  4. BLE Adapter lässt sich nicht installieren. gelöst(Nodev18)
52 Beiträge 7 Kommentatoren 5.5k Aufrufe 6 Beobachtet
  • L Offline
    LarryXXL
    schrieb am zuletzt editiert von LarryXXL
    Systemdata Proxmox VM
    Hardwaresystem: intel i5
    Arbeitsspeicher: 8GB
    Festplattenart: virtuell
    Betriebssystem: Ubuntu
    Node-Version: 20.4.0
    Nodejs-Version: 20.4.0
    NPM-Version: 9.7.2
    Installationsart: Skript
    Image genutzt: Nein
    • L Offline
      LarryXXL
      $ iobroker add ble --host iob-server
      NPM version: 9.7.2
      Installing iobroker.ble@0.13.4... (System call)
      npm ERR! code 7npm ERR! path /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noblenpm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! gyp ERR! UNCAUGHT EXCEPTION npm ERR! gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#<Object>'npm ERR! gyp ERR! stack at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)npm ERR! gyp ERR! stack at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9npm ERR! gyp ERR! stack at FSReqCallback.oncomplete (node:fs:189:23)npm ERR! gyp ERR! System Linux 5.15.0-76-genericnpm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noblenpm ERR! gyp ERR! node -v v20.4.0npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! Node-gyp failed to build your package.npm ERR! gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-07-16T16_55_15_625Z-debug-0.log
      host.iob-server Cannot install iobroker.ble@0.13.4: 7
      ERROR: Process exited with code 25
      alle anderen adapter laufen und sind grün.
      DJMarc75D Thomas BraunT 2 Antworten Letzte Antwort
      • L LarryXXL
        NPM version: 9.7.2
        DJMarc75D Offline
        DJMarc75D Offline
        DJMarc75
        @larryxxl sagte in BLE Adapter lässt sich nicht installieren.:
        NPM version: 9.7.2
        absolut schräg....
        bitte mal die Ausgabe (Langfassung) von
        iob diag
        zeigen
        Lehrling seit 1975 !!!
        • L LarryXXL
          NPM version: 9.7.2
          @larryxxl
          Mit nodejs@20 gibt es noch verschiedene Probleme.
          Setz die empfohlene v18 ein.
          L 1 Antwort Letzte Antwort
            @larryxxl
            LarryXXL
            Skript v.2023-04-16
            *** BASE SYSTEM ***
            Architecture    : x86_64
            Docker          : false
            Virtualization  : kvm
            Distributor ID: Ubuntu
            Description:    Ubuntu 22.04.2 LTS
            Release:        22.04
            Codename:       jammy
            PRETTY_NAME="Ubuntu 22.04.2 LTS"
            NAME="Ubuntu"
            VERSION_ID="22.04"
            VERSION="22.04.2 LTS (Jammy Jellyfish)"
            VERSION_CODENAME=jammy
            ID=ubuntu
            ID_LIKE=debian
            HOME_URL="https://www.ubuntu.com/"
            SUPPORT_URL="https://help.ubuntu.com/"
            BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
            PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
            UBUNTU_CODENAME=jammy
            Systemuptime and Load:
             19:06:54 up 14 min,  2 users,  load average: 0.89, 0.32, 0.19
            CPU threads: 8
            *** Time and Time Zones ***
                           Local time: Sun 2023-07-16 19:06:54 CEST
                       Universal time: Sun 2023-07-16 17:06:54 UTC
                             RTC time: Sun 2023-07-16 17:06:54
                          NTP service: active
                      RTC in local TZ: no
            *** User and Groups ***
            root
            /root
            root
            *** X-Server-Setup ***
            X-Server:       false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Mem:            7.9G        217M        6.9G        1.0M        818M        7.5G
            Swap:             0B          0B          0B
            Total:          7.9G        217M        6.9G
                     7937 M total memory
                      217 M used memory
                      380 M active memory
                      426 M inactive memory
                     6901 M free memory
                       55 M buffer memory
                      762 M swap cache
                        0 M total swap
                        0 M used swap
                        0 M free swap
            *** FILESYSTEM ***
            Filesystem                        Type   Size  Used Avail Use% Mounted on
            tmpfs                             tmpfs  794M  1.1M  793M   1% /run
            /dev/mapper/ubuntu--vg-ubuntu--lv ext4   9.8G  7.5G  1.8G  81% /
            tmpfs                             tmpfs  3.9G     0  3.9G   0% /dev/shm
            tmpfs                             tmpfs  5.0M     0  5.0M   0% /run/lock
            /dev/sda2                         ext4   1.7G  240M  1.4G  15% /boot
            tmpfs                             tmpfs  794M  4.0K  794M   1% /run/user/0
            [Sun Jul 16 18:52:11 2023] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
            [Sun Jul 16 18:52:12 2023] EXT4-fs (dm-0): re-mounted. Opts: (null). Quota mode: none.
