  4. wie ersetzte ich den CC2531/CC2530
cc2530cc2531cc2538cc2592ersetztenreichweite
374 Beiträge 62 Kommentatoren 112.9k Aufrufe 68 Beobachtet
  • MyzerATM MyzerAT
    wie kann ich den herdsman auf einem slave installieren? bekomme immer FM:
    $ ./iobroker url "https://github.com/ioBroker/ioBroker.zigbee/tarball/herdsman"
    install https://github.com/ioBroker/ioBroker.zigbee/tarball/herdsman
    npm install https://github.com/ioBroker/ioBroker.zigbee/tarball/herdsman --production --save --prefix "/opt/iobroker" (System call)
    npm
    WARN checkPermissions Missing write access to /opt/iobroker/node_modules/readline-utils/node_modules/mute-stream
    npm
    WARN checkPermissions Missing write access to /opt/iobroker/node_modules/serialport/node_modules/bindings
    npm WARN
    checkPermissions Missing write access to /opt/iobroker/node_modules/serialport/node_modules/nan
    npm
     ERR! path /opt/iobroker/node_modules/readline-utils/node_modules/mute-streamnpm ERR! code EACCES
    npm ERR! errno
     -13npm ERR! syscall access
    npm
     ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/readline-utils/node_modules/mute-stream'npm ERR!  { Error: EACCES: permission denied, access '/opt/iobroker/node_modules/readline-utils/node_modules/mute-stream'
    npm ERR!   stack: 'Error: EACCES: permission denied, access \'/opt/iobroker/node_modules/readline-utils/node_modules/mute-stream\'',
    npm ERR!   errno: -13,
    npm ERR!   code: 'EACCES',
    npm ERR!   syscall: 'access',
    npm
    ERR!   path: '/opt/iobroker/node_modules/readline-utils/node_modules/mute-stream' }npm ERR!
    npm ERR! The operation was rejected by your operating system.
    npm ERR!
     It is likely you do not have the permissions to access this file as the current usernpm ERR!
    npm ERR! If you believe this might be a permissions issue, please double-check the
    npm ERR! permissions of the file and its containing directories, or try running
    npm ERR! the command again as root/Administrator (though this is not recommended).
    npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2019-12-18T17_34_01_569Z-debug.log
    ERROR: host.RDJLTULLN Cannot install https://github.com/ioBroker/ioBroker.zigbee/tarball/herdsman: 243
    gibt es einen befehl per konsole?
    SRo769S Offline
    SRo769S Offline
    SRo769
    #114
    @MyzerAT Das scheint ein Rechteproblem zu sein - setze die Berechtigungen der angegebenen Verzeichnisse auf dem Slave nochmal neu. Nutzer/Eigentümer: iobroker mit Berechtigung 0755 rekursiv . Danach sollte die Installation klappen.
    • SRo769S SRo769
      AlCalzoneA Offline
      AlCalzoneA Offline
      AlCalzone
      #115
      @MyzerAT @SRo769 Einfacher ist es, den Fixer auszuführen. Der biegt auch gleich noch Berechtigungen im npm-Cache-Verzeichnis gerade.
      MyzerATM 1 Antwort Letzte Antwort
      • SRo769S SRo769
        @Xsev hatte ich auch einmal. Dann zurück auf Anfang - ich hoffe, du hast ein Backup. Du kannst den Adapter wieder zurück auf den Shepherd-Converter bringen und dann das Backup rein kopieren. Danach sollte wieder alles da sein (mit altem Stick). Danach nochmal der gleiche Weg: Converter auf Herdsman aktualisieren und dann den neuen Stick anklemmen, Adapter einschalten - nun sollten alle Geräte da sein und auch funktionieren. Hab das 2x getestet - hat jedesmal sauber funktioniert.
        XsevX Offline
        XsevX Offline
        Xsev
        schrieb am zuletzt editiert von Xsev
        #116
        @SRo769 Danke für die Info.
