  4. Test Adapter Linux Control v1.x.x
adaptercontrolhardwarelinuxsteuern
718 Beiträge 74 Kommentatoren 255.8k Aufrufe 67 Beobachtet
    deta
    #664
    Fehler gefunden....
    Ich hatte noch keinen openssh Server auf dem Desktop installiert 😞
    Jetzt geht es.
    • D deta
      Fehler gefunden....
      Jetzt geht es.
      denjo
      #665
      ich habe auch probleme mit dem Adapter
      über Putty kann ich ohne probleme zugreifen
      Mein IObroker ist bei allem auf aktuellen stand
      Node.js: v20.19.4
      JS Controller 7.0.6
      Adapter. 1.1.5
      host.iOBroker
      2025-08-13 20:44:20.577	info	"system.adapter.linux-control.0" disabled
      linux-control.0
      2025-08-13 20:44:06.264	error	Object linux-control.0.command.host is invalid: obj.common.states has an invalid type! Expected "object", received "string"
      host.iOBroker
      2025-08-13 20:44:05.094	info	instance system.adapter.linux-control.0 in version "1.1.5" started with pid 3987
      host.iOBroker
      2025-08-13 20:43:34.740	info	Restart adapter system.adapter.linux-control.0 because enabled
      host.iOBroker
      2025-08-13 20:43:34.740	error	instance system.adapter.linux-control.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      host.iOBroker
      2025-08-13 20:43:34.740	error	Caught by controller[14]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
      host.iOBroker
      2025-08-13 20:43:34.740	error	Caught by controller[14]: at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1127:27)
      host.iOBroker
      2025-08-13 20:43:34.740	error	Caught by controller[14]: at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2490:15)
      host.iOBroker
      2025-08-13 20:43:34.740	error	Caught by controller[14]: Error: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern
      host.iOBroker
      2025-08-13 20:43:34.740	error	Caught by controller[14]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      host.iOBroker
      2025-08-13 20:43:34.740	error	Caught by controller[13]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
      host.iOBroker
      2025-08-13 20:43:34.740	error	Caught by controller[13]: at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1127:27)
      host.iOBroker
      2025-08-13 20:43:34.740	error	Caught by controller[13]: at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2490:15)
      host.iOBroker
      2025-08-13 20:43:34.740	error	Caught by controller[13]: Error: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern
      host.iOBroker
      2025-08-13 20:43:34.740	error	Caught by controller[13]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      host.iOBroker
      2025-08-13 20:43:34.740	error	Caught by controller[12]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
      host.iOBroker
      2025-08-13 20:43:34.740	error	Caught by controller[12]: at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1127:27)
      host.iOBroker
      2025-08-13 20:43:34.740	error	Caught by controller[12]: at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2490:15)
      host.iOBroker
      2025-08-13 20:43:34.740	error	Caught by controller[12]: Error: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern
      host.iOBroker
      2025-08-13 20:43:34.740	error	Caught by controller[12]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      host.iOBroker
      2025-08-13 20:43:34.740	error	Caught by controller[11]: at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
      host.iOBroker
      2025-08-13 20:43:34.740	error	Caught by controller[11]: at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12)
      host.iOBroker
      2025-08-13 20:43:34.740	error	Caught by controller[11]: ReplyError: Error The pattern "linux-control.0.hyperion.services.systemd-fsck@dev-disk-by\x2dpartuuid-2f6f3587\x2d01.restart" is not a valid ID pattern
      host.iOBroker
      2025-08-13 20:43:34.740	error	Caught by controller[11]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      host.iOBroker
      2025-08-13 20:43:34.740	error	Caught by controller[10]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
      host.iOBroker
      2025-08-13 20:43:34.740	error	Caught by controller[10]: at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1127:27)
      host.iOBroker
      2025-08-13 20:43:34.740	error	Caught by controller[10]: at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2490:15)
      host.iOBroker
      2025-08-13 20:43:34.740	error	Caught by controller[10]: Error: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern
      host.iOBroker
      2025-08-13 20:43:34.740	error	Caught by controller[10]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      host.iOBroker
      2025-08-13 20:43:34.740	error	Caught by controller[9]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
      host.iOBroker
      2025-08-13 20:43:34.740	error	Caught by controller[9]: at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1127:27)
      host.iOBroker
      2025-08-13 20:43:34.740	error	Caught by controller[9]: at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2490:15)
      host.iOBroker
      2025-08-13 20:43:34.740	error	Caught by controller[9]: Error: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern
      host.iOBroker
      2025-08-13 20:43:34.740	error	Caught by controller[9]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      host.iOBroker
      2025-08-13 20:43:34.740	error	Caught by controller[8]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
      host.iOBroker
      2025-08-13 20:43:34.740	error	Caught by controller[8]: at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1127:27)
      host.iOBroker
      2025-08-13 20:43:34.740	error	Caught by controller[8]: at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2490:15)
      host.iOBroker
      2025-08-13 20:43:34.740	error	Caught by controller[8]: Error: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern
      host.iOBroker
      2025-08-13 20:43:34.740	error	Caught by controller[8]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      host.iOBroker
      2025-08-13 20:43:34.740	error	Caught by controller[7]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
      host.iOBroker
      2025-08-13 20:43:34.740	error	Caught by controller[7]: at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1127:27)
      host.iOBroker
      2025-08-13 20:43:34.740	error	Caught by controller[7]: at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2490:15)
      host.iOBroker
      2025-08-13 20:43:34.740	error	Caught by controller[7]: Error: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern
      host.iOBroker
      2025-08-13 20:43:34.740	error	Caught by controller[6]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      host.iOBroker
      2025-08-13 20:43:34.740	error	Caught by controller[5]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
      host.iOBroker
      2025-08-13 20:43:34.739	error	Caught by controller[5]: at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1127:27)
      host.iOBroker
      2025-08-13 20:43:34.739	error	Caught by controller[5]: at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2490:15)
      host.iOBroker
      2025-08-13 20:43:34.739	error	Caught by controller[5]: Error: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern
      host.iOBroker
      2025-08-13 20:43:34.739	error	Caught by controller[5]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      host.iOBroker
      2025-08-13 20:43:34.739	error	Caught by controller[4]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
      host.iOBroker
      2025-08-13 20:43:34.739	error	Caught by controller[4]: at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1127:27)
      host.iOBroker
      2025-08-13 20:43:34.739	error	Caught by controller[4]: at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2490:15)
      host.iOBroker
      2025-08-13 20:43:34.739	error	Caught by controller[4]: Error: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern
      host.iOBroker
      2025-08-13 20:43:34.739	error	Caught by controller[4]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      host.iOBroker
      2025-08-13 20:43:34.739	error	Caught by controller[3]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
      host.iOBroker
      2025-08-13 20:43:34.739	error	Caught by controller[3]: at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1127:27)
      host.iOBroker
      2025-08-13 20:43:34.739	error	Caught by controller[3]: at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2490:15)
      host.iOBroker
      2025-08-13 20:43:34.739	error	Caught by controller[3]: Error: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern
      host.iOBroker
      2025-08-13 20:43:34.739	error	Caught by controller[3]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      host.iOBroker
      2025-08-13 20:43:34.739	error	Caught by controller[2]: at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
      host.iOBroker
      2025-08-13 20:43:34.739	error	Caught by controller[2]: at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12)
      host.iOBroker
      2025-08-13 20:43:34.739	error	Caught by controller[2]: ReplyError: Error The pattern "linux-control.0.hyperion.services.●.restart" is not a valid ID pattern
      host.iOBroker
      2025-08-13 20:43:34.739	error	Caught by controller[2]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      host.iOBroker
      2025-08-13 20:43:34.739	error	Caught by controller[1]: at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
      host.iOBroker
      2025-08-13 20:43:34.739	error	Caught by controller[1]: at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12)
      host.iOBroker
      2025-08-13 20:43:34.739	error	Caught by controller[1]: ReplyError: Error The pattern "linux-control.0.hyperion.services.●.restart" is not a valid ID pattern
      host.iOBroker
      2025-08-13 20:43:34.739	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      linux-control.0
      2025-08-13 20:43:34.634	error	[needrestart] hyperion (192.168.178.67:22): error: Cannot find view "system", stack: Error: Cannot find view "system" at ObjectsInRedisClient._getObjectView (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:4272:19) at Immediate.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:4346:33)
      linux-control.0
      2025-08-13 20:43:34.595	error	Cannot find view "system" for search "state" : Connection is closed.
