  4. INTEL NUC Kit NUC8i5BEK Proxmox+Debian VM kein Onboard BT
189 Beiträge 18 Kommentatoren 32.6k Aufrufe 10 Beobachtet
  • S Superdad
    Ausgabe von dmesg in Proxmox.
    root@pve:~# dmesg | grep tooth
    [    5.428947] Bluetooth: Core ver 2.22
    [    5.428965] Bluetooth: HCI device and connection manager initialized
    [    5.428995] Bluetooth: HCI socket layer initialized
    [    5.428999] Bluetooth: L2CAP socket layer initialized
    [    5.429003] Bluetooth: SCO socket layer initialized
    [    5.433876] Bluetooth: hci0: Firmware revision 0.1 build 184 week 15 2019
    [    8.031647] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
    [    8.031649] Bluetooth: BNEP filters: protocol multicast
    [    8.031652] Bluetooth: BNEP socket layer initialized
    [   12.070350] Bluetooth: hci0: urb 000000008df1e450 failed to resubmit (2)
    [  164.403866] Bluetooth: hci0: Firmware revision 0.1 build 184 week 15 2019
    [  256.967089] Bluetooth: hci0: urb 000000003ff3f2ed failed to resubmit (2)
    [  930.768975] Modules linked in: tcp_diag inet_diag nfsv3 nfs_acl nfs lockd grace fscache veth ip_set ip6table_filter ip6_tables iptable_filter cmac bnep softdog nfnetlink_log nfnetlink nls_iso8859_1 dm_thin_pool dm_persistent_data dm_bio_prison dm_bufio libcrc32c snd_hda_codec_hdmi intel_rapl x86_pkg_temp_thermal intel_powerclamp coretemp snd_hda_codec_realtek snd_hda_codec_generic kvm_intel kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcbc aesni_intel aes_x86_64 crypto_simd glue_helper cryptd snd_soc_skl snd_soc_skl_ipc snd_hda_ext_core snd_soc_sst_dsp snd_soc_sst_ipc snd_soc_acpi i915 snd_soc_core snd_compress ac97_bus snd_pcm_dmaengine wmi_bmof intel_wmi_thunderbolt drm_kms_helper drm intel_cstate i2c_algo_bit fb_sys_fops btusb btrtl btbcm btintel iwlmvm bluetooth mac80211 rtsx_pci_ms
    [ 2094.425954] Bluetooth: hci0: Firmware revision 0.1 build 184 week 15 2019
    [ 2195.809396] Bluetooth: hci0: urb 00000000f2205b5e failed to resubmit (2)
    [ 4613.078873] Bluetooth: hci0: Firmware revision 0.1 build 184 week 15 2019
    [ 4616.769724] Bluetooth: hci0: urb 000000001b52b7b8 failed to resubmit (2)
    [ 4767.795902] Bluetooth: hci0: Firmware revision 0.1 build 184 week 15 2019
    [ 9174.243886] Bluetooth: hci0: Firmware revision 0.1 build 184 week 15 2019
    [ 9177.776850] Bluetooth: hci0: urb 00000000dc56a48b failed to resubmit (2)
    [ 9262.249870] Bluetooth: hci0: Firmware revision 0.1 build 184 week 15 2019
    [ 9290.733310] Bluetooth: hci0: urb 000000002a962bfd failed to resubmit (2)
    [ 9586.752868] Bluetooth: hci0: Firmware revision 0.1 build 184 week 15 2019
    [ 9607.213728] Bluetooth: hci0: urb 00000000c3d97bb3 failed to resubmit (2)
    [10153.768841] Bluetooth: hci0: Firmware revision 0.1 build 184 week 15 2019
    [10253.982889] Bluetooth: hci0: urb 00000000fc0a1aee failed to resubmit (2)
    [11506.075844] Bluetooth: hci0: Firmware revision 0.1 build 184 week 15 2019
    [11561.341543] Bluetooth: hci0: urb 000000006e2e8cd1 failed to resubmit (2)
    [12533.847878] Bluetooth: hci0: Firmware revision 0.1 build 184 week 15 2019
    [12536.773457] Bluetooth: hci0: urb 000000006e2719f4 failed to resubmit (2)
    unltdnetworxU Offline
    unltdnetworx
    #143
    @Superdad
    Ich hoffe ohne die 17-2??!
