Bambulab 3d-Drucker adapter
Ich habe gerade auf die neue Version geupdatet und in den Einstellungen den P1P ausgewählt.
Jetzt bekomme ich im log zu jeder aktualisierung (5 Sekunden) folgenden Fehler:
[messageHandler] TypeError: Cannot read properties of undefined (reading 'ams') | TypeError: Cannot read properties of undefined (reading 'ams') at Bambulab.messageHandler (/opt/iobroker/node_modules/iobroker.bambulab/main.js:154:43) at MqttClient.<anonymous> (/opt/iobroker/node_modules/iobroker.bambulab/main.js:93:11) at MqttClient.emit (node:events:513:28) at MqttClient._handlePublish (/opt/iobroker/node_modules/mqtt/lib/client.js:1547:12) at MqttClient._handlePacket (/opt/iobroker/node_modules/mqtt/lib/client.js:535:12) at work (/opt/iobroker/node_modules/mqtt/lib/client.js:438:12) at Writable.writable._write (/opt/iobroker/node_modules/mqtt/lib/client.js:452:5) at doWrite (/opt/iobroker/node_modules/mqtt/node_modules/readable-stream/lib/_stream_writable.js:409:139) at writeOrBuffer (/opt/iobroker/node_modules/mqtt/node_modules/readable-stream/lib/_stream_writable.js:398:5) at Writable.write (/opt/iobroker/node_modules/mqtt/node_modules/readable-stream/lib/_stream_writable.js:307:11)@darkdevil druckst du gerade ohne ams? oder ist keine angeschlossen?
kannst du den mqtt json code mitschneiden und bereitstellen? -
[messageHandler] TypeError: Cannot read properties of undefined (reading 'ams') | TypeError: Cannot read properties of undefined (reading 'ams') at Bambulab.messageHandler (/opt/iobroker/node_modules/iobroker.bambulab/main.js:154:43) at MqttClient.<anonymous> (/opt/iobroker/node_modules/iobroker.bambulab/main.js:93:11) at MqttClient.emit (node:events:513:28) at MqttClient._handlePublish (/opt/iobroker/node_modules/mqtt/lib/client.js:1547:12) at MqttClient._handlePacket (/opt/iobroker/node_modules/mqtt/lib/client.js:535:12) at work (/opt/iobroker/node_modules/mqtt/lib/client.js:438:12) at Writable.writable._write (/opt/iobroker/node_modules/mqtt/lib/client.js:452:5) at doWrite (/opt/iobroker/node_modules/mqtt/node_modules/readable-stream/lib/_stream_writable.js:409:139) at writeOrBuffer (/opt/iobroker/node_modules/mqtt/node_modules/readable-stream/lib/_stream_writable.js:398:5) at Writable.write (/opt/iobroker/node_modules/mqtt/node_modules/readable-stream/lib/_stream_writable.js:307:11)Alles klar danke, ich dachte die Situation wenn man keine ams hat richtig abgefangen zu haben da ist aber noch ein Fehler
Bitte Adapter einmal auf debug stellen und posten was bei Printer Message kommt (eventuelle Seriennummer & Token entfernen)
Printer Message {"print":{"upload":{"status":"idle","progress":0,"message":""},"nozzle_temper":20.5,"nozzle_target_temper":0,"bed_temper":18.875,"bed_target_temper":0,"chamber_temper":5,"mc_print_stage":"1","heatbreak_fan_speed":"0","cooling_fan_speed":"0","big_fan1_speed":"0","big_fan2_speed":"0","mc_percent":0,"mc_remaining_time":0,"ams_status":0,"ams_rfid_status":6,"hw_switch_state":1,"spd_mag":100,"spd_lvl":2,"print_error":0,"lifecycle":"product","wifi_signal":"-53dBm","gcode_state":"IDLE","gcode_file_prepare_percent":"0","queue_number":0,"project_id":"0","profile_id":"0","task_id":"0","subtask_id":"0","subtask