            [Sun Jul 16 18:52:12 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
            TARGET              SOURCE                            FSTYPE   OPTIONS
            /                   /dev/mapper/ubuntu--vg-ubuntu--lv ext4     rw,relatime
            |-/snap/core20/1950 /dev/loop0                        squashfs ro,nodev,relatime,errors=continue
            |-/snap/core20/1974 /dev/loop1                        squashfs ro,nodev,relatime,errors=continue
            |-/snap/lxd/24061   /dev/loop2                        squashfs ro,nodev,relatime,errors=continue
            |-/snap/snapd/19361 /dev/loop3                        squashfs ro,nodev,relatime,errors=continue
            |-/snap/snapd/19457 /dev/loop4                        squashfs ro,nodev,relatime,errors=continue
            `-/boot             /dev/sda2                         ext4     rw,relatime
            /var:
            2.1G    /var/
            1.1G    /var/log
            992M    /var/log/journal/8716649619c849e1a3f7aa18f9c78966
            651M    /var/lib
            Archived and active journals take up 991.7M in the file system.
            /opt/iobroker/backups:
            4.0K    /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            185M    /opt/iobroker/iobroker-data/
            86M     /opt/iobroker/iobroker-data/files
            65M     /opt/iobroker/iobroker-data/backup-objects
            51M     /opt/iobroker/iobroker-data/files/javascript.admin
            33M     /opt/iobroker/iobroker-data/files/javascript.admin/static
            14M     /opt/iobroker/iobroker-data/objects.jsonl
            7.2M    /opt/iobroker/iobroker-data/files/ham.admin/static/js/main.8080bc0b.js.map
            6.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/910.e1389bdb.chunk.js.map
            6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
            5.3M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/472.d73f9bde.chunk.js.map
            *** NodeJS-Installation ***
            /usr/bin/nodejs         v20.4.0
            /usr/bin/node           v20.4.0
            /usr/bin/npm            9.7.2
            /usr/bin/npx            9.7.2
            nodejs:
              Installed: 20.4.0-deb-1nodesource1
              Candidate: 20.4.0-deb-1nodesource1
              Version table:
             *** 20.4.0-deb-1nodesource1 500
                    500 https://deb.nodesource.com/node_20.x jammy/main amd64 Packages
                 12.22.9~dfsg-1ubuntu3 500
                    500 http://de.archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
            No problems detected
            *** ioBroker-Installation ***
            ioBroker Status
            iobroker is not running on this host.
