  4. Test Adapter Zendure Solarflow
2.7k Beiträge 129 Kommentatoren 1.4m Aufrufe 128 Beobachtet
    @michi-0 sagte in Test Adapter Zendure Solarflow:
    Log sieht aus wie zuvor.
    Chronologisch falsch herum.
    Lies doch das Log aus
    iob logs --watch
    aus. Oder ändere wenigstens die Anzeigerichtung in der GUI, wenn du es schon da raus kopieren musst...
    System auf Stand gebracht?
    Michi 0
    #1520
    JS noch mit upgedated.
    2025-07-20 18:46:08.757  - info: host.iobroker-server instance system.adapter.mqtt.0 in version "6.1.2" started with pid 36040
    2025-07-20 18:46:08.907  - info: ical.1 (36025) Terminated (NO_ERROR): Without reason
    2025-07-20 18:46:09.422  - info: host.iobroker-server instance system.adapter.ical.1 having pid 36025 terminated with code 0 (NO_ERROR)
    2025-07-20 18:46:09.480  - info: host.iobroker-server stopInstance system.adapter.zendure-solarflow.0 (force=false, process=true)
    2025-07-20 18:46:09.483  - info: zendure-solarflow.0 (35487) Got terminate signal TERMINATE_YOURSELF
    2025-07-20 18:46:09.484  - info: zendure-solarflow.0 (35487) [onUnload] MQTT client stopped!
    2025-07-20 18:46:09.484  - info: zendure-solarflow.0 (35487) terminating
    2025-07-20 18:46:09.484  - info: zendure-solarflow.0 (35487) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2025-07-20 18:46:09.547  - info: host.iobroker-server stopInstance system.adapter.zendure-solarflow.0 send kill signal
    2025-07-20 18:46:09.577  - info: mqtt.0 (36040) starting. Version 6.1.2 in /opt/iobroker/node_modules/iobroker.mqtt, node: v20.19.4, js-controller: 7.0.6
    2025-07-20 18:46:09.705  - info: mqtt.0 (36040) Starting MQTT server on 192.168.2.52:1883
    2025-07-20 18:46:09.775  - info: mqtt.0 (36040) State value to set for "mqtt.0.info.clients.iobroker-server_mqtt_1" has to be type "string" but received type "boolean"
    2025-07-20 18:46:09.985  - info: zendure-solarflow.0 (35487) terminating
    2025-07-20 18:46:10.030  - info: host.iobroker-server instance system.adapter.zendure-solarflow.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2025-07-20 18:46:13.188  - info: host.iobroker-server instance system.adapter.zendure-solarflow.0 in version "1.15.4" started with pid 36055
    2025-07-20 18:46:13.930  - info: zendure-solarflow.0 (36055) starting. Version 1.15.4 in /opt/iobroker/node_modules/iobroker.zendure-solarflow, node: v20.19.4, js-controller: 7.0.6
    2025-07-20 18:46:14.027  - info: mqtt.0 (36040) Client [ioBroker.zendure-solarflow.0] connected with secret 1753029974025_3999
    2025-07-20 18:46:14.050  - info: zendure-solarflow.0 (36055) [onConnected] Connected with MQTT!
