  4. Vis-2(.0) - Neuer Adapter als Beta
691 Beiträge 101 Kommentatoren 302.6k Aufrufe 115 Beobachtet
  • D Digi-Bit
    und die "metro Tile Navigation" gehen auch nicht....
    hat jemand noch eine Idee ?
    Benutz hier keiner ein Navi Icon ????
    wie ändert ihr den die VIS Ansicht ???
    mfg
    Digi-Bit
    iobroker.vis-2@2.2.4 using theme "dark"
    Prompt.js:14
    Prompt.js:15 Nice to see you here! :) Join our dev community here https://github.com/ioBroker/ioBroker or here https://github.com/iobroker-community-adapters
    Prompt.js:16 Help us to create open source project with reactJS!
    Prompt.js:17 See you :)
    socket.io.js:66 [2023-09-10T17:55:18.974Z] Try to connect
    fetch.ts:45     POST https://sentry.iobroker.net/api/232/envelope/?sentry_key=db8b6e837c71447a876069559a00a742&sentry_version=7&sentry_client=sentry.javascript.browser%2F7.66.0 net::ERR_BLOCKED_BY_ADBLOCKER
    (anonymous) @ fetch.ts:45
    (anonymous) @ base.ts:76
    add @ promisebuffer.ts:49
    a @ base.ts:92
    value @ baseclient.ts:713
    value @ baseclient.ts:353
    value @ baseclient.ts:223
    value @ hub.ts:480
    value @ hub.ts:412
    fn @ sdk.ts:206
    (anonymous) @ sdk.ts:235
    cn @ sdk.ts:125
    (anonymous) @ GenericApp.js:262
    Promise.then (async)
    onReady @ GenericApp.js:246
    (anonymous) @ LegacyConnection.js:487
    (anonymous) @ LegacyConnection.js:448
    value @ LegacyConnection.js:416
    value @ LegacyConnection.js:427
    value @ LegacyConnection.js:378
    (anonymous) @ LegacyConnection.js:271
    SocketClient.findAnswer @ socket.io.js:304
    socket.onmessage @ socket.io.js:212
    instrument.ts:139 Version vis-jqui-mfd: 1.0.12
    instrument.ts:139 Metro version: "1.2.0"
    instrument.ts:139 Version vis-weather: 2.5.6
    instrument.ts:139 Version justgage: 1.0.2
    instrument.ts:139 Version netatmo-energy: 0.1.0
    instrument.ts:139 Version openligadb: 0.5.0
    instrument.ts:139 Version trashschedule: 2.2.0
    instrument.ts:139 Version Info-Adapter-Widget: 1.9.26
    instrument.ts:139 Download the Vue Devtools extension for a better development experience:
    https://github.com/vuejs/vue-devtools
    instrument.ts:139 You are running Vue in development mode.
    Make sure to turn on production mode when deploying for production.
    See more tips at https://vuejs.org/guide/deployment.html
    instrument.ts:139 Version vis-materialdesign: 0.5.9
    fetch.ts:126     POST https://sentry.iobroker.net/api/77/envelope/?sentry_key=888b0efc877b4b12a8a83e3c1fb7fe1a&sentry_version=7 net::ERR_BLOCKED_BY_ADBLOCKER
    (anonymous) @ fetch.ts:126
    t @ syncpromise.ts:34
    n.Ft @ fetch.ts:125
    n.sendSession @ fetch.ts:91
    t.sendSession @ basebackend.ts:108
    t.ht @ baseclient.ts:262
    t.captureSession @ baseclient.ts:158
    value @ hub.ts:480
    value @ hub.ts:425
    value @ hub.ts:454
    (anonymous) @ sdk.ts:199
    t.init @ sdk.ts:94
    _initializeSentry @ widgets.min.js:1
    await in initializeSentry (async)
    (anonymous) @ materialdesign.js:35
    (anonymous) @ widgets.min.js:1
    (anonymous) @ visEngine.jsx:1173
    emit @ visEngine.jsx:1173
    getObject @ widgets.min.js:1
    getVersion @ widgets.min.js:1
    (anonymous) @ materialdesign.js:32
    a @ helpers.ts:98
    setTimeout (async)
    (anonymous) @ trycatch.ts:120
    waitForVisConnected @ widgets.min.js:1
    showVersion @ materialdesign.js:31
    baseclient.ts:160 Uncaught (in promise) TypeError: t.update is not a function
       at t.captureSession (baseclient.ts:160:15)
       at e.value (hub.ts:480:1)
       at e.value (hub.ts:425:1)
       at e.value (hub.ts:454:1)
       at sdk.ts:199:9
       at t.init (sdk.ts:94:5)
       at Object._initializeSentry (widgets.min.js:1:20151)
       at Object.initializeSentry (widgets.min.js:1:19863)
    t.captureSession @ baseclient.ts:160
    value @ hub.ts:480
    value @ hub.ts:425
    value @ hub.ts:454
    t.init @ sdk.ts:94
    a @ helpers.ts:98
    setTimeout (async)
    instrument.ts:139 Version vis-material-advanced: 1.7.3
    instrument.ts:139 common.visWidgets.i18n is deprecated. Use common.visWidgets.openweathermap.i18n instead.
    (anonymous) @ instrument.ts:139
    (anonymous) @ instrument.ts:129
    l @ visUtils.jsx:846
    r @ visUtils.jsx:841
    (anonymous) @ visUtils.jsx:839
    g @ visUtils.jsx:832
    (anonymous) @ visWidgetsCatalog.jsx:30
    sentryWrapped @ helpers.ts:87
    setTimeout (async)
    (anonymous) @ trycatch.ts:119
    (anonymous) @ visWidgetsCatalog.jsx:29
    value @ visWidgetsCatalog.jsx:28
    (anonymous) @ App.jsx:616
    f @ regeneratorRuntime.js:45
    (anonymous) @ regeneratorRuntime.js:133
    (anonymous) @ regeneratorRuntime.js:74
    r @ asyncToGenerator.js:3
    o @ asyncToGenerator.js:22
    (anonymous) @ asyncToGenerator.js:27
    (anonymous) @ asyncToGenerator.js:19
    (anonymous) @ App.jsx:620
    onLoaded @ App.jsx:801
    (anonymous) @ visEngine.jsx:1506
    r @ asyncToGenerator.js:12
    (anonymous) @ visEngine.jsx:1511
    (anonymous) @ visEngine.jsx:219
    i @ visEngine.jsx:209
    Ia @ react-dom.production.min.js:147
    ji @ react-dom.production.min.js:198
    yl @ react-dom.production.min.js:292
    gs @ react-dom.production.min.js:280
    Ms @ react-dom.production.min.js:280
    zs @ react-dom.production.min.js:280
    as @ react-dom.production.min.js:268
    x @ scheduler.production.min.js:13
    T @ scheduler.production.min.js:14
    DevTools failed to load source map: Could not load content for http://25.25.50.100:12085/vis-2/widgets/openweathermap/static/js/src_translations_js.8cc6492a.chunk.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
    DevTools failed to load source map: Could not load content for http://25.25.50.100:12085/vis-2/widgets/vis-2-widgets-material/static/js/src_translations_js.395fc3f6.chunk.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
    DevTools failed to load source map: Could not load content for http://25.25.50.100:12085/vis-2/widgets/vis-2-widgets-gauges/static/js/src_translations_js.cace16e5.chunk.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
    DevTools failed to load source map: Could not load content for http://25.25.50.100:12085/vis-2/widgets/vis-2-widgets-energy/static/js/src_translations_js.10c291be.chunk.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
