  4. JavaScript
  5. Energieanzeige (kWh) über HTML Tabelle - vis
javascripttemplate
696 Beiträge 37 Kommentatoren 223.8k Aufrufe 46 Beobachtet
  • N Nordischerjung
    @liv-in-sky
    Tolle Arbeit, danke schön 👍
    gibt es die Möglichkeit noch Meross und Fritz DECT Steckdosen mit aufzunehmen?
    liv-in-skyL Offline
    liv-in-skyL Offline
    #112
    @Nordischerjung gibt es
    poste bitte den json export der datenpunkte für meross.0 und auch fritzdect.0 mit den steckdosen
    N 1 Antwort Letzte Antwort
    • liv-in-skyL liv-in-sky
      N Offline
      N Offline
      Nordischerjung
      #113
      @liv-in-sky sagte in Energieanzeige (kWh) über HTML Tabelle - vis:
       "fritzdect.0.DECT200_087610439476": {
         "type": "channel",
         "common": {
           "name": "FRITZ!DECT 200 #1",
           "role": "switch"
         "native": {
           "aid": "087610439476"
         "from": "system.adapter.fritzdect.0",
         "ts": 1544640387823,
         "_id": "fritzdect.0.DECT200_087610439476",
         "acl": {
           "object": 1636,
           "owner": "system.user.admin",
       "fritzdect.0.DECT200_087610439476.devicelock": {
         "type": "state",
         "common": {
           "name": "Switch Button lock",
           "type": "boolean",
           "read": true,
           "write": false,
           "role": "indicator"
         "native": {},
         "ts": 1544640387875,
         "_id": "fritzdect.0.DECT200_087610439476.devicelock",
         "acl": {
           "object": 1636,
           "state": 1636,
       "fritzdect.0.DECT200_087610439476.energy": {
         "type": "state",
         "common": {
           "name": "Switch total energy",
           "type": "number",
           "unit": "Wh",
           "min": 0,
           "read": true,
           "write": false,
           "role": "value.power.consumption",
           "desc": "Switch total energy"
         "native": {},
         "ts": 1544640387872,
         "_id": "fritzdect.0.DECT200_087610439476.energy",
         "acl": {
           "object": 1636,
           "state": 1636,
       "fritzdect.0.DECT200_087610439476.fwversion": {
         "type": "state",
         "common": {
           "name": "FW version",
           "type": "string",
           "read": true,
           "write": false,
           "role": "text",
           "desc": "firmware version"
         "native": {},
         "ts": 1544640387828,
         "_id": "fritzdect.0.DECT200_087610439476.fwversion",
         "acl": {
           "object": 1636,
           "state": 1636,
       "fritzdect.0.DECT200_087610439476.id": {
         "type": "state",
         "common": {
           "name": "ID",
           "type": "string",
           "read": true,
           "write": false,
           "role": "text",
           "desc": "ID"
         "native": {},
         "ts": 1544640387825,
         "_id": "fritzdect.0.DECT200_087610439476.id",
         "acl": {
           "object": 1636,
           "state": 1636,
       "fritzdect.0.DECT200_087610439476.lock": {
         "type": "state",
         "common": {
           "name": "Switch UI/API lock",
           "type": "boolean",
           "read": true,
           "write": false,
           "role": "indicator"
         "native": {},
         "ts": 1544640387869,
         "_id": "fritzdect.0.DECT200_087610439476.lock",
         "acl": {
           "object": 1636,
           "state": 1636,
       "fritzdect.0.DECT200_087610439476.manufacturer": {
         "type": "state",
         "common": {
           "name": "Manufacturer",
           "type": "string",
           "read": true,
           "write": false,
           "role": "text",
           "desc": "Manufacturer"
         "native": {},
         "ts": 1544640387829,
         "_id": "fritzdect.0.DECT200_087610439476.manufacturer",
         "acl": {
           "object": 1636,
           "state": 1636,
       "fritzdect.0.DECT200_087610439476.mode": {
         "type": "state",
         "common": {
           "name": "Switch mode",
           "type": "string",
           "read": true,
           "write": false,
           "role": "text",
           "desc": "Switch mode"
         "native": {},
         "ts": 1544640387868,
         "_id": "fritzdect.0.DECT200_087610439476.mode",
         "acl": {
           "object": 1636,
           "state": 1636,
       "fritzdect.0.DECT200_087610439476.name": {
         "type": "state",
         "common": {
           "name": "Name",
           "type": "string",
           "read": true,
           "write": false,
           "role": "text",
           "desc": "Name"
         "native": {},
         "ts": 1544640387827,
         "_id": "fritzdect.0.DECT200_087610439476.name",
         "acl": {
           "object": 1636,
           "state": 1636,
       "fritzdect.0.DECT200_087610439476.power": {
         "type": "state",
         "common": {
