  4. [SourceAnalytix 0.4.8-Final] Released !
2.3k Beiträge 184 Kommentatoren 1.5m Aufrufe 153 Beobachtet
  • DutchmanD Dutchman
    @laser sagte in [SourceAnalytix 0.4.8-Final] Released !:
    @dutchman
    2023-11-05 14:57:20.876  - error: modbus.0 (4041450) Request timed out.
    2023-11-05 14:57:20.877  - warn: modbus.0 (4041450) Poll error count: 1 code: {"err":"timeout","timeout":5000}
    2023-11-05 14:57:23.530  - info: host.raspberrypi stopInstance system.adapter.vedirect.0 (force=false, process=true)
    2023-11-05 14:57:23.542  - error: vedirect.0 (4061474) Sentry disabled, error catched : [onUnload] TypeError: SerialPort.close is not a function
    2023-11-05 14:57:23.576  - info: host.raspberrypi stopInstance system.adapter.vedirect.0 send kill signal
    2023-11-05 14:57:24.143  - info: host.raspberrypi instance system.adapter.vedirect.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-11-05 14:57:25.905  - info: host.raspberrypi instance system.adapter.vedirect.0 started with pid 4063780
    2023-11-05 14:58:00.003  - warn: javascript.0 (53524) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
    2023-11-05 14:59:00.002  - warn: javascript.0 (53524) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
    2023-11-05 15:00:00.013  - warn: javascript.0 (53524) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
    2023-11-05 15:01:00.005  - warn: javascript.0 (53524) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
    2023-11-05 15:01:01.013  - info: javascript.0 (53524) script.js.Heizung.TagNachtZeitraum: Tag:
    2023-11-05 15:02:00.004  - warn: javascript.0 (53524) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
    2023-11-05 15:03:00.004  - warn: javascript.0 (53524) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
    2023-11-05 15:04:00.003  - warn: javascript.0 (53524) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
    2023-11-05 15:05:00.003  - warn: javascript.0 (53524) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
    2023-11-05 15:06:00.002  - warn: javascript.0 (53524) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
    2023-11-05 15:07:00.002  - warn: javascript.0 (53524) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
    2023-11-05 15:08:00.003  - warn: javascript.0 (53524) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
    2023-11-05 15:09:00.021  - warn: javascript.0 (53524) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
    2023-11-05 15:10:00.004  - warn: javascript.0 (53524) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
    2023-11-05 15:10:01.007  - info: javascript.0 (53524) script.js.Heizung.TagNachtZeitraum: Tag:
    2023-11-05 15:11:00.005  - warn: javascript.0 (53524) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
    2023-11-05 15:12:00.005  - warn: javascript.0 (53524) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
    2023-11-05 15:13:00.003  - warn: javascript.0 (53524) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
    2023-11-05 15:14:00.011  - warn: javascript.0 (53524) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
    2023-11-05 15:15:00.023  - warn: javascript.0 (53524) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
    2023-11-05 15:16:00.014  - warn: javascript.0 (53524) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
    2023-11-05 15:17:00.009  - warn: javascript.0 (53524) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
    2023-11-05 15:18:00.003  - warn: javascript.0 (53524) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
    2023-11-05 15:19:00.009  - warn: javascript.0 (53524) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
    2023-11-05 15:20:00.004  - warn: javascript.0 (53524) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
    OK, diesen JS- Fehler werde ich eliminieren (ist eine andere Baustelle).
    Ich sehe hier keine Fehler von SA ? 😅
    Laser
    schrieb am zuletzt editiert von Laser
    #2058
    @dutchman ich sehe auch keine! Auch zu anderen Zeiten mit der Zacke nach unten sehe ich keine SA-Fehler im Protokoll.
      @crunchip sagte in [SourceAnalytix 0.4.8-Final] Released !:
      @dutchman sagte in [SourceAnalytix 0.4.8-Final] Released !:
      das verstehe ich nicht,
      Ich ja eben auch nicht, muss ich mir in einer ruhigen Minute nochmal genauer ansehen.
