  5. Sayit-Block funktioniert nicht mehr
    6.8k
34 Beiträge 12 Kommentatoren 5.4k Aufrufe 11 Beobachtet
  • DJMarc75D DJMarc75
    @bender275
    die Nachfragen nach
    iob diag
    überlesen ?
    Bender275
    @djmarc75
    Sorry, war unterwegs. Hier iob diag
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Model		: Raspberry Pi 4 Model B Rev 1.4
    Architecture    : aarch64
    Docker          : false
    Virtualization  : none
    Distributor ID:	Raspbian
    Description:	Raspbian GNU/Linux 11 (bullseye)
    Release:	11
    Codename:	bullseye
    PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
    NAME="Raspbian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=raspbian
    ID_LIKE=debian
    HOME_URL="http://www.raspbian.org/"
    SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
    BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
    Systemuptime and Load:
     20:07:24 up 7 days,  2:27,  0 users,  load average: 1.02, 1.07, 0.96
    CPU threads: 4
    Raspberry only:
    throttled=0x0
    Other values than 0x0 hint to temperature/voltage problems
    temp=53.0'C
    volt=0.8600V
    *** Time and Time Zones ***
                   Local time: Mon 2023-07-10 20:07:24 CEST
               Universal time: Mon 2023-07-10 18:07:24 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server: 	true
    Desktop: 	LXDE-pi
    Terminal: 	x11
    Boot Target: 	graphical.target
    *** MEMORY ***
    Mem:            7.8G        2.2G        2.0G         53M        3.6G        5.4G
    Swap:            99M          0B         99M
    Total:          7.9G        2.2G        2.1G
             7811 M total memory
             2231 M used memory
             3833 M active memory
             1604 M inactive memory
             2017 M free memory
              279 M buffer memory
             3282 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FILESYSTEM ***
    /dev/root      ext4      470G   17G  434G   4% /
    devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
    tmpfs          tmpfs     3.9G  3.8M  3.9G   1% /dev/shm
    tmpfs          tmpfs     1.6G  796K  1.6G   1% /run
    /dev/sda1      vfat      253M   51M  202M  20% /boot
    tmpfs          tmpfs     782M   20K  782M   1% /run/user/1000
    [Mon Jul  3 17:40:17 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:5F:01:0C:5F:3D vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=5d45f9a3-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Mon Jul  3 17:40:19 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
    [Mon Jul  3 17:40:19 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Mon Jul  3 17:40:21 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
    TARGET                       SOURCE       FSTYPE            OPTIONS
    /                            /dev/sda2    ext4              rw,noatime
    |-/boot                      /dev/sda1    vfat              rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
    `-/home/pi/thinclient_drives xrdp-chansrv fuse.xrdp-chansrv rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
    /var:
    2.8G	/var/
    1.3G	/var/log
    1.2G	/var/log/journal/d305c1d5b0964304901f0bf58ddc9f97
    918M	/var/cache
    Archived and active journals take up 1.1G in the file system.
    /opt/iobroker/backups:
    566M	/opt/iobroker/backups/
    704K	/opt/iobroker/backups/skripte
    688K	/opt/iobroker/backups/skripte/Räume
    252K	/opt/iobroker/backups/skripte/Räume/allgemein
    156K	/opt/iobroker/backups/skripte/Räume/Küche
    /opt/iobroker/iobroker-data:
    391M	/opt/iobroker/iobroker-data/
    214M	/opt/iobroker/iobroker-data/files
    126M	/opt/iobroker/iobroker-data/backup-objects
    51M	/opt/iobroker/iobroker-data/files/javascript.admin
    45M	/opt/iobroker/iobroker-data/files/devices.admin/static
    35M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    22M	/opt/iobroker/iobroker-data/objects.jsonl
    19M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
    8.9M	/opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.7de3299d.chunk.js.map
    8.7M	/opt/iobroker/iobroker-data/objects.json.migrated
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v18.16.1
    /usr/bin/node 		v18.16.1
    /usr/bin/npm 		9.5.1
    /usr/bin/npx 		9.5.1
    nodejs:
      Installed: 18.16.1-deb-1nodesource1
      Candidate: 18.16.1-deb-1nodesource1
      Version table:
     *** 18.16.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main armhf Packages
         12.22.12~dfsg-1~deb11u4 500
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller: 	4.0.24
    admin: 		6.3.5
    javascript: 	6.2.0
    Adapters from github: 	4
    Adapter State
    + system.adapter.admin.0                  : admin                 : Raspi4                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : Raspi4                                   -  enabled
    + system.adapter.bestway.0                : bestway               : Raspi4                                   -  enabled
    + system.adapter.bluelink.0               : bluelink              : Raspi4                                   -  enabled
    + system.adapter.cloud.0                  : cloud                 : Raspi4                                   -  enabled
      system.adapter.daswetter.0              : daswetter             : Raspi4                                   -  enabled
      system.adapter.devices.0                : devices               : Raspi4                                   -  enabled
