  4. Anfrage zu solax Adapter für Solax X1 Mini 1.5 G4
71 Beiträge 4 Kommentatoren 3.0k Aufrufe 4 Beobachtet
  • I icke2002
    @simatec Wird leider immer schlimmer!?
    Die Version 0.9.7 von npm lässt sich installieren - fehlt bei mir irgendetwas?
    Punkt 13 und 18 - 23 - ich verstehe es nicht!
    0 verbose cli C:\Program Files\nodejs\node.exe C:\Program Files\nodejs\node_modules\npm\bin\npm-cli.js
    1 info using npm@10.7.0
    2 info using node@v20.15.0
    3 silly config:load:file:C:\Program Files\nodejs\node_modules\npm\npmrc
    4 silly config:load:file:C:\ioBroker\.npmrc
    5 silly config:load:file:C:\WINDOWS\system32\config\systemprofile\.npmrc
    6 silly config:load:file:C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm\etc\npmrc
    7 verbose title npm install simatec/ioBroker.solax
    8 verbose argv "install" "simatec/ioBroker.solax"
    9 verbose logfile logs-max:10 dir:C:\WINDOWS\system32\config\systemprofile\AppData\Local\npm-cache\_logs\2024-06-27T16_53_21_153Z-
    10 verbose logfile C:\WINDOWS\system32\config\systemprofile\AppData\Local\npm-cache\_logs\2024-06-27T16_53_21_153Z-debug-0.log
    11 silly logfile start cleaning logs, removing 1 files
    12 silly logfile done cleaning log files
    13 verbose stack Error: An unknown git error occurred
    13 verbose stack     at makeError (C:\Program Files\nodejs\node_modules\npm\node_modules\@npmcli\git\lib\make-error.js:28:13)
    13 verbose stack     at C:\Program Files\nodejs\node_modules\npm\node_modules\@npmcli\git\lib\spawn.js:37:26
    13 verbose stack     at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
    14 verbose cwd C:\ioBroker
    15 verbose Windows_NT 10.0.19045
    16 verbose node v20.15.0
    17 verbose npm  v10.7.0
    18 error code ENOENT
    19 error syscall spawn git
    20 error path git
    21 error errno -4058
    22 error enoent An unknown git error occurred
    23 error enoent This is related to npm not being able to find a file.
    23 error enoent
    24 verbose exit -4058
    25 verbose code -4058
    26 silly unfinished npm timer reify 1719507201733
    27 silly unfinished npm timer reify:loadTrees 1719507201739
    28 silly unfinished npm timer idealTree:userRequests 1719507201999
    29 error A complete log of this run can be found in: C:\WINDOWS\system32\config\systemprofile\AppData\Local\npm-cache\_logs\2024-06-27T16_53_21_153Z-debug-0.log
    @icke2002 sagte in Anfrage zu solax Adapter für Solax X1 Mini 1.5 G4:
    20 error path git
    23 error enoent
    da war doch was mit dem installer für Win.
    Ich glaube der installiert das Paket git nicht standardmäßig
    I 1 Antwort Letzte Antwort
      20 error path git
      23 error enoent
      I Offline
      I Offline
      icke2002
      @homoran ok - danke - wie kann ich das Problem als newbee lösen?
      HomoranH simatecS 2 Antworten Letzte Antwort
      • I icke2002
        Suche benutzen und u.a. dieses finden:
        https://forum.iobroker.net/post/1166454
        • I icke2002
          simatecS Offline
          simatecS Offline
          simatec
          @icke2002 oder du wartest, bis ich die Version auf npm habe und installierst von npm über die Katze
          • Besuche meine Github Seite
          • HowTo Restore ioBroker
          I 2 Antworten Letzte Antwort
            I Offline
            I Offline
            icke2002
            @homoran Ich hatte gesucht - aber nicht gefunden - Danke für den Tip. Nach Neustart lief die Installation!👍 😳
            • simatecS simatec
              I Offline
              I Offline
              icke2002
              @simatec nach der git -Installation konnte ich den Adapter installieren und jetzt läuft es!
