  3. Einsteigerfragen
  4. Installation
  5. Hiler für den Umzug auf Fujitsu Rechner
50 Beiträge 5 Kommentatoren 1.0k Aufrufe 6 Beobachtet
  • B
    B
    brokeling
    ```bash
    Script v.2026-10-01
    *** BASE SYSTEM ***
    Operating System: Debian GNU/Linux 13 (trixie)
     Static hostname: debian
           Icon name: computer-desktop
             Chassis: desktop 🖥️
              Kernel: Linux 6.12.115+deb13.1-amd64
        Architecture: x86-64
     Hardware Vendor: FUJITSU
      Hardware Model: ESPRIMO Q958
    Firmware Version: V5.0.0.13 R1.25.0 for D3613-A1x
       Firmware Date: Tue 2020-06-30
        Firmware Age: 6y 4month 3d
    OS is similar to:
    model name      : Intel(R) Core(TM) i5-8500T CPU @ 2.10GHz
    Docker          : false
    Virtualization  : none
    Unknown
    Kernel          : x86_64
    Userland        : 64bit
    Installation date unknown (filesystem does not support birth time).
    Systemuptime and Load:
     20:12:31 up 20 min,  1 user,  load average: 0.28, 0.18, 0.11
    CPU threads     : 6
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'trixie'!
    *** TIME AND TIMEZONES ***
                   Local time: Mon 2026-11-02 20:12:31 CET
               Universal time: Mon 2026-11-02 19:12:31 UTC
                     RTC time: Mon 2026-11-02 19:12:31
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    fu
    HOME=/home/fu
    GROUPS=fu cdrom floppy sudo audio dip video plugdev users netdev iobroker
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video plugdev redis
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         Unknown
    Display-Manager:        Not found
    Desktop:
    Session:                tty
    Boot Target:            multi-user.target
    *** MEMORY ***
    Mem:             16G        562M         15G        3.8M        265M         15G
    Swap:            16G          0B         16G
    Total:           33G        562M         32G
    Active iob-Instances:   1
            15739 M total memory
              536 M used memory
              229 M active memory
               94 M inactive memory
            15213 M free memory
               40 M buffer memory
              212 M swap cache
            16123 M total swap
                0 M used swap
            16123 M free swap
    top - 20:12:31 up 20 min,  1 user,  load average: 0.28, 0.18, 0.11
    Tasks: 158 total,   1 running, 157 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  1.5 us,  0.0 sy,  0.0 ni, 98.5 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :  15739.7 total,  15212.7 free,    536.6 used,    254.1 buff/cache
    MiB Swap:  16124.0 total,  16124.0 free,      0.0 used.  15203.2 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    9 CRITICAL ERRORS DETECTED!
    Check 'sudo dmesg --level=emerg,alert,crit -T' for details
    *** FILESYSTEM ***
    udev           devtmpfs  7.7G     0  7.7G   0% /dev
    tmpfs          tmpfs     1.6G  916K  1.6G   1% /run
    /dev/sda2      ext4      452G  3.0G  426G   1% /
    tmpfs          tmpfs     7.7G     0  7.7G   0% /dev/shm
    efivarfs       efivarfs  192K   55K  133K  29% /sys/firmware/efi/efivars
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
    tmpfs          tmpfs     7.7G  2.5M  7.7G   1% /tmp
    /dev/sda1      vfat      975M  9.1M  966M   1% /boot/efi
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
    tmpfs          tmpfs     1.6G  4.0K  1.6G   1% /run/user/1000
    Messages concerning filesystems in dmesg (Last 15 lines only):
    [Mon Nov  2 19:51:39 2026] EXT4-fs (sda2): mounted filesystem 02539a68-0ad4-4a92-84fe-3f5e829ec662 ro with ordered data mode. Quota mode: none.
    [Mon Nov  2 19:51:40 2026] EXT4-fs (sda2): re-mounted 02539a68-0ad4-4a92-84fe-3f5e829ec662 r/w.
