  4. js-controller 2.0 ab sofort im Latest Repo
js-controller
1.1k Beiträge 89 Kommentatoren 527.5k Aufrufe 64 Beobachtet
  • L lonsimbt
    Habe heute das Update auf die neue Version eingespielt. Dabei tauchten folgende Fehlermeldungen in der Konsole auf:
    npm install iobroker.js-controller@2.0.25 --unsafe-perm --production --save --prefix "/opt/iobroker" (System call)
    In file included from ../src/unix_dgram.cc:5:
    ../../nan/nan.h: In function 'void Nan::AsyncQueueWorker(Nan::AsyncWorker*)':
    ../../nan/nan.h:2298:62: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]
         , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
    In file included from ../../nan/nan.h:54,
    ../src/unix_dgram.cc: At global scope:
    /home/iobroker/.node-gyp/10.16.3/include/node/node.h:573:43: warning: cast between incompatible function types from 'void (*)(v8::Local<v8::Object>)' to 'node::addon_register_func' {aka 'void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)'} [-Wcast-function-type]
           (node::addon_register_func) (regfunc),                          \
    /home/iobroker/.node-gyp/10.16.3/include/node/node.h:607:3: note: in expansion of macro 'NODE_MODULE_X'
       NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
    ../src/unix_dgram.cc:404:1: note: in expansion of macro 'NODE_MODULE'
     NODE_MODULE(unix_dgram, Initialize)
    In file included from /home/iobroker/.node-gyp/10.16.3/include/node/node.h:63,
    /home/iobroker/.node-gyp/10.16.3/include/node/v8.h: In instantiation of 'void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)]':
    /home/iobroker/.node-gyp/10.16.3/include/node/node_object_wrap.h:84:78:   required from here
    /home/iobroker/.node-gyp/10.16.3/include/node/v8.h:9502:16: warning: cast between incompatible function types from 'v8::WeakCallbackInfo<node::ObjectWrap>::Callback' {aka 'void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)'} to 'Callback' {aka 'void (*)(const v8::WeakCallbackInfo<void>&)'} [-Wcast-function-type]
                    reinterpret_cast<Callback>(callback), type);
    /home/iobroker/.node-gyp/10.16.3/include/node/v8.h: In instantiation of 'void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = Nan::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)]':
    ../../nan/nan_object_wrap.h:65:61:   required from here
    /home/iobroker/.node-gyp/10.16.3/include/node/v8.h:9502:16: warning: cast between incompatible function types from 'v8::WeakCallbackInfo<Nan::ObjectWrap>::Callback' {aka 'void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)'} to 'Callback' {aka 'void (*)(const v8::WeakCallbackInfo<void>&)'} [-Wcast-function-type]
    Das scheint aber keine Auswirkungen auf die Funktionsfähigkeit gehabt zu haben. Das Update ist bis zum Ende durchgelaufen.
    Die Umstellung auf redis für Objekte hat problemlos funktioniert. Das System fühlt sich damit insgesamt deutlich "fluffiger" an. Kein Auffälligkeiten soweit in den Logs.
    Gruß Marco
    apollon77A
    apollon77A
    #110
    @lonsimbt Welche nodejs Version hast Du? An der Stelle sind es erstmal nur "compiler Warnungen" von einem nativen Paket. Kann passieren, und hat ist kein Fehler und daher ok.
    L 1 Antwort Letzte Antwort
    • apollon77A apollon77
      @mameier1234 versuch mal bitte sonos GitHub version ... geht die?
      M
      M
      mameier1234
      #111
      @apollon77 Sonos Github, Check ! Läuft und keine Fehler mehr.
      Grüße,
      Martin
      • M mameier1234
        apollon77A
        apollon77A
        #112
        @mameier1234 Habe es auf latest released und oben ergänzt
        BBTownB 1 Antwort Letzte Antwort
          BBTownB
          BBTownB
          BBTown
          #113
          @apollon77 das Problem mit der HomeMatic Heizungssteuerung unter iQontrol ist mit der heute erschienenen iQontrol v0.2.12 behoben.
          Falls Du dein FAQ oder die Adapterversion im ersten Post aktualisieren möchtest.
          ioBroker auf NUC (VM debian v13 (Trixie ), node v24.22.2 npm v11.19.0, js-controller v7.2.5 jsonl/jsonl / HomeMatic CCU-2 (Wired und Funk) / Philips HUE / echo.DOT / Broadlink RM pro / SONOS
            @MathiasJ https://github.com/AlCalzone/ioBroker.ble/issues/226 habe ich mal für Dich angelegt
            MathiasJM
            MathiasJM
            MathiasJ
            schrieb am zuletzt editiert von MathiasJ
            #114
            @apollon77
            Danke erst mal.
