  3. Einsteigerfragen
  4. ioBroker auf neuer Maschine aufgesetzt und Adapter Probleme
    apollon77A
267 Beiträge 8 Kommentatoren 75.6k Aufrufe 8 Beobachtet
  • G Gismoh
    idash@ioBrokerVM:/home/iobroker$ sudo -u iobroker npm cache clear --force
    npm WARN using --force Recommended protections disabled.
    idash@ioBrokerVM:/home/iobroker$ cd
    idash@ioBrokerVM:~$ iobroker upgrade ble@0.13.4
    Adapter "ble"            is not installed.
    Thomas BraunT
    Thomas BraunT
    #112
    @gismoh sagte in ioBroker auf neuer Maschine aufgesetzt und Adapter Probleme:
    iobroker add ble@0.13.4 --debug
    G 1 Antwort Letzte Antwort
      G
      G
      Gismoh
      #113
      idash@ioBrokerVM:~$ iobroker add ble@0.13.4 --debug
      NPM version: 9.8.1
      Installing iobroker.ble@0.13.4... (System call)
      npm ERR! code 1
      npm ERR! path /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble
      npm ERR! command failed
      npm ERR! command sh -c node-gyp-build
      npm ERR! gyp info it worked if it ends with ok
      npm ERR! gyp info using node-gyp@7.1.2
      npm ERR! gyp info using node@18.18.2 | linux | x64
      npm ERR! gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3"
      npm ERR! (node:6399) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.
      npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)
      npm ERR! gyp info spawn /usr/bin/python3
      npm ERR! gyp info spawn args [
      npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',
      npm ERR! gyp info spawn args   'binding.gyp',
      npm ERR! gyp info spawn args   '-f',
      npm ERR! gyp info spawn args   'make',
      npm ERR! gyp info spawn args   '-I',
      npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble/build/config.gypi',
      npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/addon.gypi',
      npm ERR! gyp info spawn args   '/home/iobroker/.cache/node-gyp/18.18.2/include/node/common.gypi',
      npm ERR! gyp info spawn args   '-Dlibrary=shared_library',
      npm ERR! gyp info spawn args   '-Dvisibility=default',
      npm ERR! gyp info spawn args   '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.18.2',
      npm ERR! gyp info spawn args   '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',
      npm ERR! gyp info spawn args   '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.18.2/<(target_arch)/node.lib',
      npm ERR! gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble',
      npm ERR! gyp info spawn args   '-Dnode_engine=v8',
      npm ERR! gyp info spawn args   '--depth=.',
      npm ERR! gyp info spawn args   '--no-parallel',
      npm ERR! gyp info spawn args   '--generator-output',
      npm ERR! gyp info spawn args   'build',
      npm ERR! gyp info spawn args   '-Goutput_dir=.'
      npm ERR! gyp info spawn args ]
      npm ERR! Traceback (most recent call last):
      npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>
      npm ERR!     sys.exit(gyp.script_main())
      npm ERR!              ^^^^^^^^^^^^^^^^^
      npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_main
      npm ERR!     return main(sys.argv[1:])
      npm ERR!            ^^^^^^^^^^^^^^^^^^
      npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in main
      npm ERR!     return gyp_main(args)
      npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_main
      npm ERR!     [generator, flat_list, targets, data] = Load(
      npm ERR!                                             ^^^^^
      npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Load
      npm ERR!     result = gyp.input.Load(
      npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Load
      npm ERR!     LoadTargetBuildFile(
      npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFile
      npm ERR!     build_file_data = LoadOneBuildFile(
      npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFile
      npm ERR!     build_file_contents = open(build_file_path, "rU").read()
      npm ERR!                           ^^^^^^^^^^^^^^^^^^^^^^^^^^^
      npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gyp
      npm ERR! gyp ERR! configure error
      npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1
      npm ERR! gyp ERR! stack     at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)
      npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:517:28)
      npm ERR! gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:292:12)
      npm ERR! gyp ERR! System Linux 6.1.0-13-amd64
      npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble
      npm ERR! gyp ERR! node -v v18.18.2
      npm ERR! gyp ERR! node-gyp -v v7.1.2
      npm ERR! gyp ERR! not ok
      npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-08T22_56_29_824Z-debug-0.log
      npm ERR! code 1
      npm ERR!                                             ^^^^^
      host.ioBrokerVM Cannot install iobroker.ble@0.13.4: 1
      ioBroker auf: Lenovo ThinkCentre M910Q Tiny i5-7500T 16 GB mit proxmox in VM (Bookworm)
      • G Gismoh
        NPM version: 9.8.1
        npm ERR! code 1
        npm ERR!                                             ^^^^^
        npm ERR! code 1
        npm ERR!                                             ^^^^^
        Thomas BraunT
        Thomas BraunT
        #114
        @gismoh
        sudo apt update
        apt policy node-gyp
        G 2 Antworten Letzte Antwort
          @gismoh
          sudo apt update
          apt policy node-gyp
          G
          G
          Gismoh
          #115
          idash@ioBrokerVM:~$ sudo apt update
          OK:1 http://deb.debian.org/debian bookworm InRelease
          OK:2 http://security.debian.org/debian-security bookworm-security InRelease
          OK:3 http://deb.debian.org/debian bookworm-updates InRelease
          OK:4 https://repos.influxdata.com/debian stable InRelease
          OK:5 https://deb.nodesource.com/node_18.x nodistro InRelease
          Alle Pakete sind aktuell.