    + system.adapter.discovery.0              : discovery             : Raspi4                                   -  enabled
      system.adapter.dwd.0                    : dwd                   : Raspi4                                   -  enabled
    + system.adapter.email.0                  : email                 : Raspi4                                   -  enabled
      system.adapter.feiertage.0              : feiertage             : Raspi4                                   -  enabled
    + system.adapter.fritzdect.0              : fritzdect             : Raspi4                                   -  enabled
    + system.adapter.fronius-wattpilot.0      : fronius-wattpilot     : Raspi4                                   -  enabled
    + system.adapter.fronius.0                : fronius               : Raspi4                                   -  enabled
    + system.adapter.hs100.0                  : hs100                 : Raspi4                                   -  enabled
    + system.adapter.info.0                   : info                  : Raspi4                                   -  enabled
    + system.adapter.iot.0                    : iot                   : Raspi4                                   -  enabled
    + system.adapter.jarvis.0                 : jarvis                : Raspi4                                   -  enabled
    + system.adapter.javascript.0             : javascript            : Raspi4                                   -  enabled
    + system.adapter.klf200.0                 : klf200                : Raspi4                                   -  enabled
    + system.adapter.lgtv.0                   : lgtv                  : Raspi4                                   -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : Raspi4                                   -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.net-tools.0              : net-tools             : Raspi4                                   -  enabled
    + system.adapter.nuki.0                   : nuki                  : Raspi4                                   -  enabled
    + system.adapter.ping.0                   : ping                  : Raspi4                                   -  enabled
    + system.adapter.sayit.0                  : sayit                 : Raspi4                                   -  enabled
    + system.adapter.sayit.1                  : sayit                 : Raspi4                                   -  enabled
    + system.adapter.sayit.2                  : sayit                 : Raspi4                                   -  enabled
    + system.adapter.scenes.0                 : scenes                : Raspi4                                   -  enabled
    + system.adapter.shelly.0                 : shelly                : Raspi4                                   -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shelly.1                 : shelly                : Raspi4                                   -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.sprinklecontrol.0        : sprinklecontrol       : Raspi4                                   -  enabled
    + system.adapter.sql.0                    : sql                   : Raspi4                                   -  enabled, port: 3306
    + system.adapter.tuya.0                   : tuya                  : Raspi4                                   -  enabled
      system.adapter.vis.0                    : vis                   : Raspi4                                   -  enabled
    + system.adapter.web.0                    : web                   : Raspi4                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    Stable (default): http://download.iobroker.net/sources-dist.json
    Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
    Installed ioBroker-Instances
    Adapter    "backitup"     : 2.6.23   , installed 2.6.23
    Adapter    "bestway"      : 0.0.4    , installed 0.0.4
    Adapter    "bluelink"     : 2.3.2    , installed 2.3.2
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "daswetter"    : 3.1.8    , installed 3.1.8
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "dwd"          : 2.8.3    , installed 2.8.3
    Adapter    "email"        : 1.2.0    , installed 1.2.0
    Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
    Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
    Adapter    "fronius"      : 1.1.3    , installed 1.1.3
    Adapter    "fronius-wattpilot": 4.5.1, installed 4.5.1
    Adapter    "hs100"        : 2.1.2    , installed 2.1.6
    Adapter    "iot"          : 1.14.5   , installed 1.14.5
    Adapter    "jarvis"       : 3.1.2    , installed 3.1.2
    Adapter    "javascript"   : 7.0.3    , installed 6.2.0  [Updatable]
    Adapter    "klf200"       : 1.0.1    , installed 1.0.1
    Adapter    "lgtv"         : 1.1.10   , installed 1.1.10
    Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "nuki"         : 1.6.0    , installed 1.6.0
    Adapter    "sayit"        : 3.0.5    , installed 3.0.5
    Adapter    "shelly"       : 6.4.1    , installed 6.4.1
    Adapter    "sprinklecontrol": 0.2.13 , installed 0.2.13
    Adapter    "tuya"         : 3.14.2   , installed 3.14.2
    Objects and States
    Objects: 	8225
    States: 	6469
    Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:3 https://deb.nodesource.com/node_18.x bullseye InRelease
    Reading package lists...