      linux-control.0
      2025-08-13 20:43:34.593	error	[servicesInfo] hyperion (192.168.178.67:22): error: DB closed, stack: Error: DB closed at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25) at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20) at Object.onceWrapper (node:events:639:26) at Socket.emit (node:events:524:28) at Socket.emit (node:domain:489:12) at TCP.<anonymous> (node:net:343:12)
      linux-control.0
      2025-08-13 20:43:34.554	error	The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern
      linux-control.0
      2025-08-13 20:43:34.554	error	Error: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2490:15) at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1127:27) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      linux-control.0
      2025-08-13 20:43:34.554	error	unhandled promise rejection: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern
      linux-control.0
      2025-08-13 20:43:34.553	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      linux-control.0
      2025-08-13 20:43:34.515	error	The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern
      linux-control.0
      2025-08-13 20:43:34.515	error	Error: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2490:15) at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1127:27) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      linux-control.0
      2025-08-13 20:43:34.515	error	unhandled promise rejection: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern
      linux-control.0
      2025-08-13 20:43:34.514	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      linux-control.0
      2025-08-13 20:43:34.480	error	The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern
      linux-control.0
      2025-08-13 20:43:34.480	error	Error: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2490:15) at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1127:27) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      linux-control.0
      2025-08-13 20:43:34.479	error	unhandled promise rejection: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern
      linux-control.0
      2025-08-13 20:43:34.479	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      linux-control.0
      2025-08-13 20:43:34.464	error	Error The pattern "linux-control.0.hyperion.services.systemd-fsck@dev-disk-by\x2dpartuuid-2f6f3587\x2d01.restart" is not a valid ID pattern
      linux-control.0
      2025-08-13 20:43:34.463	error	ReplyError: Error The pattern "linux-control.0.hyperion.services.systemd-fsck@dev-disk-by\x2dpartuuid-2f6f3587\x2d01.restart" is not a valid ID pattern at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12) at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
      linux-control.0
      2025-08-13 20:43:34.463	error	unhandled promise rejection: Error The pattern "linux-control.0.hyperion.services.systemd-fsck@dev-disk-by\x2dpartuuid-2f6f3587\x2d01.restart" is not a valid ID pattern
      linux-control.0
      2025-08-13 20:43:34.463	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      host.iOBroker-Server
      2025-08-13 20:43:34.462	warn	States 127.0.0.1:45704 Error from InMemDB: Error: The pattern "linux-control.0.hyperion.services.systemd-fsck@dev-disk-by\x2dpartuuid-2f6f3587\x2d01.restart" is not a valid ID pattern at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2490:15) at StatesInMemoryServer.handleSubscribe (file:///opt/iobroker/node_modules/@iobroker/db-base/src/lib/inMemFileDB.ts:324:59) at StatesInMemoryServer._subscribeForClient (file:///opt/iobroker/node_modules/@iobroker/db-states-file/src/lib/states/statesInMemFileDB.js:242:14) at RedisHandler.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-states-jsonl/src/lib/states/statesInMemServerRedis.js:380:26) at RedisHandler.emit (node:events:524:28) at RedisHandler.emit (node:domain:489:12) at Immediate._onImmediate (file:///opt/iobroker/node_modules/@iobroker/db-base/src/lib/redisHandler.ts:210:37) at processImmediate (node:internal/timers:483:21)
      linux-control.0
      2025-08-13 20:43:34.436	error	The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern
      linux-control.0
      2025-08-13 20:43:34.436	error	Error: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2490:15) at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1127:27) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      linux-control.0
      2025-08-13 20:43:34.435	error	unhandled promise rejection: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern
      linux-control.0
      2025-08-13 20:43:34.435	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      linux-control.0
      2025-08-13 20:43:34.366	error	The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern
      linux-control.0
      2025-08-13 20:43:34.366	error	Error: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2490:15) at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1127:27) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      linux-control.0
      2025-08-13 20:43:34.365	error	unhandled promise rejection: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern
      linux-control.0
      2025-08-13 20:43:34.365	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      linux-control.0
      2025-08-13 20:43:34.351	error	The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern
      linux-control.0
