic links encountered, stat '/opt/iobroker/node_modules/noble'
            npm WARN bl@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):
            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
            npm ERR! errno 1
            npm ERR! iobroker.js-controller@2.0.25 install: `node iobroker.js setup first`
            npm ERR!
            npm ERR! Failed at the iobroker.js-controller@2.0.25 install script.
            npm ERR!     /root/.npm/_logs/2020-01-17T20_16_38_051Z-debug.log
            • G gentlel
              NPM version: 6.13.0
              fs.js:114
                  throw err;
              npm ERR! errno 1
              npm ERR!
              sigi234S
              sigi234S
              #1029
              @gentlel
              Fixer mal laufen lassen?
              G 1 Antwort Letzte Antwort
              • sigi234S sigi234
                @gentlel
                G
                G
                gentlel
                #1030
                @sigi234 Ja aber der zeigt das hier an obwohl iobroker in /opt/iobroker ist 6⃣
                iobroker:~$ curl -sL https://iobroker.net/fix.sh | bash -
                library: loaded
                Library version=2020-01-13
                ioBroker is not installed in /opt/iobroker! Cannot fix anything...
                • G gentlel
                  library: loaded
                  sigi234S
                  sigi234S
                  #1031
                  @gentlel sagte in js-controller 2.0 ab sofort im Latest Repo:
                  library: loaded
                  Was kommt bei:
                  cd /opt/iobroker
                  iobroker list instances
                  node -v
                  nodejs -v
                  npm -v
                  • G
                    G
                    gentlel
                    #1032
                    @sigi234 said in js-controller 2.0 ab sofort im Latest Repo:
                    elmar@iobroker:/opt/iobroker$ iobroker list instances
                    internal/modules/cjs/loader.js:584
                        throw err;
                    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                        at Function.Module._resolveFilename (internal/modules/cjs/loader.js:582:15)
                        at Function.Module._load (internal/modules/cjs/loader.js:508:25)
                        at Function.Module.runMain (internal/modules/cjs/loader.js:754:12)
                        at startup (internal/bootstrap/node.js:283:19)
                        at bootstrapNodeJSCore (internal/bootstrap/node.js:622:3)
                    node -v
                    v10.15.3
                    nodejs -v
                    npm -v
                    6.13.0
                    Bis gerade eben lief iobroker ganz normal. Dann habe ich die homematic adapter upgedatet und die wollten js controller 2.0 haben :( seit dem geht nichts mehr :(
                    dslraserD apollon77A 2 Antworten Letzte Antwort
                    • G gentlel
                          throw err;
                      node -v
                      v10.15.3
                      nodejs -v
                      npm -v
                      6.13.0
                      dslraserD
                      dslraserD
                      dslraser
                      #1033
                      @gentlel
                      wieso diese Version ?
                      • G
                        G
                        gentlel
                        #1034
                        Habe es auch nur mit js-controller versucht... gleiches Bild. 2.0.25 habe ich irgendwo im FOrum gelesen
                        • G gentlel
                              throw err;
                          node -v
                          v10.15.3
                          nodejs -v
                          npm -v
                          6.13.0
                          apollon77A
                          apollon77A
                          #1035
                          @gentlel dann siehe erster Post bzw faq Post. Manuell Controller per npm drüber installieren.
                          • G gentlel
                            apollon77A
                            apollon77A
                            #1036
                            @gentlel Stable ist 2.1.1 und im Latest Test gerade die 2.2.7
                            • NightlyN
                              NightlyN
                              Nightly
                              #1037
                              Hallo, beim Updaten auf js-controller 2.2.9 kommen diverse Fehlermeldungen. Nach dem Update funktioniert alles soweit, ausser dass beim Updaten von Adaptern der selbe Fehler ebenso kommt. Danke für Hinweise, was unternommen werden kann.
                              root@ioBroker2:~# iobroker upgrade self
                              Update js-controller from @1.5.3 to @2.2.9
                              NPM version: 4.6.1
                              npm install iobroker.js-controller@2.2.9 --unsafe-perm --production --save --prefix "/opt/iobroker" (System call)
                              ../authenticate_pam.cc:30:31: fatal error: security/pam_appl.h: Datei oder Verzeichnis nicht gefunden
                               #include <security/pam_appl.h>
                              compilation terminated.
                              make: *** [Release/obj.target/authenticate_pam/authenticate_pam.o] Fehler 1
                              gyp ERR! build error
                              gyp ERR! stack Error: `make` failed with exit code: 2
                              gyp ERR! stack     at ChildProcess.onExit (/root/.nvm/versions/node/v8.11.3/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:285:23)
                              gyp ERR! stack     at emitTwo (events.js:126:13)
                              gyp ERR! stack     at ChildProcess.emit (events.js:214:7)
                              gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12)
                              gyp ERR! System Linux 4.9.0-8-amd64
                              gyp ERR! command "/root/.nvm/versions/node/v8.11.3/bin/node" "/root/.nvm/versions/node/v8.11.3/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                              gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pam
                              gyp ERR! node -v v8.11.3
                              gyp ERR! node-gyp -v v3.6.0
                              gyp ERR! not ok
                              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fsevents):
                              npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                              npm WARN ws@7.2.3 requires a peer of bufferutil@^4.0.1 but none was installed.
