  4. nach Admin-Adapter-Update iobroker nicht über Web erreichbar
    5.2k
65 Beiträge 8 Kommentatoren 8.6k Aufrufe 6 Beobachtet
    @rennigel iob start admin --debug
    rennigel
    @homoran said in nach Admin-Adapter-Update iobroker nicht über Web erreichbar:
    pi@RPi4:/opt/iobroker $ iob start admin --debug
    pi@RPi4:/opt/iobroker $ iob list instances
      system.adapter.admin.0                  : admin                 : RPi4                                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    Kein "+" vor der Instanz ...
    Hab danach nochmal in Log geschaut, letzter Eintrag den Admin betreffend ist eine ca. ein 3/4 Stunde her, Meldung identisch wie vorhin:
    2023-08-03 15:06:42.517  - info: host.RPi4 system.adapter.admin.0 will be rebuilt
    2023-08-03 15:06:42.517  - warn: host.RPi4 adapter "admin" seems to be installed for a different version of Node.js. Trying to rebuild it... 3 attempt
    2023-08-03 15:07:23.333  - info: host.RPi4 instance system.adapter.admin.0 started with pid 6162
    2023-08-03 15:07:25.119  - error: host.RPi4 Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/adapter-core/build/index.js
    2023-08-03 15:07:25.119  - error: host.RPi4 Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.admin/main.js
    2023-08-03 15:07:25.124  - error: host.RPi4 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/adapter-core/build/index.js:21:1)
    2023-08-03 15:07:25.127  - error: host.RPi4 Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/adapter-core/build/index.js',
    2023-08-03 15:07:25.127  - error: host.RPi4 Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.admin/main.js'
    2023-08-03 15:07:25.128  - error: host.RPi4 instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2023-08-03 15:07:25.128  - info: host.RPi4 Rebuild for adapter system.adapter.admin.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
    • R rennigel
      @crunchip said in nach Admin-Adapter-Update iobroker nicht über Web erreichbar:
      @rennigel iob list instances
      pi@RPi4:/opt/iobroker $ iob start web
      + system.adapter.alexa2.0                 : alexa2                : RPi4                                     -  enabled
      + system.adapter.backitup.0               : backitup              : RPi4                                     -  enabled
      + system.adapter.botvac.0                 : botvac                : RPi4                                     -  enabled
      + system.adapter.discovery.0              : discovery             : RPi4                                     -  enabled
      + system.adapter.history.0                : history               : RPi4                                     -  enabled
      + system.adapter.hue-extended.0           : hue-extended          : RPi4                                     -  enabled
      + system.adapter.hue.0                    : hue                   : RPi4                                     -  enabled, port: 80
      + system.adapter.influxdb.0               : influxdb              : RPi4                                     -  enabled, port: 8086
      + system.adapter.info.0                   : info                  : RPi4                                     -  enabled
      + system.adapter.jarvis.0                 : jarvis                : RPi4                                     -  enabled
      + system.adapter.javascript.0             : javascript            : RPi4                                     -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : RPi4                                     -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.netatmo.0                : netatmo               : RPi4                                     -  enabled
      + system.adapter.nuki-extended.0          : nuki-extended         : RPi4                                     -  enabled
      + system.adapter.ping.0                   : ping                  : RPi4                                     -  enabled
        system.adapter.rickshaw.0               : rickshaw              : RPi4                                     -  enabled
      + system.adapter.shelly.0                 : shelly                : RPi4                                     -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.simple-api.0             : simple-api            : RPi4                                     -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.sourceanalytix.0         : sourceanalytix        : RPi4                                     -  enabled
        system.adapter.sprinklecontrol.0        : sprinklecontrol       : RPi4                                     - disabled
