  4. Adapter: iobroker.backitup (stable Release)
adapterbackitupiobroker backupbackupiobroker.backitup
2.3k Beiträge 185 Kommentatoren 1.6m Aufrufe 50 Beobachtet
  • simatecS Offline
    simatecS Offline
    simatec
    #883
    Bitte mal einen Log posten
    • Besuche meine Github Seite
    • HowTo Restore ioBroker
    • Homer.J.H Offline
      Homer.J.H Offline
      Homer.J.
      #884
      ! Gestartet…
      ! [DEBUG] [mount] start with {"mountType":"CIFS","type":"storage","source":"Local","mount":"//DiskStation1517","deleteOldBackup":false,"dir":"sharename/backupDir","user":"steffen","pass":"","backupDir":"/opt/iobroker/backups"}
      ! [ERROR] [mount] - [undefined Unable to apply new capability set.
      ! [ERROR] [mount] - [IGNORED] Error: Command failed: mount -t cifs -o user=steffen,password=!!!!,rw,file_mode=0777,dir_mode=0777 //DiskStation1517/sharename/backupDir /opt/iobroker/backups
      ! Unable to apply new capability set.
      ! [DEBUG] [ccu] start with {"type":"creator","time":"10:25","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"Local","mount":"//DiskStation1517","deleteOldBackup":false,"dir":"sharename/backupDir","user":"steffen","pass":"
      ","context":{"fileNames":[],"errors":{},"done":[],"types":[]},"adapter":null},"history":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"telegram":{"enabled":true,"type":"message","instance":"telegram.0","systemLang":"de"},"host":"192.168.178.51","user":"Admin","pass":"","backupDir":"/opt/iobroker/backups"}
      ! [DEBUG] [ccu] - CCU Version: 3.37.8.20180929
      ! [DEBUG] [ccu] - Requesting backup from CCU
      ! [DEBUG] [ccu] - done
      ! [DEBUG] [cifs] start with {"mountType":"CIFS","type":"storage","source":"Local","mount":"//DiskStation1517","deleteOldBackup":false,"dir":"sharename/backupDir","user":"steffen","pass":"
      ","backupDir":"/opt/iobroker/backups","deleteBackupAfter":0}
      ! [DEBUG] [cifs] - done
      ! [DEBUG] [clean] start with {"deleteBackupAfter":0}
      ! [DEBUG] [clean] - done
      ! [DEBUG] [telegram] start with {"type":"creator","time":"10:25","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"Local","mount":"//DiskStation1517","deleteOldBackup":false,"dir":"sharename/backupDir","user":"steffen","pass":"","context":{"fileNames":["/opt/iobroker/backups/homematic_2018_10_11-10_27_20_3.37.8.20180929_backupiobroker.tar.sbk"],"errors":{},"done":["ccu"],"types":["homematic"]},"adapter":null},"history":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"telegram":{"enabled":true,"type":"message","instance":"telegram.0","systemLang":"de","time":"11 Oktober 2018 um 10:27 Uhr"},"host":"192.168.178.51","user":"Admin","pass":"","backupDir":"/opt/iobroker/backups"}
      ! [DEBUG] [telegram] - [ccu] used Telegram-Instance: telegram.0
      ! [DEBUG] [telegram] - done
      ! [DEBUG] [history] start with {"type":"creator","time":"10:25","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"Local","mount":"//DiskStation1517","deleteOldBackup":false,"dir":"sharename/backupDir","user":"steffen","pass":"","context":{"fileNames":["/opt/iobroker/backups/homematic_2018_10_11-10_27_20_3.37.8.20180929_backupiobroker.tar.sbk"],"errors":{},"done":["ccu"],"types":["homematic"]},"adapter":null},"history":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de","time":"11 Oktober 2018 um 10:27 Uhr"},"telegram":{"enabled":true,"type":"message","instance":"telegram.0","systemLang":"de"},"host":"192.168.178.51","user":"Admin","pass":"","backupDir":"/opt/iobroker/backups"}
      ! [DEBUG] [history] - backitup.0.history.html
      ! [DEBUG] [umount] start with {"mountType":"CIFS","type":"storage","source":"Local","mount":"//DiskStation1517","deleteOldBackup":false,"dir":"sharename/backupDir","user":"steffen","pass":"****","backupDir":"/opt/iobroker/backups"}
      ! [ERROR] [umount] - umount: /opt/iobroker/backups: must be superuser to unmount
      ! [ERROR] [umount] - [IGNORED] Error: Command failed: umount /opt/iobroker/backups
      ! umount: /opt/iobroker/backups: must be superuser to unmount
      ! [EXIT] 0
      • Homer.J.H Offline
        Homer.J.H Offline
        Homer.J.
        #885
        Das ist jetzt die Log Datei von manuellen Backup, wie bekomme ich vom autom. Backup die Log Datei. ?
        • simatecS Offline
          simatecS Offline
          simatec
          #886
          Bei dir fehlt in den Einstellungen die Pfadangabe zu deinem NAS.
          • Homer.J.H Offline
            Homer.J.H Offline
            Homer.J.
            #887
            Hat bis vor 3 Tagen mit den Einstellungen so funktioniert, wenn ich manuell Anstoße wird das Backup auch in den Ordner wie vorher gespeichert, beim automatischen löscht er mir zwar das alte legt aber eben kein neues an.Ich gebe mal einen neuen Pfad an und versuche es nochmal so.
