  4. [gelöst] js-controller 3.0.19 upgrade Fehler - Iobroker tot
js-controller update
47 Beiträge 17 Kommentatoren 8.0k Aufrufe 12 Beobachtet
    Bei mir funktioniert es leider nicht:
    pi@ioBroker-RasPi4:/opt/iobroker $ npm install iobroker.js-controller@3.0.20
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    npm WARN deprecated fsevents@1.2.12: fsevents 1 will break on node v14+ and could be using insecure binaries. Upgrade to fsevents 2.
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/chokidar/node_modules/fsevents
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.loxone/node_modules/chokidar/node_modules/fsevents
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.loxone/node_modules/chokidar/node_modules/fsevents/node_modules
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/iobroker.js-controller/node_modules/chokidar/node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@^1.2.7 (node_modules/chokidar/node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.12: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@^1.2.7 (node_modules/iobroker.loxone/node_modules/chokidar/node_modules/fsevents):
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/fsevents/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.loxone/node_modules/fsevents/package.json'
    npm WARN ws@7.2.1 requires a peer of bufferutil@^4.0.1 but none is installed. You must install peer dependencies yourself.
    npm WARN ws@7.2.1 requires a peer of utf-8-validate@^5.0.2 but none is installed. You must install peer dependencies yourself.
    npm ERR! path /opt/iobroker/node_modules/chokidar/node_modules/fsevents
    npm ERR! code EACCES
    npm ERR! errno -13
    npm ERR! syscall access
    npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/chokidar/node_modules/fsevents'
    npm ERR! { [Error: EACCES: permission denied, access '/opt/iobroker/node_modules/chokidar/node_modules/fsevents']
    npm ERR! stack:
    npm ERR! 'Error: EACCES: permission denied, access '/opt/iobroker/node_modules/chokidar/node_modules/fsevents'',
    npm ERR! errno: -13,
    npm ERR! code: 'EACCES',
    npm ERR! syscall: 'access',
    npm ERR! path: '/opt/iobroker/node_modules/chokidar/node_modules/fsevents' }
    npm ERR!
    npm ERR! The operation was rejected by your operating system.
    npm ERR! It is likely you do not have the permissions to access this file as the current user
    npm ERR!
    npm ERR! If you believe this might be a permissions issue, please double-check the
    npm ERR! permissions of the file and its containing directories, or try running
    npm ERR! the command again as root/Administrator (though this is not recommended).
    npm ERR! /home/pi/.npm/_logs/2020-04-28T10_11_11_846Z-debug.log
    und jetzt hab ich glaube ich noch ein größeres Problem:
    pi@ioBroker-RasPi4:/opt/iobroker $ sudo iobroker update
    internal/modules/cjs/loader.js:638
    throw err;
    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iob roker.js'
    at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
    at Function.Module._load (internal/modules/cjs/loader.js:562:25)
    at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
    at startup (internal/bootstrap/node.js:283:19)
    at bootstrapNodeJSCore (internal/bootstrap/node.js:622:3)
    arteckA Offline
    arteckA Offline
    arteck
    @smart-home lass den fixer drüber laufen dann nochma update
    • arteckA arteck
      @arteck
      pi@ioBroker-RasPi4:/opt/iobroker $ curl -sL https://iobroker.net/fix.sh | bash -
      library: loaded
      Library version=2020-04-12
      ioBroker is not installed in /opt/iobroker! Cannot fix anything...
        @arteck
        library: loaded
        arteckA Offline
        arteckA Offline
        arteck
        @smart-home
        dann Brechstange
        sudo -H -u iobroker npm install ioBroker/ioBroker.js-controller
        • arteckA arteck
          @smart-home
          dann Brechstange
          @arteck in /opt/iobroker Verzeichnis oder ohne Verzeichnis?
            @smart-home Npm Befehle immer im ioBroekr Verzeicvhnis
            • ? Offline
              Brechstange war erfolgreich!!! Vielen Dank!
              IoBroker wieder online .... kein Datenverlust... und auf Version 3.0.20.
              Vielen Dank! Ich hatte mich schon auf einen langen Nachmittag der Neuinstallation und Wiederherstellung gefreut🙄
              BBTownB 1 Antwort Letzte Antwort
                BBTownB Offline
                BBTownB Offline
                BBTown
                schrieb am zuletzt editiert von BBTown
                @smart-home aber nicht doch, Du arbeitest doch 100%ig mit Backups, oder? 😎
                • ? Offline
                  Jupp mache ich. Hab extra auf den Server geschaut 👀 letztes Backup 26.04 wäre also alles ok....