            Objects type: jsonl
            States  type: jsonl
            Core adapters versions
            js-controller:  5.0.8
            admin:          6.6.0
            javascript:     7.1.1
            Adapters from github:   4
            Adapter State
              system.adapter.accuweather.0            : accuweather           : iob-server                               -  enabled
              system.adapter.admin.0                  : admin                 : iob-server                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
              system.adapter.alexa2.0                 : alexa2                : iob-server                               -  enabled
              system.adapter.backitup.0               : backitup              : iob-server                               -  enabled
              system.adapter.discovery.0              : discovery             : iob-server                               -  enabled
              system.adapter.ham.0                    : ham                   : iob-server                               -  enabled
              system.adapter.history.0                : history               : iob-server                               -  enabled
              system.adapter.hue-extended.0           : hue-extended          : iob-server                               -  enabled
              system.adapter.javascript.0             : javascript            : iob-server                               -  enabled
              system.adapter.mihome.0                 : mihome                : iob-server                               -  enabled, port: 9898, bind: 0.0.0.0
              system.adapter.nina.0                   : nina                  : iob-server                               -  enabled
              system.adapter.radar2.0                 : radar2                : iob-server                               -  enabled
              system.adapter.tapo.0                   : tapo                  : iob-server                               -  enabled
              system.adapter.tuya.0                   : tuya                  : iob-server                               -  enabled
              system.adapter.yeelight-2.0             : yeelight-2            : iob-server                               -  enabled
              system.adapter.zigbee.0                 : zigbee                : iob-server                               -  enabled, port: /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
            + instance is alive
            ioBroker-Repositories
            Active repo(s): beta
            Installed ioBroker-Instances
            Used repository: beta
            Adapter    "accuweather"  : 1.2.4    , installed 1.2.4
            Adapter    "admin"        : 6.6.0    , installed 6.6.0
            Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
            Adapter    "backitup"     : 2.6.23   , installed 2.6.23
            Adapter    "discovery"    : 3.2.0    , installed 3.2.0
            Adapter    "ham"          : 5.3.1    , installed 5.3.1
            Adapter    "history"      : 2.2.4    , installed 2.2.4
            Adapter    "hue-extended" : 2.0.0    , installed 2.0.1
            Adapter    "javascript"   : 7.1.1    , installed 7.1.1
            Controller "js-controller": 5.0.8    , installed 5.0.8
            Adapter    "mihome"       : 1.4.0    , installed 1.4.0
            Adapter    "nina"         : 0.0.25   , installed 0.0.25
            Adapter    "radar2"       : 2.0.7    , installed 2.0.7
            Adapter    "tapo"         : 0.0.8    , installed 0.0.8
            Adapter    "tuya"         : 3.14.2   , installed 3.14.2
            Adapter    "yeelight-2"   : 1.2.1    , installed 1.2.1
            Adapter    "zigbee"       : 1.8.18   , installed 1.8.14 [Updatable]
            Objects and States
            Objects:        6156
            States:         5431
            Hit:1 http://de.archive.ubuntu.com/ubuntu jammy InRelease
            Hit:2 https://deb.nodesource.com/node_20.x jammy InRelease
            Hit:3 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease
            Get:4 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease [108 kB]
            Hit:5 http://de.archive.ubuntu.com/ubuntu jammy-security InRelease
            Fetched 108 kB in 1s (193 kB/s)
            Reading package lists...
            Pending Updates: 0
            *** Listening Ports ***
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          22849      748/sshd: /usr/sbin
            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          20024      1/init
            tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      101        22689      677/systemd-resolve
            tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          21133      694/cupsd
            tcp        0      0 0.0.0.0:47307           0.0.0.0:*               LISTEN      115        33007      3269/rpc.statd
