  3. Off Topic
  4. Proxmox
  5. Proxmox WebIf nicht erreichbar
    2.7k
    4.7k
    4.0k
Geplant Angeheftet Gesperrt Verschoben Proxmox
70 Beiträge 5 Kommentatoren 6.2k Aufrufe 4 Beobachtet
  • NegaleinN Negalein
    @crunchip sagte in Proxmox WebIf nicht erreichbar:
    systemctl status pve-cluster
    ● pve-cluster.service - The Proxmox VE cluster filesystem
         Loaded: loaded (/lib/systemd/system/pve-cluster.service; enabled; vendor preset: enabled)
         Active: activating (start) since Sun 2025-10-12 15:27:11 CEST; 1ms ago
    Cntrl PID: 930 (pmxcfs)
          Tasks: 1 (limit: 18839)
         Memory: 128.0K
            CPU: 199us
         CGroup: /system.slice/pve-cluster.service
                 └─930 /usr/bin/pmxcfs
    Oct 12 15:27:11 pve systemd[1]: Starting The Proxmox VE cluster filesystem...
    systemctl restart pve-cluster
    Job for pve-cluster.service failed because the control process exited with error code.
    See "systemctl status pve-cluster.service" and "journalctl -xe" for details.
    journalctl -xe
    ░░ The job identifier is 8927 and the job result is done.
    Oct 12 15:30:03 pve systemd[1]: Starting The Proxmox VE cluster filesystem...
    ░░ Subject: A start job for unit pve-cluster.service has begun execution
    ░░ Defined-By: systemd
    ░░ Support: https://www.debian.org/support
    ░░ A start job for unit pve-cluster.service has begun execution.
    ░░ The job identifier is 8927.
    Oct 12 15:30:07 pve pmxcfs[1084]: [main] crit: Unable to get local IP address
    Oct 12 15:30:07 pve systemd[1]: pve-cluster.service: Control process exited, code=exited, status=255/EXCEPTION
    ░░ Subject: Unit process exited
    ░░ An ExecStart= process belonging to unit pve-cluster.service has exited.
    ░░ The process' exit code is 'exited' and its exit status is 255.
    Oct 12 15:30:07 pve systemd[1]: pve-cluster.service: Failed with result 'exit-code'.
    ░░ Subject: Unit failed
    ░░ The unit pve-cluster.service has entered the 'failed' state with result 'exit-code'.
    Oct 12 15:30:07 pve systemd[1]: Failed to start The Proxmox VE cluster filesystem.
    ░░ Subject: A start job for unit pve-cluster.service has failed
    ░░ A start job for unit pve-cluster.service has finished with a failure.
    ░░ The job identifier is 8927 and the job result is failed.
    Oct 12 15:30:07 pve systemd[1]: Condition check resulted in Corosync Cluster Engine being skipped.
    ░░ Subject: A start job for unit corosync.service has finished successfully
    ░░ A start job for unit corosync.service has finished successfully.
    ░░ The job identifier is 8930.
    Oct 12 15:30:07 pve pveproxy[1081]: worker exit
    Oct 12 15:30:07 pve pveproxy[1082]: worker exit
    Oct 12 15:30:07 pve pveproxy[889]: worker 1081 finished
    Oct 12 15:30:07 pve pveproxy[889]: starting 1 worker(s)
    Oct 12 15:30:07 pve pveproxy[889]: worker 1082 finished
    Oct 12 15:30:07 pve pveproxy[889]: worker 1085 started
    Oct 12 15:30:07 pve pveproxy[1083]: worker exit
    Oct 12 15:30:07 pve pveproxy[1085]: /etc/pve/local/pve-ssl.key: failed to load local private key (key_file or key) at /usr/share/perl5/PVE/APIServer/AnyEvent.pm line 1917.
    Oct 12 15:30:07 pve pveproxy[889]: worker 1083 finished
    Oct 12 15:30:07 pve pveproxy[889]: starting 2 worker(s)
    Oct 12 15:30:07 pve pveproxy[889]: worker 1086 started
    Oct 12 15:30:07 pve pveproxy[889]: worker 1087 started
    Oct 12 15:30:07 pve pveproxy[1086]: /etc/pve/local/pve-ssl.key: failed to load local private key (key_file or key) at /usr/share/perl5/PVE/APIServer/AnyEvent.pm line 1917.
    Oct 12 15:30:07 pve pveproxy[1087]: /etc/pve/local/pve-ssl.key: failed to load local private key (key_file or key) at /usr/share/perl5/PVE/APIServer/AnyEvent.pm line 1917.
    Oct 12 15:30:08 pve systemd[1]: pve-cluster.service: Scheduled restart job, restart counter is at 22.
    ░░ Subject: Automatic restarting of a unit has been scheduled
    ░░ Automatic restarting of the unit pve-cluster.service has been scheduled, as the result for
    ░░ the configured Restart= setting for the unit.
    Oct 12 15:30:08 pve systemd[1]: Stopped The Proxmox VE cluster filesystem.