                  Bin trozdem FROH
                  • apollon77A apollon77
                    3.0.20 ist auf npm und kommt jetzt bald ins latest. Imzweifel bitte IM ioBroker VERZEICHNIS !!!! per "npm install iobroker.js-controller@3.0.20" installieren
                    f0rd42
                    @apollon77 Prima, läuft wieder, vielen dank!
                      MarkusW27
                      Bei geht´s auch wieder! Danke für die schnelle Reaktion / Fix!
                      • F Offline
                        funbert
                        Danke auch von meiner Seite. Läuft wieder.
                          Berchemer
                          Brechstange hat es auch bei mir gelöst. Zumindest kommen keine Fehlermeldungen mehr und die Slaves sind auch wieder dauerhaft anwesend und nicht in Form einer ON-OFF-Beziehung 😁
                          • B Berchemer
                            Berchemer
                            @Berchemer sagte in [gelöst] js-controller 3.0.19 upgrade Fehler - Iobroker tot:
                            Btw... Auf dem Master mit Mint 19.3 hat es der Brechstange nicht bedurft. Da hat die v3.0.20 einfach funktioniert und konnte ordentlich installiert werden.
                            Probleme - und den dadurch notwendigen Brechstangeneinsatz - hatte ich nur mit den RaspBerry-Buster-Slaves!
                            • haselchenH haselchen
                              @Schuchty
                              Guck mal hier
                              https://forum.iobroker.net/topic/32731/js-controller-upgrade-fehler-iobroker-tot
                              @Negalein
                              führe die Threads mal bitte zusammen :)
                              NegaleinN Offline
                              NegaleinN Offline
                              Negalein
                              @haselchen sagte in [gelöst] js-controller 3.0.19 upgrade Fehler - Iobroker tot:
                              @Negalein
                              Erledigt :)
                              ° Fixer ---> iob fix
                              • B Berchemer
                                AlCalzoneA Offline
                                AlCalzoneA Offline
                                AlCalzone
                                Dann hast du dir da wohl die Berechtigungen nicht zerschossen :)
                                EACCES-Fehler kommen zu 99% durch unbedarfte Nutzung von sudo (siehe auch meine Signatur). Lass einfach im ioBroker-Umfeld sudo weg und es sollte nicht mehr passieren.
                                ? B 2 Antworten Letzte Antwort
                                • AlCalzoneA AlCalzone
                                  @AlCalzone
                                  Da kann ich dich nur bestätigen, ich hatte ebenfalls mir "sudo" gearbeitet😕.
                                  Werde es mir merken...kommt in Zukunft nicht mehr vor. Wieder was gelernt😬
                                    Berchemer
                                    @AlCalzone sagte in [gelöst] js-controller 3.0.19 upgrade Fehler - Iobroker tot:
                                    Als ich jedoch die Tage OHNE sudo den BLE updaten wollte, hat es nur Ärger gegeben, weshalb ich zuletzt den BLE komplett deinstallieren und dann neu installieren musste, bis die Fehlermeldungen im Log aufgehört haben 🤕
                                    Daher wollte ich hierbei den Fehler nicht erneut begehen 😨
                                    • B Berchemer
                                      Berchemer
                                      Unabhängig davon stellte sich mir schon immer die Frage, wann mit sudo und wann ohne sudo stops und updates und upgrades von iobroker durchführen. Und dann als Erweiterung noch die Frage nach dem sudo oder nicht bei node-js usw...
                                      Auch wenn ich schon länger mit Linux arbeite, habe ich bis dato immer noch nicht ansastzweise verstanden, wann ich im Zusammenhang mit ioBroker sudo verwenden muss oder nicht. Insbesondere weil das Handling sich zwischen Mint und Buster (oder ist es Ubuntu und Debian??? oder was auch immer) zu unterscheiden scheint. Zumindest habe ich das "Gefühl", dass es so ist, weil ich nicht unbedingt zu denen gehöre, die jeden Befehlsschritt auf den unterschiedlichen Betriebssystemen akribisch erfassen und im Nachhinein auswerten ;-)
                                      Aber vielleicht ist auch das mein Problem unter den unterschiedlichen Linuxsystemen allgemein...
                                      Ich lerne wirklich gerne dazu :-)
                                      • B Berchemer
                                        AlCalzoneA Offline
                                        AlCalzoneA Offline
                                        AlCalzone
                                        @Berchemer System-Updates (z.B. nodejs) brauchen zum Teil sudo. ioBroker nicht bzw. macht das selbstständig, wenn es benötigt wird. Außer man muss irgendwas gerade biegen, was verpfuscht ist.
                                        Ohne die exakte Meldung zu kennen müsste ich jetzt in die Glaskugel schauen. Ich habe schon seit längerem keine Probleme mehr mit Berechtigungen, deswegen vermute ich, dass da vorher schon was im Argen war.