            Aufgeschoben ist ja nicht aufgehoben.
            Natürlich werde ich auf den JS Version 2.0 umsteigen. Dazu brauche ich aber Zeit und die Muse dazu.
            Im Moment habe ich aber andere Dinge im Kopf
            Zudem funktionieren 3 Adapter nicht.
            1. BLE
              2.Radar2 v1.2.0 ich brauche leider hci only, weil ich einen USB Dongle weiter weg legen muss. Das ganze mache ich mit USB Extender und 10m LAN Kabel. Die v1.0.9 kann das aber noch nicht. Mit Noble habe ich laufend Aussetzer.
            2. Broadlink geht anscheinend auch noch nicht.
            IObroker auf dem NUC als VM.
            • BBTownB BBTown
              apollon77A
              apollon77A
              #115
              @BBTown Done
              • MathiasJM MathiasJ
                @apollon77
                Danke erst mal.
                1. BLE
                apollon77A
                apollon77A
                #116
                @MathiasJ Zu Radar2 GitHub-Version und Broadlink stehen in der FAQ die Lösungen. Verifiziert von einigen Usern. Eine Datei suchen und in allen Stellen ersetzen. Das ist easy. kannst Du auch schon vor dem Update tun, schadet auch bei der 1.5.14 nicht.
                Laufen bei mir beide damit.
                BLE habe ich das Issue angelegt, denke AlCalzone schaut sobald er Zeit hat. Das läuft interessanterweise bei mir auch, aber da steckt der Teufel ja in den verwendeten Geräten denke ich.
                MathiasJM 1 Antwort Letzte Antwort
                • crunchipC
                  crunchipC
                  Developer Global Moderator Most Active Forum Testing
                  #117
                  was mir noch aufgefallen ist, durch das update auf 2.0 ist mein Speichervolumen des Datenträgers um knapp 10% (knapp 1GB) geschrumpft.
                  Danach habe ich spaßeshalber zum Test mal komplett auf Redis umgestellt, kann da aber auch keine Performance Änderungen feststellen. Macht also scheinbar überhaupt keinen Sinn.
                  Im Gegenteil, meine CPU Auslastung ist im Moment sogar minimal höher als vor dem Update.
                    MathiasJM
                    MathiasJM
                    MathiasJ
                    #118
                    @apollon77
                    Also doch warten.....
                    Ich habe da 2 Slaves:
                    1 Slave läuft rpi und Radar2 (sollte laufen
                    2. Slave läuft rpi und ble (läuft nicht)
                    3. Master da läuft die VIS, JS Energie, MI home etc.
                    Ich warte noch bis das Problem mit dem Adapter BLE geklärt ist.
                    Ist jetzt nicht böse gemeint, aber mit ble und rpi2 läuft meine automatische Gießanlage
                    Edit
                    neues Multihost aufgesetzt:
                    Alle Instanzen sind grün, obwohl ich Radar2 v1.2.0, ble v 0.10.0 und Broaadlink 2.0.0 laufen habe.
                    ich habe keine Dateien lt FAQ geändert.......
                    nun heißt es, produktives System herunter fahren.......
                      apollon77A
                      apollon77A
                      #119
                      @crunchip also den zusätzlichen Speicherverbrauch kann ich nicht bestätigen und er würde auch keinerlei Sinn machen. Es sind Paketabhängigkeiten aktualisiert aber das sollte nicht so einen Effekt haben. und ohne das du jetzt sagen kannst wo der Platz weg ist ist es sehr schwierig das in direkte Verbindung zu bringen.
                      Zu redis/redis hat niemand gesagt das es bestimmte Effekte hat und ja es kann sein das cpu damit leicht hoch geht. Redis/redis hat auch ganz andere Zielsetzungen, wie es auch im Text oben steht. Es ist die Basis beispielsweise für ein high availability System wobei automatischer failover zwischen zwei hosts oder ein Cluster Ansatz möglich wird.
                      Redis/redis ist nichts was man haben MUSS wenn man es nicht braucht ;-)
                      Hier gilt wieder mal: man muss sich überlegen was man warum braucht und dann das wählen was für sein System sinn macht bzw nötig ist.
                        @apollon77
                        Edit
                        apollon77A
                        apollon77A
                        #120
                        @MathiasJ Radar2 und broadlink explodieren nicht direkt aber im logs zeigen eine fehler. Und der weißt auf was hin. Welche genaue Auswirkung der hat weiß ich nicht.
                        Zu Ble: wie gesagt tut ja bei mir auch. Also ist die. Frage was dein Prod System da genau hat. Und das muss AlCalzone checken.
