  3. Einsteigerfragen
  4. Installation
  5. vermurkste Installation
120 Beiträge 4 Kommentatoren 17.0k Aufrufe 2 Beobachtet
    @radix75
    Das war nur der Output aus meinem System, das solltest du nicht in dein Terminal klatschen...
    iob repo list
    aber schon
    Radix75
    #99
    @thomas-braun said in Daikin Adapter:
    @radix75
    iob repo list
    aber schon
    Radix1975@raspberrypi5:~ $ iob repo list
    Active repo(s): live-stable , live-beta, live-stable, stable
    • R Radix75
      Hab mal die Admin Seite in anderen browser geöffnet
      login as: Radix1975
      Radix1975@192.168.1.225's password:
      Linux raspberrypi5 6.1.0-rpi7-rpi-2712 #1 SMP PREEMPT Debian 1:6.1.63-1+rpt1 (20                                   23-11-24) aarch64
      permitted by applicable law.
      Last login: Thu Dec 28 13:31:01 2023 from 192.168.1.10
      Radix1975@raspberrypi5:~ $ echad@chet:~ $ iob repo list
      -bash: echad@chet:~: command not found
      Radix1975@raspberrypi5:~ $ Radix1975@raspberrypi5:~ $ echad@chet:~ $ iob repo li                                   st
      -bash: Radix1975@raspberrypi5:~: command not found
      -bash: -bash:: command not found
      live-stable   : http://iobroker.live/repo/sources-dist.json
      live-beta     : http://iobroker.live/repo/sources-dist-latest.json
      -bash: beta: command not found
      -bash: live-stable: command not found
      -bash: live-beta: command not found
      -bash: stable: command not found
      Radix1975@raspberrypi5:~ $ ^C
      Radix1975@raspberrypi5:~ $ --- **download.iobroker.net** ping statistics ---
      -bash: ---: command not found
      Radix1975@raspberrypi5:~ $ download.iobroker.net** ping statistics
      -bash: download.iobroker.net**: command not found
      Thomas BraunT Offline
      #100
      @radix75 sagte in Daikin Adapter:
      live-stable
      iob repo unset 'live-stable '
      iob repo unset 'live-stable'
      iob repo unset 'live-beta'
      iob repo del 'live-stable '
      iob repo del 'live-stable'
      iob repo del 'live-beta'
      dann
      iob repo list
      R 1 Antwort Letzte Antwort
        live-stable
        dann
        iob repo list
        Radix75
        #101
        live-stable
        dann
        iob repo list
        Radix1975@raspberrypi5:~ $ iob repo unset 'live-stable'
        Repository "live-stable" deactivated.
        Active repo(s): live-beta, stable
        Radix1975@raspberrypi5:~ $ iob repo unset 'live-beta'
        Repository "live-beta" deactivated.
        Active repo(s): stable
        Radix1975@raspberrypi5:~ $ iob repo del 'live-stable '
        Cannot remove repository: Repository "live-stable " not found.
        Radix1975@raspberrypi5:~ $ iob repo del 'live-stable'
        Cannot remove repository: Repository "live-stable" not found.
        Radix1975@raspberrypi5:~ $ iob repo del 'live-beta'
        Cannot remove repository: Repository "live-beta" not found.
        • HomoranH Offline
          HomoranH Offline
          #102
          Ich hab das ganze mal abgetrennt!