      + system.adapter.telegram.0               : telegram              : RPi4                                     -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.tr-064.0                 : tr-064                : RPi4                                     -  enabled
      + system.adapter.tr-064.1                 : tr-064                : RPi4                                     -  enabled
      + system.adapter.tr-064.2                 : tr-064                : RPi4                                     -  enabled
        system.adapter.vis.0                    : vis                   : RPi4                                     -  enabled
        system.adapter.web.0                    : web                   : RPi4                                     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.worx.0                   : worx                  : RPi4                                     -  enabled
      + system.adapter.yahka.0                  : yahka                 : RPi4                                     -  enabled
      + system.adapter.zigbee.0                 : zigbee                : RPi4                                     -  enabled, port: /dev/ttyACM0
      + instance is alive
      crunchipC Abwesend
      crunchipC Abwesend
      @rennigel probier mal eine 2te Admin Instanz
      iobroker add admin --enabled --port 8089
      und dann entsprechend den iobroker mit dem port aufrufen
      192.168.178.69:8089
      bzw probier es erst mit:
      geh ins Verzeichnis /opt/iobroker/node_modules/iobroker.admin/node_modules
      und nochmal einen rebuild oder kannst auch npm install --production ausführen
      HomoranH R 2 Antworten Letzte Antwort
        192.168.178.69:8089
        @crunchip sagte in nach Admin-Adapter-Update iobroker nicht über Web erreichbar:
        Dort aber einen npm rebuild statt des iob rebuild
          192.168.178.69:8089
          rennigel
          Habe jetzt folgendes gemacht:
          pi@RPi4:/opt/iobroker/log $ iobroker add admin --port 8089
          host.RPi4 create instance admin
          host.RPi4 object system.adapter.admin.1.alive created
          host.RPi4 object system.adapter.admin.1.connected created
          host.RPi4 object system.adapter.admin.1.compactMode created
          host.RPi4 object system.adapter.admin.1.cpu created
          host.RPi4 object system.adapter.admin.1.cputime created
          host.RPi4 object system.adapter.admin.1.memHeapUsed created
          host.RPi4 object system.adapter.admin.1.memHeapTotal created
          host.RPi4 object system.adapter.admin.1.memRss created
          host.RPi4 object system.adapter.admin.1.uptime created
          host.RPi4 object system.adapter.admin.1.inputCount created
          host.RPi4 object system.adapter.admin.1.outputCount created
          host.RPi4 object system.adapter.admin.1.eventLoopLag created
          host.RPi4 object system.adapter.admin.1.sigKill created
          host.RPi4 object system.adapter.admin.1.logLevel created
          host.RPi4 object system.adapter.admin.upload created
          host.RPi4 object admin.1.info created
          host.RPi4 object admin.1 created
          host.RPi4 object admin.1.info.connected created
          host.RPi4 object admin.1.info.connection created
          host.RPi4 object admin.1.info.newsFeed created
          host.RPi4 object admin.1.info.newsETag created
          host.RPi4 object admin.1.info.newsLastId created
          host.RPi4 object admin.1.info.updatesList created
          host.RPi4 Set default value of admin.1.info.connected:
          host.RPi4 Set default value of admin.1.info.connection: false
          host.RPi4 Set default value of admin.1.info.updatesList:
          host.RPi4 object system.adapter.admin.1 created
          pi@RPi4:/opt/iobroker/log $ cd /opt/iobroker/node_modules/iobroker.admin/node_modules
          pi@RPi4:/opt/iobroker/node_modules/iobroker.admin/node_modules $ npm install --production
          npm WARN config production Use `--omit=dev` instead.
          added 123 packages, removed 1 package, and audited 159 packages in 2m
          14 packages are looking for funding
            run `npm fund` for details
          found 0 vulnerabilities
          pi@RPi4:/opt/iobroker/node_modules/iobroker.admin/node_modules $ iob start admin.1
          Aber auf Port 8089 passiert auch nichts.
          (Hab's jetzt nur der Sicherheit wegen über den einen Rechner mit Edge und einen anderen mit Firefox probiert ... nur um den Browser als Fehlerquelle auszuschließen. Hat aber schon immer von beiden problemlos geklappt.)