    DevTools failed to load source map: Could not load content for http://25.25.50.100:12085/vis-2/widgets/openweathermap/static/css/src_react-weather_Weather_js-webpack_sharing_consume_default_iobroker_vis-2-widgets-react-dev-fe17a4.83721eea.chunk.css.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
    DevTools failed to load source map: Could not load content for http://25.25.50.100:12085/vis-2/widgets/vis-2-widgets-material/static/css/src_RGBLight_jsx-node_modules_react-icons_lib_esm_index_js-node_modules_babel_runtime_helpers-6abf93.1cc15eaf.chunk.css.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
    DevTools failed to load source map: Could not load content for http://25.25.50.100:12085/vis-2/widgets/vis-2-widgets-material/static/css/src_Map_jsx-node_modules_leaflet_dist_leaflet_css-node_modules_babel_runtime_helpers_esm_obje-1f1968.c7bfc0ae.chunk.css.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
    DevTools failed to load source map: Could not load content for http://25.25.50.100:12085/vis-2/widgets/openweathermap/static/js/src_react-weather_Weather_js-webpack_sharing_consume_default_iobroker_vis-2-widgets-react-dev-fe17a4.08a2daf7.chunk.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
    DevTools failed to load source map: Could not load content for http://25.25.50.100:12085/vis-2/widgets/openweathermap/static/js/src_Weather_jsx-node_modules_babel_runtime_helpers_esm_objectSpread2_js-node_modules_babel_ru-577953.c93194ca.chunk.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
    DevTools failed to load source map: Could not load content for http://25.25.50.100:12085/vis-2/widgets/vis-2-widgets-material/static/js/src_Player_jsx.21d8294e.chunk.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
    DevTools failed to load source map: Could not load content for http://25.25.50.100:12085/vis-2/widgets/vis-2-widgets-material/static/js/src_Html_jsx.2b739d92.chunk.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
    DevTools failed to load source map: Could not load content for http://25.25.50.100:12085/vis-2/widgets/vis-2-widgets-material/static/js/src_ThemeSwitcher_jsx.992c8ff3.chunk.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
    DevTools failed to load source map: Could not load content for http://25.25.50.100:12085/vis-2/widgets/vis-2-widgets-material/static/js/src_WasherDryer_jsx.ebe2a019.chunk.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
    DevTools failed to load source map: Could not load content for http://25.25.50.100:12085/vis-2/widgets/vis-2-widgets-material/static/js/src_Generic_jsx-src_ObjectChart_jsx.d1b9c3f4.chunk.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
    DevTools failed to load source map: Could not load content for http://25.25.50.100:12085/vis-2/widgets/vis-2-widgets-material/static/js/src_Thermostat_jsx.307e9801.chunk.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
    DevTools failed to load source map: Could not load content for http://25.25.50.100:12085/vis-2/widgets/vis-2-widgets-material/static/js/src_Actual_jsx-node_modules_babel_runtime_helpers_esm_setPrototypeOf_js.eb88a87d.chunk.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
    DevTools failed to load source map: Could not load content for http://25.25.50.100:12085/vis-2/widgets/vis-2-widgets-material/static/js/src_Components_BlindsBase_js.a97ca885.chunk.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
    DevTools failed to load source map: Could not load content for http://25.25.50.100:12085/vis-2/widgets/vis-2-widgets-material/static/js/src_Blinds_jsx-src_Generic_jsx.44d8cea0.chunk.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
    DevTools failed to load source map: Could not load content for http://25.25.50.100:12085/vis-2/widgets/vis-2-widgets-material/static/js/src_Clock_jsx.8acd6a41.chunk.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
    DevTools failed to load source map: Could not load content for http://25.25.50.100:12085/vis-2/widgets/vis-2-widgets-material/static/js/src_Lock_jsx.6af52d4e.chunk.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
    DevTools failed to load source map: Could not load content for http://25.25.50.100:12085/vis-2/widgets/vis-2-widgets-material/static/js/src_Switches_jsx-node_modules_babel_runtime_helpers_esm_assertThisInitialized_js-node_modules-54afab.abbb27c8.chunk.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
    DevTools failed to load source map: Could not load content for http://25.25.50.100:12085/vis-2/widgets/vis-2-widgets-material/static/js/src_SimpleState_jsx.f06bef5f.chunk.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
    DevTools failed to load source map: Could not load content for http://25.25.50.100:12085/vis-2/widgets/vis-2-widgets-material/static/js/src_ViewInWidget_jsx.9ca044fa.chunk.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
    DevTools failed to load source map: Could not load content for http://25.25.50.100:12085/vis-2/widgets/vis-2-widgets-material/static/js/src_RGBLight_jsx-node_modules_react-icons_lib_esm_index_js-node_modules_babel_runtime_helpers-6abf93.230da3de.chunk.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
    DevTools failed to load source map: Could not load content for http://25.25.50.100:12085/vis-2/widgets/vis-2-widgets-material/static/js/src_Camera_jsx.325abfa3.chunk.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
    DevTools failed to load source map: Could not load content for http://25.25.50.100:12085/vis-2/widgets/vis-2-widgets-material/static/js/src_deviceWidget_js.2aef2139.chunk.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
    DevTools failed to load source map: Could not load content for http://25.25.50.100:12085/vis-2/widgets/vis-2-widgets-material/static/js/src_Wizard_jsx.5afb26bd.chunk.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
    DevTools failed to load source map: Could not load content for http://25.25.50.100:12085/vis-2/widgets/vis-2-widgets-material/static/js/src_Security_jsx.87440c69.chunk.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
    DevTools failed to load source map: Could not load content for http://25.25.50.100:12085/vis-2/widgets/vis-2-widgets-gauges/static/js/src_ColorGauge_jsx-node_modules_babel_runtime_helpers_esm_defineProperty_js-node_modules_babe-17d7ec.7cfe7aba.chunk.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
    DevTools failed to load source map: Could not load content for http://25.25.50.100:12085/vis-2/widgets/vis-2-widgets-gauges/static/js/src_WaterGauge_jsx.55c65fc6.chunk.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
