  4. [WLED] LED streifen (WS2812B,WS2811,SK6812,APA102) bedienen
    apollon77A
adapateradapterneu hiertesttestentesterwled
655 Beiträge 73 Kommentatoren 271.4k Aufrufe 79 Beobachtet
  • liv-in-skyL liv-in-sky
    @Chaot bin mir nicht mehr sicher- aber ich glaube ich habe die 0.9.0 version geflsht, weil die 0.9.1 nicht lief - irgendetwas war da
    ChaotC
    ChaotC
    Chaot
    #143
    @liv-in-sky @Dutchman
    Ich denke mal das das mit der 0.9.1 zusammenhängt.
    Hier mal ein Auszug aus dem Debug:
    wled.0	2020-03-02 22:57:19.856	debug	(14947) Create_state called for : info.connection with value : true
    wled.0	2020-03-02 22:57:19.849	error	(14947) Read Data error : TypeError: Cannot read property 'info' of null
    wled.0	2020-03-02 22:57:19.843	debug	(14947) "API response data : null"
    wled.0	2020-03-02 22:57:19.840	debug	(14947) Datatype : boolean
    wled.0	2020-03-02 22:57:19.839	debug	(14947) Write value : false
    wled.0	2020-03-02 22:57:19.839	debug	(14947) Create_state called for : 68c63aea1b7e._info.leds.seglock with value : false
    wled.0	2020-03-02 22:57:19.839	debug	(14947) State created : seglock : false
    wled.0	2020-03-02 22:57:19.838	debug	(14947) Write value : false
    wled.0	2020-03-02 22:57:19.838	debug	(14947) Create_state called for : 68c63aea1b7e._info.leds.maxseg with value : 10
    wled.0	2020-03-02 22:57:19.837	debug	(14947) State created : maxseg : 10
    wled.0	2020-03-02 22:57:19.837	debug	(14947) Write value : false
    wled.0	2020-03-02 22:57:19.836	debug	(14947) Create_state called for : 68c63aea1b7e._info.leds.maxpwr with value : 850
    wled.0	2020-03-02 22:57:19.836	debug	(14947) State created : maxpwr : 850
    wled.0	2020-03-02 22:57:19.835	debug	(14947) Write value : false
    wled.0	2020-03-02 22:57:19.835	debug	(14947) Create_state called for : 68c63aea1b7e._info.leds.pwr with value : 140
    wled.0	2020-03-02 22:57:19.834	debug	(14947) State created : pwr : 140
    wled.0	2020-03-02 22:57:19.834	debug	(14947) Write value : false
    wled.0	2020-03-02 22:57:19.833	debug	(14947) Create_state called for : 68c63aea1b7e._info.leds.pin with value : 2
    wled.0	2020-03-02 22:57:19.833	debug	(14947) State created : pin : [2]
    wled.0	2020-03-02 22:57:19.832	debug	(14947) Write value : false
    wled.0	2020-03-02 22:57:19.832	debug	(14947) Create_state called for : 68c63aea1b7e._info.leds.wv with value : false
    wled.0	2020-03-02 22:57:19.831	debug	(14947) State created : wv : false
    wled.0	2020-03-02 22:57:19.830	debug	(14947) Write value : false
    wled.0	2020-03-02 22:57:19.830	debug	(14947) Create_state called for : 68c63aea1b7e._info.leds.rgbw with value : false
    wled.0	2020-03-02 22:57:19.830	debug	(14947) State created : rgbw : false
    wled.0	2020-03-02 22:57:19.828	debug	(14947) Write value : false
    wled.0	2020-03-02 22:57:19.828	debug	(14947) Create_state called for : 68c63aea1b7e._info.leds.count with value : 40
    wled.0	2020-03-02 22:57:19.827	debug	(14947) State created : count : 40
    wled.0	2020-03-02 22:57:19.824	debug	(14947) Data received from WLED device 3c71bf29273b : {"state":{"on":true,"bri":38,"transition":7,"ps":-1,"pss":0,"pl":-1,"ccnf":{"min":1,"max":5,"time":12},"nl":{"on":false,"dur":60,"fade":true,"tbri