      Schöner wäre es allerdings, ich würde die paar Tasmota auch hinbekommen, das sie sich nicht zurück setzen. Aber auch das gelingt mir nicht
      Können gerne mal zusammen schauen oder das du mir wieder deine Logs von SA an meinen zentralen SEQ schickst
      Dan kan alles weiterlaufen und wen der Fehler auftritt hab ich die Info die ich brauche
      Wen möglich hätte ich das am liebsten, kan ich selber durch die log Daten stöbern.
      crunchipC Offline
      crunchipC Offline
      #2059
      @dutchman machen wir bei Gelegenheit, hab allerdings aktuell anderweitig einiges um die Ohren.
      Wenn mal bisserl Luft ist, meld ich mich bei dir
      • L Laser
        crunchipC Offline
        crunchipC Offline
        #2060
        @laser da müste dann allerdings ne Meldung im Log erscheinen,... device reset....Erkannt
        L 1 Antwort Letzte Antwort
          Laser
          #2061
          @crunchip Es kommt zu keiner Zeit diese Meldung! Ich werde das runtergeladene Log aber nochmal durchsuchen! Bisher nichts dergleichen gefunden. Zumindest nicht zu den Zeiten mit den Zacken. Woanders schon!
           Device reset detected for alias.0.EnergieBattEntnahme.TotalEM0 store current cumulatedReading 676.0043000000001 as valueAtDeviceReset (previous valueAtDeviceReset : 424.93600000000004)
          2023-11-05 05:10:57.102  - warn: sourceanalytix.0 (3493514) Device reset detected for alias.0.ACLaden_Total-EM1.Total-EM1 store current cumulatedReading 257.5341 as valueAtDeviceReset (previous valueAtDeviceReset : 165.17810000000003)
          2023-11-05 05:10:57.105  - warn: sourceanalytix.0 (3493514) Device reset detected for shelly.1.SHEM#244CAB419A03#1.Emeter1.Total store current cumulatedReading 257.5341 as valueAtDeviceReset (previous valueAtDeviceReset : 165.17810000000003)
          2023-11-05 05:10:57.148  - warn: sourceanalytix.0 (3493514) Object of state "sourceanalytix.0.alias__0__ACLaden_Total-EM1__Total-EM1.cumulativeReading" is missing the required property "common.type"
          2023-11-05 05:10:57.161  - warn: sourceanalytix.0 (3493514) Object of state "sourceanalytix.0.shelly__1__SHEM#244CAB419A03#1__Emeter1__Total.cumulativeReading" is missing the required property "common.type"
          2023-11-05 05:10:57.185  - warn: sourceanalytix.0 (3493514) Object of state "sourceanalytix.0.alias__0__ACLaden_Total-EM1__Total-EM1.2023.readingCumulative" is missing the required property "common.type"
            spike2
            schrieb am zuletzt editiert von spike2
            #2062
            Ist es möglich die geloggten Adapter - Daten von einer Steckdose auf einer andere zu übertragen?
            Der Grund ist, ich habe eine Steckdose von einem anderen System im Einsatz und möchte die "alte" mit dem "neuen" System ersetzen.
            Geht vermutlich nur händisch, die Daten auf
            die "neue" zu übertragen, richtig?
            Also wie im unten stehenden Bild.
            DutchmanD crunchipC 2 Antworten Letzte Antwort
            • S spike2
              DutchmanD Offline
              DutchmanD Offline
              Dutchman
              #2063
              @spike2 sagte in [SourceAnalytix 0.4.8-Final] Released !:
              das wird demnaest moeglich sein
                spike2
                #2064
                @dutchman ohh, dass wäre der Wahnsinn :)
                • S spike2
                  crunchipC Offline
                  crunchipC Offline
                  #2065
                  @spike2 https://forum.iobroker.net/post/835238
                    spike2
                    #2066
                    @crunchip klingt vielversprechend, werde ich die Tage mal ausprobieren.
                    • S spike2
                      DutchmanD Offline
                      DutchmanD Offline
                      Dutchman
                      #2067
                      der Grundgedanke ist das man einen alias definieren kann, damit haben wir in SA auch nicht mehr den langen Datenpunkt Namen sondern alias.
                      ich integriere das momentan, dazu gehört auch wen man den alias ändert das er die Daten umzieht.
