  4. [WLED] LED streifen (WS2812B,WS2811,SK6812,APA102) bedienen
adapateradapterneu hiertesttestentesterwled
655 Beiträge 73 Kommentatoren 263.1k Aufrufe 79 Beobachtet
  • ChaotC Chaot
    @Dutchman
    Ich habe den Adapter gestern abgeschaltet weil ich nicht das ganze log voll haben wollte.
    Aktuell sieht es nach dem Start so aus:
    wled.0	2020-03-02 21:59:49.421	error	(9307) Read Data error : TypeError: Cannot read property 'info' of null
    wled.0	2020-03-02 21:59:18.699	error	(9307) Read Data error : TypeError: Cannot read property 'info' of null
    wled.0	2020-03-02 21:58:26.858	error	(9307) Read Data error : TypeError: Cannot read property 'info' of undefined
    wled.0	2020-03-02 21:58:12.896	error	(9307) Read Data error : TypeError: Cannot read property 'info' of undefined
    wled.0	2020-03-02 21:57:44.763	info	(9307) Devices array from bonjour scan : {"192.168.8.189":"68c63aea1b7e","192.168.8.186":"3c71bf29273b","192.168.8.185":"cc50e304f753","192.168.8.188":"246f28b4865c"}
    wled.0	2020-03-02 21:57:44.763	info	(9307) Device wled-b4865c found on IP 192.168.8.188
    wled.0	2020-03-02 21:57:44.676	error	(9307) Read Data error : TypeError: Cannot read property 'info' of null
    wled.0	2020-03-02 21:57:44.670	error	(9307) Read Data error : TypeError: Cannot read property 'info' of null
    wled.0	2020-03-02 21:57:44.634	info	(9307) Devices array from bonjour scan : {"192.168.8.189":"68c63aea1b7e","192.168.8.186":"3c71bf29273b","192.168.8.185":"cc50e304f753"}
    wled.0	2020-03-02 21:57:44.633	info	(9307) Device wled-04f753 found on IP 192.168.8.185
    wled.0	2020-03-02 21:57:44.629	info	(9307) Devices array from bonjour scan : {"192.168.8.189":"68c63aea1b7e","192.168.8.186":"3c71bf29273b"}
    wled.0	2020-03-02 21:57:44.628	info	(9307) Device wled-29273b found on IP 192.168.8.186
    wled.0	2020-03-02 21:57:44.606	info	(9307) Devices array from bonjour scan : {"192.168.8.189":"68c63aea1b7e"}
    wled.0	2020-03-02 21:57:44.605	info	(9307) Device wled-ea1b7e found on IP 192.168.8.189
    wled.0	2020-03-02 21:57:44.554	warn	(9307) State attribute definition missing for + Connection
    wled.0	2020-03-02 21:57:44.517	info	(9307) starting. Version 0.1.5 in /opt/iobroker/node_modules/iobroker.wled, node: v10.19.0
    Adapter ist gün und alle aktiven Controler sind vorhanden.
    liv-in-skyL
    liv-in-skyL
    #142
    @Chaot bin mir nicht mehr sicher- aber ich glaube ich habe die 0.9.0 version geflsht, weil die 0.9.1 nicht lief - irgendetwas war da
    • liv-in-skyL liv-in-sky
      ChaotC
      ChaotC
      Chaot
      #143
      @liv-in-sky @Dutchman
      Ich denke mal das das mit der 0.9.1 zusammenhängt.
