  4. [SourceAnalytix 0.4.8-Final] Released !
    apollon77A
2.3k Beiträge 184 Kommentatoren 1.6m Aufrufe 153 Beobachtet
  • D derelvis
    @nieip @m4rgott
    Das Problem des fehlenden Übertrags der meterReadings in "prevDay, prevWeek, prevMonth, prevYear" kann man wie folgt beheben:
    • folgenden Kommentar in der iobroker/node_modules/iobroker.sourceanalytix/main.js suchen (ca. Zeile 852) und darunter
    							//ToDo: Think / discuss what to do with meter readings
    							// Handle meter reading states
    							// if (this.config.currentYearPrevious) await this.setStateAsync(`${stateID}.currentYear.meterReadings.previousWeek.${weekdays[x]}`, {
    							// 	val: await this.getStateAsync(`${stateID}.currentYear.meterReadings.currentWeek.${weekdays[x]}`),
    							// 	ack: true
    • folgenden Block einfügen:
    							//derelvis: copy cumulativeReading into prevValue
    							if (beforeReset.day !== actualDate.day) {
    								await this.setPreviousValues(`${stateDetails.deviceName}.cumulativeReading`, `${stateDetails.deviceName}.currentYear.meterReadings.01_previousDay`);
    							if (beforeReset.week !== actualDate.week) {
    								await this.setPreviousValues(`${stateDetails.deviceName}.cumulativeReading`, `${stateDetails.deviceName}.currentYear.meterReadings.02_previousWeek`);
    							if (beforeReset.month !== actualDate.month) {
    								await this.setPreviousValues(`${stateDetails.deviceName}.cumulativeReading`, `${stateDetails.deviceName}.currentYear.meterReadings.03_previousMonth`);
    							if (beforeReset.quarter !== actualDate.quarter) {
    								await this.setPreviousValues(`${stateDetails.deviceName}.cumulativeReading`, `${stateDetails.deviceName}.currentYear.meterReadings.04_previousQuarter`);
    							if (beforeReset.year !== actualDate.year) {
    								await this.setPreviousValues(`${stateDetails.deviceName}.cumulativeReading`, `${stateDetails.deviceName}.currentYear.meterReadings.05_previousYear`);
    							//derelvis end
    • danach (ca. Zeile 888) sollte es so weitergehen:
    						await this.extendForeignObject(stateID, obj);
    						this.log.info(`Memory values after reset : ${JSON.stringify(this.activeStates[stateID])}`);
    • Instanz SourceAnalytics neustarten
    So werden dann auch die MeterReadings aus dem Datenpunkt cumulativeReading (fortlaufender Zählerstand) zu den jeweiligen Zeitpunkten in die prevValues übernommen, wie bei den anderen Kategorien. :-) Läuft bei mir so seit letztem Sonntag:
    Wenn man sich 01_previousDay per Signal/Telegramm usw. bei Änderung schicken lässt, sollte man um Mitternacht das erste mal einen Zählerstand bekommen. Praktisch kann man sich so dann auch per history oder influx die jeweils monatlichen oder jährlichen Zählerständer loggen.
    Vielleicht mag es ja mal jemand testen (auf eigene Gefahr) und Rückmeldung geben? ;-)
    nieIPN
    nieIPN
    nieIP
    schrieb am zuletzt editiert von nieIP
    #2072
    frisch gestrichen
    L 1 Antwort Letzte Antwort
    • nieIPN nieIP
      frisch gestrichen
      L
      L
      Laser
      schrieb am zuletzt editiert von Laser
      #2073
      Frage hat sich gerade erledigt
      • nieIPN nieIP
        Hallo
        ich nutze Version 0.4.8
        Wegen dem Reset des Zählerstandes auf 0 würde ich wie einige Seiten vorher beschrieben die
        editieren.
        Oder gibt es schon eine online verfügbare neuere Version, wo der code mit drin ist??
        EDIT in der 0.4.15 scheint die Änderung schon drin zu sein. erledigt.
        nieIPN
        nieIPN
        nieIP
        #2074
        mit der Version 0.4.15 habe ich beim Adapterstart bei 4 vom 12 Geräten eine Fehlermeldung.
        Kann mir jemand sagen, in welche Richtung ich da suchen muss ??
