  4. Material Design Widgets: Calendar Widget
    apollon77A
vis
201 Beiträge 46 Kommentatoren 60.3k Aufrufe 53 Beobachtet
  • ScroungerS Scrounger
    @Adnim
    Jetzt müsste es gehen:
    // momentjs is required as dependecies in javascript adapter
    const moment = require("moment");
    var instances = $(`[id=ical.*.data.table]`);
    instances.on(ical2CalendarWidget);
    function ical2CalendarWidget() {
        try {
            let calList = [];
            for (var inst = 0; inst <= instances.length - 1; inst++) {
                let icalObj = getState(instances[inst]).val;
                if (icalObj) {
                    for (var i = 0; i <= icalObj.length - 1; i++) {
                        let item = icalObj[i];
                        // extract calendar color
                        let calendarName = item._class.split(' ')[0].replace('ical_', '');
                        let startTime = moment(item._date);
                        let endTime = moment(item._end);
                        let start = startTime.format("YYYY-MM-DD HH:mm");
                        let end = endTime.format("YYYY-MM-DD HH:mm");
                        if (startTime.format('HH:mm') === '00:00' && endTime.format('HH:mm') === '00:00') {
                            // is full-day event
                            if (endTime.diff(startTime, 'hours') === 24) {
                                // full-day event, one day
                                start = startTime.format("YYYY-MM-DD");
                                end = startTime.format("YYYY-MM-DD");
                            } else {
                                // full-day event, multiple days
                                end = endTime.format("YYYY-MM-DD");
                        // create object for calendar widget
                        calList.push({
                            color: getMyCalendarColor(calendarName),
                            colorText: getMyCalendarTextColor(calendarName),
                            start: start,
                            end: end
                    function getMyCalendarColor(calendarName) {
                        // assign colors via the calendar names, use calendar name as set in ical
                        if (calendarName === 'calendar1') {
                            return '#FF0000';
                        } else if (calendarName === 'calendar2') {
                            return '#44739e'
                        } else if (calendarName === 'calendar3') {
                            return '#32a852'
                    function getMyCalendarTextColor(calendarName) {
                            return '#FFFFFF';
                            return '#FFFFFF'
                            return '#FFFFFF'
                // Enter the destination data point that is to be used as object ID in the widget
                setState('0_userdata.0.materialdesignwidgets.ical2Calendar', JSON.stringify(calList), true);
        } catch (e) {
            console.error(`ical2MaterialDesignCalendarWidget: message: ${e.message}, stack: ${e.stack}`);
    ical2CalendarWidget();
    S
    S
    sveni_lee
    @Scrounger
    super, so hatte ich mir das vorgestellt.
    • J
      J
      jerzimeik
      schrieb am zuletzt editiert von jerzimeik
      soweit läuft das widget inkl. scipt. Nur zeigt er mir nicht die Termine aller Instanzen an.
      Unter den objects steht in der Datei zwar alles drin
      [{"name":"Rest- & Biomüll","start":"2020-02-06","end":"2020-02-06"},{"name":"Friseur","start":"2020-02-05 09:00","end":"2020-02-05 09:30"},{"name":"Physio","start":"2020-02-06 08:00","end":"2020-02-06 08:30"},{"name":"Training AH","start":"2020-02-06 19:30","end":"2020-02-06 21:30"},{"name":"Vitamin D3","start":"2020-02-07 12:30","end":"2020-02-07 12:30"},]
      Aber in der vis nicht:
      Der erste Eintrag steht sogar doppelt.
      Was muss ich tun?
      Witzigerweise zeigt er in der Monatsansicht alle Termine an?!?
      ub.privatU 1 Antwort Letzte Antwort
      • J jerzimeik
        Was muss ich tun?
        ub.privatU
        ub.privatU
        ub.privat
        schrieb am zuletzt editiert von ub.privat
        Servus und einen schönen guten Abend,
        ich mach es mir noch ein wenig schwer mit dem CalendarWidget.
        1. Wo muss das Script eingestellt werden?
          • zentral unter Scripte "common" , "root-Verzeichnis", oder ...?
          • oder im Widget unter Scripte?
