  4. Test Adapter Linux Control v1.x.x
adaptercontrolhardwarelinuxsteuern
718 Beiträge 74 Kommentatoren 255.8k Aufrufe 67 Beobachtet
  • NegaleinN Offline
    NegaleinN Offline
    Negalein
    #551
    @Scrounger
    kannst du zu meinem Issue irgendwas sagen?
    Seit JS-Controller 5 kommen die Fehler und dein Adapter stoppt.
    Er sagt irgendwas von invalid Characters. Aber welche?
    linux-control.0 2023-11-05 15:21:15.201	error	adapter disabled
    linux-control.0 2023-11-05 15:20:43.666	error	[needrestart] Proxmox (10.0.1.201:22): error: Cannot find view "system", stack: Error: Cannot find view "system" at ObjectsInRedisClient._getObjectView (/opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:4317:19) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:4392:37)
    linux-control.0 2023-11-05 15:20:43.612	error	Cannot find view "system" for search "state" : Connection is closed.
    linux-control.0 2023-11-05 15:20:43.610	error	[servicesInfo] Proxmox (10.0.1.201:22): error: Connection is closed., stack: Error: Connection is closed. at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25) at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20) at Object.onceWrapper (node:events:632:26) at Socket.emit (node:events:517:28) at Socket.emit (node:domain:489:12) at TCP.<anonymous> (node:net:350:12)
    linux-control.0 2023-11-05 15:20:43.250	error	The pattern "io.linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.stop" is not a valid ID pattern
    linux-control.0 2023-11-05 15:20:43.250	error	Error: The pattern "io.linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.stop" is not a valid ID pattern at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2467:15) at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27) at processTicksAndRejections (node:internal/process/task_queues:95:5)
    linux-control.0 2023-11-05 15:20:43.184	error	unhandled promise rejection: The pattern "io.linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.stop" is not a valid ID pattern
    linux-control.0 2023-11-05 15:20:43.184	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    linux-control.0 2023-11-05 15:20:43.181	warn	Used invalid characters: linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.stop changed to linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by_x2duuid-9C29_x2d4D7D.stop
    linux-control.0 2023-11-05 15:20:43.177	error	Error The pattern "linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.start" is not a valid ID pattern
    linux-control.0 2023-11-05 15:20:43.177	error	ReplyError: Error The pattern "linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.start" is not a valid ID pattern at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12) at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
    linux-control.0 2023-11-05 15:20:43.177	error	unhandled promise rejection: Error The pattern "linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.start" is not a valid ID pattern
    linux-control.0 2023-11-05 15:20:43.177	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    linux-control.0 2023-11-05 15:20:43.098	warn	Used invalid characters: linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.start changed to linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by_x2duuid-9C29_x2d4D7D.start
    linux-control.0 2023-11-05 15:20:43.098	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    linux-control.0 2023-11-05 15:20:43.088	error	Error The pattern "linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.restart" is not a valid ID pattern
    linux-control.0 2023-11-05 15:20:43.088	error	ReplyError: Error The pattern "linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.restart" is not a valid ID pattern at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12) at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
    linux-control.0 2023-11-05 15:20:43.086	error	unhandled promise rejection: Error The pattern "linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.restart" is not a valid ID pattern
    linux-control.0 2023-11-05 15:20:43.086	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    linux-control.0 2023-11-05 15:20:43.018	warn	Used invalid characters: linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.restart changed to linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by_x2duuid-9C29_x2d4D7D.restart
    linux-control.0 2023-11-05 15:20:42.973	warn	State "linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.description" has no existing object, this might lead to an error in future versions
    linux-control.0 2023-11-05 15:20:42.971	warn	Used invalid characters: linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.description changed to linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by_x2duuid-9C29_x2d4D7D.description
    linux-control.0 2023-11-05 15:20:42.967	warn	State "linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.running" has no existing object, this might lead to an error in future versions
    linux-control.0 2023-11-05 15:20:42.965	warn	Used invalid characters: linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.running changed to linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by_x2duuid-9C29_x2d4D7D.running
    linux-control.0 2023-11-05 15:20:42.962	warn	State "linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.active" has no existing object, this might lead to an error in future versions
    linux-control.0 2023-11-05 15:20:42.958	warn	Used invalid characters: linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.active changed to linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by_x2duuid-9C29_x2d4D7D.active
    linux-control.0 2023-11-05 15:20:42.916	warn	State "linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.load" has no existing object, this might lead to an error in future versions
    linux-control.0 2023-11-05 15:20:42.913	warn	Used invalid characters: linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.load changed to linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by_x2duuid-9C29_x2d4D7D.load
    Das zB control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.stop wurde lt. Log nach linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by_x2duuid-9C29_x2d4D7D.stop geändert.