    Show mounted filesystems:
    TARGET      SOURCE    FSTYPE OPTIONS
    /           /dev/sda2 ext4   rw,relatime,errors=remount-ro
    `-/boot/efi /dev/sda1 vfat   rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro
    /var:
    525M    /var/
    291M    /var/cache
    284M    /var/cache/apt
    194M    /var/lib
    192M    /var/cache/apt/archives
    Archived and active journals take up 8M in the file system.
    /opt/iobroker/backups:
    du: cannot access '/opt/iobroker/backups/': No such file or directory
    /opt/iobroker/iobroker-data:
    21M     /opt/iobroker/iobroker-data/files
    12M     /opt/iobroker/iobroker-data/files/backitup.admin
    8.6M    /opt/iobroker/iobroker-data/files/admin.admin
    8.5M    /opt/iobroker/iobroker-data/files/backitup.admin/custom
    6.8M    /opt/iobroker/iobroker-data/files/backitup.admin/custom/assets/_virtual_mf___mfe_internal__ConfigCustomBackItUpSet__mf_owner__1__loadShare___mf_0_iobroker_mf_1_gui_mf_2_components__loadShare__.js-Bs-T0f9g.js
    6.7M    /opt/iobroker/iobroker-data/files/admin.admin/custom/assets/_virtual_mf___mfe_internal__AdminComponentEasyAccessSet__mf_owner__1__loadShare___mf_0_iobroker_mf_1_gui_mf_2_components__loadShare__.js-wBTkI4zM.js
    2.3M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-B8tnXn1c.js
    1.4M    /opt/iobroker/iobroker-data/files/backitup.admin/custom/assets/_virtual_mf___mfe_internal__ConfigCustomBackItUpSet__mf_owner__1__loadShare___mf_0_iobroker_mf_1_json_mf_2_config__loadShare__.js-CKWPej0K.js
    1.4M    /opt/iobroker/iobroker-data/files/admin.admin/custom/assets/_virtual_mf___mfe_internal__AdminComponentEasyAccessSet__mf_owner__1__loadShare___mf_0_iobroker_mf_1_json_mf_2_config__loadShare__.js-BgmCjhru.js
    USB-Devices by-id:
    USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
    please always prefer the links 'by-id':
    No Devices found 'by-id'
    No nvbackup.json found.
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v24.22.2
    /usr/bin/node           v24.22.2
    /usr/bin/npm            11.19.1
    /usr/bin/npx            11.19.1
    ✓ Node.js installation is correct
    Recommended versions are nodejs  Cannot read system.config: null (OK when migrating or restoring) and npm  Cannot read system.config: null (OK when migrating or restoring)
    nodejs:
      Installed: 24.22.2-1nodesource1
      Candidate: 24.22.2-1nodesource1
      Version table:
     *** 24.22.2-1nodesource1 1001
            500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages
         24.22.1-1nodesource1 1001
         24.22.0-1nodesource1 1001
         24.21.0-1nodesource1 1001
         24.20.0-1nodesource1 1001
         24.19.0-1nodesource1 1001
         24.18.1-1nodesource1 1001
         24.18.0-1nodesource1 1001
         24.17.0-1nodesource1 1001
         24.16.0-1nodesource1 1001
         24.15.0-1nodesource1 1001
         24.14.1-1nodesource1 1001
         24.14.0-1nodesource1 1001
         24.13.1-1nodesource1 1001
         24.13.0-1nodesource1 1001
         24.12.0-1nodesource1 1001
         24.11.1-1nodesource1 1001
         24.11.0-1nodesource1 1001
         24.10.0-1nodesource1 1001
         24.9.0-1nodesource1 1001
         24.8.0-1nodesource1 1001
         24.7.0-1nodesource1 1001
         24.6.0-1nodesource1 1001
         24.5.0-1nodesource1 1001
         24.4.1-1nodesource1 1001
         24.4.0-1nodesource1 1001
         24.3.0-1nodesource1 1001
         24.1.0-1nodesource1 1001
         24.0.2-1nodesource1 1001
         24.0.1-1nodesource1 1001
         24.0.0-1nodesource1 1001
         20.19.2+dfsg-1+deb13u3 500
            500 http://security.debian.org/debian-security trixie-security/main amd64 Packages
         20.19.2+dfsg-1+deb13u2 500
            500 http://deb.debian.org/debian trixie/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    No known Vulnerabilities detected!
