  3. Einsteigerfragen
  4. ioBroker auf neuer Maschine aufgesetzt und Adapter Probleme
    apollon77A
267 Beiträge 8 Kommentatoren 77.4k Aufrufe 8 Beobachtet
    @gismoh
    sudo -u iobroker rm -rf /home/iobroker/.npm/_cacache/tmp
    G
    G
    Gismoh
    #111
    idash@ioBrokerVM:/home/iobroker$ sudo -u iobroker npm cache clear --force
    npm WARN using --force Recommended protections disabled.
    idash@ioBrokerVM:/home/iobroker$ cd
    idash@ioBrokerVM:~$ iobroker upgrade ble@0.13.4
    Adapter "ble"            is not installed.
    ioBroker auf: Lenovo ThinkCentre M910Q Tiny i5-7500T 16 GB mit proxmox in VM (Bookworm)
    • G Gismoh
      Thomas BraunT
      Thomas BraunT
      Most Active Developer
      #112
      @gismoh sagte in ioBroker auf neuer Maschine aufgesetzt und Adapter Probleme:
      iobroker add ble@0.13.4 --debug
      G 1 Antwort Letzte Antwort
        G
        G
        Gismoh
        #113
        idash@ioBrokerVM:~$ iobroker add ble@0.13.4 --debug
        NPM version: 9.8.1
        Installing iobroker.ble@0.13.4... (System call)
        npm ERR! code 1
        npm ERR! path /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble
        npm ERR! command failed
        npm ERR! command sh -c node-gyp-build
        npm ERR! gyp info it worked if it ends with ok
        npm ERR! gyp info using node-gyp@7.1.2
        npm ERR! gyp info using node@18.18.2 | linux | x64
        npm ERR! gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3"
        npm ERR! (node:6399) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.
        npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)
        npm ERR! gyp info spawn /usr/bin/python3
        npm ERR! gyp info spawn args [
        npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',
        npm ERR! gyp info spawn args   'binding.gyp',
        npm ERR! gyp info spawn args   '-f',
        npm ERR! gyp info spawn args   'make',
        npm ERR! gyp info spawn args   '-I',
        npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble/build/config.gypi',
        npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/addon.gypi',
        npm ERR! gyp info spawn args   '/home/iobroker/.cache/node-gyp/18.18.2/include/node/common.gypi',
        npm ERR! gyp info spawn args   '-Dlibrary=shared_library',
        npm ERR! gyp info spawn args   '-Dvisibility=default',
        npm ERR! gyp info spawn args   '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.18.2',
        npm ERR! gyp info spawn args   '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',
        npm ERR! gyp info spawn args   '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.18.2/<(target_arch)/node.lib',
        npm ERR! gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble',
        npm ERR! gyp info spawn args   '-Dnode_engine=v8',
        npm ERR! gyp info spawn args   '--depth=.',
        npm ERR! gyp info spawn args   '--no-parallel',
        npm ERR! gyp info spawn args   '--generator-output',
        npm ERR! gyp info spawn args   'build',
        npm ERR! gyp info spawn args   '-Goutput_dir=.'
        npm ERR! gyp info spawn args ]
        npm ERR! Traceback (most recent call last):
        npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>
        npm ERR!     sys.exit(gyp.script_main())
        npm ERR!              ^^^^^^^^^^^^^^^^^
        npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_main
        npm ERR!     return main(sys.argv[1:])
        npm ERR!            ^^^^^^^^^^^^^^^^^^
        npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in main
        npm ERR!     return gyp_main(args)
        npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_main
        npm ERR!     [generator, flat_list, targets, data] = Load(
        npm ERR!                                             ^^^^^
        npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Load
        npm ERR!     result = gyp.input.Load(
        npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Load
        npm ERR!     LoadTargetBuildFile(
        npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFile
        npm ERR!     build_file_data = LoadOneBuildFile(
        npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFile
        npm ERR!     build_file_contents = open(build_file_path, "rU").read()
        npm ERR!                           ^^^^^^^^^^^^^^^^^^^^^^^^^^^
        npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gyp
        npm ERR! gyp ERR! configure error
        npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1
        npm ERR! gyp ERR! stack     at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)
        npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:517:28)
        npm ERR! gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:292:12)
        npm ERR! gyp ERR! System Linux 6.1.0-13-amd64
        npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
        npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble
        npm ERR! gyp ERR! node -v v18.18.2
        npm ERR! gyp ERR! node-gyp -v v7.1.2
        npm ERR! gyp ERR! not ok
        npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-08T22_56_29_824Z-debug-0.log
        npm ERR! code 1
        npm ERR!                                             ^^^^^
        host.ioBrokerVM Cannot install iobroker.ble@0.13.4: 1
        • G Gismoh
          NPM version: 9.8.1
          npm ERR! code 1
          npm ERR!                                             ^^^^^
          npm ERR! code 1
          npm ERR!                                             ^^^^^
          Thomas BraunT
          Thomas BraunT
          #114
          @gismoh
          sudo apt update
          apt policy node-gyp
          G 2 Antworten Letzte Antwort
            @gismoh
            sudo apt update
            apt policy node-gyp
            G
            G
            Gismoh
            #115
            idash@ioBrokerVM:~$ sudo apt update
            OK:1 http://deb.debian.org/debian bookworm InRelease
            OK:2 http://security.debian.org/debian-security bookworm-security InRelease
            OK:3 http://deb.debian.org/debian bookworm-updates InRelease
            OK:4 https://repos.influxdata.com/debian stable InRelease
            OK:5 https://deb.nodesource.com/node_18.x nodistro InRelease
            Alle Pakete sind aktuell.
