Hiler für den Umzug auf Fujitsu Rechner
fu@debian:~$ iob status Cannot read system.config: null (OK when migrating or restoring) host.debian Plugin sentry Failed to initialize plugin: Sentry Plugin disabled for this process because sending of statistic data is disabled for the system iobroker is not running on this host. No iobroker host is running. Objects type: redis States type: redis -
fu@debian:~$ iob status Cannot read system.config: null (OK when migrating or restoring) host.debian Plugin sentry Failed to initialize plugin: Sentry Plugin disabled for this process because sending of statistic data is disabled for the system iobroker is not running on this host. No iobroker host is running. Objects type: redis States type: redisWas haste denn bisher getan? Die Ausgabe von
iob diaghilf auch auf anderen Plattformen ernorm weiter...
========== Start marking the full check here =========== ```bash Script v.2026-10-01 *** BASE SYSTEM *** Operating System: Debian GNU/Linux 13 (trixie) Static hostname: debian Icon name: computer-desktop Chassis: desktop 🖥️ Kernel: Linux 6.12.115+deb13.1-amd64 Architecture: x86-64 Hardware Vendor: FUJITSU Hardware Model: ESPRIMO Q958 Firmware Version: V5.0.0.13 R1.25.0 for D3613-A1x Firmware Date: Tue 2020-06-30 Firmware Age: 6y 4month 3d OS is similar to: model name : Intel(R) Core(TM) i5-8500T CPU @ 2.10GHz Docker : false Virtualization : none Unknown Kernel : x86_64 Userland : 64bit Installation date unknown (filesystem does not support birth time). Systemuptime and Load: 20:12:31 up 20 min, 1 user, load average: 0.28, 0.18, 0.11 CPU threads : 6 *** LIFE CYCLE STATUS *** Operating System is the current Debian stable version codenamed 'trixie'! *** TIME AND TIMEZONES *** Local time: Mon 2026-11-02 20:12:31 CET Universal time: Mon 2026-11-02 19:12:31 UTC RTC time: Mon 2026-11-02 19:12:31 Time zone: Europe/Berlin (CET, +0100) System clock synchronized: yes NTP service: active RTC in local TZ: no *** Users and Groups *** User that called 'iob diag': fu HOME=/home/fu GROUPS=fu cdrom floppy sudo audio dip video plugdev users netdev iobroker User that is running 'js-controller': iobroker HOME=/home/iobroker GROUPS=iobroker tty dialout audio video plugdev redis *** DISPLAY-SERVER SETUP *** Display-Server: Unknown Display-Manager: Not found Desktop: Session: tty Boot Target: multi-user.target *** MEMORY *** total used free shared buff/cache available Mem: 16G 562M 15G 3.8M 265M 15G Swap: 16G 0B 16G Total: 33G 562M 32G Active iob-Instances: 1 15739 M total memory 536 M used memory 229 M active memory 94 M inactive memory 15213 M free memory 40 M buffer memory 212 M swap cache 16123 M total swap 0 M used swap 16123 M free swap *** top - Table Of Processes *** top - 20:12:31 up 20 min, 1 user, load average: 0.28, 0.18, 0.11 Tasks: 158 total, 1 running, 157 sleeping, 0 stopped, 0 zombie %Cpu(s): 1.5 us, 0.0 sy, 0.0 ni, 98.5 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st MiB Mem : 15739.7 total, 15212.7 free, 536.6 used, 254.1 buff/cache MiB Swap: 16124.0 total, 16124.0 free, 0.0 used. 15203.2 avail Mem *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION 0 loaded units listed. *** DMESG CRITICAL ERRORS *** 9 CRITICAL ERRORS DETECTED! Check 'sudo dmesg --level=emerg,alert,crit -T' for details *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on udev devtmpfs 7.7G 0 7.7G 0% /dev tmpfs tmpfs 1.6G 916K 1.6G 1% /run /dev/sda2 ext4 452G 3.0G 426G 1% / tmpfs tmpfs 7.7G 0 7.7G 0% /dev/shm efivarfs efivarfs 192K 55K 133K 29% /sys/firmware/efi/efivars tmpfs tmpfs 5.0M 0 5.0M 