_name":"","gcode_file":"","stg":[],"stg_cur":0,"print_type":"idle","home_flag":16648,"mc_print_line_number":"0","mc_print_sub_stage":0,"sdcard":true,"force_upgrade":false,"mess_production_state":"active","layer_num":0,"total_layer_num":0,"hms":[],"online":{"ahb":false,"rfid":false,"version":689131425},"ams":{"ams":[],"ams_exist_bits":"0","tray_exist_bits":"0","tray_is_bbl_bits":"0","tray_tar":"255","tray_now":"254","tray_pre":"254","tray_read_done_bits":"0","tray_reading_bits":"0","version":1,"insert_flag":true,"power_on_flag":false},"vt_tray":{"id":"254","tag_uid":"0000000000000000","tray_id_name":"","tray_info_idx":"","tray_type":"","tray_sub_brands":"","tray_color":"00000000","tray_weight":"0","tray_diameter":"0.00","tray_temp":"0","tray_time":"0","bed_temp_type":"0","bed_temp":"0","nozzle_temp_max":"0","nozzle_temp_min":"0","xcam_info":"000000000000000000000000","tray_uuid":"00000000000000000000000000000000","remain":0,"k":0.019999999552965164,"n":1.399999976158142},"lights_report":[{"node":"chamber_light","mode":"off"}],"ipcam":{"ipcam_dev":"1","ipcam_record":"enable","timelapse":"disable","mode_bits":3},"upgrade_state":{"sequence_id":0,"progress":"","status":"","consistency_request":false,"dis_state":0,"err_code":0,"force_upgrade":false,"message":"","module":"","new_version_state":2,"new_ver_list":[]},"command":"push_status","msg":0,"sequence_id":"33"}}Ich hoffe, dass das der richtige Eintrag ist :/
@darkdevil sagte in Bambulab 3d-Drucker adapter:
jep :)
ok ich hatte erwartet das dan gar kein Datenpunkt AMS kommt, AMS ist aber da nur halt lehr dadurch knallt der code
Fixed in jetziger git versions, bitte mal neu ziehen und probieren :)
Leider nicht, es bleibt beim Fehler
der Fehler ist noch 1:1 der selbe ?
bitte nochmal von git probieren, ich habe da noch was gefunden und ergänzt
auch nach dem letzten Update bekomme ich die Fehler. Die Print Message lautet immer noch:
Printer Message {"print":{"upload":{"status":"idle","progress":0,"message":""},"nozzle_temper":21.125,"nozzle_target_temper":0,"bed_temper":19.5,"bed_target_temper":0,"chamber_temper":5,"mc_print_stage":"1","heatbreak_fan_speed":"0","cooling_fan_speed":"0","big_fan1_speed":"0","big_fan2_speed":"0","mc_percent":0,"mc_remaining_time":0,"ams_status":0,"ams_rfid_status":6,"hw_switch_state":1,"spd_mag":100,"spd_lvl":2,"print_error":83935249,"lifecycle":"product","wifi_signal":"-52dBm","gcode_state":"IDLE","gcode_file_prepare_percent":"0","queue_number":0,"project_id":"0","profile_id":"0","task_id":"0","subtask_id":"0","subtask_name":"","gcode_file":"","stg":[],"stg_cur":0,"print_type":"idle","home_flag":16904,"mc_print_line_number":"0","mc_print_sub_stage":0,"sdcard":true,"force_upgrade":false,"mess_production_state":"active","layer_num":0,"total_layer_num":0,"hms":[],"online":{"ahb":false,"rfid":false,"version":87449353},"ams":{"ams":[],"ams_exist_bits":"0","tray_exist_bits":"0","tray_is_bbl_bits":"0","tray_tar":"255","tray_now":"254","tray_pre":"254","tray_read_done_bits":"0","tray_reading_bits":"0","version":1,"insert_flag":true,"power_on_flag":false},"ipcam":{"ipcam_dev":"1","ipcam_record":"enable","timelapse":"disable","mode_bits":3},"vt_tray":{"id":"254","tag_uid":"0000000000