  4. Bambulab 3d-Drucker adapter
    apollon77A
336 Beiträge 54 Kommentatoren 142.2k Aufrufe 53 Beobachtet
  • D DarkDevil
    Leider nicht, es bleibt beim Fehler
    DutchmanD
    DutchmanD
    Dutchman
    @darkdevil sagte in Bambulab 3d-Drucker adapter:
    der Fehler ist noch 1:1 der selbe ?
    • D DarkDevil
      DutchmanD
      DutchmanD
      Dutchman
      bitte nochmal von git probieren, ich habe da noch was gefunden und ergänzt
      • DutchmanD Dutchman
        D
        D
        DarkDevil
        @dutchman
        auch nach dem letzten Update bekomme ich die Fehler. Die Print Message lautet immer noch:
        	Printer Message {"print":{"upload":{"status":"idle","progress":0,"message":""},"nozzle_temper":21.125,"nozzle_target_temper":0,"bed_temper":19.5,"bed_target_temper":0,"chamber_temper":5,"mc_print_stage":"1","heatbreak_fan_speed":"0","cooling_fan_speed":"0","big_fan1_speed":"0","big_fan2_speed":"0","mc_percent":0,"mc_remaining_time":0,"ams_status":0,"ams_rfid_status":6,"hw_switch_state":1,"spd_mag":100,"spd_lvl":2,"print_error":83935249,"lifecycle":"product","wifi_signal":"-52dBm","gcode_state":"IDLE","gcode_file_prepare_percent":"0","queue_number":0,"project_id":"0","profile_id":"0","task_id":"0","subtask_id":"0","subtask_name":"","gcode_file":"","stg":[],"stg_cur":0,"print_type":"idle","home_flag":16904,"mc_print_line_number":"0","mc_print_sub_stage":0,"sdcard":true,"force_upgrade":false,"mess_production_state":"active","layer_num":0,"total_layer_num":0,"hms":[],"online":{"ahb":false,"rfid":false,"version":87449353},"ams":{"ams":[],"ams_exist_bits":"0","tray_exist_bits":"0","tray_is_bbl_bits":"0","tray_tar":"255","tray_now":"254","tray_pre":"254","tray_read_done_bits":"0","tray_reading_bits":"0","version":1,"insert_flag":true,"power_on_flag":false},"ipcam":{"ipcam_dev":"1","ipcam_record":"enable","timelapse":"disable","mode_bits":3},"vt_tray":{"id":"254","tag_uid":"0000000000000000","tray_id_name":"","tray_info_idx":"","tray_type":"","tray_sub_brands":"","tray_color":"00000000","tray_weight":"0","tray_diameter":"0.00","tray_temp":"0","tray_time":"0","bed_temp_type":"0","bed_temp":"0","nozzle_temp_max":"0","nozzle_temp_min":"0","xcam_info":"000000000000000000000000","tray_uuid":"00000000000000000000000000000000","remain":0,"k":0.019999999552965164,"n":1.399999976158142},"lights_report":[{"node":"chamber_light","mode":"off"}],"upgrade_state":{"sequence_id":0,"progress":"","status":"","consistency_request":false,"dis_state":0,"err_code":0,"force_upgrade":false,"message":"","module":"","new_version_state":2,"new_ver_list":[]},"command":"push_status","msg":0,"sequence_id":"19"}}
        • D DarkDevil
          @dutchman
          DutchmanD
          DutchmanD
          Dutchman
          Hmm sehr merkwürdig, ich habe mir deine MQTT Nachricht in de adapter kopiert und erhalte selbe diese Fehler nicht :/
          Habe aber auch noch eine kleine optimalisierung gemacht im code, ziehe mal bitte nochmal neu von git und beachte das Jetzt auch die version 1.5 installiert wird ich erhoffe mir das es damit erledigt ist :)
            D
            D
            DarkDevil
            @dutchman ich habe den adapter vorhin einmal komplett gelöscht und von github die version 1.5. geladen.
