  4. BLE Adapter lässt sich nicht installieren. gelöst(Nodev18)
52 Beiträge 7 Kommentatoren 5.5k Aufrufe 6 Beobachtet
  • L LarryXXL
    $ iobroker add ble --host iob-server
    NPM version: 9.7.2
    Installing iobroker.ble@0.13.4... (System call)
    npm ERR! code 7npm ERR! path /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noblenpm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! gyp ERR! UNCAUGHT EXCEPTION npm ERR! gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#<Object>'npm ERR! gyp ERR! stack at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)npm ERR! gyp ERR! stack at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9npm ERR! gyp ERR! stack at FSReqCallback.oncomplete (node:fs:189:23)npm ERR! gyp ERR! System Linux 5.15.0-76-genericnpm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noblenpm ERR! gyp ERR! node -v v20.4.0npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! Node-gyp failed to build your package.npm ERR! gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-07-16T16_55_15_625Z-debug-0.log
    host.iob-server Cannot install iobroker.ble@0.13.4: 7
    ERROR: Process exited with code 25
    alle anderen adapter laufen und sind grün.
    DJMarc75D Offline
    DJMarc75D Offline
    DJMarc75
    @larryxxl sagte in BLE Adapter lässt sich nicht installieren.:
    NPM version: 9.7.2
    absolut schräg....
    bitte mal die Ausgabe (Langfassung) von
    iob diag
    zeigen
    Lehrling seit 1975 !!!
    • L LarryXXL
      NPM version: 9.7.2
      @larryxxl
      Mit nodejs@20 gibt es noch verschiedene Probleme.
      Setz die empfohlene v18 ein.
      L 1 Antwort Letzte Antwort
        @larryxxl
        LarryXXL
        Skript v.2023-04-16
        *** BASE SYSTEM ***
        Architecture    : x86_64
        Docker          : false
        Virtualization  : kvm
        Distributor ID: Ubuntu
        Description:    Ubuntu 22.04.2 LTS
        Release:        22.04
        Codename:       jammy
        PRETTY_NAME="Ubuntu 22.04.2 LTS"
        NAME="Ubuntu"
        VERSION_ID="22.04"
        VERSION="22.04.2 LTS (Jammy Jellyfish)"
        VERSION_CODENAME=jammy
        ID=ubuntu
        ID_LIKE=debian
        HOME_URL="https://www.ubuntu.com/"
        SUPPORT_URL="https://help.ubuntu.com/"
        BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
        PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
        UBUNTU_CODENAME=jammy
        Systemuptime and Load:
         19:06:54 up 14 min,  2 users,  load average: 0.89, 0.32, 0.19
        CPU threads: 8
        *** Time and Time Zones ***
                       Local time: Sun 2023-07-16 19:06:54 CEST
                   Universal time: Sun 2023-07-16 17:06:54 UTC
                         RTC time: Sun 2023-07-16 17:06:54
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        root
        /root
        root
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:            7.9G        217M        6.9G        1.0M        818M        7.5G
        Swap:             0B          0B          0B
        Total:          7.9G        217M        6.9G
                 7937 M total memory
                  217 M used memory
                  380 M active memory
                  426 M inactive memory
                 6901 M free memory
                   55 M buffer memory
                  762 M swap cache
                    0 M total swap
                    0 M used swap
                    0 M free swap
        *** FILESYSTEM ***
        Filesystem                        Type   Size  Used Avail Use% Mounted on
        tmpfs                             tmpfs  794M  1.1M  793M   1% /run
        /dev/mapper/ubuntu--vg-ubuntu--lv ext4   9.8G  7.5G  1.8G  81% /
        tmpfs                             tmpfs  3.9G     0  3.9G   0% /dev/shm
        tmpfs                             tmpfs  5.0M     0  5.0M   0% /run/lock
        /dev/sda2                         ext4   1.7G  240M  1.4G  15% /boot
        tmpfs                             tmpfs  794M  4.0K  794M   1% /run/user/0
        [Sun Jul 16 18:52:11 2023] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
        [Sun Jul 16 18:52:12 2023] EXT4-fs (dm-0): re-mounted. Opts: (null). Quota mode: none.
