  3. Einsteigerfragen
  4. Einbindung von Geräten
  5. Conbee III mit zigbee-Adapter nutzen
59 Beiträge 7 Kommentatoren 3.1k Aufrufe 4 Beobachtet
  • A Awacs2000
    Ah, so, oder:
    root@IO-BROKER:~# ls -l /dev/ttyUSB0
    crw-rw-rw- 1 root dialout 188, 0 Jun 5 12:40 /dev/ttyUSB0
    root@IO-BROKER:~#
    @Awacs2000
    Und was haben wir zum root gesagt?
    Ich bin dann an der Stelle raus.
      Awacs2000
      Ah, sorry. Falsch angemeldet
      mike@IO-BROKER:~$ ls -l /dev/ttyUSB0
      crw-rw-rw- 1 root dialout 188, 0 Jun 5 13:01 /dev/ttyUSB0
      mike@IO-BROKER:~$
      mike@LINUX-VMs:~# ls -l /dev/serial/by-id/
      total 0
      lrwxrwxrwx 1 root root 13 Jun 5 12:16 usb-dresden_elektronik_ConBee_III_DE03480916-if00-port0 -> ../../ttyUSB0
      mike@LINUX-VMs:~#
        Awacs2000
        Starting zigbee-herdsman...
        Zigbee-Herdsman started successfully with Coordinator firmware version: ConBee3 : 0x26550900 (X-X.2.6.85)
        Network parameters: panID=50500 channel=11 extendedPanID=dddddddddddddddd
        Unable to disable LED, unsupported function.
        No devices
        Closing network.
        mike@IO-BROKER:~$ tail -n 20 /opt/iobroker/log/iobroker.current.log
        2026-06-05 13:05:08.388 - info: zigbee.0 (994) delete old Backup files. keep only last 10
        2026-06-05 13:05:08.389 - info: zigbee.0 (994) Autostart Zigbee subsystem
        2026-06-05 13:05:08.389 - info: zigbee.0 (994) Starting Adapter npm ...
        2026-06-05 13:05:08.395 - info: zigbee.0 (994) Installed Version: iobroker.zigbee@3.4.5 (Converters 26.62.0 Herdsman 10.3.0)
        2026-06-05 13:05:08.395 - info: zigbee.0 (994) configured transmit power : normal
        2026-06-05 13:05:08.395 - info: zigbee.0 (994) Starting Zigbee-Herdsman
        2026-06-05 13:05:13.532 - info: zigbee.0 (994) Zigbee-Herdsman started successfully with Coordinator firmware version: ConBee3 : 0x26550900 (X-X.2.6.85)
        2026-06-05 13:05:13.532 - info: zigbee.0 (994) No devices
        2026-06-05 13:05:13.533 - info: zigbee.0 (994) Zigbee started
        2026-06-05 13:05:13.533 - info: zigbee.0 (994) Config value 0xdddddddddddddddd : Network value 0xdddddddddddddddd
        2026-06-05 13:05:13.580 - info: host.IO-BROKER stopInstance system.adapter.zigbee.0 (force=false, process=true)
        2026-06-05 13:05:13.583 - info: zigbee.0 (994) Got terminate signal TERMINATE_YOURSELF
        2026-06-05 13:05:13.583 - info: zigbee.0 (994) Halting zigbee adapter. Restart delay is at least 30 seconds.
        2026-06-05 13:05:13.583 - info: zigbee.0 (994) cleaning everything up
        2026-06-05 13:05:13.621 - info: host.IO-BROKER stopInstance system.adapter.zigbee.0 send kill signal
        2026-06-05 13:05:14.083 - info: zigbee.0 (994) Saved local configuration data
        2026-06-05 13:05:15.815 - info: zigbee.0 (994) Closing network.
        2026-06-05 13:05:17.584 - info: zigbee.0 (994) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2026-06-05 13:05:18.119 - info: host.IO-BROKER instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        AsgothianA Samson71S 2 Antworten Letzte Antwort
          Awacs2000
          Das sieht ja jetzt glaube ok aus, ABER, ich habe jetzt z.B. einen Aquara Fenster-/Türkontakt aktviert (mit 10cm Abstand zum Conbee-Stick) und 5-10 Sek. die Taste gedrückt bis die blaue LED 3x geblinkt hat.
          Aber es tut sich nichts in der Kopplung
          • A Awacs2000
            No devices
            Closing network.
            AsgothianA Offline
            AsgothianA Offline
            Asgothian
            @Awacs2000 sagte:
            No devices
            Closing network.
            Bevor du Geräte anmeldest solltest du:
            • Die ExtPan ID anpassen
            • den Transport Key anpassen
            Mit der ExtPanID bekommst du in der Zukunft Probleme, und der Standard Network Key ist ungünstig, weil darüber die Transportverschlüsselung läuft - sprich dein Nachbar und du können marodierende Geräte bekommen.
            A,.
            Nachtrag: die Fensterkontakte sind immer kritisch anzulernen. Da brauche ich auch oft mehrere Versuche.
              Awacs2000
              Die ExtPan ID rauslöschen
              den Transport Key rauslöschen
              Reboot?
              Oder wie macht man das?
              • A Awacs2000
                No devices
                Closing network.