    DevTools failed to load source map: Could not load content for http://25.25.50.100:12085/vis-2/widgets/vis-2-widgets-gauges/static/js/src_BatteryGauge_jsx.9a9b6397.chunk.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
    DevTools failed to load source map: Could not load content for http://25.25.50.100:12085/vis-2/widgets/vis-2-widgets-energy/static/js/src_ConsumptionComparison_jsx-node_modules_babel_runtime_helpers_esm_assertThisInitialized_js-a3b647.276e7680.chunk.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
    DevTools failed to load source map: Could not load content for http://25.25.50.100:12085/vis-2/widgets/vis-2-widgets-energy/static/js/src_IntervalSelector_jsx.4fc76338.chunk.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
    DevTools failed to load source map: Could not load content for http://25.25.50.100:12085/vis-2/widgets/vis-2-widgets-energy/static/js/src_Consumption_jsx-node_modules_babel_runtime_helpers_esm_assertThisInitialized_js-node_modu-9f7f55.3efe16ee.chunk.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
    DevTools failed to load source map: Could not load content for http://25.25.50.100:12085/vis-2/widgets/vis-2-widgets-energy/static/js/src_Distribution_jsx.6c5c263b.chunk.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
    VM1681:68 Uncaught SyntaxError: Missing catch or finally after try
       at i.value (visEngine.jsx:1847:54)
       at i.value (visEngine.jsx:1940:14)
       at bi (react-dom.production.min.js:204:189)
       at ji (react-dom.production.min.js:203:149)
       at yl (react-dom.production.min.js:292:172)
       at gs (react-dom.production.min.js:280:389)
       at Ms (react-dom.production.min.js:280:320)
       at zs (react-dom.production.min.js:280:180)
       at as (react-dom.production.min.js:268:209)
       at x (scheduler.production.min.js:13:203)
       at MessagePort.T (scheduler.production.min.js:14:128)
    value @ visEngine.jsx:1847
    value @ visEngine.jsx:1940
    bi @ react-dom.production.min.js:204
    ji @ react-dom.production.min.js:203
    instrument.ts:139 Common user CSS not found: Not exists
    (anonymous) @ visEngine.jsx:1903
    Promise.catch (async)
    value @ visEngine.jsx:1903
    value @ visEngine.jsx:1941
    instrument.ts:139 [2023-09-10T17:55:26.142Z] +SUBSCRIBE: hmip.0.devices.3014F711A0000858A994D9E4.channels.1.on
    instrument.ts:139 [2023-09-10T17:55:26.152Z] +SUBSCRIBE: zigbee.0.00158d0002ff234a.state
    instrument.ts:139 [2023-09-10T17:55:26.168Z] +SUBSCRIBE: sonoff.0.Fritzbox-O2.ENERGY_Power
    2instrument.ts:139 Someone tries to register new ref for view 1041_Anwesenheit
    (anonymous) @ captureconsole.ts:73
    n.registerViewRef @ visEngine.jsx:1187
    (anonymous) @ visView.jsx:79
    value @ visView.jsx:78
    Vl @ react-dom.production.min.js:261
    gl @ react-dom.production.min.js:260
    Hl @ react-dom.production.min.js:259
    (anonymous) @ react-dom.production.min.js:283
    xs @ react-dom.production.min.js:281
    as @ react-dom.production.min.js:270
    instrument.ts:139 [2023-09-10T17:55:26.646Z] +SUBSCRIBE: 0_userdata.0.10_VIS-TAB8.Fenster_Türen.ALLES_ZU
    :12085/vis.0/Samsung-Tab8/font/Seven%20Segment.ttf:1     GET http://25.25.50.100:12085/vis.0/Samsung-Tab8/font/Seven%20Segment.ttf net::ERR_ABORTED 404 (Not Found)
    instrument.ts:139 [2023-09-10T17:55:27.886Z] +SUBSCRIBE: ical.0.data.html
    instrument.ts:139 [2023-09-10T17:55:27.908Z] +SUBSCRIBE: daswetter.0.NextDays.Location_1.Day_1.Maximale_Temperatur_value
    instrument.ts:139 [2023-09-10T17:55:27.918Z] +SUBSCRIBE: daswetter.0.NextDays.Location_1.Day_1.Minimale_Temperatur_value
    instrument.ts:139 [2023-09-10T17:55:27.946Z] +SUBSCRIBE: hmip.0.devices.3014F711A0000EDBE9A1B496.channels.1.actualTemperature
    instrument.ts:139 [2023-09-10T17:55:27.952Z] +SUBSCRIBE: javascript.0.temperaturen.heute_min
    instrument.ts:139 [2023-09-10T17:55:27.957Z] +SUBSCRIBE: javascript.0.temperaturen.heute_max
    instrument.ts:139 [2023-09-10T17:55:27.962Z] +SUBSCRIBE: daswetter.0.NextDays.Location_1.Day_4.Wetter_Symbol_id
    instrument.ts:139 [2023-09-10T17:55:28.055Z] +SUBSCRIBE: esphome.0.78E36D1A7B00.Sensor.3203868340.state
    instrument.ts:139 [2023-09-10T17:55:28.062Z] +SUBSCRIBE: esphome.0.78E36D1A6768.Sensor.1594211186.state
    instrument.ts:139 [2023-09-10T17:55:28.068Z] +SUBSCRIBE: esphome.0.78E36D1A7B00.Sensor.3076461096.state
    instrument.ts:139 [2023-09-10T17:55:28.074Z] +SUBSCRIBE: 0_userdata.0.Eigene_Objekte.Netatmo.Ragow.Rooms.Wohnzimmer Ragow.Soll_Temp
    instrument.ts:139 [2023-09-10T17:55:28.081Z] +SUBSCRIBE: hmip.0.devices.3014F711A0002018A99D211C.channels.1.setPointTemperature
    instrument.ts:139 [2023-09-10T17:55:28.089Z] +SUBSCRIBE: hmip.0.devices.3014F711A0000393C99B4388.channels.1.setPointTemperature
    instrument.ts:139 [2023-09-10T17:55:28.100Z] +SUBSCRIBE: netatmo-energy.0.homes.0.rooms.0.settings.SetTemp
    instrument.ts:139 [2023-09-10T17:55:28.105Z] +SUBSCRIBE: 1
    instrument.ts:139 [2023-09-10T17:55:28.112Z] +SUBSCRIBE: system.adapter.netatmo-energy.0.alive
    instrument.ts:139 [2023-09-10T17:55:28.132Z] +SUBSCRIBE: 0_userdata.0.Eigene_Objekte.Netatmo.Ragow.Rooms.Wohnzimmer Ragow.Ist_Temp
    instrument.ts:139 [2023-09-10T17:55:28.159Z] +SUBSCRIBE: netatmo-energy.0.homes.0.rooms.0.status.therm_measured_temperature
    instrument.ts:139 [2023-09-10T17:55:28.206Z] +SUBSCRIBE: mihome-vacuum.0.info.state
    instrument.ts:139 [2023-09-10T17:55:28.216Z] +SUBSCRIBE: 0_userdata.0.Wäschetrockner.Wäschetrockner_Status
    instrument.ts:139 [2023-09-10T17:55:28.221Z] +SUBSCRIBE: 0_userdata.0.Waschmaschine.Waschmaschiene_fertig
    instrument.ts:139 [2023-09-10T17:55:28.240Z] +SUBSCRIBE: 0_userdata.0.10_VIS-TAB8.NoNo.Betriebsbereitschaft
    instrument.ts:139 [2023-09-10T17:55:28.266Z] +SUBSCRIBE: 0_userdata.0.SpühlMaschine.Spühlmaschiene_Status
    instrument.ts:139 [2023-09-10T17:55:28.290Z] +SUBSCRIBE: hmip.0.devices.3014F711A000275D8993D266.channels.1.raining
    instrument.ts:139 [2023-09-10T17:55:28.312Z] +SUBSCRIBE: 0_userdata.0.Sonstiges.Steckdosen_Online
    instrument.ts:139 [2023-09-10T17:55:28.317Z] +SUBSCRIBE: javascript.0.VIS-Status.alle_steckdosen_og_aus
    instrument.ts:139 [2023-09-10T17:55:28.341Z] +SUBSCRIBE: 0_userdata.0.System.Alle_Adapter_gestartet
    instrument.ts:139 [2023-09-10T17:55:28.346Z] +SUBSCRIBE: 0_userdata.0.Sonstiges.Temperatur_Normal