        [Sun Jul 16 18:52:12 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
        TARGET              SOURCE                            FSTYPE   OPTIONS
        /                   /dev/mapper/ubuntu--vg-ubuntu--lv ext4     rw,relatime
        |-/snap/core20/1950 /dev/loop0                        squashfs ro,nodev,relatime,errors=continue
        |-/snap/core20/1974 /dev/loop1                        squashfs ro,nodev,relatime,errors=continue
        |-/snap/lxd/24061   /dev/loop2                        squashfs ro,nodev,relatime,errors=continue
        |-/snap/snapd/19361 /dev/loop3                        squashfs ro,nodev,relatime,errors=continue
        |-/snap/snapd/19457 /dev/loop4                        squashfs ro,nodev,relatime,errors=continue
        `-/boot             /dev/sda2                         ext4     rw,relatime
        /var:
        2.1G    /var/
        1.1G    /var/log
        992M    /var/log/journal/8716649619c849e1a3f7aa18f9c78966
        651M    /var/lib
        Archived and active journals take up 991.7M in the file system.
        /opt/iobroker/backups:
        4.0K    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        185M    /opt/iobroker/iobroker-data/
        86M     /opt/iobroker/iobroker-data/files
        65M     /opt/iobroker/iobroker-data/backup-objects
        51M     /opt/iobroker/iobroker-data/files/javascript.admin
        33M     /opt/iobroker/iobroker-data/files/javascript.admin/static
        14M     /opt/iobroker/iobroker-data/objects.jsonl
        7.2M    /opt/iobroker/iobroker-data/files/ham.admin/static/js/main.8080bc0b.js.map
        6.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/910.e1389bdb.chunk.js.map
        6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
        5.3M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/472.d73f9bde.chunk.js.map
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v20.4.0
        /usr/bin/node           v20.4.0
        /usr/bin/npm            9.7.2
        /usr/bin/npx            9.7.2
        nodejs:
          Installed: 20.4.0-deb-1nodesource1
          Candidate: 20.4.0-deb-1nodesource1
          Version table:
         *** 20.4.0-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_20.x jammy/main amd64 Packages
             12.22.9~dfsg-1ubuntu3 500
                500 http://de.archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
        No problems detected
        *** ioBroker-Installation ***
        ioBroker Status
        iobroker is not running on this host.
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  5.0.8
        admin:          6.6.0
        javascript:     7.1.1
        Adapters from github:   4
        Adapter State
          system.adapter.accuweather.0            : accuweather           : iob-server                               -  enabled
          system.adapter.admin.0                  : admin                 : iob-server                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          system.adapter.alexa2.0                 : alexa2                : iob-server                               -  enabled
          system.adapter.backitup.0               : backitup              : iob-server                               -  enabled
          system.adapter.discovery.0              : discovery             : iob-server                               -  enabled
          system.adapter.ham.0                    : ham                   : iob-server                               -  enabled
          system.adapter.history.0                : history               : iob-server                               -  enabled
          system.adapter.hue-extended.0           : hue-extended          : iob-server                               -  enabled
          system.adapter.javascript.0             : javascript            : iob-server                               -  enabled
          system.adapter.mihome.0                 : mihome                : iob-server                               -  enabled, port: 9898, bind: 0.0.0.0
          system.adapter.nina.0                   : nina                  : iob-server                               -  enabled
          system.adapter.radar2.0                 : radar2                : iob-server                               -  enabled
          system.adapter.tapo.0                   : tapo                  : iob-server                               -  enabled
          system.adapter.tuya.0                   : tuya                  : iob-server                               -  enabled
