  4. Test Adapter Linux Control v1.x.x
adaptercontrolhardwarelinuxsteuern
718 Beiträge 74 Kommentatoren 255.8k Aufrufe 67 Beobachtet
  • D denjo
    ich habe auch probleme mit dem Adapter
    über Putty kann ich ohne probleme zugreifen
    Mein IObroker ist bei allem auf aktuellen stand
    Node.js: v20.19.4
    JS Controller 7.0.6
    Adapter. 1.1.5
    host.iOBroker
    2025-08-13 20:44:20.577	info	"system.adapter.linux-control.0" disabled
    linux-control.0
    2025-08-13 20:44:06.264	error	Object linux-control.0.command.host is invalid: obj.common.states has an invalid type! Expected "object", received "string"
    host.iOBroker
    2025-08-13 20:44:05.094	info	instance system.adapter.linux-control.0 in version "1.1.5" started with pid 3987
    host.iOBroker
    2025-08-13 20:43:34.740	info	Restart adapter system.adapter.linux-control.0 because enabled
    host.iOBroker
    2025-08-13 20:43:34.740	error	instance system.adapter.linux-control.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    host.iOBroker
    2025-08-13 20:43:34.740	error	Caught by controller[14]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
    host.iOBroker
    2025-08-13 20:43:34.740	error	Caught by controller[14]: at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1127:27)
    host.iOBroker
    2025-08-13 20:43:34.740	error	Caught by controller[14]: at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2490:15)
    host.iOBroker
    2025-08-13 20:43:34.740	error	Caught by controller[14]: Error: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern
    host.iOBroker
    2025-08-13 20:43:34.740	error	Caught by controller[14]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    host.iOBroker
    2025-08-13 20:43:34.740	error	Caught by controller[13]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
    host.iOBroker
    2025-08-13 20:43:34.740	error	Caught by controller[13]: at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1127:27)
    host.iOBroker
    2025-08-13 20:43:34.740	error	Caught by controller[13]: at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2490:15)
    host.iOBroker
    2025-08-13 20:43:34.740	error	Caught by controller[13]: Error: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern
    host.iOBroker
    2025-08-13 20:43:34.740	error	Caught by controller[13]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    host.iOBroker
    2025-08-13 20:43:34.740	error	Caught by controller[12]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
    host.iOBroker
    2025-08-13 20:43:34.740	error	Caught by controller[12]: at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1127:27)
    host.iOBroker
    2025-08-13 20:43:34.740	error	Caught by controller[12]: at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2490:15)
    host.iOBroker
    2025-08-13 20:43:34.740	error	Caught by controller[12]: Error: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern
    host.iOBroker
    2025-08-13 20:43:34.740	error	Caught by controller[12]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    host.iOBroker
    2025-08-13 20:43:34.740	error	Caught by controller[11]: at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
    host.iOBroker
    2025-08-13 20:43:34.740	error	Caught by controller[11]: at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12)
    host.iOBroker
    2025-08-13 20:43:34.740	error	Caught by controller[11]: ReplyError: Error The pattern "linux-control.0.hyperion.services.systemd-fsck@dev-disk-by\x2dpartuuid-2f6f3587\x2d01.restart" is not a valid ID pattern
    host.iOBroker
    2025-08-13 20:43:34.740	error	Caught by controller[11]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    host.iOBroker
    2025-08-13 20:43:34.740	error	Caught by controller[10]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
    host.iOBroker
    2025-08-13 20:43:34.740	error	Caught by controller[10]: at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1127:27)
    host.iOBroker
    2025-08-13 20:43:34.740	error	Caught by controller[10]: at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2490:15)
    host.iOBroker
    2025-08-13 20:43:34.740	error	Caught by controller[10]: Error: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern
    host.iOBroker
    2025-08-13 20:43:34.740	error	Caught by controller[10]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    host.iOBroker
    2025-08-13 20:43:34.740	error	Caught by controller[9]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
    host.iOBroker
    2025-08-13 20:43:34.740	error	Caught by controller[9]: at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1127:27)
    host.iOBroker
    2025-08-13 20:43:34.740	error	Caught by controller[9]: at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2490:15)
    host.iOBroker
    2025-08-13 20:43:34.740	error	Caught by controller[9]: Error: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern
    host.iOBroker
    2025-08-13 20:43:34.740	error	Caught by controller[9]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    host.iOBroker