        Ich hab jetzt alles neu gepairt, was früher ein Drama war (Aquara und Xiamomi Senoren) ist mit dem neuen Stick ein Traum! Was mich früher einen halben Tag gekostet hat hab ich heute in 1,5 Stunden gemacht.
        Ergebniss:
        Soweit läuft wieder alles, hab noch ein paar Senoren die Fehler aber die kommen noch.
        Was interressant ist, ich konnte mir 3 Router sparen und 3 Osram Plugs die nur an strtegisch wichtigen Funkorten waren aber sonst keinen Nutzen hatten, die Plugs kann ich jetzt anderweitig gebrauchen und die Router hoffentlich in Ruhestand schicken..
        • MathiasJM Offline
          MathiasJM Offline
          MathiasJ
          #117
          Mir ist meine IObroker-Installation abgeschmiert.
          Nun habe ich wieder alles hinbekommen.
          Kann mir jemand die github-Seite geben, bei der ich den neuen Adapter installieren kann?
          Weil....einige backups sind da auch betroffen :(
          Danke schon mal im voraus
          IObroker auf dem NUC als VM.
          SRo769S 1 Antwort Letzte Antwort
          • X Offline
            X Offline
            xADDRx
            schrieb am zuletzt editiert von xADDRx
            #118
            mein neuer Stick ist nun da. Wollte alles neu pairen.
            bevor ich alles umsonst mache, ist das normal das es so aussieht und da off steht:
            Sonos, Intel Nuc, Iobroker Pro, Proxmox, IPad Air (Wand), Vis, Xiaomi, Devolo, Bose, Philips Hue, Instar, Synology
            AsgothianA arteckA 2 Antworten Letzte Antwort
            • X xADDRx
              AsgothianA Offline
              AsgothianA Offline
              Asgothian
              #119
              @xADDRx Ja
              X 1 Antwort Letzte Antwort
              • AsgothianA Asgothian
                @xADDRx Ja
                X Offline
                X Offline
                xADDRx
                #120
                @Asgothian huch, wie schnell... Danke!
                • MathiasJM MathiasJ
                  SRo769S Offline
                  SRo769S Offline
                  SRo769
                  #121
                  @MathiasJ https://github.com/ioBroker/ioBroker.zigbee/tarball/herdsman
                  MathiasJM 1 Antwort Letzte Antwort
                  • SRo769S SRo769
                    MathiasJM Offline
                    MathiasJM Offline
                    MathiasJ
                    schrieb am zuletzt editiert von MathiasJ
                    #122
                    @SRo769
                    vielen Dank...... Installation läuft :)
                    Den Link habe ich in meiner Sammlung gespeichert, für den Fall, ich brauche inn noch mal......
                    • AlCalzoneA AlCalzone
                      MyzerATM Offline
                      MyzerATM Offline
                      MyzerAT
                      #123
                      @AlCalzone
                      thx,habe ich gemacht und hat geklappt!
                      lg Rudi
                      Node 22.23.0
                      Nodejs 22.23.0
                      npm 10.9.8
                      js-controller 7.2.2
                      • XsevX Offline
                        XsevX Offline
                        Xsev
                        #124
                        Hat diese Einstellung eine Funktion mit dem neuen Stick? Ist mir vorher noch nie aufgefallen..