        2023-12-08 18:53:09.125 - info: sourceanalytix.0 (946) Initialization of hm-rega.0.44242 successfully
        2023-12-08 18:53:09.127 - info: sourceanalytix.0 (946) Initialising "hm-rpc.0.KEQ0971587.2.ENERGY_COUNTER" | (2 of 12)
        2023-12-08 18:53:09.197 - error: sourceanalytix.0 (946) Check settings for hm-rpc.0.KEQ0971587.2.ENERGY_COUNTER ! Known valueAtDeviceReset : (6.9214) > known cumulative value (6.921399994000001) cannot proceed
        2023-12-08 18:53:09.198 - error: sourceanalytix.0 (946) Troubleshoot Data hm-rpc.0.KEQ0971587.2.ENERGY_COUNTER custom Data : {"type":"state","common":{"def":0,"type":"number","read":true,"write":false,"min":0,"max":838860.7,"unit":"Wh","name":"ZwStecker_21-GetraenkeKuehschrank.ENERGY_COUNTER","role":"value.power.consumption","custom":{"sql.0":{"enabled":true,"storageType":"","counter":false,"aliasId":"","debounceTime":0,"blockTime":0,"changesOnly":true,"changesRelogInterval":"86400","changesMinDelta":"0.01","ignoreBelowNumber":"","disableSkippedValueLogging":false,"retention":0,"customRetentionDuration":365,"maxLength":10,"enableDebugLogs":false,"debounce":100},"sourceanalytix.0":{"enabled":true,"selectedUnit":"Detect automatically","deviceResetLogicEnabled":true,"threshold":0.0001,"start_day":6.2118,"start_week":5.669600000000001,"start_month":4.7242,"start_quarter":28.578500000000002,"start_year":0,"alias":"Getraenke_Leistung_Analyse","selectedPrice":"Strombezug","costs":true,"consumption":true,"valueAtDeviceReset":6.9214,"valueAtDeviceInit":6.921399994000001,"cumulativeValue":6.2118}}},"native":{"CONTROL":"POWERMETER.ENERGY_COUNTER","DEFAULT":0,"FLAGS":1,"ID":"ENERGY_COUNTER","MAX":838860.7,"MIN":0,"OPERATIONS":5,"TAB_ORDER":0,"TYPE":"FLOAT","UNIT":"Wh"},"_id":"hm-rpc.0.KEQ0971587.2.ENERGY_COUNTER","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.sourceanalytix.0","user":"system.user.admin","ts":1701967931210}
        2023-12-08 18:53:09.199 - error: sourceanalytix.0 (946) Cannot handle calculations for hm-rpc.0.KEQ0971587.2.ENERGY_COUNTER, check log messages and adjust settings!
        2023-12-08 18:53:09.202 - error: sourceanalytix.0 (946) Initialization of hm-rpc.0.KEQ0971587.2.ENERGY_COUNTER failed, check warn messages !
        2023-12-08 18:53:09.203 - info: sourceanalytix.0 (946) Initialising "hm-rpc.0.LEQ1344854.2.ENERGY_COUNTER" | (3 of 12)
        2023-12-08 18:53:09.264 - error: sourceanalytix.0 (946) Check settings for hm-rpc.0.LEQ1344854.2.ENERGY_COUNTER ! Known valueAtDeviceReset : (53.9896) > known cumulative value (53.989599976) cannot proceed
        2023-12-08 18:53:09.266 - error: sourceanalytix.0 (946) Troubleshoot Data hm-rpc.0.LEQ1344854.2.ENERGY_COUNTER custom Data : {"type":"state","common":{"def":0,"type":"number","read":true,"write":false,"min":0,"max":838860.7,"unit":"Wh","name":"ZwStecker_Server-2.ENERGY_COUNTER","role":"value.power.consumption","custom":{"sql.0":{"enabled":true,"storageType":"","counter":false,"aliasId":"","debounceTime":0,"blockTime":0,"changesOnly":true,"changesRelogInterval":"86400","changesMinDelta":"0.01","ignoreBelowNumber":"","disableSkippedValueLogging":false,"retention":0,"customRetentionDuration":365,"maxLength":0,"enableDebugLogs":false,"debounce":100},"sourceanalytix.0":{"enabled":true,"selectedUnit":"Detect automatically","deviceResetLogicEnabled":true,"threshold":0.001,"start_day":48.4355,"start_week":41.325300000000006,"start_month":30.6427,"start_quarter":380.38259999999997,"start_year":0,"alias":"Server_Leistung_Analyse","selectedPrice":"Strombezug","costs":true,"consumption":true,"valueAtDeviceReset":53.9896,"valueAtDeviceInit":53.989599976,"cumulativeValue":48.4355}}},"native":{"CONTROL":"POWERMETER.ENERGY_COUNTER","DEFAULT":0,"FLAGS":1,"ID":"ENERGY_COUNTER","MAX":838860.7,"MIN":0,"OPERATIONS":5,"TAB_ORDER":0,"TYPE":"FLOAT","UNIT":"Wh"},"_id":"hm-rpc.0.LEQ1344854.2.ENERGY_COUNTER","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.sourceanalytix.0","user":"system.user.admin","ts":1701968924431}
        2023-12-08 18:53:09.267 - error: sourceanalytix.0 (946) Cannot handle calculations for hm-rpc.0.LEQ1344854.2.ENERGY_COUNTER, check log messages and adjust settings!