          system.adapter.yeelight-2.0             : yeelight-2            : iob-server                               -  enabled
          system.adapter.zigbee.0                 : zigbee                : iob-server                               -  enabled, port: /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
        + instance is alive
        ioBroker-Repositories
        Active repo(s): beta
        Installed ioBroker-Instances
        Used repository: beta
        Adapter    "accuweather"  : 1.2.4    , installed 1.2.4
        Adapter    "admin"        : 6.6.0    , installed 6.6.0
        Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
        Adapter    "backitup"     : 2.6.23   , installed 2.6.23
        Adapter    "discovery"    : 3.2.0    , installed 3.2.0
        Adapter    "ham"          : 5.3.1    , installed 5.3.1
        Adapter    "history"      : 2.2.4    , installed 2.2.4
        Adapter    "hue-extended" : 2.0.0    , installed 2.0.1
        Adapter    "javascript"   : 7.1.1    , installed 7.1.1
        Controller "js-controller": 5.0.8    , installed 5.0.8
        Adapter    "mihome"       : 1.4.0    , installed 1.4.0
        Adapter    "nina"         : 0.0.25   , installed 0.0.25
        Adapter    "radar2"       : 2.0.7    , installed 2.0.7
        Adapter    "tapo"         : 0.0.8    , installed 0.0.8
        Adapter    "tuya"         : 3.14.2   , installed 3.14.2
        Adapter    "yeelight-2"   : 1.2.1    , installed 1.2.1
        Adapter    "zigbee"       : 1.8.18   , installed 1.8.14 [Updatable]
        Objects and States
        Objects:        6156
        States:         5431
        Hit:1 http://de.archive.ubuntu.com/ubuntu jammy InRelease
        Hit:2 https://deb.nodesource.com/node_20.x jammy InRelease
        Hit:3 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease
        Get:4 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease [108 kB]
        Hit:5 http://de.archive.ubuntu.com/ubuntu jammy-security InRelease
        Fetched 108 kB in 1s (193 kB/s)
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          22849      748/sshd: /usr/sbin
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          20024      1/init
        tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      101        22689      677/systemd-resolve
        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          21133      694/cupsd
        tcp        0      0 0.0.0.0:47307           0.0.0.0:*               LISTEN      115        33007      3269/rpc.statd
        tcp6       0      0 :::22                   :::*                    LISTEN      0          22861      748/sshd: /usr/sbin
        tcp6       0      0 :::111                  :::*                    LISTEN      0          15771      1/init
        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          21132      694/cupsd
        tcp6       0      0 :::52297                :::*                    LISTEN      115        33011      3269/rpc.statd
        udp        0      0 127.0.0.53:53           0.0.0.0:*                           101        22688      677/systemd-resolve
        udp        0      0 192.168.1.166:68        0.0.0.0:*                           100        16195      675/systemd-network
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          20025      1/init
        udp        0      0 0.0.0.0:49712           0.0.0.0:*                           115        33005      3269/rpc.statd
        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          23649      756/cups-browsed
        udp        0      0 127.0.0.1:901           0.0.0.0:*                           0          33001      3269/rpc.statd
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           116        22281      689/avahi-daemon: r
        udp        0      0 0.0.0.0:51718           0.0.0.0:*                           116        22283      689/avahi-daemon: r
        udp6       0      0 :::35688                :::*                                116        22284      689/avahi-daemon: r
        udp6       0      0 :::44404                :::*                                115        33009      3269/rpc.statd
        udp6       0      0 :::111                  :::*                                0          15772      1/init
        udp6       0      0 fe80::4401:1ff:fe01:546 :::*                                100        22714      675/systemd-network
        udp6       0      0 :::5353                 :::*                                116        22282      689/avahi-daemon: r
