  4. Test Adapter ioBroker.backitup v3.1.x
backitupbackitup backupccuhistorymysqlredisrestorerestore backup
2.8k Beiträge 170 Kommentatoren 2.8m Aufrufe 113 Beobachtet
    @ichderarnd sagte in Test Adapter ioBroker.backitup v2.8.x:
    Habe dann das fix-skript nochmal laufen lassen und die 18.18.1 installiert.
    Zeig mal bitte die vollständige Ausgabe davon.
    I Offline
    I Offline
    ichderarnd
    #2514
    Der erste Lauf für die nodejs 16 war schon aus dem History Buffer raus. Hier der zweite Aufruf mit Update auf die 18.18.1:
    ioBroker nodejs fixer 2023-10-09
    Recommended nodejs-version is: 18.18.1
    Checking your installation now. Please be patient!
    Your current setup is:
    /usr/bin/nodejs         v16.20.2
    /usr/bin/node           v16.20.2
    /usr/bin/npm            8.19.4
    /usr/bin/npx            8.19.4
    /usr/bin/corepack       0.17.0
    We found these nodejs versions available for installation:
    nodejs:
      Installed: 16.20.2-deb-1nodesource1
      Candidate: 16.20.2-deb-1nodesource1
      Version table:
     *** 16.20.2-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
         10.24.0~dfsg-1~deb10u3 500
    Nothing to do - Your installation is using the correct paths.
    You are running nodejs v16.20.2. Do you want to install recommended version 18.18.1?
    Press <y> to continue or any other key to quit
    Trying to fix your installation now. Please be patient.
    Waiting for ioBroker to shut down - Give me a minute...
    *** These repos are active on your system:
    Get:1 http://archive.raspberrypi.org/debian buster InRelease [32.6 kB]
    Get:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
    Get:3 https://apt.pivccu.de/piVCCU testing InRelease [13.6 kB]
    Get:4 http://archive.raspberrypi.org/debian buster/main armhf Packages [400 kB]
    Get:5 http://raspbian.raspberrypi.org/raspbian buster/non-free Sources [139 kB]
    Get:6 https://apt.pivccu.de/piVCCU testing/main armhf Packages [13.8 kB]
    Get:7 http://raspbian.raspberrypi.org/raspbian buster/main Sources [11.4 MB]
    Get:8 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [13.0 MB]
    Get:9 http://raspbian.raspberrypi.org/raspbian buster/non-free armhf Packages [110 kB]
    Fetched 25.1 MB in 11s (2383 kB/s)
    Reading package lists... Done
    *** Installing ca-certificates, curl and gnupg, just in case they are missing.
    *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
    deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
    Package: nodejs
    Pin: origin deb.nodesource.com
    Pin-Priority: 1001
    *** These repos are active after the adjustments:
    Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Hit:2 http://archive.raspberrypi.org/debian buster InRelease
    Hit:3 https://apt.pivccu.de/piVCCU testing InRelease
    Get:4 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
    Get:5 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages [5529 B]
    Fetched 17.7 kB in 1s (13.3 kB/s)
    Installing the recommended nodejs version now!
    Extracting templates from packages: 100%
    (Reading database ... 266527 files and directories currently installed.)
    Preparing to unpack .../ncurses-bin_6.1+20181013-2+deb10u4_armhf.deb ...
    Unpacking ncurses-bin (6.1+20181013-2+deb10u4) over (6.1+20181013-2+deb10u3) ...
    Setting up ncurses-bin (6.1+20181013-2+deb10u4) ...
    Preparing to unpack .../ncurses-base_6.1+20181013-2+deb10u4_all.deb ...
    Unpacking ncurses-base (6.1+20181013-2+deb10u4) over (6.1+20181013-2+deb10u3) ...
    Setting up ncurses-base (6.1+20181013-2+deb10u4) ...
    Preparing to unpack .../0-python2.7-dev_2.7.16-2+deb10u3_armhf.deb ...
    Unpacking python2.7-dev (2.7.16-2+deb10u3) over (2.7.16-2+deb10u2) ...
    Preparing to unpack .../1-libpython2.7-dev_2.7.16-2+deb10u3_armhf.deb ...
    Unpacking libpython2.7-dev:armhf (2.7.16-2+deb10u3) over (2.7.16-2+deb10u2) ...
    Preparing to unpack .../2-libpython2.7_2.7.16-2+deb10u3_armhf.deb ...
    Unpacking libpython2.7:armhf (2.7.16-2+deb10u3) over (2.7.16-2+deb10u2) ...
    Preparing to unpack .../3-python2.7_2.7.16-2+deb10u3_armhf.deb ...
    Unpacking python2.7 (2.7.16-2+deb10u3) over (2.7.16-2+deb10u2) ...
    Preparing to unpack .../4-libpython2.7-stdlib_2.7.16-2+deb10u3_armhf.deb ...
    Unpacking libpython2.7-stdlib:armhf (2.7.16-2+deb10u3) over (2.7.16-2+deb10u2) ...
    Preparing to unpack .../5-python2.7-minimal_2.7.16-2+deb10u3_armhf.deb ...
    Unpacking python2.7-minimal (2.7.16-2+deb10u3) over (2.7.16-2+deb10u2) ...
    Preparing to unpack .../6-libpython2.7-minimal_2.7.16-2+deb10u3_armhf.deb ...
    Unpacking libpython2.7-minimal:armhf (2.7.16-2+deb10u3) over (2.7.16-2+deb10u2) ...
    Preparing to unpack .../7-libncurses6_6.1+20181013-2+deb10u4_armhf.deb ...
    Unpacking libncurses6:armhf (6.1+20181013-2+deb10u4) over (6.1+20181013-2+deb10u3) ...
    Preparing to unpack .../8-libtinfo6_6.1+20181013-2+deb10u4_armhf.deb ...
    Unpacking libtinfo6:armhf (6.1+20181013-2+deb10u4) over (6.1+20181013-2+deb10u3) ...
    Setting up libtinfo6:armhf (6.1+20181013-2+deb10u4) ...
    Preparing to unpack .../libncursesw6_6.1+20181013-2+deb10u4_armhf.deb ...
    Unpacking libncursesw6:armhf (6.1+20181013-2+deb10u4) over (6.1+20181013-2+deb10u3) ...
    Setting up libncursesw6:armhf (6.1+20181013-2+deb10u4) ...
    Preparing to unpack .../00-vim-tiny_2%3a8.1.0875-5+deb10u6_armhf.deb ...
    Unpacking vim-tiny (2:8.1.0875-5+deb10u6) over (2:8.1.0875-5+deb10u5) ...
    Preparing to unpack .../01-xxd_2%3a8.1.0875-5+deb10u6_armhf.deb ...
    Unpacking xxd (2:8.1.0875-5+deb10u6) over (2:8.1.0875-5+deb10u5) ...
    Preparing to unpack .../02-vim-common_2%3a8.1.0875-5+deb10u6_all.deb ...
    Unpacking vim-common (2:8.1.0875-5+deb10u6) over (2:8.1.0875-5+deb10u5) ...
    Preparing to unpack .../03-ncurses-term_6.1+20181013-2+deb10u4_all.deb ...
    Unpacking ncurses-term (6.1+20181013-2+deb10u4) over (6.1+20181013-2+deb10u3) ...
    Preparing to unpack .../04-ghostscript_9.27~dfsg-2+deb10u9_armhf.deb ...
    Unpacking ghostscript (9.27~dfsg-2+deb10u9) over (9.27~dfsg-2+deb10u8) ...
    Preparing to unpack .../05-libgs9_9.27~dfsg-2+deb10u9_armhf.deb ...
    Unpacking libgs9:armhf (9.27~dfsg-2+deb10u9) over (9.27~dfsg-2+deb10u8) ...
    Preparing to unpack .../06-libgs9-common_9.27~dfsg-2+deb10u9_all.deb ...
    Unpacking libgs9-common (9.27~dfsg-2+deb10u9) over (9.27~dfsg-2+deb10u8) ...
    Preparing to unpack .../07-libdw1_0.176-1.1+deb10u1_armhf.deb ...
    Unpacking libdw1:armhf (0.176-1.1+deb10u1) over (0.176-1.1) ...
    Preparing to unpack .../08-libelf1_0.176-1.1+deb10u1_armhf.deb ...
    Unpacking libelf1:armhf (0.176-1.1+deb10u1) over (0.176-1.1) ...
    Preparing to unpack .../09-libflac-dev_1.3.2-3+deb10u3_armhf.deb ...
    Unpacking libflac-dev:armhf (1.3.2-3+deb10u3) over (1.3.2-3+deb10u2) ...
    Preparing to unpack .../10-libflac8_1.3.2-3+deb10u3_armhf.deb ...
    Unpacking libflac8:armhf (1.3.2-3+deb10u3) over (1.3.2-3+deb10u2) ...
    Preparing to unpack .../11-libncursesw5_6.1+20181013-2+deb10u4_armhf.deb ...
    Unpacking libncursesw5:armhf (6.1+20181013-2+deb10u4) over (6.1+20181013-2+deb10u3) ...
    Preparing to unpack .../12-libncurses5_6.1+20181013-2+deb10u4_armhf.deb ...
    Unpacking libncurses5:armhf (6.1+20181013-2+deb10u4) over (6.1+20181013-2+deb10u3) ...
    Preparing to unpack .../13-libtinfo5_6.1+20181013-2+deb10u4_armhf.deb ...
    Unpacking libtinfo5:armhf (6.1+20181013-2+deb10u4) over (6.1+20181013-2+deb10u3) ...
    Preparing to unpack .../14-libpq-dev_11.21-0+deb10u2_armhf.deb ...
    Unpacking libpq-dev (11.21-0+deb10u2) over (11.19-0+deb10u1) ...
    Preparing to unpack .../15-libpq5_11.21-0+deb10u2_armhf.deb ...
    Unpacking libpq5:armhf (11.21-0+deb10u2) over (11.19-0+deb10u1) ...
    Preparing to unpack .../16-libvpx-dev_1.7.0-3+deb10u2_armhf.deb ...
    Unpacking libvpx-dev:armhf (1.7.0-3+deb10u2) over (1.7.0-3+deb10u1) ...
    Preparing to unpack .../17-libvpx5_1.7.0-3+deb10u2_armhf.deb ...
    Unpacking libvpx5:armhf (1.7.0-3+deb10u2) over (1.7.0-3+deb10u1) ...
    Preparing to unpack .../18-libwebp-dev_0.6.1-2+deb10u3_armhf.deb ...
    Unpacking libwebp-dev:armhf (0.6.1-2+deb10u3) over (0.6.1-2+deb10u2) ...