      Hier mal ein Auszug aus dem Debug:
      wled.0	2020-03-02 22:57:19.856	debug	(14947) Create_state called for : info.connection with value : true
      wled.0	2020-03-02 22:57:19.849	error	(14947) Read Data error : TypeError: Cannot read property 'info' of null
      wled.0	2020-03-02 22:57:19.843	debug	(14947) "API response data : null"
      wled.0	2020-03-02 22:57:19.840	debug	(14947) Datatype : boolean
      wled.0	2020-03-02 22:57:19.839	debug	(14947) Write value : false
      wled.0	2020-03-02 22:57:19.839	debug	(14947) Create_state called for : 68c63aea1b7e._info.leds.seglock with value : false
      wled.0	2020-03-02 22:57:19.839	debug	(14947) State created : seglock : false
      wled.0	2020-03-02 22:57:19.838	debug	(14947) Write value : false
      wled.0	2020-03-02 22:57:19.838	debug	(14947) Create_state called for : 68c63aea1b7e._info.leds.maxseg with value : 10
      wled.0	2020-03-02 22:57:19.837	debug	(14947) State created : maxseg : 10
      wled.0	2020-03-02 22:57:19.837	debug	(14947) Write value : false
      wled.0	2020-03-02 22:57:19.836	debug	(14947) Create_state called for : 68c63aea1b7e._info.leds.maxpwr with value : 850
      wled.0	2020-03-02 22:57:19.836	debug	(14947) State created : maxpwr : 850
      wled.0	2020-03-02 22:57:19.835	debug	(14947) Write value : false
      wled.0	2020-03-02 22:57:19.835	debug	(14947) Create_state called for : 68c63aea1b7e._info.leds.pwr with value : 140
      wled.0	2020-03-02 22:57:19.834	debug	(14947) State created : pwr : 140
      wled.0	2020-03-02 22:57:19.834	debug	(14947) Write value : false
      wled.0	2020-03-02 22:57:19.833	debug	(14947) Create_state called for : 68c63aea1b7e._info.leds.pin with value : 2
      wled.0	2020-03-02 22:57:19.833	debug	(14947) State created : pin : [2]
      wled.0	2020-03-02 22:57:19.832	debug	(14947) Write value : false
      wled.0	2020-03-02 22:57:19.832	debug	(14947) Create_state called for : 68c63aea1b7e._info.leds.wv with value : false
      wled.0	2020-03-02 22:57:19.831	debug	(14947) State created : wv : false
      wled.0	2020-03-02 22:57:19.830	debug	(14947) Write value : false
      wled.0	2020-03-02 22:57:19.830	debug	(14947) Create_state called for : 68c63aea1b7e._info.leds.rgbw with value : false
      wled.0	2020-03-02 22:57:19.830	debug	(14947) State created : rgbw : false
      wled.0	2020-03-02 22:57:19.828	debug	(14947) Write value : false
      wled.0	2020-03-02 22:57:19.828	debug	(14947) Create_state called for : 68c63aea1b7e._info.leds.count with value : 40
      wled.0	2020-03-02 22:57:19.827	debug	(14947) State created : count : 40
      wled.0	2020-03-02 22:57:19.824	debug	(14947) Data received from WLED device 3c71bf29273b : {"state":{"on":true,"bri":38,"transition":7,"ps":-1,"pss":0,"pl":-1,"ccnf":{"min":1,"max":5,"time":12},"nl":{"on":false,"dur":60,"fade":true,"tbri
      wled.0	2020-03-02 22:57:19.823	debug	(14947) "API response data : [object Object]"
      wled.0	2020-03-02 22:57:19.821	debug	(14947) Datatype : object
      wled.0	2020-03-02 22:57:19.820	debug	(14947) Write value : false
      wled.0	2020-03-02 22:57:19.820	debug	(14947) Create_state called for : 68c63aea1b7e._info.vid with value : 2002222
      wled.0	2020-03-02 22:57:19.819	debug	(14947) State created : vid : 2002222
      wled.0	2020-03-02 22:57:19.816	debug	(14947) Datatype : number
      wled.0	2020-03-02 22:57:19.815	debug	(14947) Write value : false
      wled.0	2020-03-02 22:57:19.815	debug	(14947) Create_state called for : 68c63aea1b7e._info.ver with value : 0.9.1
      wled.0	2020-03-02 22:57:19.815	debug	(14947) State created : ver : "0.9.1"
      wled.0	2020-03-02 22:57:19.811	debug	(14947) Datatype : string
      wled.0	2020-03-02 22:57:19.808	debug	(14947) Write value : true
      wled.0	2020-03-02 22:57:19.807	debug	(14947) Create_state called for : 68c63aea1b7e._info._online with value : true
      wled.0	2020-03-02 22:57:19.803	error	(14947) Read Data error : TypeError: Cannot read property 'info' of null
      wled.0	2020-03-02 22:57:19.802	debug	(14947) "API response data : null"
      wled.0	2020-03-02 22:57:19.801	error	(14947) Read Data error : TypeError: Cannot read property 'info' of null
      wled.0	2020-03-02 22:57:19.800	debug	(14947) "API response data : null"
      wled.0	2020-03-02 22:57:19.798	debug	(14947) Write value : true
      wled.0	2020-03-02 22:57:19.797	debug	(14947) Create_state called for : info.connection with value : true
      wled.0	2020-03-02 22:57:19.788	debug	(14947) Data received from WLED device 68c63aea1b7e : {"state":{"on":true,"bri":86,"transition":7,"ps":-1,"pss":1023,"pl":-1,"ccnf":{"min":1,"max":5,"time":12},"nl":{"on":false,"dur":60,"fade":true,"t
      wled.0	2020-03-02 22:57:19.787	debug	(14947) "API response data : [object Object]"
      wled.0	2020-03-02 22:57:19.750	debug	(14947) Devices array from bonjour scan : {"192.168.8.189":"68c63aea1b7e","192.168.8.186":"3c71bf29273b","192.168.8.185":"cc50e304f753"}
      wled.0	2020-03-02 22:57:19.750	debug	(14947) Getting data for cc50e304f753
      wled.0	2020-03-02 22:57:19.750	debug	(14947) Getting data for 3c71bf29273b
      wled.0	2020-03-02 22:57:19.749	debug	(14947) Getting data for 68c63aea1b7e
      wled.0	2020-03-02 22:57:19.749	debug	(14947) polling timer for devices : {"192.168.8.189":"68c63aea1b7e","192.168.8.186":"3c71bf29273b","192.168.8.185":"cc50e304f753"}
      • B bishop
        wled läuft bei mir, jetzt würde ich sie gerne in den iobroker bekommen.