    *** ioBroker-Installation ***
    ioBroker Status
    iobroker is not running on this host.
    No iobroker host is running.
    Objects type: redis
    States  type: redis
    Hosts:
    Core adapters versions
    js-controller:  7.2.5
    admin:          8.3.5
    javascript:     "javascript" not found
    nodejs modules from github:     0
    Adapter State
    + instance is alive
    ioBroker-Repositories
    List is empty
    Installed ioBroker-Adapters
    │ (index) │
    ioBroker-Adapter Versions and update status
    Error: Object "system.config" not found
    Objects and States
    Objects:        3
    States:         2
    Hit:1 http://deb.debian.org/debian trixie InRelease
    Hit:2 http://deb.debian.org/debian trixie-updates InRelease
    Hit:3 http://security.debian.org/debian-security trixie-security InRelease
    Hit:4 https://deb.nodesource.com/node_24.x nodistro InRelease
    Reading package lists...
    Pending systemupdates: 0
    *** Listening Ports ***
    Netid State  Recv-Q Send-Q                          Local Address:Port          Peer Address:PortProcess
    udp   UNCONN 0      0                              192.168.178.53:bootpc             0.0.0.0:*    users:(("dhcpcd",pid=937,fd=3))
    udp   UNCONN 0      0                                     0.0.0.0:sunrpc             0.0.0.0:*    users:(("rpcbind",pid=616,fd=5),("systemd",pid=1,fd=45))
    udp   UNCONN 0      0                                        [::]:sunrpc                [::]:*    users:(("rpcbind",pid=616,fd=7),("systemd",pid=1,fd=47))
    udp   UNCONN 0      0      [2a00:1e:f441:101:6a84:7eff:fe72:7254]:dhcpv6-client         [::]:*    users:(("dhcpcd",pid=1431,fd=3))
    udp   UNCONN 0      0      [fd01:f11a:d828:0:6a84:7eff:fe72:7254]:dhcpv6-client         [::]:*    users:(("dhcpcd",pid=1430,fd=3))
    udp   UNCONN 0      0      [fd01:f11a:d828:0:7653:e369:f521:957f]:dhcpv6-client         [::]:*    users:(("dhcpcd",pid=884,fd=3))
    udp   UNCONN 0      0      [2a00:1e:f441:101:39d5:35be:6e5c:106d]:dhcpv6-client         [::]:*    users:(("dhcpcd",pid=867,fd=3))
    udp   UNCONN 0      0             [fe80::21ad:cde1:9f6:ac24]%eno1:dhcpv6-client         [::]:*    users:(("dhcpcd",pid=831,fd=3))
    tcp   LISTEN 0      128                                   0.0.0.0:ssh                0.0.0.0:*    users:(("sshd",pid=744,fd=6))
    tcp   LISTEN 0      4096                                  0.0.0.0:sunrpc             0.0.0.0:*    users:(("rpcbind",pid=616,fd=4),("systemd",pid=1,fd=44))
    tcp   LISTEN 0      511                                 127.0.0.1:redis              0.0.0.0:*    users:(("redis-server",pid=735,fd=8))
    tcp   LISTEN 0      128                                      [::]:ssh                   [::]:*    users:(("sshd",pid=744,fd=7))
    tcp   LISTEN 0      4096                                     [::]:sunrpc                [::]:*    users:(("rpcbind",pid=616,fd=6),("systemd",pid=1,fd=46))
    tcp   LISTEN 0      511                                     [::1]:redis                 [::]:*    users:(("redis-server",pid=735,fd=9))
    tail: cannot open '/opt/iobroker/log/iobroker.current.log' for reading: No such file or directory
    ============= Mark until here for C&P =============
    • B brokeling
      ```bash
      Script v.2026-10-01
      *** BASE SYSTEM ***
               Chassis: desktop 🖥️
      OS is similar to:
      Docker          : false
      Unknown
      Kernel          : x86_64
      Userland        : 64bit
      CPU threads     : 6
                    NTP service: active
                RTC in local TZ: no
      fu
      HOME=/home/fu
      iobroker
      HOME=/home/iobroker
      Desktop:
      Session:                tty
      *** MEMORY ***
      Swap:            16G          0B         16G
      Total:           33G        562M         32G
                536 M used memory
                229 M active memory
              15213 M free memory
                 40 M buffer memory
                212 M swap cache
              16123 M total swap
                  0 M used swap
              16123 M free swap
      *** FILESYSTEM ***
      /var:
      525M    /var/
      291M    /var/cache
      284M    /var/cache/apt
      194M    /var/lib
      USB-Devices by-id:
      nodejs:
        Version table:
      ioBroker Status
      Objects type: redis
      States  type: redis
      Hosts:
      admin:          8.3.5
      Adapter State
      + instance is alive
      List is empty
      │ (index) │
      Objects and States
      Objects:        3
      States:         2
      Thomas BraunT
      Thomas BraunT
      Most Active Developer
      @brokeling sagte:
      Objects type: redis
      Ist redis installiert? Wird ja gerne vergessen.