          HomoranH crunchipC 2 Antworten Letzte Antwort
          • R rennigel
            @rennigel sagte in nach Admin-Adapter-Update iobroker nicht über Web erreichbar:
            list instances
            • R rennigel
              crunchipC Abwesend
              crunchipC Abwesend
              pi@RPi4:/opt/iobroker/node_modules/iobroker.admin/node_modules $ npm install --production npm WARN config production Use --omit=dev instead.
              ggf noch --omit=dev mit anhängen, admin 1 sollte aber normalerweise laufen
                Vielleicht wäre es einfacher das package-lock.json zu löschen.
                Mich wundert nur, dass gar nichts in Konsole oder log steht.
                Uwe-KU 1 Antwort Letzte Antwort
                  Uwe-KU Offline
                  Uwe-KU Offline
                  Uwe-K
                  @homoran Hallo, ich kämpfe mit dem gleichen Problem "IOB Broker nicht mehr erreichbar, sonst funktioniert aber alles : Zigbee, Debmatic etc "
                  habe hier schon viel mitgelesen, aber keinen Erfolg gehabt bisher.
                  Frage : soll ich hier "zwischenfragen" ? wird ggf verwirrend werden fürchte ich.
                  Bei einem eigenen Post könnte ich ggf auf die Suchfunktion verwiesen werden, dadurch habe ich ja diesen Thread gefunden ...
                  cu
                  Uwe
                  • Uwe-KU Uwe-K
                    crunchipC Abwesend
                    crunchipC Abwesend
                    @uwe-k sagte in nach Admin-Adapter-Update iobroker nicht über Web erreichbar:
                    ein admin Update?
                    mach einen eigenen Thread dazu auf, mit stichhaltigen Fakten
                    • R Offline
                      rennigel
                      pi@RPi4:~ $ iob list instances
                        system.adapter.admin.1                  : admin                 : RPi4                                     -  enabled, port: 8089, bind: 0.0.0.0, run as: admin
                      + instance is alive
                      Zweite Admin Instanz ist da, aber auch nicht "alive"
                      • R rennigel
                        + instance is alive
                        und beim Versuch zu starten auch nichts im log?
                        mach mal eine zweite Session in der Konsole auf u d starte dortt iob logs --watch
                        auf der anderen Konsole dann iob start admin.1
                        dann bitte die zeitgleiche Ausgabe aus den logs hier posten
                        • R Offline
                          rennigel
                          Habe ich getan.
                          Leider läuft mein log gerade mit ziemlichen warnings voll, weil a) mein NAS nicht läuft, weswegen influx meckert b) ich dauerhaft informiert werde, dass meine Shellys nicht sicher sind und c) mein Saugroboter spinnt ....
                          Abgesehen davon keine einzige Meldung während des Starts des Adapters admin.1
                          Ich habe es auch probiert mit --debug (in der Annahme, dass dann das Schreiben ins Log erzwungen wird).
                          Ich hänge es dennoch mal an, auch wenn es in meinen Augen nur "Ballast" ist.
                          2023-08-03 23:53:24.773  - info: influxdb.0 (4035) Connecting http://192.168.178.40:8086/ ...
