  4. zwave - Beta ioBroker.zwavews
    5.1k
231 Beiträge 21 Kommentatoren 19.4k Aufrufe 18 Beobachtet
    @RikDRS
    Und im Log steht dazu?
    RikDRS
    #41
    @Thomas-Braun sagte in zwave - Beta ioBroker.zwavews:
    @RikDRS
    hier die Befehle / log während des versuchtem Updates:
    $ iobroker upgrade zwavews@0.1.11 --debug
    Update zwavews from @0.0.12 to @0.1.11
    NPM version: 10.8.2
    Installing iobroker.zwavews@0.1.11... (System call)
    npm error code ETARGET
    npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2026-02-02T16_21_11_449Z-debug-0.log
    Updating objects from io-package.json for adapter "zwavews" with version "0.0.12"
    Update "system.adapter.zwavews.0"
    upload [12] zwavews.admin /opt/iobroker/node_modules/iobroker.zwavews/admin/i18n/de/translations.json i18n/de/translations.json application/json
    upload [11] zwavews.admin /opt/iobroker/node_modules/iobroker.zwavews/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [10] zwavews.admin /opt/iobroker/node_modules/iobroker.zwavews/admin/i18n/es/translations.json i18n/es/translations.json application/json
    upload [9] zwavews.admin /opt/iobroker/node_modules/iobroker.zwavews/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [8] zwavews.admin /opt/iobroker/node_modules/iobroker.zwavews/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [7] zwavews.admin /opt/iobroker/node_modules/iobroker.zwavews/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [6] zwavews.admin /opt/iobroker/node_modules/iobroker.zwavews/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [5] zwavews.admin /opt/iobroker/node_modules/iobroker.zwavews/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    upload [4] zwavews.admin /opt/iobroker/node_modules/iobroker.zwavews/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    upload [3] zwavews.admin /opt/iobroker/node_modules/iobroker.zwavews/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
    upload [2] zwavews.admin /opt/iobroker/node_modules/iobroker.zwavews/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [1] zwavews.admin /opt/iobroker/node_modules/iobroker.zwavews/admin/jsonConfig.json jsonConfig.json application/json
    upload [0] zwavews.admin /opt/iobroker/node_modules/iobroker.zwavews/admin/zwavews.png zwavews.png image/png
    Process exited with code 0
    hier die oben genannte Log-Datei:
    0 verbose cli /usr/bin/node /usr/bin/npm
    1 info using npm@10.8.2
    2 info using node@v20.20.0
    3 silly config load:file:/usr/lib/node_modules/npm/npmrc
    4 silly config load:file:/opt/iobroker/.npmrc
    5 silly config load:file:/home/iobroker/.npmrc
    6 silly config load:file:/usr/etc/npmrc
    7 verbose title npm install iobroker.zwavews@0.1.11
    8 verbose argv "install" "--save-exact" "iobroker.zwavews@0.1.11" "--foreground-scripts"
    9 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs/2026-02-02T16_21_11_449Z-
    10 verbose logfile /home/iobroker/.npm/_logs/2026-02-02T16_21_11_449Z-debug-0.log
    11 silly packumentCache heap:2197815296 maxSize:549453824 maxEntrySize:274726912
    12 silly logfile start cleaning logs, removing 1 files
    13 silly logfile done cleaning log files
    14 silly idealTree buildDeps
    15 silly fetch manifest iobroker.zwavews@0.1.11
    16 silly packumentCache full:https://registry.npmjs.org/iobroker.zwavews cache-miss
    17 http fetch GET 200 https://registry.npmjs.org/iobroker.zwavews 2262ms (cache updated)
    18 silly packumentCache full:https://registry.npmjs.org/iobroker.zwavews set size:undefined disposed:false
    19 silly placeDep ROOT iobroker.zwavews@ REPLACE for: iobroker.inst@3.0.0 want: 0.1.11
    20 verbose type version
    21 verbose stack iobroker.zwavews: No matching version found for iobroker.zwavews@0.1.11.
