  4. Anfrage zu solax Adapter für Solax X1 Mini 1.5 G4
71 Beiträge 4 Kommentatoren 3.0k Aufrufe 4 Beobachtet
  • simatecS simatec
    @icke2002 Also bei mir läuft es sauber durch ...
    $ iobroker url simatec/ioBroker.solax --host iobroker-dev --debug
    install simatec/ioBroker.solax
    NPM version: 10.7.0
    Installing simatec/ioBroker.solax... (System call)
    removed 362 packages, and changed 1 package in 4s157 packages are looking for funding run `npm fund` for details
    upload [16] solax.admin /opt/iobroker/node_modules/iobroker.solax/admin/admin.d.ts admin.d.ts video/mp2t
    upload [14] solax.admin /opt/iobroker/node_modules/iobroker.solax/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [12] solax.admin /opt/iobroker/node_modules/iobroker.solax/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [11] solax.admin /opt/iobroker/node_modules/iobroker.solax/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [9] solax.admin /opt/iobroker/node_modules/iobroker.solax/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [6] solax.admin /opt/iobroker/node_modules/iobroker.solax/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
    upload [5] solax.admin /opt/iobroker/node_modules/iobroker.solax/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [3] solax.admin /opt/iobroker/node_modules/iobroker.solax/admin/jsonConfig.json jsonConfig.json application/json
    upload [2] solax.admin /opt/iobroker/node_modules/iobroker.solax/admin/solax.png solax.png image/png
    upload [0] solax.admin /opt/iobroker/node_modules/iobroker.solax/admin/words.js words.js application/javascript
    Update "system.adapter.solax.0"
    Process exited with code 0
    simatecS Offline
    simatecS Offline
    simatec
    @simatec Starte mal dein System komplett neu und versuche es erneut
    • Besuche meine Github Seite
    • HowTo Restore ioBroker
    I 2 Antworten Letzte Antwort
    • simatecS simatec
      I Offline
      I Offline
      icke2002
      @simatec ok mach ich!
      • I icke2002
        @homoran verstehe ich nicht - bei mir ist alles zu erkennen???
        @icke2002 sagte in Anfrage zu solax Adapter für Solax X1 Mini 1.5 G4:
        ich denke mal dein Bildschirm ist breiter als 7cm.
        I 1 Antwort Letzte Antwort
          I Offline
          I Offline
          icke2002
          @homoran richtig?
          • simatecS simatec
            I Offline
            I Offline
            icke2002
            @simatec hat nichts genützt - bricht mit Fehler ab!?
            0 verbose cli C:\Program Files\nodejs\node.exe C:\Program Files\nodejs\node_modules\npm\bin\npm-cli.js
            1 info using npm@10.7.0
            2 info using node@v20.15.0
            3 silly config:load:file:C:\Program Files\nodejs\node_modules\npm\npmrc
            4 silly config:load:file:C:\ioBroker\.npmrc
            5 silly config:load:file:C:\WINDOWS\system32\config\systemprofile\.npmrc
            6 silly config:load:file:C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm\etc\npmrc
            7 verbose title npm install simatec/ioBroker.solax
            8 verbose argv "install" "simatec/ioBroker.solax"
            9 verbose logfile logs-max:10 dir:C:\WINDOWS\system32\config\systemprofile\AppData\Local\npm-cache\_logs\2024-06-23T17_34_25_905Z-
            10 verbose logfile C:\WINDOWS\system32\config\systemprofile\AppData\Local\npm-cache\_logs\2024-06-23T17_34_25_905Z-debug-0.log
            11 silly logfile done cleaning log files
            12 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules/iobroker.solax
            13 verbose stack Error: An unknown git error occurred
            13 verbose stack     at makeError (C:\Program Files\nodejs\node_modules\npm\node_modules\@npmcli\git\lib\make-error.js:28:13)
            13 verbose stack     at C:\Program Files\nodejs\node_modules\npm\node_modules\@npmcli\git\lib\spawn.js:37:26
            13 verbose stack     at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
            14 verbose cwd C:\ioBroker
            15 verbose Windows_NT 10.0.19045
            16 verbose node v20.15.0
            17 verbose npm  v10.7.0
            18 error code ENOENT
            19 error syscall spawn git
            20 error path git
            21 error errno -4058
            22 error enoent An unknown git error occurred
            23 error enoent This is related to npm not being able to find a file.
            23 error enoent
            24 verbose exit -4058
            25 verbose code -4058
            26 silly unfinished npm timer reify 1719164066510
            27 silly unfinished npm timer reify:loadTrees 1719164066570
            28 silly unfinished npm timer idealTree:userRequests 1719164066788
            29 error A complete log of this run can be found in: C:\WINDOWS\system32\config\systemprofile\AppData\Local\npm-cache\_logs\2024-06-23T17_34_25_905Z-debug-0.log
            • I icke2002
              @icke2002
              9 verbose logfile logs-max:10 dir:C:\WINDOWS\system32\config\systemprofile\AppData\Local\npm-cache\_logs\2024-06-27T14_25_10_988Z-
              10 verbose logfile C:\WINDOWS\system32\config\systemprofile\AppData\Local\npm-cache\_logs\2024-06-27T14_25_10_988Z-debug-0.log
              20 error path git
              23 error enoent
              26 silly unfinished npm timer reify 1719498311579
              27 silly unfinished npm timer reify:loadTrees 1719498311583
              28 silly unfinished npm timer idealTree:userRequests 1719498311824
              29 error A complete log of this run can be found in: C:\WINDOWS\system32\config\systemprofile\AppData\Local\npm-cache\_logs\2024-06-27T14_25_10_988Z-debug-0.log
              simatecS Offline
              simatecS Offline
              simatec
              @icke2002 Dann lösche den Adapter vorher komplett. Also auch im Tab Adapter. Sprich Instanzen und Adapter löschen.