        2. Wie kann ich dem Widget mehrere Kalender zuordnen? Habe zwei ical- Instanzen...
        3. Welchen Datenpunkt der ical-Instanz wähle ich aus?
        Danke schon mal für eure sicher hilfreichen Tipps!
        Agria4800A 1 Antwort Letzte Antwort
        • ub.privatU ub.privat
          Agria4800A
          Agria4800A
          Agria4800
          @ub-privat zu 1: unter javascript Adapter, der muss natürlich installiert sein!
          dann unter:
          zu 2: entweder machst du ein Widget per Instanz ( dann bitte den * aus Punkt 3 mit der ical 0 oder 1 ändern), oder lässt dir wie unter Punkt 3 alle in einem anzeigen!
          und zu 3:
          mit dem * sucht er alle ical Instanzen ab!
          • Agria4800A Agria4800
            dann unter:
            und zu 3:
            ub.privatU
            ub.privatU
            ub.privat
            @Agria4800
            Danke für deine Hilfe, leider bekomme ich immer noch keine Kalendereinträge angezeigt.
            Script ist wie folgt hinterlegt:
            Nun muss ich ja im Widget den DP angeben:
            HIer kann ich nun die Kalender = ical-Instanzen auswählen:
            Ich denke, genau hier habe ich mein Verständisproblem!
            Egal was ich anwähle, es folgt kein Ergebnis.
            Mache ich etwas falsch?
            Gemäß Beschreibung;
            wird ein JSON-String als Object-ID benötigt.
            Nur in meiner Objekt-Liste ist kein JSON-String, maximal ein HTML und Tabelle...!
            Wie gesagt, es ist GUTER RAT TEUER!?
              @Agria4800
              Gemäß Beschreibung;
              Agria4800A
              Agria4800A
              Agria4800
              @ub-privat naja, bist auf den richtigen Weg :-)
              im Script wird ein Datenpunkt angelegt (recht weit unten...)
                      setState('0_userdata.0.materialdesignwidgets.ical4Calendar', JSON.stringify(calList), true);
              diesen Datenpunkt musst du in dem Widget, welches du schon hast, eintragen, dann passt es ;-)
                ub.privatU
                ub.privatU
                ub.privat
                @Agria4800
                Dankeschöne, wieder einen kleinen Schritt weiter:
                Leider ist deser DP nicht erzeugt!
                Ergo, es muss noch etwas falsch sein...???😢 😠
                  @sigi234
                  @sigi234 sagte in Material Design Widgets: Calendar Widget:
                  Bei reinziehen:
                  Das ist eine Fehlermeldung die von der vuetify api kommt, kann ignoriert werden.
                  Nach einfügen der ID:
                  Kann ich nicht reproduzieren. Brauch zwingend den Wert deines verwendeten Objektes!
                  Edit: in testing thread verschoben, da es fehlerbehbung betrifft und nicht die Einstellung des Widgets
                  sigi234S
                  sigi234S
                  @Scrounger
                  Altes Widget funktioniert einwandfrei!
                  J.A.R.V.I.S.J ScroungerS 2 Antworten Letzte Antwort
                  • sigi234S sigi234
                    @Scrounger
                    J.A.R.V.I.S.J
                    J.A.R.V.I.S.J
                    J.A.R.V.I.S.
                    schrieb am zuletzt editiert von J.A.R.V.I.S.
                    @sigi234 ich vermute mal stark, dass der Calendar Adapter (noch?) nicht unterstützt wird und das Widget derzeit nur auf iCal ausgelegt ist.
                    • sigi234S sigi234
                      @Scrounger
                      ScroungerS
                      ScroungerS
                      Scrounger
                      schrieb am zuletzt editiert von Scrounger
                      Das kann auch nicht gehen, da du ein Objekt String (de: Zeichenkette) mit einem JSON-String als Objekt verwenden musst und nicht so wie du das gemacht hast eine Datenstruktur.
                      Das ging auch nicht in einer vorherigen Version.