0% /run/lock tmpfs tmpfs 1.0M 0 1.0M 0% /run/credentials/systemd-journald.service tmpfs tmpfs 7.7G 2.5M 7.7G 1% /tmp /dev/sda1 vfat 975M 9.1M 966M 1% /boot/efi tmpfs tmpfs 1.0M 0 1.0M 0% /run/credentials/getty@tty1.service tmpfs tmpfs 1.6G 4.0K 1.6G 1% /run/user/1000 Messages concerning filesystems in dmesg (Last 15 lines only): [Mon Nov 2 19:51:39 2026] EXT4-fs (sda2): mounted filesystem 02539a68-0ad4-4a92-84fe-3f5e829ec662 ro with ordered data mode. Quota mode: none. [Mon Nov 2 19:51:40 2026] EXT4-fs (sda2): re-mounted 02539a68-0ad4-4a92-84fe-3f5e829ec662 r/w. Show mounted filesystems: TARGET SOURCE FSTYPE OPTIONS / /dev/sda2 ext4 rw,relatime,errors=remount-ro `-/boot/efi /dev/sda1 vfat rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro Files in neuralgic directories: /var: 525M /var/ 291M /var/cache 284M /var/cache/apt 194M /var/lib 192M /var/cache/apt/archives Hint: You are currently not seeing messages from other users and the system. Users in groups 'adm', 'systemd-journal' can see all messages. Pass -q to turn off this notice. Archived and active journals take up 8M in the file system. /opt/iobroker/backups: du: cannot access '/opt/iobroker/backups/': No such file or directory /opt/iobroker/iobroker-data: 21M /opt/iobroker/iobroker-data/files 21M /opt/iobroker/iobroker-data/ 12M /opt/iobroker/iobroker-data/files/backitup.admin 8.6M /opt/iobroker/iobroker-data/files/admin.admin 8.5M /opt/iobroker/iobroker-data/files/backitup.admin/custom The five largest files in iobroker-data are: 6.8M /opt/iobroker/iobroker-data/files/backitup.admin/custom/assets/_virtual_mf___mfe_internal__ConfigCustomBackItUpSet__mf_owner__1__loadShare___mf_0_iobroker_mf_1_gui_mf_2_components__loadShare__.js-Bs-T0f9g.js 6.7M /opt/iobroker/iobroker-data/files/admin.admin/custom/assets/_virtual_mf___mfe_internal__AdminComponentEasyAccessSet__mf_owner__1__loadShare___mf_0_iobroker_mf_1_gui_mf_2_components__loadShare__.js-wBTkI4zM.js 2.3M /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-B8tnXn1c.js 1.4M /opt/iobroker/iobroker-data/files/backitup.admin/custom/assets/_virtual_mf___mfe_internal__ConfigCustomBackItUpSet__mf_owner__1__loadShare___mf_0_iobroker_mf_1_json_mf_2_config__loadShare__.js-CKWPej0K.js 1.4M /opt/iobroker/iobroker-data/files/admin.admin/custom/assets/_virtual_mf___mfe_internal__AdminComponentEasyAccessSet__mf_owner__1__loadShare___mf_0_iobroker_mf_1_json_mf_2_config__loadShare__.js-BgmCjhru.js USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id': No Devices found 'by-id' No nvbackup.json found. *** NodeJS-Installation *** /usr/bin/nodejs v24.22.2 /usr/bin/node v24.22.2 /usr/bin/npm 11.19.1 /usr/bin/npx 11.19.1 ✓ Node.js installation is correct Recommended versions are nodejs Cannot read system.config: null (OK when migrating or restoring) and npm Cannot read system.config: null (OK when migrating or restoring) nodejs: Installed: 24.22.2-1nodesource1 Candidate: 24.22.2-1nodesource1 Version table: *** 24.22.2-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 100 /var/lib/dpkg/status 24.22.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.22.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.21.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.20.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.19.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.18.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.18.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.14.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.13.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.11.