      2025-08-13 20:43:34.351	error	Error: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2490:15) at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1127:27) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      linux-control.0
      2025-08-13 20:43:34.351	error	unhandled promise rejection: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern
      linux-control.0
      2025-08-13 20:43:34.350	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      linux-control.0
      2025-08-13 20:43:34.288	error	The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern
      linux-control.0
      2025-08-13 20:43:34.288	error	Error: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2490:15) at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1127:27) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      linux-control.0
      2025-08-13 20:43:34.287	error	unhandled promise rejection: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern
      linux-control.0
      2025-08-13 20:43:34.287	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      linux-control.0
      2025-08-13 20:43:34.256	error	The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern
      linux-control.0
      2025-08-13 20:43:34.256	error	Error: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2490:15) at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1127:27) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      linux-control.0
      2025-08-13 20:43:34.255	error	unhandled promise rejection: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern
      linux-control.0
      2025-08-13 20:43:34.255	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      linux-control.0
      2025-08-13 20:43:34.215	error	The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern
      linux-control.0
      2025-08-13 20:43:34.215	error	Error: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2490:15) at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1127:27) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      linux-control.0
      2025-08-13 20:43:34.215	error	unhandled promise rejection: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern
      linux-control.0
      2025-08-13 20:43:34.215	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      linux-control.0
      2025-08-13 20:43:34.194	error	The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern
      linux-control.0
      2025-08-13 20:43:34.194	error	Error: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2490:15) at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1127:27) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      linux-control.0
      2025-08-13 20:43:34.145	error	unhandled promise rejection: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern
      linux-control.0
      2025-08-13 20:43:34.145	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      linux-control.0
      2025-08-13 20:43:34.138	error	ReplyError: Error The pattern "linux-control.0.hyperion.services.●.restart" is not a valid ID pattern at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12) at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
      linux-control.0
      2025-08-13 20:43:34.138	error	unhandled promise rejection: Error The pattern "linux-control.0.hyperion.services.●.restart" is not a valid ID pattern
      linux-control.0
      2025-08-13 20:43:34.138	error	Error The pattern "linux-control.0.hyperion.services.●.restart" is not a valid ID pattern
      linux-control.0
      2025-08-13 20:43:34.137	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      • D denjo
        Node.js: v20.19.4
        JS Controller 7.0.6
        Adapter. 1.1.5
        host.iOBroker
        linux-control.0
        host.iOBroker
        host.iOBroker
        host.iOBroker
        host.iOBroker
        host.iOBroker
        host.iOBroker
        host.iOBroker
        host.iOBroker
        host.iOBroker
        host.iOBroker
        host.iOBroker
        host.iOBroker
        host.iOBroker
        host.iOBroker
        host.iOBroker
        host.iOBroker
        host.iOBroker
        host.iOBroker
        host.iOBroker
        host.iOBroker
        host.iOBroker
        host.iOBroker
        host.iOBroker
        host.iOBroker
        host.iOBroker
        host.iOBroker
        host.iOBroker
        host.iOBroker
        host.iOBroker
        host.iOBroker
        host.iOBroker
        host.iOBroker
        host.iOBroker
        host.iOBroker
        host.iOBroker
        host.iOBroker
        host.iOBroker
        host.iOBroker
        host.iOBroker
        host.iOBroker
        host.iOBroker
        host.iOBroker
        host.iOBroker
        host.iOBroker
        host.iOBroker
        host.iOBroker
        host.iOBroker
        host.iOBroker
        host.iOBroker
        host.iOBroker
        host.iOBroker
        host.iOBroker
        host.iOBroker
        host.iOBroker
        host.iOBroker
        host.iOBroker
        host.iOBroker
        host.iOBroker
        host.iOBroker
        host.iOBroker
        host.iOBroker
        host.iOBroker
        host.iOBroker
        host.iOBroker
        host.iOBroker
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        linux-control.0
        crunchipC Offline
        crunchipC Offline
        #666
        @denjo sagte in Test Adapter Linux Control v1.x.x:
        Ist das Problem
        • F Offline
          flispy
          #667
          Moin,
          leider bekomme ich neuerdings nur noch die Meldungen: "Host seems not to be online".