        2023-07-16 19:06:34.474  - info: accuweather.0 (3331) terminating
        2023-07-16 19:06:34.478  - info: mihome.0 (3019) terminating
        2023-07-16 19:06:34.479  - info: javascript.0 (3000) terminating
        2023-07-16 19:06:34.478  - info: alexa2.0 (3078) terminating
        2023-07-16 19:06:34.496  - info: tapo.0 (3380) terminating
        2023-07-16 19:06:34.496  - info: backitup.0 (3232) terminating
        2023-07-16 19:06:34.496  - info: admin.0 (2946) terminating
        2023-07-16 19:06:34.676  - info: host.iob-server instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
        2023-07-16 19:06:34.676  - info: host.iob-server instance system.adapter.yeelight-2.0 terminated with code 0 (NO_ERROR)
        2023-07-16 19:06:34.770  - info: host.iob-server instance system.adapter.discovery.0 terminated with code 0 (NO_ERROR)
        2023-07-16 19:06:34.770  - info: host.iob-server instance system.adapter.nina.0 terminated with code 0 (NO_ERROR)
        2023-07-16 19:06:34.789  - info: host.iob-server instance system.adapter.accuweather.0 terminated with code 0 (NO_ERROR)
        2023-07-16 19:06:34.809  - info: host.iob-server instance system.adapter.alexa2.0 terminated with code 0 (NO_ERROR)
        2023-07-16 19:06:34.852  - info: host.iob-server instance system.adapter.mihome.0 terminated with code 0 (NO_ERROR)
        2023-07-16 19:06:34.853  - info: host.iob-server instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
        2023-07-16 19:06:34.853  - info: host.iob-server instance system.adapter.hue-extended.0 terminated with code 0 (NO_ERROR)
        2023-07-16 19:06:34.881  - info: host.iob-server instance system.adapter.radar2.0 terminated with code 0 (NO_ERROR)
        2023-07-16 19:06:34.881  - info: host.iob-server instance system.adapter.tapo.0 terminated with code 0 (NO_ERROR)
        2023-07-16 19:06:34.903  - info: host.iob-server instance system.adapter.history.0 terminated with code 0 (NO_ERROR)
        2023-07-16 19:06:34.903  - info: host.iob-server instance system.adapter.javascript.0 terminated with code 0 (NO_ERROR)
        2023-07-16 19:06:34.956  - info: host.iob-server instance system.adapter.ham.0 terminated with code 0 (NO_ERROR)
        2023-07-16 19:06:35.041  - info: host.iob-server instance system.adapter.zigbee.0 terminated with code 0 (NO_ERROR)
        2023-07-16 19:06:37.502  - info: host.iob-server instance system.adapter.tuya.0 terminated with code 0 (NO_ERROR)
        2023-07-16 19:06:37.502  - info: host.iob-server All instances are stopped.
        2023-07-16 19:06:37.657  - info: host.iob-server terminated
        iob diag has finished.
        • L LarryXXL
          Skript v.2023-04-16
          *** BASE SYSTEM ***
          Docker          : false
          Release:        22.04
          Codename:       jammy
          NAME="Ubuntu"
          VERSION_ID="22.04"
          ID=ubuntu
          ID_LIKE=debian
          CPU threads: 8
                        NTP service: active
                    RTC in local TZ: no
          root
          /root
          root
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Swap:             0B          0B          0B
                   7937 M total memory
                    217 M used memory
                    380 M active memory
                   6901 M free memory
                     55 M buffer memory
                    762 M swap cache
                      0 M total swap
                      0 M used swap
                      0 M free swap
          *** FILESYSTEM ***
          /var:
          2.1G    /var/
          1.1G    /var/log
          651M    /var/lib
          /usr/bin/npm            9.7.2
          /usr/bin/npx            9.7.2
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          6.6.0
          javascript:     7.1.1
          Adapter State
          + instance is alive
          Objects and States
          Objects:        6156
          States:         5431
          Pending Updates: 0
          @larryxxl
          Nicht als root herumhampeln, SWAP aktivieren, nodejs@18 verwenden.
          Dein / ist so gut wie voll, das fällt dir als nächstes auf die Füße.
            @larryxxl
            StefanH 0
            schrieb am zuletzt editiert von StefanH 0
            Hallo in die Runde, vielleicht kann mir jemand helfen.
            Habe auf dem Raspi 4 erfolgreich Bluetooth aktiviert und im iobroker ebenfalls den BLE-Adapter erfolgreich zum Laufen gebracht. Leider wird mein XIAOMI Helligkeitssensor nicht vom Adapter erkannt.
            Habe im Adapter das xiaomi - Plugin aktiviert.