    Pending Updates: 17
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       109227     6942/io.jarvis.0
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       105697     6214/iobroker.js-co
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       103137     6214/iobroker.js-co
    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          14136      599/lighttpd
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15951      594/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      999        15029      553/pihole-FTL
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          24909578   27450/cupsd
    tcp        0      0 127.0.0.1:4711          0.0.0.0:*               LISTEN      999        15035      553/pihole-FTL
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      117        15904      568/mosquitto
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       104924     6399/io.shelly.1
    tcp6       0      0 :::80                   :::*                    LISTEN      0          14137      599/lighttpd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          15953      594/sshd: /usr/sbin
    tcp6       0      0 :::53                   :::*                    LISTEN      999        15031      553/pihole-FTL
    tcp6       0      0 :::1883                 :::*                    LISTEN      117        15905      568/mosquitto
    tcp6       0      0 ::1:3350                :::*                    LISTEN      0          14610      556/xrdp-sesman
    tcp6       0      0 ::1:4711                :::*                    LISTEN      999        15036      553/pihole-FTL
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          24909577   27450/cupsd
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       4014514    29072/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       104666     6232/io.admin.0
    tcp6       0      0 :::3306                 :::*                    LISTEN      116        14243      813/mysqld
    tcp6       0      0 :::3389                 :::*                    LISTEN      115        14248      615/xrdp
    udp        0      0 0.0.0.0:34960           0.0.0.0:*                           108        13926      376/avahi-daemon: r
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       106000     6382/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       106001     6382/io.tuya.0
    udp        0      0 0.0.0.0:60008           0.0.0.0:*                           1001       23722718   11297/io.javascript
    udp        0      0 0.0.0.0:40139           0.0.0.0:*                           1001       28266417   -
    udp        0      0 0.0.0.0:53              0.0.0.0:*                           999        15028      553/pihole-FTL
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14950      443/dhcpcd
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          24912270   27452/cups-browsed
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13924      376/avahi-daemon: r
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       104117     6348/io.shelly.0
    udp6       0      0 :::44036                :::*                                108        13927      376/avahi-daemon: r
    udp6       0      0 :::53                   :::*                                999        15030      553/pihole-FTL
    udp6       0      0 :::5353                 :::*                                108        13925      376/avahi-daemon: r
    2023-07-10 19:55:00.181  - info: host.Raspi4 instance system.adapter.dwd.0 started with pid 7582
    2023-07-10 19:55:03.170  - info: dwd.0 (7582) starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.16.1, js-controller: 4.0.24
    2023-07-10 19:55:06.461  - info: dwd.0 (7582) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-07-10 19:55:06.998  - info: host.Raspi4 instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-07-10 20:00:00.024  - info: javascript.0 (11297) script.js.Räume.Wohnen.Fernsehlicht_nicht_bei_ausser_Haus: Own states (javascript.0.scriptEnabled.Räume.Wohnen.Fernsehlicht_nach_Zeitplan_ein_aus) should not be used in javascript.X.scriptEnabled.*! Please move the states to 0_userdata.0.*
    2023-07-10 20:00:00.215  - info: host.Raspi4 instance system.adapter.dwd.0 started with pid 7800
    2023-07-10 20:00:00.290  - info: bluelink.0 (6906) Forcing refresh from Server
    2023-07-10 20:00:00.291  - info: bluelink.0 (6906) Read new update for XXX from the server
    2023-07-10 20:00:00.305  - info: bluelink.0 (6906) Forcing refresh from Car
    2023-07-10 20:00:00.306  - info: bluelink.0 (6906) Read new update for XXX directly from the car
    2023-07-10 20:00:03.352  - info: bluelink.0 (6906) Update for XXX successfull
    2023-07-10 20:00:03.857  - info: dwd.0 (7800) starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.16.1, js-controller: 4.0.24
    2023-07-10 20:00:04.260  - info: host.Raspi4 instance system.adapter.daswetter.0 started with pid 7817
    2023-07-10 20:00:07.359  - info: daswetter.0 (7817) starting. Version 3.1.8 in /opt/iobroker/node_modules/iobroker.daswetter, node: v18.16.1, js-controller: 4.0.24
    2023-07-10 20:00:08.183  - info: dwd.0 (7800) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-07-10 20:00:08.729  - info: host.Raspi4 instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-07-10 20:00:18.257  - info: daswetter.0 (7817) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
    2023-07-10 20:00:18.775  - info: daswetter.0 (7817) cleaned everything up...
