  4. Bambulab 3d-Drucker adapter
    6.7k
331 Beiträge 54 Kommentatoren 129.1k Aufrufe 53 Beobachtet
  • D DarkDevil
    @dutchman
    auch nach dem letzten Update bekomme ich die Fehler. Die Print Message lautet immer noch:
    	Printer Message {"print":{"upload":{"status":"idle","progress":0,"message":""},"nozzle_temper":21.125,"nozzle_target_temper":0,"bed_temper":19.5,"bed_target_temper":0,"chamber_temper":5,"mc_print_stage":"1","heatbreak_fan_speed":"0","cooling_fan_speed":"0","big_fan1_speed":"0","big_fan2_speed":"0","mc_percent":0,"mc_remaining_time":0,"ams_status":0,"ams_rfid_status":6,"hw_switch_state":1,"spd_mag":100,"spd_lvl":2,"print_error":83935249,"lifecycle":"product","wifi_signal":"-52dBm","gcode_state":"IDLE","gcode_file_prepare_percent":"0","queue_number":0,"project_id":"0","profile_id":"0","task_id":"0","subtask_id":"0","subtask_name":"","gcode_file":"","stg":[],"stg_cur":0,"print_type":"idle","home_flag":16904,"mc_print_line_number":"0","mc_print_sub_stage":0,"sdcard":true,"force_upgrade":false,"mess_production_state":"active","layer_num":0,"total_layer_num":0,"hms":[],"online":{"ahb":false,"rfid":false,"version":87449353},"ams":{"ams":[],"ams_exist_bits":"0","tray_exist_bits":"0","tray_is_bbl_bits":"0","tray_tar":"255","tray_now":"254","tray_pre":"254","tray_read_done_bits":"0","tray_reading_bits":"0","version":1,"insert_flag":true,"power_on_flag":false},"ipcam":{"ipcam_dev":"1","ipcam_record":"enable","timelapse":"disable","mode_bits":3},"vt_tray":{"id":"254","tag_uid":"0000000000000000","tray_id_name":"","tray_info_idx":"","tray_type":"","tray_sub_brands":"","tray_color":"00000000","tray_weight":"0","tray_diameter":"0.00","tray_temp":"0","tray_time":"0","bed_temp_type":"0","bed_temp":"0","nozzle_temp_max":"0","nozzle_temp_min":"0","xcam_info":"000000000000000000000000","tray_uuid":"00000000000000000000000000000000","remain":0,"k":0.019999999552965164,"n":1.399999976158142},"lights_report":[{"node":"chamber_light","mode":"off"}],"upgrade_state":{"sequence_id":0,"progress":"","status":"","consistency_request":false,"dis_state":0,"err_code":0,"force_upgrade":false,"message":"","module":"","new_version_state":2,"new_ver_list":[]},"command":"push_status","msg":0,"sequence_id":"19"}}
    DutchmanD Offline
    DutchmanD Offline
    Dutchman
    @darkdevil sagte in Bambulab 3d-Drucker adapter:
    Hmm sehr merkwürdig, ich habe mir deine MQTT Nachricht in de adapter kopiert und erhalte selbe diese Fehler nicht :/
    Habe aber auch noch eine kleine optimalisierung gemacht im code, ziehe mal bitte nochmal neu von git und beachte das Jetzt auch die version 1.5 installiert wird ich erhoffe mir das es damit erledigt ist :)
    • DutchmanD Dutchman
      D Online
      D Online
      DarkDevil
      @dutchman ich habe den adapter vorhin einmal komplett gelöscht und von github die version 1.5. geladen.