                Samson71S Offline
                Samson71S Offline
                Samson71
                @Awacs2000
                Willst oder kannst Du nicht Lesen, ist das bewusste Ignoranz oder wie muss ich mir das Ignorieren der Bitte um Nutzung von Code-Tags </> erklären?
                Markus
                Bitte beachten:
                  Awacs2000
                  schrieb am zuletzt editiert von Awacs2000
                  Also, jetzt mal ganz langsam. Ich war glaube vor vielen Jahren das letzte mal hier im Forum.
                  Was meinst Du genau? Was mache ich falsch?
                  Davon mal abgeshen, hatte ich es tatsächlich obern überlesen.
                    Awacs2000
                    2026-06-05 13:10:07.266  - info: zigbee.0 (1035) init localConfig
                    2026-06-05 13:10:07.277  - info: zigbee.0 (1035) Adapter ready - starting subsystems. Adapter is running in info mode.
                    2026-06-05 13:10:07.277  - warn: zigbee.0 (1035) Activating zigbee-herdsman debug connection - successful
                    Meinst Du das so? Ist das so korrekt mal als Beispiel.
                    • A Awacs2000
                      Samson71S Offline
                      Samson71S Offline
                      Samson71
                      @Awacs2000
                      Poste bitte Logs nicht stumpf als Text mit Copy and Paste oder als Screenshot. Ist beides schlecht zu lesen und aus Bildern kann man auch nicht zitieren. Für Logs gibt es die Code-Tag-Funktion
                      Markus
                      Bitte beachten:
                      • A Awacs2000
                        Samson71S Offline
                        Samson71S Offline
                        Samson71
                        @Awacs2000 sagte:
                        Jepp. Genau.
                        Markus
                        Bitte beachten:
                          Awacs2000
                          Alles klar, sorry dafür. Wußte ich nicht.
                          • A Awacs2000
                            Samson71S Offline
                            Samson71S Offline
                            Samson71
                            @Awacs2000
                            Ich bleibe da hartnäckig 😉
                            Markus
                            Bitte beachten:
                              Awacs2000
                              Macht es Sinn den NVRAM auf dem Stick nochmal zu löschen?
                              Anlernen klappt irgendwie immer noch nicht.
                              • A Awacs2000
                                Reboot?
                                AsgothianA Offline
                                AsgothianA Offline
                                Asgothian
                                @Awacs2000 sagte:
                                Reboot?
                                Es gibt eine Anleitung hier: https://github.com/ioBroker/ioBroker.zigbee/wiki/Step‐by‐Step-guide-for-the-Zigbee-network-configuration
                                Ansonsten:
                                • Konfigurationsseite öffnen
                                • Hardware Tab
                                • via 'start stop' button in der Seite nur das Zigbee Netz anhalten
                                • Werte in der Konfiguration anpassen
                                • via 'start stop' button in der Seite nur das Zigbee Netz starten
                                • Schauen was das Ergebnis ist - wenn es läuft: Konfiguration speichern, dann startet der Adapter Neu
                                A.
                                  Awacs2000
                                  Hm, hilft alles irgendwie nicht.
                                  Aktuell ist dann die PanID mit einem roten X versehen.
                                  Wenn ich die Channel scanne kommt ein "Error"
                                  overriding zigbee options with:
                                  extPanID : db9a11e33b0d63ce
                                  panID : 50800
                                  channel : 15
                                  port : /dev/ttyUSB0
                                  adapterType : deconz
                                  baudRate : 115200
                                  precfgkey : 01040906080B0D0F00050609080A0C0D
                                  flowCTRL : false
                                  Network parameters in Config     : panID=50900 channel=15 extendedPanID=db9a11e33b0d53ce
                                  Network parameters on Coordinator: panID=50900 channel=15 extendedPanID=dddddddddddddddd
                                  Starting zigbee-herdsman problem : failed to start adapter connection to firmware
                                  Failed to start Zigbee: no message given
                                  Und jetzt kommt wieder "failed to start adapter connection to firmware", obwohl das eben alles super aussah.
                                  • A Awacs2000
                                    panID : 50800
                                    channel : 15
                                    port : /dev/ttyUSB0
                                    baudRate : 115200
                                    flowCTRL : false
                                    @Awacs2000 sagte:
                                    Wohl eher nicht, wenn..
                                    @Awacs2000 sagte:
                                    Ist!
                                    Was sagt denn das rote x?
                                    • Michael SchmittM Offline
                                      Michael Schmitt
                                      nutzt du einen Usb2.0 port und eine Usb Verlängerung ?
                                        Awacs2000
                                        Mein Rechner hat kein USB2-Port. Verlängerung habe ich aber dran.
                                        Ich hatte eben auch kurzzeitig wieder alles komplett grün abgehakt.
                                        Channel-Scan geht aber trotzdem nicht.
                                        Irgendwie klappt es mal, dann ist der Channel oder die PanID wieder mit einem X versehen.
                                        habe jetzt alles komplett, also auch den Host, mal rebootet.
                                        Aktuell geht nach dem reboot gar nichts mehr. Bleibt alles rot.
                                        Hätte ich das vorher gewußt, hätte ich echt mein Phoscon behalten.
                                        Michael SchmittM 1 Antwort Letzte Antwort
                                          Awacs2000