    Preparing to unpack .../19-libwebp6_0.6.1-2+deb10u3_armhf.deb ...
    Unpacking libwebp6:armhf (0.6.1-2+deb10u3) over (0.6.1-2+deb10u2) ...
    Preparing to unpack .../20-libwebpmux3_0.6.1-2+deb10u3_armhf.deb ...
    Unpacking libwebpmux3:armhf (0.6.1-2+deb10u3) over (0.6.1-2+deb10u2) ...
    Preparing to unpack .../21-libwebpdemux2_0.6.1-2+deb10u3_armhf.deb ...
    Unpacking libwebpdemux2:armhf (0.6.1-2+deb10u3) over (0.6.1-2+deb10u2) ...
    Preparing to unpack .../22-libx11-dev_2%3a1.6.7-1+deb10u4_armhf.deb ...
    Unpacking libx11-dev:armhf (2:1.6.7-1+deb10u4) over (2:1.6.7-1+deb10u3) ...
    Preparing to unpack .../23-libx11-data_2%3a1.6.7-1+deb10u4_all.deb ...
    Unpacking libx11-data (2:1.6.7-1+deb10u4) over (2:1.6.7-1+deb10u3) ...
    Preparing to unpack .../24-libx11-6_2%3a1.6.7-1+deb10u4_armhf.deb ...
    Unpacking libx11-6:armhf (2:1.6.7-1+deb10u4) over (2:1.6.7-1+deb10u3) ...
    Preparing to unpack .../25-libx11-xcb-dev_2%3a1.6.7-1+deb10u4_armhf.deb ...
    Unpacking libx11-xcb-dev:armhf (2:1.6.7-1+deb10u4) over (2:1.6.7-1+deb10u3) ...
    Preparing to unpack .../26-libx11-xcb1_2%3a1.6.7-1+deb10u4_armhf.deb ...
    Unpacking libx11-xcb1:armhf (2:1.6.7-1+deb10u4) over (2:1.6.7-1+deb10u3) ...
    Preparing to unpack .../27-libxpm4_1%3a3.5.12-1+deb10u2_armhf.deb ...
    Unpacking libxpm4:armhf (1:3.5.12-1+deb10u2) over (1:3.5.12-1+deb10u1) ...
    Preparing to unpack .../28-nodejs_18.18.1-1nodesource1_armhf.deb ...
    Detected old npm client, removing...
    Unpacking nodejs (18.18.1-1nodesource1) over (16.20.2-deb-1nodesource1) ...
    Preparing to unpack .../29-openjdk-11-jdk_11.0.20+8-1~deb10u1_armhf.deb ...
    Unpacking openjdk-11-jdk:armhf (11.0.20+8-1~deb10u1) over (11.0.18+10-1~deb10u1) ...
    Preparing to unpack .../30-openjdk-11-jdk-headless_11.0.20+8-1~deb10u1_armhf.deb ...
    Unpacking openjdk-11-jdk-headless:armhf (11.0.20+8-1~deb10u1) over (11.0.18+10-1~deb10u1) ...
    Preparing to unpack .../31-openjdk-11-jre_11.0.20+8-1~deb10u1_armhf.deb ...
    Unpacking openjdk-11-jre:armhf (11.0.20+8-1~deb10u1) over (11.0.18+10-1~deb10u1) ...
    Preparing to unpack .../32-openjdk-11-jre-headless_11.0.20+8-1~deb10u1_armhf.deb ...
    Unpacking openjdk-11-jre-headless:armhf (11.0.20+8-1~deb10u1) over (11.0.18+10-1~deb10u1) ...
    Preparing to unpack .../33-python-urllib3_1.24.1-1+deb10u1_all.deb ...
    Unpacking python-urllib3 (1.24.1-1+deb10u1) over (1.24.1-1) ...
    Preparing to unpack .../34-python3-renderpm_3.5.13-1+deb10u2_armhf.deb ...
    Unpacking python3-renderpm:armhf (3.5.13-1+deb10u2) over (3.5.13-1+deb10u1) ...
    Preparing to unpack .../35-python3-reportlab-accel_3.5.13-1+deb10u2_armhf.deb ...
    Unpacking python3-reportlab-accel:armhf (3.5.13-1+deb10u2) over (3.5.13-1+deb10u1) ...
    Preparing to unpack .../36-python3-reportlab_3.5.13-1+deb10u2_all.deb ...
    Unpacking python3-reportlab (3.5.13-1+deb10u2) over (3.5.13-1+deb10u1) ...
    Preparing to unpack .../37-python3-urllib3_1.24.1-1+deb10u1_all.deb ...
    Unpacking python3-urllib3 (1.24.1-1+deb10u1) over (1.24.1-1) ...
    Preparing to unpack .../38-qemu-utils_1%3a3.1+dfsg-8+deb10u11_armhf.deb ...
    Unpacking qemu-utils (1:3.1+dfsg-8+deb10u11) over (1:3.1+dfsg-8+deb10u9) ...
    Setting up libgs9-common (9.27~dfsg-2+deb10u9) ...
    Setting up python-urllib3 (1.24.1-1+deb10u1) ...
    Setting up libx11-xcb1:armhf (2:1.6.7-1+deb10u4) ...
    Setting up python3-renderpm:armhf (3.5.13-1+deb10u2) ...
    Setting up libgs9:armhf (9.27~dfsg-2+deb10u9) ...
    Setting up openjdk-11-jre-headless:armhf (11.0.20+8-1~deb10u1) ...
    Installing new version of config file /etc/java-11-openjdk/security/java.policy ...
    Installing new version of config file /etc/java-11-openjdk/security/java.security ...
    Setting up libpq5:armhf (11.21-0+deb10u2) ...
    Setting up libpq-dev (11.21-0+deb10u2) ...
    Setting up openjdk-11-jdk-headless:armhf (11.0.20+8-1~deb10u1) ...
    Setting up ghostscript (9.27~dfsg-2+deb10u9) ...
    Setting up nodejs (18.18.1-1nodesource1) ...
    Setting up xxd (2:8.1.0875-5+deb10u6) ...
    Setting up libflac8:armhf (1.3.2-3+deb10u3) ...
    Setting up libpython2.7-minimal:armhf (2.7.16-2+deb10u3) ...
    Setting up vim-common (2:8.1.0875-5+deb10u6) ...
    Setting up libx11-data (2:1.6.7-1+deb10u4) ...
    Setting up python2.7-minimal (2.7.16-2+deb10u3) ...
    Setting up libncurses6:armhf (6.1+20181013-2+deb10u4) ...
    Setting up python3-reportlab-accel:armhf (3.5.13-1+deb10u2) ...
    Setting up libwebp6:armhf (0.6.1-2+deb10u3) ...
    Setting up python3-urllib3 (1.24.1-1+deb10u1) ...
    Setting up python3-reportlab (3.5.13-1+deb10u2) ...
    Setting up libx11-6:armhf (2:1.6.7-1+deb10u4) ...
    Setting up qemu-utils (1:3.1+dfsg-8+deb10u11) ...
    Setting up libwebpmux3:armhf (0.6.1-2+deb10u3) ...
    Setting up libtinfo5:armhf (6.1+20181013-2+deb10u4) ...
    Setting up libelf1:armhf (0.176-1.1+deb10u1) ...
    Setting up libvpx5:armhf (1.7.0-3+deb10u2) ...
    Setting up ncurses-term (6.1+20181013-2+deb10u4) ...
    Setting up libdw1:armhf (0.176-1.1+deb10u1) ...
    Setting up libflac-dev:armhf (1.3.2-3+deb10u3) ...
    Setting up libxpm4:armhf (1:3.5.12-1+deb10u2) ...
    Setting up libwebpdemux2:armhf (0.6.1-2+deb10u3) ...
    Setting up libx11-dev:armhf (2:1.6.7-1+deb10u4) ...
    Setting up openjdk-11-jre:armhf (11.0.20+8-1~deb10u1) ...
    Setting up vim-tiny (2:8.1.0875-5+deb10u6) ...
    Setting up libncurses5:armhf (6.1+20181013-2+deb10u4) ...
    Setting up libpython2.7-stdlib:armhf (2.7.16-2+deb10u3) ...
    Setting up libwebp-dev:armhf (0.6.1-2+deb10u3) ...
    Setting up libvpx-dev:armhf (1.7.0-3+deb10u2) ...
    Setting up openjdk-11-jdk:armhf (11.0.20+8-1~deb10u1) ...
    Setting up libncursesw5:armhf (6.1+20181013-2+deb10u4) ...
    Setting up libx11-xcb-dev:armhf (2:1.6.7-1+deb10u4) ...
    Setting up libpython2.7:armhf (2.7.16-2+deb10u3) ...
    Setting up libpython2.7-dev:armhf (2.7.16-2+deb10u3) ...
    Setting up python2.7 (2.7.16-2+deb10u3) ...
    Setting up python2.7-dev (2.7.16-2+deb10u3) ...
    Processing triggers for mime-support (3.62) ...
    Processing triggers for hicolor-icon-theme (0.17-2) ...
    Processing triggers for gnome-menus (3.31.4-3) ...
    Processing triggers for libc-bin (2.28-10+rpt2+rpi1+deb10u2) ...
    Processing triggers for man-db (2.8.5-2) ...
    Processing triggers for desktop-file-utils (0.23-4) ...
    Installing the recommended nodejs version!
    We tried our best to fix your nodejs. Please run iob diag again to verify.
    *** RESTARTING ioBroker NOW! ***
     Please refresh or restart your browser in a few moments.
    "iob diag" findet folgende Fehler:
    Errors in npm tree:
    npm ERR! code ELSPROBLEMS
    npm ERR! extraneous: @types/caseless@0.12.3 /opt/iobroker/node_modules/@types/caseless
    npm ERR! extraneous: @types/request@2.48.9 /opt/iobroker/node_modules/@types/request
    npm ERR! extraneous: @types/tough-cookie@4.0.3 /opt/iobroker/node_modules/@types/tough-cookie
    npm ERR! extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript
    npm ERR! invalid: iobroker.energiefluss@3.5.0 /opt/iobroker/node_modules/iobroker.energiefluss
    npm ERR! invalid: iobroker.sourceanalytix@0.4.12 /opt/iobroker/node_modules/iobroker.sourceanalytix
    npm ERR! invalid: iobroker.vr200@1.1.0 /opt/iobroker/node_modules/iobroker.vr200
    npm ERR! invalid: iobroker.vw-connect@0.1.3 /opt/iobroker/node_modules/iobroker.vw-connect
    npm ERR! extraneous: jsonata@1.8.6 /opt/iobroker/node_modules/jsonata
    npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
    npm ERR! extraneous: picocolors@1.0.0 /opt/iobroker/node_modules/picocolors
    npm ERR! extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
    npm ERR! extraneous: typescript@4.7.4 /opt/iobroker/node_modules/typescript
    npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
    npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
    npm ERR! extraneous: form-data@2.5.1 /opt/iobroker/node_modules/@types/request/node_modules/form-data
    npm ERR! extraneous: debug@4.3.4 /opt/iobroker/node_modules/virtual-tsc/node_modules/debug
    npm ERR! extraneous: ms@2.1.2 /opt/iobroker/node_modules/virtual-tsc/node_modules/ms
    npm ERR! invalid: xmlbuilder@0.4.2 /opt/iobroker/node_modules/xmlbuilder
    npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-10-10T21_14_39_557Z-debug-0.log
      Merkwürdig.
