  4. Test eCharts Adapter
echarts
666 Beiträge 109 Kommentatoren 263.6k Aufrufe 84 Beobachtet
  • M Maas-Meister
    Brauche dringend Hilfe: (schon super viel Zeit verbrannt)
    Ich möchte meinen Stromverbrauch + Stromkosten nebeneinander in ein Balken-Diagramm anzeigen lassen.
    Als Quelle habe ich ein json-string
    [{"from":"2023-03-01T00:00:00.000+01:00","to":"2023-04-01T00:00:00.000+02:00","cost":137.372376561,"unitPrice":0.25357,"unitPriceVAT":0.040486,"consumption":541.754,"consumptionUnit":"kWh","currency":"EUR"},{"from":"2023-04-01T00:00:00.000+02:00","to":"2023-05-01T00:00:00.000+02:00","cost":90.7700860794,"unitPrice":0.243949,"unitPriceVAT":0.03895,"consumption":372.087,"consumptionUnit":"kWh","currency":"EUR"},{"from":"2023-05-01T00:00:00.000+02:00","to":"2023-06-01T00:00:00.000+02:00","cost":45.3044254425,"unitPrice":0.219539,"unitPriceVAT":0.035052,"consumption":206.362,"consumptionUnit":"kWh","currency":"EUR"},{"from":"2023-06-01T00:00:00.000+02:00","to":"2023-07-01T00:00:00.000+02:00","cost":41.3673965509,"unitPrice":0.234526,"unitPriceVAT":0.037445,"consumption":176.387,"consumptionUnit":"kWh","currency":"EUR"},{"from":"2023-07-01T00:00:00.000+02:00","to":"2023-08-01T00:00:00.000+02:00","cost":44.7069721861,"unitPrice":0.225864,"unitPriceVAT":0.036062,"consumption":197.938,"consumptionUnit":"kWh","currency":"EUR"},{"from":"2023-08-01T00:00:00.000+02:00","to":"2023-09-01T00:00:00.000+02:00","cost":58.4057955355,"unitPrice":0.247937,"unitPriceVAT":0.039587,"consumption":235.567,"consumptionUnit":"kWh","currency":"EUR"},{"from":"2023-09-01T00:00:00.000+02:00","to":"2023-10-01T00:00:00.000+02:00","cost":62.7189878063,"unitPrice":0.257247,"unitPriceVAT":0.041073,"consumption":243.808,"consumptionUnit":"kWh","currency":"EUR"},{"from":"2023-10-01T00:00:00.000+02:00","to":"2023-11-01T00:00:00.000+01:00","cost":113.0440595319,"unitPrice":0.243011,"unitPriceVAT":0.0388,"consumption":465.18,"consumptionUnit":"kWh","currency":"EUR"},{"from":"2023-11-01T00:00:00.000+01:00","to":"2023-12-01T00:00:00.000+01:00","cost":165.1500357416,"unitPrice":0.24995,"unitPriceVAT":0.039908,"consumption":660.731,"consumptionUnit":"kWh","currency":"EUR"},{"from":"2023-12-01T00:00:00.000+01:00","to":"2024-01-01T00:00:00.000+01:00","cost":218.4211066317,"unitPrice":0.21144,"unitPriceVAT":0.033759,"consumption":1033.019,"consumptionUnit":"kWh","currency":"EUR"}]
    Dieses formatiere ich in ein E-Charts taugliches JSON um und logge dies mit History:
        "ts": 1677625200000,
        "val": 541.754
        "ts": 1680300000000,
        "val": 372.087
        "ts": 1682892000000,
        "val": 206.362
        "ts": 1685570400000,
        "val": 176.387
        "ts": 1688162400000,
        "val": 197.938
        "ts": 1690840800000,
        "val": 235.567
        "ts": 1693519200000,
        "val": 243.808
        "ts": 1696111200000,
        "val": 465.18
        "ts": 1698793200000,
        "val": 660.731
        "ts": 1701385200000,
        "val": 1033.019
    Wenn ich dieses in E-Charts bringen will, werden mir die Monate angezeigt, aber keine Werte.
    Hab es schon aus der History Datenbank + direkt als json - beides ohne Erfolg.
    Wie muss das json aussehen damit ich Balken sehen kann?
    Sombornus
    #591
    Servus @maas-meister,
    ich habe folgendes festgestellt: Wieso auch immer funktioniert die Darstellung von Bar-Charts auf Basis von JSON Daten nur mit dem Firefox Browser!
    Aus meiner Sicht sieht das JSON Beispiel von Dir gut aus. Probiere einfach mal den Firefox aus.
    So sieht jedenfalls Dein Beispiel bei mir aus:
    • S Sombornus
      Maas-Meister
      #592
      @sombornus sagte in Test eCharts Adapter:
      MEGA, danke für den Tipp!