    2025-07-20 18:46:14.092  - info: mqtt.0 (36040) State value to set for "mqtt.0.info.clients.iobroker-server_mqtt_1" has to be type "string" but received type "boolean"
    2025-07-20 18:46:14.996  - info: mqtt.0 (36040) Client [ioBroker.zendure-solarflow.0] subscribes on "/BC8B7F/BC8B7F/#" with regex /^BC8B7F\.BC8B7F\..*/
    2025-07-20 18:46:14.996  - info: mqtt.0 (36040) Client [ioBroker.zendure-solarflow.0] subscribes on "/BC8B7F/BC8B7F/#"  with regex /^mqtt\.0\.BC8B7F\.BC8B7F\..*/
    2025-07-20 18:46:14.997  - info: mqtt.0 (36040) Client [ioBroker.zendure-solarflow.0] subscribes on "iot/BC8B7F/BC8B7F/#" with regex /^iot\.BC8B7F\.BC8B7F\..*/
    2025-07-20 18:46:14.997  - info: mqtt.0 (36040) Client [ioBroker.zendure-solarflow.0] subscribes on "iot/BC8B7F/BC8B7F/#"  with regex /^mqtt\.0\.iot\.BC8B7F\.BC8B7F\..*/
    2025-07-20 18:46:15.196  - info: mqtt.0 (36040) Client [ioBroker.zendure-solarflow.0] publishOnSubscribe send all known states
    2025-07-20 18:46:15.198  - info: mqtt.0 (36040) Client [ioBroker.zendure-solarflow.0] publishOnSubscribe send all known states
    Hoffe ich nähere mich einer lesbaren Fehleranzeige ;-)
    • D Online
      D Online
      Daniel 8
      #1521
      Was hat es jetzt mit dem Schalter Smart Mode auf sich? Ich kann den Solarflow 800 Pro wie oben schon mal beschrieben nicht umschalten. Er springt immer wieder zurück. Was kann ich noch versuchen?
      Solarflow 800 Pro mit 1,3 Kwp / Iobroker / Homematic / Shellys / Mediola / Intertechno
      • M Michi 0
        #1522
        Fehleranzeige
        Ja.
        Aber da stehen gar keine Fehlermeldungen drin.
        • M Michi 0
          Hallo Zusammen,
          habe seit 3 Tagen einen Solarflow 2400 ac. Den Adapter habe ich in Version 2.0.0 alpha.0 installiert. Wenn er in der Clound hängt bekommt er auch alle Daten. Änderungen sind aber nicht möglich.
          Leider habe ich von Mqtt keine Ahnung und komme daher trotz fleißigen Lesen dieses Threads nicht klar mit der Steuerung. Wenn ich den Adapter auf Lokal umstelle bekommt der Mqtt keinerlei Daten. Im Log schaut (für mich) alles ganz gut aus.
          Wenn ich im Solarflow Änderungen mache werden bei manchen Postitionen (bspw. "Set AC Mode") diese in den Mqtt-Objekten angezeigt (ohne Wirkung auf den Solarflow). Bei manchen Änderungen (bspw. Entladeleistung) werden diese nicht in den Mqtt-Objekten angezeigt.
          Den Cloud-Disconnector habe ich verwendet. Glaube aber nicht dass das funktioniert hat, da die Handy-App immer noch vollen Zugriff hat. Im Cloud-Disconnector konnte ich leider auch nicht die Telemetrie abrufen. Trotzdem habe ich beim Override die Mitteilung erhalten, dass der Traffic nun an den lokalen Mqtt-Server umgeleitet wird.
          Hat einer von Euch ne Ahnung was da schief läuft?
          maxclaudiM Offline
          maxclaudiM Offline
          maxclaudi
          schrieb am zuletzt editiert von maxclaudi
          #1523
          Kann nicht sein, dass productId == deviceId ist
          Die productid ist z.B. 6-stellig, in Deinem Fall: BC8B7F
          Die deviceID ist z.B. 8-stellig, fingiertes Beispiel: AaBccXcd
          Falls der Disconnector beim 2400AC funktioniert, hast Du doch die deviceId erfahren und notiert/gespeichert?
          Beispiel:
          die deviceId bei Adapter-Instanz eingegeben.
          Beispiel:
          Broker wird anonym betrieben? Ohne user+password?
          Danach müsste im log die deviceId auftauchen, nur als Beispiel von oben kopiert:
          > 2025-07-20 18:46:14.997  - info: mqtt.0 (36040) Client [ioBroker.zendure-solarflow.0] subscribes on "iot/BC8B7F/AaBccXcd/....
          Den Rest , wie auch Broker mit user und password verwenden, generieren usw. findest hier im Thread oder/und in meinen posts.