                      Damit kann man dan auch alias einen andere state zuweisen was im Grunde ist was du brauchst :)
                        spike2
                        #2068
                        @dutchman Ja genau ich denke auch, dass es das ist was ich bräuchte 😉
                        Gibt es schon einen ungefähren Fahrplan wann das Update erscheinen könnte?
                        Bitte nicht falsch verstehen, ich will keineswegs Stress machen 😀
                          badsnoopy667
                          schrieb am zuletzt editiert von badsnoopy667
                          #2069
                          Ist es eigentlich möglich SourceAnlaytix auch zusammen mit einem variablen Stromtarif (z.B. Tibber) zu nutzen?
                          Ich habe zwei Datenpunkte: "Verbrauch" und "aktueller_Preis", in kWh und €ent/kWh.
                          Kann ich den variablen Preis als Rechengröße in Sourceanalytix verwenden?
                          Ich möchte gerne wissen, wie viel ich mit dem variablen Stromtarif gegenüber meinem aktuell noch festen Tarif sparen würde, damit ich eine fundierte Entscheidung treffen kann.
                          Vielen Dank im Vorraus! Ich hoffe die Frage hat hier noch keiner gestellt, aber bei meiner Forumsuche ist nix bei rumgekommen.
                          • B badsnoopy667
                            crunchipC Offline
                            crunchipC Offline
                            #2070
                            @badsnoopy667 nein, variabel geht (noch) nicht
                            • nieIPN Offline
                              nieIPN Offline
                              nieIP
                              schrieb am zuletzt editiert von nieIP
                              #2071
                              Hallo
                              ich nutze Version 0.4.8
                              Wegen dem Reset des Zählerstandes auf 0 würde ich wie einige Seiten vorher beschrieben die
                              iobroker/node_modules/iobroker.sourceanalytix/main.js
                              editieren.
                              Oder gibt es schon eine online verfügbare neuere Version, wo der code mit drin ist??
                              EDIT in der 0.4.15 scheint die Änderung schon drin zu sein. erledigt.
                              nieIPN 1 Antwort Letzte Antwort
                              • D derelvis
                                @nieip @m4rgott
                                Das Problem des fehlenden Übertrags der meterReadings in "prevDay, prevWeek, prevMonth, prevYear" kann man wie folgt beheben:
                                • folgenden Kommentar in der iobroker/node_modules/iobroker.sourceanalytix/main.js suchen (ca. Zeile 852) und darunter
                                							//ToDo: Think / discuss what to do with meter readings
                                							// Handle meter reading states
                                							// if (this.config.currentYearPrevious) await this.setStateAsync(`${stateID}.currentYear.meterReadings.previousWeek.${weekdays[x]}`, {
                                							// 	val: await this.getStateAsync(`${stateID}.currentYear.meterReadings.currentWeek.${weekdays[x]}`),
                                							// 	ack: true
                                • folgenden Block einfügen:
                                							//derelvis: copy cumulativeReading into prevValue
                                							if (beforeReset.day !== actualDate.day) {
                                								await this.setPreviousValues(`${stateDetails.deviceName}.cumulativeReading`, `${stateDetails.deviceName}.currentYear.meterReadings.01_previousDay`);
                                							if (beforeReset.week !== actualDate.week) {
                                								await this.setPreviousValues(`${stateDetails.deviceName}.cumulativeReading`, `${stateDetails.deviceName}.currentYear.meterReadings.02_previousWeek`);
                                							if (beforeReset.month !== actualDate.month) {
                                								await this.setPreviousValues(`${stateDetails.deviceName}.cumulativeReading`, `${stateDetails.deviceName}.currentYear.meterReadings.03_previousMonth`);
                                							if (beforeReset.quarter !== actualDate.quarter) {
                                								await this.setPreviousValues(`${stateDetails.deviceName}.cumulativeReading`, `${stateDetails.deviceName}.currentYear.meterReadings.04_previousQuarter`);
                                							if (beforeReset.year !== actualDate.year) {
                                								await this.setPreviousValues(`${stateDetails.deviceName}.cumulativeReading`, `${stateDetails.deviceName}.currentYear.meterReadings.05_previousYear`);
                                							//derelvis end
                                • danach (ca. Zeile 888) sollte es so weitergehen:
                                						await this.extendForeignObject(stateID, obj);
                                						this.log.info(`Memory values after reset : ${JSON.stringify(this.activeStates[stateID])}`);
                                • Instanz SourceAnalytics neustarten
                                So werden dann auch die MeterReadings aus dem Datenpunkt cumulativeReading (fortlaufender Zählerstand) zu den jeweiligen Zeitpunkten in die prevValues übernommen, wie bei den anderen Kategorien. :-) Läuft bei mir so seit letztem Sonntag:
                                Wenn man sich 01_previousDay per Signal/Telegramm usw. bei Änderung schicken lässt, sollte man um Mitternacht das erste mal einen Zählerstand bekommen. Praktisch kann man sich so dann auch per history oder influx die jeweils monatlichen oder jährlichen Zählerständer loggen.