    instrument.ts:139 [2023-09-10T17:55:28.364Z] +SUBSCRIBE: 0_userdata.0.10_VIS-TAB8.Beleuchtung.EG-Alle_Lampen_aus_check
    instrument.ts:139 [2023-09-10T17:55:28.376Z] +SUBSCRIBE: 0_userdata.0.10_VIS-TAB8.Beleuchtung.OG-Alle_Lampen_aus
    instrument.ts:139 [2023-09-10T17:55:28.388Z] +SUBSCRIBE: 0_userdata.0.10_VIS-TAB8.Beleuchtung.Dach-Alle_Lampen_aus
    instrument.ts:139 [2023-09-10T17:55:28.431Z] +SUBSCRIBE: javascript.0.zeiten.nachtlaenge_fortschritt
    instrument.ts:139 [2023-09-10T17:55:28.432Z] +SUBSCRIBE: javascript.0.zeiten.tageslaenge_fortschritt
    instrument.ts:139 Version vis-hqwidgets: 1.2.0
    instrument.ts:139 [2023-09-10T17:55:28.449Z] +SUBSCRIBE: daswetter.0.NextHours.Location_1.Day_1.moon_symbol
    instrument.ts:139 [2023-09-10T17:55:28.450Z] +SUBSCRIBE: 0_userdata.0.10_VIS-TAB8.zeiten.tageslaenge_tageslicht_in_minuten
    instrument.ts:139 [2023-09-10T17:55:28.457Z] +SUBSCRIBE: 0_userdata.0.10_VIS-TAB8.zeiten.tageslaenge_fortschritt
    instrument.ts:139 [2023-09-10T17:55:28.486Z] +SUBSCRIBE: 0_userdata.0.10_VIS-TAB8.zeiten.rolladen_oeffnen_verzoegerung
    instrument.ts:139 [2023-09-10T17:55:28.493Z] +SUBSCRIBE: 0_userdata.0.10_VIS-TAB8.zeiten.rolladen_schliessen_verzoegerung
    instrument.ts:139 [2023-09-10T17:55:28.494Z] +SUBSCRIBE: 0_userdata.0.10_VIS-TAB8.zeiten.weihnachtszeit
    instrument.ts:139 [2023-09-10T17:55:28.518Z] +SUBSCRIBE: trashschedule.0.type.json
    instrument.ts:139 [2023-09-10T17:55:28.543Z] +SUBSCRIBE: 0_userdata.0.10_VIS-TAB8.Anwesenheit.Rolf
    instrument.ts:139 [2023-09-10T17:55:28.548Z] +SUBSCRIBE: 0_userdata.0.10_VIS-TAB8.Anwesenheit.Alexander
    instrument.ts:139 [2023-09-10T17:55:28.555Z] +SUBSCRIBE: 0_userdata.0.10_VIS-TAB8.Anwesenheit.Kari
    instrument.ts:139 [2023-09-10T17:55:28.591Z] +SUBSCRIBE: 0_userdata.0.10_VIS-TAB8.Anwesenheit.Detlev
    instrument.ts:139 [2023-09-10T17:55:28.601Z] +SUBSCRIBE: 0_userdata.0.10_VIS-TAB8.Anwesenheit.Rolf_Time_Limit
    instrument.ts:139 [2023-09-10T17:55:28.609Z] +SUBSCRIBE: 0_userdata.0.10_VIS-TAB8.Anwesenheit.Detlev_Time_Limit
    instrument.ts:139 [2023-09-10T17:55:28.616Z] +SUBSCRIBE: 0_userdata.0.10_VIS-TAB8.Anwesenheit.Alexander_Time_Limit
    instrument.ts:139 [2023-09-10T17:55:28.623Z] +SUBSCRIBE: 0_userdata.0.10_VIS-TAB8.Anwesenheit.Kari_Time_Limit
    instrument.ts:139 [2023-09-10T17:55:28.646Z] +SUBSCRIBE: 0_userdata.0.Morgen_Nacht.Nacht
    instrument.ts:139 [2023-09-10T17:55:28.658Z] +SUBSCRIBE: 0_userdata.0.Sonstiges.Schlafen_im_wohnzimmer
    instrument.ts:139 [2023-09-10T17:55:28.668Z] +SUBSCRIBE: 0_userdata.0.Sonstiges.Besuch_da
    instrument.ts:139 [2023-09-10T17:55:28.683Z] +SUBSCRIBE: 0_userdata.0.Sonstiges.SchlafTimer
    instrument.ts:139 [2023-09-10T17:55:28.701Z] +SUBSCRIBE: 0_userdata.0.Alexa_Sprachausgaben.Spachausgabe
    instrument.ts:139 [2023-09-10T17:55:28.780Z] +SUBSCRIBE: 0_userdata.0.Regen_Warn_Licht.Licht-Singnal
    instrument.ts:139 [2023-09-10T17:55:28.821Z] +SUBSCRIBE: 0_userdata.0.Regen_Warn_Licht.Ansage
    instrument.ts:139 [2023-09-10T17:55:28.835Z] +SUBSCRIBE: javascript.0.scriptEnabled.50:_VIS-Tab8.Spach__Skripte.Regen
    instrument.ts:139 [2023-09-10T17:55:28.893Z] +SUBSCRIBE: 0_userdata.0.10_VIS-TAB8.Energie.Stromverbrauch.Verbrauch_Aktuell
    instrument.ts:139 [2023-09-10T17:55:28.899Z] +SUBSCRIBE: 0_userdata.0.10_VIS-TAB8.Energie.Stromverbrauch.Verbrauch_Heute
    instrument.ts:139 [2023-09-10T17:55:28.908Z] +SUBSCRIBE: 0_userdata.0.10_VIS-TAB8.Energie.Stromverbrauch.Verbrauch_Gestern
    instrument.ts:139 [2023-09-10T17:55:28.918Z] +SUBSCRIBE: 0_userdata.0.10_VIS-TAB8.Energie.Stromverbrauch.Verbrauch_Gesammt
    instrument.ts:139 [2023-09-10T17:55:28.928Z] +SUBSCRIBE: 0_userdata.0.10_VIS-TAB8.Energie.Stromverbrauch.Aktuell_Beleuchtung
    instrument.ts:139 [2023-09-10T17:55:28.938Z] +SUBSCRIBE: 0_userdata.0.10_VIS-TAB8.Energie.Stromverbrauch.VIS.Aktueller_Monat
    instrument.ts:139 [2023-09-10T17:55:28.948Z] +SUBSCRIBE: 0_userdata.0.10_VIS-TAB8.Energie.Stromverbrauch.VIS.Aktuelles_Jahr
    instrument.ts:139 [2023-09-10T17:55:28.954Z] +SUBSCRIBE: 0_userdata.0.10_VIS-TAB8.Energie.Stromverbrauch.Aktuell_Beleuchtung_Kosten
    instrument.ts:139 [2023-09-10T17:55:28.959Z] +SUBSCRIBE: 0_userdata.0.10_VIS-TAB8.Energie.Stromverbrauch.Verbrauch_Heute_Kosten
    instrument.ts:139 [2023-09-10T17:55:28.966Z] +SUBSCRIBE: 0_userdata.0.10_VIS-TAB8.Energie.Stromverbrauch.Verbrauch_Gestern_Kosten
    instrument.ts:139 [2023-09-10T17:55:28.971Z] +SUBSCRIBE: 0_userdata.0.10_VIS-TAB8.Energie.Stromverbrauch.Verbrauch_Gesammt_Kosten
    instrument.ts:139 [2023-09-10T17:55:28.981Z] +SUBSCRIBE: 0_userdata.0.10_VIS-TAB8.Energie.Stromverbrauch.VIS.Aktueller_Monat_Kosten
    instrument.ts:139 [2023-09-10T17:55:28.986Z] +SUBSCRIBE: 0_userdata.0.10_VIS-TAB8.Energie.Stromverbrauch.VIS.Aktuelles_Jahr_Kosten
    instrument.ts:139 [2023-09-10T17:55:29.029Z] +SUBSCRIBE: tuya.0.15556050840d8ea159d5.2
    instrument.ts:139 [2023-09-10T17:55:29.037Z] +SUBSCRIBE: 0_userdata.0.10_VIS-TAB8.TAB8_Screen_Status.Tab8_Screen_ON_Check_Time
    instrument.ts:139 [2023-09-10T17:55:29.044Z] +SUBSCRIBE: 0_userdata.0.10_VIS-TAB8.TAB8_Screen_Status.Tab8_No_Ereigniss_Screen_ON
    instrument.ts:139 [2023-09-10T17:55:29.056Z] +SUBSCRIBE: 0_userdata.0.10_VIS-TAB8.Clint.Port
    instrument.ts:139 [2023-09-10T17:55:29.346Z] +SUBSCRIBE: alexa2.0.Smart-Home-Devices.029ec920-e148-47f6-b45a-07383ebc1425.8-rangeValue
    instrument.ts:139 [2023-09-10T17:55:29.353Z] +SUBSCRIBE: alexa2.0.Smart-Home-Devices.029ec920-e148-47f6-b45a-07383ebc1425.5-rangeValue
    instrument.ts:139 [2023-09-10T17:55:29.360Z] +SUBSCRIBE: alexa2.0.Smart-Home-Devices.029ec920-e148-47f6-b45a-07383ebc1425.9-rangeValue
    instrument.ts:139 [2023-09-10T17:55:29.367Z] +SUBSCRIBE: alexa2.0.Smart-Home-Devices.029ec920-e148-47f6-b45a-07383ebc1425.4-rangeValue
    instrument.ts:139 [2023-09-10T17:55:29.373Z] +SUBSCRIBE: alexa2.0.Smart-Home-Devices.029ec920-e148-47f6-b45a-07383ebc1425.6-rangeValue
    instrument.ts:139 [2023-09-10T17:55:29.455Z] +SUBSCRIBE: alexa2.0.Smart-Home-Devices.029ec920-e148-47f6-b45a-07383ebc1425.temperature
    helpers.ts:111 Uncaught TypeError: Cannot read properties of null (reading 'length')
       at Function.each (jquery-1.11.2.min.js:2:2821)
       at Object.redraw (trashschedule.js:354:15)
       at Object.createWidget (trashschedule.js:192:36)
       at trashschedule.js:172:44