    Aber warum? Ich hab nichts verändert an der Konfig.
    Was kann ich machen?
    ° Fixer ---> iob fix
    • NegaleinN Negalein
      @Scrounger
      wendy2702W Online
      wendy2702W Online
      #552
      Das hakt ja schon hier:
      Gibt es den View noch?
      Dann welche Version von Proxmox und ist der fsck ein selbst definierter Befehl ?
      Wie sieht der aus?
      Gibt es das Device/laufwerk noch?
      • wendy2702W wendy2702
        Wie sieht der aus?
        NegaleinN Offline
        NegaleinN Offline
        Negalein
        #553
        @wendy2702 sagte in Test Adapter Linux Control v1.x.x:
        Nein, hat es auch nie gegeben.
        10.0.1.201 = Proxmox
        10.0.1.202:8082/vis/index.html#080_System = ioB und die View heißt 080_System
        Gibt es das Device/laufwerk noch?>
        root@proxmox:~# ls -l /dev/disk/by-id/
        total 0
        lrwxrwxrwx 1 root root  9 Sep  7 13:58 ata-SanDisk_SDSSDH3_1T00_221348800390 -> ../../sda
        lrwxrwxrwx 1 root root 10 Sep  7 13:58 ata-SanDisk_SDSSDH3_1T00_221348800390-part1 -> ../../sda1
        lrwxrwxrwx 1 root root 10 Sep  7 13:58 ata-SanDisk_SDSSDH3_1T00_221348800390-part2 -> ../../sda2
        lrwxrwxrwx 1 root root 10 Nov  6 05:06 ata-SanDisk_SDSSDH3_1T00_221348800390-part3 -> ../../sda3
        lrwxrwxrwx 1 root root 10 Sep  7 13:58 dm-name-pve-root -> ../../dm-1
        lrwxrwxrwx 1 root root 10 Sep  7 13:58 dm-name-pve-swap -> ../../dm-0
        lrwxrwxrwx 1 root root 10 Nov  6 05:00 dm-name-pve-vm--100--disk--0 -> ../../dm-6
        lrwxrwxrwx 1 root root 10 Nov  6 05:05 dm-name-pve-vm--101--disk--0 -> ../../dm-7
        lrwxrwxrwx 1 root root 10 Nov  6 04:04 dm-name-pve-vm--102--disk--0 -> ../../dm-8
        lrwxrwxrwx 1 root root 10 Nov  6 04:05 dm-name-pve-vm--103--disk--0 -> ../../dm-9
        lrwxrwxrwx 1 root root 11 Nov  6 04:07 dm-name-pve-vm--104--disk--0 -> ../../dm-10
        lrwxrwxrwx 1 root root 11 Nov  6 05:05 dm-name-pve-vm--105--disk--1 -> ../../dm-12
        lrwxrwxrwx 1 root root 11 Nov  6 05:06 dm-name-pve-vm--106--disk--0 -> ../../dm-11
        lrwxrwxrwx 1 root root 11 Nov  6 05:06 dm-name-pve-vm--107--disk--0 -> ../../dm-13
        lrwxrwxrwx 1 root root 10 Nov  6 04:04 dm-uuid-LVM-Um7uCQ5plpg4GO0G1hTw2LTdLSxAhLxM3dxrDM3dBYhNgI8mpPV3YmfHk75VT2CZ -> ../../dm-8
        lrwxrwxrwx 1 root root 10 Nov  6 05:00 dm-uuid-LVM-Um7uCQ5plpg4GO0G1hTw2LTdLSxAhLxMEohxnWLY2pMegm2B06LWZhhOb4JtDLdQ -> ../../dm-6
        lrwxrwxrwx 1 root root 11 Nov  6 05:05 dm-uuid-LVM-Um7uCQ5plpg4GO0G1hTw2LTdLSxAhLxMOiAaJ18km9GOxKBboaWrAGtoGCssq5sm -> ../../dm-12
        lrwxrwxrwx 1 root root 10 Sep  7 13:58 dm-uuid-LVM-Um7uCQ5plpg4GO0G1hTw2LTdLSxAhLxMUldB8S2CZaYIN2ywWiLNCdTYvUJEz4ot -> ../../dm-0
        lrwxrwxrwx 1 root root 10 Sep  7 13:58 dm-uuid-LVM-Um7uCQ5plpg4GO0G1hTw2LTdLSxAhLxMdti3rBZdxZYTN3oDHliWCdLGGomqi2xj -> ../../dm-1
        lrwxrwxrwx 1 root root 10 Nov  6 04:05 dm-uuid-LVM-Um7uCQ5plpg4GO0G1hTw2LTdLSxAhLxMfdz28y3obse8csoHkDgVo2rTfBy8uJfJ -> ../../dm-9
        lrwxrwxrwx 1 root root 11 Nov  6 05:06 dm-uuid-LVM-Um7uCQ5plpg4GO0G1hTw2LTdLSxAhLxMiOEhJ1hibDoUrRctAkyzN2exdG1ZcgxU -> ../../dm-13