          Zendure zenSDK Lokal API, SmartMode, SolarFlow AC 800 Pro 2
          Zendure wie 2400 AC Pro lokale IP statt Cloud: zURLtool
          maxclaudiM 1 Antwort Letzte Antwort
          • maxclaudiM maxclaudi
            Beispiel:
            Beispiel:
            maxclaudiM Offline
            maxclaudiM Offline
            maxclaudi
            #1524
            @nograx
            Es wäre doch gut, auf github oder/und im disconnector darauf hinzuweisen, dass nur die reine ip, explizit ohne mqtt:// und ohne port, beim disconnector eingegeben werden muss.
            Auch eine kurze Beschreibung wie zur Cloud reconnected wird.
            edit
            habe in code geschaut.
            Reconnect to Zendure Cloud benötigt nur WifiName, WifiPassword.
            mit klick auf Button "Reconnect to Zendure Cloud" wird als Server automatisch der globale Server verwendet: mq.zen-iot.com
              Michi 0
              #1525
              Hatte die Device-ID ursprünglich aus der Handyapp. Die ist aber nur 5-stellig... Bevor ich den Auszug aus dem Log gepostet hab, hab ich in meiner Verzweiflung einfach mal wild rumprobiert. Da das im Log zu keinen anderen Fehlermeldungen als zuvor geführt hat, hat ich das zurückstellen auf die (vermutlich ebenfalls falsche) ID vergessen.
              Wie gesagt hatte ich im Disconnector die Telemetriedaten nicht erhalten. Dann kann ich wohl davon ausgehen, dass trotz der Vollzugsmeldung die Trennung NICHT geklappt hat...?
              Hab auf Git gesehen dass das Programm bestimmte Bluetooth Eigenschaften (Werbung)= nutzt:
              using Windows.Devices.Bluetooth;
              using Windows.Devices.Bluetooth.Advertisement;
              using Windows.Devices.Bluetooth.GenericAttributeProfile;
              Und hierzu die Details vom meinem Intel-Bluetooth-Gerät:
              Kann ich die Verbindung vergessen wenn hier der Wert <falsch> ist?
              Adapter wird ohne User und PW betrieben.
              2025-07-20 21:06:19.866  - info: zendure-solarflow.0 (39027) starting. Version 1.15.4 in /opt/iobroker/node_modules/iobroker.zendure-solarflow, node: v20.19.4, js-controller: 7.0.6
              2025-07-20 21:06:19.956  - info: mqtt.0 (36040) Client [ioBroker.zendure-solarflow.0] connected with secret 1753038379950_5748
              2025-07-20 21:06:19.960  - info: zendure-solarflow.0 (39027) [onConnected] Connected with MQTT!
              2025-07-20 21:06:19.980  - info: mqtt.0 (36040) State value to set for "mqtt.0.info.clients.iobroker-server_mqtt_1" has to be type "string" but received type "boolean"
              2025-07-20 21:06:20.925  - info: mqtt.0 (36040) Client [ioBroker.zendure-solarflow.0] subscribes on "/BC8B7F/5-stelligeID/#" with regex /^BC8B7F\.5-stelligeID\..*/
              2025-07-20 21:06:20.925  - info: mqtt.0 (36040) Client [ioBroker.zendure-solarflow.0] subscribes on "/BC8B7F/5-stelligeID/#"  with regex /^mqtt\.0\.BC8B7F\.5-stelligeID\..*/
              2025-07-20 21:06:20.926  - info: mqtt.0 (36040) Client [ioBroker.zendure-solarflow.0] subscribes on "iot/BC8B7F/5-stelligeID/#" with regex /^iot\.BC8B7F\.5-stelligeID\..*/
              2025-07-20 21:06:20.926  - info: mqtt.0 (36040) Client [ioBroker.zendure-solarflow.0] subscribes on "iot/BC8B7F/5-stelligeID/#"  with regex /^mqtt\.0\.iot\.BC8B7F\.5-stelligeID\..*/
              2025-07-20 21:06:21.126  - info: mqtt.0 (36040) Client [ioBroker.zendure-solarflow.0] publishOnSubscribe send all known states
              2025-07-20 21:06:21.127  - info: mqtt.0 (36040) Client [ioBroker.zendure-solarflow.0] publishOnSubscribe send all known states
                @nograx
                edit
                Michi 0
                #1526
                @maxclaudi
                Hab grad die beiden Url´s auf dem Pi-Hole auf den ioBroker bzw. Mqtt Server umgeleitet. In der Handyapp ist die Verbindung jetzt zumindest weg. Allerdings dürfte damit immer noch nicht mein DeviceID-Problem gelöst sein.