                          2023-08-03 23:53:24.774  - info: influxdb.0 (4035) Influx DB Version used: 1.x
                          2023-08-03 23:53:24.779  - error: influxdb.0 (4035) Error: connect ECONNREFUSED 192.168.178.40:8086
                          2023-08-03 23:53:26.190  - warn: shelly.0 (4323) [authEnabled] 192.168.178.155 (shelly1 / shelly1-C4FC6C / SHSW-1#C4FC6C#1): This device is not protected via restricted login (see adapter documentation for details)
                          2023-08-03 23:53:26.267  - warn: shelly.0 (4323) [authEnabled] 192.168.178.152 (shellydimmer2 / shellydimmer2-48551900BDA6 / SHDM-2#48551900BDA6#1): This device is not protected via restricted login (see adapter documentation for details)
                          2023-08-03 23:53:26.297  - warn: shelly.0 (4323) [authEnabled] 192.168.178.160 (shellydimmer2 / shellydimmer2-40F52000E62F / SHDM-2#40F52000E62F#1): This device is not protected via restricted login (see adapter documentation for details)
                          2023-08-03 23:53:26.317  - warn: shelly.0 (4323) [authEnabled] 192.168.178.159 (shellydimmer2 / shellydimmer2-40F520015676 / SHDM-2#40F520015676#1): This device is not protected via restricted login (see adapter documentation for details)
                          2023-08-03 23:53:26.494  - info: botvac.0 (4620) devices found: 1
                          2023-08-03 23:53:27.071  - warn: botvac.0 (4620) could not update robot Staubsaugbär
                          2023-08-03 23:53:27.074  - warn: botvac.0 (4620) Read-only state "botvac.0.Staubsaugbär.status.reachable" has been written without ack-flag with value "true"
                          2023-08-03 23:53:27.154  - warn: shelly.0 (4323) [authEnabled] 192.168.178.157 (shelly1 / shelly1-C42940 / SHSW-1#C42940#1): This device is not protected via restricted login (see adapter documentation for details)
                          2023-08-03 23:53:28.888  - warn: shelly.0 (4323) [authEnabled] 192.168.178.156 (shelly1 / shelly1-C4F5D9 / SHSW-1#C4F5D9#1): This device is not protected via restricted login (see adapter documentation for details)
                          2023-08-03 23:53:31.372  - warn: shelly.0 (4323) [authEnabled] 192.168.178.153 (shellydimmer / shellydimmer-CC50E3F35994 / SHDM-1#CC50E3F35994#1): This device is not protected via restricted login (see adapter documentation for details)
                          2023-08-03 23:53:31.410  - warn: shelly.0 (4323) [authEnabled] 192.168.178.151 (shelly1 / shelly1-C4834E / SHSW-1#C4834E#1): This device is not protected via restricted login (see adapter documentation for details)
                          2023-08-03 23:53:32.599  - warn: shelly.0 (4323) [authEnabled] 192.168.178.154 (shelly1 / shelly1-C4870D / SHSW-1#C4870D#1): This device is not protected via restricted login (see adapter documentation for details)
                          2023-08-03 23:53:34.780  - info: influxdb.0 (4035) Connecting http://192.168.178.40:8086/ ...
                          2023-08-03 23:53:34.781  - info: influxdb.0 (4035) Influx DB Version used: 1.x
                          2023-08-03 23:53:34.791  - error: influxdb.0 (4035) Error: connect ECONNREFUSED 192.168.178.40:8086
                          2023-08-03 23:53:36.600  - warn: shelly.0 (4323) [authEnabled] 192.168.178.155 (shelly1 / shelly1-C4FC6C / SHSW-1#C4FC6C#1): This device is not protected via restricted login (see adapter documentation for details)
                          2023-08-03 23:53:36.618  - warn: shelly.0 (4323) [authEnabled] 192.168.178.152 (shellydimmer2 / shellydimmer2-48551900BDA6 / SHDM-2#48551900BDA6#1): This device is not protected via restricted login (see adapter documentation for details)
                          2023-08-03 23:53:36.666  - warn: shelly.0 (4323) [authEnabled] 192.168.178.160 (shellydimmer2 / shellydimmer2-40F52000E62F / SHDM-2#40F52000E62F#1): This device is not protected via restricted login (see adapter documentation for details)
                          2023-08-03 23:53:36.676  - warn: shelly.0 (4323) [authEnabled] 192.168.178.159 (shellydimmer2 / shellydimmer2-40F520015676 / SHDM-2#40F520015676#1): This device is not protected via restricted login (see adapter documentation for details)
                          2023-08-03 23:53:37.508  - warn: shelly.0 (4323) [authEnabled] 192.168.178.157 (shelly1 / shelly1-C42940 / SHSW-1#C42940#1): This device is not protected via restricted login (see adapter documentation for details)
                          2023-08-03 23:53:39.164  - warn: shelly.0 (4323) [authEnabled] 192.168.178.156 (shelly1 / shelly1-C4F5D9 / SHSW-1#C4F5D9#1): This device is not protected via restricted login (see adapter documentation for details)
                          2023-08-03 23:53:41.578  - warn: shelly.0 (4323) [authEnabled] 192.168.178.153 (shellydimmer / shellydimmer-CC50E3F35994 / SHDM-1#CC50E3F35994#1): This device is not protected via restricted login (see adapter documentation for details)
                          2023-08-03 23:53:41.706  - warn: shelly.0 (4323) [authEnabled] 192.168.178.151 (shelly1 / shelly1-C4834E / SHSW-1#C4834E#1): This device is not protected via restricted login (see adapter documentation for details)
                          2023-08-03 23:53:42.882  - warn: shelly.0 (4323) [authEnabled] 192.168.178.154 (shelly1 / shelly1-C4870D / SHSW-1#C4870D#1): This device is not protected via restricted login (see adapter documentation for details)
                          2023-08-03 23:53:44.791  - info: influxdb.0 (4035) Connecting http://192.168.178.40:8086/ ...
