[Vorlage] Alias per Skript erzeugen
@patti72 sagte:
Die selbe Warnung im log.
Die Warnung ist oben leider nicht vollständig. Bitte nochmal aus dem Reiter "Log" in Code tags posten.
Mehr kommt nicht, wenn ich das Script starte.
2020-01-04 08:17:42.694 - debug: javascript.0 (2420) system.adapter.admin.0: logging false 2020-01-04 08:17:43.293 - debug: javascript.0 (2420) system.adapter.admin.0: logging true 2020-01-04 08:17:52.269 - debug: javascript.0 (2420) sendTo "loadTypings" to system.adapter.admin.0 from system.adapter.javascript.0 2020-01-04 08:20:47.665 - debug: javascript.0 (2420) sendTo "loadTypings" to system.adapter.admin.0 from system.adapter.javascript.0 2020-01-04 08:20:53.988 - info: javascript.0 (2420) Stop script script.js.common.alias_anlegen 2020-01-04 08:20:56.554 - info: javascript.0 (2420) Start javascript script.js.common.alias_anlegen 2020-01-04 08:20:56.569 - info: javascript.0 (2420) script.js.common.alias_anlegen: getObject(id=deconz.0.Lights.2.on, enumName=undefined) => {"type":"state","common":{"name":"Lampe1 on","type":"boolean","role":"switch","read":true,"write":true},"native":{},"from":"system.adapter.deconz.0","user":"system.user.admin","ts":1578087361576,"_id":"deconz.0.Lights.2.on"} 2020-01-04 08:20:56.571 - warn: javascript.0 (2420) script.js.common.alias_anlegen: setObject(id=alias.0.lampe2, obj={"type":"state","common":{"name":"Lampe1 on","type":"boolean","role":"switch","read":true,"write":true,"alias":{"id":"deconz.0.Lights.2.on"}},"native":{}}) - was not executed, while debug mode is active 2020-01-04 08:20:56.572 - info: javascript.0 (2420) script.js.common.alias_anlegen: registered 0 subscriptions and 0 schedules 2020-01-04 08:28:45.983 - debug: javascript.0 (2420) system.adapter.admin.0: logging false 2020-01-04 08:28:53.754 - info: info.0 (1408) Popup news was read... 2020-01-04 08:28:55.246 - info: host.iobroker_oben Update repository "default" under "http://download.iobroker.net/sources-dist.json" 2020-01-04 08:29:48.955 - debug: javascript.0 (2420) system.adapter.admin.0: logging true -
@Markus84 said in [Vorlage] Alias per Skript erzeugen:
@paul53 Besten Dank. Jetzt habe ich es (hoffentlich) verstanden und werde es gleich mal versuchen umzusetzen.
Vielleicht habe ich es doch nicht so ganz verstanden... Den Alias anzulegen hat wunderbar funktioniert. Den value synchronisiert er auch sehr schön zwischen Alias und dem zu schaltenden Datenpunkt. Wenn ich Name, state oder role ändere, wird diese Änderung jedoch nicht mitsynchronisiert. Ist das normal? Falls dies normal ist, kann ich bedenkenlos diese Daten im Alias ändern (werden dann logischerweise zwar nicht synchronisiert) oder lässt man besser die Finger davon?
Es ist ja gerade die Idee von der Alias-Funktion, dass du am Alias-Objekt role, Name, Funktion, Raum usw. "schön" setzt. Die Objekte im Adapternamespace können sich ja beliebig ändern, wenn der Adapter das für richtig hält oder wenn mal ein Gerät ersetzt werden soll.
@Garfonso Danke für die Klarstellung! Wenn man einmal verstanden hat, wofür Alias-Objekte sind, ist es natürlich logisch. Es macht bestimmt eine riesen Arbeit die Alias-Objekte einmal einzurichten, aber das ist es auf lange Sicht definitiv Wert.
Ich möchte für meine Xiaomi Bewegungsmelder einen alias Datenpunkt erstellen.
Im Xiaomi ist der Datenpunkt vom Typ number und zeigt die verstrichene Zeit in Sekunden seit der letzten Auslösung an:
Der alias Datenpunkt soll ein boolean sein, der bei (Xiaomi = 0) true und sonst (Xiaomi > 0) false ist.
Dein Skript am Fredanfang habe ich so angepasst:
Bekomme aber den Datenpunkt so angelegt:
Was mache ich falsch?
Vielen Dank im Voraus!
Ulrich -
Ulrich@zahnheinrich sagte:
Wie sieht die RAW-Ansicht des Alias-Objektes aus (bitte in Code tags (</>) posten) ?
Bitteschön:{ "type": "state", "common": { "name": "BWM Räumchen", "role": "sensor.motion", "write": false, "read": true, "type": "boolean", "unit": "seconds", "desc": "per Script erstellt", "alias": { "id": "mihome.0.devices.motion_158d00013f7666.no_motion", "read": "val == '0' ? true : false" } }, "native": {}, "from": "system.adapter.javascript.0", "user": "system.user.admin", "ts": 1578589323783, "_id": "alias.0.BWM.Raeumchen.MOTION", "acl": { "object": 1636, "state": 1636, "owner": "system.user.admin", "ownerGroup": "system.group.administrator" } } -
Bitteschön:{ "type": "state", "common": { "name": "BWM Räumchen", "role": "sensor.motion", "write": false, "read": true, "type": "boolean", "unit": "seconds", "desc": "per Script erstellt", "alias": { "id": "mihome.0.devices.motion_158d00013f7666.no_motion", "read": "val == '0' ? true : false" } }, "native": {}, "from": "system.adapter.javascript.0", "user": "system.user.admin", "ts": 1578589323783, "_id": "alias.0.BWM.Raeumchen.MOTION", "acl": { "object": 1636, "state": 1636, "owner": "system.user.admin", "ownerGroup": "system.group.administrator" } }@zahnheinrich
Lösche mal Zeile 9 (unit) raus und ändere "read""read": "val == 0 ? true : false"oder
"read": "val ? false : true"oder
"read": "!val" -
@zahnheinrich
"read": "!val"@paul53 sagte in [Vorlage] Alias per Skript erzeugen:
Danke!"read": "!val"
funktioniert.
Bei "unit" hatte ich im script "" eingetragen. Das führte aber nicht zur gewünschten Unterdrückung jeglicher Einheit im Alias.
Muss ich das dann immer händisch löschen, oder?Vielen Dank für deine Mühe, hatte stundenlang alle Konbinationen ohne Erfolg durchprobiert!
funktioniert.
if(unit) liefert bei einem Leerstring false, die Einheit wurde also nicht überschrieben. Ein Leerzeichen " " hätte sie unsichtbar gemacht.
Dankeschön, wieder etwas gelernt
Kurioserweise bekomme ich ab jetzt bei einem neuen Datenpunkt ein Infosymbol :
Was sagt mir das?
Was sagt mir das?
Da bin ich aber froh
Ich nämlich auch nicht! -
Was sagt mir das?
@zahnheinrich hab vor kurzen einen neuen Schalter am Gateway angelernt, nachdem dieser in IoBroker erschien, kam auch dieses Symbol. Hat also nichts mit dem Alias zu tun. Hängt wahrscheinlich eher mit dem Adapter zusammen, bzw eher mit Admin/Js-Controller