            tcp6       0      0 :::22                   :::*                    LISTEN      0          22861      748/sshd: /usr/sbin
            tcp6       0      0 :::111                  :::*                    LISTEN      0          15771      1/init
            tcp6       0      0 ::1:631                 :::*                    LISTEN      0          21132      694/cupsd
            tcp6       0      0 :::52297                :::*                    LISTEN      115        33011      3269/rpc.statd
            udp        0      0 127.0.0.53:53           0.0.0.0:*                           101        22688      677/systemd-resolve
            udp        0      0 192.168.1.166:68        0.0.0.0:*                           100        16195      675/systemd-network
            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          20025      1/init
            udp        0      0 0.0.0.0:49712           0.0.0.0:*                           115        33005      3269/rpc.statd
            udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          23649      756/cups-browsed
            udp        0      0 127.0.0.1:901           0.0.0.0:*                           0          33001      3269/rpc.statd
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           116        22281      689/avahi-daemon: r
            udp        0      0 0.0.0.0:51718           0.0.0.0:*                           116        22283      689/avahi-daemon: r
            udp6       0      0 :::35688                :::*                                116        22284      689/avahi-daemon: r
            udp6       0      0 :::44404                :::*                                115        33009      3269/rpc.statd
            udp6       0      0 :::111                  :::*                                0          15772      1/init
            udp6       0      0 fe80::4401:1ff:fe01:546 :::*                                100        22714      675/systemd-network
            udp6       0      0 :::5353                 :::*                                116        22282      689/avahi-daemon: r
            2023-07-16 19:06:34.474  - info: accuweather.0 (3331) terminating
            2023-07-16 19:06:34.478  - info: mihome.0 (3019) terminating
            2023-07-16 19:06:34.479  - info: javascript.0 (3000) terminating
            2023-07-16 19:06:34.478  - info: alexa2.0 (3078) terminating
            2023-07-16 19:06:34.496  - info: tapo.0 (3380) terminating
            2023-07-16 19:06:34.496  - info: backitup.0 (3232) terminating
            2023-07-16 19:06:34.496  - info: admin.0 (2946) terminating
            2023-07-16 19:06:34.676  - info: host.iob-server instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
            2023-07-16 19:06:34.676  - info: host.iob-server instance system.adapter.yeelight-2.0 terminated with code 0 (NO_ERROR)
            2023-07-16 19:06:34.770  - info: host.iob-server instance system.adapter.discovery.0 terminated with code 0 (NO_ERROR)
            2023-07-16 19:06:34.770  - info: host.iob-server instance system.adapter.nina.0 terminated with code 0 (NO_ERROR)
            2023-07-16 19:06:34.789  - info: host.iob-server instance system.adapter.accuweather.0 terminated with code 0 (NO_ERROR)
            2023-07-16 19:06:34.809  - info: host.iob-server instance system.adapter.alexa2.0 terminated with code 0 (NO_ERROR)
            2023-07-16 19:06:34.852  - info: host.iob-server instance system.adapter.mihome.0 terminated with code 0 (NO_ERROR)
            2023-07-16 19:06:34.853  - info: host.iob-server instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
            2023-07-16 19:06:34.853  - info: host.iob-server instance system.adapter.hue-extended.0 terminated with code 0 (NO_ERROR)
            2023-07-16 19:06:34.881  - info: host.iob-server instance system.adapter.radar2.0 terminated with code 0 (NO_ERROR)
            2023-07-16 19:06:34.881  - info: host.iob-server instance system.adapter.tapo.0 terminated with code 0 (NO_ERROR)
            2023-07-16 19:06:34.903  - info: host.iob-server instance system.adapter.history.0 terminated with code 0 (NO_ERROR)
            2023-07-16 19:06:34.903  - info: host.iob-server instance system.adapter.javascript.0 terminated with code 0 (NO_ERROR)
            2023-07-16 19:06:34.956  - info: host.iob-server instance system.adapter.ham.0 terminated with code 0 (NO_ERROR)
            2023-07-16 19:06:35.041  - info: host.iob-server instance system.adapter.zigbee.0 terminated with code 0 (NO_ERROR)
            2023-07-16 19:06:37.502  - info: host.iob-server instance system.adapter.tuya.0 terminated with code 0 (NO_ERROR)
            2023-07-16 19:06:37.502  - info: host.iob-server All instances are stopped.
            2023-07-16 19:06:37.657  - info: host.iob-server terminated
            iob diag has finished.