                          2023-08-03 23:53:44.791  - info: influxdb.0 (4035) Influx DB Version used: 1.x
                          2023-08-03 23:53:44.796  - error: influxdb.0 (4035) Error: connect ECONNREFUSED 192.168.178.40:8086
                          Das ist genau der Moment des (nicht funktionierenden) Starts des admin.1
                          Davor und dahinter sieht es im Log genauso aus.
                          In "iob list instances" imme rnoch kein "+"
                          crunchipC HomoranH 2 Antworten Letzte Antwort
                          • R rennigel
                            Habe ich getan.
                            crunchipC Abwesend
                            crunchipC Abwesend
                            @rennigel ist zwar noch früh am Morgen aber probier mal so
                            iob stop
                            iob del admin
                            iob fix
                            cd /opt/iobroker
                            npm install iobroker.admin --omit=dev
                            iob start
                            Danach
                            iob list instances
                            Sollte keine admin Instanz vorhanden sein
                            cd /opt/iobroker
                            npm add iobroker.admin
                            R 1 Antwort Letzte Antwort
                              iob stop
                              iob del admin
                              iob fix
                              cd /opt/iobroker
                              iob start
                              Danach
                              iob list instances
                              cd /opt/iobroker
                              rennigel
                              schrieb am zuletzt editiert von rennigel
                              @crunchip
                              Das ist in der Tat früh ... early bird und so ... ;-)
                              Beim Löschen erhalte ich folgende Meldung:
                              pi@RPi4:~ $ iob del admin
                              Delete adapter "admin"
                              host.RPi4 Counted 2 instances of admin
                              Cannot remove adapter "admin", because instance "info" depends on it!
                              Den Info einfach auch löschen und dann hinterher wieder installieren?
                              Gibt es eine Reihenfolge zu beachten?
                              Falls ja: nur mit "npm install iobroker.info" oder auch mit dem Zusatz "--omit=dev"
                              • R rennigel
                                Habe ich getan.
                                ich sehe keinerlei debug Ausgaben
                                  rennigel
                                  Hätte ich dann mit
                                  "iob start admin.1 --debug"
                                  starten müssen, damit die Instanz die richtige Logstufe hat?
                                  Ich wollte das gerade ausprobieren, habe iob wieder gestartet, hatte in einem 2. Fenster das Log mitlaufen und als ich da aus Neugierde währenddessen reinschaue ....