        lrwxrwxrwx 1 root root 10 Nov  6 05:05 dm-uuid-LVM-Um7uCQ5plpg4GO0G1hTw2LTdLSxAhLxMljq2p7vA13bd3yyKg19GNtsJ0RmMBuBi -> ../../dm-7
        lrwxrwxrwx 1 root root 11 Nov  6 05:06 dm-uuid-LVM-Um7uCQ5plpg4GO0G1hTw2LTdLSxAhLxMqu8b9ffqSwzJpJJH3V1dSl2uQhw8p3UP -> ../../dm-11
        lrwxrwxrwx 1 root root 11 Nov  6 04:07 dm-uuid-LVM-Um7uCQ5plpg4GO0G1hTw2LTdLSxAhLxMzv1OgYTuzbVrrzPLozpFivIdBr4F5xQv -> ../../dm-10
        lrwxrwxrwx 1 root root 10 Nov  6 05:06 lvm-pv-uuid-gELFXe-CNIv-TyOf-EVPI-b8LY-bEn2-Pct9zA -> ../../sda3
        lrwxrwxrwx 1 root root  9 Sep  7 13:58 wwn-0x5001b448b72fa263 -> ../../sda
        lrwxrwxrwx 1 root root 10 Sep  7 13:58 wwn-0x5001b448b72fa263-part1 -> ../../sda1
        lrwxrwxrwx 1 root root 10 Sep  7 13:58 wwn-0x5001b448b72fa263-part2 -> ../../sda2
        lrwxrwxrwx 1 root root 10 Nov  6 05:06 wwn-0x5001b448b72fa263-part3 -> ../../sda3
        7.2-7
        Meister MopperM crunchipC wendy2702W 3 Antworten Letzte Antwort
          total 0
          7.2-7
          Meister MopperM Online
          Meister Mopper
          #554
          @negalein sagte in Test Adapter Linux Control v1.x.x:
          7.2-7
          Ich fahre die 8.x und habe mit dem Adapter keine Pobleme. Aber vielleicht gibt es ja jemanden, der mit 7.2-7 auch keine Probleme hat, dann könnte man das Problem mglw. eingrenzen.
          Proxmox und HA ...
            7.2-7
            NegaleinN Offline
            NegaleinN Offline
            Negalein
            #555
            @meister-mopper sagte in Test Adapter Linux Control v1.x.x:
            komisch ist, dass vor JS-Controller 5 keine Probleme waren.
            Muss mir mal das Tut für das Update auf 8.x anschaun.
            Auf den ersten Blick sieht es sehr umfangreich aus. :(
              Meister Mopper
              schrieb am zuletzt editiert von Meister Mopper
              #556
              Es war nicht kompliziert und ich habe meine komplette HA-Umgebung binnen ca. einer Stunde auf 8.x gehoben. Läuft hier auch sehr stabil, keinerlei Ausfälle oder Störungen.
              Wenn du ein Backup des node hast, kannst du das ja zurückpfeifen.
              Proxmox und HA ...
                NegaleinN Offline
                NegaleinN Offline
                Negalein
                #557
                ich werde da zeitnah einen eigenen Thread erstellen (darf dich dann verlinken ;) ). Ein paar Fragen/Problemchen stehen schon auf der Liste.
                Wird hier sonst zu OT.
                  total 0
                  7.2-7
                  crunchipC Abwesend
                  crunchipC Abwesend
                  #558
                  @negalein proxmox root und sudo? 🤔
                    NegaleinN Offline
                    NegaleinN Offline
                    Negalein
                    #559
                    @crunchip sagte in Test Adapter Linux Control v1.x.x:
                    habs gerade gesehn.
                    aber auch ohne sudo spinnt er rum.
                      total 0
                      7.2-7
                      wendy2702W Online
                      wendy2702W Online
                      #560
                      Gibt es dieses Object?
                      Eventuell auch ohne das „io“ am Anfang.