          idash@ioBrokerVM:~$ apt policy node-gyp
          node-gyp:
            Installiert:           (keine)
            Installationskandidat: 9.3.0-2
            Versionstabelle:
               9.3.0-2 500
                  500 http://deb.debian.org/debian bookworm/main amd64 Packages
            @gismoh
            sudo apt update
            apt policy node-gyp
            G
            G
            Gismoh
            #116
            soll ich?:
            sudo npm install -g node-gyp
            • G Gismoh
              soll ich?:
              Thomas BraunT
              Thomas BraunT
              #117
              NEIN!
              Hast du das in der Vergangenheit schon mal gemacht?
              Oder mit 'npm' schon mal gemacht?
                NEIN!
                G
                G
                Gismoh
                schrieb am zuletzt editiert von Gismoh
                #118
                nein, hatte erst gerade eben danach gesucht
                npm vermutlich auch nicht, es sei denn es ist mir weiter oben (HEUTE) so angeraten wurden - meine aber nicht. Habe dieses Backup (der VM) erst heute eingespielt und dann das Backup (iobroker) aufgespielt.
                • G Gismoh
                  Thomas BraunT
                  Thomas BraunT
                  #119
                  @gismoh
                  Vergiss irgendwelche npm-Befehle, die ein -g beinhalten.
                  Irgendwo zieht die Kiste ein altes node-gyp her.
                  type -p node-gyp
                    @gismoh
                    type -p node-gyp
                    G
                    G
                    Gismoh
                    #120
                    kam keine Ausgabe:
                    idash@ioBrokerVM:~$ type -p node-gyp
                    idash@ioBrokerVM:~$
                    Was macht das backitup nur, das es mir den ble zerschießt?
                    Davor hat es ja funktioniert.
                    • G Gismoh
                      kam keine Ausgabe:
                      idash@ioBrokerVM:~$
                      Thomas BraunT
                      Thomas BraunT
                      #121
                      Nichts.
                      iobroker rebuild iobroker.ble
                        Nichts.
                        G
                        G
                        Gismoh
                        #122
                        idash@ioBrokerVM:~$ iobroker rebuild iobroker.ble
                        Rebuilding native module "iobroker.ble" ...
                        rebuilt dependencies successfully
                        Rebuilding native modules done
                        • G Gismoh
                          Thomas BraunT
                          Thomas BraunT
                          #123
                          @gismoh
                          iob list adapters
                            @gismoh
                            iob list adapters
                            G
                            G
                            Gismoh
                            #124
                            idash@ioBrokerVM:~$ iob list adapters
                            system.adapter.accuweather             : accuweather    - v1.1.4
                            system.adapter.admin                   : admin          - v6.3.5
                            system.adapter.alarm                   : alarm          - v3.3.13
                            system.adapter.alexa2                  : alexa2         - v3.23.2
                            system.adapter.asuswrt                 : asuswrt        - v1.0.1
                            system.adapter.backitup                : backitup       - v2.8.1
                            system.adapter.broadlink2              : broadlink2     - v2.0.3
                            system.adapter.cloud                   : cloud          - v4.0.4
                            system.adapter.daikin-cloud            : daikin-cloud   - v0.3.0
                            system.adapter.daswetter               : daswetter      - v3.1.10
                            system.adapter.deconz                  : deconz         - v1.3.21
                            system.adapter.device-reminder         : device-reminder - v1.2.9
                            system.adapter.discovery               : discovery      - v3.1.0
                            system.adapter.ecovacs-deebot          : ecovacs-deebot - v1.4.13
                            system.adapter.enigma2                 : enigma2        - v2.0.3
                            system.adapter.fb-checkpresence        : fb-checkpresence - v1.2.2
                            system.adapter.fiat                    : fiat           - v0.0.8
                            system.adapter.flot                    : flot           - v1.12.0
                            system.adapter.fritzdect               : fritzdect      - v2.1.11
                            system.adapter.fullybrowser            : fullybrowser   - v2.1.2
                            system.adapter.go-e                    : go-e           - v1.0.27
                            system.adapter.ham                     : ham            - v5.3.1
                            system.adapter.harmony                 : harmony        - v1.2.2
                            system.adapter.hue                     : hue            - v3.10.0
                            system.adapter.hue-extended            : hue-extended   - v2.0.0
                            system.adapter.icons-mfd-svg           : icons-mfd-svg  - v1.1.0
                            system.adapter.influxdb                : influxdb       - v3.2.0
                            system.adapter.info                    : info           - v2.0.0
                            system.adapter.iot                     : iot            - v1.14.5
                            system.adapter.javascript              : javascript     - v7.1.4
                            system.adapter.meross                  : meross         - v1.15.1
                            system.adapter.mihome-vacuum           : mihome-vacuum  - v4.0.0
                            system.adapter.mobile                  : mobile         - v1.0.1
                            system.adapter.openweathermap          : openweathermap - v0.3.9
                            system.adapter.parser                  : parser         - v1.3.2
                            system.adapter.pi-hole                 : pi-hole        - v1.3.6
                            system.adapter.ping                    : ping           - v1.4.12
                            system.adapter.pushover                : pushover       - v3.0.3
                            system.adapter.pvforecast              : pvforecast     - v2.8.1