           "name": "Switch act power",
           "type": "number",
           "unit": "W",
           "min": 0,
           "max": 4000,
           "read": true,
           "write": false,
           "role": "value.power",
           "desc": "Switch act power",
           "custom": {
             "sourceanalytix.0": {
               "enabled": true,
               "alias": "Sprudelwasser",
               "state_type": "kWh_consumption",
               "state_unit": "automatically",
               "costs": true,
               "consumption": true,
               "meter_values": true,
               "start_day": -0.7576769199999999,
               "start_week": 0,
               "start_month": 0,
               "start_quarter": 0,
               "start_year": 0
         "native": {},
         "from": "system.adapter.sourceanalytix.0",
         "ts": 1580425200083,
         "_id": "fritzdect.0.DECT200_087610439476.power",
         "acl": {
           "object": 1636,
           "state": 1636,
         "user": "system.user.admin"
       "fritzdect.0.DECT200_087610439476.present": {
         "type": "state",
         "common": {
           "name": "Switch present",
           "type": "boolean",
           "read": true,
           "write": false,
           "role": "indicator.connected",
           "desc": "Switch present"
         "native": {},
         "_id": "fritzdect.0.DECT200_087610439476.present",
         "acl": {
           "object": 1636,
           "state": 1636,
       "fritzdect.0.DECT200_087610439476.prodname": {
         "type": "state",
         "common": {
           "name": "Product Name",
           "type": "string",
           "read": true,
           "write": false,
           "role": "text",
           "desc": "Product Name"
         "native": {},
         "ts": 1544640387830,
         "_id": "fritzdect.0.DECT200_087610439476.prodname",
         "acl": {
           "object": 1636,
           "state": 1636,
       "fritzdect.0.DECT200_087610439476.state": {
         "type": "state",
         "common": {
           "name": "Switch on/off",
           "type": "boolean",
           "read": true,
           "write": true,
           "role": "switch",
           "desc": "Switch on/off"
         "native": {},
         "ts": 1544640387831,
         "_id": "fritzdect.0.DECT200_087610439476.state",
         "acl": {
           "object": 1636,
           "state": 1636,
       "fritzdect.0.DECT200_087610439476.temp": {
         "type": "state",
         "common": {
           "name": "actual Temp",
           "type": "number",
           "unit": "°C",
           "read": true,
           "write": false,
           "role": "value.temperature",
           "desc": "actual Temp"
         "native": {},
         "ts": 1544640387873,
         "_id": "fritzdect.0.DECT200_087610439476.temp",
         "acl": {
           "object": 1636,
           "state": 1636,
       "fritzdect.0.DECT200_087610439476.voltage": {
         "type": "state",
         "common": {
           "name": "Switch act voltage",
           "type": "number",
           "unit": "V",
           "min": 0,
           "max": 250,
           "read": true,
           "write": false,
           "role": "value.voltage",
           "desc": "Switch act voltage"
         "native": {},
         "ts": 1544640387876,
         "_id": "fritzdect.0.DECT200_087610439476.voltage",
         "acl": {
           "object": 1636,
           "state": 1636,
      meinst du das? Von meross hab ich zur Zeit nur Outdoor Steckdosen ohne Messung. Die mit Messung bekomme ich erst Montag
      Gruß Nordischerjung
      sonnige Grüße von der Ostsee
      liv-in-skyL 3 Antworten Letzte Antwort
      • N Nordischerjung
           "type": "channel",
           "common": {
             "role": "switch"
           "native": {
           "acl": {
             "object": 1636,
           "type": "state",
           "common": {
             "type": "boolean",
             "read": true,
             "write": false,
             "role": "indicator"
           "native": {},
           "acl": {
             "object": 1636,
             "state": 1636,
           "type": "state",
           "common": {
             "type": "number",
             "unit": "Wh",
             "min": 0,
             "read": true,
             "write": false,
           "native": {},
           "acl": {
             "object": 1636,
             "state": 1636,
           "type": "state",
           "common": {
             "type": "string",
             "read": true,
             "write": false,
             "role": "text",
           "native": {},
           "acl": {
             "object": 1636,
             "state": 1636,
           "type": "state",
           "common": {
             "name": "ID",
             "type": "string",
             "read": true,
             "write": false,
             "role": "text",