        2023-12-08 18:53:09.269 - error: sourceanalytix.0 (946) Initialization of hm-rpc.0.LEQ1344854.2.ENERGY_COUNTER failed, check warn messages !
        2023-12-08 18:53:09.270 - info: sourceanalytix.0 (946) Initialising "hm-rpc.0.MEQ0025548.1.GAS_ENERGY_COUNTER" | (4 of 12)
        2023-12-08 18:53:09.328 - error: sourceanalytix.0 (946) Check settings for hm-rpc.0.MEQ0025548.1.GAS_ENERGY_COUNTER ! Known valueAtDeviceReset : (2385.4) > known cumulative value (2385.399998) cannot proceed
        2023-12-08 18:53:09.329 - error: sourceanalytix.0 (946) Troubleshoot Data hm-rpc.0.MEQ0025548.1.GAS_ENERGY_COUNTER custom Data : {"type":"state","common":{"def":0,"type":"number","read":true,"write":false,"min":0,"max":2147483.644531,"unit":"m3","name":"GAS_Zaehler_1-Gas.GAS_ENERGY_COUNTER","custom":{"sql.0":{"enabled":true,"changesOnly":true,"debounce":"1200","retention":0,"changesRelogInterval":"86400","changesMinDelta":0.01,"aliasId":"","storageType":"","debounceTime":0,"blockTime":1200,"ignoreBelowNumber":"","disableSkippedValueLogging":false,"counter":false,"customRetentionDuration":365,"maxLength":10,"enableDebugLogs":false},"sourceanalytix.0":{"enabled":true,"selectedUnit":"m³","deviceResetLogicEnabled":true,"threshold":1,"start_day":2375.47,"start_week":2362.31,"start_month":2340.72,"start_quarter":2154.71,"start_year":1588,"alias":"Gas_Kosten_Analyse","selectedPrice":"Gas","costs":true,"consumption":true,"meter_values":true,"valueAtDeviceReset":2385.4,"valueAtDeviceInit":2385.399998,"cumulativeValue":2375.47}}},"native":{"CONTROL":"POWERMETER_IGL.GAS_ENERGY_COUNTER","DEFAULT":0,"FLAGS":1,"ID":"GAS_ENERGY_COUNTER","MAX":2147483.644531,"MIN":0,"OPERATIONS":5,"TAB_ORDER":0,"TYPE":"FLOAT","UNIT":"m3"},"_id":"hm-rpc.0.MEQ0025548.1.GAS_ENERGY_COUNTER","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.sourceanalytix.0","user":"system.user.admin","ts":1701967948852}
        2023-12-08 18:53:09.330 - error: sourceanalytix.0 (946) Cannot handle calculations for hm-rpc.0.MEQ0025548.1.GAS_ENERGY_COUNTER, check log messages and adjust settings!
        2023-12-08 18:53:09.332 - error: sourceanalytix.0 (946) Initialization of hm-rpc.0.MEQ0025548.1.GAS_ENERGY_COUNTER failed, check warn messages !