    wled.0	2020-03-02 22:57:19.823	debug	(14947) "API response data : [object Object]"
    wled.0	2020-03-02 22:57:19.821	debug	(14947) Datatype : object
    wled.0	2020-03-02 22:57:19.820	debug	(14947) Write value : false
    wled.0	2020-03-02 22:57:19.820	debug	(14947) Create_state called for : 68c63aea1b7e._info.vid with value : 2002222
    wled.0	2020-03-02 22:57:19.819	debug	(14947) State created : vid : 2002222
    wled.0	2020-03-02 22:57:19.816	debug	(14947) Datatype : number
    wled.0	2020-03-02 22:57:19.815	debug	(14947) Write value : false
    wled.0	2020-03-02 22:57:19.815	debug	(14947) Create_state called for : 68c63aea1b7e._info.ver with value : 0.9.1
    wled.0	2020-03-02 22:57:19.815	debug	(14947) State created : ver : "0.9.1"
    wled.0	2020-03-02 22:57:19.811	debug	(14947) Datatype : string
    wled.0	2020-03-02 22:57:19.808	debug	(14947) Write value : true
    wled.0	2020-03-02 22:57:19.807	debug	(14947) Create_state called for : 68c63aea1b7e._info._online with value : true
    wled.0	2020-03-02 22:57:19.803	error	(14947) Read Data error : TypeError: Cannot read property 'info' of null
    wled.0	2020-03-02 22:57:19.802	debug	(14947) "API response data : null"
    wled.0	2020-03-02 22:57:19.801	error	(14947) Read Data error : TypeError: Cannot read property 'info' of null
    wled.0	2020-03-02 22:57:19.800	debug	(14947) "API response data : null"
    wled.0	2020-03-02 22:57:19.798	debug	(14947) Write value : true
    wled.0	2020-03-02 22:57:19.797	debug	(14947) Create_state called for : info.connection with value : true
    wled.0	2020-03-02 22:57:19.788	debug	(14947) Data received from WLED device 68c63aea1b7e : {"state":{"on":true,"bri":86,"transition":7,"ps":-1,"pss":1023,"pl":-1,"ccnf":{"min":1,"max":5,"time":12},"nl":{"on":false,"dur":60,"fade":true,"t
    wled.0	2020-03-02 22:57:19.787	debug	(14947) "API response data : [object Object]"
    wled.0	2020-03-02 22:57:19.750	debug	(14947) Devices array from bonjour scan : {"192.168.8.189":"68c63aea1b7e","192.168.8.186":"3c71bf29273b","192.168.8.185":"cc50e304f753"}
    wled.0	2020-03-02 22:57:19.750	debug	(14947) Getting data for cc50e304f753
    wled.0	2020-03-02 22:57:19.750	debug	(14947) Getting data for 3c71bf29273b
    wled.0	2020-03-02 22:57:19.749	debug	(14947) Getting data for 68c63aea1b7e
    wled.0	2020-03-02 22:57:19.749	debug	(14947) polling timer for devices : {"192.168.8.189":"68c63aea1b7e","192.168.8.186":"3c71bf29273b","192.168.8.185":"cc50e304f753"}
    • B bishop
      wled läuft bei mir, jetzt würde ich sie gerne in den iobroker bekommen.
      Mit dem Adapter tut sich aber leider nichts bekomme nur eine fehlermeldung.
      im Adapter habe ich keine Möglichkeit etwas einzutragen.
      @Dutchman vielen dank das mit den Segmenten sollte funktionieren nur 10 sind etwas zuwenig für meine Treppenstufen.
      Habe aber auf Github schon das issue gesehene das einer mehr möchte es aber wegen beschränkung des Rams leider nicht geht wenn ich das richtig verstanden habe.
      wonach sucht er Automatisch, fehlt eine Einstellung in der WLed Gui?
      DutchmanD
      DutchmanD
      Dutchman
      #144
      @bishop sagte in [WLED] LED streifen (WS2812B,WS2811,SK6812,APA102) bedienen:
      er such nach dem DNS bonjour service, sicher das du dir richtige Firmware version drauf hast von WLED ?