      Mit einer schiefen Installation ist da gar nix merkwürdig. Höchstens verbesserungswürdig.
      I Offline
      I Offline
      ichderarnd
      schrieb am zuletzt editiert von ichderarnd
      #2515
      Mit der schiefen Installation hat's funktioniert...
      Nodejs 18 scheint eine neue Javascript Engine zu haben. An dem npm icmp scheint sich seit 3 Jahren nichts geändert zu haben. Da muss ich morgen weiter suchen.
      Die Raw Sockets sind aktiviert. Daran liegt's nicht.
      • I ichderarnd
        #2516
        @ichderarnd
        Da ist/war aber auch noch wesentlich mehr schief installiert.
        sudo apt update
        sudo apt full-upgrade
        liefert?
        I 1 Antwort Letzte Antwort
          @ichderarnd
          sudo apt update
          liefert?
          I Offline
          I Offline
          ichderarnd
          #2517
          Das liefert nachfolgenden Output. Die oben gezeigten Fehlerausgaben mit "iob diag" bleiben danach bestehen.
          Sollten wir einen anderen Thread nehmen? Das ist zu OT hier...
          ~ $ sudo apt update
          Holen:1 http://archive.raspberrypi.org/debian buster InRelease [32,6 kB]
          Holen:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB]
          OK:3 https://deb.nodesource.com/node_18.x nodistro InRelease
          OK:4 https://apt.pivccu.de/piVCCU testing InRelease
          Holen:5 http://archive.raspberrypi.org/debian buster/main armhf Packages [400 kB]
          Es wurden 447 kB in 1 s geholt (357 kB/s).
          Alle Pakete sind aktuell.
          N: Für das Depot »http://archive.raspberrypi.org/debian buster InRelease« wurde der »Suite«-Wert von »oldstable« in »oldoldstable« geändert.
          ~ $ sudo apt full-upgrade
          Paketaktualisierung (Upgrade) wird berechnet... Fertig
          Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt:
            alsa-base gconf-service gconf2-common gstreamer0.10-alsa
            gstreamer0.10-plugins-base gyp libc-ares2 libexiv2-14 libgconf-2-4
            libgfortran3 libgmime-2.6-0 libgstreamer-plugins-base0.10-0
            libgstreamer0.10-0 libjs-inherits libjs-is-typedarray libllvm6.0
            libmicrodns0 libncurses5 libuv1-dev libva-wayland2 libxfce4util-bin
            libxfce4util-common libxfce4util7 libxfconf-0-2 lockfile-progs lxplug-volume
            node-abbrev node-ajv node-ansi node-ansi-align node-ansi-regex
            node-ansi-styles node-ansistyles node-aproba node-archy
            node-are-we-there-yet node-asn1 node-assert-plus node-asynckit
            node-aws-sign2 node-aws4 node-balanced-match node-bcrypt-pbkdf node-bluebird
            node-boxen node-brace-expansion node-builtin-modules node-builtins
            node-cacache node-call-limit node-camelcase node-caseless node-chalk
            node-chownr node-cli-boxes node-cliui node-clone node-co node-color-convert
            node-color-name node-combined-stream node-concat-map node-concat-stream
            node-config-chain node-console-control-strings node-copy-concurrently
            node-core-util-is node-cross-spawn node-cyclist node-dashdash
            node-decamelize node-decompress-response node-deep-extend node-defaults
            node-delayed-stream node-delegates node-detect-indent node-detect-newline
            node-duplexer3 node-duplexify node-ecc-jsbn node-editor node-encoding
            node-end-of-stream node-errno node-escape-string-regexp node-execa
            node-extend node-extsprintf node-find-up node-flush-write-stream
            node-forever-agent node-form-data node-from2 node-fs-vacuum
            node-fs-write-stream-atomic node-fs.realpath node-gauge node-get-caller-file
            node-get-stream node-getpass node-glob node-got node-graceful-fs
            node-har-schema node-har-validator node-has-flag node-has-symbol-support-x
            node-has-to-string-tag-x node-has-unicode node-hosted-git-info
            node-http-signature node-iconv-lite node-iferr node-import-lazy
            node-imurmurhash node-inflight node-inherits node-ini node-invert-kv
            node-is-builtin-module node-is-npm node-is-object node-is-plain-obj
            node-is-retry-allowed node-is-stream node-is-typedarray node-isarray
            node-isexe node-isstream node-isurl node-jsbn node-json-parse-better-errors
            node-json-schema node-json-stable-stringify node-json-stringify-safe
            node-jsonify node-jsonparse node-jsonstream node-jsprim node-latest-version
            node-lazy-property node-lcid node-libnpx node-locate-path node-lockfile
            node-lowercase-keys node-lru-cache node-mem node-mime-types node-mimic-fn
            node-mimic-response node-minimatch node-minimist node-mississippi
            node-mkdirp node-move-concurrently node-mute-stream node-node-uuid node-nopt
            node-normalize-package-data node-npm-package-arg node-npm-run-path
            node-npmlog node-oauth-sign node-object-assign node-once node-opener
            node-os-locale node-osenv node-p-cancelable node-p-finally node-p-limit
            node-p-locate node-p-timeout node-package-json node-parallel-transform
            node-path-exists node-path-is-absolute node-path-is-inside
            node-performance-now node-prepend-http node-process-nextick-args
            node-promise-inflight node-promzard node-proto-list node-prr node-pump
            node-pumpify node-punycode node-qs node-qw node-rc node-read
            node-read-package-json node-readable-stream node-registry-auth-token
            node-registry-url node-request node-require-directory
            node-require-main-filename node-resolve-from node-retry node-rimraf
            node-run-queue node-safe-buffer node-semver node-semver-diff
            node-set-blocking node-sha node-shebang-command node-shebang-regex
            node-signal-exit node-slash node-slide node-sorted-object node-spdx-correct
            node-spdx-expression-parse node-spdx-license-ids node-sshpk node-ssri
            node-stream-each node-stream-iterate node-stream-shift node-string-decoder
            node-string-width node-strip-ansi node-strip-eof node-strip-json-comments
            node-supports-color node-tar node-term-size node-text-table node-through
            node-through2 node-timed-out node-tough-cookie node-tunnel-agent
            node-tweetnacl node-typedarray node-uid-number node-unique-filename
            node-unpipe node-url-parse-lax node-url-to-options node-util-deprecate
            node-uuid node-validate-npm-package-license node-validate-npm-package-name
            node-verror node-wcwidth.js node-which node-which-module node-wide-align
            node-widest-line node-wrap-ansi node-wrappy node-write-file-atomic
            node-xdg-basedir node-xtend node-y18n node-yallist node-yargs
            node-yargs-parser pimixer pmount point-rpi python-colorzero
            python3-pyperclip python3-thonny rtimucli xfconf
          Verwenden Sie »sudo apt autoremove«, um sie zu entfernen.
          0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
          • I ichderarnd
            ~ $ sudo apt update
            #2518
            Upgraden. Buster ist damit 'TOT'.
              I Offline
              I Offline
              ichderarnd
              #2519
              OK... Nach welcher Anleitung sollte ich vorgehen? Da gibt's ja mehrere Quellen...
              Sollte das "apt autoremove" vorher ausgeführt werden?
              • I ichderarnd
                #2520
                Ich hab mir seinerzeit meine eigene Anleitung geschrieben. Schau durch meine Themen durch.
                  I Offline
                  I Offline
                  ichderarnd
                  #2521
                  Danke, gefunden. Tolle Arbeit ❕ 👍
                  Ich muss es auf's Wochenende verschieben. Leider steht noch Arbeit an.
                  Bin gespannt!
                  • FeuersturmF Offline
                    FeuersturmF Offline
                    Feuersturm
                    #2522
                    Ich hab ein Master/Slave Testsystem und habe gerade mal testweise auf dem Master ein Backup ausgeführt und wollte es danach wiederherstellen.
                    Das Backup wurde auch angeblich erfolgreich durchgeführt.
                    Wenn ich dann das Backup wiederherstellen will, erscheint nur folgendes Bild. ioBroker wurde im Hintergrund gestoppt und läuft nicht mehr und der Restore wird nicht durchgeführt
                    Hat noch jemand dieses Verhalten?
                    Im web Adapter ist folgendes eingestellt
                    Ausführung von Backup welches erfolgreich war
                    Started iobroker ...