            Beim Starten des Adapter erscheint folgendes im Log:
            ble.0
            2023-08-09 07:32:40.655	info	starting scan for services ["fe95"]
            ble.0
            2023-08-09 07:32:40.083	info	starting scanner process...
            ble.0
            2023-08-09 07:32:40.053	info	monitored services: fe95
            ble.0
            2023-08-09 07:32:40.052	info	enabled plugins: Xiaomi, _default
            ble.0
            2023-08-09 07:32:40.050	info	loaded plugins: Xiaomi, mi-flora, ruuvi-tag, _default
            ble.0
            2023-08-09 07:32:39.979	info	starting. Version 0.13.4 in /opt/iobroker/node_modules/iobroker.ble, node: v18.16.1, js-controller: 4.0.24
            host.Raspberry-PI4
            2023-08-09 07:32:37.294	info	instance system.adapter.ble.0 started with pid 3879
            Hier noch die Daten im Objektknoten des BLE-Adapters:
            Habe auch schon das Objekt: allowNewDevices auf true gesetzt und dann den Pairing-Modus auf dem Helligkeitssensor aktiviert. Hat bisher leider alles nichts gebracht.
            Ich gehen davon aus, dass ich für die Anbindung des Sensors an IOBroker keinen Zigbee-Hub benötige.
            Gruss Stefan
            • S StefanH 0
              ble.0
              ble.0
              ble.0
              ble.0
              ble.0
              ble.0
              host.Raspberry-PI4
              Gruss Stefan
              StefanH 0
              @stefanh-0
              bin jetzt etwas weiter gekommen.
              Nachdem ich den Haken mal bei:
              gesetzt habe, hat er schon mal Devices gefunden, das ist sehr schön und sagt mir, dass mein Bluetooth auf dem Rasp und der BLE-Adapter in IOBroker funktionieren.
              Es können jedoch von den Devices keine Daten ausgelesen werden.
              Das kann aber normal sein, da der XIAOMI Lichtsensor möglicher vom Plugin noch garnicht unterstützt wird und die restlichen gefundenen Bluetooth-Devices ohne geeignete Plugins sowieso nicht ausgelesen werden können.
              • S StefanH 0
                @stefanh-0
                crunchipC Offline
                crunchipC Offline
                @stefanh-0 sagte in BLE Adapter lässt sich nicht installieren. gelöst(Nodev18):
                XIAOMI Lichtsensor
                bluetooth? wohl eher zigbee
                  XIAOMI Lichtsensor
                  StefanH 0
                  @crunchip
                  Ist mir schon klar dass zigbee als Protokoll verwendet wird, aber das sollten die Plugins ja hoffentlich können.
                  • S StefanH 0
                    @crunchip
                    crunchipC Offline
                    crunchipC Offline
                    @stefanh-0 scheinbar ist dir nicht ganz klar was der ble Adapter macht, das hat nichts mit zigbee zu tun, nur weil xiaomi als plugin drin steht.
                    es gibt Geräte von xiaomi die mit bluetooth funken, wie z.b der Xiaomi Temperature and humidity sensor
                      StefanH 0
                      @crunchip
                      Ok , danke für die Info und Klarstellung. Dachte bisher, dass zigbee auf Bluetooth aufsetzt. War mir nicht klar, dass zigbee ein eigenständiger Funkstandard ist.
                      • S StefanH 0
                        @crunchip
                        crunchipC Offline
                        crunchipC Offline
                        @stefanh-0 auf die schnelle https://www.libe.net/smart-home-funk
                        Walter.O.W 1 Antwort Letzte Antwort
                          Walter.O.W Online
                          Walter.O.W Online
                          Walter.O.
                          Hänge mich hier noch mal an.
                          Ich kann BLE _0.13.4 nicht Instalieren.
                          Plattform: linux
                          Betriebssystem: linux
                          Architektur: x64
                          Geschwindigkeit: 1496 MHz
                          Modell: Intel(R) Celeron(R) CPU 1007U @ 1.50GHz
                          RAM: 7.5 GB
                          Node.js: v18.19.0
                          NPM: 10.2.3
                          Freier Festplattenspeicher: 453.0 GB
                          $ iobroker add ble --host Mini-pc-Master
                          npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/@abandonware/noblenpm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! (node:17520) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)npm ERR! Traceback (most recent call last):npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>npm ERR! sys.exit(gyp.script_main())npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR! return main(sys.argv[1:])npm ERR! ^^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR! return gyp_main(args)npm ERR! ^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_mainnpm ERR! [generator, flat_list, targets, data] = Load(npm ERR! ^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Loadnpm ERR! result = gyp.input.Load(npm ERR! ^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR! LoadTargetBuildFile(npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR! build_file_data = LoadOneBuildFile(npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR! build_file_contents = open(build_file_path, "rU").read()npm ERR! ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:517:28)npm ERR! gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:292:12)npm ERR! gyp ERR! System Linux 6.1.0-17-amd64npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/@abandonware/noblenpm ERR! gyp ERR! node -v v18.19.0npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-23T18_42_08_732Z-debug-0.loghost.Mini-pc-Master Cannot install iobroker.ble@0.13.4: 1
                          Kann jemand weiterhelfen?
