  3. Einsteigerfragen
  4. Einbindung von Geräten
  5. Conbee III mit zigbee-Adapter nutzen
59 Beiträge 7 Kommentatoren 3.1k Aufrufe 4 Beobachtet
    Awacs2000
    Das sieht ja jetzt glaube ok aus, ABER, ich habe jetzt z.B. einen Aquara Fenster-/Türkontakt aktviert (mit 10cm Abstand zum Conbee-Stick) und 5-10 Sek. die Taste gedrückt bis die blaue LED 3x geblinkt hat.
    Aber es tut sich nichts in der Kopplung
    • A Awacs2000
      Starting zigbee-herdsman...
      Zigbee-Herdsman started successfully with Coordinator firmware version: ConBee3 : 0x26550900 (X-X.2.6.85)
      Network parameters: panID=50500 channel=11 extendedPanID=dddddddddddddddd
      Unable to disable LED, unsupported function.
      No devices
      Closing network.
      mike@IO-BROKER:~$ tail -n 20 /opt/iobroker/log/iobroker.current.log
      2026-06-05 13:05:08.388 - info: zigbee.0 (994) delete old Backup files. keep only last 10
      2026-06-05 13:05:08.389 - info: zigbee.0 (994) Autostart Zigbee subsystem
      2026-06-05 13:05:08.389 - info: zigbee.0 (994) Starting Adapter npm ...
      2026-06-05 13:05:08.395 - info: zigbee.0 (994) Installed Version: iobroker.zigbee@3.4.5 (Converters 26.62.0 Herdsman 10.3.0)
      2026-06-05 13:05:08.395 - info: zigbee.0 (994) configured transmit power : normal
      2026-06-05 13:05:08.395 - info: zigbee.0 (994) Starting Zigbee-Herdsman
      2026-06-05 13:05:13.532 - info: zigbee.0 (994) Zigbee-Herdsman started successfully with Coordinator firmware version: ConBee3 : 0x26550900 (X-X.2.6.85)
      2026-06-05 13:05:13.532 - info: zigbee.0 (994) No devices
      2026-06-05 13:05:13.533 - info: zigbee.0 (994) Zigbee started
      2026-06-05 13:05:13.533 - info: zigbee.0 (994) Config value 0xdddddddddddddddd : Network value 0xdddddddddddddddd
      2026-06-05 13:05:13.580 - info: host.IO-BROKER stopInstance system.adapter.zigbee.0 (force=false, process=true)
      2026-06-05 13:05:13.583 - info: zigbee.0 (994) Got terminate signal TERMINATE_YOURSELF
      2026-06-05 13:05:13.583 - info: zigbee.0 (994) Halting zigbee adapter. Restart delay is at least 30 seconds.
      2026-06-05 13:05:13.583 - info: zigbee.0 (994) cleaning everything up
      2026-06-05 13:05:13.621 - info: host.IO-BROKER stopInstance system.adapter.zigbee.0 send kill signal
      2026-06-05 13:05:14.083 - info: zigbee.0 (994) Saved local configuration data
      2026-06-05 13:05:15.815 - info: zigbee.0 (994) Closing network.
      2026-06-05 13:05:17.584 - info: zigbee.0 (994) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2026-06-05 13:05:18.119 - info: host.IO-BROKER instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      AsgothianA Offline
      AsgothianA Offline
      Asgothian
      @Awacs2000 sagte:
      No devices
      Closing network.
      Bevor du Geräte anmeldest solltest du:
      • Die ExtPan ID anpassen
      • den Transport Key anpassen
      Mit der ExtPanID bekommst du in der Zukunft Probleme, und der Standard Network Key ist ungünstig, weil darüber die Transportverschlüsselung läuft - sprich dein Nachbar und du können marodierende Geräte bekommen.
      A,.
      Nachtrag: die Fensterkontakte sind immer kritisch anzulernen. Da brauche ich auch oft mehrere Versuche.
        Awacs2000
        Die ExtPan ID rauslöschen
        den Transport Key rauslöschen
        Reboot?
        Oder wie macht man das?
        • A Awacs2000
          No devices
          Closing network.
          Samson71S Offline
          Samson71S Offline
          Samson71
          @Awacs2000
          Willst oder kannst Du nicht Lesen, ist das bewusste Ignoranz oder wie muss ich mir das Ignorieren der Bitte um Nutzung von Code-Tags </> erklären?
          Markus
          Bitte beachten:
            Awacs2000
            schrieb am zuletzt editiert von Awacs2000
            Also, jetzt mal ganz langsam. Ich war glaube vor vielen Jahren das letzte mal hier im Forum.
            Was meinst Du genau? Was mache ich falsch?
            Davon mal abgeshen, hatte ich es tatsächlich obern überlesen.
              Awacs2000
              2026-06-05 13:10:07.266  - info: zigbee.0 (1035) init localConfig
              2026-06-05 13:10:07.277  - info: zigbee.0 (1035) Adapter ready - starting subsystems. Adapter is running in info mode.