        Mit dem Adapter tut sich aber leider nichts bekomme nur eine fehlermeldung.
        im Adapter habe ich keine Möglichkeit etwas einzutragen.
        @Dutchman vielen dank das mit den Segmenten sollte funktionieren nur 10 sind etwas zuwenig für meine Treppenstufen.
        Habe aber auf Github schon das issue gesehene das einer mehr möchte es aber wegen beschränkung des Rams leider nicht geht wenn ich das richtig verstanden habe.
        wonach sucht er Automatisch, fehlt eine Einstellung in der WLed Gui?
        DutchmanD
        DutchmanD
        Dutchman
        #144
        @bishop sagte in [WLED] LED streifen (WS2812B,WS2811,SK6812,APA102) bedienen:
        er such nach dem DNS bonjour service, sicher das du dir richtige Firmware version drauf hast von WLED ?
        • ChaotC Chaot
          DutchmanD
          DutchmanD
          Dutchman
          #145
          @Chaot sagte in [WLED] LED streifen (WS2812B,WS2811,SK6812,APA102) bedienen:
          hmm danke, ich schau es mir nachher mal an die version ist 9 Tage alt viellicht hat Aircookie da doch was geändert.
          • DutchmanD Dutchman
            M
            M
            mtaxer
            #146
            @Dutchman Version 0.9.1 läuft bei mir problemlos mit deiner aktuellen Adapterversion
            SG
            Mario
            • M mtaxer
              SG
              Mario
              DutchmanD
              DutchmanD
              Dutchman
              #147
              @bigd-73 sagte in [WLED] LED streifen (WS2812B,WS2811,SK6812,APA102) bedienen:
              welche 0.9.1, rc1 .... rc2 oder. die vor 9 Tagen released wurde ?
              M ChaotC 2 Antworten Letzte Antwort
                M
                M
                mtaxer
                schrieb am zuletzt editiert von mtaxer
                #148
                @Dutchman ok, da gibts verschiedene ... diese hier: https://github.com/Aircoookie/WLED/releases
                Also die vor 10 Tagen wie ich gerade sehe.
                  ChaotC
                  ChaotC
                  Chaot
                  schrieb am zuletzt editiert von Chaot
                  #149
                  @Dutchman Oh, dann nutze ich vermutlich zwei verschieden Versionen der 0.9.1.
                  Die Deckenlichter habe ich gleich am Erscheinungstag geflasht und den letzten Streifen erst gestern.
                  Ich kann aber mal versuchen den neuen Streifen mit der anderen Version zu flashen um zu schauen ob das was ändert.
                  Edit:
                  Der Fehler ist noch da:
                  wled.0	2020-03-03 19:58:13.891	error	(738) Read Data error : TypeError: Cannot read property 'info' of undefined
                  wled.0	2020-03-03 19:55:52.158	error	(738) Read Data error : TypeError: Cannot read property 'info' of null
                  wled.0	2020-03-03 19:55:52.139	error	(738) Read Data error : TypeError: Cannot read property 'info' of null
                  wled.0	2020-03-03 19:55:51.995	warn	(738) State attribute definition missing for + Connection
                  host.ioBroker	2020-03-03 19:55:50.435	info	instance system.adapter.wled.0 started with pid 738
                  • B
                    B
                    bishop
                    #150
                    @Dutchman also bei mir funktioniert nur die "WLED_0.9.0-b1_ESP8266.bin"
                    die 0.9.1 wird nicht erkannt von dem Adapter!
                    E 1 Antwort Letzte Antwort
                    • B bishop
                      E
                      E
                      e-s
                      #151
                      @bishop @Chaot
                      hatte damals mit der 0.9.0-b1 angefangen und vor 2 Tagen per OTA auf 0.9.1, hatte bisher keine Fehlermeldungen. Läuft alles so wie es soll.