      Werde ich später testen - auch ob der Fully Browser dies richtig wieder gibt.
      Wenn ich "Line" einstellen, wird mir was angezeigt. Sobald ich auf "Bar" stelle sehe ich gar nichts mehr.
      Was hast du unten noch eingestellt?
      • U Offline
        U Offline
        user12
        schrieb am zuletzt editiert von user12
        #593
        Guten Tag, hat jemand zufällig eine Idee.
        Ich habe mit einigen Videoanleitungen mein ersten Versuche geschafft und habe einen Sensor in IOBroker integriert und möchte diese Daten per Telegram an mich senden.
        Der Export und und das dazugehörige Kommando klappt gut.
        Ich möchte gerne die Bildgröße, die mir mein Telegrambot anzeigt ändern. Im Moment hat es folgende Auflösungen: 1024x300.
        Kann man das irgendwie ändern?
        Danke für die Tipps
        Hier das zugehörige Blockly
        • U user12
          Danke für die Tipps
          David G.D Online
          David G.D Online
          David G.
          #594
          @user12
          Ich mache es so
          U 1 Antwort Letzte Antwort
          • David G.D David G.
            @user12
            Ich mache es so
            U Offline
            U Offline
            user12
            #595
            @david-g
            Danke, hat super geklappt)
            • LatziL Offline
              LatziL Offline
              Latzi
              #596
              Gibt es eine Möglichkeit, bei mehrfachen y-Achsenskalen die Werte zu versetzen, damit sie nicht übereinander erscheinen?
              • Steffe.S.S Offline
                Steffe.S.S Offline
                Steffe.S.
                #597
                Hallo, gibt es eine Möglichkeit, die Schrift oben links etwas weiter nach rechts zu rücken? Irgendwie hängt die Schrift immer über der Bezeichnung der Y Achse linksbündig (egal was ich im Adapter einstelle die Schrift ist immer oben links. Oben recht, unten recht / links wird nicht berücksichtigt)
                BananaJoeB Steffe.S.S 2 Antworten Letzte Antwort
                • Steffe.S.S Steffe.S.
                  BananaJoeB Offline
                  BananaJoeB Offline
                  BananaJoe
                  #598
                  @steffe-s also bei mir ist diese zwar unten, wird aber immer innerhalb der Grafik angezeigt:
                  Oben auch:
                  Spiel mal weiter mit den Einstellungen
                    Steffe.S.S Offline
                    Steffe.S.S Offline
                    Steffe.S.
                    schrieb am zuletzt editiert von Steffe.S.
                    #599
                    @steffe-s sagte in Test eCharts Adapter:
                    ... unter Optionen habe ich Auto-Abstand ausgeschaltet, dann passt es mit der Schrift. Wenn ich Auto-Abstand wieder einschalte ist der beschriebene Fehler wieder da, es liegt also definitiv an der Einstellung. Kann das Problem / die Lösung vielleicht jemand destätigen bzw. testen?
                      BananaJoeB Offline
                      BananaJoeB Offline
                      BananaJoe
                      #600
                      @steffe-s Auto-Abstand kann in der Tat komische Effekte hervorrufen. Bei manchen meiner eCharts ist keine Änderungen zu erkennen, bei anderen verschiebt es sich dann wie bei dir ungünstig.
                      Kommt wohl auf die Kombination der Parameter an.
                      • spicerS Offline
                        spicerS Offline
                        spicer
                        #601
                        Ist etwa auch das schuld, dass der negative X-Offset immer noch nicht funzt, obschon der Dev das eingebunden hat?
                        Wenn es mehrere Möglichkeiten gibt, eine Aufgabe zu erledigen, und eine davon in einer Katastrophe endet oder sonstwie unerwünschte Konsequenzen nach sich zieht, dann wird es jemand genau so machen. Alles, was schiefgehen kann, wird auch schiefgehen.
                        (Murphys Gesetz)
                        • BluefoxB Bluefox
                          Aktuelle Test Version 0.4.2
                          Veröffentlichungsdatum 01.11.2020
                          Github Link https://github.com/ioBroker/ioBroker.echarts
                          Hallo Community,
                          ich möchte für den Test mein neuen Adapter abgeben: echarts.
                          Die Entwicklung hat mehr als ein Jahr gedauert (seit 21 Okt 2019) und ich habe sehr viel Zeit in diesen Adapter inverstiert.
                          Der Adapter ist als Ersatz für flot gedacht und alle Presets aus flot werden beim Start automatisch einmalig übernommen.
                          Ich denke, dass Adapter selbst erklärend ist. Man kann im Vis die Charts benutzen oder auch irgendwo als iframe: http://IP:8082/echarts/index.html?preset=echarts.0.PRESETID.