000000","tray_id_name":"","tray_info_idx":"","tray_type":"","tray_sub_brands":"","tray_color":"00000000","tray_weight":"0","tray_diameter":"0.00","tray_temp":"0","tray_time":"0","bed_temp_type":"0","bed_temp":"0","nozzle_temp_max":"0","nozzle_temp_min":"0","xcam_info":"000000000000000000000000","tray_uuid":"00000000000000000000000000000000","remain":0,"k":0.019999999552965164,"n":1.399999976158142},"lights_report":[{"node":"chamber_light","mode":"off"}],"upgrade_state":{"sequence_id":0,"progress":"","status":"","consistency_request":false,"dis_state":0,"err_code":0,"force_upgrade":false,"message":"","module":"","new_version_state":2,"new_ver_list":[]},"command":"push_status","msg":0,"sequence_id":"19"}} -
Printer Message {"print":{"upload":{"status":"idle","progress":0,"message":""},"nozzle_temper":21.125,"nozzle_target_temper":0,"bed_temper":19.5,"bed_target_temper":0,"chamber_temper":5,"mc_print_stage":"1","heatbreak_fan_speed":"0","cooling_fan_speed":"0","big_fan1_speed":"0","big_fan2_speed":"0","mc_percent":0,"mc_remaining_time":0,"ams_status":0,"ams_rfid_status":6,"hw_switch_state":1,"spd_mag":100,"spd_lvl":2,"print_error":83935249,"lifecycle":"product","wifi_signal":"-52dBm","gcode_state":"IDLE","gcode_file_prepare_percent":"0","queue_number":0,"project_id":"0","profile_id":"0","task_id":"0","subtask_id":"0","subtask_name":"","gcode_file":"","stg":[],"stg_cur":0,"print_type":"idle","home_flag":16904,"mc_print_line_number":"0","mc_print_sub_stage":0,"sdcard":true,"force_upgrade":false,"mess_production_state":"active","layer_num":0,"total_layer_num":0,"hms":[],"online":{"ahb":false,"rfid":false,"version":87449353},"ams":{"ams":[],"ams_exist_bits":"0","tray_exist_bits":"0","tray_is_bbl_bits":"0","tray_tar":"255","tray_now":"254","tray_pre":"254","tray_read_done_bits":"0","tray_reading_bits":"0","version":1,"insert_flag":true,"power_on_flag":false},"ipcam":{"ipcam_dev":"1","ipcam_record":"enable","timelapse":"disable","mode_bits":3},"vt_tray":{"id":"254","tag_uid":"0000000000000000","tray_id_name":"","tray_info_idx":"","tray_type":"","tray_sub_brands":"","tray_color":"00000000","tray_weight":"0","tray_diameter":"0.00","tray_temp":"0","tray_time":"0","bed_temp_type":"0","bed_temp":"0","nozzle_temp_max":"0","nozzle_temp_min":"0","xcam_info":"000000000000000000000000","tray_uuid":"00000000000000000000000000000000","remain":0,"k":0.019999999552965164,"n":1.399999976158142},"lights_report":[{"node":"chamber_light","mode":"off"}],"upgrade_state":{"sequence_id":0,"progress":"","status":"","consistency_request":false,"dis_state":0,"err_code":0,"force_upgrade":false,"message":"","module":"","new_version_state":2,"new_ver_list":[]},"command":"push_status","msg":0,"sequence_id":"19"}}@darkdevil sagte in Bambulab 3d-Drucker adapter:
Hmm sehr merkwürdig, ich habe mir deine MQTT Nachricht in de adapter kopiert und erhalte selbe diese Fehler nicht :/
Habe aber auch noch eine kleine optimalisierung gemacht im code, ziehe mal bitte nochmal neu von git und beachte das Jetzt auch die version 1.5 installiert wird ich erhoffe mir das es damit erledigt ist :)
@dutchman ich habe den adapter vorhin einmal komplett gelöscht und von github die version 1.5. geladen.