                    [DEBUG] [iobroker] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"02:40","debugging":true,"slaveBackup":"Master","everyXDays":"1","deleteBackupAfter":0,"ignoreErrors":false,"dir":"/opt/iobroker","historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
                    [DEBUG] [iobroker] - host.ioBrokerTestsystem 11794 states saved
                    [DEBUG] [iobroker] - host.ioBrokerTestsystem 13146 objects saved
                    [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2023_10_11-21_41_40_backupiobroker.tar.gz
                    [DEBUG] [iobroker] - This backup can only be restored with js-controller version up from 4.1
                    [DEBUG] [iobroker] - done
                    [DEBUG] [clean] - No older backup files are deleted, because this backup was started manually
                    [DEBUG] [clean] - done
                    [DEBUG] [historyHTML] - new history html values created
                    [DEBUG] [historyHTML] - done
                    [DEBUG] [historyHTML] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"02:40","debugging":true,"slaveBackup":"Master","everyXDays":"1","deleteBackupAfter":0,"ignoreErrors":false,"dir":"/opt/iobroker","historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de","time":"11. Oktober 2023 um 21:41 Uhr"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"backupDir":"/opt/iobroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
                    [DEBUG] [historyJSON] - new history json values created
                    [DEBUG] [historyJSON] - done
                    [DEBUG] [historyJSON] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"02:40","debugging":true,"slaveBackup":"Master","everyXDays":"1","deleteBackupAfter":0,"ignoreErrors":false,"dir":"/opt/iobroker","historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de","time":"11. Oktober 2023 um 21:42 Uhr"},"signal":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"backupDir":"/opt/iobroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
                    [EXIT] 0
                    iob diag
                    Skript v.2023-10-10
                    *** BASE SYSTEM ***
                     Static hostname: ioBrokerTestsystem
                           Icon name: computer-container
                             Chassis: container
                      Virtualization: lxc
                    Operating System: Ubuntu 22.04.3 LTS
                              Kernel: Linux 6.2.16-14-pve
                        Architecture: x86-64
                    model name      : Intel(R) Celeron(R) CPU  N3150  @ 1.60GHz
                    Docker          : false
                    Virtualization  : lxc
                    Kernel          : x86_64
                    Userland        : amd64
                    Systemuptime and Load:
                     21:37:36 up 3 min,  2 users,  load average: 9.68, 5.20, 4.05
                    CPU threads: 4
                    *** Time and Time Zones ***
                                   Local time: Wed 2023-10-11 21:37:36 CEST
                               Universal time: Wed 2023-10-11 19:37:36 UTC
                                     RTC time: n/a
                                  NTP service: inactive
                              RTC in local TZ: no
                    *** User and Groups ***
                    proxmox
                    /home/proxmox
                    proxmox sudo iobroker
                    *** X-Server-Setup ***
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Mem:            6.0G        1.9G        3.6G        0.0K        543M        4.1G
                    Swap:           1.5G          0B        1.5G
                    Total:          7.5G        1.9G        5.1G
                             6000 M total memory
                             1876 M used memory
                              179 M active memory
                             2129 M inactive memory
                             3579 M free memory
                                0 M buffer memory
                              544 M swap cache
                             1512 M total swap
                                0 M used swap
                             1512 M free swap
                    *** FAILED SERVICES ***
                      UNIT                   LOAD   ACTIVE SUB    DESCRIPTION
                    * run-rpc_pipefs.mount   loaded failed failed RPC Pipe File System
                    * sys-kernel-debug.mount loaded failed failed Kernel Debug File System
                    2 loaded units listed.
                    *** FILESYSTEM ***
                    Filesystem                          Type   Size  Used Avail Use% Mounted on
                    /dev/mapper/data2-vm--3108--disk--1 ext4    20G   14G  4.6G  76% /
                    none                                tmpfs  492K  4.0K  488K   1% /dev
                    tmpfs                               tmpfs  7.7G     0  7.7G   0% /dev/shm
                    tmpfs                               tmpfs  3.1G  152K  3.1G   1% /run
                    tmpfs                               tmpfs  5.0M     0  5.0M   0% /run/lock
                    tmpfs                               tmpfs  1.0M     0  1.0M   0% /run/credentials/systemd-sysusers.service
                    tmpfs                               tmpfs  1.6G     0  1.6G   0% /run/user/1001
                    dmesg: read kernel buffer failed: Operation not permitted
                    TARGET SOURCE                              FSTYPE OPTIONS
                    /      /dev/mapper/data2-vm--3108--disk--1 ext4   rw,relatime,stripe=16
                    /var:
                    1.2G    /var/
                    478M    /var/lib
                    387M    /var/log
                    377M    /var/log/journal/db91a8d9813048b3b0d9627361bf92a2
                    Archived and active journals take up 40.0M in the file system.
                    /opt/iobroker/backups:
                    99M     /opt/iobroker/backups/
                    /opt/iobroker/iobroker-data:
                    998M    /opt/iobroker/iobroker-data/
                    770M    /opt/iobroker/iobroker-data/files
                    179M    /opt/iobroker/iobroker-data/files/vis-2
                    163M    /opt/iobroker/iobroker-data/backup-objects
                    162M    /opt/iobroker/iobroker-data/files/vis
                    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                    24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.5f66c5d9.js.map
                    24M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.9f2a6569.js.map
                    24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.5f66c5d9.js.map
                    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.eafddf6f.js.map
                    USB-Devices by-id:
                    find: '/dev/serial/by-id/': No such file or directory
                    *** NodeJS-Installation ***
                    /usr/bin/nodejs         v18.18.1
                    /usr/bin/node           v18.18.1
                    /usr/bin/npm            9.8.1
                    /usr/bin/npx            9.8.1
                    /usr/bin/corepack       0.19.0
                    nodejs:
                      Installed: 18.18.1-1nodesource1
                      Candidate: 18.18.1-1nodesource1
                      Version table:
                     *** 18.18.1-1nodesource1 1001
                            500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                         18.18.0-1nodesource1 1001
                         18.17.1-1nodesource1 1001
                         18.17.0-1nodesource1 1001
                         18.16.1-1nodesource1 1001
                         18.16.0-1nodesource1 1001
                         18.15.0-1nodesource1 1001
                         18.14.2-1nodesource1 1001
                         18.14.1-1nodesource1 1001
                         18.14.0-1nodesource1 1001
                         18.13.0-1nodesource1 1001
                         18.12.0-1nodesource1 1001
                         18.11.0-1nodesource1 1001
                         18.10.0-1nodesource1 1001
                         18.9.1-1nodesource1 1001
                         18.9.0-1nodesource1 1001
                         18.8.0-1nodesource1 1001
                         18.7.0-1nodesource1 1001
                         18.6.0-1nodesource1 1001
                         18.5.0-1nodesource1 1001
                         18.4.0-1nodesource1 1001
                         18.3.0-1nodesource1 1001
                         18.2.0-1nodesource1 1001
                         18.1.0-1nodesource1 1001
                         18.0.0-1nodesource1 1001
                         12.22.9~dfsg-1ubuntu3 500
                            500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
                    No problems detected
                    Errors in npm tree:
                    *** ioBroker-Installation ***
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    Core adapters versions
                    js-controller:  5.0.13
                    admin:          6.10.7
                    javascript:     7.1.5
                    Adapters from github:   5
                    Adapter State
                    + system.adapter.admin.0                  : admin                 : ioBrokerTestsystem                       -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                    + system.adapter.backitup.0               : backitup              : ioBrokerTestsystem                       -  enabled
                      system.adapter.benchmark.0              : benchmark             : ioBrokerTestsystem                       - disabled
                      system.adapter.daswetter.0              : daswetter             : ioBrokerTestsystem                       -  enabled
                      system.adapter.device-watcher.0         : device-watcher        : ioBrokerTestsystem                       - disabled
                      system.adapter.devices.0                : devices               : ioBrokerTestsystem                       - disabled
                      system.adapter.discovery.0              : discovery             : ioBrokerNew                              - disabled
                      system.adapter.dwd.0                    : dwd                   : ioBrokerTestsystem                       -  enabled
                    + system.adapter.echarts.0                : echarts               : ioBrokerTestsystem                       -  enabled
                    + system.adapter.fritzbox.0               : fritzbox              : ioBrokerTestsystem                       -  enabled
                    + system.adapter.fully-tablet-control.0   : fully-tablet-control  : ioBrokerTestsystem                       -  enabled
                      system.adapter.history.1                : history               : ioBrokerNew                              - disabled
                    + system.adapter.hm-rega.0                : hm-rega               : ioBrokerTestsystem                       -  enabled
                    + system.adapter.hm-rpc.0                 : hm-rpc                : ioBrokerTestsystem                       -  enabled, port: 0
                      system.adapter.hue.0                    : hue                   : ioBrokerTestsystem                       - disabled, port: 443
                      system.adapter.ical.0                   : ical                  : ioBrokerTestsystem                       -  enabled
                      system.adapter.ical.1                   : ical                  : ioBrokerTestsystem                       -  enabled
                      system.adapter.ical.2                   : ical                  : ioBrokerTestsystem                       -  enabled
                      system.adapter.ical.3                   : ical                  : ioBrokerTestsystem                       -  enabled
                      system.adapter.ical.4                   : ical                  : ioBrokerTestsystem                       -  enabled
                      system.adapter.ical.5                   : ical                  : ioBrokerTestsystem                       -  enabled
                      system.adapter.icons-material-png.0     : icons-material-png    : ioBrokerTestsystem                       - disabled
                      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBrokerTestsystem                       - disabled
                      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : ioBrokerTestsystem                       - disabled