      sudo apt update
      apt policy redis
      • B
        B
        brokeling
        ist installiert
        fu@debian:~$ sudo apt update
        OK:1 http://security.debian.org/debian-security trixie-security InRelease
        OK:2 http://deb.debian.org/debian trixie InRelease
        OK:3 http://deb.debian.org/debian trixie-updates InRelease
        OK:4 https://deb.nodesource.com/node_24.x nodistro InRelease
        Alle Pakete sind aktuell.
        fu@debian:~$ apt policy redis
        redis:
          Installiert:           (keine)
          Installationskandidat: 5:8.0.2-3+deb13u3
          Versionstabelle:
             5:8.0.2-3+deb13u3 500
             5:8.0.2-3+deb13u2 500
        fu@debian:~$
        • B brokeling
          ist installiert
          redis:
            Versionstabelle:
          fu@debian:~$
          Thomas BraunT
          Thomas BraunT
          @brokeling sagte:
          redis:
          Nö...
          sudo apt install redis
          • B
            B
            brokeling
            seltsam. hatte es nämlich markiert.
            fu@debian:~$ sudo apt install redis
            Installiere:
              redis
            Zusammenfassung:
              Aktualisiere: 0, Installiere: 1, Entferne: 0, Aktualisiere nicht: 0
              Herunterlade-Größe: 18,1 kB
              Benötigter Platz: 29,7 kB / 457 GB verfügbar
            Holen:1 http://security.debian.org/debian-security trixie-security/main amd64 redis all 5:8.0.2-3+deb13u3 [18,1 kB]
            Es wurden 18,1 kB in 0 s geholt (505 kB/s).
            Vormals nicht ausgewähltes Paket redis wird gewählt.
            (Lese Datenbank ... 58203 Dateien und Verzeichnisse sind derzeit installiert.)
            Vorbereitung zum Entpacken von .../redis_5%3a8.0.2-3+deb13u3_all.deb ...
            Entpacken von redis (5:8.0.2-3+deb13u3) ...
            redis (5:8.0.2-3+deb13u3) wird eingerichtet ...
            fu@debian:~$
            • B brokeling
              Installiere:
                redis
              Zusammenfassung:
              fu@debian:~$
              Thomas BraunT
              Thomas BraunT
              @brokeling sagte:
              Wo markiert? In deinem Backup? Das sind doch nur die Daten, die eigentliche Datenbank, also das Programm das dir diese Daten verwaltet, muss natürlich auch erstmal vorhanden sein.
              • B brokeling
                Installiere:
                  redis
                Zusammenfassung:
                fu@debian:~$
                Thomas BraunT
                Thomas BraunT
                @brokeling Was ist denn da los?
                • B
                  B
                  brokeling
                  nein, markiert bei der iob installation. da wurde man gefragt, ob redis auch mit installiert werden soll.
                  Komme aber noch nicht auf die Benutzeroberfläche über die ip...
                  • B brokeling
                    Thomas BraunT
                    Thomas BraunT
                    @brokeling
                    Hast du das Backup jetzt nach der Instalation von redis nochmal draufgeworfen?