        2023-12-08 18:53:09.333 - info: sourceanalytix.0 (946) Initialising "hm-rpc.0.OEQ0070768.2.ENERGY_COUNTER" | (5 of 12)
        2023-12-08 18:53:09.396 - error: sourceanalytix.0 (946) Check settings for hm-rpc.0.OEQ0070768.2.ENERGY_COUNTER ! Known valueAtDeviceReset : (13.8524) > known cumulative value (13.852399997) cannot proceed
        2023-12-08 18:53:09.397 - error: sourceanalytix.0 (946) Troubleshoot Data hm-rpc.0.OEQ0070768.2.ENERGY_COUNTER custom Data : {"type":"state","common":{"def":0,"type":"number","read":true,"write":false,"min":0,"max":838860.699219,"unit":"Wh","name":"Klimatruhe-2-Klima.ENERGY_COUNTER","custom":{"sql.0":{"enabled":true,"changesOnly":true,"debounce":"1200","retention":0,"changesRelogInterval":"86400","changesMinDelta":0.01,"storageType":"","aliasId":"","debounceTime":0,"blockTime":1200,"ignoreBelowNumber":"","disableSkippedValueLogging":false,"counter":false,"customRetentionDuration":365,"maxLength":10,"enableDebugLogs":false},"sourceanalytix.0":{"enabled":true,"selectedUnit":"Detect automatically","deviceResetLogicEnabled":true,"threshold":0.001,"start_day":6.9262,"start_week":6.9262,"start_month":6.9262,"start_quarter":335.2113,"start_year":0,"alias":"Klima_Leistung_Analyse","selectedPrice":"Strombezug","costs":true,"consumption":true,"valueAtDeviceReset":13.8524,"valueAtDeviceInit":6.926199996999999,"cumulativeValue":6.9262}},"role":"value.power.consumption"},"native":{"CONTROL":"POWERMETER.ENERGY_COUNTER","DEFAULT":0,"FLAGS":1,"ID":"ENERGY_COUNTER","MAX":838860.699219,"MIN":0,"OPERATIONS":5,"TAB_ORDER":0,"TYPE":"FLOAT","UNIT":"Wh"},"_id":"hm-rpc.0.OEQ0070768.2.ENERGY_COUNTER","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.sourceanalytix.0","user":"system.user.admin","ts":1701968930074}
        2023-12-08 18:53:09.398 - error: sourceanalytix.0 (946) Cannot handle calculations for hm-rpc.0.OEQ0070768.2.ENERGY_COUNTER, check log messages and adjust settings!
        2023-12-08 18:53:09.398 - error: sourceanalytix.0 (946) Initialization of hm-rpc.0.OEQ0070768.2.ENERGY_COUNTER failed, check warn messages !
        2023-12-08 18:53:09.399 - info: sourceanalytix.0 (946) Initialising "hm-rpc.1.0001D3C990BF8F.6.ENERGY_COUNTER" | (6 of 12)
        2023-12-08 18:53:16.583 - info: sourceanalytix.0 (946) Initialization of hm-rpc.1.0001D3C990BF8F.6.ENERGY_COUNTER successfully
        2023-12-08 18:53:16.585 - info: sourceanalytix.0 (946) Initialising "hm-rpc.1.0001D3C99C6758.6.ENERGY_COUNTER" | (7 of 12)
        2023-12-08 18:53:23.519 - info: sourceanalytix.0 (946) Initialization of hm-rpc.1.0001D3C99C6758.6.ENERGY_COUNTER successfully
        2023-12-08 18:53:23.520 - info: sourceanalytix.0 (946) Initialising "hm-rpc.1.0001D70994EA29.6.ENERGY_COUNTER" | (8 of 12)
        2023-12-08 18:53:30.298 - info: sourceanalytix.0 (946) Initialization of hm-rpc.1.0001D70994EA29.6.ENERGY_COUNTER successfully
        2023-12-08 18:53:30.298 - info: sourceanalytix.0 (946) Initialising "hm-rpc.1.0001D70994EA37.6.ENERGY_COUNTER" | (9 of 12)
          @badsnoopy667 nein, variabel geht (noch) nicht
          B
          B
          badsnoopy667
          #2075
          @crunchip
          Danke für den Hinweis.
          Falls noch jemand sowas vorhat:
          Ich hab's jetzt so gelöst, dass ich einen neuen Datenpunkt "Netzbezug_dynamisch" angelegt habe. Diesen beschreibe ich mit "Netzbezug * (VariablerPreis / FixerPreis)" wobei FixerPreis mein aktueller Strompreis ist und der variable halt der von Tibber/Awattar.
          Damit stimmt zwar bei diesem Datenpunkt die kWh Angabe nicht, aber der Preis den Sourceanalytix berechnet sollte dem des dynamischen Tarifs entsprechen. Schaun wir mal, ob das klappt.