       at sentryWrapped (helpers.ts:87:17)
    each @ jquery-1.11.2.min.js:2
    redraw @ trashschedule.js:354
    createWidget @ trashschedule.js:192
    (anonymous) @ trashschedule.js:172
    n.Ft @ fetch.ts:125
    value @ hub.ts:480
    value @ hub.ts:425
    value @ hub.ts:454
    fn @ sdk.ts:205
    (anonymous) @ sdk.ts:241
    y @ instrument.ts:105
    f.onpopstate @ instrument.ts:358
    st.onpopstate @ instrument.ts:333
    changeView @ visEngine.jsx:500
    (anonymous) @ VM1535:637
    dispatch @ jquery-1.11.2.min.js:3
    r.handle @ jquery-1.11.2.min.js:3
    App.jsx:554 Uncaught (in promise) TypeError: s.changeProject is not a function
       at App.jsx:554:24
       at f (regeneratorRuntime.js:45:16)
       at Generator.<anonymous> (regeneratorRuntime.js:133:17)
       at Generator.next (regeneratorRuntime.js:74:21)
       at r (asyncToGenerator.js:3:20)
       at o (asyncToGenerator.js:22:9)
       at asyncToGenerator.js:27:7
       at new Promise (<anonymous>)
       at n.<anonymous> (asyncToGenerator.js:19:12)
       at n.changeView (App.jsx:579:6)
       at onHashChange (App.jsx:145:14)
    sigi234S Online
    sigi234S Online
    #203
    @digi-bit sagte in Vis-2(.0) - Neuer Adapter als Beta:
    mfg
    Digi-Bit
    Bei mir funktionieren sie aber.
    Edit:
    Es kommt auch eine Horizontale Navigation:
    https://github.com/ioBroker/ioBroker.vis-2
    • sigi234S sigi234
      mfg
      Digi-Bit
      Edit:
      Digi-Bit
      #204
      @sigi234
      Ja.... also wenn ich ein Paar davon benutze dann geht es eine weile und irgend wann macht es peng und dann geht nix mehr.
      Ich habe Vis-2 deinstalliert und neu installiert und alle Projekte gelöscht.
      Dann ein von Vorne angefangen und jeden Ordner und jede Seite von " Hand " angelegt.
      Die Widgets habe ich dann von der Beta V2.1.2 importiert.
      und als ich mit den "Serien" fertig war und es mal gestartet habe dann hat es komisch aufgeblinkt und nun kann ich nur noch von "MAIN" auf "Serien" hin und her klicken bei den anderen NAVIS passiert nix mehr.
      2023-09-12-Kastanienhof (12).zip
      Weiß ja nicht ob da mal einer drauf kucken will....
      Wenn das bei jemand anderem einwandfrei geht, also viel zu sehen ist nicht da ich nur die Haubzeiten kopiert habe die sich wiederum aus anderen zusammen setzen, aber man sieht ja wie er hin und her schalten würde.
      Bei der Aktiven Seite ist dann um den Navi Icon ein Blauer Rahmen, nur mal als Info...
      Wenn das nur bei mir rumspinnen sollte, sollte ich vielleicht mal an einer neu Installation denken .......mmmmmmmmm
      mfg
      Digi-Bit
      Router: Ubiquiti UniFi Dream Machine Pro|Iobroker I.NUCi5/Debian, 6 x Switche, 3 x APs, 3 x Cam, 2 x Nas(Qnap 4 & 8 Bay's)
      7 x Echos, 76 x Tasmota, 58 x ZigBee, Homatic Ip, 2 x USV
      • Smilie108S Online
        Smilie108S Online
        Smilie108
        #205
        Hi Nochmal eine Frage
        Ist es nur bei mir so ich muss im editor alle Seiten die ich anzeigen will auch zur bearbeitung offen haben sonst gehen sie in der live visu nicht Nav links sind zwar da aber es gibt keine Bildumschaltung mehr
        Danke Smilie108
        • Smilie108S Smilie108
          Danke Smilie108
          MK-66
          #206
          @smilie108
          Hi, ist auch genauso bei mir. Die Navigation mittels navigation Widgets funktioniert nur, wenn die Seiten zu denen navigiert werden soll auch bereits im Editor geöffnet sind.
          Ist offenbar noch ein Bug in VIS-2.
          • M MK-66
            @smilie108
            Digi-Bit
            #207
            @mk-66
            so ein Mist, diese Variante ist mir bei den zig Stunden am rum Popel nicht aufgefallen......😕
            Jetzt weiß ich auch wieso das eine Zeitlang funktioniert hat und dann auf einmal nicht mehr, weil ich die Seiten beim Editor dann zu gemacht habe, noch mal testen und da der schreck .....
            Jetzt sehe ich das auch, na endlich ist wenigstes der Fehler gefunden, ich war schon beim aufgeben............
            Wann kommt V2.2.5 Raus ? 😊
            ( ist jetzt nicht "ernst" gemeint ........... rennnnnnnnnnnnnnnnnnnnnnnnnnn )
            mfg
            Digi-Bit
            • D Digi-Bit
              @mk-66
              mfg
              Digi-Bit
              #208
              @digi-bit
              Schon da:
              Adapter    "vis-2"        : 2.2.5    , installed 2.2.5
              This upgrade of "vis-2" will introduce the following changes:
              -> 2.2.5:
              Implemented horizontal navigation
                @digi-bit
                Schon da:
                -> 2.2.5:
                Digi-Bit
                #209
                Wunderbar !!!!!!!!!! 👍
                Mein Projekt von V2.1.2 funktioniert nun auch auf V2.2.5
                D A N K EEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEE !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
                mfg
                Digi-Bit
                • Smilie108S Online
                  Smilie108S Online
                  Smilie108
                  #210
                  @Thomas-Braun
                  Super jetzt gehts auch ohne das die fenster offen sind ;) DAANNNNKKKKKEEEEEE ;)
                  mfg Smilie108
                    SidM
                    #211
                    ich habe vor ein paar Wochen Vis 2 Beta installiert und mal 1-2 Sachen dort probiert und auch mal nen VIS 1 Projekt geladen und seitdem nichts wieder damit gemacht.
                    Heute wollte ich mich mal wieder dransetzen und meine alte VIS bearbeiten oder vielleicht auch komplett neu gestalten.
                    Allerdings habe ich das Problem dass weder Widgets noch Seiten vom Projekt geladen werden. Stattdessen läuft nur der Blaue Ladebalken bei beiden Fenstern, mehr tut sich hier nicht.
                    Auch das erstellen eines neues Projekts ändert daran nichts.
                    Habe auch mal den VIS 2 Adapter gelöscht und neu installiert (v.2.2.5), auch hier bleibt das gleiche Verhalten.
                    Einstellungen Web Adapter:
                    Vielen Dank.
                    • E Offline
                      e-i-k-e
                      schrieb am zuletzt editiert von e-i-k-e
                      #212
                      Moin,
                      mein Hintergrund wird nur im Querformat angezeigt und im unteren "weißen" Bereich kann ich nicht im Editor arbeiten.