              2026-06-05 13:10:07.277  - warn: zigbee.0 (1035) Activating zigbee-herdsman debug connection - successful
              Meinst Du das so? Ist das so korrekt mal als Beispiel.
              • A Awacs2000
                Samson71S Offline
                Samson71S Offline
                Samson71
                @Awacs2000
                Poste bitte Logs nicht stumpf als Text mit Copy and Paste oder als Screenshot. Ist beides schlecht zu lesen und aus Bildern kann man auch nicht zitieren. Für Logs gibt es die Code-Tag-Funktion
                Markus
                Bitte beachten:
                • A Awacs2000
                  Samson71S Offline
                  Samson71S Offline
                  Samson71
                  @Awacs2000 sagte:
                  Jepp. Genau.
                  Markus
                  Bitte beachten:
                    Awacs2000
                    Alles klar, sorry dafür. Wußte ich nicht.
                    • A Awacs2000
                      Samson71S Offline
                      Samson71S Offline
                      Samson71
                      @Awacs2000
                      Ich bleibe da hartnäckig 😉
                      Markus
                      Bitte beachten:
                        Awacs2000
                        Macht es Sinn den NVRAM auf dem Stick nochmal zu löschen?
                        Anlernen klappt irgendwie immer noch nicht.
                        • A Awacs2000
                          Reboot?
                          AsgothianA Offline
                          AsgothianA Offline
                          Asgothian
                          @Awacs2000 sagte:
                          Reboot?
                          Es gibt eine Anleitung hier: https://github.com/ioBroker/ioBroker.zigbee/wiki/Step‐by‐Step-guide-for-the-Zigbee-network-configuration
                          Ansonsten:
                          • Konfigurationsseite öffnen
                          • Hardware Tab
                          • via 'start stop' button in der Seite nur das Zigbee Netz anhalten
                          • Werte in der Konfiguration anpassen
                          • via 'start stop' button in der Seite nur das Zigbee Netz starten
                          • Schauen was das Ergebnis ist - wenn es läuft: Konfiguration speichern, dann startet der Adapter Neu
                          A.
                            Awacs2000
                            Hm, hilft alles irgendwie nicht.
                            Aktuell ist dann die PanID mit einem roten X versehen.
                            Wenn ich die Channel scanne kommt ein "Error"
                            overriding zigbee options with:
                            extPanID : db9a11e33b0d63ce
                            panID : 50800
                            channel : 15
                            port : /dev/ttyUSB0
                            adapterType : deconz
                            baudRate : 115200
                            precfgkey : 01040906080B0D0F00050609080A0C0D
                            flowCTRL : false
                            Network parameters in Config     : panID=50900 channel=15 extendedPanID=db9a11e33b0d53ce
                            Network parameters on Coordinator: panID=50900 channel=15 extendedPanID=dddddddddddddddd
                            Starting zigbee-herdsman problem : failed to start adapter connection to firmware
                            Failed to start Zigbee: no message given
                            Und jetzt kommt wieder "failed to start adapter connection to firmware", obwohl das eben alles super aussah.
                            • A Awacs2000
                              panID : 50800
                              channel : 15
                              port : /dev/ttyUSB0
                              baudRate : 115200
                              flowCTRL : false
                              @Awacs2000 sagte:
                              Wohl eher nicht, wenn..
                              @Awacs2000 sagte:
                              Ist!
                              Was sagt denn das rote x?
                              • Michael SchmittM Offline
                                Michael Schmitt
                                nutzt du einen Usb2.0 port und eine Usb Verlängerung ?
                                  Awacs2000
                                  Mein Rechner hat kein USB2-Port. Verlängerung habe ich aber dran.
                                  Ich hatte eben auch kurzzeitig wieder alles komplett grün abgehakt.
                                  Channel-Scan geht aber trotzdem nicht.
                                  Irgendwie klappt es mal, dann ist der Channel oder die PanID wieder mit einem X versehen.
                                  habe jetzt alles komplett, also auch den Host, mal rebootet.
                                  Aktuell geht nach dem reboot gar nichts mehr. Bleibt alles rot.
                                  Hätte ich das vorher gewußt, hätte ich echt mein Phoscon behalten.
                                  Michael SchmittM 1 Antwort Letzte Antwort
                                    Awacs2000
                                    • A Awacs2000
                                      Michael Schmitt
                                      @Awacs2000 sagte:
                                      kannst doch mit einem Backup schnell wieder herstellen
                                        Awacs2000
                                        Klar kann ich das wieder herstellen, aber das Ziel war ja, dass ich nur noch zigbee und den Conbee III nutze.
                                        • AsgothianA Offline
                                          AsgothianA Offline
                                          Asgothian
                                          Nur das Fehler-Log posten (als Screenshot) hilft leider nichts - da fehlt context.
                                          Bitte nach dem von mir verlinkten Dokument vorgehen - das habe ich nicht aus jux und dollerei geschrieben.
                                          A.
