  3. Einsteigerfragen
  4. Installation
  5. vermurkste Installation
120 Beiträge 4 Kommentatoren 17.0k Aufrufe 2 Beobachtet
    Ich hab das ganze mal abgetrennt!
    hat ja nix mehr mit Daikin zu tun
    @Radix75 bitte den provisorischen Threadtitel anpassen
    Radix75
    #103
    @homoran said in vermurkste Installation:
    Daikin muss ich später noch auf den IOBroker machen wenn der endlich Adapter suchen kann
    • R Radix75
      Thomas BraunT Offline
      #104
      @radix75
      iob update
      R 1 Antwort Letzte Antwort
        @radix75
        iob update
        Radix75
        #105
        @thomas-braun said in vermurkste Installation:
        @radix75
        iob update
        Radix1975@raspberrypi5:~ $ iob update
        Used repository: stable
        Cannot download repository hash file from "http://download.iobroker.net/sources-dist-hash.json": timeout of 10000ms exceeded
        Cannot download repository file from "http://download.iobroker.net/sources-dist.json": timeout of 10000ms exceeded
        Thomas BraunT R 2 Antworten Letzte Antwort
        • R Radix75
          @radix75
          iob update
          #106
          @radix75
          iob repo add live-stable http://iobroker.live/repo/sources-dist.json
          iob repo unset stable
          iob repo set live-stable
          iob update
          • R Radix75
            @radix75
            iob update
            Radix75
            #107
            @radix75 said in vermurkste Installation:
            @radix75
            iob update
            Ist das Netzwerk so richtig???2e63ea19-d5f9-4686-abda-c92ce7ea0d2a-image.png
            R HomoranH 2 Antworten Letzte Antwort
            • R Radix75
              @radix75
              iob update
              Radix75
              #108
              Radix1975@raspberrypi5:~ $ iob repo add live-stable http://iobroker.live/repo/sources-dist.json
              Repository "live-stable" added as "http://iobroker.live/repo/sources-dist.json"
              live-stable   : http://iobroker.live/repo/sources-dist.json
              Active repo(s): stable
              Radix1975@raspberrypi5:~ $ iob repo unset stable
              Repository "stable" deactivated.
              Active repo(s):
              Radix1975@raspberrypi5:~ $ iob repo set live-stable
              Repository "live-stable" set as active.
              Active repo(s): live-stable
              Used repository: live-stable
              Adapter    "admin"        : 6.12.0   , installed 6.12.0
              Adapter    "backitup"     : 2.9.8    , installed 2.9.8
              Adapter    "discovery"    : 4.2.0    , installed 4.2.0
              Controller "js-controller": 5.0.17   , installed 5.0.17
              • R Radix75
                Active repo(s):
                #109
                @radix75
                Dann sollte es wieder funktionieren.
                • R Radix75
                  @radix75
                  iob update
                  HomoranH Offline
                  HomoranH Offline
                  #110
                  @radix75 sagte in vermurkste Installation:
                  äääähm?
                  Das ist die Konfiguration des admins, die passt.
                  Um dein Netzwerk musst du dich kümmern
                    @radix75
                    Radix75
                    #111
                    @radix75
                    Funktioniert !
                    Ein großes Dankeschön dafür.
                    Als nächstes würde ich erstmal ein Beckup der Karte machen wollen.
                    Danach müße ich dann nach https://github.com/alexreinert/piVCCU/blob/master/docs/setup/raspberrypi.md
                    piVCCU installieren auch hier hatte ich in der Vergangenheit schon oft das Problem das das Netzwerk nach dem Schritt 6-9 nicht mehr geht.
                    Ich habe auch heute das neue CCU RPI-RF-Modul bekommen hier wahren ja noch Probleme mit dem GPIO aufstecken und die Tatsache das ich nur das Original Netzteil mit UCB C habe zu lösen
                    • R Radix75
                      @radix75
                      Funktioniert !
                      #112
                      @radix75
                      Zu pivCCU kann ich nicht viel sagen.
                      • R Radix75
                        @radix75
                        Funktioniert !
                        HomoranH Offline
                        HomoranH Offline
                        #113
                        wie bereits gesagt bist du da falsch abgebogen.
                          Radix75
                          #114
                          mit welchen Kommando kann ich ein Image der SD karte auf einem externen USB Stick schreiben?
                          • R Radix75
                            HomoranH Offline
                            HomoranH Offline
                            #115
                            @radix75 wenn du die Frage stellst, bin ich mir nicht sicher ob das das richtige Vorgehen für dich sein wird
                              Radix75
                              #116
                              Warum nicht? Wir haben Stunden geraucht um alles einzurichten wenn jetzt was bei der Installation von pivCCU
                              was schief geht habe ich eine zweite SD Karte. Ich habe ja so ein SD Kartenleser für USB
                              • R Radix75
                                HomoranH Offline
                                HomoranH Offline
                                #117
                                @radix75 dann nimm die 2te Karte und fang mit OS und piVCCU an.
                                ich bin mir immer noch nicht sicher ob dein Netzwerk sauber tickt.
                                So lange hat es nur deswegen gedauert
                                  Radix75
                                  #118
                                  Können wir das noch irgendwie Herausfinden?
                                  • R Radix75
                                    HomoranH Offline
                                    HomoranH Offline
                                    #119
                                    ich leider nicht.
                                    Die Frage ist, warum es keine funktionierende Namensauflösung gibt.
                                      ich leider nicht.
                                      Radix75
                                      schrieb am zuletzt editiert von Radix75
                                      #120
                                      ich leider nicht.
                                      So nach langem suchen und Hilfe im ELV Forum habe ich herausgefunden woran es lag das die Namensauflösung nicht geht.
                                      Ich habe hier vor längerer Zeit den nameserver 37.4.251.175 von meinem VPN Service in der Fritzbox eingetragen scheinbar blockt dieser dann Anfragen an externe Webseiten so auch an den KAY server von ELV
                                      Test über
                                      code_text
                                      ```pi@raspberrypi:~ $ ping www.google.de
                                      und
                                      pi@raspberrypi:~ $ cat /etc/resolv.conf
                                      domain fritz.box
                                      search fritz.box
                                      pi@raspberrypi:~ $ ls -la /etc/resolv.confich habe das auf die IP 192.168.1.1 meiner Fritzbox geändert.
                                      Das einzige Problem ist wie ich jetzt über VPN auf neine WEB UI der CCU komme wie macht ihr das so?