            der Fehler hat sich verändert :/
            	[messageHandler] TypeError: Cannot read properties of undefined (reading 'ams_exist_bits') | TypeError: Cannot read properties of undefined (reading 'ams_exist_bits') at Bambulab.messageHandler (/opt/iobroker/node_modules/iobroker.bambulab/main.js:199:57) at MqttClient.<anonymous> (/opt/iobroker/node_modules/iobroker.bambulab/main.js:107:11) at MqttClient.emit (node:events:513:28) at MqttClient._handlePublish (/opt/iobroker/node_modules/mqtt/lib/client.js:1547:12) at MqttClient._handlePacket (/opt/iobroker/node_modules/mqtt/lib/client.js:535:12) at work (/opt/iobroker/node_modules/mqtt/lib/client.js:438:12) at Writable.writable._write (/opt/iobroker/node_modules/mqtt/lib/client.js:452:5) at doWrite (/opt/iobroker/node_modules/mqtt/node_modules/readable-stream/lib/_stream_writable.js:409:139) at writeOrBuffer (/opt/iobroker/node_modules/mqtt/node_modules/readable-stream/lib/_stream_writable.js:398:5) at Writable.write (/opt/iobroker/node_modules/mqtt/node_modules/readable-stream/lib/_stream_writable.js:307:11)
            • D DarkDevil
              DutchmanD
              DutchmanD
              Dutchman
              schrieb am zuletzt editiert von Dutchman
              Bitte noch einmal neu von git ziehen habe da noch eine Stelle geändert
              Edit: Per chat bestaetigt das es hiermit geloest ist :)
              BjoernFB 1 Antwort Letzte Antwort
                BjoernFB
                BjoernFB
                BjoernF
                schrieb am zuletzt editiert von BjoernF
                @dutchman Genial dass du hier an einem Adapter arbeitest. Ich behelfe mir aktuell noch mit einer Connection über Home Assistant die ich mir dann in IOB rüber ziehe.
                Nebst den Funktionen die du schon auf der Liste hast, wären noch folgende Statusabfragen interessant, die man sich ggf. in die VIS einbauen könnte.
                • Pinterstatus (Printing, idle, error usw.)
                • PrintProgress
                • remaining time
                • print time
                • Bed temperature
                • Nozzle Temperature
                • AMS infos (tray details)
                • Current layer
                • und und und :-) in HA sind echt viele Status Daten drin, die er sich aus dem Drucker per MQTT zieht, wäre super wenn man die auch in den IOB Adapter zur Verfügung hätte, dann könnte die Brücke über HA wieder raus ;-)
                EDIT: Erinnerung an mich selbst, erst checken dann labern LOL sehe nun dass ja alles oben genannte bereits drin ist im Adapter!
                GEILE ARBEIT!
                VG BJörn
                • BjoernFB BjoernF
                  • PrintProgress
                  • remaining time
                  • print time
                  • Bed temperature
                  • Current layer
                  GEILE ARBEIT!
                  VG BJörn
                  DutchmanD
                  DutchmanD
                  Dutchman
                  @bjoernf sagte in Bambulab 3d-Drucker adapter:
                  GEILE ARBEIT!
                  danke fuer die blumen :) ja glaube von deiner liste habe ich alles drin ;)
                    GEILE ARBEIT!
                    BjoernFB
                    BjoernFB
                    BjoernF
                    @dutchman wobei print end time konnte ich jetzt noch nicht finden in den DPs
                    • BjoernFB BjoernF
                      DutchmanD
                      DutchmanD
                      Dutchman
                      Hmm end Zeit nicht, remaining time wohl.
                      Da der Wert nicht vom Drucker kommt könnte man aber ne Berechnung einbauen
                      Wen gewünscht bitte kleine issue auf git mit der info erstellen dan arbeite ich die issues ab und Beier es bei einer nächsten Version ein
                        Aktuelle Test Version 0.3.0-beta.3
                        Veröffentlichungsdatum 28.07.2023
                        Github Link https://github.com/DrozmotiX/ioBroker.bambulab
                        Nach Anregungen in und node-red workflow diesem Forum Topic dachte ich mir es wird zeit auch fuer den bambulab eine iOBroker Integration zu implementieren.