            • L LarryXXL
              Skript v.2023-04-16
              *** BASE SYSTEM ***
              Docker          : false
              Release:        22.04
              Codename:       jammy
              NAME="Ubuntu"
              VERSION_ID="22.04"
              ID=ubuntu
              ID_LIKE=debian
              CPU threads: 8
                            NTP service: active
                        RTC in local TZ: no
              root
              /root
              root
              X-Server:       false
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Swap:             0B          0B          0B
                       7937 M total memory
                        217 M used memory
                        380 M active memory
                       6901 M free memory
                         55 M buffer memory
                        762 M swap cache
                          0 M total swap
                          0 M used swap
                          0 M free swap
              *** FILESYSTEM ***
              /var:
              2.1G    /var/
              1.1G    /var/log
              651M    /var/lib
              /usr/bin/npm            9.7.2
              /usr/bin/npx            9.7.2
              nodejs:
                Version table:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              admin:          6.6.0
              javascript:     7.1.1
              Adapter State
              + instance is alive
              Objects and States
              Objects:        6156
              States:         5431
              Pending Updates: 0
              @larryxxl
              Nicht als root herumhampeln, SWAP aktivieren, nodejs@18 verwenden.
              Dein / ist so gut wie voll, das fällt dir als nächstes auf die Füße.
                @larryxxl
                StefanH 0
                schrieb am zuletzt editiert von StefanH 0
                Hallo in die Runde, vielleicht kann mir jemand helfen.
                Habe auf dem Raspi 4 erfolgreich Bluetooth aktiviert und im iobroker ebenfalls den BLE-Adapter erfolgreich zum Laufen gebracht. Leider wird mein XIAOMI Helligkeitssensor nicht vom Adapter erkannt.
                Habe im Adapter das xiaomi - Plugin aktiviert.
                Beim Starten des Adapter erscheint folgendes im Log:
                ble.0
                2023-08-09 07:32:40.655	info	starting scan for services ["fe95"]
                ble.0
                2023-08-09 07:32:40.083	info	starting scanner process...
                ble.0
                2023-08-09 07:32:40.053	info	monitored services: fe95
                ble.0
                2023-08-09 07:32:40.052	info	enabled plugins: Xiaomi, _default
                ble.0
                2023-08-09 07:32:40.050	info	loaded plugins: Xiaomi, mi-flora, ruuvi-tag, _default
                ble.0
                2023-08-09 07:32:39.979	info	starting. Version 0.13.4 in /opt/iobroker/node_modules/iobroker.ble, node: v18.16.1, js-controller: 4.0.24
                host.Raspberry-PI4
                2023-08-09 07:32:37.294	info	instance system.adapter.ble.0 started with pid 3879
                Hier noch die Daten im Objektknoten des BLE-Adapters:
                Habe auch schon das Objekt: allowNewDevices auf true gesetzt und dann den Pairing-Modus auf dem Helligkeitssensor aktiviert. Hat bisher leider alles nichts gebracht.
                Ich gehen davon aus, dass ich für die Anbindung des Sensors an IOBroker keinen Zigbee-Hub benötige.
                Gruss Stefan
                • S StefanH 0
                  ble.0
                  ble.0
                  ble.0
                  ble.0
                  ble.0
                  ble.0
                  host.Raspberry-PI4
                  Gruss Stefan
                  StefanH 0
                  @stefanh-0
                  bin jetzt etwas weiter gekommen.
                  Nachdem ich den Haken mal bei:
                  gesetzt habe, hat er schon mal Devices gefunden, das ist sehr schön und sagt mir, dass mein Bluetooth auf dem Rasp und der BLE-Adapter in IOBroker funktionieren.
                  Es können jedoch von den Devices keine Daten ausgelesen werden.
                  Das kann aber normal sein, da der XIAOMI Lichtsensor möglicher vom Plugin noch garnicht unterstützt wird und die restlichen gefundenen Bluetooth-Devices ohne geeignete Plugins sowieso nicht ausgelesen werden können.
                  • S StefanH 0
                    @stefanh-0
                    crunchipC Offline
                    crunchipC Offline
                    @stefanh-0 sagte in BLE Adapter lässt sich nicht installieren. gelöst(Nodev18):
                    XIAOMI Lichtsensor
                    bluetooth? wohl eher zigbee
                      XIAOMI Lichtsensor
                      StefanH 0
                      @crunchip
                      Ist mir schon klar dass zigbee als Protokoll verwendet wird, aber das sollten die Plugins ja hoffentlich können.