            Bei mir läuft aber auch IoBroker im docker weiß nicht ob es da Unterschiede gibt. ?
            • simatecS Offline
              simatecS Offline
              simatec
              #888
              Kann sein, dass durch ein Update deine Pfadangabe verloren gegangen ist.
              Da wurde was geändert.
              • Homer.J.H Offline
                Homer.J.H Offline
                Homer.J.
                #889
                Kannst du mir vielleicht einen Tipp geben über die Pfadeingabe habe die Ordner so Angelegt.
                • simatecS Offline
                  simatecS Offline
                  simatec
                  #890
                  Ich kenne Diskstation leider nicht.
                  Aber theoretisch sollte der Pfad „Sicherung/iobroker_…..“ sein.
                  • Homer.J.H Offline
                    Homer.J.H Offline
                    Homer.J.
                    #891
                    Hab das noch im Log stehen, heißt denke ich das ich keine Verbindung zur Diskstation habe.
                    Benutzer und Passwort sind richtig woran könnte es noch liegen.
                    ! backitup.0
                    ! 2018-10-11 15:45:55.374
                    ! error
                    ! backitup.0
                    ! error
                    ! Error: Command failed: mount -t cifs -o user=steffen,password=!!!!!,rw,file_mode=0777,dir_mode=0777 //192.168.178.33/volume3/Sicherung/ioBroker_minimal /opt/iobroker/backups
                    • simatecS Offline
                      simatecS Offline
                      simatec
                      #892
                      Ist das dein Passwort oder nur blind gemacht?
                      Hast du das Paket cifs-utils installiert?
                      „sudo apt-get install cifs-utils“
                      Siehe Doku
                      • Homer.J.H Offline
                        Homer.J.H Offline
                        Homer.J.
                        #893
                        Ist nur Blind gemacht.
                        Paket ist übers Terminal installiert.
                        Hab auch keine Ahnung was ich noch machen soll.
                        • simatecS Offline
                          simatecS Offline
                          simatec
                          #894
                          Wenn dein Passwort Sonderzeichen hat, setze es mal in den Einstellungen in Anführungszeichen.
                          Statt der IP kannst du auch den Hostname deiner Diskstation mal probieren.
                          Sind die Freigaben in der Diskstation alle eingerichtet?
                          Probiere mal alternativ die nfs Freigabe in deiner Diskstation.
                          • BluefoxB Offline
                            BluefoxB Offline
                            #895
                            Kommando ist fehlgeschlagen, weil vermutlich schon gemountet ist.
                            Und umount nicht funktioniert, weil
                            • dslraserD Offline
                              dslraserD Offline
                              dslraser
                              #896
                              @Bluefox:
                              ```` `  Aha, jetzt kommen wir der Sache näher.
                              Mein ioBroker läuft auf einer Synology Diskstation im Docker, welcher gemountet ist.
                              Ich bekomme die gleichen Fehlermeldungen. FTP hingegen funktioniert.
                              Wie kann man das nun über Cifs oder NFS lösen ?
                              • Homer.J.H Offline
                                Homer.J.H Offline
                                Homer.J.
                                #897
                                Ich hatte vorher das Script von buanet laufen im Aufgabenplaner auf der DS und es jetzt deaktiviert, hat es damit etwas zu tun. ?
                                • simatecS Offline
                                  simatecS Offline
                                  simatec
                                  #898
                                  Eventuell ist da noch der mount vorhanden.
                                  Mach mal ein „sudo umount /opt/iobroker/backups“ über Konsole
                                  Und dann probiere mal manuell zu mounten, damit du erstmal testen kannst, ob deine ganzen Pfade stimmen.
                                  • J Offline
                                    jeti
                                    #899
                                    ich hatte gestern einen selbstverschuldeten Stromausfall, hier ist so einiges nun durcheinander… wo finde ich denn in einem alten Backup, ja diese habe ich, möchte ich aber nicht komplett einspielen, die configuration von backitup?
                                    Ich hänge an der CIFS Konfiguration die ich vorher am laufen hatte, aber in den Backups nicht finde ...
                                    Danke und Gruß
                                    EDIT: ok, CIFS geht wieder -> aber interessehalber, wo legt iobroker die ganzen configs ab?
                                    • simatecS Offline
                                      simatecS Offline
                                      simatec
                                      #900
                                      In dem minimal backup ist eine json.
                                      In der könntest du mit einem Editor schauen.
                                      Bin aber gerade nicht am Rechner, um selber zu schauen.
                                      • R Offline
                                        Ritter
                                        #901
                                        ich habe iobroker unter Windows laufen. Braucht man hierfür auch cifs-utils? Wenn ja, wie installiert man das? Bekomme nämlich die Synology Diskstation nicht gemountet.
                                        • Homer.J.H Offline
                                          Homer.J.H Offline
                                          Homer.J.
                                          #902
                                          hab es jetzt mal auf meiner Testumgebung installiert Pfad eingegeben, die Testumgebung habe ich auf einem Tinker laufen und funktioniert wunderbar.
                                          Die selbe Einstellung auf der DS funktioniert nicht was muss ich ändern.