      • ChaotC Chaot
        DutchmanD
        DutchmanD
        Dutchman
        #145
        @Chaot sagte in [WLED] LED streifen (WS2812B,WS2811,SK6812,APA102) bedienen:
        hmm danke, ich schau es mir nachher mal an die version ist 9 Tage alt viellicht hat Aircookie da doch was geändert.
        • DutchmanD Dutchman
          M
          M
          mtaxer
          #146
          @Dutchman Version 0.9.1 läuft bei mir problemlos mit deiner aktuellen Adapterversion
          SG
          Mario
          • M mtaxer
            SG
            Mario
            DutchmanD
            DutchmanD
            Dutchman
            #147
            @bigd-73 sagte in [WLED] LED streifen (WS2812B,WS2811,SK6812,APA102) bedienen:
            welche 0.9.1, rc1 .... rc2 oder. die vor 9 Tagen released wurde ?
            M ChaotC 2 Antworten Letzte Antwort
              M
              M
              mtaxer
              schrieb am zuletzt editiert von mtaxer
              #148
              @Dutchman ok, da gibts verschiedene ... diese hier: https://github.com/Aircoookie/WLED/releases
              Also die vor 10 Tagen wie ich gerade sehe.
                ChaotC
                ChaotC
                Chaot
                schrieb am zuletzt editiert von Chaot
                #149
                @Dutchman Oh, dann nutze ich vermutlich zwei verschieden Versionen der 0.9.1.
                Die Deckenlichter habe ich gleich am Erscheinungstag geflasht und den letzten Streifen erst gestern.
                Ich kann aber mal versuchen den neuen Streifen mit der anderen Version zu flashen um zu schauen ob das was ändert.
                Edit:
                Der Fehler ist noch da:
                wled.0	2020-03-03 19:58:13.891	error	(738) Read Data error : TypeError: Cannot read property 'info' of undefined
                wled.0	2020-03-03 19:55:52.158	error	(738) Read Data error : TypeError: Cannot read property 'info' of null
                wled.0	2020-03-03 19:55:52.139	error	(738) Read Data error : TypeError: Cannot read property 'info' of null
                wled.0	2020-03-03 19:55:51.995	warn	(738) State attribute definition missing for + Connection
                host.ioBroker	2020-03-03 19:55:50.435	info	instance system.adapter.wled.0 started with pid 738
                • B
                  B
                  bishop
                  #150
                  @Dutchman also bei mir funktioniert nur die "WLED_0.9.0-b1_ESP8266.bin"
                  die 0.9.1 wird nicht erkannt von dem Adapter!
                  E 1 Antwort Letzte Antwort
                  • B bishop
                    E
                    E
                    e-s
                    #151
                    @bishop @Chaot
                    hatte damals mit der 0.9.0-b1 angefangen und vor 2 Tagen per OTA auf 0.9.1, hatte bisher keine Fehlermeldungen. Läuft alles so wie es soll.
                    • B
                      B
                      bishop
                      #152
                      kann ich bestätigen nach update von 0.9.0 auf 0.9.1 funktioniert es bei mir auch.
                      Direkt mit 0.9.1 ging es nicht!
                      • B bishop
                        DutchmanD
                        DutchmanD
                        Dutchman
                        #153
                        danke wichtige info für die analyse.
                          ChaotC
                          ChaotC
                          Chaot
                          #154
                          @Dutchman
                          Ich bin jetzt mit dem neuen Streifen auf 0.9.0 runter.