              Super - Danke!👍 👍 👍
              • I icke2002
                Super - Danke!👍 👍 👍
                simatecS Offline
                simatecS Offline
                simatec
                @icke2002 Poste mal bitte die Objekte, die nun alle erzeugt wurden. Sind die Daten alle korrekt und plausibel?
                • simatecS simatec
                  I Offline
                  I Offline
                  icke2002
                  @simatec
                  • simatecS simatec
                    I Offline
                    I Offline
                    icke2002
                    schrieb am zuletzt editiert von icke2002
                    @simatec schein erstmal ok zu sein - werde ich morgen nochmal prüfen, wenn mehr Sonne ist.
                    Ich will das Ganze dann sowieso auf einer Raspi4 zum Laufen bringen. Ich habe heute auf jeden Fall viel gelernt - danke nochmal!
                    • I icke2002
                      @simatec
                      @icke2002
                      @homoran sagte in Anfrage zu solax Adapter für Solax X1 Mini 1.5 G4:
                      @icke2002 Bitte keine 4K Briefmarken posten!
                      24% davon sind zu wenig zum erkennen.
                      3.1k ist nicht viel besser lesbar ;-)
                      • I icke2002
                        simatecS Offline
                        simatecS Offline
                        simatec
                        @icke2002 feddInEnergy sieht irgendwie komisch aus vom Wert... Prüfe das mal, ob das passt
                          @icke2002
                          I Offline
                          I Offline
                          icke2002
                          @homoran ich weiss leider nicht, wie es besser geht - es wird noch dem Einfügen immer auf resized gesetzt?
                          • I icke2002
                            Fenster deutlich schmaler ziehen, ohne dass Informationen verloren gehen.
                            siehe auch: https://forum.iobroker.net/topic/51555/hinweise-für-gute-forenbeiträge/1
                            Bin zwar jetzt am "großen" Monitor, aber mit
                            lässt sich kein 4k sinnvoll darstellen
                            • I icke2002
                              simatecS Offline
                              simatecS Offline
                              simatec
                              #66
                              @icke2002 consumeenergy bitte auch mal prüfen
                              • simatecS simatec
                                I Offline
                                I Offline
                                icke2002
                                #67
                                @simatec consumeenergy ist noch um den Faktor 10 zu hoch - sollte ca. 154 kWh sein.
                                • I icke2002
                                  simatecS Offline
                                  simatecS Offline
                                  simatec
                                  #68
                                  @icke2002 wird in v0.9.9 gefixt. Die Version kommt heute Nacht ins latest
                                  • simatecS simatec
                                    I Offline
                                    I Offline
                                    icke2002
                                    #69
                                    @simatec Was mir noch aufgefallen ist:
                                    1. der Wert für Feed-in Energy ist ebenfalls um den Faktor 10 zu hoch und sollte vom Wert her Total Feed-in Energy entsprechen.
                                      2.Total Feed-in Energy ist ebenfalls um den Faktor 10 zu hoch und sollte der tägliche Feed-in Energy sein.
                                    den Rest versuche ich morgen bei Sonnenschein nochmal überprüfen - eventuell gleich mit Version 0.9.9
                                    • I icke2002
                                      simatecS Offline
                                      simatecS Offline
                                      simatec
                                      #70
                                      @icke2002 Ja bitte alle Werte mal checken. Aufgrund fehlender Hardware hab ich den Code blind geschrieben.
                                      • simatecS simatec
                                        I Offline
                                        I Offline
                                        icke2002
                                        #71
                                        @simatec sieht erstmal ganz gut aus. Die Bedeutung von feedinenergy könnte (Gesamteinspeisung sein?) und totalFeed (diesen Wert kann ich im Moment gar nicht zuordnen?) erschließt sich mir noch nicht.