                      Hab jetzt das skript nochmal angepasst, damit es hoffentlich wirklich out of the box funktioniert:
                      // remove this, if you know to use your own datapoint
                      let datapointId = 'materialdesignwidgets.calendar.ical2calendar'
                      createState(datapointId, "[]", {
                        read: true,
                        write: false,
                        desc: "JSON String for Calendar Widget",
                        type: "string",
                        def: "[]"
                          try {
                              let calList = [];
                                  if (icalObj) {
                                              } else {
                                          calList.push({
                                              start: start,
                                              end: end
                                              return '#FF0000';
                                              return '#44739e'
                                              return '#32a852'
                                              return '#FFFFFF';
                                              return '#FFFFFF'
                                              return '#FFFFFF'
                                  setState(datapointId, JSON.stringify(calList), true);
                          } catch (e) {
                      Es wird euch jetzt autmoatisch ein Datenpunkt in der Javascript instanz angelegt.
                      Im Calendar Wigdet dann unter Objekt Id diesen Datenpunkt auswählen, da muss dann folgendes drin stehen javascript.0.materialdesignwidgets.calendar.ical2calendar
                      J.A.R.V.I.S.J ub.privatU 2 Antworten Letzte Antwort
                          read: true,
                          write: false,
                          type: "string",
                          def: "[]"
                            try {
                                let calList = [];
                                    if (icalObj) {
                                                } else {
                                            calList.push({
                                                start: start,
                                                end: end
                                                return '#FF0000';
                                                return '#44739e'
                                                return '#32a852'
                                                return '#FFFFFF';
                                                return '#FFFFFF'
                                                return '#FFFFFF'
                            } catch (e) {
                        J.A.R.V.I.S.J
                        J.A.R.V.I.S.J
                        J.A.R.V.I.S.
                        @Scrounger er verwendet den Calendar Adapter. Dieser hat allerdings eine andere Struktur und das Skript müsste daraufhin angepasst werden.
                        Deswegen funktioniert das Skript bei @sigi234 auch nicht.
                        ScroungerS 1 Antwort Letzte Antwort
                        • S
                          S
                          syryna
                          schrieb am zuletzt editiert von syryna
                          @Scrounger
                          Erstmal vielen Dank für deine Tollen UI Widgets. Durch dich ist sogar ein Laie wie ich fähig ein UI zusammenzubsateln. Tolle Arbeit !
                          Ich hätte jedoch noch 2 Wünsche:
                          1. Der Rot markierte Bereich läßt sich nicht färben. Vermutlich geht es über CSS aber da wäre ebenfalls eine Einstellung gut. ich nehme an es ist follende Klasse: class="v-calendar-daily__scroll-area".
                            -> Korrektur: die Klasse alleine reicht nicht aus. dann wird der untere Teil schwarz, nicht aber die Scrolbar und ebenfalls nicht der schmale Balken oberhalb der Scrollbar. Ich schätze mal am besten wäre das Scrollen zu deaktivieren. Bei mir gäbe es nichts zu scrollen.
                          2. Wäre es möglich parallele Termine nicht überlappend anzuzeigen sondern nebeneinander?
                            -> Korrektur: Das geht schon mit Modusüberlappung : Column
                          Grüße, Micha
                          • S syryna
                            @Scrounger
                            Grüße, Micha
                            ScroungerS
                            ScroungerS
                            Scrounger
                            @syryna sagte in Material Design Widgets: Calendar Widget:
                            Müsste über Hintergrund der View anpassen oder über widget css hintergrund gehen - ungetestet.
                            Die Scrollbar farben kannst glaub nicht ändern, ist vom browser so vorgegeben, hab ich mich noch nie mit beschäftigt. Ausblenden geht leider nicht, ist von der API so vorgegeben.
                            • S syryna
                              @Scrounger
                              Grüße, Micha
                              ScroungerS
                              ScroungerS
                              Scrounger
                              Scrollbar anpassung, siehe hier:
                              https://forum.iobroker.net/topic/29660/material-design-widgets-top-app-bar-widget/88
                              • smarthomegirlS
                                smarthomegirlS
                                smarthomegirl
                                ich habe mich die Tage mal an das hier beschriebene Calendar Widget gewagt. Habe es in VIS auch bereits zugeordnet und das hier genannte Skript im ioBroker ordnungsgemäß hinterlegt.