    ░░ Subject: A stop job for unit pve-cluster.service has finished
    ░░ A stop job for unit pve-cluster.service has finished.
    ░░ The job identifier is 9103 and the job result is done.
    Oct 12 15:30:08 pve systemd[1]: Starting The Proxmox VE cluster filesystem...
    ░░ The job identifier is 9103.
    crunchipC Abwesend
    crunchipC Abwesend
    @negalein zeig mal den Eintrag in /etc/pve/corosync.conf
      NegaleinN Offline
      NegaleinN Offline
      Negalein
      die ist leer
      @uweklatt sagte in Proxmox WebIf nicht erreichbar:
      Sind ALLE Beteiligten Geräte umgestellt?
      geht nur um dieses Gerät! Alle anderen (PC, Handy, ...) laufen schon monatelang unter neuer Konfig.
      ° Fixer ---> iob fix
        die ist leer
        crunchipC Abwesend
        crunchipC Abwesend
        @negalein sagte in Proxmox WebIf nicht erreichbar:
        die ist leer
        ok,also kein cluster sondern single node
          die ist leer
          NegaleinN Offline
          NegaleinN Offline
          Negalein
          sondern single node
          ja, das wäre das nächste Projekt ;)
            Weil du nur den proxy und nicht den Netzwerkdienst neu gestartet hast.
            ah, deshalb.
            Nach reboot hat er die richtige IP gehabt.
            Aber GUI geht nicht.
            Ist die 206 auch frei, oder Vllt schon anderweitig belegt?
            Ja, definitiv frei
            Gibt's im LOG etwas zu sehen?
            wo find ich das?
            Ist die Fehlermeldung von oben noch vorhanden?
            Ja
            Möglichkeit wäre noch testhalber von statisch auf DHCP stellen um eventuelle Fehler auszuschließen.
            in der /etc/network/interfaces:auto?
            iface vmbr0 inet DHCP
            address 10.0.1.206/23
            gateway 10.0.1.1
            bridge-ports enp0s31f6
            bridge-stp off
            bridge-fd 0
            so?
            etc/hosts
            127.0.0.1 localhost.localdomain localhost
            10.0.1.206 proxmox-3.fritz.box
            # The following lines are desirable for IPv6 capable hosts
            ::1     ip6-localhost ip6-loopback
            fe00::0 ip6-localnet
            ff00::0 ip6-mcastprefix
            ff02::1 ip6-allnodes
            ff02::2 ip6-allrouters
            ff02::3 ip6-allhosts
            crunchipC Abwesend
            crunchipC Abwesend
        127.0.0.1 localhost.localdomain localhost        10.0.1.206 proxmox-3.fritz.box        # The following lines are desirable for IPv6 capable hosts        ::1     ip6-localhost ip6-loopback        fe00::0 ip6-localnet        ff00::0 ip6-mcastprefix        ff02::1 ip6-allnodes        ff02::2 ip6-allrouters        ff02::3 ip6-allhosts
            irgendwo is da noch der Wurm drin
            ergänze das mal, siehe Zeile 2
            10.0.1.206 proxmox-3.fritz.box proxmox-3
            und um sicherzustellen auch nochmal in /etc/hostname nachsehen ob der Hostname so drinsteht proxmox-3
            hast du jetzt auf dhcp umgestellt oder noch statisch?
            NegaleinN 2 Antworten Letzte Antwort
              NegaleinN Offline
              NegaleinN Offline
              Negalein
              etc/hosts
              Zeile 2 mit proxmox-3 ergänzt
              etc/hostname pve durch proxmox-3 ersetzt
              schon auf dhcp
              er hat jetzt 10.0.0.33 bekommen
              GUI funktioniert :)
              Jetzt kann ich das Netzwerk in der GUI wieder auf statisch stellen. :)
              und dann pack ich auch gleich die 2. Kiste
                NegaleinN Offline
                NegaleinN Offline
                Negalein
                @crunchip
                normal, dass in der GUI noch die .1.206 steht?
                ich dachte, dort aktivier ich auch static?
                  @crunchip
                  crunchipC Abwesend
                  crunchipC Abwesend
                  ja
                  eigentlich nicht
                    etc/hosts
                    schon auf dhcp
                    GUI funktioniert :)
                    crunchipC Abwesend
                    crunchipC Abwesend
                    GUI funktioniert
                    ist den jetzt der pve-ssl.key wieder korrekt?
                      GUI funktioniert
                      NegaleinN Offline
                      NegaleinN Offline
                      Negalein
                      ● pve-guests.service - PVE guests
                           Loaded: loaded (/lib/systemd/system/pve-guests.service; enabled; vendor preset: enabled)
                           Active: active (exited) since Sun 2025-10-12 17:00:02 CEST; 1min 38s ago
                          Process: 938 ExecStartPre=/usr/share/pve-manager/helpers/pve-startall-delay (code=exited, status=0/SUCCESS)
                          Process: 939 ExecStart=/usr/bin/pvesh --nooutput create /nodes/localhost/startall (code=exited, status=0/SUCCESS)
                         Main PID: 939 (code=exited, status=0/SUCCESS)
                              CPU: 766ms
                      Oct 12 17:00:01 proxmox-3 systemd[1]: Starting PVE guests...