                          crunchipC
                          crunchipC
                          #121
                          @apollon77 ich wollte halt einfach nur mal testen, ob und was sich tut, wenn ich auf redis umstelle.
                          Beobachten konnt ich schön die veränderte Cpu Auslastung, da ich mir das in Grafana darstellen lasse
                          Bezüglich des Speicherverbrauchs, kann ich nur dies so wiedergeben, wie ich es hier vorfinde, und das ist nun mal
                          • vor dem Update 36% frei
                          • nach dem Update 26% frei
                          ohne sonst irgend etwas gemacht zu haben.
                          Vllt liegt es auch daran, das meine Iobroker Installation generell sehr groß ist und ich sehr viele Adapter installiert habe.
                          Die Frage ist, wie und wo sollte/könnte ich suchen.
                            MathiasJM
                            MathiasJM
                            MathiasJ
                            #122
                            @apollon77
                            negativ...... Anwesenheit wird erkannt, im Log finde ich nichts.......
                            Broadlink läßt sich auch bedienen...der TV geht zumindest ein und aus......
                            Mein produktives System hat nichts, läuft noch auf JS-Controller 1.5.....
                            ich habe das prod. System nur ausgeschaltet und nun läuft das Testsystem mit JS 2.0
                            Das einizige, das mir auf den Zeiger geht, paw will ein nicht vorhandenes Update. Das hatte er aber schon vorher.
                            Was mir aufgefallen ist, der Slave mit dem Raspberry PI 3B+ wird 5 Grad heißer als vorher.....
                              apollon77A
                              apollon77A
                              #123
                              @crunchip das redis/redis leicht mehr cpu braucht ist schon bekannt und hier werden wir weiter optimieren.
                              Es kann aber sich sein das das nur ist weil redis als dB schneller antwortet. Damit: es gibt einfach höheren Durchsatz. Und ja damit höhere cpu Last.
                              Ich denke aber das die Größenordnung von der wir reden vollkommen ok ist.
                                @apollon77
                                apollon77A
                                apollon77A
                                #124
                                @MathiasJ 5 grad heißer ... ist das schlimm? Siehe sich letzter Post. Generell braucht der Controller 2.0 etwas weniger cpu Last, aber hat ein anderen gesamtverhalten. Die Berichte davon das es schneller ist bedeuten dann das der Durchsatz höher ist was generell ein anderes lastverhalten bedeutet.
                                Durch den rewrite ist ein Vergleich auf der Ebene Äpfel und Birnen. ;-) aber interessant Erkenntnis.
                                  MathiasJM
                                  MathiasJM
                                  MathiasJ
                                  #125
                                  @apollon77
                                  Was mich aber wundert, dass Radar und Broadlink ohne Änderungen läuft.
                                  Du hast ja geschrieben, dass man da was ändern soll.......
                                  das kann ich jetzt nicht bestätigen ;)
                                  dafür hat sich gerade der Slave verabschiedet 😞
                                  • arteckA
                                    arteckA
                                    arteck
                                    #126
                                    @MathiasJ @crunchip euch ist aber schon klar dass mehr Funktionen auch mit mehr an Ressourcen zusammen hängt. Es ist halt so da Rede mehr verbraucht..klar es ackert auch mehr.. Vorher hast du mehr sd oder Platten Zugriffe gehabt..
                                    Ich für mich muss sagen und ich habe es schon seid 1 Monat produktiv laufen.. ES IST BESSER.. Performanter
                                    ergo auch die lade Zeit von der Visu ist besser
                                    Und mein System ist auch nicht gerade klein..
                                    MathiasJM ChaotC 2 Antworten Letzte Antwort
                                      @apollon77
                                      apollon77A
                                      apollon77A
                                      #127
                                      @MathiasJ sagte in js-controller 2.0 ab sofort im Latest Repo:
                                      Logs?details?
                                      • arteckA arteck
                                        MathiasJM
                                        MathiasJM
                                        MathiasJ
                                        #128
                                        @arteck
                                        ist schon klar......
                                        wie gesagt, ist auch nur mein Testsystem.....
                                        @apollon77 Slave läuft...... man sollte bei der Überwachung vielleicht auch die richtige IP eingeben......
                                        • arteckA arteck
                                          ChaotC
                                          ChaotC
                                          Chaot
                                          #129
                                          @arteck Hast du redis/redis oder file/redis?
                                          Oder anders gefragt:
                                          Bringt die Umstellung von file/redis auf redis/redis noch Geschwindigkeit oder macht das dann eher nichts aus?
                                          Prozessorlast und Speicher ist mir eher nebensächlich.
                                          33.2k
                                          84.3k