                                  2023-08-04 09:30:28.926  - info: host.RPi4 iobroker.js-controller version 4.0.24 js-controller starting
                                  2023-08-04 09:30:28.935  - info: host.RPi4 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                                  2023-08-04 09:30:28.936  - info: host.RPi4 hostname: RPi4, node: v18.17.0
                                  2023-08-04 09:30:28.938  - info: host.RPi4 ip addresses: 192.168.178.21 2a02:2f4:4217:cc00:5e5d:c93:a398:e367 fe80::a42e:3571:42bc:6227 192.168.178.69 2a02:2f4:4217:cc00:c97c:4f8d:f209:b490 fe80::8414:2919:516a:9a2f
                                  2023-08-04 09:30:30.462  - info: host.RPi4 connected to Objects and States
                                  2023-08-04 09:30:30.517  - info: host.RPi4 added notifications configuration of host
                                  2023-08-04 09:30:31.259  - info: host.RPi4 31 instances found
                                  2023-08-04 09:30:31.321  - info: host.RPi4 starting 29 instances
                                  2023-08-04 09:30:31.501  - info: host.RPi4 instance system.adapter.admin.0 started with pid 17070
                                  2023-08-04 09:30:35.072  - info: admin.0 (17070) starting. Version 6.7.0 in /opt/iobroker/node_modules/iobroker.admin, node: v18.17.0, js-controller: 4.0.24
                                  2023-08-04 09:30:35.136  - info: admin.0 (17070) requesting all states
                                  2023-08-04 09:30:35.137  - info: admin.0 (17070) requesting all objects
                                  2023-08-04 09:30:36.658  - info: host.RPi4 instance system.adapter.admin.1 started with pid 17086
                                  2023-08-04 09:30:37.462  - info: admin.0 (17070) received all objects
                                  2023-08-04 09:30:38.008  - info: admin.0 (17070) socket.io server listening on port 8081
                                  2023-08-04 09:30:38.012  - info: admin.0 (17070) http server listening on port 8081
                                  2023-08-04 09:30:38.012  - info: admin.0 (17070) Use link "http://127.0.0.1:8081" to configure.
                                  2023-08-04 09:30:39.478  - info: host.RPi4 instance system.adapter.history.0 started with pid 17106
                                  2023-08-04 09:30:40.671  - info: admin.1 (17086) starting. Version 6.7.0 in /opt/iobroker/node_modules/iobroker.admin, node: v18.17.0, js-controller: 4.0.24
                                  2023-08-04 09:30:40.740  - info: admin.1 (17086) requesting all states
                                  2023-08-04 09:30:40.742  - info: admin.1 (17086) requesting all objects
                                  2023-08-04 09:30:42.805  - info: admin.1 (17086) received all objects
                                  2023-08-04 09:30:43.049  - info: history.0 (17106) starting. Version 2.2.4 in /opt/iobroker/node_modules/iobroker.history, node: v18.17.0, js-controller: 4.0.24
                                  2023-08-04 09:30:43.206  - info: history.0 (17106) enabled logging of tr-064.0.callmonitor.lastCall.caller (Count=1), Alias=false
                                  2023-08-04 09:30:43.207  - info: history.0 (17106) enabled logging of tr-064.0.callmonitor.lastCall.callee (Count=2), Alias=false
                                  2023-08-04 09:30:43.209  - info: history.0 (17106) enabled logging of tr-064.0.callmonitor.lastCall.duration (Count=3), Alias=false
                                  2023-08-04 09:30:43.211  - info: history.0 (17106) enabled logging of 0_userdata.0.QVR.Kamera-hinten.bewegung-erkannt (Count=4), Alias=false
                                  2023-08-04 09:30:43.474  - info: admin.1 (17086) socket.io server listening on port 8089
                                  2023-08-04 09:30:43.480  - info: admin.1 (17086) http server listening on port 8089
                                  2023-08-04 09:30:43.482  - info: admin.1 (17086) Use link "http://127.0.0.1:8089" to configure.
                                  Beide Admin-Instanzen starten!
                                  Ich habe in der Zwischenzeit absolut nichts verändert oder rumprobiert (um Eure Hilfe nicht mit meinem potentiellen Rumgepfusche zu gefährden).
                                  Schön, dass es jetzt plötzlich läuft, aber die Ursache zu wissen wäre ggf. hilfreich, um zu verhindern, dass das wieder passiert.