                        Supported devices :
                        • X1
                        • P1p (der P1s muss noch getestet werden)
                        Supported controls:
                        pause/resume/start/stop
                        control lights (chamber & head)
                        provide custom g-code
                        es werden mehr folgen, wen ihr wünsche habt bitte in diesem thread melden oder am besten ein git-issue erstellen !
                        Momentan wirft der adapter beim starten noch einige "warn" Meldungen, diese können ignoriert werden und werde in v0.2.0 behoben sein
                        Viel spass beim drucken, Über feedback werde ich ich sehr freuen!
                        moment kann man den adapter leider nur ueber git installieren, aufnähme in die repo ist beantragt :)
                        Status der implementierung:
                        Supported models
                        Printer-Model Status
                        P1p ✅
                        P1s ❓needs testing
                        X1 ✅
                        AMS ✅
                        Supported commands
                        Command X1C X1 P1P P1S
                        Custom g-code ✅ ✅ ✅ ❓ needs testing
                        Pause ✅ ✅ ✅ ❓ needs testing
                        Resume ✅ ✅ ✅ ❓ needs testing
                        Stop ✅ ✅ ✅ ❓ needs testing
                        Fan-Aux ✅ ✅ ❓ needs testing ❓ needs testing
                        Fan-Chamber ✅ ✅ ❓ needs testing ❓ needs testing
                        Fan-ToolHead ✅ ✅ ❓ needs testing ❓ needs testing
                        Light-Chamber ✅ ✅ ❓ needs testing ❓ needs testing
                        Light-Nozzle ✅ ✅ ❓ needs testing ❓ needs testing
                        Light-Logo ✅ ✅ ❓ needs testing ❓ needs testing
                        Temperature-Bed ✅ ✅ ✅ ❓ needs testing
                        Temperature-Nozzle ✅ ✅ ✅ ❓ needs testing
                        Speed Level ✅ ✅ ✅ ❓ needs testing
                        To-Do
                        Implement more commands, please provide feedback what we need ❗
                        Optimize state attributes definitions
                        Test printer series P1S
                        S
                        S
                        SoerenKaiser99
                        @dutchman ich habe seit eben einen P1S. Kann ich helfen beim Testen?
                        • WebrangerW
                          WebrangerW
                          Webranger
                          Seit Donnerstg steht nun ein x1C bei mir im Keller.
                          Hab den Adapter ohne Probleme installieren können.
                          Ich seh allerding glaube ich nicht alle Datenpunkte.
                          z.B. sind bei mir nicht zu finden:
                          Pinterstatus (Printing, idle, error usw.), PrintProgress, remaining time, print time, Bed temperature, Nozzle Temperature, AMS infos (tray details), Current layer
                          Bei mir sieht es so aus:
                          Hab ich irgendwas vergessen?
                          Gruss Danyel
                          Intel NUC Celeron, Xiaomi Gateway, Fritzbox 7590, XS1
                          A DutchmanD 2 Antworten Letzte Antwort
                          • S
                            S
                            spoeh-man
                            bei mir wirft der adapter ständig Fehler
                            	[messageHandler] TypeError: Cannot read properties of undefined (reading 'ams') | TypeError: Cannot read properties of undefined (reading 'ams') at Bambulab.messageHandler (/opt/iobroker/node_modules/iobroker.bambulab/main.js:199:57) at MqttClient.<anonymous> (/opt/iobroker/node_modules/iobroker.bambulab/main.js:107:11) at MqttClient.emit (node:events:514:28) at MqttClient._handlePublish (/opt/iobroker/node_modules/mqtt/lib/client.js:1547:12) at MqttClient._handlePacket (/opt/iobroker/node_modules/mqtt/lib/client.js:535:12) at work (/opt/iobroker/node_modules/mqtt/lib/client.js:438:12) at writable._write (/opt/iobroker/node_modules/mqtt/lib/client.js:452:5) at doWrite (/opt/iobroker/node_modules/mqtt/node_modules/readable-stream/lib/_stream_writable.js:409:139) at writeOrBuffer (/opt/iobroker/node_modules/mqtt/node_modules/readable-stream/lib/_stream_writable.js:398:5) at Writable.write (/opt/iobroker/node_modules/mqtt/node_modules/readable-stream/lib/_stream_writable.js:307:11)
                            • WebrangerW Webranger
                              Gruss Danyel
                              A
                              A
                              Apropo
                              @webranger Sieht bei mir leider genauso aus. Hast du inzwischen raus gefunden woran es liegt?