              Im Anschluss dann nochmals die Installation via Github siehe Screenshot
              • simatecS simatec
                I Offline
                I Offline
                icke2002
                @simatec Wird leider immer schlimmer!?
                Die Version 0.9.7 von npm lässt sich installieren - fehlt bei mir irgendetwas?
                Punkt 13 und 18 - 23 - ich verstehe es nicht!
                9 verbose logfile logs-max:10 dir:C:\WINDOWS\system32\config\systemprofile\AppData\Local\npm-cache\_logs\2024-06-27T16_53_21_153Z-
                10 verbose logfile C:\WINDOWS\system32\config\systemprofile\AppData\Local\npm-cache\_logs\2024-06-27T16_53_21_153Z-debug-0.log
                11 silly logfile start cleaning logs, removing 1 files
                12 silly logfile done cleaning log files
                20 error path git
                23 error enoent
                26 silly unfinished npm timer reify 1719507201733
                27 silly unfinished npm timer reify:loadTrees 1719507201739
                28 silly unfinished npm timer idealTree:userRequests 1719507201999
                29 error A complete log of this run can be found in: C:\WINDOWS\system32\config\systemprofile\AppData\Local\npm-cache\_logs\2024-06-27T16_53_21_153Z-debug-0.log
                • I icke2002
                  20 error path git
                  23 error enoent
                  20 error path git
                  23 error enoent
                  da war doch was mit dem installer für Win.
                  Ich glaube der installiert das Paket git nicht standardmäßig
                    20 error path git
                    23 error enoent
                    I Offline
                    I Offline
                    icke2002
                    @homoran ok - danke - wie kann ich das Problem als newbee lösen?
                    HomoranH simatecS 2 Antworten Letzte Antwort
                    • I icke2002
                      Suche benutzen und u.a. dieses finden:
                      https://forum.iobroker.net/post/1166454
                      • I icke2002
                        simatecS Offline
                        simatecS Offline
                        simatec
                        @icke2002 oder du wartest, bis ich die Version auf npm habe und installierst von npm über die Katze
                          I Offline
                          I Offline
                          icke2002
                          @homoran Ich hatte gesucht - aber nicht gefunden - Danke für den Tip. Nach Neustart lief die Installation!👍 😳
                          • simatecS simatec
                            I Offline
                            I Offline
                            icke2002
                            @simatec nach der git -Installation konnte ich den Adapter installieren und jetzt läuft es!
                            Super - Danke!👍 👍 👍
                            • I icke2002
                              Super - Danke!👍 👍 👍
                              simatecS Offline
                              simatecS Offline
                              simatec
                              @icke2002 Poste mal bitte die Objekte, die nun alle erzeugt wurden. Sind die Daten alle korrekt und plausibel?
                              • simatecS simatec
                                I Offline
                                I Offline
                                icke2002
                                @simatec
                                • simatecS simatec
                                  I Offline
                                  I Offline
                                  icke2002
                                  schrieb am zuletzt editiert von icke2002
                                  @simatec schein erstmal ok zu sein - werde ich morgen nochmal prüfen, wenn mehr Sonne ist.
                                  Ich will das Ganze dann sowieso auf einer Raspi4 zum Laufen bringen. Ich habe heute auf jeden Fall viel gelernt - danke nochmal!
                                  • I icke2002
                                    @simatec
                                    @icke2002
                                    @homoran sagte in Anfrage zu solax Adapter für Solax X1 Mini 1.5 G4:
                                    @icke2002 Bitte keine 4K Briefmarken posten!
                                    24% davon sind zu wenig zum erkennen.
                                    3.1k ist nicht viel besser lesbar ;-)
                                    • I icke2002
                                      simatecS Offline
                                      simatecS Offline
                                      simatec
                                      @icke2002 feddInEnergy sieht irgendwie komisch aus vom Wert... Prüfe das mal, ob das passt
                                        @icke2002
                                        I Offline
                                        I Offline
                                        icke2002
                                        @homoran ich weiss leider nicht, wie es besser geht - es wird noch dem Einfügen immer auf resized gesetzt?
                                        • I icke2002
                                          Fenster deutlich schmaler ziehen, ohne dass Informationen verloren gehen.
                                          siehe auch: https://forum.iobroker.net/topic/51555/hinweise-für-gute-forenbeiträge/1
                                          Bin zwar jetzt am "großen" Monitor, aber mit
                                          lässt sich kein 4k sinnvoll darstellen