                                Vielleicht mag es ja mal jemand testen (auf eigene Gefahr) und Rückmeldung geben? ;-)
                                nieIPN Offline
                                nieIPN Offline
                                nieIP
                                #2072
                                frisch gestrichen
                                • nieIPN nieIP
                                  frisch gestrichen
                                  Laser
                                  #2073
                                  Frage hat sich gerade erledigt
                                  • nieIPN nieIP
                                    Hallo
                                    editieren.
                                    nieIPN Offline
                                    nieIPN Offline
                                    nieIP
                                    #2074
                                    mit der Version 0.4.15 habe ich beim Adapterstart bei 4 vom 12 Geräten eine Fehlermeldung.
                                    Kann mir jemand sagen, in welche Richtung ich da suchen muss ??
                                    2023-12-08 18:53:09.125 - info: sourceanalytix.0 (946) Initialization of hm-rega.0.44242 successfully
                                    2023-12-08 18:53:09.127 - info: sourceanalytix.0 (946) Initialising "hm-rpc.0.KEQ0971587.2.ENERGY_COUNTER" | (2 of 12)
                                    2023-12-08 18:53:09.197 - error: sourceanalytix.0 (946) Check settings for hm-rpc.0.KEQ0971587.2.ENERGY_COUNTER ! Known valueAtDeviceReset : (6.9214) > known cumulative value (6.921399994000001) cannot proceed
                                    2023-12-08 18:53:09.198 - error: sourceanalytix.0 (946) Troubleshoot Data hm-rpc.0.KEQ0971587.2.ENERGY_COUNTER custom Data : {"type":"state","common":{"def":0,"type":"number","read":true,"write":false,"min":0,"max":838860.7,"unit":"Wh","name":"ZwStecker_21-GetraenkeKuehschrank.ENERGY_COUNTER","role":"value.power.consumption","custom":{"sql.0":{"enabled":true,"storageType":"","counter":false,"aliasId":"","debounceTime":0,"blockTime":0,"changesOnly":true,"changesRelogInterval":"86400","changesMinDelta":"0.01","ignoreBelowNumber":"","disableSkippedValueLogging":false,"retention":0,"customRetentionDuration":365,"maxLength":10,"enableDebugLogs":false,"debounce":100},"sourceanalytix.0":{"enabled":true,"selectedUnit":"Detect automatically","deviceResetLogicEnabled":true,"threshold":0.0001,"start_day":6.2118,"start_week":5.669600000000001,"start_month":4.7242,"start_quarter":28.578500000000002,"start_year":0,"alias":"Getraenke_Leistung_Analyse","selectedPrice":"Strombezug","costs":true,"consumption":true,"valueAtDeviceReset":6.9214,"valueAtDeviceInit":6.921399994000001,"cumulativeValue":6.2118}}},"native":{"CONTROL":"POWERMETER.ENERGY_COUNTER","DEFAULT":0,"FLAGS":1,"ID":"ENERGY_COUNTER","MAX":838860.7,"MIN":0,"OPERATIONS":5,"TAB_ORDER":0,"TYPE":"FLOAT","UNIT":"Wh"},"_id":"hm-rpc.0.KEQ0971587.2.ENERGY_COUNTER","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.sourceanalytix.0","user":"system.user.admin","ts":1701967931210}
                                    2023-12-08 18:53:09.199 - error: sourceanalytix.0 (946) Cannot handle calculations for hm-rpc.0.KEQ0971587.2.ENERGY_COUNTER, check log messages and adjust settings!
