  3. Einsteigerfragen
  4. ioBroker auf neuer Maschine aufgesetzt und Adapter Probleme
267 Beiträge 8 Kommentatoren 70.1k Aufrufe 8 Beobachtet
  • G Gismoh
    ja, amd64 (ble lief ja auch bereits auf einer neuinstallation - ohne Backup)
    Alt: ARMv7 Processor rev 3 (v7l), Node.js v18.18.2, NPM 9.8.1
    Neu: Architektur x64, Node.js v18.18.2, NPM 9.8.1
    Backup ist auf Neuinstallation wieder eingespielt - aber noch nichts weiter gemacht.
    crunchipC
    crunchipC
    Developer Global Moderator Most Active Forum Testing
    #251
    @gismoh dann nun die Ausgabe von
    iob add ble --debug
    G 2 Antworten Letzte Antwort
      iob add ble --debug
      G
      G
      Gismoh
      schrieb am zuletzt editiert von Gismoh
      #252
      @crunchip
      Sorry, erst nun, haben noch Besuch ;)
      idash@ioBrokerVM:~$ iob add ble --debug
      NPM version: 9.8.1
      Installing iobroker.ble@0.13.4... (System call)
      npm ERR! code 1
      npm ERR! path /opt/iobroker/node_modules/@abandonware/noble
      npm ERR! command failed
      npm ERR! command sh -c node-gyp-build
      npm ERR! gyp info it worked if it ends with ok
      npm ERR! gyp info using node-gyp@7.1.2
      npm ERR! gyp info using node@18.18.2 | linux | x64
      npm ERR! gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3"
      npm ERR! (node:5847) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.
      npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)
      npm ERR! gyp info spawn /usr/bin/python3
      npm ERR! gyp info spawn args [
      npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',
      npm ERR! gyp info spawn args   'binding.gyp',
      npm ERR! gyp info spawn args   '-f',
      npm ERR! gyp info spawn args   'make',
      npm ERR! gyp info spawn args   '-I',
      npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/@abandonware/noble/build/config.gypi',
      npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/addon.gypi',
      npm ERR! gyp info spawn args   '/home/iobroker/.cache/node-gyp/18.18.2/include/node/common.gypi',
      npm ERR! gyp info spawn args   '-Dlibrary=shared_library',
      npm ERR! gyp info spawn args   '-Dvisibility=default',
      npm ERR! gyp info spawn args   '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.18.2',
      npm ERR! gyp info spawn args   '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',
      npm ERR! gyp info spawn args   '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.18.2/<(target_arch)/node.lib',
      npm ERR! gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/node_modules/@abandonware/noble',
      npm ERR! gyp info spawn args   '-Dnode_engine=v8',
      npm ERR! gyp info spawn args   '--depth=.',
      npm ERR! gyp info spawn args   '--no-parallel',
      npm ERR! gyp info spawn args   '--generator-output',
      npm ERR! gyp info spawn args   'build',
      npm ERR! gyp info spawn args   '-Goutput_dir=.'