    2023-07-10 20:00:18.795  - info: host.Raspi4 instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-07-10 20:00:36.575  - info: bluelink.0 (6906) Update for XXX successfull
    2023-07-10 20:05:00.206  - info: host.Raspi4 instance system.adapter.dwd.0 started with pid 8042
    2023-07-10 20:05:03.366  - info: dwd.0 (8042) starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.16.1, js-controller: 4.0.24
    2023-07-10 20:05:06.544  - info: dwd.0 (8042) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-07-10 20:05:07.104  - info: host.Raspi4 instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-07-10 20:08:01.238  - info: admin.0 (6232) ==> Connected system.user.admin from ::ffff:10.0.2.11
    		     v.2023-04-16
    Operatingsystem: 	Raspbian GNU/Linux 11 (bullseye)
    Kernel: 		6.1.36-v8+
    Installation: 		Native
    Timezone: 		Europe/Berlin (CEST, +0200)
    User-ID: 		1000
    X-Server: 		true
    Pending OS-Updates: 	17
    Pending iob updates: 	1
    Nodejs-Installation: 	/usr/bin/nodejs 	v18.16.1
    			/usr/bin/npm 		9.5.1
    			/usr/bin/npx 		9.5.1
    Recommended versions are nodejs 18.x.y and npm 9.x.y
    MEMORY:
    Mem:            7.8G        2.3G        2.0G         53M        3.6G        5.4G
    Swap:            99M          0B         99M
    Total:          7.9G        2.3G        2.1G
    Active iob-Instances: 	32
    ioBroker Core: 		js-controller 		4.0.24
    			admin 			6.3.5
    ioBroker Status: 	iobroker is running on this host.
    Objects type: jsonl
    States  type: jsonl
    Objects: 		8225
    States: 		6469
    Size of iob-Database:
    8.7M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
    7.0M	/opt/iobroker/iobroker-data/states.jsonl
    1.1M	/opt/iobroker/iobroker-data/states.json.migrated
    1.1M	/opt/iobroker/iobroker-data/states.json.bak.migrated
    0	/opt/iobroker/iobroker-data/states.json.broken
    [/s]
    @d0nnergurke Werd ich probieren, danke!
    • D d0nnergurke
      Ein Downgrade vom SayIt-Adapter auf 3.0.4 sollte eher helfen - Wichtig ist: Nach dem Downgrade die betroffenen Skripte editieren/neu speichern. Das Problem entsteht, weil seit SayIt-Version 3.0.5 die Skript-Blöcke in Blockly anders übersetzt werden. Die Übersetzung findet jedoch erst statt wenn ein Blockly-Skript geändert oder neu erstellt wird, daher funktionieren "alte" Blockly-Skripte weiterhin.
      Statt ursprünglich den Wert von [SayIt-Instanz].tts.text per "setStateDelayed" zu ändern wird ab 3.0.5 per "sendTo" mit dem Adapter kommuniziert. Bei mir reagiert der Adapter jedoch auch nicht auf den SendTo-Befehl - Siehe auch https://github.com/ioBroker/ioBroker.sayit/issues/267
      Bender275
      @d0nnergurke
      Werde ich probieren, vielen Dank!
      • DJMarc75D Offline
        DJMarc75D Offline
        DJMarc75
        @bender275
        Desktop ausknipsen
        Updates einspielen
        Adapter auf Stand bringen
        Dann kucken wir mal weiter
        Lehrling seit 1975 !!!
          Bender275
          Also, mit dem Downgrade des SayIt-Adapters gemäß d0nnergurke funktioniert wieder alles einwandfrei. Danke!
          • S Online
            S Online
            spike2
            Wie funktioniert der Downgrade auf die 3.0.4?
            Mir wird über den Expertenmodus egal ob Stable oder Beta Repo lediglich die 3.0.0 oder 3.0.5 angezeigt ?