    Gruß, Michael
    Weitere Infos im Profil.
    Wenn euch der Beitrag weitergeholfen hat, könnt ihr die Bewertung rechts unten im Beitrag nutzen.
      Superdad
      schrieb am zuletzt editiert von Superdad
      #144
      Muss ich schauen.
      Ups! Die waren drin.
      Habs sie jetzt rausgenommen und neu rebootet.
      CCU3
      iOBroker auf IntelNUC Proxmox
      • S Superdad
        Muss ich schauen.
        crunchipC Offline
        crunchipC Offline
        #145
        @Superdad na sieht nicht so aus, da stimmt was nicht mit deiner Firmware...so kann auch nix in IoBroker laufen
        • unltdnetworxU Offline
          unltdnetworx
          #146
          Ich tippe darauf, dass die 17-2 Version drin ist. Die hat wie bereits geschrieben nicht funktioniert.
          Gruß, Michael
            Superdad
            #147
            Habe jetzt alle 17er drin gelassen, außer die 17-2er.
            Rebootet und ble bleibt trotzdem gelb.
            CCU3
              Superdad
              #148
              Das kommt bei gestoppter VM:
              root@pve:~# dmesg |grep iwlwifi
              [    5.096398] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
              [    5.120563] iwlwifi 0000:00:14.3: loaded firmware version 34.3125811985.0 op_mode iwlmvm
              [    5.183248] iwlwifi 0000:00:14.3: Detected Intel(R) Dual Band Wireless AC 9560, REV=0x318
              [    5.349523] iwlwifi 0000:00:14.3: Microcode SW error detected. Restarting 0x0.
              [    5.349531] iwlwifi 0000:00:14.3: Not valid error log pointer 0x00000000 for Init uCode
              [    5.349568] iwlwifi 0000:00:14.3: SecBoot CPU1 Status: 0x3, CPU2 Status: 0x2458
              [    5.349571] iwlwifi 0000:00:14.3: Failed to start INIT ucode: -5
              [    5.361808] iwlwifi 0000:00:14.3: Failed to run INIT ucode: -5
              [  405.231295]  fb_sys_fops zavl(PO) iwlwifi snd_hda_codec syscopyarea intel_rapl_perf memstick ecdh_generic sysfillrect icp(PO) sysimgblt snd_hda_core wmi_bmof mei_me intel_wmi_thunderbolt snd_hwdep mei snd_pcm snd_timer snd cfg80211 soundcore pcspkr intel_pch_thermal shpchp wmi video mac_hid acpi_pad zcommon(PO) znvpair(PO) spl(O) vhost_net vhost tap ib_iser rdma_cm iw_cm ib_cm ib_core iscsi_tcp libiscsi_tcp libiscsi scsi_transport_iscsi sunrpc ip_tables x_tables autofs4 btrfs xor zstd_compress raid6_pq rtsx_pci_sdmmc e1000e(O) ptp pps_core i2c_i801 rtsx_pci ahci libahci
              und
              root@pve:~# lsusb -t
              /:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/6p, 10000M
              /:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/12p, 480M
                  |__ Port 10: Dev 2, If 0, Class=Wireless, Driver=btusb, 12M
                  |__ Port 10: Dev 2, If 1, Class=Wireless, Driver=btusb, 12M
              CCU3
              • S Superdad
                crunchipC Offline
                crunchipC Offline
                #149
                @Superdad lösch mal dein durchgereichtes Bluetooth Gerät in der VM und beende diese
                dann schaust auf deinem Host
                hciconfig -a
                und dann
                hciconfig hci0 up
                  Superdad
                  #150
                  root@pve:~# hciconfig -a
                  hci0:   Type: Primary  Bus: USB
                          BD Address: D8:F2:CA:31:D5:2A  ACL MTU: 1021:4  SCO MTU: 96:6
                          UP RUNNING
                          RX bytes:745 acl:0 sco:0 events:51 errors:0
                          TX bytes:2187 acl:0 sco:0 commands:51 errors:0
                          Features: 0xbf 0xfe 0x0f 0xfe 0xdb 0xff 0x7b 0x87
                          Packet type: DM1 DM3 DM5 DH1 DH3 DH5 HV1 HV2 HV3
                          Link policy: RSWITCH SNIFF
                          Link mode: SLAVE ACCEPT
                          Class: 0x000104
                          Service Classes: Unspecified
                          Device Class: Computer, Desktop workstation
                          HCI Version:  (0x9)  Revision: 0x100
                          LMP Version:  (0x9)  Subversion: 0x100
                          Manufacturer: Intel Corp. (2)
                  root@pve:~# hciconfig hci0 up
                  root@pve:~#
                  CCU3
                  unltdnetworxU 1 Antwort Letzte Antwort
                  • S Superdad
                            UP RUNNING
                            Class: 0x000104
                    root@pve:~#
                    unltdnetworx
                    #151
                    @Superdad
                    Auch im Host keine 17-2?