          hat ja nix mehr mit Daikin zu tun
          @Radix75 bitte den provisorischen Threadtitel anpassen
            Radix75
            #103
            @homoran said in vermurkste Installation:
            Daikin muss ich später noch auf den IOBroker machen wenn der endlich Adapter suchen kann
            • R Radix75
              #104
              @radix75
              iob update
                @radix75
                iob update
                Radix75
                #105
                @thomas-braun said in vermurkste Installation:
                @radix75
                iob update
                Radix1975@raspberrypi5:~ $ iob update
                Used repository: stable
                Cannot download repository hash file from "http://download.iobroker.net/sources-dist-hash.json": timeout of 10000ms exceeded
                Cannot download repository file from "http://download.iobroker.net/sources-dist.json": timeout of 10000ms exceeded
                Thomas BraunT R 2 Antworten Letzte Antwort
                • R Radix75
                  @radix75
                  iob update
                  #106
                  @radix75
                  iob repo add live-stable http://iobroker.live/repo/sources-dist.json
                  iob repo unset stable
                  iob repo set live-stable
                  iob update
                  • R Radix75
                    @radix75
                    iob update
                    Radix75
                    #107
                    @radix75 said in vermurkste Installation:
                    @radix75
                    iob update
                    Ist das Netzwerk so richtig???2e63ea19-d5f9-4686-abda-c92ce7ea0d2a-image.png
                    R HomoranH 2 Antworten Letzte Antwort
                    • R Radix75
                      @radix75
                      iob update
                      Radix75
                      #108
                      Radix1975@raspberrypi5:~ $ iob repo add live-stable http://iobroker.live/repo/sources-dist.json
                      Repository "live-stable" added as "http://iobroker.live/repo/sources-dist.json"
                      Radix1975@raspberrypi5:~ $ iob repo unset stable
                      Repository "stable" deactivated.
                      Active repo(s):
                      Radix1975@raspberrypi5:~ $ iob repo set live-stable
                      Repository "live-stable" set as active.
                      Used repository: live-stable
                      Adapter    "admin"        : 6.12.0   , installed 6.12.0
                      Adapter    "backitup"     : 2.9.8    , installed 2.9.8
                      Adapter    "discovery"    : 4.2.0    , installed 4.2.0
                      Controller "js-controller": 5.0.17   , installed 5.0.17
                      • R Radix75
                        Active repo(s):
                        #109
                        @radix75
                        Dann sollte es wieder funktionieren.
                        • R Radix75
                          @radix75
                          iob update
                          HomoranH Offline
                          HomoranH Offline
                          #110
                          @radix75 sagte in vermurkste Installation:
                          äääähm?
                          Das ist die Konfiguration des admins, die passt.
                          Um dein Netzwerk musst du dich kümmern
                            @radix75
                            Radix75
                            #111
                            @radix75
                            Funktioniert !
                            Ein großes Dankeschön dafür.
                            Als nächstes würde ich erstmal ein Beckup der Karte machen wollen.
                            Danach müße ich dann nach https://github.com/alexreinert/piVCCU/blob/master/docs/setup/raspberrypi.md
                            piVCCU installieren auch hier hatte ich in der Vergangenheit schon oft das Problem das das Netzwerk nach dem Schritt 6-9 nicht mehr geht.
                            Ich habe auch heute das neue CCU RPI-RF-Modul bekommen hier wahren ja noch Probleme mit dem GPIO aufstecken und die Tatsache das ich nur das Original Netzteil mit UCB C habe zu lösen
                            • R Radix75
                              @radix75
                              Funktioniert !
                              #112
                              @radix75
                              Zu pivCCU kann ich nicht viel sagen.
                              • R Radix75
                                @radix75
                                Funktioniert !
                                HomoranH Offline
                                HomoranH Offline
                                #113
                                wie bereits gesagt bist du da falsch abgebogen.
                                  Radix75
                                  #114
                                  mit welchen Kommando kann ich ein Image der SD karte auf einem externen USB Stick schreiben?
                                  • R Radix75
                                    HomoranH Offline
                                    HomoranH Offline
                                    #115
                                    @radix75 wenn du die Frage stellst, bin ich mir nicht sicher ob das das richtige Vorgehen für dich sein wird
                                      Radix75
                                      #116
                                      Warum nicht? Wir haben Stunden geraucht um alles einzurichten wenn jetzt was bei der Installation von pivCCU
                                      was schief geht habe ich eine zweite SD Karte. Ich habe ja so ein SD Kartenleser für USB
                                      • R Radix75
                                        HomoranH Offline
                                        HomoranH Offline
                                        #117
                                        @radix75 dann nimm die 2te Karte und fang mit OS und piVCCU an.
                                        ich bin mir immer noch nicht sicher ob dein Netzwerk sauber tickt.
                                        So lange hat es nur deswegen gedauert
                                          Radix75
                                          #118
                                          Können wir das noch irgendwie Herausfinden?