                            system.adapter.radar2                  : radar2         - v2.0.7
                            system.adapter.shelly                  : shelly         - v6.4.1
                            system.adapter.simple-api              : simple-api     - v2.7.2
                            system.adapter.smartcontrol            : smartcontrol   - v2.0.1
                            system.adapter.socketio                : socketio       - v6.5.5
                            system.adapter.sonoff                  : sonoff         - v2.5.3
                            system.adapter.tado                    : tado           - v0.4.9
                            system.adapter.telegram                : telegram       - v1.16.0
                            system.adapter.tibberlink              : tibberlink     - v1.0.0
                            system.adapter.tr-064                  : tr-064         - v4.2.4
                            system.adapter.vis                     : vis            - v1.4.16
                            system.adapter.vis-hqwidgets           : vis-hqwidgets  - v1.4.0
                            system.adapter.vis-jqui-mfd            : vis-jqui-mfd   - v1.0.12
                            system.adapter.vis-material-advanced   : vis-material-advanced - v1.7.4
                            system.adapter.vis-metro               : vis-metro      - v1.2.0
                            system.adapter.vis-timeandweather      : vis-timeandweather - v1.2.2
                            system.adapter.weatherunderground      : weatherunderground - v3.6.0
                            system.adapter.web                     : web            - v4.3.0
                            system.adapter.worx                    : worx           - v2.3.2
                            system.adapter.ws                      : ws             - v2.5.5
                            • G Gismoh
                              Thomas BraunT
                              Thomas BraunT
                              #125
                              @gismoh
                              iobroker install ble
                                @gismoh
                                G
                                G
                                Gismoh
                                #126
                                idash@ioBrokerVM:~$ iobroker install ble
                                NPM version: 9.8.1
                                npm ERR! code 1
                                npm ERR! (node:1950) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.
                                npm ERR!                                             ^^^^^
                                npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-08T23_26_40_665Z-debug-0.log
                                • G Gismoh
                                  NPM version: 9.8.1
                                  npm ERR! code 1
                                  npm ERR!                                             ^^^^^
                                  Thomas BraunT
                                  Thomas BraunT
                                  #127
                                  Ich muss lagsam mal in die Heia...
                                  nano /opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py
                                  gibt es nicht?
                                    gibt es nicht?
                                    G
                                    G
                                    Gismoh
                                    #128
                                    leider nicht:
                                    Verzeichnis „/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp“ existiert nicht
                                    Dann wünsch ich dir eine gute Nacht, und besten Dank!
                                    • G Gismoh
                                      leider nicht:
                                      G
                                      G
                                      Gismoh
                                      #129
                                      @all
                                      Besten Dank an alle, welche sich hier als helfende Hand mit eingebunden haben! 👏 💐
                                      Habe mir nun auch noch ein USB-Bluetooth Modul bestellt - keine Ahnung ob es damit evtl. besser geht.
                                      Was mich immer nur wundert, das die "Erstinstallation" incl. BLE geklappt hat, also der BLE grün war und auch Geräte gefunden hat. Erst nach Backup Einspielung verweigerte der ble seinen Dienst.
                                      Würde mich freuen, wenn noch eine Lösung gefunden werden könnte ;)
                                      • G Gismoh
                                        @all
                                        crunchipC
                                        crunchipC
                                        Developer Global Moderator Most Active Forum Testing
                                        #130
                                        letzte Variante,
                                        den Ble auf dem alten System deinstallieren, dann ein backup erstellen, dieses auf deinen neuen System spielen und danach dann den ble installieren.
                                          letzte Variante,
                                          G
                                          G
                                          Gismoh
                                          #131
                                          @crunchip
                                          Guten Morgen,
                                          kann ich gerne mache, mit einer "rest-Hoffnung".
                                          Allerdings sehe ich selber als Laie keinen großen unterschied zur Vorgehensweise von gestern,
                                          dort hatte ich ja auf dem alten System den ble entfernt -
                                          und auf dem neuen System den ble belassen. Leider wurde der bestehende ble auf dem neuen System mit dem Backup entfernt.
                                          Werde ich aber gerne ausprobieren, mache vorher noch einer Sicherung der jetzigen VM - für den Fall das evtl. jemand dort noch mal ansetzen mag -und kann ja nicht schaden.
                                          Spiele dann nun wieder die Sicherung von der Erstinstallation auf der neuen Maschine ein, wo ioBroker frisch installiert wurde, deinstalliere außer admin und backitup die Adapter und spiele dann das gestrige Backup von der alten Maschine (Raspi) ein, wo ich das ble deinstalliert hatte.
                                          Melde mich dann nach "Verzug" wieder ;)
                                          84.0k