                        • XsevX Xsev
                          arteckA Offline
                          arteckA Offline
                          arteck
                          #125
                          @Xsev ja gilt aber auch nur für die genannten Platinen
                          • X xADDRx
                            arteckA Offline
                            arteckA Offline
                            arteck
                            #126
                            @xADDRx ja an der Karte bin ich noch dran
                            • P Offline
                              Phil85
                              #127
                              erstmal Vielen Dank an @dimaiv für die schnelle Lieferung des CC2538 Sticks. Er hat auf Anhieb einwandfrei funktioniert. Nur macht mir die Reichweite im Vergleich zum XIAMO Gateway ein bißchen sorgen. Habe bisher nur Xiaomo Sensoren gepairt welche auch auf Anhieb erkannt werden. Hab jetzt 10 Sensoren verbunden wobei alle außer 2 funktionieren. Die Sensoren befinden sich alle auf einem Stockwerk und die zwei nicht funktionierenden sind ca. 8m vom Stick entfernt. Link Quality aktualisiert sich nicht und in den Objekten steht was über 100. nur in der Map sind die zwei rot mit Wert eins. Ich habe den neuen herdsman 1.0.0b drauf. Das Xiaomi Gateway hatte bisher über 2 Stockwerke keine Probleme. Hat mir vielleicht einer einen Tipp wie ich die Reichweite positiv beeinflussen könnte. Geplant sind noch einige CC2530/CC2592 Router aber trotz allem habe ich mir eine wesentlich höhere Reichweite versprochen. Ich habe hier noch ein ziemlich starkes unifi Wlan Netzwerk, könnte das vielleicht der Grund sein. Zigbee und Wlan beides auf Kanal 11. Sollte sich ja nicht überschneiden
                              FredFF LatziL 2 Antworten Letzte Antwort
                              • P Phil85
                                FredFF Online
                                FredFF Online
                                FredF
                                Most Active Forum Testing
                                #128
                                @Phil85 sagte in wie ersetzte ich den CC2531/CC2530:
                                Doch tut es. Meine Probleme haben sich massiv verringert, seit ich den Unifi nicht mehr auf Kanal 11 laufen lasse.
                                P 1 Antwort Letzte Antwort
                                • P Phil85
                                  LatziL Online
                                  LatziL Online
                                  Latzi
                                  #129
                                  @Phil85
                                  ist der Stick direkt oder mit Verlängerung angeschlossen?
                                  • FredFF FredF
                                    Pascal51882
                                    #130
                                    @FredF Hieß es nicht irgendwo, dass der WLAN Kanal 11 und Zigbee Kanal 11 nicht das Gleiche sind sondern versetzt?
                                    • H Offline
                                      haiperf
                                      #131
                                      Ja. 11 und 11 sollte gehen.
                                      https://www.metageek.com/training/resources/zigbee-wifi-coexistence.html
                                      • P Offline
                                        Pascal51882
                                        #132
                                        So siehts bei mir aus.
                                        Meine direkten Nachbarn haben 4x FB7490 liegen auf WLAN Kanal 1. Wäre es sinnvoll Zigbee nach oben zu setzen? Was wäre hier dann sinnvoll? Kommen Xiaomi/Aqara, Philips Hue, Osram damit klar? Klar ist, dass ich alles neu anlernen muss.
                                        GarfonsoG 1 Antwort Letzte Antwort
                                        • P Pascal51882
                                          GarfonsoG Offline
                                          GarfonsoG Offline
                                          Garfonso
                                          #133
                                          @Pascal51882
                                          Ich habe mein zigbee Netz nach Analysen mit meinem Handy auf Kanal 16 gesetzt. Das ging mit allen, Aquara Sensoren, Hue Lampen (diverse von Iris über Lightstrips zu den Birnen) und Fernbedienungen, Osram Steckdosen und ein Lightstrip.
                                          Wenn du sicher sein willst, geht z.B. 15. Die Hue app bzw. Hue Bridge kann nur eine handvoll Kanäle (11,15, ...). Aber wie gesagt, selbst die Hue Gerät sind bei mir problemlos mit umgezogen.
                                          Ultimativer Lovelace Leitfaden: https://forum.iobroker.net/topic/35937/der-ultimative-iobroker-lovelace-leitfaden-dokumentation
                                          Lovelace UI Beispiele: https://forum.iobroker.net/topic/35950/zeigt-her-eure-lovelace-visualisierung