                      • S StefanH 0
                        @crunchip
                        crunchipC Offline
                        crunchipC Offline
                        @stefanh-0 scheinbar ist dir nicht ganz klar was der ble Adapter macht, das hat nichts mit zigbee zu tun, nur weil xiaomi als plugin drin steht.
                        es gibt Geräte von xiaomi die mit bluetooth funken, wie z.b der Xiaomi Temperature and humidity sensor
                          StefanH 0
                          @crunchip
                          Ok , danke für die Info und Klarstellung. Dachte bisher, dass zigbee auf Bluetooth aufsetzt. War mir nicht klar, dass zigbee ein eigenständiger Funkstandard ist.
                          • S StefanH 0
                            @crunchip
                            crunchipC Offline
                            crunchipC Offline
                            @stefanh-0 auf die schnelle https://www.libe.net/smart-home-funk
                            Walter.O.W 1 Antwort Letzte Antwort
                              Walter.O.W Online
                              Walter.O.W Online
                              Walter.O.
                              Hänge mich hier noch mal an.
                              Ich kann BLE _0.13.4 nicht Instalieren.
                              Plattform: linux
                              Betriebssystem: linux
                              Architektur: x64
                              Geschwindigkeit: 1496 MHz
                              Modell: Intel(R) Celeron(R) CPU 1007U @ 1.50GHz
                              RAM: 7.5 GB
                              Node.js: v18.19.0
                              NPM: 10.2.3
                              Freier Festplattenspeicher: 453.0 GB
                              $ iobroker add ble --host Mini-pc-Master
                              npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/@abandonware/noblenpm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! (node:17520) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)npm ERR! Traceback (most recent call last):npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>npm ERR! sys.exit(gyp.script_main())npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR! return main(sys.argv[1:])npm ERR! ^^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR! return gyp_main(args)npm ERR! ^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_mainnpm ERR! [generator, flat_list, targets, data] = Load(npm ERR! ^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Loadnpm ERR! result = gyp.input.Load(npm ERR! ^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR! LoadTargetBuildFile(npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR! build_file_data = LoadOneBuildFile(npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR! build_file_contents = open(build_file_path, "rU").read()npm ERR! ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:517:28)npm ERR! gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:292:12)npm ERR! gyp ERR! System Linux 6.1.0-17-amd64npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/@abandonware/noblenpm ERR! gyp ERR! node -v v18.19.0npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-23T18_42_08_732Z-debug-0.loghost.Mini-pc-Master Cannot install iobroker.ble@0.13.4: 1
                              Kann jemand weiterhelfen?
                              • Walter.O.W Walter.O.
                                Plattform: linux
                                Architektur: x64
                                RAM: 7.5 GB
                                Node.js: v18.19.0
                                NPM: 10.2.3
                                @walter-o sagte in BLE Adapter lässt sich nicht installieren. gelöst(Nodev18):
                                Wie bist du da ansonsten so unterwegs?
                                iob diag
                                anschauen.
                                  Plattform: linux
                                  Architektur: x64
                                  RAM: 7.5 GB
                                  Node.js: v18.19.0
                                  NPM: 10.2.3
                                  hast du die notwendigen Zusatzpakete installiert?
                                    iob diag
                                    anschauen.
                                    Walter.O.W Online
                                    Walter.O.W Online
                                    Walter.O.
                                    @thomas-braun sagte in BLE Adapter lässt sich nicht installieren. gelöst(Nodev18):
                                    iob diag
                                    Wie kann ich das denn alles kopieren?
                                    Bekomme nicht mal die hälfte kopiert...
                                      Walter.O.W Online
                                      Walter.O.W Online
                                      Walter.O.
                                      @homoran welche währen das?
                                        iob diag
                                        Markieren, kopieren, hier rein hauen.
                                          steht in der Adapterbeschreibung, hab ich nicht im Kopf