                Wie kann ich die sonst noch rausbekommen?
                maxclaudiM nograxN 2 Antworten Letzte Antwort
                • M Michi 0
                  @maxclaudi
                  maxclaudiM Offline
                  maxclaudiM Offline
                  maxclaudi
                  #1527
                  @michi-0
                  wenn die URL erfolgreich umgeleitet wird, dann werden keys und value beim Broker published (irgendwann, vielleicht auch erst nach Stunden).
                  Der Broker veröffentlicht ja dann.
                  Nimm MQTT-Explorer und verbinde Dich mit Deinem Broker und warte ab.
                  Oder installiere ne mqtt-Client-Instanz, verbinde Dich mit dem Server.
                  Spätestens nach ein paar Stunden (oder Morgen Mittag) werden Nachrichten veröffentlicht.
                  Wenn es mehr Veränderungen gibt, geht's auch schneller
                  Dann siehst was angelegt wurde.
                  deviceId ist dann direkt unter der productId.
                  /BC8B7F/deviceId/properties/report
                  oder z. B. im mqtt-Client-Adapter:
                  mqtt.x.BC8B7F.deviceId.properties.report
                  oder schau beim Broker im log (wenn darauf reagiert wird/eingestellt ist)
                  Edit:
                  Ob und was man in der App alles sieht, weiß ich schon gar nicht mehr.
                  Vielleicht geht's da auch?
                  Muss jemand anderes beantworten oder selbst rausfinden.
                  deviceId ist auf jeden Fall nicht sn und auch nicht Deine productID.
                  • M Michi 0
                    @maxclaudi
                    nograxN Online
                    nograxN Online
                    nograx
                    #1528
                    @michi-0 Hast du den 2400 AC mal komplett stromlos gemacht und ausgeschaltet? Bluetooth Verbindung muss zwingend getrennt werden. Bevor beides nicht gemacht wurde werden die Daten weiterhin entweder an die Cloud geschickt oder NUR per Bluetooth übertragen.
                    • L Offline
                      lesiflo
                      #1529
                      Moin, auch wenn das schon mal irgendwo beantwortet wurde, wozu ist der neue Schalter "Smart Mode" ? Hab's nicht mitbekommen.
                      nograxN 1 Antwort Letzte Antwort
                      • L lesiflo
                        nograxN Online
                        nograxN Online
                        nograx
                        #1530
                        @lesiflo sagte in Test Adapter Zendure Solarflow:
                        Werde ich noch mal in der readme dokumentieren. Ist zwar nicht zu 100% bestätigt, aber es ist wohl so das Control-Änderungen die hart über die properties laufen (z.B. setOutputLimit, acMode) in den flash speicher geschrieben werden. Das kann dann die Lebensdauer des Gerätes beeinträchtigen, bzw. können irgendwann ggf. Änderungen nicht mehr sauber gespeichert werden. "smartMode" sollte dann dafür sorgen das Änderungen nur noch in den Ram geschrieben werden.
                        Gleichzeitig bin ich gerade dabei die "deviceAutomation" Funktion einzubauen, dann werden die Geräte exakt so gesteuert wie Zendure das über die Cloud macht (funktioniert auch lokal). Diese Funktion dürfte dann auch nicht in den Flash schreiben.
                          Michi 0
                          #1531
                          Danke schon mal für die Hinweise. Meine Frau ist heute und morgen im Homeoffice. Da traue ich mich nicht mit DNS an der Internetverbindung rumzuspielen ;-)
                          Kann mich daher erst ab Mittwoch wieder der DNS Thematik über den PI-Hole widmen...
                          Den Solarflow hatte ich für mindestens 10 Sekunden ausgeschaltet und auch vom Netz genommen. Im Disconnector wurde er mir aber auch "nur" als SolarHub angezeigt.