                                    2023-12-08 18:53:09.202 - error: sourceanalytix.0 (946) Initialization of hm-rpc.0.KEQ0971587.2.ENERGY_COUNTER failed, check warn messages !
                                    2023-12-08 18:53:09.203 - info: sourceanalytix.0 (946) Initialising "hm-rpc.0.LEQ1344854.2.ENERGY_COUNTER" | (3 of 12)
                                    2023-12-08 18:53:09.264 - error: sourceanalytix.0 (946) Check settings for hm-rpc.0.LEQ1344854.2.ENERGY_COUNTER ! Known valueAtDeviceReset : (53.9896) > known cumulative value (53.989599976) cannot proceed
                                    2023-12-08 18:53:09.266 - error: sourceanalytix.0 (946) Troubleshoot Data hm-rpc.0.LEQ1344854.2.ENERGY_COUNTER custom Data : {"type":"state","common":{"def":0,"type":"number","read":true,"write":false,"min":0,"max":838860.7,"unit":"Wh","name":"ZwStecker_Server-2.ENERGY_COUNTER","role":"value.power.consumption","custom":{"sql.0":{"enabled":true,"storageType":"","counter":false,"aliasId":"","debounceTime":0,"blockTime":0,"changesOnly":true,"changesRelogInterval":"86400","changesMinDelta":"0.01","ignoreBelowNumber":"","disableSkippedValueLogging":false,"retention":0,"customRetentionDuration":365,"maxLength":0,"enableDebugLogs":false,"debounce":100},"sourceanalytix.0":{"enabled":true,"selectedUnit":"Detect automatically","deviceResetLogicEnabled":true,"threshold":0.001,"start_day":48.4355,"start_week":41.325300000000006,"start_month":30.6427,"start_quarter":380.38259999999997,"start_year":0,"alias":"Server_Leistung_Analyse","selectedPrice":"Strombezug","costs":true,"consumption":true,"valueAtDeviceReset":53.9896,"valueAtDeviceInit":53.989599976,"cumulativeValue":48.4355}}},"native":{"CONTROL":"POWERMETER.ENERGY_COUNTER","DEFAULT":0,"FLAGS":1,"ID":"ENERGY_COUNTER","MAX":838860.7,"MIN":0,"OPERATIONS":5,"TAB_ORDER":0,"TYPE":"FLOAT","UNIT":"Wh"},"_id":"hm-rpc.0.LEQ1344854.2.ENERGY_COUNTER","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.sourceanalytix.0","user":"system.user.admin","ts":1701968924431}
                                    2023-12-08 18:53:09.267 - error: sourceanalytix.0 (946) Cannot handle calculations for hm-rpc.0.LEQ1344854.2.ENERGY_COUNTER, check log messages and adjust settings!
                                    2023-12-08 18:53:09.269 - error: sourceanalytix.0 (946) Initialization of hm-rpc.0.LEQ1344854.2.ENERGY_COUNTER failed, check warn messages !