                      Du hast nach „by-Id“ abgefragt. Gibt es bei dir eventuell „x2….“ ?
                      NegaleinN 2 Antworten Letzte Antwort
                        NegaleinN Offline
                        NegaleinN Offline
                        Negalein
                        #561
                        nein
                        total 0
                        • David G.D Online
                          David G.D Online
                          David G.
                          #562
                          Evtl stehe ich grad voll am Schlauch.
                          Gibt's einen Menüpunkt im Adapter wo ich eigene globale Befehle hinterlegen kann die für jeden Host ausgeführt werden?
                          Irgendwie doof, ein und den selben Befehl x mal unter "Meine Befehle" für jeden Rechner anzulegen.
                            NegaleinN Offline
                            NegaleinN Offline
                            Negalein
                            #563
                            kannst du dir denken, was ich noch machen könnte?
                            läuft jetzt, nachdem ich ihn in den letzten Wochen bestimmt 20x neu installiert habe.
                            • David G.D David G.
                              Meister Mopper
                              #564
                              @david-g
                              Ist das nicht geradezu ein Thema für github?
                              Proxmox und HA ...
                                @david-g
                                David G.D Online
                                David G.D Online
                                David G.
                                #565
                                @meister-mopper
                                Falls deine Antwort in etwa:
                                Nein, das geht aktuell nicht.
                                ist, dann ja.
                                Frage aber erstmal, bevor ich da was auf mache.
                                  @meister-mopper
                                  ist, dann ja.
                                  Meister Mopper
                                  #566
                                  @david-g sagte in Test Adapter Linux Control v1.x.x:
                                  Ist das jetzt Aggression, oder solte ich reagiern?
                                  Proxmox und HA ...
                                    David G.D Online
                                    David G.D Online
                                    David G.
                                    #567
                                    @meister-mopper
                                    Ne, garnicht. Kein Funken Aggression.
                                    Wollte wirklich einfach vorher fragen.
                                    Hatte schon einige Adapter wo mir mobil nicht alles angezeigt wird (arbeite ausschließlich mobil(Auch wenn es in letzter Zeit nicht mehr vorgekommen ist.)).
                                    Auf git schreibe ich, wenn ich ein Issue hab oder ein Feature Request. Nicht bei einer Frage zum Adapter.
                                    https://github.com/Scrounger/ioBroker.linux-control/issues/59
                                    • David G.D Online
                                      David G.D Online
                                      David G.
                                      #568
                                      Habe jetzt mal ein paar Rechner im Adapter konfiguriert.
                                      2 Problemchsn habe ich.
                                      Auf einem Rechner kann ich kein Upgrade über
                                      linux-control.0.localhost.control.aptUpgrade
                                      anstoßen. Apt-update klappt.
                                      Es kommt als response:
                                      sudo: Leider dürfen die folgenden Umgebungsvariablen nicht gesetzt werden: DEBIAN_FRONTEND
                                      Ich versuche mittels
                                      awk '{u=$2+$4; t=$2+$4+$5; if (NR==1){u1=u; t1=t;} else printf "%.2f\n", ($2+$4-u1) * 100 / (t-t1); }' \
                                      <(grep 'cpu ' /proc/stat) <(sleep 1;grep 'cpu ' /proc/stat)
                                      die aktuelle CPU-Auslastung auszulesen. In der Konsole klappt es auch. Der DP der von Linux control wird immer mit einer 0 befüllt.
                                      Im Log kommt:
                                      	[userCommandExecute] localhost (192.168.99.33:22, id: Cpu_Auslastung, description: ): response error: awk: cannot open /dev/fd/63 (No such file or directory), stack: ResponseError: [userCommandExecute] localhost (192.168.99.33:22, id: Cpu_Auslastung, description: ): awk: cannot open /dev/fd/63 (No such file or directory) at LinuxControl.sendCommand (/opt/iobroker/node_modules/iobroker.linux-control/main.js:886:26) at processTicksAndRejections (node:internal/process/task_queues:95:5) at LinuxControl.userCommandExecute (/opt/iobroker/node_modules/iobroker.linux-control/main.js:249:21)
                                        Im Log kommt:
                                        da_WoodyD Online
                                        da_WoodyD Online
                                        #569
                                        @david-g Upgrade groß geschrieben?
                                        • da_WoodyD da_Woody
                                          David G.D Online
                                          David G.D Online
                                          David G.
                                          #570
                                          @da_woody
                                          Läuft ja über den DP vom Adapter.
                                          Was der da im Hintergrund sendet weiß ich nicht.
                                          GrizzelbeeG 1 Antwort Letzte Antwort