            idash@ioBrokerVM:~$ apt policy node-gyp
            node-gyp:
              Installiert:           (keine)
              Installationskandidat: 9.3.0-2
              Versionstabelle:
                 9.3.0-2 500
                    500 http://deb.debian.org/debian bookworm/main amd64 Packages
              @gismoh
              sudo apt update
              apt policy node-gyp
              G
              G
              Gismoh
              #116
              soll ich?:
              sudo npm install -g node-gyp
              • G Gismoh
                soll ich?:
                Thomas BraunT
                Thomas BraunT
                #117
                NEIN!
                Hast du das in der Vergangenheit schon mal gemacht?
                Oder mit 'npm' schon mal gemacht?
                  NEIN!
                  G
                  G
                  Gismoh
                  schrieb am zuletzt editiert von Gismoh
                  #118
                  nein, hatte erst gerade eben danach gesucht
                  npm vermutlich auch nicht, es sei denn es ist mir weiter oben (HEUTE) so angeraten wurden - meine aber nicht. Habe dieses Backup (der VM) erst heute eingespielt und dann das Backup (iobroker) aufgespielt.
                  • G Gismoh
                    Thomas BraunT
                    Thomas BraunT
                    #119
                    @gismoh
                    Vergiss irgendwelche npm-Befehle, die ein -g beinhalten.
                    Irgendwo zieht die Kiste ein altes node-gyp her.
                    type -p node-gyp
                      @gismoh
                      type -p node-gyp
                      G
                      G
                      Gismoh
                      #120
                      kam keine Ausgabe:
                      idash@ioBrokerVM:~$ type -p node-gyp
                      idash@ioBrokerVM:~$
                      Was macht das backitup nur, das es mir den ble zerschießt?
                      Davor hat es ja funktioniert.
                      • G Gismoh
                        kam keine Ausgabe:
                        idash@ioBrokerVM:~$
                        Thomas BraunT
                        Thomas BraunT
                        #121
                        Nichts.
                        iobroker rebuild iobroker.ble
                          Nichts.
                          G
                          G
                          Gismoh
                          #122
                          idash@ioBrokerVM:~$ iobroker rebuild iobroker.ble
                          Rebuilding native module "iobroker.ble" ...
                          rebuilt dependencies successfully
                          Rebuilding native modules done
                          • G Gismoh
                            Thomas BraunT
                            Thomas BraunT
                            #123
                            @gismoh
                            iob list adapters
                              @gismoh
                              iob list adapters
                              G
                              G
                              Gismoh
                              #124
                              idash@ioBrokerVM:~$ iob list adapters
                              system.adapter.accuweather             : accuweather    - v1.1.4
                              system.adapter.admin                   : admin          - v6.3.5
                              system.adapter.alarm                   : alarm          - v3.3.13
                              system.adapter.alexa2                  : alexa2         - v3.23.2
                              system.adapter.asuswrt                 : asuswrt        - v1.0.1
                              system.adapter.backitup                : backitup       - v2.8.1
                              system.adapter.broadlink2              : broadlink2     - v2.0.3
                              system.adapter.cloud                   : cloud          - v4.0.4
                              system.adapter.daikin-cloud            : daikin-cloud   - v0.3.0
                              system.adapter.daswetter               : daswetter      - v3.1.10
                              system.adapter.deconz                  : deconz         - v1.3.21
                              system.adapter.device-reminder         : device-reminder - v1.2.9
                              system.adapter.discovery               : discovery      - v3.1.0
                              system.adapter.ecovacs-deebot          : ecovacs-deebot - v1.4.13
                              system.adapter.enigma2                 : enigma2        - v2.0.3
                              system.adapter.fb-checkpresence        : fb-checkpresence - v1.2.2
                              system.adapter.fiat                    : fiat           - v0.0.8
                              system.adapter.flot                    : flot           - v1.12.0
                              system.adapter.fritzdect               : fritzdect      - v2.1.11
                              system.adapter.fullybrowser            : fullybrowser   - v2.1.2
                              system.adapter.go-e                    : go-e           - v1.0.27
                              system.adapter.ham                     : ham            - v5.3.1
                              system.adapter.harmony                 : harmony        - v1.2.2
                              system.adapter.hue                     : hue            - v3.10.0
                              system.adapter.hue-extended            : hue-extended   - v2.0.0
                              system.adapter.icons-mfd-svg           : icons-mfd-svg  - v1.1.0
                              system.adapter.influxdb                : influxdb       - v3.2.0
                              system.adapter.info                    : info           - v2.0.0
                              system.adapter.iot                     : iot            - v1.14.5
                              system.adapter.javascript              : javascript     - v7.1.4
                              system.adapter.meross                  : meross         - v1.15.1