                      • B
                        B
                        bishop
                        #152
                        kann ich bestätigen nach update von 0.9.0 auf 0.9.1 funktioniert es bei mir auch.
                        Direkt mit 0.9.1 ging es nicht!
                        • B bishop
                          DutchmanD
                          DutchmanD
                          Dutchman
                          #153
                          danke wichtige info für die analyse.
                            ChaotC
                            ChaotC
                            Chaot
                            #154
                            @Dutchman
                            Ich bin jetzt mit dem neuen Streifen auf 0.9.0 runter.
                            wled.0	2020-03-03 21:29:30.457	error	(26393) Read Data error : TypeError: Cannot read property 'info' of undefined
                            wled.0	2020-03-03 21:29:22.941	error	(26393) Read Data error : TypeError: Cannot read property 'info' of undefined
                            wled.0	2020-03-03 21:29:15.078	error	(26393) Read Data error : TypeError: Cannot read property 'info' of undefined
                            wled.0	2020-03-03 21:28:59.618	error	(26393) Read Data error : TypeError: Cannot read property 'info' of undefined
                            wled.0	2020-03-03 21:28:13.806	error	(26393) Read Data error : TypeError: Cannot read property 'info' of undefined
                            wled.0	2020-03-03 21:26:36.651	error	(26393) Read Data error : TypeError: Cannot read property 'info' of null
                            wled.0	2020-03-03 21:26:36.643	error	(26393) Read Data error : TypeError: Cannot read property 'info' of null
                            wled.0	2020-03-03 21:26:36.426	warn	(26393) State attribute definition missing for + Connection
                            host.ioBroker	2020-03-03 21:26:35.035	info	instance system.adapter.wled.0 started with pid 26393
                            21:26 Adapterstart
                            21:28 auf WLED Instanz Schraubenschlüssel (ohne Veränderungen)
                            21:29 In Objekte den Datenpunkt "wled.0.cc50e304f753.seg.0.ix" geschrieben (mehrfach und jedes mal Fehler im LOG
                            Jetzt lange Pause ohne Fehler im Log.
                            Nochmal Datenpunkt geschrieben und
                            wled.0	2020-03-03 21:34:47.355	error	(26393) Read Data error : TypeError: Cannot read property 'info' of undefined
                            Der Fehler wird bei allen Stripes gesetzt. Jedes mal wenn ich einen Datenpunkt manuell schreibe.
                            Update:
                            Ich kann jetzt sicher nachvollziehen das dieFehlermeldung nur beim Schreiben eines Datenpunkts kommt.
                            • B
                              B
                              bishop
                              #155
                              @Chaot @Dutchman
                              kann ich bestätigen, es läuft alles. Wenn man aber ein DP schreiben möchte bekommt man diese Fehlermeldung.
                              • S
                                S
                                stefande
                                schrieb am zuletzt editiert von stefande
                                #156
                                Mal eine blöde Frage:
                                Instructions
                                3. Configure intervall times for data polling and auto-detect cyclus
                                5. Adapter will send changes immediatly and polls data every x seconds (configurable)
                                Wo können die oben genannten Parameter eingestellt werden?
                                • S stefande
                                  Instructions
                                  DutchmanD
                                  DutchmanD
                                  Dutchman
                                  #157
                                  @stefande sagte in [WLED] LED streifen (WS2812B,WS2811,SK6812,APA102) bedienen:
                                  noch nirgendwo sind momentan hard coded kommt später als state bei info
                                  • B bishop
                                    @Chaot @Dutchman
                                    DutchmanD
                                    DutchmanD
                                    Dutchman
                                    #158
                                    mit der neuen Firmware ? ... ok mist... hab ich was zu. tun
                                      S
                                      S
                                      stefande
                                      #159
                                      @Dutchman sagte in [WLED] LED streifen (WS2812B,WS2811,SK6812,APA102) bedienen:
                                      Danke für die Rückmeldung. Hab schon gedacht ich bin blind.
                                      Ist das denn normal, dass es knapp 30 Sekunden dauert bis ich die "Ein Rückmeldung" bekomme?
                                      • H
                                        H
                                        HomeTed
                                        #160
                                        welche LED Streifen lassen sich alles mit WLED steuern, gibt es da irgendwo eine Übersicht?
                                        Ich suche die Eierlegende Wollmilchsau, RGB aber auch warmes & kaltes Weiß, wenn ich das richtig sehe wäre das zum Beispiel ein LED Streifen SK6812. Kann ich diesen Streifen auch komplett mit WLED steuern?
                                          E
                                          E
                                          e-s
                                          #161
                                          @Dutchman @bishop @Chaot
                                          habe bei mir auch nochmal geschaut, bei mir gibt es keine errors im log beim ändern.
                                          83.8k