                          • Walter.O.W Walter.O.
                            Plattform: linux
                            Architektur: x64
                            RAM: 7.5 GB
                            Node.js: v18.19.0
                            NPM: 10.2.3
                            @walter-o sagte in BLE Adapter lässt sich nicht installieren. gelöst(Nodev18):
                            Wie bist du da ansonsten so unterwegs?
                            iob diag
                            anschauen.
                              Plattform: linux
                              Architektur: x64
                              RAM: 7.5 GB
                              Node.js: v18.19.0
                              NPM: 10.2.3
                              hast du die notwendigen Zusatzpakete installiert?
                                iob diag
                                anschauen.
                                Walter.O.W Online
                                Walter.O.W Online
                                Walter.O.
                                @thomas-braun sagte in BLE Adapter lässt sich nicht installieren. gelöst(Nodev18):
                                iob diag
                                Wie kann ich das denn alles kopieren?
                                Bekomme nicht mal die hälfte kopiert...
                                  Walter.O.W Online
                                  Walter.O.W Online
                                  Walter.O.
                                  @homoran welche währen das?
                                    iob diag
                                    Markieren, kopieren, hier rein hauen.
                                      steht in der Adapterbeschreibung, hab ich nicht im Kopf
                                        Walter.O.W Online
                                        Walter.O.W Online
                                        Walter.O.
                                        @thomas-braun ```
                                        Copy text starting here:
        v.2023-10-10
                                         Static hostname: Mini-PC
                                               Icon name: computer-laptop
                                                 Chassis: laptop 💻
                                                  Kernel: Linux 6.1.0-17-amd64
                                            Architecture: x86-64
                                         Hardware Vendor: Wortmann_AG
                                          Hardware Model: TERRA_PC
                                        Firmware Version: 1.02
                                        Kernel:                 x86_64
                                        Userland:               amd64
                                        Timezone:               Europe/Berlin (CET, +0100)
                                        User-ID:                1000
                                        X-Server:               false
                                        Pending OS-Updates:     0
                                        Pending iob updates:    0
                                        Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
        /usr/bin/node           v18.19.0
        /usr/bin/npm            10.2.3
        /usr/bin/npx            10.2.3
        /usr/bin/corepack       0.22.0
                                        Recommended versions are nodejs  and npm
                                        MEMORY:
                                        Mem:            8.1G        3.8G        3.6G        831K        1.0G        4.3G
                                        Swap:           1.0G          0B        1.0G
                                        Total:          9.2G        3.8G        4.6G
                                        Active iob-Instances:   38
                                        Active repo(s): stable
                                        ioBroker Core:          js-controller           5.0.17
        admin                   6.12.0
                                        Objects type: jsonl
                                        States  type: jsonl
                                        + system.adapter.admin.0                  : admin                 : Mini-pc-Master                           -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                        + system.adapter.web.0                    : web                   : Mini-pc-Master                           -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                        Objects:                26578
                                        States:                 24887
                                        Size of iob-Database:
                                        30M     /opt/iobroker/iobroker-data/objects.jsonl
                                        68M     /opt/iobroker/iobroker-data/states.jsonl
                                        === Mark text until here for copying ===
                                          Walter.O.W Online
                                          Walter.O.W Online
                                          Walter.O.
                                          sudo apt-get install bluetooth bluez libbluetooth-dev libudev-dev libcap2-bin
                                          hab ich instaliert
                                          sudo setcap cap_net_raw+eip $(eval readlink -f which node)
                                          Erledigt