                      Dies ist ein VIS 1 Projekt, muss ich noch etwas in den Einstellungen ändern?
                      P M 2 Antworten Letzte Antwort
                      • E e-i-k-e
                        Moin,
                        Piemur
                        schrieb am zuletzt editiert von Piemur
                        #213
                        Moin
                        ich versuche gerade Vis-2 von 2.2.2 auf 2.2.5 upzudaten.
                        Mit V2.2.2 funktioniert es soweit, die VIS öffnet sich normal und alle Widgets (Basic, etc ) sind vorhanden.
                        Nach dem Update auf 2.2.5 bricht der Editor ab.
                        Was könnte hier schief gelaufen sein?
                        Ich hatte vis und vis-2 vorher komplett entfernt und neu aufgesetzt.
                        Installation erfolgte per Repo aus Iobroker-Adapter.
                        Iob ist auf einem RapsberryPi 4 Bullseye installiert
                        iobroker.vis-2@2.2.5 using theme "colored"
                        Prompt.js:14
                        socket.io.js:66 [2023-09-14T09:14:32.449Z] Try to connect
                        widgets.html:1     Failed to load resource: the server responded with a status of 404 (Not Found)
                        instrument.ts:144 Translate: jqui_html_dialog
                        instrument.ts:144 Translate: jqui_icon_dialog
                        instrument.ts:144 Translate: jqui_container_dialog
                        instrument.ts:144 Translate: tabs
                        instrument.ts:144 Common user CSS not found: Not exists
                        (anonym) @ instrument.ts:144
                        iob diag:
                        Skript v.2023-04-16
                        *** BASE SYSTEM ***
                        Model           : Raspberry Pi 4 Model B Rev 1.5
                        Architecture    : aarch64
                        Docker          : false
                        Virtualization  : none
                        Distributor ID: Debian
                        Description:    Debian GNU/Linux 11 (bullseye)
                        Release:        11
                        Codename:       bullseye
                        PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
                        NAME="Debian GNU/Linux"
                        VERSION_ID="11"
                        VERSION="11 (bullseye)"
                        VERSION_CODENAME=bullseye
                        ID=debian
                        HOME_URL="https://www.debian.org/"
                        SUPPORT_URL="https://www.debian.org/support"
                        BUG_REPORT_URL="https://bugs.debian.org/"
                        Systemuptime and Load:
                         11:23:41 up 8 days, 22:48,  1 user,  load average: 0.12, 0.40, 0.57
                        CPU threads: 4
                        Raspberry only:
                        throttled=0x0
                        Other values than 0x0 hint to temperature/voltage problems
                        temp=43.3'C
                        volt=0.9260V
                        *** Time and Time Zones ***
                                       Local time: Thu 2023-09-14 11:23:41 CEST
                                   Universal time: Thu 2023-09-14 09:23:41 UTC
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        *** User and Groups ***
                        rapsytrelo
                        /home/rapsytrelo
                        rapsytrelo adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                        *** X-Server-Setup ***
                        X-Server:       false
                        Desktop:
                        Terminal:       tty
                        Boot Target:    multi-user.target
                        *** MEMORY ***
                        Mem:            7.8G        2.2G        2.3G        1.0M        3.4G        5.5G
                        Swap:            99M          0B         99M
                        Total:          7.9G        2.2G        2.4G
                                 7811 M total memory
                                 2195 M used memory
                                 2290 M active memory
                                 2944 M inactive memory
                                 2254 M free memory
                                  177 M buffer memory
                                 3183 M swap cache
                                   99 M total swap
                                    0 M used swap
                                   99 M free swap
                        Raspberry only:
                        oom events: 0
                        *** FILESYSTEM ***
                        /dev/root      ext4       29G  5.6G   22G  21% /
                        devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
                        tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
                        tmpfs          tmpfs     1.6G  1.1M  1.6G   1% /run
                        /dev/sda1      vfat      255M   31M  225M  13% /boot
                        tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
                        [Tue Sep  5 12:34:57 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:34:5B:DE vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=071417eb-02 rootfstype=ext4 fsck.repair=yes rootwait
                        [Tue Sep  5 12:35:00 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                        [Tue Sep  5 12:35:00 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                        [Tue Sep  5 12:35:02 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
                        TARGET  SOURCE    FSTYPE OPTIONS
                        /       /dev/sda2 ext4   rw,noatime
                        `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                        /var:
                        651M    /var/
                        224M    /var/log
                        217M    /var/log/journal/f6d599b849934723a09caeabf10c3363
                        180M    /var/cache
                        Archived and active journals take up 216.0M in the file system.
                        /opt/iobroker/backups:
                        536M    /opt/iobroker/backups/
                        /opt/iobroker/iobroker-data:
                        780M    /opt/iobroker/iobroker-data/
                        501M    /opt/iobroker/iobroker-data/files
                        120M    /opt/iobroker/iobroker-data/files/vis-2
                        96M     /opt/iobroker/iobroker-data/backup-objects
                        88M     /opt/iobroker/iobroker-data/files/echarts.admin
                        35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                        34M     /opt/iobroker/iobroker-data/objects.jsonl
                        28M     /opt/iobroker/iobroker-data/states.jsonl
                        23M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.eb0afecd.js.map
                        23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.7952f0f7.js.map
                        *** NodeJS-Installation ***
                        /usr/bin/nodejs         v18.17.0
                        /usr/bin/node           v18.17.0
                        /usr/bin/npm            9.6.7
                        /usr/bin/npx            9.6.7
                        nodejs:
                          Installed: 18.17.0-deb-1nodesource1
                          Candidate: 18.17.1-deb-1nodesource1
                          Version table:
                             18.17.1-deb-1nodesource1 500
                                500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
                         *** 18.17.0-deb-1nodesource1 100
                             12.22.12~dfsg-1~deb11u4 500
                                500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                             12.22.12~dfsg-1~deb11u3 500
                                500 http://deb.debian.org/debian bullseye/main arm64 Packages
                        No problems detected
                        *** ioBroker-Installation ***
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Core adapters versions
                        js-controller:  4.0.24
                        admin:          6.8.0
                        javascript:     7.0.3
                        Adapters from github:   1
                        Adapter State
                        + system.adapter.admin.0                  : admin                 : rasptrelo                                -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                          system.adapter.alias-manager.0          : alias-manager         : rasptrelo                                - disabled
                        + system.adapter.backitup.0               : backitup              : rasptrelo                                -  enabled
                          system.adapter.daswetter.0              : daswetter             : rasptrelo                                -  enabled
                          system.adapter.devices.0                : devices               : rasptrelo                                - disabled
                          system.adapter.discovery.0              : discovery             : rasptrelo                                - disabled
                          system.adapter.dwd.0                    : dwd                   : rasptrelo                                -  enabled
                        + system.adapter.echarts.0                : echarts               : rasptrelo                                -  enabled
                          system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : rasptrelo                                - disabled
                        + system.adapter.fb-checkpresence.0       : fb-checkpresence      : rasptrelo                                -  enabled
                          system.adapter.feiertage.0              : feiertage             : rasptrelo                                -  enabled
                        + system.adapter.followthesun.0           : followthesun          : rasptrelo                                -  enabled
                          system.adapter.heatingcontrol.0         : heatingcontrol        : rasptrelo                                - disabled
                        + system.adapter.history.0                : history               : rasptrelo                                -  enabled
                        + system.adapter.hm-rega.0                : hm-rega               : rasptrelo                                -  enabled
                        + system.adapter.hm-rpc.0                 : hm-rpc                : rasptrelo                                -  enabled, port: 0