    2025-08-13 20:43:34.740	error	Caught by controller[8]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
    host.iOBroker
    2025-08-13 20:43:34.740	error	Caught by controller[8]: at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1127:27)
    host.iOBroker
    2025-08-13 20:43:34.740	error	Caught by controller[8]: at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2490:15)
    host.iOBroker
    2025-08-13 20:43:34.740	error	Caught by controller[8]: Error: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern
    host.iOBroker
    2025-08-13 20:43:34.740	error	Caught by controller[8]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    host.iOBroker
    2025-08-13 20:43:34.740	error	Caught by controller[7]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
    host.iOBroker
    2025-08-13 20:43:34.740	error	Caught by controller[7]: at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1127:27)
    host.iOBroker
    2025-08-13 20:43:34.740	error	Caught by controller[7]: at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2490:15)
    host.iOBroker
    2025-08-13 20:43:34.740	error	Caught by controller[7]: Error: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern
    host.iOBroker
    2025-08-13 20:43:34.740	error	Caught by controller[6]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    host.iOBroker
    2025-08-13 20:43:34.740	error	Caught by controller[5]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
    host.iOBroker
    2025-08-13 20:43:34.739	error	Caught by controller[5]: at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1127:27)
    host.iOBroker
    2025-08-13 20:43:34.739	error	Caught by controller[5]: at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2490:15)
    host.iOBroker
    2025-08-13 20:43:34.739	error	Caught by controller[5]: Error: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern
    host.iOBroker
    2025-08-13 20:43:34.739	error	Caught by controller[5]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    host.iOBroker
    2025-08-13 20:43:34.739	error	Caught by controller[4]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
    host.iOBroker
    2025-08-13 20:43:34.739	error	Caught by controller[4]: at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1127:27)
    host.iOBroker
    2025-08-13 20:43:34.739	error	Caught by controller[4]: at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2490:15)
    host.iOBroker
    2025-08-13 20:43:34.739	error	Caught by controller[4]: Error: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern
    host.iOBroker
    2025-08-13 20:43:34.739	error	Caught by controller[4]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    host.iOBroker
    2025-08-13 20:43:34.739	error	Caught by controller[3]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
    host.iOBroker
    2025-08-13 20:43:34.739	error	Caught by controller[3]: at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1127:27)
    host.iOBroker
    2025-08-13 20:43:34.739	error	Caught by controller[3]: at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2490:15)
    host.iOBroker
    2025-08-13 20:43:34.739	error	Caught by controller[3]: Error: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern
    host.iOBroker
    2025-08-13 20:43:34.739	error	Caught by controller[3]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    host.iOBroker
    2025-08-13 20:43:34.739	error	Caught by controller[2]: at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
    host.iOBroker
    2025-08-13 20:43:34.739	error	Caught by controller[2]: at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12)
    host.iOBroker
    2025-08-13 20:43:34.739	error	Caught by controller[2]: ReplyError: Error The pattern "linux-control.0.hyperion.services.●.restart" is not a valid ID pattern
    host.iOBroker
    2025-08-13 20:43:34.739	error	Caught by controller[2]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    host.iOBroker
    2025-08-13 20:43:34.739	error	Caught by controller[1]: at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
    host.iOBroker
    2025-08-13 20:43:34.739	error	Caught by controller[1]: at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12)
    host.iOBroker
    2025-08-13 20:43:34.739	error	Caught by controller[1]: ReplyError: Error The pattern "linux-control.0.hyperion.services.●.restart" is not a valid ID pattern
    host.iOBroker
    2025-08-13 20:43:34.739	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    linux-control.0
    2025-08-13 20:43:34.634	error	[needrestart] hyperion (192.168.178.67:22): error: Cannot find view "system", stack: Error: Cannot find view "system" at ObjectsInRedisClient._getObjectView (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:4272:19) at Immediate.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:4346:33)
    linux-control.0
    2025-08-13 20:43:34.595	error	Cannot find view "system" for search "state" : Connection is closed.