der Fehler hat sich verändert :/
[messageHandler] TypeError: Cannot read properties of undefined (reading 'ams_exist_bits') | TypeError: Cannot read properties of undefined (reading 'ams_exist_bits') at Bambulab.messageHandler (/opt/iobroker/node_modules/iobroker.bambulab/main.js:199:57) at MqttClient.<anonymous> (/opt/iobroker/node_modules/iobroker.bambulab/main.js:107:11) at MqttClient.emit (node:events:513:28) at MqttClient._handlePublish (/opt/iobroker/node_modules/mqtt/lib/client.js:1547:12) at MqttClient._handlePacket (/opt/iobroker/node_modules/mqtt/lib/client.js:535:12) at work (/opt/iobroker/node_modules/mqtt/lib/client.js:438:12) at Writable.writable._write (/opt/iobroker/node_modules/mqtt/lib/client.js:452:5) at doWrite (/opt/iobroker/node_modules/mqtt/node_modules/readable-stream/lib/_stream_writable.js:409:139) at writeOrBuffer (/opt/iobroker/node_modules/mqtt/node_modules/readable-stream/lib/_stream_writable.js:398:5) at Writable.write (/opt/iobroker/node_modules/mqtt/node_modules/readable-stream/lib/_stream_writable.js:307:11) -
[messageHandler] TypeError: Cannot read properties of undefined (reading 'ams_exist_bits') | TypeError: Cannot read properties of undefined (reading 'ams_exist_bits') at Bambulab.messageHandler (/opt/iobroker/node_modules/iobroker.bambulab/main.js:199:57) at MqttClient.<anonymous> (/opt/iobroker/node_modules/iobroker.bambulab/main.js:107:11) at MqttClient.emit (node:events:513:28) at MqttClient._handlePublish (/opt/iobroker/node_modules/mqtt/lib/client.js:1547:12) at MqttClient._handlePacket (/opt/iobroker/node_modules/mqtt/lib/client.js:535:12) at work (/opt/iobroker/node_modules/mqtt/lib/client.js:438:12) at Writable.writable._write (/opt/iobroker/node_modules/mqtt/lib/client.js:452:5) at doWrite (/opt/iobroker/node_modules/mqtt/node_modules/readable-stream/lib/_stream_writable.js:409:139) at writeOrBuffer (/opt/iobroker/node_modules/mqtt/node_modules/readable-stream/lib/_stream_writable.js:398:5) at Writable.write (/opt/iobroker/node_modules/mqtt/node_modules/readable-stream/lib/_stream_writable.js:307:11)@darkdevil sagte in Bambulab 3d-Drucker adapter:
Bitte noch einmal neu von git ziehen habe da noch eine Stelle geändert
Edit: Per chat bestaetigt das es hiermit geloest ist :)
@dutchman Genial dass du hier an einem Adapter arbeitest. Ich behelfe mir aktuell noch mit einer Connection über Home Assistant die ich mir dann in IOB rüber ziehe.
Nebst den Funktionen die du schon auf der Liste hast, wären noch folgende Statusabfragen interessant, die man sich ggf. in die VIS einbauen könnte.-
Pinterstatus (Printing, idle, error usw.)
PrintProgress
remaining time
print time
Bed temperature
Nozzle Temperature
AMS infos (tray details)
Current layer
und und und :-) in HA sind echt viele Status Daten drin, die er sich aus dem Drucker per MQTT zieht, wäre super wenn man die auch in den IOB Adapter zur Verfügung hätte, dann könnte die Brücke über HA wieder raus ;-)
EDIT: Erinnerung an mich selbst, erst checken dann labern LOL sehe nun dass ja alles oben genannte bereits drin ist im Adapter!
GEILE ARBEIT!VG BJörn
PrintProgress
remaining time
print time
Bed temperature
Nozzle Temperature
Current layer
@bjoernf sagte in Bambulab 3d-Drucker adapter:
GEILE ARBEIT!danke fuer die blumen :) ja glaube von deiner liste habe ich alles drin ;)
@dutchman wobei print end time konnte ich jetzt noch nicht finden in den DPs
Hmm end Zeit nicht, remaining time wohl.