    21 verbose stack     at module.exports (/usr/lib/node_modules/npm/node_modules/npm-pick-manifest/lib/index.js:215:23)
    21 verbose stack     at RegistryFetcher.manifest (/usr/lib/node_modules/npm/node_modules/pacote/lib/registry.js:130:54)
    21 verbose stack     at async #fetchManifest (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/build-ideal-tree.js:1199:20)
    21 verbose stack     at async #nodeFromEdge (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/build-ideal-tree.js:1037:19)
    21 verbose stack     at async #buildDepStep (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/build-ideal-tree.js:901:11)
    21 verbose stack     at async Arborist.buildIdealTree (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/build-ideal-tree.js:181:7)
    21 verbose stack     at async Promise.all (index 1)
    21 verbose stack     at async Arborist.reify (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:131:5)
    21 verbose stack     at async Install.exec (/usr/lib/node_modules/npm/lib/commands/install.js:150:5)
    21 verbose stack     at async Npm.exec (/usr/lib/node_modules/npm/lib/npm.js:207:9)
    22 error code ETARGET
    23 error notarget No matching version found for iobroker.zwavews@0.1.11.
    24 error notarget In most cases you or one of your dependencies are requesting
    24 error notarget a package version that doesn't exist.
    25 silly unfinished npm timer reify 1770049271911
    26 silly unfinished npm timer reify:loadTrees 1770049271927
    27 verbose cwd /opt/iobroker
    28 verbose os Linux 6.17.2-1-pve
    29 verbose node v20.20.0
    30 verbose npm  v10.8.2
    31 verbose exit 1
    32 verbose code 1
    • R RikDRS
      @RikDRS
      NPM version: 10.8.2
      31 verbose exit 1
      32 verbose code 1
      #42
      @RikDRS sagte in zwave - Beta ioBroker.zwavews:
      Könnte sein, dass die Version nicht richtig veröffentlicht worden ist.
      Aber du musst deine Kiste auch auf nodejs@22 bringen.
      iob nodejs-update
      tut das für dich.
      R 1 Antwort Letzte Antwort
      • arteckA Offline
        arteckA Offline
        arteck
        #43
        was den für eine 0.1.11... die gibbet nicht..da ist wohl mein Finger zu schnell gewesen..
        die 0.0.12 ist die AKTUELLSTE..und im stable
        • malorossM maloross
          Bei mir laufen beide Adapter parallel, einmal im Testbereich, einmal im Produktivsystem. Ich kann von beiden Adaptern aus steuern, ohne dass Fehler gemeldet werden, Beeinträchtigungen konnte ich bisher nicht feststellen, habe aber Backup von beiden Sticks gemacht.
          BTW: das funktionert bei Z-UI wesentlich einfacher.
          arteckA Offline
          arteckA Offline
          arteck
          #44
          @maloross ja das geht ohne Probleme.. da der adapter die Daten poer WS abholt.. ist es egal wohin gepostet wird..oder von wo abgeholt wird
            iob nodejs-update
            tut das für dich.
            RikDRS
            #45
            iob nodejs-update
            tut das für dich.
            Danke - done
            • R RikDRS
              @maloross
              @maloross sagte in zwave - Beta ioBroker.zwavews:
              Soweit hab ich den Server jetzt eingerichtet. Sehr irritiert hat mich aber, dass mein Ersatz-Stick (der noch nicht zum Einsatz kam (!), alle aktuellen Geräte anzeigt. Sollte doch eigentlich leer sein oder was ist da los?
              das selbe habe ich hier auch: neuen Stick - noch nie in einem System aktive gewesen - installiert. Stick im Proxmox durchgereicht, Security Keys in zwave.js-ui eingetragen, und schwupps, alle Geräte erkannt - zwar alle als unknown, aber alle da... Anscheinend aber auch Geräte die es mal gab, aber jetzt nicht mehr existieren.