    linux-control.0
    2025-08-13 20:43:34.593	error	[servicesInfo] hyperion (192.168.178.67:22): error: DB closed, stack: Error: DB closed at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25) at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20) at Object.onceWrapper (node:events:639:26) at Socket.emit (node:events:524:28) at Socket.emit (node:domain:489:12) at TCP.<anonymous> (node:net:343:12)
    linux-control.0
    2025-08-13 20:43:34.554	error	The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern
    linux-control.0
    2025-08-13 20:43:34.554	error	Error: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2490:15) at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1127:27) at processTicksAndRejections (node:internal/process/task_queues:95:5)
    linux-control.0
    2025-08-13 20:43:34.554	error	unhandled promise rejection: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern
    linux-control.0
    2025-08-13 20:43:34.553	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    linux-control.0
    2025-08-13 20:43:34.515	error	The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern
    linux-control.0
    2025-08-13 20:43:34.515	error	Error: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2490:15) at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1127:27) at processTicksAndRejections (node:internal/process/task_queues:95:5)
    linux-control.0
    2025-08-13 20:43:34.515	error	unhandled promise rejection: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern
    linux-control.0
    2025-08-13 20:43:34.514	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    linux-control.0
    2025-08-13 20:43:34.480	error	The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern
    linux-control.0
    2025-08-13 20:43:34.480	error	Error: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2490:15) at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1127:27) at processTicksAndRejections (node:internal/process/task_queues:95:5)
    linux-control.0
    2025-08-13 20:43:34.479	error	unhandled promise rejection: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern
    linux-control.0
    2025-08-13 20:43:34.479	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    linux-control.0
    2025-08-13 20:43:34.464	error	Error The pattern "linux-control.0.hyperion.services.systemd-fsck@dev-disk-by\x2dpartuuid-2f6f3587\x2d01.restart" is not a valid ID pattern
    linux-control.0
    2025-08-13 20:43:34.463	error	ReplyError: Error The pattern "linux-control.0.hyperion.services.systemd-fsck@dev-disk-by\x2dpartuuid-2f6f3587\x2d01.restart" is not a valid ID pattern at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12) at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
    linux-control.0
    2025-08-13 20:43:34.463	error	unhandled promise rejection: Error The pattern "linux-control.0.hyperion.services.systemd-fsck@dev-disk-by\x2dpartuuid-2f6f3587\x2d01.restart" is not a valid ID pattern
    linux-control.0
    2025-08-13 20:43:34.463	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    host.iOBroker-Server
    2025-08-13 20:43:34.462	warn	States 127.0.0.1:45704 Error from InMemDB: Error: The pattern "linux-control.0.hyperion.services.systemd-fsck@dev-disk-by\x2dpartuuid-2f6f3587\x2d01.restart" is not a valid ID pattern at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2490:15) at StatesInMemoryServer.handleSubscribe (file:///opt/iobroker/node_modules/@iobroker/db-base/src/lib/inMemFileDB.ts:324:59) at StatesInMemoryServer._subscribeForClient (file:///opt/iobroker/node_modules/@iobroker/db-states-file/src/lib/states/statesInMemFileDB.js:242:14) at RedisHandler.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-states-jsonl/src/lib/states/statesInMemServerRedis.js:380:26) at RedisHandler.emit (node:events:524:28) at RedisHandler.emit (node:domain:489:12) at Immediate._onImmediate (file:///opt/iobroker/node_modules/@iobroker/db-base/src/lib/redisHandler.ts:210:37) at processImmediate (node:internal/timers:483:21)
    linux-control.0
    2025-08-13 20:43:34.436	error	The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern
    linux-control.0
    2025-08-13 20:43:34.436	error	Error: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2490:15) at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1127:27) at processTicksAndRejections (node:internal/process/task_queues:95:5)
    linux-control.0
    2025-08-13 20:43:34.435	error	unhandled promise rejection: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern
    linux-control.0
    2025-08-13 20:43:34.435	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    linux-control.0