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.4.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.0.2-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.0.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 20.19.2+dfsg-1+deb13u3 500 500 http://security.debian.org/debian-security trixie-security/main amd64 Packages 20.19.2+dfsg-1+deb13u2 500 500 http://deb.debian.org/debian trixie/main amd64 Packages Temp directories causing deletion problem: 0 No problems detected Errors in npm tree: 0 No problems detected Checking for nodejs vulnerability: No known Vulnerabilities detected! *** ioBroker-Installation *** ioBroker Status Cannot read system.config: null (OK when migrating or restoring) iobroker is not running on this host. No iobroker host is running. Objects type: redis States type: redis Hosts: Cannot read system.config: null (OK when migrating or restoring) Core adapters versions js-controller: 7.2.5 admin: 8.3.5 javascript: "javascript" not found nodejs modules from github: 0 Adapter State Cannot read system.config: null (OK when migrating or restoring) + instance is alive Enabled adapters with bindings ioBroker-Repositories Cannot read system.config: null (OK when migrating or restoring) List is empty Installed ioBroker-Adapters Cannot read system.config: null (OK when migrating or restoring) ┌─────────┐ │ (index) │ ├─────────┤ └─────────┘ ioBroker-Adapter Versions and update status Cannot read system.config: null (OK when migrating or restoring) Error: Object "system.config" not found Objects and States Please stand by - This may take a while Objects: 3 States: 2 *** OS-Repositories and Updates *** Hit:1 http://deb.debian.org/debian trixie InRelease Hit:2 http://deb.debian.org/debian trixie-updates InRelease Hit:3 http://security.debian.org/debian-security trixie-security InRelease Hit:4 https://deb.nodesource.com/node_24.x nodistro InRelease Reading package lists... Pending systemupdates: 0 *** Listening Ports *** Netid State Recv-Q Send-Q Local Address:Port Peer Address:PortProcess udp UNCONN 0 0 192.168.178.53:bootpc 0.0.0.0:* users:(("dhcpcd",pid=937,fd=3)) udp UNCONN 0 0 0.0.0.0:sunrpc 0.0.0.0:* users:(("rpcbind",pid=616,fd=5),("systemd",pid=1,fd=45)) udp UNCONN 0 0 [::]:sunrpc [::]:* users:(("rpcbind",pid=616,fd=7),("systemd",pid=1,fd=47)) udp UNCONN 0 0 [2a00:1e:f441:101:6a84:7eff:fe72:7254]:dhcpv6-client [::]:* users:(("dhcpcd",pid=1431,fd=3)) udp UNCONN 0 0 [fd01:f11a:d828:0:6a84:7eff:fe72:7254]:dhcpv6-client [::]:* users:(("dhcpcd",pid=1430,fd=3)) udp UNCONN 0 0 [fd01:f11a:d828:0:7653:e369:f521:957f]:dhcpv6-client [::]:* users:(("dhcpcd",pid=884,fd=3)) udp UNCONN 0 0 [2a00:1e:f441:101:39d5:35be:6e5c:106d]:dhcpv6-client [::]:* users:(("dhcpcd",pid=867,fd=3)) udp UNCONN 0 0 [fe80::21ad:cde1:9f6:ac24]%eno1:dhcpv6-client [::]:* users:(("dhcpcd",pid=831,fd=3)) tcp LISTEN 0 128 0.0.0.0:ssh 0.0.0.0:* users:(("sshd",pid=744,fd=6)) tcp LISTEN 0 4096 0.0.0.0:sunrpc 0.0.0.0:* users:(("rpcbind",pid=616,fd=4),("systemd",pid=1,fd=44)) tcp LISTEN 0 511 127.0.0.1:redis 0.0.0.0:* users:(("redis-server",pid=735,fd=8)) tcp LISTEN 0 128 [::]:ssh [::]:* users:(("sshd",pid=744,fd=7)) tcp LISTEN 0 4096 [::]:sunrpc [::]:* users:(("rpcbind",pid=616,fd=6),("systemd",pid=1,fd=46)) tcp LISTEN 0 511 [::1]:redis [::]:* users:(("redis-server",pid=735,fd=9)) *** Log File - Last 25 Lines *** tail: cannot open '/opt/iobroker/log/iobroker.current.log' for reading: No such file or directory============= Mark until here for C&P =============
Objects type: redis
Ist redis installiert? Wird ja gerne vergessen.