                        + system.adapter.hm-rpc.1                 : hm-rpc                : rasptrelo                                -  enabled, port: 0
                        + system.adapter.hm-rpc.3                 : hm-rpc                : rasptrelo                                -  enabled, port: 0
                        + system.adapter.hue.0                    : hue                   : rasptrelo                                -  enabled, port: 443
                          system.adapter.ical.0                   : ical                  : rasptrelo                                -  enabled
                          system.adapter.icons-mfd-png.0          : icons-mfd-png         : rasptrelo                                - disabled
                          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : rasptrelo                                - disabled
                        + system.adapter.info.0                   : info                  : rasptrelo                                -  enabled
                        + system.adapter.javascript.0             : javascript            : rasptrelo                                -  enabled
                        + system.adapter.node-red.0               : node-red              : rasptrelo                                -  enabled, port: 1880, bind: 0.0.0.0
                        + system.adapter.ping.0                   : ping                  : rasptrelo                                -  enabled
                          system.adapter.rpi2.0                   : rpi2                  : rasptrelo                                - disabled
                        + system.adapter.scenes.0                 : scenes                : rasptrelo                                -  enabled
                          system.adapter.schoolfree.0             : schoolfree            : rasptrelo                                -  enabled
                        + system.adapter.shelly.0                 : shelly                : rasptrelo                                -  enabled, port: 1882, bind: 0.0.0.0
                        + system.adapter.shelly.1                 : shelly                : rasptrelo                                -  enabled, port: 1882, bind: 0.0.0.0
                          system.adapter.smartcontrol.0           : smartcontrol          : rasptrelo                                - disabled
                          system.adapter.sprinklecontrol.0        : sprinklecontrol       : rasptrelo                                - disabled
                        + system.adapter.tankerkoenig.0           : tankerkoenig          : rasptrelo                                -  enabled
                          system.adapter.tr-064.0                 : tr-064                : rasptrelo                                - disabled
                        + system.adapter.trashschedule.0          : trashschedule         : rasptrelo                                -  enabled
                          system.adapter.vis-2.0                  : vis-2                 : rasptrelo                                -  enabled
                          system.adapter.vis-colorpicker.0        : vis-colorpicker       : rasptrelo                                -  enabled
                          system.adapter.vis-metro.0              : vis-metro             : rasptrelo                                -  enabled
                          system.adapter.vis.0                    : vis                   : rasptrelo                                - disabled
                          system.adapter.weatherunderground.0     : weatherunderground    : rasptrelo                                -  enabled
                        + system.adapter.web.0                    : web                   : rasptrelo                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                        + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : rasptrelo                                -  enabled
                        + instance is alive
                        ioBroker-Repositories
                        Active repo(s): beta
                        Installed ioBroker-Instances
                        Used repository: beta
                        Adapter    "admin"        : 6.10.1   , installed 6.8.0  [Updatable]
                        Adapter    "alias-manager": 1.2.6    , installed 1.2.4  [Updatable]
                        Adapter    "backitup"     : 2.8.1    , installed 2.6.23 [Updatable]
                        Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
                        Adapter    "devices"      : 1.1.5    , installed 1.1.5
                        Adapter    "discovery"    : 4.0.0    , installed 3.1.0  [Updatable]
                        Adapter    "echarts"      : 1.5.4    , installed 1.5.1  [Updatable]
                        Adapter    "ecovacs-deebot": 1.4.13  , installed 1.4.13
                        Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
                        Adapter    "feiertage"    : 1.1.4    , installed 1.1.0  [Updatable]
                        Adapter    "followthesun" : 0.4.2    , installed 0.4.2
                        Adapter    "heatingcontrol": 2.11.1  , installed 2.11.1
                        Adapter    "history"      : 2.2.6    , installed 2.2.6
                        Adapter    "hm-rega"      : 4.0.0    , installed 3.0.47 [Updatable]
                        Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
                        Adapter    "hue"          : 3.10.0   , installed 3.9.5  [Updatable]
                        Adapter    "ical"         : 1.13.3   , installed 1.13.3
                        Adapter    "info"         : 2.0.0    , installed 1.9.26 [Updatable]
                        Adapter    "javascript"   : 7.1.4    , installed 7.0.3  [Updatable]
                        Controller "js-controller": 5.0.12   , installed 4.0.24 [Updatable]
                        Adapter    "node-red"     : 4.0.3    , installed 4.0.3
                        Adapter    "openweathermap": 0.4.3   , installed 0.3.9  [Updatable]
                        Adapter    "schoolfree"   : 1.1.2    , installed 1.1.1  [Updatable]
                        Adapter    "shelly"       : 6.4.1    , installed 6.4.1
                        Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
                        Adapter    "socketio"     : 6.5.3    , installed 6.5.3
                        Adapter    "sprinklecontrol": 0.2.13 , installed 0.2.13
                        Adapter    "trashschedule": 2.2.0    , installed 2.2.0
                        Adapter    "vis-2-widgets-gauges": 0.2.0, installed 0.2.0
                        Adapter    "vis-2-widgets-jaeger-design": 1.0.0, installed 1.0.0
                        Adapter    "vis-2-widgets-material": 1.1.3, installed 1.0.0 [Updatable]
                        Adapter    "vis-material-advanced": 1.7.4, installed 1.7.2 [Updatable]
                        Adapter    "weatherunderground": 3.6.0, installed 3.4.2 [Updatable]
                        Adapter    "web"          : 6.1.1    , installed 6.1.1
                        Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
                        Adapter    "ws"           : 2.5.4    , installed 2.5.4
                        Objects and States
                        Objects:        19869
                        States:         13299
                        Hit:1 http://deb.debian.org/debian bullseye InRelease
                        Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
                        Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                        Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                        Get:5 https://deb.nodesource.com/node_18.x bullseye InRelease [4586 B]
                        Fetched 4586 B in 1s (3145 B/s)
                        Reading package lists...
                        Pending Updates: 23
                        *** Listening Ports ***
                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13413      540/sshd: /usr/sbin
                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       4070048    256825/iobroker.js-
                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       4070617    256825/iobroker.js-
                        tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       4070718    256933/node-red
                        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       4069276    257071/io.shelly.0
                        tcp        0      0 192.168.178.57:2001     0.0.0.0:*               LISTEN      1001       4070245    256978/io.hm-rpc.0
                        tcp        0      0 192.168.178.57:2010     0.0.0.0:*               LISTEN      1001       4070740    256993/io.hm-rpc.1
                        tcp        0      0 192.168.178.57:9292     0.0.0.0:*               LISTEN      1001       4070759    257007/io.hm-rpc.3
                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       4068974    256843/io.admin.0
                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       4073876    257367/io.web.0
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          13415      540/sshd: /usr/sbin
                        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15436      661/dhcpcd
                        udp        0      0 0.0.0.0:54290           0.0.0.0:*                           108        13377      394/avahi-daemon: r
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13375      394/avahi-daemon: r
                        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       4069309    257082/io.shelly.1
                        udp6       0      0 :::53110                :::*                                108        13378      394/avahi-daemon: r
                        udp6       0      0 :::5353                 :::*                                108        13376      394/avahi-daemon: r
                        2023-09-14 11:17:44.522  - warn: node-red.0 (256896) 14 Sep 11:17:44 - [warn] [function:Richtig lueften Auswertung] RichtigLueftenAuswertung: Error: Luftfeuchtigkeit_aussen: keine korrekten Werte
                        2023-09-14 11:17:55.530  - warn: node-red.0 (256896) 14 Sep 11:17:55 - [warn] [function:Richtig lueften Auswertung] RichtigLueftenAuswertung: Error: Luftfeuchtigkeit_aussen: keine korrekten Werte
                        2023-09-14 11:17:55.569  - warn: node-red.0 (256896) 14 Sep 11:17:55 - [warn] [function:Richtig lueften Auswertung] RichtigLueftenAuswertung: Error: Luftfeuchtigkeit_aussen: keine korrekten Werte
                        2023-09-14 11:18:00.647  - info: hm-rega.0 (256959) pollingTrigger
                        2023-09-14 11:18:45.639  - info: hm-rega.0 (256959) pollingTrigger
                        2023-09-14 11:19:30.641  - info: hm-rega.0 (256959) pollingTrigger