                              Und wie ist das mit der Seriennummer? Muss man die nur beim P1P angeben? Ich finde die bei meinem X1CC in den Netzwerkeinstellungen nicht.
                              WebrangerW tugsiT 2 Antworten Letzte Antwort
                              • A Apropo
                                WebrangerW
                                WebrangerW
                                Webranger
                                @apropo nein der Fehler ist immer noch aber der Entwickler ist dran. Zu der Seriennummer, die musste ich bei mir auch erst suchen aber steht irgendwo kann dir aber auch wirklich gerade nicht sagen wo.
                                • A Apropo
                                  tugsiT
                                  tugsiT
                                  tugsi
                                  @apropo Seriennummer findest Du in der Handy-App unter Einstellungen - Firmware-Version
                                  Die Fehlermeldungen hab ich auch.
                                  Master ioBroker in Proxmox als LXC auf 1. Tiny-Lenovo, Proxmox-VM als Slave auf 2. Tinyi-Lenovo mit Zigbee und Monitor zur Visualisierung, Hauptautomatisierung über S7 auf Beckhoff CX, dazu noch Shelly, Homematic...
                                  MatzebhvM 1 Antwort Letzte Antwort
                                  • tugsiT tugsi
                                    MatzebhvM
                                    MatzebhvM
                                    Matzebhv
                                    Ich habe den Adapter erstmal wegen des Fehlers deaktiviert, sobald der Drucker läuft wird das Log komplett geflutet.
                                    Matze
                                    BTW, was ein geiler Drucker ( X1 )
                                    • D
                                      D
                                      djalexz
                                      Sehr sehr GEIL
                                      1000 Dank @Dutchman für den Adapter.
                                      Richtig nice. Bin echt begeistert :-D
                                      Ich werde in den nächsten Tagen mal alles durchtesten und entsprchend kommentieren.
                                      Wenn wir es jetzt noch hinbekommen diese dämliche Kamera vom Bambu im ioBroker anzeigen zu lassen, sind keine Wünsche mehr offen und der Drucker ist vollumfänglich im Smarthome integriert.
                                      PS. Die ganzen Anregungen im Bambulab GIT von wegen RTSPS, HomeAssistant und Co. funktionieren beim ioBroker nicht.
                                      Wie dem auch sei. Nochmals vielen vielen Dank für die Arbeit und ich freue mich zu Testen.
                                      LG Alex
                                      • D djalexz
                                        Sehr sehr GEIL
                                        LG Alex
                                        BjoernFB
                                        BjoernFB
                                        BjoernF
                                        @djalexz
                                        Hey Alex, Versuch mal den rtsp adapter, funzt bei mir mit zwei X1C sehr gut. Nur nach nem powercycle muss die Instanz neu gestartet werden 😉
                                        • BjoernFB BjoernF
                                          @djalexz
                                          D
                                          D
                                          djalexz
                                          @bjoernf
                                          Vielen Dank, aber das habe ich auch schon durch, leider ohne Erfolg.
                                          Anscheinend liegt das daran, dass via RTSPS ein Zertifikat von dem Drucker akzeptiert werden muss, dass aber in dem RTSP Adapter nicht möglich ist.
                                          Habe die neuste Firmware des Druckers und der RTSP Adapter wird ja leider schon ewig nicht mehr weiterentwickelt.
                                          LG Alex
                                          83.9k