    2025-08-13 20:43:34.366	error	The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern
    linux-control.0
    2025-08-13 20:43:34.366	error	Error: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2490:15) at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1127:27) at processTicksAndRejections (node:internal/process/task_queues:95:5)
    linux-control.0
    2025-08-13 20:43:34.365	error	unhandled promise rejection: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern
    linux-control.0
    2025-08-13 20:43:34.365	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    linux-control.0
    2025-08-13 20:43:34.351	error	The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern
    linux-control.0
    2025-08-13 20:43:34.351	error	Error: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2490:15) at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1127:27) at processTicksAndRejections (node:internal/process/task_queues:95:5)
    linux-control.0
    2025-08-13 20:43:34.351	error	unhandled promise rejection: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern
    linux-control.0
    2025-08-13 20:43:34.350	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    linux-control.0
    2025-08-13 20:43:34.288	error	The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern
    linux-control.0
    2025-08-13 20:43:34.288	error	Error: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2490:15) at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1127:27) at processTicksAndRejections (node:internal/process/task_queues:95:5)
    linux-control.0
    2025-08-13 20:43:34.287	error	unhandled promise rejection: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern
    linux-control.0
    2025-08-13 20:43:34.287	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    linux-control.0
    2025-08-13 20:43:34.256	error	The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern
    linux-control.0
    2025-08-13 20:43:34.256	error	Error: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2490:15) at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1127:27) at processTicksAndRejections (node:internal/process/task_queues:95:5)
    linux-control.0
    2025-08-13 20:43:34.255	error	unhandled promise rejection: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern
    linux-control.0
    2025-08-13 20:43:34.255	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    linux-control.0
    2025-08-13 20:43:34.215	error	The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern
    linux-control.0
    2025-08-13 20:43:34.215	error	Error: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2490:15) at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1127:27) at processTicksAndRejections (node:internal/process/task_queues:95:5)
    linux-control.0
    2025-08-13 20:43:34.215	error	unhandled promise rejection: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern
    linux-control.0
    2025-08-13 20:43:34.215	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    linux-control.0
    2025-08-13 20:43:34.194	error	The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern
    linux-control.0
    2025-08-13 20:43:34.194	error	Error: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2490:15) at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1127:27) at processTicksAndRejections (node:internal/process/task_queues:95:5)
    linux-control.0
    2025-08-13 20:43:34.145	error	unhandled promise rejection: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern
    linux-control.0
    2025-08-13 20:43:34.145	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    linux-control.0
    2025-08-13 20:43:34.138	error	ReplyError: Error The pattern "linux-control.0.hyperion.services.●.restart" is not a valid ID pattern at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12) at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
    linux-control.0
    2025-08-13 20:43:34.138	error	unhandled promise rejection: Error The pattern "linux-control.0.hyperion.services.●.restart" is not a valid ID pattern
    linux-control.0
    2025-08-13 20:43:34.138	error	Error The pattern "linux-control.0.hyperion.services.●.restart" is not a valid ID pattern
    linux-control.0
    2025-08-13 20:43:34.137	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    crunchipC Offline
    crunchipC Offline
    #666
    @denjo sagte in Test Adapter Linux Control v1.x.x:
    Ist das Problem
    • F Offline
      flispy
      #667
      Moin,
      leider bekomme ich neuerdings nur noch die Meldungen: "Host seems not to be online".
      Ich habe den Adapter in Version 1.1.6 installiert.