                    Gruß, Michael
                    • S Superdad
                      und
                      crunchipC Offline
                      crunchipC Offline
                      #152
                      @Superdad sagte in INTEL NUC Kit NUC8i5BEK Proxmox+Debian VM kein Onboard BT:
                      im Netz hab ich was von einer
                      Firmware-Version 46.3
                      gelesen
                        Superdad
                        #153
                        Ich habe die Dateien nur im Host.
                        Im iobroker (VM) gibt es ja keinen Firmware-Ordner.
                        CCU3
                        • unltdnetworxU unltdnetworx
                          @Superdad
                          crunchipC Offline
                          crunchipC Offline
                          #154
                          @unltdnetworx nein, raus damit
                            Superdad
                            #155
                            Die sind ja raus im Host.
                            CCU3
                              unltdnetworx
                              #156
                              Die Ordner mal erstellen?
                              Gruß, Michael
                                crunchipC Offline
                                crunchipC Offline
                                #157
                                @unltdnetworx nö
                                  @unltdnetworx nö
                                  unltdnetworx
                                  #158
                                  @crunchip
                                  War nur eine Idee. Wie gesagt, Ubuntu und grün
                                  Gruß, Michael
                                    Superdad
                                    #159
                                    Das kommt in der VM:
                                    root@iOBrokerNUC:~# lsusb -t
                                    /:  Bus 05.Port 1: Dev 1, Class=root_hub, Driver=ehci-pci/6p, 480M
                                    /:  Bus 04.Port 1: Dev 1, Class=root_hub, Driver=uhci_hcd/2p, 12M
                                    /:  Bus 03.Port 1: Dev 1, Class=root_hub, Driver=uhci_hcd/2p, 12M
                                    /:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=uhci_hcd/2p, 12M
                                        |__ Port 1: Dev 2, If 0, Class=Wireless, Driver=, 12M
                                        |__ Port 1: Dev 2, If 1, Class=Wireless, Driver=, 12M
                                    /:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=uhci_hcd/2p, 12M
                                        |__ Port 1: Dev 2, If 0, Class=Human Interface Device, Driver=usbhid, 12M
                                    CCU3
                                    • S Superdad
                                      crunchipC Offline
                                      crunchipC Offline
                                      #160
                                      @Superdad was zeigt auf der VM
                                      hciconfig dev
                                        Superdad
                                        #161
                                        root@iOBrokerNUC:~# hciconfig dev
                                        Can't get device info: No such device
                                        CCU3
                                          Superdad
                                          #162
                                          Habe gerade festgestellt, dass Bluetooth-Service nicht automatisch startet.
                                          Und wenn ich unter Hardware nicht USB 1-10 durchgereicht habe, also nix drin steht, kann ich auch den Buetooth-Service nicht starten.
                                          Dass funktioniert erst wenn die Hardware durchgereicht ist.
                                          CCU3