            • S spike2
              crunchipC Abwesend
              crunchipC Abwesend
              @spike2 https://www.iobroker.net/#de/documentation/tutorial/adapter.md
                S Online
                S Online
                spike2
                @crunchip Super, hat geklappt. Danke dir 👍
                  sebi2ndPC
                  schrieb am zuletzt editiert von sebi2ndPC
                  also ich bekomms auch nicht ans laufen, auch der "downgrade" nach der Anleitung klappt irgendwie nicht, was mache ich falsch?
                  root@iobroker:~# iobroker install sayit@3.0.4
                  NPM version: 9.6.7
                  Installing iobroker.sayit@3.0.4... (System call)
                  Try to solve ENOTEMPTY error automatically
                  Could not handle ENOTEMPTY, because no deletable files were found
                  npm ERR! code ENOTEMPTY
                  npm ERR! syscall rename
                  npm ERR! path /opt/iobroker/node_modules/@aws-sdk/types
                  npm ERR! dest /opt/iobroker/node_modules/@aws-sdk/.types-qurPIL6Q
                  npm ERR! errno -39
                  npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/@aws-sdk/types' -> '/opt/iobroker/node_modules/@aws-sdk/.types-qurPIL6Q'
                  npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-10-20T20_14_46_855Z-debug-0.log
                  host.iobroker Cannot install iobroker.sayit@3.0.4: 217
                  root@iobroker:~#
                  Thomas BraunT S 2 Antworten Letzte Antwort
                  • S sebi2ndPC
                    NPM version: 9.6.7
                    npm ERR! errno -39
                    root@iobroker:~#
                    @sebi2ndpc sagte in Sayit-Block funktioniert nicht mehr:
                    root Login ist falsch.
                    Als user hantieren und
                    iob fix
                    ausführen.
                    • S sebi2ndPC
                      NPM version: 9.6.7
                      npm ERR! errno -39
                      root@iobroker:~#
                      S Abwesend
                      S Abwesend
                      Shadowhunter23
                      @sebi2ndpc
                      Sollte es nicht 3.0.0 sein?
                      Proxmox 9 HA-Cluster mit 3x HP prodesk 400 G6 i5
                      ioBroker Backup Analyzer
                        iob fix
                        ausführen.
                        sebi2ndPC
                        @thomas-braun danke, das war der richtige hinweis :-) jetzt hat es geklappt.
                          sebi2ndPC
                          also sayit auf 3.0.4 downgrade hat geklappt, skripte neu editiert und gespeichert aber am laufen bekomme ich die sprachausgabe immernoch nicht. komisch das es irgendwann mal tadellos funktionierte, nur leider weiss ich nicht mehr zu welchen versions varianten vom chromecast / web adapter und say it.....
                          gibt es eine alternative evtl zu dem adapter der sprachausgaben auf den google home bringen kann?
                          UweRLPU 1 Antwort Letzte Antwort
                          • S sebi2ndPC
                            UweRLPU Offline
                            UweRLPU Offline
                            UweRLP
                            @sebi2ndpc Ich nutze hier SayIt 3.0.5
                            Irgendwann vor langer... keine Ahnung wann
                            SayIt erstellt Objecte
                            Übergib mal dem sayit.0.tts.text den auszusprechenden Text, also ein
                            • UweRLPU UweRLP
                              sebi2ndPC
                              @uwerlp
                              das ist der fehler log, den hatte ich auch schon mit der 3.0.5 er version gehabt.
                              ip mit XXXXX überschrieben.
                              2023-10-22 15:43:12.905 - info: sayit.0 (4681) saying: hallo
                              2023-10-22 15:43:13.133 - info: sayit.0 (4681) Set "chromecast.0.14c14e7b0aac.player.announcement to {"url":"http://XXXXXX/sayit.0/tts.mp3?ts=1697982193133","volume":100}
                              2023-10-22 15:43:23.646 - error: sayit.0 (4681) Error while checking if chromecast.0.14c14e7b0aac.player.announcement finished playing announcement: {"url":"http://XXXXXXX/sayit.0/tts.mp3?ts=1697982193133","volume":100}: TIMEOUT
                              2023-10-22 15:43:23.647 - error: sayit.0 (4681) Cannot play file: Timeout by checking of announcement finished playing
                              • S sebi2ndPC
                                @uwerlp
                                UweRLPU Offline
                                UweRLPU Offline
                                UweRLP
                                @sebi2ndpc Sorry mit Fehlerlog kann ich leider nichts anfangen. Wollte nur drauf hin weisen, dass auch bei mir der SendTo Block nicht mehr ging dafür aber das Object.
                                • W Offline
                                  W Offline
                                  warp735
                                  schrieb am zuletzt editiert von warp735
                                  Wird der Adapter jemals wieder repariert? Oder gibts Alternativen? Scheint sich niemand mehr darum zu kümmern (letztes Update vom April(!!!)
                                  • W warp735
                                    S Abwesend
                                    S Abwesend
                                    Shadowhunter23
                                    @warp735
                                    Schau mal ins Changelog:
                                    Und geh einfach auf eine Version darunter dann geht's ja.