      Ping vom anderen Rechner bzw. Server auf den Host gehen ohne Probleme. Auch die ssh Verbindung von der iobroker shell zum betreffenden Host gehen ohne Probleme.
      iputils-ping habe ich neu installiert.
      Hat jemand eine Idee woran es liegen könnte?
      F 1 Antwort Letzte Antwort
      • F flispy
        Moin,
        flispy
        #668
        @flispy sagte in Test Adapter Linux Control v1.x.x:
        Moin,
        hab es lösen können. Ich musste folgendes ausführen
        sudo setcap cap_net_raw+p /usr/bin/ping
        madingM 1 Antwort Letzte Antwort
        • F flispy
          Moin,
          madingM Offline
          madingM Offline
          mading
          #669
          Moin,
          Geht wieder, habe den Befehl auf dem iobroker ausgeführt. Danke!
          • F Offline
            Fichte
            schrieb am zuletzt editiert von Fichte
            #670
            Hallo zusammen
            Ich hab heut Trixie (Debian 13) unter Proxmox getestet und da erscheint diese Meldung
            [getConnection] Host 'Name' (IP:Port) seems not to be online
            "Ping wird nicht mehr mit erhöhten Privilegien ausgeführt"
            Quelle hier
            Heisst unter einem anderen User außer root geht der befehl "Ping" nicht mehr.
            Wird aber vom Adapter benötigt um zu schauem ob er online ist.
            Abhilfe steht im Link und ist relativ einfach:
            1. Anmelden
            2. sudo nano /usr/lib/sysctl.d/50-default.conf
            3. nach "net.ipv4.ping_group_range = .........." suchen und gegen "net.ipv4.ping_group_range = 1 1000" ersetzen.
            4. Speichern und Neustarten
            Liebe Grüße
            NashraN wendy2702W madingM 3 Antworten Letzte Antwort
            • F Fichte
              Hallo zusammen
              Quelle hier
              1. Anmelden
              Liebe Grüße
              NashraN Offline
              NashraN Offline
              Nashra
              Most Active Forum Testing
              #671
              @fichte
              danke für den Hinweis, Ping arbeitet wieder
              Gruß Ralf
              • F Fichte
                Hallo zusammen
                Quelle hier
                1. Anmelden
                Liebe Grüße
                wendy2702W Online
                wendy2702W Online
                #672
                @fichte auch nach einem Restart ?
                • wendy2702W wendy2702
                  Fichte
                  #673
                  @wendy2702 Ja Punkt 4
                  • F Fichte
                    Hallo zusammen
                    Quelle hier
                    1. Anmelden
                    Liebe Grüße
                    madingM Offline
                    madingM Offline
                    mading
                    #674
                    @fichte sagte in Test Adapter Linux Control v1.x.x:
                    Hallo zusammen
                    Quelle hier
                    1. Anmelden
                    Liebe Grüße
                    Muss das auf jedem server durchgeführt werden oder nur auf dem iob?
                    • madingM mading
                      Hallo zusammen
                      Quelle hier
                      1. Anmelden
                      Liebe Grüße
                      wendy2702W Online
                      wendy2702W Online
                      #675
                      @mading nur auf dem wo der Linux Control Adapter läuft.
                      • 1Topf1 Offline
                        1Topf1 Offline
                        1Topf
                        #676
                        Ich hab da auch mal ne Frage. Ich hab jetzt einen Raspi3 eingebunden, auf welchem 2 Kameras (Garten u. Hof) auf einem USB-Stick Bilder ablegen. Beide Ordner enthalten aktuell jeweils >20GB Daten. Wieso wird das nicht korrekt dargestellt? Hat da jemand eine Idee? Die Anzahl der Dateien hingegen stimmt.
                        • D3ltoroxpD Offline
                          D3ltoroxpD Offline
                          D3ltoroxp
                          schrieb am zuletzt editiert von D3ltoroxp
                          #677
                          Ich wollte mir das auch mal anschauen. Habe ein paar Befehle eingetragen und mal einen Server. In der Log bekomme ich massig so etwas. An dem Pattern kann ich ja gar nichts ändern.