              Frage: wie wechsel ich denn nun auf den neuen Adapter? Die zwave2-Instanz de- und zwavews-Instanz aktivieren?
              RikDRS
              #46
              @arteck sagte in zwave - Beta ioBroker.zwavews:
              wie ist die "best pratice"?
              • arteckA Offline
                arteckA Offline
                arteck
                #47
                der zwave2 adapter kann ohne stick nicht laufen.. also ja das eine aus das andere an ..
                • malorossM Offline
                  malorossM Offline
                  maloross
                  #48
                  Ich habe ein merkwürdiges Phänomen, dass ich nicht nachvollziehen kann:
                  Im Adapter Zwave2 ist ein Gerät in der Liste, dass als erreichbar angezeigt wird und sich auch steuern lässt (RGBW Controller). Also bisher keine Probleme damit.
                  ABER: im Z-UI wird dieses Gerät als "dead" geführt und wird so natürlich nicht eingebunden. Das Gerät wird in der Liste der Geräte geführt, sollte also bekannt sein.
                  Stellt sich die Frage: wieso funktioniert das Gerät unter Zwav2 und kann man herausfinden, was da schiefläuft?
                  Auch Frauen können sich für Technik begeistern! ;)
                  Equipment:
                  diverse HM-, HMIP-, Aeotec- Tradfri- Sonos- und Fibaro-Geräte, NAS, Proxmox mit div. LXC,
                    arteckA Offline
                    arteckA Offline
                    arteck
                    #49
                    @maloross klapp das Gerät mal auf und mach
                    wenn immer noch dead dann
                    vielleicht hilfts.. sonst musst du ein Bug bei Z-UI einstellen
                    zu den Central Scenen im Schalter .. die da wird auch nix übertragen von Z-UI.. schein ein Bug zu sein.
                    • malorossM Offline
                      malorossM Offline
                      maloross
                      #50
                      Bisher haben auch die von dir oben angemerkten Aktionen keine Besserung gebracht - Issue ist erstellt.
                      Das mit dem Quad-Schalter wird vielleicht noch, zumindest steht das Gerät in der Liste der kompatiblen Geräte
                      Equipment:
                        arteckA Offline
                        arteckA Offline
                        arteck
                        #51
                        @maloross ich hab hier unterschiedliche Schalter.lund keiner sendet eine Message.
                        komisch ist das schon
                        wobei ich hab meine direkt mit dem Rollo verbunden .. ich weiss nicht wie zwave da reagiert
                        @alcalzone weisst du da was ?
                        • malorossM Offline
                          malorossM Offline
                          maloross
                          #52
                          @arteck Info zum Quadschalter: hier könnten fehlende Events evtl. daran liegen, dass er über Zwave2 mit dem "toten" Gerät verknüpft ist
                          Equipment:
                            arteckA Offline
                            arteckA Offline
                            arteck
                            #53
                            @maloross ne glaube nicht dass es daran liegt .. das ist wie bining im zigbee.. die Geräte quatschen direkt miteinander.. und kann sein dass die dann kein publish auf den coordinator machen.. somit auch kein event im DP
                            egal ob der empfangsnode da ist oder nicht
                            malorossM 1 Antwort Letzte Antwort
                            • arteckA arteck
                              malorossM Offline
                              malorossM Offline
                              maloross
                              #54
                              Ulei - konspirative Devices, der Untergang der Menschheit ist nah! ;)
                              Equipment:
                              • arteckA arteck
                                RikDRS
                                #55
                                habe nun auf dem Proxmox den ZWave-Stick auf den ZWave-js-ui durchgereicht & die Zwave2-Instanz de- und die Zwavews-Instanz aktiviert. Security-Keys übernommen. Soweit so gut. Alle Aktoren tauchen auf.
                                Das Problem was ich nun habe ist, das iOBroker die Objekte unter der Zwavews-Instanz nicht aktualisiert. Heißt: auf der ZWave-js-ui-Oberfläche kann ich Geräte steuern, aber nicht von iOBroker aus.