      npm ERR! gyp info spawn args ]
      npm ERR! Traceback (most recent call last):
      npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>
      npm ERR!     sys.exit(gyp.script_main())
      npm ERR!              ^^^^^^^^^^^^^^^^^
      npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_main
      npm ERR!     return main(sys.argv[1:])
      npm ERR!            ^^^^^^^^^^^^^^^^^^
      npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in main
      npm ERR!     return gyp_main(args)
      npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_main
      npm ERR!     [generator, flat_list, targets, data] = Load(
      npm ERR!                                             ^^^^^
      npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Load
      npm ERR!     result = gyp.input.Load(
      npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Load
      npm ERR!     LoadTargetBuildFile(
      npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFile
      npm ERR!     build_file_data = LoadOneBuildFile(
      npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFile
      npm ERR!     build_file_contents = open(build_file_path, "rU").read()
      npm ERR!                           ^^^^^^^^^^^^^^^^^^^^^^^^^^^
      npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gyp
      npm ERR! gyp ERR! configure error
      npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1
      npm ERR! gyp ERR! stack     at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)
      npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:517:28)
      npm ERR! gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:292:12)
      npm ERR! gyp ERR! System Linux 6.1.0-13-amd64
      npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/@abandonware/noble
      npm ERR! gyp ERR! node -v v18.18.2
      npm ERR! gyp ERR! node-gyp -v v7.1.2
      npm ERR! gyp ERR! not ok
      npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-11T22_12_49_072Z-debug-0.log
      npm ERR! code 1
      npm ERR!                                             ^^^^^
      host.ioBrokerVM Cannot install iobroker.ble@0.13.4: 1
      Sieht irgendwie bekannt aus ;(
      ioBroker auf: Lenovo ThinkCentre M910Q Tiny i5-7500T 16 GB mit proxmox in VM (Bookworm)
        iob add ble --debug
        G
        G
        Gismoh
        #253
        @crunchip
        Auch hier:
        idash@ioBrokerVM:~$ sudo nano /opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py
        Verzeichnis „/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp“ existiert nicht
        in
        /usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/input.py
        gibt es auch nun die entsprechende Zeile nicht.
        • G Gismoh
          @crunchip
          Auch hier:
          in
          crunchipC
          crunchipC
          #254
          @gismoh ich hab keine Ahnung was da bei dir falsch ist bzw aus deinem backup mitgeschleift wird.
          letzte Idee wäre, auf deiner neuen Installation, so wie sie jetzt ist, nodejs de/installieren und anschließend wenn der iobroker nach dem Start fertig gebaut ist, es nochmal mit dem ble Adapter probieren
          https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian?_=1699766871988
          G 1 Antwort Letzte Antwort
            G
            G
            Gismoh
            #255
            @crunchip
            Okay, aber besten Dank für deine Unterstützung.
            Werde dies dann noch ausprobieren.
            Ansonsten werde ich noch versuchen die alten "Daten" irgendwie manuell zu übertragen.
            Eine andere Möglichkeit eines Backups außer mit "BackItUp" scheint es ja leider nicht zu geben.
            • G Gismoh
              @crunchip
              crunchipC
              crunchipC
              #256
              @gismoh sagte in ioBroker auf neuer Maschine aufgesetzt und Adapter Probleme:
              andere Möglichkeit gäbe es, macht aber keinen Sinn, wenn dein "Altsystem schon ne Macke hat"
                G
                G
                Gismoh
                #257
                @crunchip
                Auf dem "Altsystem" läuft es zumindest so, das ich laut "BackItUp" jeden Tag ein erfolgreiches Backup erstellt wird (lt. BackItUp) , und habe ansonsten auch keine Probleme, welche mir als Anwender "Komisch" vorkommen/auffallen.
                Ebenfalls das ble läuft dort;
                auf dem Neusystem erst nach der Einspielung des Backups nicht.
                Daher mein Gedanke, das es mit der Backup-Einspielung zusammenhängt, denn das Backup wurde ja erfolgreich erstellt, und zerschießt dann den ble auf dem Neustsytem - selbst wenn dieser gar nicht "Bestandteil" des Backups war - weil vor der Backerstellung deinstalliert.
                Auch im "Altsystem" kann ich ble deinstallieren und wieder erfolgreich erneut installieren.
                Ziehe auch nicht wegen mir bekannten Fehlern um, sondern weil das alte System mit den vielen Aufgaben/Geräten und Adaptern mir nicht mehr schnell genug ist/zu langsam wurde.
                Gibt es denn einen anderen Backup Adapter/Methode, welche nur die Daten und ggf. Konfiguration der alten Maschine sichert und widerherstellen kann?
                Oder anders, wenn es wirklich an meinem Alt-System liegt (Obwohl Backitup sagt, das die Sicherungen erfolgreich waren) könnte man mir dort weiterhelfen, das man dieses "Geraderückt" um dann erfolgreich umziehen zu können?