                                    2023-12-08 18:53:09.270 - info: sourceanalytix.0 (946) Initialising "hm-rpc.0.MEQ0025548.1.GAS_ENERGY_COUNTER" | (4 of 12)
                                    2023-12-08 18:53:09.328 - error: sourceanalytix.0 (946) Check settings for hm-rpc.0.MEQ0025548.1.GAS_ENERGY_COUNTER ! Known valueAtDeviceReset : (2385.4) > known cumulative value (2385.399998) cannot proceed
                                    2023-12-08 18:53:09.329 - error: sourceanalytix.0 (946) Troubleshoot Data hm-rpc.0.MEQ0025548.1.GAS_ENERGY_COUNTER custom Data : {"type":"state","common":{"def":0,"type":"number","read":true,"write":false,"min":0,"max":2147483.644531,"unit":"m3","name":"GAS_Zaehler_1-Gas.GAS_ENERGY_COUNTER","custom":{"sql.0":{"enabled":true,"changesOnly":true,"debounce":"1200","retention":0,"changesRelogInterval":"86400","changesMinDelta":0.01,"aliasId":"","storageType":"","debounceTime":0,"blockTime":1200,"ignoreBelowNumber":"","disableSkippedValueLogging":false,"counter":false,"customRetentionDuration":365,"maxLength":10,"enableDebugLogs":false},"sourceanalytix.0":{"enabled":true,"selectedUnit":"m³","deviceResetLogicEnabled":true,"threshold":1,"start_day":2375.47,"start_week":2362.31,"start_month":2340.72,"start_quarter":2154.71,"start_year":1588,"alias":"Gas_Kosten_Analyse","selectedPrice":"Gas","costs":true,"consumption":true,"meter_values":true,"valueAtDeviceReset":2385.4,"valueAtDeviceInit":2385.399998,"cumulativeValue":2375.47}}},"native":{"CONTROL":"POWERMETER_IGL.GAS_ENERGY_COUNTER","DEFAULT":0,"FLAGS":1,"ID":"GAS_ENERGY_COUNTER","MAX":2147483.644531,"MIN":0,"OPERATIONS":5,"TAB_ORDER":0,"TYPE":"FLOAT","UNIT":"m3"},"_id":"hm-rpc.0.MEQ0025548.1.GAS_ENERGY_COUNTER","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.sourceanalytix.0","user":"system.user.admin","ts":1701967948852}
                                    2023-12-08 18:53:09.330 - error: sourceanalytix.0 (946) Cannot handle calculations for hm-rpc.0.MEQ0025548.1.GAS_ENERGY_COUNTER, check log messages and adjust settings!
                                    2023-12-08 18:53:09.332 - error: sourceanalytix.0 (946) Initialization of hm-rpc.0.MEQ0025548.1.GAS_ENERGY_COUNTER failed, check warn messages !
                                    2023-12-08 18:53:09.333 - info: sourceanalytix.0 (946) Initialising "hm-rpc.0.OEQ0070768.2.ENERGY_COUNTER" | (5 of 12)
                                    2023-12-08 18:53:09.396 - error: sourceanalytix.0 (946) Check settings for hm-rpc.0.OEQ0070768.2.ENERGY_COUNTER ! Known valueAtDeviceReset : (13.8524) > known cumulative value (13.852399997) cannot proceed
                                    2023-12-08 18:53:09.397 - error: sourceanalytix.0 (946) Troubleshoot Data hm-rpc.0.OEQ0070768.2.ENERGY_COUNTER custom Data : {"type":"state","common":{"def":0,"type":"number","read":true,"write":false,"min":0,"max":838860.699219,"unit":"Wh","name":"Klimatruhe-2-Klima.ENERGY_COUNTER","custom":{"sql.0":{"enabled":true,"changesOnly":true,"debounce":"1200","retention":0,"changesRelogInterval":"86400","changesMinDelta":0.01,"storageType":"","aliasId":"","debounceTime":0,"blockTime":1200,"ignoreBelowNumber":"","disableSkippedValueLogging":false,"counter":false,"customRetentionDuration":365,"maxLength":10,"enableDebugLogs":false},"sourceanalytix.0":{"enabled":true,"selectedUnit":"Detect automatically","deviceResetLogicEnabled":true,"threshold":0.001,"start_day":6.9262,"start_week":6.9262,"start_month":6.9262,"start_quarter":335.2113,"start_year":0,"alias":"Klima_Leistung_Analyse","selectedPrice":"Strombezug","costs":true,"consumption":true,"valueAtDeviceReset":13.8524,"valueAtDeviceInit":6.926199996999999,"cumulativeValue":6.9262}},"role":"value.power.consumption"},"native":{"CONTROL":"POWERMETER.ENERGY_COUNTER","DEFAULT":0,"FLAGS":1,"ID":"ENERGY_COUNTER","MAX":838860.699219,"MIN":0,"OPERATIONS":5,"TAB_ORDER":0,"TYPE":"FLOAT","UNIT":"Wh"},"_id":"hm-rpc.0.OEQ0070768.2.ENERGY_COUNTER","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.sourceanalytix.0","user":"system.user.admin","ts":1701968930074}
                                    2023-12-08 18:53:09.398 - error: sourceanalytix.0 (946) Cannot handle calculations for hm-rpc.0.OEQ0070768.2.ENERGY_COUNTER, check log messages and adjust settings!