                          • M Michi 0
                            nograxN Online
                            nograxN Online
                            nograx
                            #1532
                            Ich habe bisher auch kein positives Beispiel vom 2400 AC vom Disconnector. Offensichtlich verwendet Zendure für den 2400 AC einen ähnlichen Bluetooth Namen wie beim Hub...
                            • nograxN nograx
                              D Online
                              D Online
                              Daniel 8
                              #1533
                              @nograx sagte in Test Adapter Zendure Solarflow:
                              Bei mir ist es ja immer noch so, das der Smartmodus nicht bleibt wenn ich ihn im iobroker umschalte. Habe einen solarflow 800 pro. An was kann das.liegen?
                              • D Daniel 8
                                nograxN Online
                                nograxN Online
                                nograx
                                #1534
                                @daniel-8 sagte in Test Adapter Zendure Solarflow:
                                Ich vermute das es den dann beim sf 800 pro nicht gibt. Daher hier die Empfehlung die Steuerung über die 'setDeviceAutomationInOutLimit' zu machen. Das werde ich heute noch in den Beta Kanal schieben.
                                • nograxN nograx
                                  D Online
                                  D Online
                                  Daniel 8
                                  #1535
                                  @nograx also wenn ich in der cloud umschalten dann wird der datenpunkt im iobroker geschälten. Nur andersum geht es nicht. Was macht die neue Regelung anderst?
                                  • nograxN nograx
                                    @stony2k sagte in Test Adapter Zendure Solarflow:
                                    Wird die SolarFlow 800 Pro auch schon bereits vom Adapter unterstützt?
                                    Sollte zumindest per Cloud jetzt funktionieren. Wenn du den eingebunden hast würde es mich freuen wenn du mir dem ProductKey mal zukommen lassen könntest.
                                    tobetobeT Offline
                                    tobetobeT Offline
                                    tobetobe
                                    #1536
                                    ich habe seit einigen Tagen den SF 800 pro. Der Adapter kommuniziert über den EU-Server mit dem Gerät und stellt die Daten in den Objekten korrekt und schnell dar.
                                    Weder in der App noch im Adapter finde ich jedoch den gewünschten ProductKey. Gibt es dafür ggf noch eine andere Bezeichnung? Wo muss ich da suchen?
                                    Mit MQTT bin ich noch nicht wirklich weiter gekommen. Hat es jemand bereits geschafft, die BT Daten des SolarFlow 800 pro mit dem BT Manager auszulesen?
                                    Beste Grüße
                                    tobetobe
                                    • tobetobeT tobetobe
                                      nograxN Online
                                      nograxN Online
                                      nograx
                                      schrieb am zuletzt editiert von nograx
                                      #1537
                                      @tobetobe sagte in Test Adapter Zendure Solarflow:
                                      Wenn der Adapter sauber Daten liefert sollte der Objektbaum wie folgte aufgebaut sein:
                                      zendure-solarflow.0.PRODUCTKEY.DEVICEKEY
                                      ProductKey = Gerätetyp
                                      DeviceKey = Individueller Key für dein Gerät (unbedingt geheim halten)
                                      T tobetobeT 2 Antworten Letzte Antwort
                                      • nograxN nograx
                                        The_Stig
                                        #1538
                                        @nograx nochmal zu dem Smartmode (bin grad im Urlaub und kann nicht testen): verstehe ich es richtig, dass mit dem Setzen dieses Modus auch gar nicht mehr die „normale“ Steuerung über iobroker/Blockly notwendig ist? Hab das leider überhaupt noch nicht verstanden, was das bewirkt? Oben schrieb ja auch jemand was von SOC - aber das sollte doch damit nichts zu tun haben, oder?
                                        • nograxN nograx
                                          tobetobeT Offline
                                          tobetobeT Offline
                                          tobetobe
                                          #1539
                                          @nograx
                                          Vielen Dank. Der ProductKey lautet R3mn8U
                                          Beste Grüße
                                          tobetobe
