  3. Einsteigerfragen
  4. Einbindung von Geräten
  5. Conbee III mit zigbee-Adapter nutzen
59 Beiträge 7 Kommentatoren 3.1k Aufrufe 4 Beobachtet
    Awacs2000
    Ah, so, oder:
    root@IO-BROKER:~# ls -l /dev/ttyUSB0
    crw-rw-rw- 1 root dialout 188, 0 Jun 5 12:40 /dev/ttyUSB0
    root@IO-BROKER:~#
    • A Awacs2000
      Ah, so, oder:
      root@IO-BROKER:~#
      @Awacs2000
      Und was haben wir zum root gesagt?
      Ich bin dann an der Stelle raus.
        Awacs2000
        Ah, sorry. Falsch angemeldet
        mike@IO-BROKER:~$ ls -l /dev/ttyUSB0
        crw-rw-rw- 1 root dialout 188, 0 Jun 5 13:01 /dev/ttyUSB0
        mike@IO-BROKER:~$
        mike@LINUX-VMs:~# ls -l /dev/serial/by-id/
        total 0
        lrwxrwxrwx 1 root root 13 Jun 5 12:16 usb-dresden_elektronik_ConBee_III_DE03480916-if00-port0 -> ../../ttyUSB0
        mike@LINUX-VMs:~#
          Awacs2000
          Starting zigbee-herdsman...
          Zigbee-Herdsman started successfully with Coordinator firmware version: ConBee3 : 0x26550900 (X-X.2.6.85)
          Network parameters: panID=50500 channel=11 extendedPanID=dddddddddddddddd
          Unable to disable LED, unsupported function.
          No devices
          Closing network.
          mike@IO-BROKER:~$ tail -n 20 /opt/iobroker/log/iobroker.current.log
          2026-06-05 13:05:08.388 - info: zigbee.0 (994) delete old Backup files. keep only last 10
          2026-06-05 13:05:08.389 - info: zigbee.0 (994) Autostart Zigbee subsystem
          2026-06-05 13:05:08.389 - info: zigbee.0 (994) Starting Adapter npm ...
          2026-06-05 13:05:08.395 - info: zigbee.0 (994) Installed Version: iobroker.zigbee@3.4.5 (Converters 26.62.0 Herdsman 10.3.0)
          2026-06-05 13:05:08.395 - info: zigbee.0 (994) configured transmit power : normal
          2026-06-05 13:05:08.395 - info: zigbee.0 (994) Starting Zigbee-Herdsman
          2026-06-05 13:05:13.532 - info: zigbee.0 (994) Zigbee-Herdsman started successfully with Coordinator firmware version: ConBee3 : 0x26550900 (X-X.2.6.85)
          2026-06-05 13:05:13.532 - info: zigbee.0 (994) No devices
          2026-06-05 13:05:13.533 - info: zigbee.0 (994) Zigbee started
          2026-06-05 13:05:13.533 - info: zigbee.0 (994) Config value 0xdddddddddddddddd : Network value 0xdddddddddddddddd
          2026-06-05 13:05:13.580 - info: host.IO-BROKER stopInstance system.adapter.zigbee.0 (force=false, process=true)
          2026-06-05 13:05:13.583 - info: zigbee.0 (994) Got terminate signal TERMINATE_YOURSELF
          2026-06-05 13:05:13.583 - info: zigbee.0 (994) Halting zigbee adapter. Restart delay is at least 30 seconds.
          2026-06-05 13:05:13.583 - info: zigbee.0 (994) cleaning everything up
          2026-06-05 13:05:13.621 - info: host.IO-BROKER stopInstance system.adapter.zigbee.0 send kill signal
          2026-06-05 13:05:14.083 - info: zigbee.0 (994) Saved local configuration data
          2026-06-05 13:05:15.815 - info: zigbee.0 (994) Closing network.
          2026-06-05 13:05:17.584 - info: zigbee.0 (994) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2026-06-05 13:05:18.119 - info: host.IO-BROKER instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          AsgothianA Samson71S 2 Antworten Letzte Antwort
            Awacs2000
            Das sieht ja jetzt glaube ok aus, ABER, ich habe jetzt z.B. einen Aquara Fenster-/Türkontakt aktviert (mit 10cm Abstand zum Conbee-Stick) und 5-10 Sek. die Taste gedrückt bis die blaue LED 3x geblinkt hat.
            Aber es tut sich nichts in der Kopplung
            • A Awacs2000
              No devices
              Closing network.
              AsgothianA Offline
              AsgothianA Offline
              Asgothian
              @Awacs2000 sagte:
              No devices
              Closing network.
              Bevor du Geräte anmeldest solltest du:
              • Die ExtPan ID anpassen
              • den Transport Key anpassen
              Mit der ExtPanID bekommst du in der Zukunft Probleme, und der Standard Network Key ist ungünstig, weil darüber die Transportverschlüsselung läuft - sprich dein Nachbar und du können marodierende Geräte bekommen.
              A,.
              Nachtrag: die Fensterkontakte sind immer kritisch anzulernen. Da brauche ich auch oft mehrere Versuche.
                Awacs2000
                Die ExtPan ID rauslöschen
                den Transport Key rauslöschen
                Reboot?
                Oder wie macht man das?
                • A Awacs2000
                  No devices
                  Closing network.
                  Samson71S Offline
                  Samson71S Offline
                  Samson71
                  @Awacs2000
                  Willst oder kannst Du nicht Lesen, ist das bewusste Ignoranz oder wie muss ich mir das Ignorieren der Bitte um Nutzung von Code-Tags </> erklären?
                  Markus
                  Bitte beachten:
                    Awacs2000
                    schrieb am zuletzt editiert von Awacs2000
                    Also, jetzt mal ganz langsam. Ich war glaube vor vielen Jahren das letzte mal hier im Forum.
                    Was meinst Du genau? Was mache ich falsch?
                    Davon mal abgeshen, hatte ich es tatsächlich obern überlesen.
                      Awacs2000
                      2026-06-05 13:10:07.266  - info: zigbee.0 (1035) init localConfig
                      2026-06-05 13:10:07.277  - info: zigbee.0 (1035) Adapter ready - starting subsystems. Adapter is running in info mode.
                      2026-06-05 13:10:07.277  - warn: zigbee.0 (1035) Activating zigbee-herdsman debug connection - successful
                      Meinst Du das so? Ist das so korrekt mal als Beispiel.
                      • A Awacs2000
                        Samson71S Offline
                        Samson71S Offline
                        Samson71
                        @Awacs2000
                        Poste bitte Logs nicht stumpf als Text mit Copy and Paste oder als Screenshot. Ist beides schlecht zu lesen und aus Bildern kann man auch nicht zitieren. Für Logs gibt es die Code-Tag-Funktion
                        Markus
                        Bitte beachten:
                        • A Awacs2000
                          Samson71S Offline
                          Samson71S Offline
                          Samson71
                          @Awacs2000 sagte:
                          Jepp. Genau.
                          Markus
                          Bitte beachten:
                            Awacs2000
                            Alles klar, sorry dafür. Wußte ich nicht.
                            • A Awacs2000
                              Samson71S Offline
                              Samson71S Offline
                              Samson71
                              @Awacs2000
                              Ich bleibe da hartnäckig 😉
                              Markus
                              Bitte beachten:
                                Awacs2000
                                Macht es Sinn den NVRAM auf dem Stick nochmal zu löschen?
                                Anlernen klappt irgendwie immer noch nicht.
                                • A Awacs2000
                                  Reboot?
                                  AsgothianA Offline
                                  AsgothianA Offline
                                  Asgothian
                                  @Awacs2000 sagte:
                                  Reboot?
                                  Es gibt eine Anleitung hier: https://github.com/ioBroker/ioBroker.zigbee/wiki/Step‐by‐Step-guide-for-the-Zigbee-network-configuration
                                  Ansonsten:
                                  • Konfigurationsseite öffnen
                                  • Hardware Tab
                                  • via 'start stop' button in der Seite nur das Zigbee Netz anhalten
                                  • Werte in der Konfiguration anpassen
                                  • via 'start stop' button in der Seite nur das Zigbee Netz starten
                                  • Schauen was das Ergebnis ist - wenn es läuft: Konfiguration speichern, dann startet der Adapter Neu
                                  A.
                                    Awacs2000
                                    Hm, hilft alles irgendwie nicht.
                                    Aktuell ist dann die PanID mit einem roten X versehen.
                                    Wenn ich die Channel scanne kommt ein "Error"
                                    overriding zigbee options with:
                                    extPanID : db9a11e33b0d63ce
                                    panID : 50800
                                    channel : 15
                                    port : /dev/ttyUSB0
                                    adapterType : deconz
                                    baudRate : 115200
                                    precfgkey : 01040906080B0D0F00050609080A0C0D
                                    flowCTRL : false
                                    Network parameters in Config     : panID=50900 channel=15 extendedPanID=db9a11e33b0d53ce
                                    Network parameters on Coordinator: panID=50900 channel=15 extendedPanID=dddddddddddddddd
                                    Starting zigbee-herdsman problem : failed to start adapter connection to firmware
                                    Failed to start Zigbee: no message given
                                    Und jetzt kommt wieder "failed to start adapter connection to firmware", obwohl das eben alles super aussah.
                                    • A Awacs2000
                                      panID : 50800
                                      channel : 15
                                      port : /dev/ttyUSB0
                                      baudRate : 115200
                                      flowCTRL : false
                                      @Awacs2000 sagte:
                                      Wohl eher nicht, wenn..
                                      @Awacs2000 sagte:
                                      Ist!
                                      Was sagt denn das rote x?
                                      • Michael SchmittM Offline
                                        Michael Schmitt
                                        nutzt du einen Usb2.0 port und eine Usb Verlängerung ?
                                          Awacs2000
                                          Mein Rechner hat kein USB2-Port. Verlängerung habe ich aber dran.
                                          Ich hatte eben auch kurzzeitig wieder alles komplett grün abgehakt.
                                          Channel-Scan geht aber trotzdem nicht.
                                          Irgendwie klappt es mal, dann ist der Channel oder die PanID wieder mit einem X versehen.
                                          habe jetzt alles komplett, also auch den Host, mal rebootet.
                                          Aktuell geht nach dem reboot gar nichts mehr. Bleibt alles rot.
                                          Hätte ich das vorher gewußt, hätte ich echt mein Phoscon behalten.
                                          Michael SchmittM 1 Antwort Letzte Antwort