          • B badsnoopy667
            @crunchip
            L
            L
            Laser
            #2076
            Ich habe das Problem, daß Sourceanalytix 4.0.15 nicht mehr richtig zählt. Mit Influx ausgewerteter Datenpunkt:
            SA zeigt aber das an (auch den gestrigen Wert mußte ich manuell eintragen):
            Dienstag hätten es auch um die 0,5 kWh sein müssen. Täglich die Werte kontrollieren und korrigieren- das ist auf Dauer Mis...
            • L Laser
              L
              L
              Laser
              #2077
              @Dutchman und wieder ist ein Tag vergangen, es wird immer noch nicht gezählt. Warum wird gerade dieser eine Datenpunkt nicht gezählt?
              EDIT: habe jetzt die Einheiten von kWh in Wh verändert und wieder zurück. Können die Einheiten da irgend etwas beeinflussen?
              EDIT 1 Tag später: Es funktioniert jetzt wieder!
              • hg6806H
                hg6806H
                hg6806
                #2078
                Durch eine Umstellung der OpenWB Wallbox ist mir ein Wert "vertausendfacht", also war vorher in kWh und ist nun in Wh ausgegeben.
                Leider zu spät entdeckt, nun sind die Sourceanalytix Wert verhagelt. Ich hatte den Wert (zum Glück alias) zwar wieder auf den alten gesetzt, Die Werte in Sourceanalytix sind trotzdem um 1000x zu hoch.
                1. Wie kann ich das wieder gerade rücken
                2. Wie kann ich das ´mit den neuen Werten handeln? Wie gesagt, füttere ich ein Alias Wert, hier müsste man bei neuen Wert durch 1000 teilen können. Notfalls müsste ich nochmal ein Zwischenschritt über Blockly durch 1000 teilen.
                • S
                  S
                  sonystar
                  #2079
                  ich weiß das Thema wurde schon mehrfach behandelt aber ich verstehe ich einfach nicht.
                  Meine Homematic Zwischenstecker haben sich heute dank Stromausfall resettet. Haben also von vorne angefangen zu Zählen.
                  Die Reseterkennung im SA-Adapter hat nicht funktioniert.
                  Demzufolge sind alle "CumulativReading" Werte nahe bei 0. Wie bekomme ich den alten Zählerstand vor dem Reset auf den aktuellen "CumulativReading"-Wert hinzuaddiert.
                  Wenn ich "valueAtDeviceReset", und "valueAtDeviceInit": auf 0 setze und den aktuellen Zählerstand (nach dem Reset) in "cumulativeValue" schreibe bleibt "CumulativReading" trotzdem nahe null.
                  Was mir auch logisch erscheint. Woher soll er auch den alten Zählerstand kennen. In welcher Variable muss ich den alten Zählerstand eintragen?
                  • hg6806H hg6806
                    crunchipC
                    crunchipC
                    Developer Global Moderator Most Active Forum Testing
                    #2080
                    @hg6806 bereits heschriebene Werte müsstest du manuell korrigieren.
                    Mit einem alias kannst du auch direkt umrechnen dazu benötigst du kein extra blockly
                    • S sonystar
                      crunchipC
                      crunchipC
                      #2081
                      @sonystar sagte in [SourceAnalytix 0.4.8-Final] Released !:
                      Kann man die nicht direkt wieder korrigieren wie z.b bei tasmota?
                        S
                        S
                        sonystar
                        schrieb am zuletzt editiert von sonystar
                        #2082
                        @crunchip
                        Nein nicht das ich wüsste.
                        Die RAW sieht jetzt bei mir so aus:
                        "valueAtDeviceReset": 0,
                        "valueAtDeviceInit": 0,
                        "cumulativeValue": 67.89         <------- ALTER STAND + NEUER STAND
                        Das scheint aber nicht richtig zu sein, denn bei "CumulativReading" steht trotzdem nur der neue Zählerstand ?!
                        Edit: Ich habe es jetzt auch nochmal nach dieser Anleitung probiert: https://forum.iobroker.net/topic/40932/sourceanalytix-0-4-8-final-released/205
                        Die RAW sieht dann so aus:
                        "valueAtDeviceReset": 67.6685,
                        "valueAtDeviceInit": null
                        Allerdings habe ich dann ein Error im Log:
                        Check settings for hm-rpc.0.PEQ0411435.2.ENERGY_COUNTER ! Known valueAtDeviceReset : (67.6685) > known cumulative value (0.0101) cannot proceed
                        Version ist übrigens die 0.4.14.