                                wo liegt mein Fehler?
                                  RikDRS
                                  #56
                                  @arteck & alle
                                  Danke für Deine & Eure Arbeit!
                                    RikDRS
                                    #57
                                    Habe nun vereinzelt unter den Zwavews-Objekten Nodes, welche "grün" sind.
                                    Versuche ich nun zB einen Switch dort zu schalten erhalte ich folgende Fehlermeldung:
                                    zwavews.0
                                    2026-02-05 04:42:00.548	error	<zwavews> error message -->> {"type":"result","success":false,"messageId":"1770262920545-deb555120f00b","errorCode":"zwave_error","zwaveErrorCode":-1,"zwaveErrorMessage":"unknown_error: TypeError: Cannot read properties of undefined (reading 'commandClass')\n at isValueID (file:///usr/lib/node_modules/zwave-js-ui/node_modules/@zwave-js/core/src/values/ValueDB.ts:43:19)\n at assertValueID (file:///usr/lib/node_modules/zwave-js-ui/node_modules/@zwave-js/core/src/values/ValueDB.ts:69:7)\n at normalizeValueID (file:///usr/lib/node_modules/zwave-js-ui/node_modules/@zwave-js/core/src/values/ValueDB.ts:84:2)\n at ZWaveNode.setValue (file:///usr/lib/node_modules/zwave-js-ui/node_modules/zwave-js/src/lib/node/Node.ts:477:13)\n at NodeMessageHandler.handle (file:///usr/lib/node_modules/zwave-js-ui/node_modules/@zwave-js/server/dist-esm/lib/node/message_handler.js:23:43)\n at Client.receiveMessage (file:///usr/lib/node_modules/zwave-js-ui/node_modules/@zwave-js/server/dist-esm/lib/server.js:132:100)\n at WebSocket.<anonymous> (file:///usr/lib/node_modules/zwave-js-ui/node_modules/@zwave-js/server/dist-esm/lib/server.js:55:45)\n at WebSocket.emit (node:events:519:28)\n at Receiver.receiverOnMessage (/usr/lib/node_modules/zwave-js-ui/node_modules/ws/lib/websocket.js:1225:20)\n at Receiver.emit (node:events:519:28)"}
                                    • arteckA Offline
                                      arteckA Offline
                                      arteck
                                      #58
                                      da stimmt was mit der Kommunikation nicht.. ich nehme mal an das hast du eingestellt
                                      mit das mqtt gateway
                                      • arteckA arteck
                                        @RikDRS das MQTT Gateway kannst aussschalten.. den WS Server brauchst du nur
                                        RikDRS
                                        #59
                                        sorry, aber inzwischen bin ich verwirrt ;)
                                        hier sagtest Du, ich benötige das MQTT nicht:
                                        jetzt benötige ich es doch?
                                        hier mal meine Einstellungen, ich habe in zwischen alles mögliche probiert
                                        Mqtt:
                                        Offensichtlich verbindet er sich, es gibt neue (Fehler-)Meldungen:
                                        Gateway:
                                        Home Assistant:
                                        Was mir auffällt: es gibt mindestes einen Aktor, der sich über die Objekte im iOBroker steuern lässt, aber eben auch welche, wo dies nicht funktioniert.
                                        Wenn ich per ZWave-js-ui den Aktor schalte, sehe ich die Änderung in den iOBroker-Objekten, von dort kann ich diesen Aktor aber nicht steuern
                                        Danke für Eure Geduld
                                        • malorossM Offline
                                          malorossM Offline
                                          maloross
                                          schrieb am zuletzt editiert von maloross
                                          #60
                                          Von @arteck habe ich weiter oben in Beitrag #46 49 bez. eines Knotens (der bei Z-UI als "dead" gekennzeichnet ist) zwei Tipps erhalten, diese schon probiert?
                                          Equipment:
