  3. Einsteigerfragen
  4. Einbindung von Geräten
  5. Conbee III mit zigbee-Adapter nutzen
59 Beiträge 7 Kommentatoren 3.1k Aufrufe 4 Beobachtet
    Awacs2000
    Starting zigbee-herdsman...
    Zigbee-Herdsman started successfully with Coordinator firmware version: ConBee3 : 0x26550900 (X-X.2.6.85)
    Network parameters: panID=50500 channel=11 extendedPanID=dddddddddddddddd
    Unable to disable LED, unsupported function.
    No devices
    Closing network.
    mike@IO-BROKER:~$ tail -n 20 /opt/iobroker/log/iobroker.current.log
    2026-06-05 13:05:08.388 - info: zigbee.0 (994) delete old Backup files. keep only last 10
    2026-06-05 13:05:08.389 - info: zigbee.0 (994) Autostart Zigbee subsystem
    2026-06-05 13:05:08.389 - info: zigbee.0 (994) Starting Adapter npm ...
    2026-06-05 13:05:08.395 - info: zigbee.0 (994) Installed Version: iobroker.zigbee@3.4.5 (Converters 26.62.0 Herdsman 10.3.0)
    2026-06-05 13:05:08.395 - info: zigbee.0 (994) configured transmit power : normal
    2026-06-05 13:05:08.395 - info: zigbee.0 (994) Starting Zigbee-Herdsman
    2026-06-05 13:05:13.532 - info: zigbee.0 (994) Zigbee-Herdsman started successfully with Coordinator firmware version: ConBee3 : 0x26550900 (X-X.2.6.85)
    2026-06-05 13:05:13.532 - info: zigbee.0 (994) No devices
    2026-06-05 13:05:13.533 - info: zigbee.0 (994) Zigbee started
    2026-06-05 13:05:13.533 - info: zigbee.0 (994) Config value 0xdddddddddddddddd : Network value 0xdddddddddddddddd
    2026-06-05 13:05:13.580 - info: host.IO-BROKER stopInstance system.adapter.zigbee.0 (force=false, process=true)
    2026-06-05 13:05:13.583 - info: zigbee.0 (994) Got terminate signal TERMINATE_YOURSELF
    2026-06-05 13:05:13.583 - info: zigbee.0 (994) Halting zigbee adapter. Restart delay is at least 30 seconds.
    2026-06-05 13:05:13.583 - info: zigbee.0 (994) cleaning everything up
    2026-06-05 13:05:13.621 - info: host.IO-BROKER stopInstance system.adapter.zigbee.0 send kill signal
    2026-06-05 13:05:14.083 - info: zigbee.0 (994) Saved local configuration data
    2026-06-05 13:05:15.815 - info: zigbee.0 (994) Closing network.
    2026-06-05 13:05:17.584 - info: zigbee.0 (994) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2026-06-05 13:05:18.119 - info: host.IO-BROKER instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    AsgothianA Samson71S 2 Antworten Letzte Antwort
      Awacs2000
      Das sieht ja jetzt glaube ok aus, ABER, ich habe jetzt z.B. einen Aquara Fenster-/Türkontakt aktviert (mit 10cm Abstand zum Conbee-Stick) und 5-10 Sek. die Taste gedrückt bis die blaue LED 3x geblinkt hat.
      Aber es tut sich nichts in der Kopplung
      • A Awacs2000
        No devices
        Closing network.
        AsgothianA Offline
        AsgothianA Offline
        Asgothian
        @Awacs2000 sagte:
        No devices
        Closing network.
        Bevor du Geräte anmeldest solltest du:
        • Die ExtPan ID anpassen
        • den Transport Key anpassen
        Mit der ExtPanID bekommst du in der Zukunft Probleme, und der Standard Network Key ist ungünstig, weil darüber die Transportverschlüsselung läuft - sprich dein Nachbar und du können marodierende Geräte bekommen.
        A,.
        Nachtrag: die Fensterkontakte sind immer kritisch anzulernen. Da brauche ich auch oft mehrere Versuche.
          Awacs2000
          Die ExtPan ID rauslöschen
          den Transport Key rauslöschen
          Reboot?
          Oder wie macht man das?
          • A Awacs2000
            No devices
            Closing network.
            Samson71S Offline
            Samson71S Offline
            Samson71
            @Awacs2000
            Willst oder kannst Du nicht Lesen, ist das bewusste Ignoranz oder wie muss ich mir das Ignorieren der Bitte um Nutzung von Code-Tags </> erklären?
            Markus
            Bitte beachten:
              Awacs2000
              schrieb am zuletzt editiert von Awacs2000
              Also, jetzt mal ganz langsam. Ich war glaube vor vielen Jahren das letzte mal hier im Forum.
              Was meinst Du genau? Was mache ich falsch?
              Davon mal abgeshen, hatte ich es tatsächlich obern überlesen.
                Awacs2000
                2026-06-05 13:10:07.266  - info: zigbee.0 (1035) init localConfig
                2026-06-05 13:10:07.277  - info: zigbee.0 (1035) Adapter ready - starting subsystems. Adapter is running in info mode.
                2026-06-05 13:10:07.277  - warn: zigbee.0 (1035) Activating zigbee-herdsman debug connection - successful
                Meinst Du das so? Ist das so korrekt mal als Beispiel.
                • A Awacs2000
                  Samson71S Offline
                  Samson71S Offline
                  Samson71
                  @Awacs2000
                  Poste bitte Logs nicht stumpf als Text mit Copy and Paste oder als Screenshot. Ist beides schlecht zu lesen und aus Bildern kann man auch nicht zitieren. Für Logs gibt es die Code-Tag-Funktion
                  Markus
                  Bitte beachten:
                  • A Awacs2000
                    Samson71S Offline
                    Samson71S Offline
                    Samson71
                    @Awacs2000 sagte:
                    Jepp. Genau.
                    Markus
                    Bitte beachten:
                      Awacs2000
                      Alles klar, sorry dafür. Wußte ich nicht.
                      • A Awacs2000
                        Samson71S Offline
                        Samson71S Offline
                        Samson71
                        @Awacs2000
                        Ich bleibe da hartnäckig 😉
                        Markus
                        Bitte beachten:
                          Awacs2000
                          Macht es Sinn den NVRAM auf dem Stick nochmal zu löschen?
                          Anlernen klappt irgendwie immer noch nicht.
                          • A Awacs2000
                            Reboot?
                            AsgothianA Offline
                            AsgothianA Offline
                            Asgothian
                            @Awacs2000 sagte:
                            Reboot?
                            Es gibt eine Anleitung hier: https://github.com/ioBroker/ioBroker.zigbee/wiki/Step‐by‐Step-guide-for-the-Zigbee-network-configuration
                            Ansonsten:
                            • Konfigurationsseite öffnen
                            • Hardware Tab
                            • via 'start stop' button in der Seite nur das Zigbee Netz anhalten
                            • Werte in der Konfiguration anpassen
                            • via 'start stop' button in der Seite nur das Zigbee Netz starten
                            • Schauen was das Ergebnis ist - wenn es läuft: Konfiguration speichern, dann startet der Adapter Neu
                            A.
                              Awacs2000
                              Hm, hilft alles irgendwie nicht.
                              Aktuell ist dann die PanID mit einem roten X versehen.
                              Wenn ich die Channel scanne kommt ein "Error"
                              overriding zigbee options with:
                              extPanID : db9a11e33b0d63ce
                              panID : 50800
                              channel : 15
                              port : /dev/ttyUSB0
                              adapterType : deconz
                              baudRate : 115200
                              precfgkey : 01040906080B0D0F00050609080A0C0D
                              flowCTRL : false
                              Network parameters in Config     : panID=50900 channel=15 extendedPanID=db9a11e33b0d53ce
                              Network parameters on Coordinator: panID=50900 channel=15 extendedPanID=dddddddddddddddd
                              Starting zigbee-herdsman problem : failed to start adapter connection to firmware
                              Failed to start Zigbee: no message given
                              Und jetzt kommt wieder "failed to start adapter connection to firmware", obwohl das eben alles super aussah.
                              • A Awacs2000
                                panID : 50800
                                channel : 15
                                port : /dev/ttyUSB0
                                baudRate : 115200
                                flowCTRL : false
                                @Awacs2000 sagte:
                                Wohl eher nicht, wenn..
                                @Awacs2000 sagte:
                                Ist!
                                Was sagt denn das rote x?
                                • Michael SchmittM Offline
                                  Michael Schmitt
                                  nutzt du einen Usb2.0 port und eine Usb Verlängerung ?
                                    Awacs2000
                                    Mein Rechner hat kein USB2-Port. Verlängerung habe ich aber dran.
                                    Ich hatte eben auch kurzzeitig wieder alles komplett grün abgehakt.
                                    Channel-Scan geht aber trotzdem nicht.
                                    Irgendwie klappt es mal, dann ist der Channel oder die PanID wieder mit einem X versehen.
                                    habe jetzt alles komplett, also auch den Host, mal rebootet.
                                    Aktuell geht nach dem reboot gar nichts mehr. Bleibt alles rot.
                                    Hätte ich das vorher gewußt, hätte ich echt mein Phoscon behalten.
                                    Michael SchmittM 1 Antwort Letzte Antwort
                                      Awacs2000
                                      • A Awacs2000
                                        Michael Schmitt
                                        @Awacs2000 sagte:
                                        kannst doch mit einem Backup schnell wieder herstellen
                                          Awacs2000
                                          Klar kann ich das wieder herstellen, aber das Ziel war ja, dass ich nur noch zigbee und den Conbee III nutze.
