  4. Anfrage zu solax Adapter für Solax X1 Mini 1.5 G4
71 Beiträge 4 Kommentatoren 3.0k Aufrufe 4 Beobachtet
  • I icke2002
    @icke2002
    0 verbose cli C:\Program Files\nodejs\node.exe C:\Program Files\nodejs\node_modules\npm\bin\npm-cli.js
    1 info using npm@10.7.0
    2 info using node@v20.15.0
    3 silly config:load:file:C:\Program Files\nodejs\node_modules\npm\npmrc
    4 silly config:load:file:C:\ioBroker\.npmrc
    5 silly config:load:file:C:\WINDOWS\system32\config\systemprofile\.npmrc
    6 silly config:load:file:C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm\etc\npmrc
    7 verbose title npm install simatec/ioBroker.solax
    8 verbose argv "install" "simatec/ioBroker.solax"
    9 verbose logfile logs-max:10 dir:C:\WINDOWS\system32\config\systemprofile\AppData\Local\npm-cache\_logs\2024-06-27T14_25_10_988Z-
    10 verbose logfile C:\WINDOWS\system32\config\systemprofile\AppData\Local\npm-cache\_logs\2024-06-27T14_25_10_988Z-debug-0.log
    11 silly logfile done cleaning log files
    12 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules/iobroker.solax
    13 verbose stack Error: An unknown git error occurred
    13 verbose stack     at makeError (C:\Program Files\nodejs\node_modules\npm\node_modules\@npmcli\git\lib\make-error.js:28:13)
    13 verbose stack     at C:\Program Files\nodejs\node_modules\npm\node_modules\@npmcli\git\lib\spawn.js:37:26
    13 verbose stack     at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
    14 verbose cwd C:\ioBroker
    15 verbose Windows_NT 10.0.19045
    16 verbose node v20.15.0
    17 verbose npm  v10.7.0
    18 error code ENOENT
    19 error syscall spawn git
    20 error path git
    21 error errno -4058
    22 error enoent An unknown git error occurred
    23 error enoent This is related to npm not being able to find a file.
    23 error enoent
    24 verbose exit -4058
    25 verbose code -4058
    26 silly unfinished npm timer reify 1719498311579
    27 silly unfinished npm timer reify:loadTrees 1719498311583
    28 silly unfinished npm timer idealTree:userRequests 1719498311824
    29 error A complete log of this run can be found in: C:\WINDOWS\system32\config\systemprofile\AppData\Local\npm-cache\_logs\2024-06-27T14_25_10_988Z-debug-0.log
    simatecS Offline
    simatecS Offline
    simatec
    @icke2002 Dann lösche den Adapter vorher komplett. Also auch im Tab Adapter. Sprich Instanzen und Adapter löschen.
    Im Anschluss dann nochmals die Installation via Github siehe Screenshot
    • Besuche meine Github Seite
    • HowTo Restore ioBroker
    I 1 Antwort Letzte Antwort
    • simatecS simatec
      I Offline
      I Offline
      icke2002
      @simatec Wird leider immer schlimmer!?
      Die Version 0.9.7 von npm lässt sich installieren - fehlt bei mir irgendetwas?
      Punkt 13 und 18 - 23 - ich verstehe es nicht!
      9 verbose logfile logs-max:10 dir:C:\WINDOWS\system32\config\systemprofile\AppData\Local\npm-cache\_logs\2024-06-27T16_53_21_153Z-
      10 verbose logfile C:\WINDOWS\system32\config\systemprofile\AppData\Local\npm-cache\_logs\2024-06-27T16_53_21_153Z-debug-0.log
      11 silly logfile start cleaning logs, removing 1 files
      12 silly logfile done cleaning log files
      20 error path git
      23 error enoent
      26 silly unfinished npm timer reify 1719507201733
      27 silly unfinished npm timer reify:loadTrees 1719507201739
      28 silly unfinished npm timer idealTree:userRequests 1719507201999
      29 error A complete log of this run can be found in: C:\WINDOWS\system32\config\systemprofile\AppData\Local\npm-cache\_logs\2024-06-27T16_53_21_153Z-debug-0.log
      • I icke2002
        20 error path git
        23 error enoent
        @icke2002 sagte in Anfrage zu solax Adapter für Solax X1 Mini 1.5 G4:
        20 error path git
        23 error enoent
        da war doch was mit dem installer für Win.