                          wled.0	2020-03-03 21:29:30.457	error	(26393) Read Data error : TypeError: Cannot read property 'info' of undefined
                          wled.0	2020-03-03 21:29:22.941	error	(26393) Read Data error : TypeError: Cannot read property 'info' of undefined
                          wled.0	2020-03-03 21:29:15.078	error	(26393) Read Data error : TypeError: Cannot read property 'info' of undefined
                          wled.0	2020-03-03 21:28:59.618	error	(26393) Read Data error : TypeError: Cannot read property 'info' of undefined
                          wled.0	2020-03-03 21:28:13.806	error	(26393) Read Data error : TypeError: Cannot read property 'info' of undefined
                          wled.0	2020-03-03 21:26:36.651	error	(26393) Read Data error : TypeError: Cannot read property 'info' of null
                          wled.0	2020-03-03 21:26:36.643	error	(26393) Read Data error : TypeError: Cannot read property 'info' of null
                          wled.0	2020-03-03 21:26:36.426	warn	(26393) State attribute definition missing for + Connection
                          host.ioBroker	2020-03-03 21:26:35.035	info	instance system.adapter.wled.0 started with pid 26393
                          21:26 Adapterstart
                          21:28 auf WLED Instanz Schraubenschlüssel (ohne Veränderungen)
                          21:29 In Objekte den Datenpunkt "wled.0.cc50e304f753.seg.0.ix" geschrieben (mehrfach und jedes mal Fehler im LOG
                          Jetzt lange Pause ohne Fehler im Log.
                          Nochmal Datenpunkt geschrieben und
                          wled.0	2020-03-03 21:34:47.355	error	(26393) Read Data error : TypeError: Cannot read property 'info' of undefined
                          Der Fehler wird bei allen Stripes gesetzt. Jedes mal wenn ich einen Datenpunkt manuell schreibe.
                          Update:
                          Ich kann jetzt sicher nachvollziehen das dieFehlermeldung nur beim Schreiben eines Datenpunkts kommt.
                          • B
                            B
                            bishop
                            #155
                            @Chaot @Dutchman
                            kann ich bestätigen, es läuft alles. Wenn man aber ein DP schreiben möchte bekommt man diese Fehlermeldung.
                            • S
                              S
                              stefande
                              schrieb am zuletzt editiert von stefande
                              #156
                              Mal eine blöde Frage:
                              Instructions
                              3. Configure intervall times for data polling and auto-detect cyclus
                              5. Adapter will send changes immediatly and polls data every x seconds (configurable)
                              Wo können die oben genannten Parameter eingestellt werden?
                              • S stefande
                                Instructions
                                DutchmanD
                                DutchmanD
                                Dutchman
                                #157
                                @stefande sagte in [WLED] LED streifen (WS2812B,WS2811,SK6812,APA102) bedienen:
                                noch nirgendwo sind momentan hard coded kommt später als state bei info
                                • B bishop
                                  @Chaot @Dutchman
                                  DutchmanD
                                  DutchmanD
                                  Dutchman
                                  #158
                                  mit der neuen Firmware ? ... ok mist... hab ich was zu. tun
                                    S
                                    S
                                    stefande
                                    #159
                                    @Dutchman sagte in [WLED] LED streifen (WS2812B,WS2811,SK6812,APA102) bedienen:
                                    Danke für die Rückmeldung. Hab schon gedacht ich bin blind.
                                    Ist das denn normal, dass es knapp 30 Sekunden dauert bis ich die "Ein Rückmeldung" bekomme?
                                    • H
                                      H
                                      HomeTed
                                      #160
                                      welche LED Streifen lassen sich alles mit WLED steuern, gibt es da irgendwo eine Übersicht?
                                      Ich suche die Eierlegende Wollmilchsau, RGB aber auch warmes & kaltes Weiß, wenn ich das richtig sehe wäre das zum Beispiel ein LED Streifen SK6812. Kann ich diesen Streifen auch komplett mit WLED steuern?
                                        E
                                        E
                                        e-s
                                        #161
                                        @Dutchman @bishop @Chaot
                                        habe bei mir auch nochmal geschaut, bei mir gibt es keine errors im log beim ändern.
                                        • E e-s
                                          ChaotC
                                          ChaotC
                                          Chaot
                                          #162
                                          @e-s WelcHe Version hast du
                                          WLED Firmware:
                                          Admin Adapter:
                                          Script Engine:
                                          Ich vermute das das auch mit dem Admin Adpter zusammenhängen könnte, da ich auch bei einem anderen Adpter Probleme habe eigene Datenpunkte zu schreiben.
                                          WLED Firmware: 0.9.1
                                          Admin Adapter: 4.0.5
                                          Script Engine: 4.4.2
                                          84.0k