             "desc": "ID"
           "native": {},
           "acl": {
             "object": 1636,
             "state": 1636,
           "type": "state",
           "common": {
             "type": "boolean",
             "read": true,
             "write": false,
             "role": "indicator"
           "native": {},
           "acl": {
             "object": 1636,
             "state": 1636,
           "type": "state",
           "common": {
             "type": "string",
             "read": true,
             "write": false,
             "role": "text",
           "native": {},
           "acl": {
             "object": 1636,
             "state": 1636,
           "type": "state",
           "common": {
             "type": "string",
             "read": true,
             "write": false,
             "role": "text",
           "native": {},
           "acl": {
             "object": 1636,
             "state": 1636,
           "type": "state",
           "common": {
             "name": "Name",
             "type": "string",
             "read": true,
             "write": false,
             "role": "text",
             "desc": "Name"
           "native": {},
           "acl": {
             "object": 1636,
             "state": 1636,
           "type": "state",
           "common": {
             "type": "number",
             "unit": "W",
             "min": 0,
             "max": 4000,
             "read": true,
             "write": false,
             "custom": {
                 "enabled": true,
                 "costs": true,
                 "start_week": 0,
                 "start_month": 0,
                 "start_quarter": 0,
                 "start_year": 0
           "native": {},
           "acl": {
             "object": 1636,
             "state": 1636,
           "type": "state",
           "common": {
             "type": "boolean",
             "read": true,
             "write": false,
           "native": {},
           "acl": {
             "object": 1636,
             "state": 1636,
           "type": "state",
           "common": {
             "type": "string",
             "read": true,
             "write": false,
             "role": "text",
           "native": {},
           "acl": {
             "object": 1636,
             "state": 1636,
           "type": "state",
           "common": {
             "type": "boolean",
             "read": true,
             "write": true,
             "role": "switch",
           "native": {},
           "acl": {
             "object": 1636,
             "state": 1636,
           "type": "state",
           "common": {
             "type": "number",
             "unit": "°C",
             "read": true,
             "write": false,
           "native": {},
           "acl": {
             "object": 1636,
             "state": 1636,
           "type": "state",
           "common": {
             "type": "number",
             "unit": "V",
             "min": 0,
             "max": 250,
             "read": true,
             "write": false,
           "native": {},
           "acl": {
             "object": 1636,
             "state": 1636,
        liv-in-skyL Offline
        liv-in-skyL Offline
        #114
        @Nordischerjung nein ich meine den ganzen pfad https://forum.iobroker.net/post/355793 und dann die ganze datei hier posten (einfach in den post ziehen -
        • N Nordischerjung
             "type": "channel",
             "common": {
               "role": "switch"
             "native": {
             "acl": {
               "object": 1636,
             "type": "state",
             "common": {
               "type": "boolean",
               "read": true,
               "write": false,
               "role": "indicator"
             "native": {},
             "acl": {
               "object": 1636,
               "state": 1636,
             "type": "state",
             "common": {
               "type": "number",
               "unit": "Wh",
               "min": 0,
               "read": true,
               "write": false,
             "native": {},
             "acl": {
               "object": 1636,
               "state": 1636,
             "type": "state",
             "common": {
               "type": "string",
               "read": true,
               "write": false,
               "role": "text",
             "native": {},
             "acl": {
               "object": 1636,
               "state": 1636,
             "type": "state",
             "common": {
               "name": "ID",
               "type": "string",
               "read": true,
               "write": false,
               "role": "text",
               "desc": "ID"
             "native": {},
             "acl": {
               "object": 1636,
               "state": 1636,
             "type": "state",
             "common": {