Da der Wert nicht vom Drucker kommt könnte man aber ne Berechnung einbauenWen gewünscht bitte kleine issue auf git mit der info erstellen dan arbeite ich die issues ab und Beier es bei einer nächsten Version ein
Aktuelle Test Version 0.3.0-beta.3 Veröffentlichungsdatum 28.07.2023 Github Link https://github.com/DrozmotiX/ioBroker.bambulab Nach Anregungen in und node-red workflow diesem Forum Topic dachte ich mir es wird zeit auch fuer den bambulab eine iOBroker Integration zu implementieren.
Supported devices :
- X1
- P1p (der P1s muss noch getestet werden)
Supported controls:
pause/resume/start/stop
control lights (chamber & head)
provide custom g-codees werden mehr folgen, wen ihr wünsche habt bitte in diesem thread melden oder am besten ein git-issue erstellen !
Momentan wirft der adapter beim starten noch einige "warn" Meldungen, diese können ignoriert werden und werde in v0.2.0 behoben sein
Viel spass beim drucken, Über feedback werde ich ich sehr freuen!
moment kann man den adapter leider nur ueber git installieren, aufnähme in die repo ist beantragt :)
Status der implementierung:
Supported models
Printer-Model Status P1p
P1s
needs testingX1
AMS
Supported commands
Command X1C X1 P1P P1S Custom g-code
needs testingPause
needs testingResume
needs testingStop
needs testingFan-Aux
needs testing
needs testingFan-Chamber
needs testing
needs testingFan-ToolHead
needs testing
needs testingLight-Chamber
needs testing
needs testingLight-Nozzle
needs testing
needs testingLight-Logo
needs testing
needs testingTemperature-Bed
needs testingTemperature-Nozzle
needs testingSpeed Level
needs testingTo-Do
Implement more commands, please provide feedback what we need
Optimize state attributes definitions
Test printer series P1S@dutchman ich habe seit eben einen P1S. Kann ich helfen beim Testen?
Seit Donnerstg steht nun ein x1C bei mir im Keller.
Hab den Adapter ohne Probleme installieren können.
Ich seh allerding glaube ich nicht alle Datenpunkte.z.B. sind bei mir nicht zu finden:
Pinterstatus (Printing, idle, error usw.), PrintProgress, remaining time, print time, Bed temperature, Nozzle Temperature, AMS infos (tray details), Current layer
Bei mir sieht es so aus:
Hab ich irgendwas vergessen?
Gruss Danyel
bei mir wirft der adapter ständig Fehler
[messageHandler] TypeError: Cannot read properties of undefined (reading 'ams') | TypeError: Cannot read properties of undefined (reading 'ams') at Bambulab.messageHandler (/opt/iobroker/node_modules/iobroker.bambulab/main.js:199:57) at MqttClient.<anonymous> (/opt/iobroker/node_modules/iobroker.bambulab/main.js:107:11) at MqttClient.emit (node:events:514:28) at MqttClient._handlePublish (/opt/iobroker/node_modules/mqtt/lib/client.js:1547:12) at MqttClient._handlePacket (/opt/iobroker/node_modules/mqtt/lib/client.js:535:12) at work (/opt/iobroker/node_modules/mqtt/lib/client.js:438:12) at writable._write (/opt/iobroker/node_modules/mqtt/lib/client.js:452:5) at doWrite (/opt/iobroker/node_modules/mqtt/node_modules/readable-stream/lib/_stream_writable.js:409:139) at writeOrBuffer (/opt/iobroker/node_modules/mqtt/node_modules/readable-stream/lib/_stream_writable.js:398:5) at Writable.write (/opt/iobroker/node_modules/mqtt/node_modules/readable-stream/lib/_stream_writable.js:307:11) -
Gruss Danyel
@webranger Sieht bei mir leider genauso aus. Hast du inzwischen raus gefunden woran es liegt?
Und wie ist das mit der Seriennummer? Muss man die nur beim P1P angeben? Ich finde die bei meinem X1CC in den Netzwerkeinstellungen nicht.