          Ich habe den Adapter in Version 1.1.6 installiert.
          Ping vom anderen Rechner bzw. Server auf den Host gehen ohne Probleme. Auch die ssh Verbindung von der iobroker shell zum betreffenden Host gehen ohne Probleme.
          iputils-ping habe ich neu installiert.
          Hat jemand eine Idee woran es liegen könnte?
          F 1 Antwort Letzte Antwort
          • F flispy
            Moin,
            flispy
            #668
            @flispy sagte in Test Adapter Linux Control v1.x.x:
            Moin,
            hab es lösen können. Ich musste folgendes ausführen
            sudo setcap cap_net_raw+p /usr/bin/ping
            madingM 1 Antwort Letzte Antwort
            • F flispy
              Moin,
              madingM Offline
              madingM Offline
              mading
              #669
              Moin,
              Geht wieder, habe den Befehl auf dem iobroker ausgeführt. Danke!
              • F Offline
                Fichte
                schrieb am zuletzt editiert von Fichte
                #670
                Hallo zusammen
                Ich hab heut Trixie (Debian 13) unter Proxmox getestet und da erscheint diese Meldung
                [getConnection] Host 'Name' (IP:Port) seems not to be online
                "Ping wird nicht mehr mit erhöhten Privilegien ausgeführt"
                Quelle hier
                Heisst unter einem anderen User außer root geht der befehl "Ping" nicht mehr.
                Wird aber vom Adapter benötigt um zu schauem ob er online ist.
                Abhilfe steht im Link und ist relativ einfach:
                1. Anmelden
                2. sudo nano /usr/lib/sysctl.d/50-default.conf
                3. nach "net.ipv4.ping_group_range = .........." suchen und gegen "net.ipv4.ping_group_range = 1 1000" ersetzen.
                4. Speichern und Neustarten
                Liebe Grüße
                NashraN wendy2702W madingM 3 Antworten Letzte Antwort
                • F Fichte
                  Hallo zusammen
                  Quelle hier
                  1. Anmelden
                  Liebe Grüße
                  NashraN Offline
                  NashraN Offline
                  Nashra
                  Most Active Forum Testing
                  #671
                  @fichte
                  danke für den Hinweis, Ping arbeitet wieder
                  Gruß Ralf
                  • F Fichte
                    Hallo zusammen
                    Quelle hier
                    1. Anmelden
                    Liebe Grüße
                    wendy2702W Online
                    wendy2702W Online
                    #672
                    @fichte auch nach einem Restart ?
                    • wendy2702W wendy2702
                      Fichte
                      #673
                      @wendy2702 Ja Punkt 4
                      • F Fichte
                        Hallo zusammen
                        Quelle hier
                        1. Anmelden
                        Liebe Grüße
                        madingM Offline
                        madingM Offline
                        mading
                        #674
                        @fichte sagte in Test Adapter Linux Control v1.x.x:
                        Hallo zusammen
                        Quelle hier
                        1. Anmelden
                        Liebe Grüße
                        Muss das auf jedem server durchgeführt werden oder nur auf dem iob?