                    • B
                      B
                      brokeling
                      nein ich wollte auf die Benutzoberfläche, den Backitup-Adapter installieren und dann das backup aufspielen.
                      Aber iobroker ist bisher über die ip am rechner nicht ansprechbar (Benutzeroberfläche).
                      • B
                        B
                        brokeling
                        Kann ich das backup anderweitig anstoßen?
                        • B brokeling
                          Thomas BraunT
                          Thomas BraunT
                          @brokeling
                          Installier das Ding nochmal neu. Oder versuch es mit dem
                          iob fix
                          • B
                            B
                            brokeling
                            seltsam. Wüsste nicht was da schief gelaufen ist...
                                                        ┌─ ioBroker Fixer 2026-10-29 ──────────────────────────────────────────────┐
                                                        │  √ Installing prerequisites                                              │
                                                        │  √ Checking ioBroker user and directory permissions                      │
                                                        │  √ Check and cleanup npm temporary directories                           │
                                                        │  √ Database maintenance                                                  │
                                                        │  √ Checking autostart                                                    │
                                                        │  Your installation was fixed successfully                                │
                                                        │  Run iobroker start to start ioBroker again!                             │
                                                        │  You can check the logs under /home/fu/iobroker-fix.log                  │
                            fu@debian:~$ iob start
                            fu@debian:~$ iobroker start
                            fu@debian:~$ iob status
                            Objects type: redis
                            States  type: redis
                            fu@debian:~$
                            iob nochmal drüber installieren?
                            • B brokeling
                              Objects type: redis
                              States  type: redis
                              fu@debian:~$
                              Thomas BraunT
                              Thomas BraunT
                              @brokeling
                              Ich würde das nochmal von vorne machen.
                              • B
                                B
                                brokeling
                                komplett, also auch debian??
                                Kann ich machen aber ich hab keine idee was falsch war. Danach sieht es wahrscheinlich genauso aus.
                                • B brokeling
                                  Thomas BraunT
                                  Thomas BraunT
                                  @brokeling
                                  Nein, nur den ioBroker mit dem Installationseinzeiler.
                                  • B
                                    B
                                    brokeling
        ┌─ ioBroker Installer 2026-10-29 ──────────────────────────────────────────┐
        │  Installs ioBroker into /opt/iobroker.                                   │
        │  Debian GNU/Linux 13 (trixie) (x86_64), Node.js v24.22.2                 │
        │  Standard users should not change the defaults, just press               │
        │  Enter.        │
        │  ► Install ioBroker                                                      │
        │    [x] Start ioBroker after the installation                             │
        │    [x] Install Redis for objects and states                              │
        │    Quit        │
        │  Installs Node.js if needed, the ioBroker packages and the service       │
        │  that starts ioBroker at boot.                                           │
        │  Classic output with every detail instead of this display: start the     │
        │  installer with --classic.                                               │
                                    Ich hatte hier install Redis auch mit markiert.
                                    Und jetzt auch.
                                    • B
                                      B
                                      brokeling
        │  √ Creating ioBroker user and directory                                  │
        │  √ Installing ioBroker                                                   │
        │  √ Installing and configuring Redis                                      │
        │  √ Finalizing installation                                               │
        │  ioBroker was installed successfully                                     │
        │  Open in a browser and start configuring:                                │
        │    http://192.168.178.53:8081                                            │
        │  You need to re-login before doing anything else on the console!         │
        │  Please run 'iob fix' first after the required re-login to finalize      │
        │  the setup.                                                              │
        │  You can check the logs under /home/fu/iobroker-install.log              │
                                      • B brokeling
        │  Enter.        │
        │    Quit        │
                                        Und jetzt auch.
                                        Thomas BraunT
                                        Thomas BraunT
                                        @brokeling
                                        Keine Ahnung was der Installer da macht. Aber offenbar irgendwas verkehrt und an der Paketdatenbank vorbei, wenn da redis auf einem Debian installiert werden soll.
                                        • B
                                          B
                                          brokeling
                                          und ich habe wieder kein Glück. keine Erreichbarkeit.
                                          fu@debian:~$ iobroker status
                                          Objects type: redis
                                          States  type: redis
                                          84.2k