                                    2023-12-08 18:53:09.398 - error: sourceanalytix.0 (946) Initialization of hm-rpc.0.OEQ0070768.2.ENERGY_COUNTER failed, check warn messages !
                                    2023-12-08 18:53:09.399 - info: sourceanalytix.0 (946) Initialising "hm-rpc.1.0001D3C990BF8F.6.ENERGY_COUNTER" | (6 of 12)
                                    2023-12-08 18:53:16.583 - info: sourceanalytix.0 (946) Initialization of hm-rpc.1.0001D3C990BF8F.6.ENERGY_COUNTER successfully
                                    2023-12-08 18:53:16.585 - info: sourceanalytix.0 (946) Initialising "hm-rpc.1.0001D3C99C6758.6.ENERGY_COUNTER" | (7 of 12)
                                    2023-12-08 18:53:23.519 - info: sourceanalytix.0 (946) Initialization of hm-rpc.1.0001D3C99C6758.6.ENERGY_COUNTER successfully
                                    2023-12-08 18:53:23.520 - info: sourceanalytix.0 (946) Initialising "hm-rpc.1.0001D70994EA29.6.ENERGY_COUNTER" | (8 of 12)
                                    2023-12-08 18:53:30.298 - info: sourceanalytix.0 (946) Initialization of hm-rpc.1.0001D70994EA29.6.ENERGY_COUNTER successfully
                                    2023-12-08 18:53:30.298 - info: sourceanalytix.0 (946) Initialising "hm-rpc.1.0001D70994EA37.6.ENERGY_COUNTER" | (9 of 12)
                                      badsnoopy667
                                      #2075
                                      @crunchip
                                      Danke für den Hinweis.
                                      Falls noch jemand sowas vorhat:
                                      Ich hab's jetzt so gelöst, dass ich einen neuen Datenpunkt "Netzbezug_dynamisch" angelegt habe. Diesen beschreibe ich mit "Netzbezug * (VariablerPreis / FixerPreis)" wobei FixerPreis mein aktueller Strompreis ist und der variable halt der von Tibber/Awattar.
                                      Damit stimmt zwar bei diesem Datenpunkt die kWh Angabe nicht, aber der Preis den Sourceanalytix berechnet sollte dem des dynamischen Tarifs entsprechen. Schaun wir mal, ob das klappt.
                                      • B badsnoopy667
                                        @crunchip
                                        Laser
                                        #2076
                                        Ich habe das Problem, daß Sourceanalytix 4.0.15 nicht mehr richtig zählt. Mit Influx ausgewerteter Datenpunkt:
                                        SA zeigt aber das an (auch den gestrigen Wert mußte ich manuell eintragen):
                                        Dienstag hätten es auch um die 0,5 kWh sein müssen. Täglich die Werte kontrollieren und korrigieren- das ist auf Dauer Mis...
                                        • L Laser
                                          Laser
                                          #2077
                                          @Dutchman und wieder ist ein Tag vergangen, es wird immer noch nicht gezählt. Warum wird gerade dieser eine Datenpunkt nicht gezählt?
                                          EDIT: habe jetzt die Einheiten von kWh in Wh verändert und wieder zurück. Können die Einheiten da irgend etwas beeinflussen?
                                          EDIT 1 Tag später: Es funktioniert jetzt wieder!