                    + system.adapter.influxdb.0               : influxdb              : ioBrokerTestsystem                       -  enabled, port: 8086
                    + system.adapter.info.0                   : info                  : ioBrokerTestsystem                       -  enabled
                    + system.adapter.javascript.0             : javascript            : ioBrokerTestsystem                       -  enabled
                      system.adapter.mqtt.0                   : mqtt                  : ioBrokerTestsystem                       - disabled, port: 1883, bind: 0.0.0.0
                    + system.adapter.nina.0                   : nina                  : ioBrokerTestsystem                       -  enabled
                      system.adapter.openweathermap.0         : openweathermap        : ioBrokerTestsystem                       -  enabled
                      system.adapter.proxmox.0                : proxmox               : ioBrokerTestsystem                       -  enabled, port: 8006
                      system.adapter.rainbird.0               : rainbird              : ioBrokerTestsystem                       - disabled
                      system.adapter.samsung-community.0      : samsung-community     : ioBrokerTestsystem                       - disabled
                      system.adapter.sayit.0                  : sayit                 : ioBrokerTestsystem                       - disabled, port: 0
                    + system.adapter.scenes.0                 : scenes                : ioBrokerTestsystem                       -  enabled
                      system.adapter.scheduler.0              : scheduler             : ioBrokerTestsystem                       - disabled
                      system.adapter.simple-api.0             : simple-api            : ioBrokerTestsystem                       - disabled, port: 8087, bind: 0.0.0.0, run as: admin
                      system.adapter.socketio.0               : socketio              : ioBrokerTestsystem                       - disabled, port: 8084, bind: 192.168.178.77, run as: admin
                      system.adapter.spotify-premium.0        : spotify-premium       : ioBrokerTestsystem                       - disabled
                      system.adapter.sql.0                    : sql                   : ioBrokerNew                              - disabled, port: 3306
                    + system.adapter.tankerkoenig.0           : tankerkoenig          : ioBrokerTestsystem                       -  enabled
                      system.adapter.telegram.0               : telegram              : ioBrokerTestsystem                       - disabled, port: 8443, bind: 0.0.0.0
                    + system.adapter.tr-064.0                 : tr-064                : ioBrokerTestsystem                       -  enabled
                    + system.adapter.trashschedule.0          : trashschedule         : ioBrokerTestsystem                       -  enabled
                    + system.adapter.unifi.0                  : unifi                 : ioBrokerTestsystem                       -  enabled
                    + system.adapter.valloxmv.0               : valloxmv              : ioBrokerTestsystem                       -  enabled, port: 80
                      system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : ioBrokerTestsystem                       - disabled
                      system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : ioBrokerTestsystem                       - disabled
                      system.adapter.vis-2-widgets-jaeger-design.0: vis-2-widgets-jaeger-design: ioBrokerTestsystem                       - disabled
                      system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: ioBrokerTestsystem                       - disabled
                    + system.adapter.vis-2.0                  : vis-2                 : ioBrokerTestsystem                       -  enabled
                      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBrokerTestsystem                       - disabled
                      system.adapter.vis-google-fonts.0       : vis-google-fonts      : ioBrokerTestsystem                       -  enabled
                      system.adapter.vis-history.0            : vis-history           : ioBrokerTestsystem                       - disabled
                    + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBrokerTestsystem                       -  enabled
                      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBrokerTestsystem                       - disabled
                      system.adapter.vis-justgage.0           : vis-justgage          : ioBrokerTestsystem                       - disabled
                      system.adapter.vis-map.0                : vis-map               : ioBrokerTestsystem                       - disabled
                      system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBrokerTestsystem                       - disabled
                      system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBrokerTestsystem                       - disabled
                      system.adapter.vis.0                    : vis                   : ioBrokerTestsystem                       - disabled
                    + system.adapter.web.0                    : web                   : ioBrokerTestsystem                       -  enabled, port: 8082, bind: 192.168.178.77, run as: admin
                      system.adapter.worx.0                   : worx                  : ioBrokerTestsystem                       - disabled
                    + instance is alive
                    + system.adapter.proxmox.0                : proxmox               : ioBrokerTestsystem                       -  enabled, port: 8006
                    ioBroker-Repositories
                    Active repo(s): beta
                    Installed ioBroker-Instances
                    Used repository: beta
                    Adapter    "admin"        : 6.10.6   , installed 6.10.7
                    Adapter    "backitup"     : 2.8.4    , installed 2.8.4
                    Adapter    "benchmark"    : 1.1.4    , installed 1.1.4
                    Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
                    Adapter    "device-watcher": 2.9.3   , installed 2.9.3
                    Adapter    "devices"      : 1.1.5    , installed 1.1.5
                    Adapter    "echarts"      : 1.5.4    , installed 1.5.4
                    Adapter    "fritzbox"     : 0.5.0    , installed 0.5.0
                    Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
                    Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
                    Adapter    "hue"          : 3.10.0   , installed 3.10.0
                    Adapter    "ical"         : 1.13.3   , installed 1.13.3
                    Adapter    "info"         : 2.0.0    , installed 2.0.0
                    Adapter    "javascript"   : 7.1.5    , installed 7.1.5
                    Controller "js-controller": 5.0.13   , installed 5.0.13
                    Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
                    Adapter    "nina"         : 0.0.25   , installed 0.0.25
                    Adapter    "openweathermap": 0.4.5   , installed 0.4.5
                    Adapter    "proxmox"      : 2.1.0    , installed 2.1.0
                    Adapter    "rainbird"     : 0.2.2    , installed 0.2.3
                    Adapter    "sayit"        : 3.0.5    , installed 3.0.5
                    Adapter    "scheduler"    : 1.1.9    , installed 1.1.9
                    Adapter    "socketio"     : 6.5.7    , installed 6.5.7
                    Adapter    "spotify-premium": 1.2.2  , installed 1.2.2
                    Adapter    "telegram"     : 2.0.1    , installed 2.0.1
                    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
                    Adapter    "unifi"        : 0.6.6    , installed 0.6.6
                    Adapter    "valloxmv"     : 1.2.0    , installed 1.2.0
                    Adapter    "vis-2"        : 2.3.0    , installed 2.3.0
                    Adapter    "vis-2-widgets-energy": 0.3.8, installed 0.3.8
                    Adapter    "vis-2-widgets-gauges": 0.2.0, installed 0.2.0
                    Adapter    "vis-2-widgets-jaeger-design": 1.0.4, installed 1.0.4
                    Adapter    "vis-2-widgets-material": 1.2.1, installed 1.2.1
                    Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
                    Adapter    "web"          : 6.1.4    , installed 6.1.4
                    Adapter    "worx"         : 2.3.3    , installed 2.3.3
                    Adapter    "ws"           : 2.5.7    , installed 2.5.7
                    Objects and States
                    Objects:        13136
                    States:         11795
                    Hit:1 https://deb.nodesource.com/node_18.x nodistro InRelease
                    Hit:2 http://archive.ubuntu.com/ubuntu jammy InRelease
                    Hit:3 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
                    Hit:4 http://archive.ubuntu.com/ubuntu jammy-security InRelease
                    Pending Updates: 0
                    *** Listening Ports ***
                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          96948094   130/sshd: /usr/sbin
                    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          96947834   1/init
                    tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      102        96948831   87/systemd-resolved
                    tcp        0      0 192.168.178.77:8082     0.0.0.0:*               LISTEN      1000       96966280   938/io.web.0
                    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       96949593   110/iobroker.js-con
                    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       96949587   110/iobroker.js-con
                    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          96949002   300/master
                    tcp        0      0 192.168.178.77:2010     0.0.0.0:*               LISTEN      1000       96960268   666/io.hm-rpc.0
                    tcp6       0      0 :::22                   :::*                    LISTEN      0          96948096   130/sshd: /usr/sbin
                    tcp6       0      0 :::111                  :::*                    LISTEN      0          96947836   1/init
                    tcp6       0      0 :::3000                 :::*                    LISTEN      108        96949149   109/grafana-server
                    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          96949003   300/master
                    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       96954033   525/io.admin.0
                    udp        0      0 127.0.0.53:53           0.0.0.0:*                           102        96948830   87/systemd-resolved
                    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          96947835   1/init
                    udp6       0      0 :::111                  :::*                                0          96947837   1/init
                    xxx
                    Log in der Browser Konsole beim Starten der Wiederherstellung
                    [2023-10-11T19:25:55.789Z] ws connection error: CLOSE_GOING_AWAY socket.io.js:68:32
                    [2023-10-11T19:25:55.790Z] Start reconnect 0 socket.io.js:66:41
                    [2023-10-11T19:25:55.790Z] Try to connect socket.io.js:66:41
                    [2023-10-11T19:25:55.791Z] ws connection error: CLOSE_GOING_AWAY 8571.7d32213d.chunk.js:2:116526
                    [2023-10-11T19:25:55.792Z] Start reconnect 0 8571.7d32213d.chunk.js:2:116526
                    [2023-10-11T19:25:55.862Z] Try to connect 8571.7d32213d.chunk.js:2:116526
                    Diese Seite verwendet die nicht standardisierte Eigenschaft "zoom". Stattdessen sollte calc() in den entsprechenden Eigenschaftswerten oder "transform" zusammen mit "transform-origin: 0 0" verwendet werden. 192.168.178.77:8081
                    iobroker.admin@6.10.7 bootstrap.jsx:20:8
                    [2023-10-11T19:25:56.455Z] Try to connect instrument.ts:144
                    Stored version: , new version: 6.10.7 instrument.ts:144
                    Connected: true instrument.ts:144
                    Diese Seite befindet sich im Kompatibilitätsmodus (Quirks). Das Seitenlayout kann beeinflusst werden. Verwenden Sie für den Standardmodus "<!DOCTYPE html>". tab_m.html
                    Layout-Darstellung wurde erzwungen, bevor die Seite vollständig geladen war. Falls Stylesheet noch nicht geladen sind, kann dies zu einem kurzzeitigen Darstellung des Inhalts ohne Formatierung führen. stylesheets-manager.js:545:10