sudo apt update apt policy redis -
ist installiert
fu@debian:~$ sudo apt update OK:1 http://security.debian.org/debian-security trixie-security InRelease OK:2 http://deb.debian.org/debian trixie InRelease OK:3 http://deb.debian.org/debian trixie-updates InRelease OK:4 https://deb.nodesource.com/node_24.x nodistro InRelease Alle Pakete sind aktuell. fu@debian:~$ apt policy redis redis: Installiert: (keine) Installationskandidat: 5:8.0.2-3+deb13u3 Versionstabelle: 5:8.0.2-3+deb13u3 500 500 http://security.debian.org/debian-security trixie-security/main amd64 Packages 5:8.0.2-3+deb13u2 500 500 http://deb.debian.org/debian trixie/main amd64 Packages fu@debian:~$ -
ist installiert
seltsam. hatte es nämlich markiert.
fu@debian:~$ sudo apt install redis Installiere: redis Zusammenfassung: Aktualisiere: 0, Installiere: 1, Entferne: 0, Aktualisiere nicht: 0 Herunterlade-Größe: 18,1 kB Benötigter Platz: 29,7 kB / 457 GB verfügbar Holen:1 http://security.debian.org/debian-security trixie-security/main amd64 redis all 5:8.0.2-3+deb13u3 [18,1 kB] Es wurden 18,1 kB in 0 s geholt (505 kB/s). Vormals nicht ausgewähltes Paket redis wird gewählt. (Lese Datenbank ... 58203 Dateien und Verzeichnisse sind derzeit installiert.) Vorbereitung zum Entpacken von .../redis_5%3a8.0.2-3+deb13u3_all.deb ... Entpacken von redis (5:8.0.2-3+deb13u3) ... redis (5:8.0.2-3+deb13u3) wird eingerichtet ... fu@debian:~$ -
fu@debian:~$ sudo apt install redis Installiere: redis Zusammenfassung: Aktualisiere: 0, Installiere: 1, Entferne: 0, Aktualisiere nicht: 0 Herunterlade-Größe: 18,1 kB Benötigter Platz: 29,7 kB / 457 GB verfügbar Holen:1 http://security.debian.org/debian-security trixie-security/main amd64 redis all 5:8.0.2-3+deb13u3 [18,1 kB] Es wurden 18,1 kB in 0 s geholt (505 kB/s). Vormals nicht ausgewähltes Paket redis wird gewählt. (Lese Datenbank ... 58203 Dateien und Verzeichnisse sind derzeit installiert.) Vorbereitung zum Entpacken von .../redis_5%3a8.0.2-3+deb13u3_all.deb ... Entpacken von redis (5:8.0.2-3+deb13u3) ... redis (5:8.0.2-3+deb13u3) wird eingerichtet ... fu@debian:~$hatte es nämlich markiert.
