  4. Anfrage zu solax Adapter für Solax X1 Mini 1.5 G4
71 Beiträge 4 Kommentatoren 3.0k Aufrufe 4 Beobachtet
  • I icke2002
    @homoran verstehe ich nicht - bei mir ist alles zu erkennen???
    simatecS Offline
    simatecS Offline
    simatec
    @icke2002 Also bei mir läuft es sauber durch ...
    $ iobroker url simatec/ioBroker.solax --host iobroker-dev --debug
    install simatec/ioBroker.solax
    NPM version: 10.7.0
    Installing simatec/ioBroker.solax... (System call)
    removed 362 packages, and changed 1 package in 4s157 packages are looking for funding run `npm fund` for details
    upload [16] solax.admin /opt/iobroker/node_modules/iobroker.solax/admin/admin.d.ts admin.d.ts video/mp2t
    upload [14] solax.admin /opt/iobroker/node_modules/iobroker.solax/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [12] solax.admin /opt/iobroker/node_modules/iobroker.solax/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [11] solax.admin /opt/iobroker/node_modules/iobroker.solax/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [9] solax.admin /opt/iobroker/node_modules/iobroker.solax/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [6] solax.admin /opt/iobroker/node_modules/iobroker.solax/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
    upload [5] solax.admin /opt/iobroker/node_modules/iobroker.solax/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [3] solax.admin /opt/iobroker/node_modules/iobroker.solax/admin/jsonConfig.json jsonConfig.json application/json
    upload [2] solax.admin /opt/iobroker/node_modules/iobroker.solax/admin/solax.png solax.png image/png
    upload [0] solax.admin /opt/iobroker/node_modules/iobroker.solax/admin/words.js words.js application/javascript
    Update "system.adapter.solax.0"
    Process exited with code 0
    • Besuche meine Github Seite
    • HowTo Restore ioBroker
    • simatecS simatec
      NPM version: 10.7.0
      simatecS Offline
      simatecS Offline
      simatec
      @simatec Starte mal dein System komplett neu und versuche es erneut
      I 2 Antworten Letzte Antwort
      • simatecS simatec
        I Offline
        I Offline
        icke2002
        @simatec ok mach ich!
        • I icke2002
          @icke2002 sagte in Anfrage zu solax Adapter für Solax X1 Mini 1.5 G4:
          ich denke mal dein Bildschirm ist breiter als 7cm.
          I 1 Antwort Letzte Antwort
            I Offline
            I Offline
            icke2002
            @homoran richtig?
            • simatecS simatec
              I Offline
              I Offline
              icke2002
              @simatec hat nichts genützt - bricht mit Fehler ab!?
              0 verbose cli C:\Program Files\nodejs\node.exe C:\Program Files\nodejs\node_modules\npm\bin\npm-cli.js
              1 info using npm@10.7.0
              2 info using node@v20.15.0
              3 silly config:load:file:C:\Program Files\nodejs\node_modules\npm\npmrc
              4 silly config:load:file:C:\ioBroker\.npmrc
              5 silly config:load:file:C:\WINDOWS\system32\config\systemprofile\.npmrc
              6 silly config:load:file:C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm\etc\npmrc
              7 verbose title npm install simatec/ioBroker.solax
              8 verbose argv "install" "simatec/ioBroker.solax"
              9 verbose logfile logs-max:10 dir:C:\WINDOWS\system32\config\systemprofile\AppData\Local\npm-cache\_logs\2024-06-23T17_34_25_905Z-
              10 verbose logfile C:\WINDOWS\system32\config\systemprofile\AppData\Local\npm-cache\_logs\2024-06-23T17_34_25_905Z-debug-0.log
              11 silly logfile done cleaning log files
              12 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules/iobroker.solax
              13 verbose stack Error: An unknown git error occurred
              13 verbose stack     at makeError (C:\Program Files\nodejs\node_modules\npm\node_modules\@npmcli\git\lib\make-error.js:28:13)
              13 verbose stack     at C:\Program Files\nodejs\node_modules\npm\node_modules\@npmcli\git\lib\spawn.js:37:26
              13 verbose stack     at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
              14 verbose cwd C:\ioBroker
              15 verbose Windows_NT 10.0.19045
              16 verbose node v20.15.0
              17 verbose npm  v10.7.0
              18 error code ENOENT
              19 error syscall spawn git
              20 error path git
              21 error errno -4058
              22 error enoent An unknown git error occurred
              23 error enoent This is related to npm not being able to find a file.