                      Oct 12 17:00:02 proxmox-3 pve-guests[939]: <root@pam> starting task UPID:proxmox-3:000003AC:00000670:68EBC272:startall::root@pam:
                      Oct 12 17:00:02 proxmox-3 pve-guests[939]: <root@pam> end task UPID:proxmox-3:000003AC:00000670:68EBC272:startall::root@pam: OK
                      Oct 12 17:00:02 proxmox-3 systemd[1]: Finished PVE guests.
                      ja
                      finde da nichts zum aktivieren (Häckchen)
                      hab ihm jetzt vorerst per Fritz eine fixe zugewiesen.
                      Läuft jetzt wieder unter .1.206
                      würds aber gern direkt in der Maschine machen.
                                CPU: 766ms
                        ja
                        crunchipC Abwesend
                        crunchipC Abwesend
                        ist nicht wie bei einer VM, da hat man die Wahl per Gui von dhcp und statisch
                        proxmox ist Standard auf statisch, wenn dann von dhcp wieder per nano /etc/network/interfaces umstellen, die IP selbst kannst du per GUI ändern.
                        auch der zugehörige Eintrag in /etc/hosts ist per Gui möglich
                        https://www.servethehome.com/how-to-change-primary-proxmox-ve-ip-address/
                          NegaleinN Offline
                          NegaleinN Offline
                          Negalein
                          ah, stimmt
                          ich mach jetzt mal Pause. Komm vom lesen schon durcheinander.
                          die nächste wird Morgen umgestellt. :)
                            ah, stimmt
                            crunchipC Abwesend
                            crunchipC Abwesend
                            @negalein OK, eigentlich nur die beiden wie zuvor geschrieben anpassen, dann sollte es laufen
                              and 161 not upgraded.
                              Pfleg die Kiste. Da hängt einiges in der Pipeline.
                              NegaleinN Offline
                              NegaleinN Offline
                              Negalein
                              @thomas-braun sagte in Proxmox WebIf nicht erreichbar:
                              Hallo Thomas,
                              wollte die Kiste up to date bringen.
                              Stehe jetzt nach dem Reboot bei do-release-upgrade an.
                              -bash: do-release-upgrade: command not found
                              Hab dann mit apt install update-manager-core versucht.
                              Da kommt
                              Reading package lists... Done
                              Package update-manager-core is not available, but is referred to by another package.
                              This may mean that the package is missing, has been obsoleted, or
                              is only available from another source
                              E: Package 'update-manager-core' has no installation candidate
                              Im Netz finde ich dazu nichts.
                                Hallo Thomas,
                                Da kommt
                                @negalein
                                Zu Proxmox kann ich dir nix weiter sagen. Und zu Schnubbibuntu auch nicht.
                                  @negalein
                                  NegaleinN Offline
                                  NegaleinN Offline
                                  Negalein
                                  hab ich nicht ;)
                                  nega@proxmox-3:~$ cat /etc/os-release
                                  PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
                                  NAME="Debian GNU/Linux"
                                  VERSION_ID="11"
                                  VERSION="11 (bullseye)"
                                  VERSION_CODENAME=bullseye
                                  ID=debian
                                  HOME_URL="https://www.debian.org/"
                                  SUPPORT_URL="https://www.debian.org/support"
                                  BUG_REPORT_URL="https://bugs.debian.org/"
                                    hab ich nicht ;)
                                    VERSION_ID="11"
                                    ID=debian
                                    @negalein
                                    do-release-upgrade ist aber ein Ubuntu-Sonderstrick, das funktioniert auf einem richtigen Debian nicht.
                                      @negalein
                                      NegaleinN Offline
                                      NegaleinN Offline
                                      Negalein
                                      ah, ok. Hab ich im Netz so gefunden.
                                      Hab jetzt mal GPT gefragt.
                                      sudo apt dist-upgrade
                                      und dann
                                      and then manually adjust /etc/apt/sources.list to the new release.
                                      wie geh ich da mit dem "and then manually ..."
                                        und dann
                                        Oh mann...
                                        Wozu gibt es eigentlich offizielle Doku? Im Fall von Debian ist die auch mehr als ausufernd. Da muss man auch nicht irgendwas von SchättJippiehTieh oder 'aus dem Netz' auf Verdacht mal in die Kiste kloppen...
                                        Kurzfassung:
                                        Ein Debian hält man innerhalb der Version per
                                        sudo apt update && sudo apt full-upgrade
                                        auf Stand.
                                        Edit: Bei Proxmox kann das aber wieder anders aussehen. Aber auch da gibt es mit Sicherheit eine offizielle Anleitung.
                                          Hallo Thomas,
                                          Da kommt
                                          crunchipC Abwesend
                                          crunchipC Abwesend
                                          Mit Proxmox v7 bist du aber generell etwas hinterher.
                                          Da würde ich eher Backups machen und neu aufsetzen