                        • madingM mading
                          Hallo zusammen
                          Quelle hier
                          1. Anmelden
                          Liebe Grüße
                          wendy2702W Online
                          wendy2702W Online
                          #675
                          @mading nur auf dem wo der Linux Control Adapter läuft.
                          • 1Topf1 Offline
                            1Topf1 Offline
                            1Topf
                            #676
                            Ich hab da auch mal ne Frage. Ich hab jetzt einen Raspi3 eingebunden, auf welchem 2 Kameras (Garten u. Hof) auf einem USB-Stick Bilder ablegen. Beide Ordner enthalten aktuell jeweils >20GB Daten. Wieso wird das nicht korrekt dargestellt? Hat da jemand eine Idee? Die Anzahl der Dateien hingegen stimmt.
                            • D3ltoroxpD Offline
                              D3ltoroxpD Offline
                              D3ltoroxp
                              schrieb am zuletzt editiert von D3ltoroxp
                              #677
                              Ich wollte mir das auch mal anschauen. Habe ein paar Befehle eingetragen und mal einen Server. In der Log bekomme ich massig so etwas. An dem Pattern kann ich ja gar nichts ändern.
                              linux-control.0
                              2026-01-10 09:37:46.274	warn	Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
                              linux-control.0
                              2026-01-10 09:37:46.182	error	adapter disabled
                              linux-control.0
                              2026-01-10 09:37:14.374	warn	State "linux-control.0.Proxmox_Homeserver.services.●.load" has no existing object, this might lead to an error in future versions
                              linux-control.0
                              2026-01-10 09:37:14.373	warn	Used invalid characters: linux-control.0.Proxmox_Homeserver.services.●.load changed to linux-control.0.Proxmox_Homeserver.services._.load
                              linux-control.0
                              2026-01-10 09:37:14.310	warn	Used invalid characters: linux-control.0.Proxmox_Homeserver.services.●.stop changed to linux-control.0.Proxmox_Homeserver.services._.stop
                              linux-control.0
                              2026-01-10 09:37:14.308	error	The pattern "io.linux-control.0.Proxmox_Homeserver.services.●.start" is not a valid ID pattern
                              linux-control.0
                              2026-01-10 09:37:14.308	error	Error: The pattern "io.linux-control.0.Proxmox_Homeserver.services.●.start" is not a valid ID pattern at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2490:15) at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1124:27) at processTicksAndRejections (node:internal/process/task_queues:105:5)
                              linux-control.0
                              2026-01-10 09:37:14.307	error	unhandled promise rejection: The pattern "io.linux-control.0.Proxmox_Homeserver.services.●.start" is not a valid ID pattern
                              linux-control.0
                              2026-01-10 09:37:14.307	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                              linux-control.0
                              2026-01-10 09:37:14.305	warn	Used invalid characters: linux-control.0.Proxmox_Homeserver.services.●.start changed to linux-control.0.Proxmox_Homeserver.services._.start
                              linux-control.0
                              2026-01-10 09:37:14.304	error	Error The pattern "linux-control.0.Proxmox_Homeserver.services.●.restart" is not a valid ID pattern
                              linux-control.0
                              2026-01-10 09:37:14.304	error	ReplyError: Error The pattern "linux-control.0.Proxmox_Homeserver.services.●.restart" is not a valid ID pattern at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12) at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
                              linux-control.0
                              2026-01-10 09:37:14.303	error	unhandled promise rejection: Error The pattern "linux-control.0.Proxmox_Homeserver.services.●.restart" is not a valid ID pattern
                              linux-control.0
                              2026-01-10 09:37:14.303	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                              linux-control.0
                              2026-01-10 09:37:14.302	warn	Used invalid characters: linux-control.0.Proxmox_Homeserver.services.●.restart changed to linux-control.0.Proxmox_Homeserver.services._.restart
                              linux-control.0
                              2026-01-10 09:37:14.259	warn	State "linux-control.0.Proxmox_Homeserver.services.●.description" has no existing object, this might lead to an error in future versions
                              linux-control.0