                • G Gismoh
                  @crunchip
                  Thomas BraunT
                  Thomas BraunT
                  #258
                  @gismoh
                  Ich würde den ble im Alt-System komplett raus werfen, schauen dass der auch nicht mehr im npm-tree auftaucht, dann davon ein Backup ziehen, umziehen und im neuen System dann den ble frisch installieren.
                    @gismoh
                    G
                    G
                    Gismoh
                    #259
                    wie kann ich das überprüfen, ob der ble nach deinstallation noch im "npm-tree" auftaucht.
                    Und wie ist er dann ggf. dort noch weiter zu entfernen?
                    • G Gismoh
                      Thomas BraunT
                      Thomas BraunT
                      #260
                      @gismoh
                      cd /opt/iobroker
                      npm ls
                      anschauen.
                        @gismoh
                        cd /opt/iobroker
                        npm ls
                        anschauen.
                        G
                        G
                        Gismoh
                        #261
                        Merci - setze mich nach dem Mittag noch mal ran.
                        Aktuell ziehe noch mal eine "Full-" Sicherung (SD-Karte klonen) vom alten System.
                          @gismoh
                          cd /opt/iobroker
                          npm ls
                          anschauen.
                          G
                          G
                          Gismoh
                          #262
                          Bin gerade dran etwas anderes zu probieren, kann ich gerne später noch etwas zu schreiben.
                          Da ich aber gerade Hilfe von einem Freund bekomme, erst mal eine kurze Frage:
                          Wo sind die Objekte gespeichert? Also in welchem Ordner/Datei?
                          Speziell vermisse ich Unterordner von Javascript.0
                          in der neuen Maschine.
                          Weis nicht ob mir noch andere Fehlen, aber diese sind mir gerade aufgefallen, das ich die nun nicht auf der neuen Installation habe.
                          (Ansonsten scheint einiges aktuell zu laufen, auch der ble - müssen aber auch noch was tun ;) )
                          Besten Dank schon einmal.
                          • G Gismoh
                            #263
                            die Objekte in der jsonl Datenbank
                            oder neinst du due Werte der Objekte?
                              G
                              G
                              Gismoh
                              #264
                              Bildlich gesprochen ist evtl. besser ;)
                              Meine hier:
                              hatte ich noch mindestens einen weiteren Unterordner gehabt, welcher nun "verschwunden" ist.
                              Nachtrag:
                              Erhalte so z.B. diese Meldung:
                              javascript.0
                              2023-11-12 18:24:03.809	warn	State "javascript.0.Eigene_DP.Offset.Luftfeuchtigkeit.Kueche-WZ-Grad" not found
                              • G Gismoh
                                Meine hier:
                                Nachtrag:
                                javascript.0
                                #265
                                @gismoh wie war der angelegt?
                                ggf. damals mit einer nicht validen Methode, die zu einem DP ohne Objekt geführt hat?
                                heute ist da dann wirklich kein Objekt.
                                Wenn es so war, kannst du manuell das Verzeichnis neu anlegen und der darin enthaltene DP taucht aus dem Nirwana wieder auf.
                                  G
                                  G
                                  Gismoh
                                  #266
                                  @all
                                  besten Dank an euch.
                                  ioBroker läuft nun bereits einige Stunden auf der neuen Maschine, incl. Influx, Grafana und Deconz
                                  (und natürlich ble 😁 )
                                  Alle Updates sind drin, und freue mich über das schnellere System.
                                  Jetzt kann es weitergehen, denn zwei Freunde von mir haben sich den selben Mini-PC geholt und betreiben dann auch bald aktiv den ioBroker - habe sie vermutlich mit dem Smart-Home ein wenig angesteckt.
                                  Sehr positiv, denn einer von beiden ist Programmierer ;)
                                  Haben die Daten "händisch", ohne Backup wieder eingespielt.
                                  Nun müssen "nur" noch die anderen PRG´s, welche noch auf dem Raspi laufen, aber losgelöst vom ioBroker sind, nachgezogen werden.
                                  • G Gismoh
                                    @all
                                    crunchipC
                                    crunchipC
                                    #267
                                    Also stumpf den Ordner opt/iobroker reinkopiert?
                                    83.8k