        Ich glaube der installiert das Paket git nicht standardmäßig
          20 error path git
          23 error enoent
          I Offline
          I Offline
          icke2002
          @homoran ok - danke - wie kann ich das Problem als newbee lösen?
          HomoranH simatecS 2 Antworten Letzte Antwort
          • I icke2002
            Suche benutzen und u.a. dieses finden:
            https://forum.iobroker.net/post/1166454
            • I icke2002
              simatecS Offline
              simatecS Offline
              simatec
              @icke2002 oder du wartest, bis ich die Version auf npm habe und installierst von npm über die Katze
              I 2 Antworten Letzte Antwort
                I Offline
                I Offline
                icke2002
                @homoran Ich hatte gesucht - aber nicht gefunden - Danke für den Tip. Nach Neustart lief die Installation!👍 😳
                • simatecS simatec
                  I Offline
                  I Offline
                  icke2002
                  @simatec nach der git -Installation konnte ich den Adapter installieren und jetzt läuft es!
                  Super - Danke!👍 👍 👍
                  • I icke2002
                    Super - Danke!👍 👍 👍
                    simatecS Offline
                    simatecS Offline
                    simatec
                    @icke2002 Poste mal bitte die Objekte, die nun alle erzeugt wurden. Sind die Daten alle korrekt und plausibel?
                    • simatecS simatec
                      I Offline
                      I Offline
                      icke2002
                      @simatec
                      • simatecS simatec
                        I Offline
                        I Offline
                        icke2002
                        schrieb am zuletzt editiert von icke2002
                        @simatec schein erstmal ok zu sein - werde ich morgen nochmal prüfen, wenn mehr Sonne ist.
                        Ich will das Ganze dann sowieso auf einer Raspi4 zum Laufen bringen. Ich habe heute auf jeden Fall viel gelernt - danke nochmal!
                        • I icke2002
                          @simatec
                          @icke2002
                          @homoran sagte in Anfrage zu solax Adapter für Solax X1 Mini 1.5 G4:
                          @icke2002 Bitte keine 4K Briefmarken posten!
                          24% davon sind zu wenig zum erkennen.
                          3.1k ist nicht viel besser lesbar ;-)
                          • I icke2002
                            simatecS Offline
                            simatecS Offline
                            simatec
                            @icke2002 feddInEnergy sieht irgendwie komisch aus vom Wert... Prüfe das mal, ob das passt
                              @icke2002
                              I Offline
                              I Offline
                              icke2002
                              @homoran ich weiss leider nicht, wie es besser geht - es wird noch dem Einfügen immer auf resized gesetzt?
                              • I icke2002
                                Fenster deutlich schmaler ziehen, ohne dass Informationen verloren gehen.
                                siehe auch: https://forum.iobroker.net/topic/51555/hinweise-für-gute-forenbeiträge/1
                                Bin zwar jetzt am "großen" Monitor, aber mit
                                lässt sich kein 4k sinnvoll darstellen
                                • I icke2002
                                  simatecS Offline
                                  simatecS Offline
                                  simatec
                                  #66
                                  @icke2002 consumeenergy bitte auch mal prüfen
                                  • simatecS simatec
                                    I Offline
                                    I Offline
                                    icke2002
                                    #67
                                    @simatec consumeenergy ist noch um den Faktor 10 zu hoch - sollte ca. 154 kWh sein.
                                    • I icke2002
                                      simatecS Offline
                                      simatecS Offline
                                      simatec
                                      #68
                                      @icke2002 wird in v0.9.9 gefixt. Die Version kommt heute Nacht ins latest
                                      • simatecS simatec
                                        I Offline
                                        I Offline
                                        icke2002
                                        #69
                                        @simatec Was mir noch aufgefallen ist:
                                        1. der Wert für Feed-in Energy ist ebenfalls um den Faktor 10 zu hoch und sollte vom Wert her Total Feed-in Energy entsprechen.
                                          2.Total Feed-in Energy ist ebenfalls um den Faktor 10 zu hoch und sollte der tägliche Feed-in Energy sein.
                                        den Rest versuche ich morgen bei Sonnenschein nochmal überprüfen - eventuell gleich mit Version 0.9.9
                                        • I icke2002
                                          simatecS Offline
                                          simatecS Offline
                                          simatec
                                          #70
                                          @icke2002 Ja bitte alle Werte mal checken. Aufgrund fehlender Hardware hab ich den Code blind geschrieben.