Wo markiert? In deinem Backup? Das sind doch nur die Daten, die eigentliche Datenbank, also das Programm das dir diese Daten verwaltet, muss natürlich auch erstmal vorhanden sein.
fu@debian:~$ sudo apt install redis Installiere: redis Zusammenfassung: Aktualisiere: 0, Installiere: 1, Entferne: 0, Aktualisiere nicht: 0 Herunterlade-Größe: 18,1 kB Benötigter Platz: 29,7 kB / 457 GB verfügbar Holen:1 http://security.debian.org/debian-security trixie-security/main amd64 redis all 5:8.0.2-3+deb13u3 [18,1 kB] Es wurden 18,1 kB in 0 s geholt (505 kB/s). Vormals nicht ausgewähltes Paket redis wird gewählt. (Lese Datenbank ... 58203 Dateien und Verzeichnisse sind derzeit installiert.) Vorbereitung zum Entpacken von .../redis_5%3a8.0.2-3+deb13u3_all.deb ... Entpacken von redis (5:8.0.2-3+deb13u3) ... redis (5:8.0.2-3+deb13u3) wird eingerichtet ... fu@debian:~$@brokeling Was ist denn da los?
*** DMESG CRITICAL ERRORS *** 9 CRITICAL ERRORS DETECTED! Check 'sudo dmesg --level=emerg,alert,crit -T' for details -
nein, markiert bei der iob installation. da wurde man gefragt, ob redis auch mit installiert werden soll.
Komme aber noch nicht auf die Benutzeroberfläche über die ip...
Hast du das Backup jetzt nach der Instalation von redis nochmal draufgeworfen?
seltsam. Wüsste nicht was da schief gelaufen ist...
▀▀████████▀▀ ┌─ ioBroker Fixer 2026-10-29 ──────────────────────────────────────────────┐ │ │ │ √ Installing prerequisites │ │ √ Checking ioBroker user and directory permissions │ │ √ Check and cleanup npm temporary directories │ │ √ Database maintenance │ │ √ Checking autostart │ │ │ │ Your installation was fixed successfully │ │ Run iobroker start to start ioBroker again! │ │ │ │ You can check the logs under /home/fu/iobroker-fix.log │ │ │ └──────────────────────────────────────────────────────────────────────────┘ fu@debian:~$ iob start fu@debian:~$ iobroker start fu@debian:~$ iob status Cannot read system.config: null (OK when migrating or restoring) iobroker is not running on this host. No iobroker host is running. Objects type: redis States type: redis fu@debian:~$iob nochmal drüber installieren?
Ich würde das nochmal von vorne machen.
komplett, also auch debian??
Kann ich machen aber ich hab keine idee was falsch war. Danach sieht es wahrscheinlich genauso aus.Nein, nur den ioBroker mit dem Installationseinzeiler.
▀▀██████▀▀ ┌─ ioBroker Installer 2026-10-29 ──────────────────────────────────────────┐ │ │ │ Installs ioBroker into /opt/iobroker. │ │ Debian GNU/Linux 13 (trixie) (x86_64), Node.js v24.22.2 │ │ Standard users should not change the defaults, just press │ │ Enter. │ │ │ │ ► Install ioBroker │ │ [x] Start ioBroker after the installation │ │ [x] Install Redis for objects and states │ │ Quit │ │ │ │ Installs Node.js if needed, the ioBroker packages and the service │ │ that starts ioBroker at boot. │ │ │ │ Classic output with every detail instead of this display: start the │ │ installer with --classic. │ │ │Ich hatte hier install Redis auch mit markiert.
Und jetzt auch. -
┌─ ioBroker Installer 2026-10-29 ──────────────────────────────────────────┐ │ │ │ √ Installing prerequisites │ │ √ Creating ioBroker user and directory │ │ √ Installing ioBroker │ │ √ Installing and configuring Redis │ │ √ Finalizing installation │ │ │ │ ioBroker was installed successfully │ │ │ │ Open in a browser and start configuring: │ │ http://192.168.178.53:8081 │ │ │ │ You need to re-login before doing anything else on the console! │ │ Please run 'iob fix' first after the required re-login to finalize │ │ the setup. │ │ │ │ You can check the logs under /home/fu/iobroker-install.log │ │