      der Fehler hat sich verändert :/
      	[messageHandler] TypeError: Cannot read properties of undefined (reading 'ams_exist_bits') | TypeError: Cannot read properties of undefined (reading 'ams_exist_bits') at Bambulab.messageHandler (/opt/iobroker/node_modules/iobroker.bambulab/main.js:199:57) at MqttClient.<anonymous> (/opt/iobroker/node_modules/iobroker.bambulab/main.js:107:11) at MqttClient.emit (node:events:513:28) at MqttClient._handlePublish (/opt/iobroker/node_modules/mqtt/lib/client.js:1547:12) at MqttClient._handlePacket (/opt/iobroker/node_modules/mqtt/lib/client.js:535:12) at work (/opt/iobroker/node_modules/mqtt/lib/client.js:438:12) at Writable.writable._write (/opt/iobroker/node_modules/mqtt/lib/client.js:452:5) at doWrite (/opt/iobroker/node_modules/mqtt/node_modules/readable-stream/lib/_stream_writable.js:409:139) at writeOrBuffer (/opt/iobroker/node_modules/mqtt/node_modules/readable-stream/lib/_stream_writable.js:398:5) at Writable.write (/opt/iobroker/node_modules/mqtt/node_modules/readable-stream/lib/_stream_writable.js:307:11)
      • D DarkDevil
        DutchmanD Offline
        DutchmanD Offline
        Dutchman
        schrieb am zuletzt editiert von Dutchman
        Bitte noch einmal neu von git ziehen habe da noch eine Stelle geändert
        Edit: Per chat bestaetigt das es hiermit geloest ist :)
        BjoernFB 1 Antwort Letzte Antwort
          BjoernFB Offline
          BjoernFB Offline
          BjoernF
          schrieb am zuletzt editiert von BjoernF
          @dutchman Genial dass du hier an einem Adapter arbeitest. Ich behelfe mir aktuell noch mit einer Connection über Home Assistant die ich mir dann in IOB rüber ziehe.
          Nebst den Funktionen die du schon auf der Liste hast, wären noch folgende Statusabfragen interessant, die man sich ggf. in die VIS einbauen könnte.
          • Pinterstatus (Printing, idle, error usw.)
          • PrintProgress
          • remaining time
          • print time
          • Bed temperature
          • Nozzle Temperature
          • AMS infos (tray details)
          • Current layer
          • und und und :-) in HA sind echt viele Status Daten drin, die er sich aus dem Drucker per MQTT zieht, wäre super wenn man die auch in den IOB Adapter zur Verfügung hätte, dann könnte die Brücke über HA wieder raus ;-)
          EDIT: Erinnerung an mich selbst, erst checken dann labern LOL sehe nun dass ja alles oben genannte bereits drin ist im Adapter!
          GEILE ARBEIT!
          VG BJörn
          • BjoernFB BjoernF
            • PrintProgress
            • remaining time
            • print time
            • Bed temperature
            • Current layer
            GEILE ARBEIT!
            VG BJörn
            DutchmanD Offline
            DutchmanD Offline
            Dutchman
            @bjoernf sagte in Bambulab 3d-Drucker adapter:
            GEILE ARBEIT!
            danke fuer die blumen :) ja glaube von deiner liste habe ich alles drin ;)
              GEILE ARBEIT!
              BjoernFB Offline
              BjoernFB Offline
              BjoernF
              @dutchman wobei print end time konnte ich jetzt noch nicht finden in den DPs
              • BjoernFB BjoernF
                DutchmanD Offline
                DutchmanD Offline
                Dutchman
                Hmm end Zeit nicht, remaining time wohl.
                Da der Wert nicht vom Drucker kommt könnte man aber ne Berechnung einbauen
                Wen gewünscht bitte kleine issue auf git mit der info erstellen dan arbeite ich die issues ab und Beier es bei einer nächsten Version ein
                  Aktuelle Test Version 0.3.0-beta.3
                  Veröffentlichungsdatum 28.07.2023
                  Github Link https://github.com/DrozmotiX/ioBroker.bambulab
                  Nach Anregungen in und node-red workflow diesem Forum Topic dachte ich mir es wird zeit auch fuer den bambulab eine iOBroker Integration zu implementieren.
                  Supported devices :
                  • X1
                  • P1p (der P1s muss noch getestet werden)
                  Supported controls:
                  pause/resume/start/stop
                  control lights (chamber & head)
                  provide custom g-code
                  es werden mehr folgen, wen ihr wünsche habt bitte in diesem thread melden oder am besten ein git-issue erstellen !