               "type": "boolean",
               "read": true,
               "write": false,
               "role": "indicator"
             "native": {},
             "acl": {
               "object": 1636,
               "state": 1636,
             "type": "state",
             "common": {
               "type": "string",
               "read": true,
               "write": false,
               "role": "text",
             "native": {},
             "acl": {
               "object": 1636,
               "state": 1636,
             "type": "state",
             "common": {
               "type": "string",
               "read": true,
               "write": false,
               "role": "text",
             "native": {},
             "acl": {
               "object": 1636,
               "state": 1636,
             "type": "state",
             "common": {
               "name": "Name",
               "type": "string",
               "read": true,
               "write": false,
               "role": "text",
               "desc": "Name"
             "native": {},
             "acl": {
               "object": 1636,
               "state": 1636,
             "type": "state",
             "common": {
               "type": "number",
               "unit": "W",
               "min": 0,
               "max": 4000,
               "read": true,
               "write": false,
               "custom": {
                   "enabled": true,
                   "costs": true,
                   "start_week": 0,
                   "start_month": 0,
                   "start_quarter": 0,
                   "start_year": 0
             "native": {},
             "acl": {
               "object": 1636,
               "state": 1636,
             "type": "state",
             "common": {
               "type": "boolean",
               "read": true,
               "write": false,
             "native": {},
             "acl": {
               "object": 1636,
               "state": 1636,
             "type": "state",
             "common": {
               "type": "string",
               "read": true,
               "write": false,
               "role": "text",
             "native": {},
             "acl": {
               "object": 1636,
               "state": 1636,
             "type": "state",
             "common": {
               "type": "boolean",
               "read": true,
               "write": true,
               "role": "switch",
             "native": {},
             "acl": {
               "object": 1636,
               "state": 1636,
             "type": "state",
             "common": {
               "type": "number",
               "unit": "°C",
               "read": true,
               "write": false,
             "native": {},
             "acl": {
               "object": 1636,
               "state": 1636,
             "type": "state",
             "common": {
               "type": "number",
               "unit": "V",
               "min": 0,
               "max": 250,
               "read": true,
               "write": false,
             "native": {},
             "acl": {
               "object": 1636,
               "state": 1636,
          liv-in-skyL Offline
          liv-in-skyL Offline
          #115
          @Nordischerjung sorry -alles gut - war schon richtig so
          • liv-in-skyL Offline
            liv-in-skyL Offline
            #116
            bäuchte eure hilfe bei 2 themen - homee user und mihome user
            es geht um den wert , ob das device online ist - ich muss noch mal ein update machen, weil die werte für die beiden maken nicht klar sind
            mihome: ws steht in state_in_use - ist das eine zahl oder boolean - wenn zahl, steht dann 0 und 1 oder kann da was anderes stehen
            homee: wie kann ich herausfinden, ob das gerät online ist
            problem - sind sie offline, werden die daten zum berechnen weiter mitgezälht, obwohl nicht aktiv
            O crunchipC 2 Antworten Letzte Antwort
            • N Nordischerjung
                 "type": "channel",
                 "common": {
                   "role": "switch"
                 "native": {
                 "acl": {
                   "object": 1636,
                 "type": "state",
                 "common": {
                   "type": "boolean",
                   "read": true,
                   "write": false,
                   "role": "indicator"
                 "native": {},
                 "acl": {
                   "object": 1636,
                   "state": 1636,
                 "type": "state",
                 "common": {
                   "type": "number",
                   "unit": "Wh",
                   "min": 0,
                   "read": true,
                   "write": false,
                 "native": {},
                 "acl": {
                   "object": 1636,