                              system.adapter.mihome-vacuum           : mihome-vacuum  - v4.0.0
                              system.adapter.mobile                  : mobile         - v1.0.1
                              system.adapter.openweathermap          : openweathermap - v0.3.9
                              system.adapter.parser                  : parser         - v1.3.2
                              system.adapter.pi-hole                 : pi-hole        - v1.3.6
                              system.adapter.ping                    : ping           - v1.4.12
                              system.adapter.pushover                : pushover       - v3.0.3
                              system.adapter.pvforecast              : pvforecast     - v2.8.1
                              system.adapter.radar2                  : radar2         - v2.0.7
                              system.adapter.shelly                  : shelly         - v6.4.1
                              system.adapter.simple-api              : simple-api     - v2.7.2
                              system.adapter.smartcontrol            : smartcontrol   - v2.0.1
                              system.adapter.socketio                : socketio       - v6.5.5
                              system.adapter.sonoff                  : sonoff         - v2.5.3
                              system.adapter.tado                    : tado           - v0.4.9
                              system.adapter.telegram                : telegram       - v1.16.0
                              system.adapter.tibberlink              : tibberlink     - v1.0.0
                              system.adapter.tr-064                  : tr-064         - v4.2.4
                              system.adapter.vis                     : vis            - v1.4.16
                              system.adapter.vis-hqwidgets           : vis-hqwidgets  - v1.4.0
                              system.adapter.vis-jqui-mfd            : vis-jqui-mfd   - v1.0.12
                              system.adapter.vis-material-advanced   : vis-material-advanced - v1.7.4
                              system.adapter.vis-metro               : vis-metro      - v1.2.0
                              system.adapter.vis-timeandweather      : vis-timeandweather - v1.2.2
                              system.adapter.weatherunderground      : weatherunderground - v3.6.0
                              system.adapter.web                     : web            - v4.3.0
                              system.adapter.worx                    : worx           - v2.3.2
                              system.adapter.ws                      : ws             - v2.5.5
                              • G Gismoh
                                Thomas BraunT
                                Thomas BraunT
                                #125
                                @gismoh
                                iobroker install ble
                                  @gismoh
                                  G
                                  G
                                  Gismoh
                                  #126
                                  idash@ioBrokerVM:~$ iobroker install ble
                                  NPM version: 9.8.1
                                  npm ERR! code 1
                                  npm ERR! (node:1950) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.
                                  npm ERR!                                             ^^^^^
                                  npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-08T23_26_40_665Z-debug-0.log
                                  • G Gismoh
                                    NPM version: 9.8.1
                                    npm ERR! code 1
                                    npm ERR!                                             ^^^^^
                                    Thomas BraunT
                                    Thomas BraunT
                                    #127
                                    Ich muss lagsam mal in die Heia...
                                    nano /opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py
                                    gibt es nicht?
                                      gibt es nicht?
                                      G
                                      G
                                      Gismoh
                                      #128
                                      leider nicht:
                                      Verzeichnis „/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp“ existiert nicht
                                      Dann wünsch ich dir eine gute Nacht, und besten Dank!
                                      • G Gismoh
                                        leider nicht:
                                        G
                                        G
                                        Gismoh
                                        #129
                                        @all
                                        Besten Dank an alle, welche sich hier als helfende Hand mit eingebunden haben! 👏 💐
                                        Habe mir nun auch noch ein USB-Bluetooth Modul bestellt - keine Ahnung ob es damit evtl. besser geht.
                                        Was mich immer nur wundert, das die "Erstinstallation" incl. BLE geklappt hat, also der BLE grün war und auch Geräte gefunden hat. Erst nach Backup Einspielung verweigerte der ble seinen Dienst.
                                        Würde mich freuen, wenn noch eine Lösung gefunden werden könnte ;)
                                        • G Gismoh
                                          @all
                                          crunchipC
                                          crunchipC
                                          Developer Global Moderator Most Active Forum Testing
                                          #130
                                          letzte Variante,
                                          den Ble auf dem alten System deinstallieren, dann ein backup erstellen, dieses auf deinen neuen System spielen und danach dann den ble installieren.
                                          84.0k