                  Momentan wirft der adapter beim starten noch einige "warn" Meldungen, diese können ignoriert werden und werde in v0.2.0 behoben sein
                  Viel spass beim drucken, Über feedback werde ich ich sehr freuen!
                  moment kann man den adapter leider nur ueber git installieren, aufnähme in die repo ist beantragt :)
                  Status der implementierung:
                  Supported models
                  Printer-Model Status
                  P1p ✅
                  P1s ❓needs testing
                  X1 ✅
                  AMS ✅
                  Supported commands
                  Command X1C X1 P1P P1S
                  Custom g-code ✅ ✅ ✅ ❓ needs testing
                  Pause ✅ ✅ ✅ ❓ needs testing
                  Resume ✅ ✅ ✅ ❓ needs testing
                  Stop ✅ ✅ ✅ ❓ needs testing
                  Fan-Aux ✅ ✅ ❓ needs testing ❓ needs testing
                  Fan-Chamber ✅ ✅ ❓ needs testing ❓ needs testing
                  Fan-ToolHead ✅ ✅ ❓ needs testing ❓ needs testing
                  Light-Chamber ✅ ✅ ❓ needs testing ❓ needs testing
                  Light-Nozzle ✅ ✅ ❓ needs testing ❓ needs testing
                  Light-Logo ✅ ✅ ❓ needs testing ❓ needs testing
                  Temperature-Bed ✅ ✅ ✅ ❓ needs testing
                  Temperature-Nozzle ✅ ✅ ✅ ❓ needs testing
                  Speed Level ✅ ✅ ✅ ❓ needs testing
                  To-Do
                  Implement more commands, please provide feedback what we need ❗
                  Optimize state attributes definitions
                  Test printer series P1S
                  SoerenKaiser99
                  @dutchman ich habe seit eben einen P1S. Kann ich helfen beim Testen?
                  • WebrangerW Offline
                    WebrangerW Offline
                    Webranger
                    Seit Donnerstg steht nun ein x1C bei mir im Keller.
                    Hab den Adapter ohne Probleme installieren können.
                    Ich seh allerding glaube ich nicht alle Datenpunkte.
                    z.B. sind bei mir nicht zu finden:
                    Pinterstatus (Printing, idle, error usw.), PrintProgress, remaining time, print time, Bed temperature, Nozzle Temperature, AMS infos (tray details), Current layer
                    Bei mir sieht es so aus:
                    Hab ich irgendwas vergessen?
                    Gruss Danyel
                    Intel NUC Celeron, Xiaomi Gateway, Fritzbox 7590, XS1
                    A DutchmanD 2 Antworten Letzte Antwort
                      spoeh-man
                      bei mir wirft der adapter ständig Fehler
                      	[messageHandler] TypeError: Cannot read properties of undefined (reading 'ams') | TypeError: Cannot read properties of undefined (reading 'ams') at Bambulab.messageHandler (/opt/iobroker/node_modules/iobroker.bambulab/main.js:199:57) at MqttClient.<anonymous> (/opt/iobroker/node_modules/iobroker.bambulab/main.js:107:11) at MqttClient.emit (node:events:514:28) at MqttClient._handlePublish (/opt/iobroker/node_modules/mqtt/lib/client.js:1547:12) at MqttClient._handlePacket (/opt/iobroker/node_modules/mqtt/lib/client.js:535:12) at work (/opt/iobroker/node_modules/mqtt/lib/client.js:438:12) at writable._write (/opt/iobroker/node_modules/mqtt/lib/client.js:452:5) at doWrite (/opt/iobroker/node_modules/mqtt/node_modules/readable-stream/lib/_stream_writable.js:409:139) at writeOrBuffer (/opt/iobroker/node_modules/mqtt/node_modules/readable-stream/lib/_stream_writable.js:398:5) at Writable.write (/opt/iobroker/node_modules/mqtt/node_modules/readable-stream/lib/_stream_writable.js:307:11)
                      • WebrangerW Webranger
                        Gruss Danyel
                        Apropo
                        @webranger Sieht bei mir leider genauso aus. Hast du inzwischen raus gefunden woran es liegt?
                        Und wie ist das mit der Seriennummer? Muss man die nur beim P1P angeben? Ich finde die bei meinem X1CC in den Netzwerkeinstellungen nicht.