                   "state": 1636,
                 "type": "state",
                 "common": {
                   "type": "string",
                   "read": true,
                   "write": false,
                   "role": "text",
                 "native": {},
                 "acl": {
                   "object": 1636,
                   "state": 1636,
                 "type": "state",
                 "common": {
                   "name": "ID",
                   "type": "string",
                   "read": true,
                   "write": false,
                   "role": "text",
                   "desc": "ID"
                 "native": {},
                 "acl": {
                   "object": 1636,
                   "state": 1636,
                 "type": "state",
                 "common": {
                   "type": "boolean",
                   "read": true,
                   "write": false,
                   "role": "indicator"
                 "native": {},
                 "acl": {
                   "object": 1636,
                   "state": 1636,
                 "type": "state",
                 "common": {
                   "type": "string",
                   "read": true,
                   "write": false,
                   "role": "text",
                 "native": {},
                 "acl": {
                   "object": 1636,
                   "state": 1636,
                 "type": "state",
                 "common": {
                   "type": "string",
                   "read": true,
                   "write": false,
                   "role": "text",
                 "native": {},
                 "acl": {
                   "object": 1636,
                   "state": 1636,
                 "type": "state",
                 "common": {
                   "name": "Name",
                   "type": "string",
                   "read": true,
                   "write": false,
                   "role": "text",
                   "desc": "Name"
                 "native": {},
                 "acl": {
                   "object": 1636,
                   "state": 1636,
                 "type": "state",
                 "common": {
                   "type": "number",
                   "unit": "W",
                   "min": 0,
                   "max": 4000,
                   "read": true,
                   "write": false,
                   "custom": {
                       "enabled": true,
                       "costs": true,
                       "start_week": 0,
                       "start_month": 0,
                       "start_quarter": 0,
                       "start_year": 0
                 "native": {},
                 "acl": {
                   "object": 1636,
                   "state": 1636,
                 "type": "state",
                 "common": {
                   "type": "boolean",
                   "read": true,
                   "write": false,
                 "native": {},
                 "acl": {
                   "object": 1636,
                   "state": 1636,
                 "type": "state",
                 "common": {
                   "type": "string",
                   "read": true,
                   "write": false,
                   "role": "text",
                 "native": {},
                 "acl": {
                   "object": 1636,
                   "state": 1636,
                 "type": "state",
                 "common": {
                   "type": "boolean",
                   "read": true,
                   "write": true,
                   "role": "switch",
                 "native": {},
                 "acl": {
                   "object": 1636,
                   "state": 1636,
                 "type": "state",
                 "common": {
                   "type": "number",
                   "unit": "°C",
                   "read": true,
                   "write": false,
                 "native": {},
                 "acl": {
                   "object": 1636,
                   "state": 1636,
                 "type": "state",
                 "common": {
                   "type": "number",
                   "unit": "V",
                   "min": 0,
                   "max": 250,
                   "read": true,
                   "write": false,
                 "native": {},
                 "acl": {
                   "object": 1636,
                   "state": 1636,
              liv-in-skyL Offline
              liv-in-skyL Offline
              #117
              @Nordischerjung fritzdect ist drin (beim nächsten update dabei)
              meross: machen wir wenn du die datenpunkte hast
                O Offline
                O Offline
                Oli
                #118
                @liv-in-sky
                mit dem homee Adapter derzeit leider gar nicht.