                    [2023-10-11T19:26:00.824Z] Try to connect socket.io.js:66:41
                    "Backitup": {"en": "Backitup", "de": "Backitup", "ru": "Backitup", "pt": "Backitup", "nl": "Backitup", "fr": "Backitup", "es": "Backitup", "pl": "Backitup", "it": "Backitup", "zh-cn": "Backitup"}, translate.js:24:17
                    current theme: react-colored tab_m.js:102:13
                    "ioBroker": {"en": "ioBroker", "de": "ioBroker", "ru": "ioBroker", "pt": "ioBroker", "nl": "ioBroker", "fr": "ioBroker", "es": "ioBroker", "pl": "ioBroker", "it": "ioBroker", "zh-cn": "ioBroker"}, translate.js:24:17
                    system.adapter.admin.0 instrument.ts:144
                    system.adapter.backitup.0 instrument.ts:144
                    system.adapter.benchmark.0 instrument.ts:144
                    system.adapter.daswetter.0 instrument.ts:144
                    system.adapter.device-watcher.0 instrument.ts:144
                    system.adapter.devices.0 instrument.ts:144
                    system.adapter.discovery.0 instrument.ts:144
                    system.adapter.dwd.0 instrument.ts:144
                    system.adapter.echarts.0 instrument.ts:144
                    system.adapter.fritzbox.0 instrument.ts:144
                    system.adapter.fully-tablet-control.0 instrument.ts:144
                    system.adapter.history.1 instrument.ts:144
                    system.adapter.hm-rega.0 instrument.ts:144
                    system.adapter.hm-rpc.0 instrument.ts:144
                    system.adapter.hue.0 instrument.ts:144
                    system.adapter.ical.0 instrument.ts:144
                    system.adapter.ical.1 instrument.ts:144
                    system.adapter.ical.2 instrument.ts:144
                    system.adapter.ical.3 instrument.ts:144
                    system.adapter.ical.4 instrument.ts:144
                    system.adapter.ical.5 instrument.ts:144
                    system.adapter.icons-material-png.0 instrument.ts:144
                    system.adapter.icons-mfd-svg.0 instrument.ts:144
                    system.adapter.icons-ultimate-png.0 instrument.ts:144
                    system.adapter.influxdb.0 instrument.ts:144
                    system.adapter.info.0 instrument.ts:144
                    system.adapter.javascript.0 instrument.ts:144
                    system.adapter.mqtt.0 instrument.ts:144
                    system.adapter.nina.0 instrument.ts:144
                    system.adapter.openweathermap.0 instrument.ts:144
                    system.adapter.proxmox.0 instrument.ts:144
                    system.adapter.rainbird.0 instrument.ts:144
                    system.adapter.samsung-community.0 instrument.ts:144
                    system.adapter.sayit.0 instrument.ts:144
                    system.adapter.scenes.0 instrument.ts:144
                    system.adapter.scheduler.0 instrument.ts:144
                    system.adapter.simple-api.0 instrument.ts:144
                    system.adapter.socketio.0 instrument.ts:144
                    system.adapter.spotify-premium.0 instrument.ts:144
                    system.adapter.sql.0 instrument.ts:144
                    system.adapter.tankerkoenig.0 instrument.ts:144
                    system.adapter.telegram.0 instrument.ts:144
                    system.adapter.tr-064.0 instrument.ts:144
                    system.adapter.trashschedule.0 instrument.ts:144
                    system.adapter.unifi.0 instrument.ts:144
                    system.adapter.valloxmv.0 instrument.ts:144
                    system.adapter.vis.0 instrument.ts:144
                    system.adapter.vis-2.0 instrument.ts:144
                    system.adapter.vis-2-widgets-energy.0 instrument.ts:144
                    system.adapter.vis-2-widgets-gauges.0 instrument.ts:144
                    system.adapter.vis-2-widgets-jaeger-design.0 instrument.ts:144
                    system.adapter.vis-2-widgets-material.0 instrument.ts:144
                    system.adapter.vis-fancyswitch.0 instrument.ts:144
                    system.adapter.vis-google-fonts.0 instrument.ts:144
                    system.adapter.vis-history.0 instrument.ts:144
                    system.adapter.vis-inventwo.0 instrument.ts:144
                    system.adapter.vis-jqui-mfd.0 instrument.ts:144
                    system.adapter.vis-justgage.0 instrument.ts:144
                    system.adapter.vis-map.0 instrument.ts:144
                    system.adapter.vis-materialdesign.0 instrument.ts:144
                    system.adapter.vis-timeandweather.0 instrument.ts:144
                    system.adapter.web.0 instrument.ts:144
                    system.adapter.worx.0 instrument.ts:144
                    getInstances: 75 instrument.ts:144
                    Diese Seite befindet sich im Kompatibilitätsmodus (Quirks). Das Seitenlayout kann beeinflusst werden. Verwenden Sie für den Standardmodus "<!DOCTYPE html>". index_m.html
                    [2023-10-11T19:26:52.015Z] Try to connect socket.io.js:66:41
                    Passwort-Felder sind in einem unsicheren (http://) Iframe vorhanden. Dies ist ein Sicherheitsrisiko, durch das Zugangsdaten gestohlen werden können. index_m.html
                    "Signal": {"en": "Signal", "de": "Signal", "ru": "Signal", "pt": "Signal", "nl": "Signal", "fr": "Signal", "es": "Signal", "pl": "Signal", "it": "Signal", "zh-cn": "Signal"}, translate.js:24:17
                    "Discord": {"en": "Discord", "de": "Discord", "ru": "Discord", "pt": "Discord", "nl": "Discord", "fr": "Discord", "es": "Discord", "pl": "Discord", "it": "Discord", "zh-cn": "Discord"}, translate.js:24:17
                    "http": {"en": "http", "de": "http", "ru": "http", "pt": "http", "nl": "http", "fr": "http", "es": "http", "pl": "http", "it": "http", "zh-cn": "http"}, translate.js:24:17
                    "https": {"en": "https", "de": "https", "ru": "https", "pt": "https", "nl": "https", "fr": "https", "es": "https", "pl": "https", "it": "https", "zh-cn": "https"}, translate.js:24:17
                    "1.x": {"en": "1.x", "de": "1.x", "ru": "1.x", "pt": "1.x", "nl": "1.x", "fr": "1.x", "es": "1.x", "pl": "1.x", "it": "1.x", "zh-cn": "1.x"}, translate.js:24:17
                    "2.x": {"en": "2.x", "de": "2.x", "ru": "2.x", "pt": "2.x", "nl": "2.x", "fr": "2.x", "es": "2.x", "pl": "2.x", "it": "2.x", "zh-cn": "2.x"}, translate.js:24:17
                    Restore Type: local index_m.js:722:25
                    Object { data: {…} }
                    index_m.js:725:29
                    Object { local: {…} }
                    index_m.js:736:33
                    "OK": {"en": "OK", "de": "OK", "ru": "OK", "pt": "OK", "nl": "OK", "fr": "OK", "es": "OK", "pl": "OK", "it": "OK", "zh-cn": "OK"}, translate.js:24:17
                    "Started restore ...": {"en": "Started restore ...", "de": "Started restore ...", "ru": "Started restore ...", "pt": "Started restore ...", "nl": "Started restore ...", "fr": "Started restore ...", "es": "Started restore ...", "pl": "Started restore ...", "it": "Started restore ...", "zh-cn": "Started restore ..."}, translate.js:24:17
                    "ioBroker will be stopped and started again. Please wait": {"en": "ioBroker will be stopped and started again. Please wait", "de": "ioBroker will be stopped and started again. Please wait", "ru": "ioBroker will be stopped and started again. Please wait", "pt": "ioBroker will be stopped and started again. Please wait", "nl": "ioBroker will be stopped and started again. Please wait", "fr": "ioBroker will be stopped and started again. Please wait", "es": "ioBroker will be stopped and started again. Please wait", "pl": "ioBroker will be stopped and started again. Please wait", "it": "ioBroker will be stopped and started again. Please wait", "zh-cn": "ioBroker will be stopped and started again. Please wait"}, translate.js:24:17
                    Speicherverbrauch von "will-change" ist zu hoch. Die Budget-Grenze ist die Fläche des Dokuments multipliziert mit 3 (869076 px). Vorkommen von "will-change", die das Budget überschreiten, werden ignoriert. index_m.html
                    Restore finish! index_m.js:849:53
                    Restore Url: http://192.168.178.77:8091/backitup-restore.html index_m.js:852:57
                    [2023-10-11T19:27:40.593Z] ws connection error: CLOSE_ABNORMAL socket.io.js:68:32
                    [2023-10-11T19:27:40.594Z] Start reconnect 0 socket.io.js:66:41
                    [2023-10-11T19:27:40.594Z] Try to connect socket.io.js:66:41
                    [2023-10-11T19:27:40.595Z] ws connection error: CLOSE_ABNORMAL instrument.ts:144
                    [2023-10-11T19:27:40.596Z] Start reconnect 0 instrument.ts:144
                    [2023-10-11T19:27:40.661Z] Try to connect instrument.ts:144
                    [2023-10-11T19:27:43.601Z] No READY flag received in 3 seconds. Re-init socket.io.js:67:32
                    Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.77:8081//adapter/backitup?sid=1697052460594 aufbauen. socket.io.js:140:21
                    [2023-10-11T19:27:43.602Z] Start reconnect 1 socket.io.js:66:41
                    Die Verbindung zu ws://192.168.178.77:8081//adapter/backitup?sid=1697052460594 wurde unterbrochen, während die Seite geladen wurde. socket.io.js:140:21
                    [2023-10-11T19:27:43.608Z] Reconnect is already running 1 socket.io.js:66:41
                    [2023-10-11T19:27:43.608Z] ws connection error: CLOSE_ABNORMAL socket.io.js:68:32
                    [2023-10-11T19:27:43.693Z] No READY flag received in 3 seconds. Re-init instrument.ts:144
                    Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.77:8081/?sid=1697052460662&name=admin aufbauen. socket.io.js:140:21
                    [2023-10-11T19:27:43.694Z] Start reconnect 1 instrument.ts:144
                    Die Verbindung zu ws://192.168.178.77:8081/?sid=1697052460662&name=admin wurde unterbrochen, während die Seite geladen wurde. socket.io.js:140:21
                    [2023-10-11T19:27:43.697Z] Reconnect is already running 1 instrument.ts:144
                    [2023-10-11T19:27:43.697Z] ws connection error: CLOSE_ABNORMAL instrument.ts:144
                    [2023-10-11T19:27:44.610Z] Try to connect socket.io.js:66:41
                    [2023-10-11T19:27:44.706Z] Try to connect instrument.ts:144
                    [2023-10-11T19:27:45.751Z] ws connection error: CLOSE_ABNORMAL socket.io.js:68:32
                    [2023-10-11T19:27:45.751Z] Start reconnect 2 socket.io.js:66:41
                    [2023-10-11T19:27:47.717Z] No READY flag received in 3 seconds. Re-init instrument.ts:144
                    Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.77:8081/?sid=1697052464707&name=admin aufbauen. socket.io.js:140:21
                    [2023-10-11T19:27:47.718Z] Start reconnect 2 instrument.ts:144
                    Die Verbindung zu ws://192.168.178.77:8081/?sid=1697052464707&name=admin wurde unterbrochen, während die Seite geladen wurde. socket.io.js:140:21
                    [2023-10-11T19:27:47.725Z] Reconnect is already running 2 instrument.ts:144
                    [2023-10-11T19:27:47.727Z] ws connection error: CLOSE_ABNORMAL instrument.ts:144
                    [2023-10-11T19:27:47.729Z] Reconnect is already running 2 instrument.ts:144
                    [2023-10-11T19:27:49.720Z] Try to connect instrument.ts:144
                    [2023-10-11T19:27:52.738Z] No READY flag received in 3 seconds. Re-init instrument.ts:144
                    Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.77:8081/?sid=1697052469720&name=admin aufbauen. socket.io.js:140:21
                    [2023-10-11T19:27:52.738Z] Start reconnect 3 instrument.ts:144
                    Die Verbindung zu ws://192.168.178.77:8081/?sid=1697052469720&name=admin wurde unterbrochen, während die Seite geladen wurde. socket.io.js:140:21
                    [2023-10-11T19:27:52.744Z] Reconnect is already running 3 instrument.ts:144
                    [2023-10-11T19:27:52.745Z] ws connection error: CLOSE_ABNORMAL instrument.ts:144
                    [2023-10-11T19:27:52.746Z] Reconnect is already running 3 instrument.ts:144
                    [2023-10-11T19:27:55.805Z] Try to connect instrument.ts:144
                    Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.77:8081/?sid=1697052475811&name=admin aufbauen. socket.io.js:140:21
                    [2023-10-11T19:27:57.881Z] Start reconnect 4 instrument.ts:144
