  3. Einsteigerfragen
  4. Installation
  5. vermurkste Installation
120 Beiträge 4 Kommentatoren 17.0k Aufrufe 2 Beobachtet
  • R Radix75
    @homoran said in vermurkste Installation:
    Ich hab das ganze mal abgetrennt!
    hat ja nix mehr mit Daikin zu tun
    @Radix75 bitte den provisorischen Threadtitel anpassen
    Daikin muss ich später noch auf den IOBroker machen wenn der endlich Adapter suchen kann
    Thomas BraunT Offline
    #104
    @radix75
    iob update
    R 1 Antwort Letzte Antwort
      @radix75
      iob update
      Radix75
      #105
      @thomas-braun said in vermurkste Installation:
      @radix75
      iob update
      Radix1975@raspberrypi5:~ $ iob update
      Used repository: stable
      Cannot download repository hash file from "http://download.iobroker.net/sources-dist-hash.json": timeout of 10000ms exceeded
      Cannot download repository file from "http://download.iobroker.net/sources-dist.json": timeout of 10000ms exceeded
      Thomas BraunT R 2 Antworten Letzte Antwort
      • R Radix75
        @radix75
        iob update
        #106
        @radix75
        iob repo add live-stable http://iobroker.live/repo/sources-dist.json
        iob repo unset stable
        iob repo set live-stable
        iob update
        • R Radix75
          @radix75
          iob update
          Radix75
          #107
          @radix75 said in vermurkste Installation:
          @radix75
          iob update
          Ist das Netzwerk so richtig???2e63ea19-d5f9-4686-abda-c92ce7ea0d2a-image.png
          R HomoranH 2 Antworten Letzte Antwort
          • R Radix75
            @radix75
            iob update
            Radix75
            #108
            Radix1975@raspberrypi5:~ $ iob repo add live-stable http://iobroker.live/repo/sources-dist.json
            Repository "live-stable" added as "http://iobroker.live/repo/sources-dist.json"
            live-stable   : http://iobroker.live/repo/sources-dist.json
            Active repo(s): stable
            Radix1975@raspberrypi5:~ $ iob repo unset stable
            Repository "stable" deactivated.
            Active repo(s):
            Radix1975@raspberrypi5:~ $ iob repo set live-stable
            Repository "live-stable" set as active.
            Active repo(s): live-stable
            Used repository: live-stable
            Adapter    "admin"        : 6.12.0   , installed 6.12.0
            Adapter    "backitup"     : 2.9.8    , installed 2.9.8
            Adapter    "discovery"    : 4.2.0    , installed 4.2.0
            Controller "js-controller": 5.0.17   , installed 5.0.17
            • R Radix75
              Active repo(s):
              #109
              @radix75
              Dann sollte es wieder funktionieren.
              • R Radix75
                @radix75
                iob update
                #110
                @radix75 sagte in vermurkste Installation:
                äääähm?
                Das ist die Konfiguration des admins, die passt.
                Um dein Netzwerk musst du dich kümmern
                  @radix75
                  Radix75
                  #111
                  @radix75
                  Funktioniert !
                  Ein großes Dankeschön dafür.
                  Als nächstes würde ich erstmal ein Beckup der Karte machen wollen.
                  Danach müße ich dann nach https://github.com/alexreinert/piVCCU/blob/master/docs/setup/raspberrypi.md
                  piVCCU installieren auch hier hatte ich in der Vergangenheit schon oft das Problem das das Netzwerk nach dem Schritt 6-9 nicht mehr geht.
                  Ich habe auch heute das neue CCU RPI-RF-Modul bekommen hier wahren ja noch Probleme mit dem GPIO aufstecken und die Tatsache das ich nur das Original Netzteil mit UCB C habe zu lösen
                  • R Radix75
                    @radix75
                    Funktioniert !
                    #112
                    @radix75
                    Zu pivCCU kann ich nicht viel sagen.
                    • R Radix75
                      @radix75
                      Funktioniert !
                      #113
                      wie bereits gesagt bist du da falsch abgebogen.
                        Radix75
                        #114
                        mit welchen Kommando kann ich ein Image der SD karte auf einem externen USB Stick schreiben?
                        • R Radix75
                          #115
                          @radix75 wenn du die Frage stellst, bin ich mir nicht sicher ob das das richtige Vorgehen für dich sein wird
                            Radix75
                            #116
                            Warum nicht? Wir haben Stunden geraucht um alles einzurichten wenn jetzt was bei der Installation von pivCCU
                            was schief geht habe ich eine zweite SD Karte. Ich habe ja so ein SD Kartenleser für USB
                            • R Radix75
                              #117
                              @radix75 dann nimm die 2te Karte und fang mit OS und piVCCU an.
                              ich bin mir immer noch nicht sicher ob dein Netzwerk sauber tickt.
                              So lange hat es nur deswegen gedauert
                                Radix75
                                #118
                                Können wir das noch irgendwie Herausfinden?
                                • R Radix75
                                  #119
                                  ich leider nicht.
                                  Die Frage ist, warum es keine funktionierende Namensauflösung gibt.
                                    ich leider nicht.
                                    Radix75
                                    schrieb am zuletzt editiert von Radix75
                                    #120
                                    ich leider nicht.
                                    So nach langem suchen und Hilfe im ELV Forum habe ich herausgefunden woran es lag das die Namensauflösung nicht geht.
                                    Ich habe hier vor längerer Zeit den nameserver 37.4.251.175 von meinem VPN Service in der Fritzbox eingetragen scheinbar blockt dieser dann Anfragen an externe Webseiten so auch an den KAY server von ELV
                                    Test über
                                    code_text
                                    ```pi@raspberrypi:~ $ ping www.google.de
                                    und
                                    pi@raspberrypi:~ $ cat /etc/resolv.conf
                                    domain fritz.box
                                    search fritz.box
                                    pi@raspberrypi:~ $ ls -la /etc/resolv.confich habe das auf die IP 192.168.1.1 meiner Fritzbox geändert.
                                    Das einzige Problem ist wie ich jetzt über VPN auf neine WEB UI der CCU komme wie macht ihr das so?