                Oliver
                • O Oli
                  @liv-in-sky
                  liv-in-skyL Offline
                  liv-in-skyL Offline
                  #119
                  @Oli wie oft werden den die daten upgedatet - evtl geht was über last_change irgendeines datenpunktes - wobei es da am adapter selbst liegt, ob er updated, wenn keine oder keine veränderten daten kommen - kannst du bitte mal testen
                  kurzscript - datenpunkt kannst du ändern auf deine geräte - müßte aber eh von dir sein
                  alle 20 sekunden wird die zeit diff gemessen - wann er das letzte mal gändert wurde
                  wir suchen den unterschied zw. gerät ist aktiv ( also wie oft liest der adapter die daten und macht update) und was geschieht mit dieser zeitdifferenz, wenn gerät offline - also nicht im netzwerk erreichbar
                   schedule(' */20 * * * * *',  function () {
                  var ddd=getState("homee.0.MeteringPlug-20.CurrentEnergyUse-190").lc
                  log(parseInt((new Date().getTime())) - new Date(ddd))
                  O N 3 Antworten Letzte Antwort
                    O Offline
                    O Offline
                    Oli
                    #120
                    @liv-in-sky
                    Kann ich aber leider erst Montag Abend testen.
                    Oliver
                    • O Oli
                      @liv-in-sky
                      liv-in-skyL Offline
                      liv-in-skyL Offline
                      #121
                      @Oli kein thema
                        crunchipC Offline
                        crunchipC Offline
                        #122
                        @liv-in-sky was brauchst du zwecks mihome?
                          liv-in-skyL Offline
                          liv-in-skyL Offline
                          #123
                          @crunchip hi M
                          hast du mihome steckdosen, die eine energieanzeige haben
                          crunchipC ? 2 Antworten Letzte Antwort
                            @crunchip hi M
                            crunchipC Offline
                            crunchipC Offline
                            #124
                            @liv-in-sky hab ich selbst grad gemerkt🤦 sind ja im Energie script. Nein leider nix mit Strom von Mihome
                              liv-in-skyL Offline
                              liv-in-skyL Offline
                              #125
                              @crunchip dann warte ich halt bis montag
                                @crunchip hi M
                                #126
                                @crunchip hi M
                                Hi, ich hab so eine, unter anderem...
                                Was brauchst du davon? ( Konnte hier noch nicht soviel mitlesen die letzten Wochen..)
                                  @crunchip hi M
                                  liv-in-skyL Offline
                                  liv-in-skyL Offline
                                  #127
                                  @ilovegym hi - eigentlich nur das hier - ich muss irgendwie rausfinden, wenn das ding offline ist
                                  https://forum.iobroker.net/post/368458
                                  O vauvau07V 2 Antworten Letzte Antwort
                                    O Offline
                                    O Offline
                                    Oli
                                    #128
                                    @liv-in-sky
                                    Ich glaube nicht, dass der homee Adapter sowas abbildet
                                    https://forum.iobroker.net/topic/26083/wünsche-für-den-homee-adapter
                                    Oliver
                                      vauvau07V Offline
                                      vauvau07V Offline
                                      vauvau07
                                      #129
                                      @liv-in-sky
                                      ist es möglich folgendes Gerät einzubinden
                                      zigbee.0.00158d0003893df5.json
                                      Gruß Volkmar
                                      • O Oli
                                        @liv-in-sky
                                        liv-in-skyL Offline
                                        liv-in-skyL Offline
                                        #130
                                        @Oli deshalb versuche ich den dp-update-cyclus zu finden und ob der adapter diese updates auch macht, wenn das gerät nicht online ist
                                        • vauvau07V vauvau07
                                          @liv-in-sky
                                          liv-in-skyL Offline
                                          liv-in-skyL Offline
                                          #131
                                          @vauvau07 sind schön längst drin - hat das script sofort erkannt
                                          vauvau07V 1 Antwort Letzte Antwort