                        • S sonystar
                          @crunchip
                          crunchipC
                          crunchipC
                          #2083
                          @sonystar den Wert holt sich SA ja vom Gerät.
                          Wie sehen die Startwerte zum Gerät aus?
                            S
                            S
                            sonystar
                            #2084
                            @crunchip sagte in [SourceAnalytix 0.4.8-Final] Released !:
                            Die Startwerte sehen so aus. Sind halt die Werte vor dem Reset.
                            "start_day": 67.667,
                            "start_week": 67.6617,
                            "start_month": 63.3263,
                            "start_quarter": 55.17710000000001,
                            "start_year": 6.059,
                            Beim Stand von 67,6685 wurde die Steckdose resettet.
                            Habe oben auch nochmal einen kleinen Edit eingefügt.
                            • S
                              S
                              sonystar
                              #2085
                              Habe es gelöst.
                              1. SA gestoppt
                              2. die RAW angepasst:
                              "cumulativeValue": 0
                              1. Schwellenwert der Geräte-Reset-Erkennung auf 0,001
                              2. SA gestartet
                              3. den Wert des Datenpunktes (bei mir Energy.Counter) manuell auf den Stand vor dem Reset schreiben
                              4. Warten bis neue Werte reinkommen
                              5. Staunen, dass der Reset nun funktioniert hat und wieder alles wunderbar passt.
                              Ich verstehe es nicht, aber bin Happy.
                              Vielen Dank trotzdem!
                              • F
                                F
                                Fichte
                                #2086
                                Hallo zusammen
                                Ich lese einen Stromzähler via SML Tasmota aus (Watt).
                                Ab einen gewissen Punkt Springt Sourceanalytix um und schreibt Utopische werte
                                Ich hab die schon die Werte gelöscht und auch die einstellung dazu noch einmal komplett neu gemacht.
                                Aber ab irgend einen Punkt Springt er dann auf solche werte.
                                Habe via History die Daten mit gelogt um zu schauen ob es nicht an Utopischen leistungswerten liegt, aber da ist alles Super und nie ein wert Über 12000 Watt.
                                Habe noch andere Geräte wie EM3 und Gosund etc. und dort funktioniert alles super.
                                Hat oder hatte jemand schon das selbe Problem und/oder gibt es hier eine Lösung.?
                                Liebe Grüße
                                crunchipC D 2 Antworten Letzte Antwort
                                • F Fichte
                                  Hallo zusammen
                                  Liebe Grüße
                                  crunchipC
                                  crunchipC
                                  #2087
                                  @fichte erkennen eines device reset ist bei watt ja schon mal unnötig
                                  @fichte sagte in [SourceAnalytix 0.4.8-Final] Released !:
                                  bestimmte Uhrzeit?
                                  F 1 Antwort Letzte Antwort
                                    bestimmte Uhrzeit?
                                    F
                                    F
                                    Fichte
                                    #2088
                                    @crunchip Den reset "1" setz er immer wenn ich Sourceanalytix auf einen wert konfiguriere.
                                    Ich log die Daten mal mit und schaue ab wann es passiert.
                                    LG
                                    • F Fichte
                                      LG
                                      crunchipC
                                      crunchipC
                                      #2089
                                      @fichte dann mach das Häckchen weg bei "Erkennen der Zurücksetzung" , du erfasst ja keinen Zählerstand
                                        F
                                        F
                                        Fichte
                                        #2090
                                        @crunchip Hab jetzt den selber fehler nur im History
                                        Das ist der LOG (History) aus Sourceanalytix:
                                        und hier ist der LOG (History) aus dem Datenpunkt den ich lese:
                                        Und im Log selbst ist in der Zeit nichts drin:
                                        Also ich kann nicht sehen das es aus irgend einen GRund den Wert so in die Höhe schnellen lässt.
                                        • F Fichte
                                          crunchipC
                                          crunchipC
                                          #2091
                                          @fichte ich seh das die Werte im 10 sec Takt rein kommen, ausser hier
                                          das ist dann genau dein Sprung
                                          ansonsten fällt mir nichts weiter auf
                                          84.0k