                    [2023-10-11T19:27:57.881Z] ws connection error: CLOSE_ABNORMAL instrument.ts:144
                    [2023-10-11T19:27:57.882Z] Reconnect is already running 4 instrument.ts:144
                    [2023-10-11T19:28:01.888Z] Try to connect instrument.ts:144
                    Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.77:8081/?sid=1697052481894&name=admin aufbauen. socket.io.js:140:21
                    [2023-10-11T19:28:03.962Z] Start reconnect 5 instrument.ts:144
                    [2023-10-11T19:28:03.963Z] ws connection error: CLOSE_ABNORMAL instrument.ts:144
                    [2023-10-11T19:28:03.964Z] Reconnect is already running 5 instrument.ts:144
                    [2023-10-11T19:28:08.968Z] Try to connect instrument.ts:144
                    Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.77:8081/?sid=1697052488968&name=admin aufbauen. socket.io.js:140:21
                    [2023-10-11T19:28:11.022Z] Start reconnect 5 instrument.ts:144
                    [2023-10-11T19:28:11.023Z] ws connection error: CLOSE_ABNORMAL instrument.ts:144
                    [2023-10-11T19:28:11.025Z] Reconnect is already running 5 instrument.ts:144
                    [2023-10-11T19:28:16.076Z] Try to connect instrument.ts:144
                    Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.77:8081/?sid=1697052496077&name=admin aufbauen. socket.io.js:140:21
                    [2023-10-11T19:28:18.138Z] Start reconnect 5 instrument.ts:144
                    [2023-10-11T19:28:18.139Z] ws connection error: CLOSE_ABNORMAL instrument.ts:144
                    [2023-10-11T19:28:18.141Z] Reconnect is already running 5 instrument.ts:144
                    [2023-10-11T19:28:23.147Z] Try to connect instrument.ts:144
                    Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.77:8081/?sid=1697052503147&name=admin aufbauen. socket.io.js:140:21
                    [2023-10-11T19:28:25.202Z] Start reconnect 5 instrument.ts:144
                    [2023-10-11T19:28:25.203Z] ws connection error: CLOSE_ABNORMAL instrument.ts:144
                    [2023-10-11T19:28:25.204Z] Reconnect is already running 5 instrument.ts:144
                    [2023-10-11T19:28:30.235Z] Try to connect instrument.ts:144
                    Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.77:8081/?sid=1697052510236&name=admin aufbauen. socket.io.js:140:21
                    [2023-10-11T19:28:32.291Z] Start reconnect 5 instrument.ts:144
                    [2023-10-11T19:28:32.291Z] ws connection error: CLOSE_ABNORMAL instrument.ts:144
                    [2023-10-11T19:28:32.292Z] Reconnect is already running 5 instrument.ts:144
                    [2023-10-11T19:28:37.296Z] Try to connect instrument.ts:144
                    Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.77:8081/?sid=1697052517298&name=admin aufbauen. socket.io.js:140:21
                    [2023-10-11T19:28:39.395Z] Start reconnect 5 instrument.ts:144
                    [2023-10-11T19:28:39.396Z] ws connection error: CLOSE_ABNORMAL instrument.ts:144
                    [2023-10-11T19:28:39.397Z] Reconnect is already running 5 instrument.ts:144
                    [2023-10-11T19:28:44.436Z] Try to connect instrument.ts:144
                    Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.77:8081/?sid=1697052524436&name=admin aufbauen. socket.io.js:140:21
                    [2023-10-11T19:28:47.063Z] Start reconnect 5 instrument.ts:144
                    [2023-10-11T19:28:47.063Z] ws connection error: CLOSE_ABNORMAL instrument.ts:144
                    [2023-10-11T19:28:47.064Z] Reconnect is already running 5 instrument.ts:144
                    [2023-10-11T19:28:52.065Z] Try to connect instrument.ts:144
                    [2023-10-11T19:28:55.080Z] No READY flag received in 3 seconds. Re-init instrument.ts:144
                    Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.77:8081/?sid=1697052532066&name=admin aufbauen. socket.io.js:140:21
                    [2023-10-11T19:28:55.081Z] Start reconnect 5 instrument.ts:144
                    Die Verbindung zu ws://192.168.178.77:8081/?sid=1697052532066&name=admin wurde unterbrochen, während die Seite geladen wurde. socket.io.js:140:21
                    [2023-10-11T19:28:55.085Z] Reconnect is already running 5 instrument.ts:144
                    [2023-10-11T19:28:55.086Z] ws connection error: CLOSE_ABNORMAL instrument.ts:144
                    [2023-10-11T19:28:55.087Z] Reconnect is already running 5 instrument.ts:144
                    [2023-10-11T19:29:00.130Z] Try to connect instrument.ts:144
                    Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.77:8081/?sid=1697052540133&name=admin aufbauen. socket.io.js:140:21
                    [2023-10-11T19:29:02.185Z] Start reconnect 5 instrument.ts:144
                    [2023-10-11T19:29:02.186Z] ws connection error: CLOSE_ABNORMAL instrument.ts:144
                    [2023-10-11T19:29:02.189Z] Reconnect is already running 5 instrument.ts:144
                    [2023-10-11T19:29:07.203Z] Try to connect instrument.ts:144
                    [2023-10-11T19:29:10.219Z] No READY flag received in 3 seconds. Re-init instrument.ts:144
                    Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.77:8081/?sid=1697052547203&name=admin aufbauen. socket.io.js:140:21
                    [2023-10-11T19:29:10.219Z] Start reconnect 5 instrument.ts:144
                    Die Verbindung zu ws://192.168.178.77:8081/?sid=1697052547203&name=admin wurde unterbrochen, während die Seite geladen wurde. socket.io.js:140:21
                    [2023-10-11T19:29:10.223Z] Reconnect is already running 5 instrument.ts:144
                    [2023-10-11T19:29:10.223Z] ws connection error: CLOSE_ABNORMAL instrument.ts:144
                    [2023-10-11T19:29:10.224Z] Reconnect is already running 5 instrument.ts:144
                    [2023-10-11T19:29:15.290Z] Try to connect instrument.ts:144
                    Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.77:8081/?sid=1697052555291&name=admin aufbauen. socket.io.js:140:21
                    [2023-10-11T19:29:17.347Z] Start reconnect 5 instrument.ts:144
                    [2023-10-11T19:29:17.348Z] ws connection error: CLOSE_ABNORMAL instrument.ts:144
                    [2023-10-11T19:29:17.349Z] Reconnect is already running 5 instrument.ts:144
                    [2023-10-11T19:29:22.377Z] Try to connect instrument.ts:144
                    [2023-10-11T19:29:25.408Z] No READY flag received in 3 seconds. Re-init instrument.ts:144
                    Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.77:8081/?sid=1697052562378&name=admin aufbauen. socket.io.js:140:21
                    [2023-10-11T19:29:25.409Z] Start reconnect 5 instrument.ts:144
                    Die Verbindung zu ws://192.168.178.77:8081/?sid=1697052562378&name=admin wurde unterbrochen, während die Seite geladen wurde. socket.io.js:140:21
                    [2023-10-11T19:29:25.414Z] Reconnect is already running 5 instrument.ts:144
                    [2023-10-11T19:29:25.414Z] ws connection error: CLOSE_ABNORMAL instrument.ts:144
                    [2023-10-11T19:29:25.415Z] Reconnect is already running 5 instrument.ts:144
                    [2023-10-11T19:29:30.424Z] Try to connect instrument.ts:144
                    [2023-10-11T19:29:33.480Z] No READY flag received in 3 seconds. Re-init instrument.ts:144
                    Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.77:8081/?sid=1697052570424&name=admin aufbauen. socket.io.js:140:21
                    [2023-10-11T19:29:33.480Z] Start reconnect 5 instrument.ts:144
                    Die Verbindung zu ws://192.168.178.77:8081/?sid=1697052570424&name=admin wurde unterbrochen, während die Seite geladen wurde. socket.io.js:140:21
                    [2023-10-11T19:29:33.482Z] Reconnect is already running 5 instrument.ts:144
                    [2023-10-11T19:29:33.483Z] ws connection error: CLOSE_ABNORMAL instrument.ts:144
                    [2023-10-11T19:29:33.484Z] Reconnect is already running 5 instrument.ts:144
                    [2023-10-11T19:29:38.484Z] Try to connect instrument.ts:144
                    Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.77:8081/?sid=1697052578484&name=admin aufbauen. socket.io.js:140:21
                    [2023-10-11T19:29:40.532Z] Start reconnect 5 instrument.ts:144
                    [2023-10-11T19:29:40.533Z] ws connection error: CLOSE_ABNORMAL instrument.ts:144
                    [2023-10-11T19:29:40.534Z] Reconnect is already running 5 instrument.ts:144
                    [2023-10-11T19:29:45.537Z] Try to connect instrument.ts:144
                    [2023-10-11T19:29:48.553Z] No READY flag received in 3 seconds. Re-init instrument.ts:144
                    Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.77:8081/?sid=1697052585538&name=admin aufbauen. socket.io.js:140:21
                    [2023-10-11T19:29:48.553Z] Start reconnect 5 instrument.ts:144
                    Die Verbindung zu ws://192.168.178.77:8081/?sid=1697052585538&name=admin wurde unterbrochen, während die Seite geladen wurde. socket.io.js:140:21
                    [2023-10-11T19:29:48.559Z] Reconnect is already running 5 instrument.ts:144
                    [2023-10-11T19:29:48.559Z] ws connection error: CLOSE_ABNORMAL instrument.ts:144
                    [2023-10-11T19:29:48.560Z] Reconnect is already running 5 instrument.ts:144
                    [2023-10-11T19:29:53.564Z] Try to connect instrument.ts:144
                    [2023-10-11T19:29:56.569Z] No READY flag received in 3 seconds. Re-init instrument.ts:144
                    Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.77:8081/?sid=1697052593565&name=admin aufbauen. socket.io.js:140:21
                    [2023-10-11T19:29:56.569Z] Start reconnect 5 instrument.ts:144
                    Die Verbindung zu ws://192.168.178.77:8081/?sid=1697052593565&name=admin wurde unterbrochen, während die Seite geladen wurde. socket.io.js:140:21
                    [2023-10-11T19:29:56.571Z] Reconnect is already running 5 instrument.ts:144
                    [2023-10-11T19:29:56.571Z] ws connection error: CLOSE_ABNORMAL instrument.ts:144
                    [2023-10-11T19:29:56.572Z] Reconnect is already running 5 instrument.ts:144
                    [2023-10-11T19:30:01.572Z] Try to connect instrument.ts:144
                    [2023-10-11T19:30:04.589Z] No READY flag received in 3 seconds. Re-init instrument.ts:144
                    Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.77:8081/?sid=1697052601573&name=admin aufbauen. socket.io.js:140:21
                    [2023-10-11T19:30:04.589Z] Start reconnect 5 instrument.ts:144
                    Die Verbindung zu ws://192.168.178.77:8081/?sid=1697052601573&name=admin wurde unterbrochen, während die Seite geladen wurde. socket.io.js:140:21
                    [2023-10-11T19:30:04.670Z] Reconnect is already running 5 instrument.ts:144
                    [2023-10-11T19:30:04.671Z] ws connection error: CLOSE_ABNORMAL instrument.ts:144
                    [2023-10-11T19:30:04.671Z] Reconnect is already running 5 instrument.ts:144
                    [2023-10-11T19:30:09.597Z] Try to connect instrument.ts:144
                    Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.77:8081/?sid=1697052609598&name=admin aufbauen. socket.io.js:140:21
                    [2023-10-11T19:30:11.655Z] Start reconnect 5 instrument.ts:144
                    [2023-10-11T19:30:11.656Z] ws connection error: CLOSE_ABNORMAL instrument.ts:144
                    [2023-10-11T19:30:11.656Z] Reconnect is already running 5 instrument.ts:144
                    [2023-10-11T19:30:16.659Z] Try to connect instrument.ts:144
                    [2023-10-11T19:30:19.660Z] No READY flag received in 3 seconds. Re-init instrument.ts:144
                    Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.77:8081/?sid=1697052616659&name=admin aufbauen. socket.io.js:140:21
                    [2023-10-11T19:30:19.661Z] Start reconnect 5 instrument.ts:144
                    Die Verbindung zu ws://192.168.178.77:8081/?sid=1697052616659&name=admin wurde unterbrochen, während die Seite geladen wurde. socket.io.js:140:21
                    [2023-10-11T19:30:19.664Z] Reconnect is already running 5 instrument.ts:144
                    [2023-10-11T19:30:19.664Z] ws connection error: CLOSE_ABNORMAL instrument.ts:144
                    [2023-10-11T19:30:24.673Z] Try to connect instrument.ts:144
                    [2023-10-11T19:30:27.676Z] No READY flag received in 3 seconds. Re-init instrument.ts:144