                                  Beim Start der GUI kam dann folgende Meldung:
                                  Kann das ursächlich sein? Vor allem, dass dann ausgerechnet NUR der Admin-Adapter nicht startet? Klar, zu wenig Speicher sorgt für Probleme, aber hängen die beiden Sachen Kausal zusammen?
                                  Als ich gestern "iob diag" ausgeführt habe, sah es auch nicht ganz so dramatisch aus ....
                                  *** MEMORY ***
                                  Mem:           1.9G        1.2G        271M         20M        423M        587M
                                  Swap:           99M        9.0M         90M
                                  Total:         2.0G        1.2G        362M
                                  Reichen meine 2GB RAM tatsächlich nicht?
                                  Oder habe ich irgendwo einen versteckten Speicherfresser ...?
                                  Auf dem RPi ist nichts anderes als iobroker installiert.
                                  Aber abgesehen vom RAM, was sollte ich noch tun, um das System nachhaltig zu stabilisieren?
                                  • R rennigel
                                    Hätte ich dann mit
                                    *** MEMORY ***
                                    Swap:           99M        9.0M         90M
                                    Sehr wahrscheinlich nicht!
                                    Das hätte aber irgendwo zu sehen sein müssen (log/Konsole)
                                    da ist definitiv keine Reserve mehr (ohne admin)
                                    nach dem Start des Admin waren ja nur noch 30MB frei.
                                    hätte man schon bei deiner langen Liste an Instanzen ahnen können
                                    • R rennigel
                                      Hätte ich dann mit
                                      *** MEMORY ***
                                      Swap:           99M        9.0M         90M
                                      crunchipC Abwesend
                                      crunchipC Abwesend
                                      2GB RAM
                                      Da hatte ich oben gar nicht darauf geachtet.
                                      Notfallplan
                                      Deinstalliere den info Adapter, braucht man nicht.
                                      Den discovery Adapter deaktivieren ggf auch löschen, wird eigentlich auch nicht benötigt.
                                      Den backitup Adapter kannst du mittels script "schlafen legen" bzw nur für den Zeitraum des backups aktivieren.
                                      Dies sollte ein paar Ram freischaufeln.
                                      Langfristig wirst du aber etwas mit mehr Ram benötigen
                                      Ps
                                      Und den 2ten admin natürlich wieder löschen
                                      • R Offline
                                        rennigel
                                        @crunchip
                                        Bereinige grad die installierten Adapter, danke für die Infos.
                                        Was ist mit Adapter web?
                                        Ich lese, Admin hat seinen eigenen Webserver, braucht als web nicht.
                                        vis und rickshaw habe ich gelöscht (nutze ich nicht), aber wird web auch für jarvis benötigt? Ich vermute mal, ja.
                                        Gibt es noch irgendwelche purge-Aktionen, Cache-Lösch-Funktionen o.ä., die den Speicher optimieren?
                                        • R Offline
                                          rennigel
                                          Habe nochmal "iob diag" ausgeführt, sieht im Speicher jetzt so aus:
                                          *** MEMORY ***
                                          Mem:           1.9G        1.2G        459M         18M        230M        568M
                                          Swap:           99M         78M         21M
                                          Total:         2.0G        1.3G        481M
                                                   1872 M total memory
                                                   1182 M used memory
                                                    158 M active memory
                                                   1144 M inactive memory
                                                    459 M free memory
                                                     43 M buffer memory
                                                    186 M swap cache
                                                     99 M total swap
                                                     78 M used swap
                                                     21 M free swap
                                          Knapp 0,5 GB freier Speicher klingt jetzt nicht so wenig, aber ihr meintet, das allgemein die 2GB schon knapp bemessen sind (wie kommen denn dann die Leute mit RPi3 und 1 GB klar ...?).
                                          Wie sind denn die Zahlen praxisorient richtig zu interpretieren, oder anders: Wieviel freien Speicher braucht iobroker um stabil zu laufen (in % vom Gesamt-RAM oder absoluten MB)
                                          crunchipC Thomas BraunT 2 Antworten Letzte Antwort