                          linux-control.0
                          2026-01-10 09:37:46.274	warn	Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
                          linux-control.0
                          2026-01-10 09:37:46.182	error	adapter disabled
                          linux-control.0
                          2026-01-10 09:37:14.374	warn	State "linux-control.0.Proxmox_Homeserver.services.●.load" has no existing object, this might lead to an error in future versions
                          linux-control.0
                          2026-01-10 09:37:14.373	warn	Used invalid characters: linux-control.0.Proxmox_Homeserver.services.●.load changed to linux-control.0.Proxmox_Homeserver.services._.load
                          linux-control.0
                          2026-01-10 09:37:14.310	warn	Used invalid characters: linux-control.0.Proxmox_Homeserver.services.●.stop changed to linux-control.0.Proxmox_Homeserver.services._.stop
                          linux-control.0
                          2026-01-10 09:37:14.308	error	The pattern "io.linux-control.0.Proxmox_Homeserver.services.●.start" is not a valid ID pattern
                          linux-control.0
                          2026-01-10 09:37:14.308	error	Error: The pattern "io.linux-control.0.Proxmox_Homeserver.services.●.start" is not a valid ID pattern at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2490:15) at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1124:27) at processTicksAndRejections (node:internal/process/task_queues:105:5)
                          linux-control.0
                          2026-01-10 09:37:14.307	error	unhandled promise rejection: The pattern "io.linux-control.0.Proxmox_Homeserver.services.●.start" is not a valid ID pattern
                          linux-control.0
                          2026-01-10 09:37:14.307	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                          linux-control.0
                          2026-01-10 09:37:14.305	warn	Used invalid characters: linux-control.0.Proxmox_Homeserver.services.●.start changed to linux-control.0.Proxmox_Homeserver.services._.start
                          linux-control.0
                          2026-01-10 09:37:14.304	error	Error The pattern "linux-control.0.Proxmox_Homeserver.services.●.restart" is not a valid ID pattern
                          linux-control.0
                          2026-01-10 09:37:14.304	error	ReplyError: Error The pattern "linux-control.0.Proxmox_Homeserver.services.●.restart" is not a valid ID pattern at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12) at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
                          linux-control.0
                          2026-01-10 09:37:14.303	error	unhandled promise rejection: Error The pattern "linux-control.0.Proxmox_Homeserver.services.●.restart" is not a valid ID pattern
                          linux-control.0
                          2026-01-10 09:37:14.303	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                          linux-control.0
                          2026-01-10 09:37:14.302	warn	Used invalid characters: linux-control.0.Proxmox_Homeserver.services.●.restart changed to linux-control.0.Proxmox_Homeserver.services._.restart
                          linux-control.0
                          2026-01-10 09:37:14.259	warn	State "linux-control.0.Proxmox_Homeserver.services.●.description" has no existing object, this might lead to an error in future versions
                          linux-control.0
                          2026-01-10 09:37:14.258	warn	Used invalid characters: linux-control.0.Proxmox_Homeserver.services.●.description changed to linux-control.0.Proxmox_Homeserver.services._.description
                          linux-control.0
                          2026-01-10 09:37:14.209	warn	State "linux-control.0.Proxmox_Homeserver.services.●.running" has no existing object, this might lead to an error in future versions
                          linux-control.0
                          2026-01-10 09:37:14.207	warn	Used invalid characters: linux-control.0.Proxmox_Homeserver.services.●.running changed to linux-control.0.Proxmox_Homeserver.services._.running
                          linux-control.0
                          2026-01-10 09:37:14.159	warn	State "linux-control.0.Proxmox_Homeserver.services.●.active" has no existing object, this might lead to an error in future versions
                          linux-control.0
                          2026-01-10 09:37:14.158	warn	Used invalid characters: linux-control.0.Proxmox_Homeserver.services.●.active changed to linux-control.0.Proxmox_Homeserver.services._.active
                          linux-control.0
                          2026-01-10 09:37:14.114	warn	State "linux-control.0.Proxmox_Homeserver.services.●.load" has no existing object, this might lead to an error in future versions
                          linux-control.0
                          2026-01-10 09:37:14.113	warn	Used invalid characters: linux-control.0.Proxmox_Homeserver.services.●.load changed to linux-control.0.Proxmox_Homeserver.services._.load
                          linux-control.0
                          2026-01-10 09:37:14.010	error	Error The pattern "linux-control.0.Proxmox_Homeserver.services.●.stop" is not a valid ID pattern
                          Was kann ich tun, oder wo liegt mein Fehler. So sehen die Befehle aus.