                    Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.77:8081/?sid=1697052624673&name=admin aufbauen. socket.io.js:140:21
                    [2023-10-11T19:30:27.676Z] Start reconnect 5 instrument.ts:144
                    Die Verbindung zu ws://192.168.178.77:8081/?sid=1697052624673&name=admin wurde unterbrochen, während die Seite geladen wurde. socket.io.js:140:21
                    [2023-10-11T19:30:27.678Z] Reconnect is already running 5 instrument.ts:144
                    [2023-10-11T19:30:27.678Z] ws connection error: CLOSE_ABNORMAL instrument.ts:144
                    [2023-10-11T19:30:27.679Z] Reconnect is already running 5 instrument.ts:144
                    [2023-10-11T19:30:32.678Z] Try to connect instrument.ts:144
                    [2023-10-11T19:30:35.694Z] No READY flag received in 3 seconds. Re-init instrument.ts:144
                    Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.77:8081/?sid=1697052632678&name=admin aufbauen. socket.io.js:140:21
                    [2023-10-11T19:30:35.695Z] Start reconnect 5 instrument.ts:144
                    Die Verbindung zu ws://192.168.178.77:8081/?sid=1697052632678&name=admin wurde unterbrochen, während die Seite geladen wurde. socket.io.js:140:21
                    [2023-10-11T19:30:35.696Z] Reconnect is already running 5 instrument.ts:144
                    [2023-10-11T19:30:35.696Z] ws connection error: CLOSE_ABNORMAL instrument.ts:144
                    [2023-10-11T19:30:35.697Z] Reconnect is already running 5 instrument.ts:144
                    [2023-10-11T19:30:40.705Z] Try to connect instrument.ts:144
                    [2023-10-11T19:30:43.710Z] No READY flag received in 3 seconds. Re-init instrument.ts:144
                    Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.77:8081/?sid=1697052640705&name=admin aufbauen. socket.io.js:140:21
                    [2023-10-11T19:30:43.711Z] Start reconnect 5 instrument.ts:144
                    Die Verbindung zu ws://192.168.178.77:8081/?sid=1697052640705&name=admin wurde unterbrochen, während die Seite geladen wurde. socket.io.js:140:21
                    [2023-10-11T19:30:43.713Z] Reconnect is already running 5 instrument.ts:144
                    [2023-10-11T19:30:43.714Z] ws connection error: CLOSE_ABNORMAL instrument.ts:144
                    [2023-10-11T19:30:43.715Z] Reconnect is already running 5 instrument.ts:144
                    [2023-10-11T19:30:48.782Z] Try to connect instrument.ts:144
                    [2023-10-11T19:30:51.818Z] No READY flag received in 3 seconds. Re-init instrument.ts:144
                    Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.77:8081/?sid=1697052648782&name=admin aufbauen. socket.io.js:140:21
                    [2023-10-11T19:30:51.819Z] Start reconnect 5 instrument.ts:144
                    Die Verbindung zu ws://192.168.178.77:8081/?sid=1697052648782&name=admin wurde unterbrochen, während die Seite geladen wurde. socket.io.js:140:21
                    [2023-10-11T19:30:51.821Z] Reconnect is already running 5 instrument.ts:144
                    [2023-10-11T19:30:51.821Z] ws connection error: CLOSE_ABNORMAL instrument.ts:144
                    [2023-10-11T19:30:57.495Z] Try to connect instrument.ts:144
                    Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.77:8081/?sid=1697052657496&name=admin aufbauen. socket.io.js:140:21
                    [2023-10-11T19:30:59.563Z] Start reconnect 5 instrument.ts:144
                    [2023-10-11T19:30:59.563Z] ws connection error: CLOSE_ABNORMAL instrument.ts:144
                    [2023-10-11T19:30:59.564Z] Reconnect is already running 5 instrument.ts:144
                    Thomas BraunT simatecS 2 Antworten Letzte Antwort
                    • FeuersturmF Feuersturm
                      [EXIT] 0
                      iob diag
                      Skript v.2023-10-10
                      *** BASE SYSTEM ***
                               Chassis: container
                        Virtualization: lxc
                      Docker          : false
                      Kernel          : x86_64
                      Userland        : amd64
                      CPU threads: 4
                                       RTC time: n/a
                                RTC in local TZ: no
                      proxmox
                      /home/proxmox
                      X-Server:       false
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Swap:           1.5G          0B        1.5G
                               6000 M total memory
                               1876 M used memory
                                179 M active memory
                               3579 M free memory
                                  0 M buffer memory
                                544 M swap cache
                               1512 M total swap
                                  0 M used swap
                               1512 M free swap
                      *** FILESYSTEM ***
                      /var:
                      1.2G    /var/
                      478M    /var/lib
                      387M    /var/log
                      USB-Devices by-id:
                      /usr/bin/npm            9.8.1
                      /usr/bin/npx            9.8.1
                      nodejs:
                        Version table:
                      Errors in npm tree:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      admin:          6.10.7
                      javascript:     7.1.5
                      Adapter State
                      + instance is alive
                      Objects and States
                      Objects:        13136
                      States:         11795
                      Reading package lists...
                      Pending Updates: 0
                      xxx
                      index_m.js:725:29
                      index_m.js:736:33
                      #2523
                      @feuersturm sagte in Test Adapter ioBroker.backitup v2.8.x:
                      • run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
                      Da klemmt es wohl beim mount irgendwo.
                      Wird das Backup auf eine Freigabe geschoben?
                        FeuersturmF Offline
                        FeuersturmF Offline
                        Feuersturm
                        #2524
                        @thomas-braun Nein, bei dem Testsystem wird das Backup lokal abgelegt
                          [EXIT] 0
                          iob diag
                          Skript v.2023-10-10
                          *** BASE SYSTEM ***
                                   Chassis: container
                            Virtualization: lxc
                          Docker          : false
                          Kernel          : x86_64
                          Userland        : amd64
                          CPU threads: 4
                                           RTC time: n/a
                                    RTC in local TZ: no
                          proxmox
                          /home/proxmox
                          X-Server:       false
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Swap:           1.5G          0B        1.5G
                                   6000 M total memory
                                   1876 M used memory
                                    179 M active memory
                                   3579 M free memory
                                      0 M buffer memory
                                    544 M swap cache
                                   1512 M total swap
                                      0 M used swap
                                   1512 M free swap
                          *** FILESYSTEM ***
                          /var:
                          1.2G    /var/
                          478M    /var/lib
                          387M    /var/log
                          USB-Devices by-id:
                          /usr/bin/npm            9.8.1
                          /usr/bin/npx            9.8.1
                          nodejs:
                            Version table:
                          Errors in npm tree:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          admin:          6.10.7
                          javascript:     7.1.5
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        13136
                          States:         11795
                          Pending Updates: 0
                          xxx
                          index_m.js:725:29
                          index_m.js:736:33
                          simatecS Online
                          simatecS Online
                          simatec
                          #2525
                          @feuersturm socket hat hier keinen Einfluss, da ja iob komplett gestoppt ist. Backitup spannt einen eigenen Webserver für das restore Interface auf.
                          Auf welchen System hast du dein Testsystem laufen? Docker?
                          • Besuche meine Github Seite
                          • HowTo Restore ioBroker
                            simatecS Online
                            simatecS Online
                            simatec
                            #2526
                            @feuersturm Normal sollte es so aussehen ... Ist gerade mit aktueller Backitup Version getestet
                            • simatecS simatec
                              FeuersturmF Offline
                              FeuersturmF Offline
                              Feuersturm
                              #2527
                              @simatec sagte in Test Adapter ioBroker.backitup v2.8.x:
                              Nein, es läuft unter proxmox in einem lxc Container
                                simatecS Online
                                simatecS Online
                                simatec
                                #2528
                                @feuersturm gut bei mir in dem test auch. Ein lxc mit debian12
                                • simatecS simatec
                                  FeuersturmF Offline
                                  FeuersturmF Offline
                                  Feuersturm
                                  #2529
                                  @simatec Ich hab es mit meinem Firefoxbrowser getestet. Kann es nochmal mit meinem Chromebrowser testen ob es sich dort anders verhält.
                                  • mickymM Offline
                                    mickymM Offline
                                    mickym
                                    #2530
                                    Ich hab mal ein neues Issue für das Node-Red Backup erstellt.
                                    https://github.com/simatec/ioBroker.backitup/issues/1005
                                    Im Prinzip ist das Backup für die 1. Instanz nun voll nutzbar - man muss aber manuell noch ein npm install ausführen.
                                    Zusätzliche Instanzen werden aber nicht erkannt.
                                      simatecS Online
                                      simatecS Online
                                      simatec
                                      #2531
                                      @feuersturm ja das wäre gut. Eventuell blockt der Firefox Popups
                                      • mickymM mickym
                                        simatecS Online
                                        simatecS Online
                                        simatec
                                        #2532
                                        @mickym npm muss manuell ausgeführt werden. Wegen der unterschiedlichen Instanzen muss ich schauen. Bei mir waren die Tests alle in Ordnung
                                        • simatecS simatec
                                          mickymM Offline
                                          mickymM Offline
                                          mickym
                                          #2533
                                          @simatec Nun das klingt so, dass Meldungen nicht erwünscht sind.
                                          Bei mir wird nur die Instanz 0 gesichert und die Instanz 1 nicht.
                                          Warum man den npm install nicht ausführen kann, erschließt sich mir zwar nicht, vielleicht sollte man dann ggf. einen kleinen Hinweis vermerken.
                                          Wie gesagt, es ist ein großer Schritt vorwärts - aber wenn hier mein Feedback nicht erwünscht ist, dann mach das Issue einfach wieder zu.