                        WebrangerW tugsiT 2 Antworten Letzte Antwort
                        • A Apropo
                          WebrangerW Offline
                          WebrangerW Offline
                          Webranger
                          @apropo nein der Fehler ist immer noch aber der Entwickler ist dran. Zu der Seriennummer, die musste ich bei mir auch erst suchen aber steht irgendwo kann dir aber auch wirklich gerade nicht sagen wo.
                          • A Apropo
                            tugsiT Offline
                            tugsiT Offline
                            tugsi
                            @apropo Seriennummer findest Du in der Handy-App unter Einstellungen - Firmware-Version
                            Die Fehlermeldungen hab ich auch.
                            Master ioBroker in Proxmox als LXC auf 1. Tiny-Lenovo, Proxmox-VM als Slave auf 2. Tinyi-Lenovo mit Zigbee und Monitor zur Visualisierung, Hauptautomatisierung über S7 auf Beckhoff CX, dazu noch Shelly, Homematic...
                            MatzebhvM 1 Antwort Letzte Antwort
                            • tugsiT tugsi
                              MatzebhvM Offline
                              MatzebhvM Offline
                              Matzebhv
                              Ich habe den Adapter erstmal wegen des Fehlers deaktiviert, sobald der Drucker läuft wird das Log komplett geflutet.
                              Matze
                              BTW, was ein geiler Drucker ( X1 )
                                djalexz
                                Sehr sehr GEIL
                                1000 Dank @Dutchman für den Adapter.
                                Richtig nice. Bin echt begeistert :-D
                                Ich werde in den nächsten Tagen mal alles durchtesten und entsprchend kommentieren.
                                Wenn wir es jetzt noch hinbekommen diese dämliche Kamera vom Bambu im ioBroker anzeigen zu lassen, sind keine Wünsche mehr offen und der Drucker ist vollumfänglich im Smarthome integriert.
                                PS. Die ganzen Anregungen im Bambulab GIT von wegen RTSPS, HomeAssistant und Co. funktionieren beim ioBroker nicht.
                                Wie dem auch sei. Nochmals vielen vielen Dank für die Arbeit und ich freue mich zu Testen.
                                LG Alex
                                • D djalexz
                                  Sehr sehr GEIL
                                  LG Alex
                                  BjoernFB Offline
                                  BjoernFB Offline
                                  BjoernF
                                  @djalexz
                                  Hey Alex, Versuch mal den rtsp adapter, funzt bei mir mit zwei X1C sehr gut. Nur nach nem powercycle muss die Instanz neu gestartet werden 😉
                                  • BjoernFB BjoernF
                                    @djalexz
                                    djalexz
                                    @bjoernf
                                    Vielen Dank, aber das habe ich auch schon durch, leider ohne Erfolg.
                                    Anscheinend liegt das daran, dass via RTSPS ein Zertifikat von dem Drucker akzeptiert werden muss, dass aber in dem RTSP Adapter nicht möglich ist.
                                    Habe die neuste Firmware des Druckers und der RTSP Adapter wird ja leider schon ewig nicht mehr weiterentwickelt.
                                    LG Alex
                                    • D djalexz
                                      @bjoernf
                                      LG Alex
                                      BjoernFB Offline
                                      BjoernFB Offline
                                      BjoernF
                                      @djalexz
                                      Hm merkwürdig denn meine zwei laufen auch auf der neusten Firmware und der rtsp Adapter liefert mir nen Bild in der VIS 🤔
                                      D WebrangerW 2 Antworten Letzte Antwort
                                      • BjoernFB BjoernF
                                        @djalexz
                                        djalexz
                                        @bjoernf
                                        Dann bin ich einfach nur zu blöd das einzurichten (was durchaus vorkommt :-) )
                                        Sollten aber verm. nicht in diesem Thread darüber diskutieren um nicht unnötig "off-topic" zu werden.
                                        Ich mach mal nen neuen dafür auf.
                                        LG Alex
                                        • BjoernFB BjoernF
                                          @djalexz
                                          WebrangerW Offline
                                          WebrangerW Offline
                                          Webranger
                                          @bjoernf wie ist den der rstp link von dem Bambu wenn ich mal fragen darf?