                                Im Datenpunkt 0_userdata.0.materialdesignwidgets.ical2calendar wird der anstehende Termin auch angezeigt, nur im VIS habe ich folgende Fehlermeldung:
                                Hier der Datenpunkt:
                                Wo liegt der Fehler? Was muss ich einstellen?
                                👍 Ich danke Euch im Voraus. 👍
                                smarthomegirlS 1 Antwort Letzte Antwort
                                • smarthomegirlS smarthomegirl
                                  smarthomegirlS
                                  smarthomegirlS
                                  smarthomegirl
                                  schrieb am zuletzt editiert von smarthomegirl
                                  @smarthomegirl
                                  Edit: hat sich erledigt, die Zuweisung war nicht ganz korrekt.
                                  Noch zwei Fragen:
                                  1. Was muss ich einstellen und wo, damit ich farbliche Termine angezeigt bekomme?
                                  2. Ich habe 3 Google-Kalender im iCal Adapter verknüpft, doch im Widget werden mir nur die Termine von einem Kalender angezeigt. Was muss ich einstellen, um die Termine aller Kalender im Widget zu sehen ?
                                    @smarthomegirl
                                    Noch zwei Fragen:
                                    ScroungerS
                                    ScroungerS
                                    Scrounger
                                    @smarthomegirl sagte in Material Design Widgets: Calendar Widget:
                                    Noch zwei Fragen:
                                    **1. Was muss ich einstellen und wo, damit ich farbliche Termine angezeigt bekomme?
                                    Aktuell muss man die Farben manuell per Skript zuweisen. Das geht in der Funktion getMyCalendarColor. Dort muss man den Kalendernamen eintragen und die Farbe definieren, anbei der Auszug:
                                                            return '#FF0000';
                                                            return '#44739e'
                                                            return '#32a852'
                                    in der nächsten Version vom ical adapter wird die eingestellte Farbe dann mitgeliefert. Das werd ich dann einbauen, dann muss man am Skript gar nichts mehr ändern.
                                    1. Ich habe 3 Google-Kalender im iCal Adapter verknüpft, doch im Widget werden mir nur die Termine von einem Kalender angezeigt. Was muss ich einstellen, um die Termine aller Kalender im Widget zu sehen ?**
                                    Das geht, denke du hast evtl. nicht das richtige Skript oder etwas daran verändert., nimm das von hier:
                                    https://github.com/Scrounger/ioBroker.vis-materialdesign#calendar
                                    Und dann als Datenpunkt (objekt ID) javascript.0.materialdesignwidgets.calendar.ical2calendar im Widget verwenden.
                                    • F
                                      F
                                      Förster
                                      Versuche das auch bei mir umzusetzen, scheitere aber am Wigdet: das Kalender Widget wird mir im VIS Editor nicht zur Auswahl angeboten. Die anderen, zB Alerts oder Masonry, schon.
                                      MD Adapter 0.2.49
                                      VIS 1.2.4
                                      Was muss ich tun ?
                                      F 1 Antwort Letzte Antwort
                                        Noch zwei Fragen:
        return '#FF0000';
        return '#44739e'
        return '#32a852'
                                        smarthomegirlS
                                        smarthomegirlS
                                        smarthomegirl
                                        @Scrounger sagte in Material Design Widgets: Calendar Widget:
        return '#FF0000';
        return '#44739e'
        return '#32a852'
                                        Okay, ich habe die Kalender und die Farben zugewiesen. Allerdings bleibt der Termin weiterhin ohne Farbe (siehe Bild)
                                        Habe dein Skript (von GitHub) genommen und im Widget den Datenpunkt javascript.0.materialdesignwidgets.calendar.ical2calendar verknüpft. Jedoch wird auch hier nach wie vor die Termine von einem Kalender angezeigt und leider nicht von allen drei Kalendern.
                                        Was mache ich hier immer noch falsch?
        return '#FF0000';
        return '#44739e'
        return '#32a852'
                                          ScroungerS
                                          ScroungerS
                                          Scrounger
                                          @smarthomegirl
                                          zeig mal dein skript, screenshot von Datenpunkten des ical adapters und ob was im log steht, nach dem du den ical Adapter und das skript neugestartet hast.
                                          83.9k