                          Die Issues, wie immer, bitte ich auf github erstellen: https://github.com/ioBroker/ioBroker.echarts/issues
                          stenmic
                          schrieb am zuletzt editiert von stenmic
                          #602
                          @bluefox
                          Hi, zwei Fragen.
                          Sobald ich bei echart das Grid einfärbe wird es gestrichelt dargestellt. Ist das normal?
                          Schön wäre auch wenn man mehr Optionen aus Datenpunkten übernehmen könnte.
                          z.B. Farben und Zeitbereiche. Dann könnte man mehr über die VIS steuern.
                          Bei Farben meine ich, wenn der Wert für mich positiv ist möchte ich ne grüne Line, bei schlechten Werten eine Rote. Die Farbe steht in einem Datenpunkt, den ich je nach Situation flexibel anpasse.
                          Oder vielleicht könnte man Bindings analog vis nutzen. Dann wäre der Adapterfür mich der Killer für Grafana.
                          • M Online
                            M Online
                            micklafisch
                            #603
                            Der eChart Adapter flackert alle 10 Sekunden kurz auf und scheint sich zu aktualisieren (per HTML Widget mittels Binding als auch mit dem eChart Widget). Kann dies auch manuell angestoßen werden?
                            Grund ist, ich manipuliere mit JSON in einem Chart eine zweite Linie welchen einen Bereich im Chart markiert. Wenn ich jetzt das JSON ändere, wird erst mit der nächsten Aktualisierung dieses JSON verarbeitet und angezeigt-> im schlimmsten Fall 9,9 Sekunden. Hört sich trivial an, aber wenn nach dem auslösen nichts passiert, sind fast 10 Sekunden lange bis optisch sich was ändert.
                            Leider funktioniert das laut Github zum JSON erwähnte
                             The chart will be automatically updated every time the value changes.
                            nicht, sondern lediglich nur alle 10 Sekunden.
                            • M Online
                              M Online
                              micklafisch
                              #604
                              ergänzend kann ich berichten, dass bei einer Änderung der Daten im Datenpunkt die JSON Linie sofort ausgeblendet wird, aber die Anzeige der geänderten Daten erst nach der oben genannten Aktualisierung erfolgt. Dabei ist es auch egal ob die JSON Linie an erster Stelle oder an zweiter Stelle im Chart ist.
                              • GarganoG Offline
                                GarganoG Offline
                                Gargano
                                #605
                                Wenn sich das Chart aktualisiert, wird oben ein laufender Balken eingeblendet. Dadurch verschiebt sich das Chart kurz ein Stück nach unten. Also ein Zucken nach unten.
                                Kann ich diese Zucken unterbinden ?
                                • D3ltoroxpD Offline
                                  D3ltoroxpD Offline
                                  D3ltoroxp
                                  #606
                                  Ich hänge mich hier mal mit an. Ich versuche mich gerade mit dem eChart Adapter. Nun würde ich gerne das Widget in der VIS nutzen, leider taucht es bei mir nicht auf. Habe schon upload vis und Strg+F5 probiert. Bekomme das Widget leider nicht angezeigt.
                                  -cs-- sigi234S Bernd1967B 3 Antworten Letzte Antwort
                                  • D3ltoroxpD D3ltoroxp
                                    -cs-- Offline
                                    -cs-- Offline
                                    -cs-
                                    #607
                                    Hi, entweder hab ich was übersehen, auf alle fälle finde es nicht.
                                    Wenn ich in einem EChart, dargestellt in auf einem Mobilen Gerät, egal ob Fully Browser oder ioBroker- App, einzelne Charte ausblenden möchte funktioniert das nicht.
                                    Am PC kann man ja einzelne Charts aus und einblenden, aber auf mobilen Geräten scheint es mir so, als wie wenn es immer einen Doppelcklick ausführt. Sprich man kann keine einzelnen Charts ein-/ausblenden.
                                    Wie bringe ich es fertig an mobilen Geräten einzelne Charts aus- oder einzublenden?
                                    Schöne Grüße
                                    Christian
                                      sigi234S Online
                                      sigi234S Online
                                      #608
                                      @d3ltoroxp
                                      Lösche den Filter mal
                                      D3ltoroxpD 1 Antwort Letzte Antwort
                                      • sigi234S sigi234
                                        @d3ltoroxp
                                        D3ltoroxpD Offline
                                        D3ltoroxpD Offline
                                        D3ltoroxp
                                        #609
                                        @sigi234 Du meinst hier ?
                                        Hab ich raus und mal komplett durchgescrollt, aber ich sehe kein eCharts.
                                          sigi234S Online
                                          sigi234S Online
                                          #610
                                          @d3ltoroxp sagte in Test eCharts Adapter:
                                          Welche Version vom Adaper ?