              23 error enoent
              24 verbose exit -4058
              25 verbose code -4058
              26 silly unfinished npm timer reify 1719164066510
              27 silly unfinished npm timer reify:loadTrees 1719164066570
              28 silly unfinished npm timer idealTree:userRequests 1719164066788
              29 error A complete log of this run can be found in: C:\WINDOWS\system32\config\systemprofile\AppData\Local\npm-cache\_logs\2024-06-23T17_34_25_905Z-debug-0.log
              • I icke2002
                @icke2002
                9 verbose logfile logs-max:10 dir:C:\WINDOWS\system32\config\systemprofile\AppData\Local\npm-cache\_logs\2024-06-27T14_25_10_988Z-
                10 verbose logfile C:\WINDOWS\system32\config\systemprofile\AppData\Local\npm-cache\_logs\2024-06-27T14_25_10_988Z-debug-0.log
                20 error path git
                23 error enoent
                26 silly unfinished npm timer reify 1719498311579
                27 silly unfinished npm timer reify:loadTrees 1719498311583
                28 silly unfinished npm timer idealTree:userRequests 1719498311824
                29 error A complete log of this run can be found in: C:\WINDOWS\system32\config\systemprofile\AppData\Local\npm-cache\_logs\2024-06-27T14_25_10_988Z-debug-0.log
                simatecS Offline
                simatecS Offline
                simatec
                @icke2002 Dann lösche den Adapter vorher komplett. Also auch im Tab Adapter. Sprich Instanzen und Adapter löschen.
                Im Anschluss dann nochmals die Installation via Github siehe Screenshot
                • simatecS simatec
                  I Offline
                  I Offline
                  icke2002
                  @simatec Wird leider immer schlimmer!?
                  Die Version 0.9.7 von npm lässt sich installieren - fehlt bei mir irgendetwas?
                  Punkt 13 und 18 - 23 - ich verstehe es nicht!
                  9 verbose logfile logs-max:10 dir:C:\WINDOWS\system32\config\systemprofile\AppData\Local\npm-cache\_logs\2024-06-27T16_53_21_153Z-
                  10 verbose logfile C:\WINDOWS\system32\config\systemprofile\AppData\Local\npm-cache\_logs\2024-06-27T16_53_21_153Z-debug-0.log
                  11 silly logfile start cleaning logs, removing 1 files
                  12 silly logfile done cleaning log files
                  20 error path git
                  23 error enoent
                  26 silly unfinished npm timer reify 1719507201733
                  27 silly unfinished npm timer reify:loadTrees 1719507201739
                  28 silly unfinished npm timer idealTree:userRequests 1719507201999
                  29 error A complete log of this run can be found in: C:\WINDOWS\system32\config\systemprofile\AppData\Local\npm-cache\_logs\2024-06-27T16_53_21_153Z-debug-0.log
                  • I icke2002
                    20 error path git
                    23 error enoent
                    20 error path git
                    23 error enoent
                    da war doch was mit dem installer für Win.
                    Ich glaube der installiert das Paket git nicht standardmäßig
                      20 error path git
                      23 error enoent
                      I Offline
                      I Offline
                      icke2002
                      @homoran ok - danke - wie kann ich das Problem als newbee lösen?
                      HomoranH simatecS 2 Antworten Letzte Antwort
                      • I icke2002
                        Suche benutzen und u.a. dieses finden:
                        https://forum.iobroker.net/post/1166454
                        • I icke2002
                          simatecS Offline
                          simatecS Offline
                          simatec
                          @icke2002 oder du wartest, bis ich die Version auf npm habe und installierst von npm über die Katze
                            I Offline
                            I Offline
                            icke2002
                            @homoran Ich hatte gesucht - aber nicht gefunden - Danke für den Tip. Nach Neustart lief die Installation!👍 😳
                            • simatecS simatec
                              I Offline
                              I Offline
                              icke2002
                              @simatec nach der git -Installation konnte ich den Adapter installieren und jetzt läuft es!
                              Super - Danke!👍 👍 👍
                              • I icke2002
                                Super - Danke!👍 👍 👍
                                simatecS Offline
                                simatecS Offline
                                simatec
                                @icke2002 Poste mal bitte die Objekte, die nun alle erzeugt wurden. Sind die Daten alle korrekt und plausibel?
                                • simatecS simatec
                                  I Offline
                                  I Offline
                                  icke2002
                                  @simatec
                                  • simatecS simatec
                                    I Offline
                                    I Offline
                                    icke2002
                                    schrieb am zuletzt editiert von icke2002
                                    @simatec schein erstmal ok zu sein - werde ich morgen nochmal prüfen, wenn mehr Sonne ist.
                                    Ich will das Ganze dann sowieso auf einer Raspi4 zum Laufen bringen. Ich habe heute auf jeden Fall viel gelernt - danke nochmal!
                                    • I icke2002
                                      @simatec
                                      @icke2002
                                      @homoran sagte in Anfrage zu solax Adapter für Solax X1 Mini 1.5 G4:
                                      @icke2002 Bitte keine 4K Briefmarken posten!
                                      24% davon sind zu wenig zum erkennen.
                                      3.1k ist nicht viel besser lesbar ;-)
                                      • I icke2002
                                        simatecS Offline
                                        simatecS Offline
                                        simatec
                                        @icke2002 feddInEnergy sieht irgendwie komisch aus vom Wert... Prüfe das mal, ob das passt
                                          @icke2002
                                          I Offline
                                          I Offline
                                          icke2002
                                          @homoran ich weiss leider nicht, wie es besser geht - es wird noch dem Einfügen immer auf resized gesetzt?