                              2026-01-10 09:37:14.258	warn	Used invalid characters: linux-control.0.Proxmox_Homeserver.services.●.description changed to linux-control.0.Proxmox_Homeserver.services._.description
                              linux-control.0
                              2026-01-10 09:37:14.209	warn	State "linux-control.0.Proxmox_Homeserver.services.●.running" has no existing object, this might lead to an error in future versions
                              linux-control.0
                              2026-01-10 09:37:14.207	warn	Used invalid characters: linux-control.0.Proxmox_Homeserver.services.●.running changed to linux-control.0.Proxmox_Homeserver.services._.running
                              linux-control.0
                              2026-01-10 09:37:14.159	warn	State "linux-control.0.Proxmox_Homeserver.services.●.active" has no existing object, this might lead to an error in future versions
                              linux-control.0
                              2026-01-10 09:37:14.158	warn	Used invalid characters: linux-control.0.Proxmox_Homeserver.services.●.active changed to linux-control.0.Proxmox_Homeserver.services._.active
                              linux-control.0
                              2026-01-10 09:37:14.114	warn	State "linux-control.0.Proxmox_Homeserver.services.●.load" has no existing object, this might lead to an error in future versions
                              linux-control.0
                              2026-01-10 09:37:14.113	warn	Used invalid characters: linux-control.0.Proxmox_Homeserver.services.●.load changed to linux-control.0.Proxmox_Homeserver.services._.load
                              linux-control.0
                              2026-01-10 09:37:14.010	error	Error The pattern "linux-control.0.Proxmox_Homeserver.services.●.stop" is not a valid ID pattern
                              Was kann ich tun, oder wo liegt mein Fehler. So sehen die Befehle aus.
                              • madingM Offline
                                madingM Offline
                                mading
                                schrieb am zuletzt editiert von mading
                                #678
                                Interessant, irgendwie interpretiert er was falsch bzgl. des Datenpunkts services.●.load und der anderen
                                Gibt es den Datenpunkt? Wie ist er benannt?
                                • Ro75R Offline
                                  Ro75R Offline
                                  Ro75
                                  #679
                                  Ggfs. mit Alias arbeiten.
                                  Ro75.
                                    D3ltoroxpD Offline
                                    D3ltoroxp
                                    #680
                                    Hm der Adapter hat ja die DP's erstellt, sollte das dann nicht passen ? Heißt das ich müsst die jetzt von Hand abändern, wenn ich so komische Schreibweise finde ?
                                    • D3ltoroxpD D3ltoroxp
                                      crunchipC Offline
                                      crunchipC Offline
                                      #681
                                      @D3ltoroxp die Frage ist eher, was da genau läuft auf deinen Systemen. Hat ja nichts mit den Befehlen zu tun.
                                      D3ltoroxpD 1 Antwort Letzte Antwort
                                      • RoddiEFR Offline
                                        RoddiEFR Offline
                                        RoddiEF
                                        #682
                                        Ich war mal so frei und habe mir diesen Adapter mal installiert aber bekomme sofort nach dem ersten Start eine Fehlermeldung:
                                        linux-control.0
                                        2026-01-12 18:02:09.233	error	Object linux-control.0.command.host is invalid: obj.common.states has an invalid type! Expected "object", received "string"
                                        Kann jemand was damit anfangen und mir Sagen wo der Adapter sein Problem hat?
                                        Edit:
                                        Eingetragen sind nur 2 Raspberry sonst sind keine weiteren Einstellungen gemacht worden.
                                        Ich bin wie ich bin, was anderes bekommt man nicht !!
                                        • RoddiEFR RoddiEF
                                          linux-control.0
                                          Edit:
                                          Meister MopperM Online
                                          Meister Mopper
                                          schrieb am zuletzt editiert von Meister Mopper
                                          #683
                                          @RoddiEF
                                          Guckst du hier
                                          Is aber nicht schlimm, der Adapter läuft sonst super gut!
                                          Proxmox und HA ...