                          • madingM Offline
                            madingM Offline
                            mading
                            schrieb am zuletzt editiert von mading
                            #678
                            Interessant, irgendwie interpretiert er was falsch bzgl. des Datenpunkts services.●.load und der anderen
                            Gibt es den Datenpunkt? Wie ist er benannt?
                            • Ro75R Offline
                              Ro75R Offline
                              Ro75
                              #679
                              Ggfs. mit Alias arbeiten.
                              Ro75.
                                D3ltoroxpD Offline
                                D3ltoroxp
                                #680
                                Hm der Adapter hat ja die DP's erstellt, sollte das dann nicht passen ? Heißt das ich müsst die jetzt von Hand abändern, wenn ich so komische Schreibweise finde ?
                                • D3ltoroxpD D3ltoroxp
                                  crunchipC Offline
                                  crunchipC Offline
                                  #681
                                  @D3ltoroxp die Frage ist eher, was da genau läuft auf deinen Systemen. Hat ja nichts mit den Befehlen zu tun.
                                  D3ltoroxpD 1 Antwort Letzte Antwort
                                  • RoddiEFR Offline
                                    RoddiEFR Offline
                                    RoddiEF
                                    #682
                                    Ich war mal so frei und habe mir diesen Adapter mal installiert aber bekomme sofort nach dem ersten Start eine Fehlermeldung:
                                    linux-control.0
                                    2026-01-12 18:02:09.233	error	Object linux-control.0.command.host is invalid: obj.common.states has an invalid type! Expected "object", received "string"
                                    Kann jemand was damit anfangen und mir Sagen wo der Adapter sein Problem hat?
                                    Edit:
                                    Eingetragen sind nur 2 Raspberry sonst sind keine weiteren Einstellungen gemacht worden.
                                    Ich bin wie ich bin, was anderes bekommt man nicht !!
                                    • RoddiEFR RoddiEF
                                      linux-control.0
                                      Edit:
                                      Meister MopperM Online
                                      Meister Mopper
                                      schrieb am zuletzt editiert von Meister Mopper
                                      #683
                                      @RoddiEF
                                      Guckst du hier
                                      Is aber nicht schlimm, der Adapter läuft sonst super gut!
                                      Proxmox und HA ...
                                      • RoddiEFR Offline
                                        RoddiEFR Offline
                                        RoddiEF
                                        schrieb am zuletzt editiert von RoddiEF
                                        #684
                                        @meister-mopper
                                        hab mir das Verlinkte mal angesehen aber bin nicht so Überzeugt. Der letzte Beitrag zu dem Thema ist von Juni 2025, sind ja nun doch schon einige Monde vergangen ohne Reaktion darauf. Mir stellt sich halt die Frage ob der Adapter noch betreut wird oder nicht?
                                        • RoddiEFR RoddiEF
                                          @meister-mopper
                                          Meister Mopper
                                          #685
                                          @RoddiEF sagte in Test Adapter Linux Control v1.x.x:
                                          @meister-mopper
                                          Der Adaper wird gut betreut und funkioniert like a charme. Vielleicht ist ja mit deinem System was falsch.
                                          Zeig doch mal bitte das Ergebnis von iob diag direkt hier in codetags </> eingestellt.
                                          Proxmox und HA ...
                                          RoddiEFR 1 Antwort Letzte Antwort