                        2023-09-14 11:20:00.089  - info: host.rasptrelo instance system.adapter.dwd.0 started with pid 260926
                        2023-09-14 11:20:02.952  - info: dwd.0 (260926) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.0, js-controller: 4.0.24
                        2023-09-14 11:20:04.630  - info: dwd.0 (260926) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                        2023-09-14 11:20:05.165  - info: host.rasptrelo instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                        2023-09-14 11:20:15.642  - info: hm-rega.0 (256959) pollingTrigger
                        2023-09-14 11:21:00.693  - info: hm-rega.0 (256959) pollingTrigger
                        2023-09-14 11:21:45.648  - info: hm-rega.0 (256959) pollingTrigger
                        2023-09-14 11:22:30.650  - info: hm-rega.0 (256959) pollingTrigger
                        2023-09-14 11:22:55.529  - warn: node-red.0 (256896) 14 Sep 11:22:55 - [warn] [function:Richtig lueften Auswertung] RichtigLueftenAuswertung: Error: Luftfeuchtigkeit_aussen: keine korrekten Werte
                        2023-09-14 11:22:55.569  - warn: node-red.0 (256896) 14 Sep 11:22:55 - [warn] [function:Richtig lueften Auswertung] RichtigLueftenAuswertung: Error: Luftfeuchtigkeit_aussen: keine korrekten Werte
                        2023-09-14 11:23:15.652  - info: hm-rega.0 (256959) pollingTrigger
                        2023-09-14 11:24:00.657  - info: hm-rega.0 (256959) pollingTrigger
                        2023-09-14 11:24:45.660  - info: hm-rega.0 (256959) pollingTrigger
                        soweit ich das im Protokoll gesehen habe:
                        023-09-14 11:10:31.487 - debug: Delete file vis-2/widgets/trashschedule/css/style.css
                        2023-09-14 11:10:31.491 - debug: Delete file vis-2/widgets/trashschedule/js/trashschedule.js
                        2023-09-14 11:10:31.496 - debug: Delete file vis-2/widgets/trashschedule.html
                        2023-09-14 11:10:31.500 - debug: Delete file vis-2/widgets.html
                        wird beim Update die widgets.html gelöscht
                        R P 2 Antworten Letzte Antwort
                        • P Piemur
                          Moin
                          Prompt.js:14
                          iob diag:
                          Skript v.2023-04-16
                          *** BASE SYSTEM ***
                          Docker          : false
                          Release:        11
                          Codename:       bullseye
                          VERSION_ID="11"
                          ID=debian
                          CPU threads: 4
                          Raspberry only:
                          throttled=0x0
                          temp=43.3'C
                          volt=0.9260V
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          rapsytrelo
                          /home/rapsytrelo
                          X-Server:       false
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Swap:            99M          0B         99M
                                   7811 M total memory
                                   2195 M used memory
                                   2254 M free memory
                                    177 M buffer memory
                                   3183 M swap cache
                                     99 M total swap
                                      0 M used swap
                                     99 M free swap
                          Raspberry only:
                          oom events: 0
                          *** FILESYSTEM ***
                          /var:
                          651M    /var/
                          224M    /var/log
                          180M    /var/cache
                          /usr/bin/npm            9.6.7
                          /usr/bin/npx            9.6.7
                          nodejs:
                            Version table:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          admin:          6.8.0
                          javascript:     7.0.3
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        19869
                          States:         13299
                          Pending Updates: 23
                          RMortan
                          #214
                          Hey
                          Ich habe mal ne Frage wieso werden mir nicht alle Projekte aus Vis1 nicht anzeigt und wieso kann ich das Fehlende Objekt nicht importieren... Bzw. Taucht in der Liste auf aber lässt sich nicht öffnen... Ebenso kann ich einzelne View nicht importieren kann?
                          Hat einer einen Tipp stelle gerne Informationen zur Verfügung die noch benötigt werden..
                          Danke und Grüße aus Kreischa
                          • v522533V Offline
                            v522533V Offline
                            v522533
                            #215
                            @sidm
                            Genau das habe ich auch. Gibt es hier schon eine Lösung?
                            Gruß Chris
                            • P Piemur
                              Moin
                              Prompt.js:14
                              iob diag:
                              Skript v.2023-04-16
                              *** BASE SYSTEM ***
                              Docker          : false
                              Release:        11
                              Codename:       bullseye
                              VERSION_ID="11"
                              ID=debian
                              CPU threads: 4
                              Raspberry only:
                              throttled=0x0
                              temp=43.3'C
                              volt=0.9260V
                                               RTC time: n/a
                                            NTP service: active
                                        RTC in local TZ: no
                              rapsytrelo
                              /home/rapsytrelo
                              X-Server:       false
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                              Swap:            99M          0B         99M
                                       7811 M total memory
                                       2195 M used memory
                                       2254 M free memory
                                        177 M buffer memory
                                       3183 M swap cache
                                         99 M total swap
                                          0 M used swap
                                         99 M free swap
                              Raspberry only:
                              oom events: 0
                              *** FILESYSTEM ***
                              /var:
                              651M    /var/
                              224M    /var/log
                              180M    /var/cache
                              /usr/bin/npm            9.6.7
                              /usr/bin/npx            9.6.7
                              nodejs:
                                Version table:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              admin:          6.8.0
                              javascript:     7.0.3
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects:        19869
                              States:         13299
                              Pending Updates: 23
                              Piemur
                              #216
                              @piemur
                              Ich hab nun js-controler auf 5.0.12 installiert und Vis-2 erfolgreich auf v2.2.6 installiert.
                              Widgets werden nun angezeigt.
                              Jetzt kann ich loslegen :-)
                              • P Piemur
                                @piemur
                                Digi-Bit
                                #217
                                @piemur sagte in Vis-2(.0) - Neuer Adapter als Beta:
                                @piemur
                                Wo gibt es den die V2.2.6 schon ?
                                mir wird nur die 2.2.5 angezeigt ;(
                                mfg
                                Digi-Bit
                                • D Digi-Bit
                                  @piemur
                                  mfg
                                  Digi-Bit
                                  #218
                                  @digi-bit
                                  Zufällig gerade geupdated:
                                  Adapter    "vis-2"        : 2.2.6    , installed 2.2.5  [Updatable]
                                    dflow41
                                    schrieb am zuletzt editiert von dflow41
                                    #219
                                    Hallo zusammen, ich musste bei mir am Wochenende alles mit BackitUp wiederherstellen. Hat auch soweit gut funktioniert bis auf den VIS-2-Adapter. Den musste ich natürlich neu installieren und jetzt bekomme ich ihn auch wieder grün angezeigt (V 2.1.5). Allerdings kann ich VIS2 nicht starten bzw. öffnen. Auch in die Einstellungen der Instanz komme ich nicht rein. Hat jemand schon mal hierzu Erfahrungen gesammelt oder Tipps wie ich VIS2 wieder zum laufen bekomme?
                                    Nachtrag: Habe gerade noch festgestellt, dass auch VIS1 nicht gestartet werden kann. Im Protokoll sehe ich aber eigentlich keine Fehler, aber seltsame Infos. Die Seite wird einfach nicht mehr aufgebaut.
                                    Kann mir hier jemand Hinweise geben was ich noch testen sollte?
                                    • v522533V Offline
                                      v522533V Offline
                                      v522533
                                      #220
                                      @piemur
                                      Bei mir werden leider immer noch keine Widgets angezeigt. Nur blaue Ladebalken.
                                      Gruß Chris
                                        @digi-bit
                                        sigi234S Online
                                        sigi234S Online
                                        #221
                                        @thomas-braun sagte in Vis-2(.0) - Neuer Adapter als Beta:
                                        Hallo, via Konsole oder per Admin?
                                        • sigi234S Online
                                          sigi234S Online
                                          #222
                                          kann keine Widgets auswählen, kommt ein Fehler:
                                          Edit2