                              npm WARN ws@7.2.3 requires a peer of utf-8-validate@^5.0.2 but none was installed.
                              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 (node_modules/authenticate-pam):
                              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 install: `node-gyp rebuild`
                              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                              Host "ioBroker2" (linux) updated
                              Execute: chmod -R 777 /opt/iobroker
                              Chmod finished. Restart controller
                              Starting node restart.js
                              Update von Adapter:
                              $ ./iobroker upgrade cloud
                              Update cloud from @3.0.2 to @3.0.3
                              NPM version: 4.6.1
                              npm install iobroker.cloud@3.0.3 --unsafe-perm --loglevel error --prefix "/opt/iobroker" (System call)
                              ../authenticate_pam.cc:30:31: fatal error: security/pam_appl.h: Datei oder Verzeichnis nicht gefunden #include <security/pam_appl.h>                               ^compilation terminated.
                              gyp
                               ERR! build error
                              gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/root/.nvm/versions/node/v8.11.3/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:285:23)gyp ERR!
                               stack     at emitTwo (events.js:126:13)gyp ERR! stack     at ChildProcess.emit (events.js:214:7)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12)gyp
                               ERR! System Linux 4.9.0-8-amd64gyp ERR! command "/root/.nvm/versions/node/v8.11.3/bin/node" "/root/.nvm/versions/node/v8.11.3/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd
                               /opt/iobroker/node_modules/authenticate-pamgyp ERR! node -v v8.11.3gyp ERR! node-gyp -v v3.6.0gyp ERR! not ok
                              upload [6] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/words.js words.js application/javascript
                              Update "system.adapter.cloud.0"
                              upload [5] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/index_m.html index_m.html text/html
                              upload [4] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/index.html index.html text/html
                              upload [3] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/cloud.png cloud.png image/png
                              upload [2] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/blockly.js blockly.js application/javascript
                              upload [1] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/alexalogo.png alexalogo.png image/png
                              upload [0] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/actions.js actions.js application/javascript
                              Adapter "cloud" updated
                              process exited with code 0
                              Thomas BraunT paul53P 2 Antworten Letzte Antwort
                              • NightlyN Nightly
                                NPM version: 4.6.1
                                gyp ERR! not ok
                                Update von Adapter:
                                NPM version: 4.6.1
                                gyp
                                 ERR! build error
                                Thomas BraunT
                                Thomas BraunT
                                #1038
                                @Nightly Da versuchst du aber einen Sprung...
                                nodejs -v
                                node -v
                                Und wenn du da auf einem Debian unterwegs bist: Ich bin kein Freund von root-shells...
                                lsb_release -a
                                NightlyN 1 Antwort Letzte Antwort
                                  nodejs -v
                                  node -v
                                  lsb_release -a
                                  NightlyN
                                  NightlyN
                                  Nightly
                                  #1039
                                  @Thomas-Braun
                                  root@ioBroker2:~# nodejs -v
                                  v8.12.0
                                  root@ioBroker2:~# node -v
                                  v8.11.3
                                  root@ioBroker2:~# lsb_release -a
                                  No LSB modules are available.
                                  Distributor ID:	Debian
                                  Description:	Debian GNU/Linux 9.5 (stretch)
                                  Release:	9.5
                                  Codename:	stretch
                                  • NightlyN Nightly
                                    @Thomas-Braun
                                    v8.12.0
                                    v8.11.3
                                    Release:	9.5
                                    Codename:	stretch
                                    Thomas BraunT
                                    Thomas BraunT
                                    #1040
                                    @Nightly node falsch installiert (und in einer zu niedrigen Version für iobroker 2.2.9, denke ich) .
                                    Und melde dich als root ab! Das wird als normaler user ausgeführt. (Es sei denn, das läuft im Docker ab...)
                                    • NightlyN Nightly
                                      NPM version: 4.6.1
                                      gyp ERR! not ok
                                      Update von Adapter:
                                      NPM version: 4.6.1
                                      gyp
                                       ERR! build error
                                      paul53P
                                      paul53P
                                      #1041
                                      @Nightly sagte:
                                      NPM version: 4.6.1
                                      Die Version ist sehr alt.
                                        @Nightly sagte:
                                        NPM version: 4.6.1
                                        Thomas BraunT
                                        Thomas BraunT
                                        #1042
                                        @paul53 said in js-controller 2.0 ab sofort im Latest Repo:
                                        Nicht nur alt, sondern auch schief installiert.
                                          NightlyN
                                          NightlyN
                                          Nightly
                                          #1043
                                          @Thomas-Braun Was meinst du mit "falsch"/"schief" installiert? Unterschiedliche Versionen von nodejs und node? Hatte da vor einiger Zeit Probleme mit yahka Adapter, als ich zu aktuell war, und musste da mühsam zurück. Seit dann habe ich's gelassen ;)
                                          Bezüglich root schaue ich mir an.
                                          83.8k
