  4. RPI2 Adapter kann nicht installiert werden
    6.4k
167 Beiträge 11 Kommentatoren 13.2k Aufrufe 10 Beobachtet
  • G Gonzokalle
    @Homoran
    Habe es mal mit nodejs 22 probiert und neu gestartet.
    ioBroker nodejs fixer 2025-08-09
    You requested to install latest version from nodejs v22 tree.
    Your current setup is:
    /usr/bin/nodejs         v22.21.0
    /usr/bin/node           v22.21.0
    /usr/bin/npm            10.9.4
    /usr/bin/npx            10.9.4
    /usr/bin/corepack       0.34.0
    We found these nodejs versions available for installation:
    nodejs:
      Installed: 22.21.0-1nodesource1
      Candidate: 22.21.0-1nodesource1
      Version table:
     *** 22.21.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
            100 /var/lib/dpkg/status
         22.20.0-1nodesource1 1001
         22.19.0-1nodesource1 1001
         22.18.0-1nodesource1 1001
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         20.19.2+dfsg-1 500
            500 http://deb.debian.org/debian trixie/main arm64 Packages
    Nothing to do - Your installation is using the correct paths.
    You are running nodejs v22.21.0. Do you want to install latest version from nodejs v.22 tree?
    Press <y> to continue or any other key to quit
    Trying to fix your installation now. Please be patient.
    find: '/run/user/1000/doc': Permission denied
    find: '/run/user/1000/gvfs': Permission denied
    Stopping ioBroker now
    ioBroker has been stopped
    Removing dfsg-nodejs
    *** These repos are active on your system:
    Hit:1 http://deb.debian.org/debian trixie InRelease
    Hit:2 http://archive.raspberrypi.com/debian trixie InRelease
    Hit:3 http://deb.debian.org/debian trixie-updates InRelease
    Hit:4 http://deb.debian.org/debian-security trixie-security InRelease
    Reading package lists... Done
    *** Installing ca-certificates, curl and gnupg, just in case they are missing.
    *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
    deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_22.x nodistro main
    Package: nodejs
    Pin: origin deb.nodesource.com
    Pin-Priority: 1001
    *** These repos are active after the adjustments:
    Hit:1 http://archive.raspberrypi.com/debian trixie InRelease
    Hit:2 http://deb.debian.org/debian trixie InRelease
    Get:5 https://deb.nodesource.com/node_22.x nodistro InRelease [12.1 kB]
    Get:6 https://deb.nodesource.com/node_22.x nodistro/main armhf Packages [7375 B]
    Get:7 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages [8572 B]
    Fetched 28.1 kB in 0s (140 kB/s)
    W: https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
    Installing nodejs now!
    Installing latest nodejs v22 release
    SUCCESS!
    v22.21.0 has been installed! You are using the latest nodejs@22 release now!
    COMPATIBILITY CHECK IN PROGRESS (Only a --dry-run! No modules are really changed or added!)
    add usocket 0.3.0
    add unix-dgram 2.0.6
    add raw-socket 1.8.1
    add nan 2.19.0
    add number-is-nan 1.0.1
    add npmlog 4.1.2
    add node-gyp 7.1.2
    add rimraf 3.0.2
    add minimatch 3.1.2
    add glob 7.2.3
    add brace-expansion 1.1.12
    add net-ping 1.2.4
    add napi-thread-safe-callback 0.0.6
    add gauge 2.7.4
    add strip-ansi 3.0.1
    add string-width 1.0.2
    add signal-exit 3.0.7
    add is-fullwidth-code-point 1.0.0
    add ansi-regex 2.1.1
    add fsevents 2.3.3
    add es6-promise 4.2.8
    add env-paths 2.2.1
    add diskusage 1.2.0
    add cpu-features 0.0.10
    add code-point-at 1.1.0
    add buildcheck 0.0.7
    add authenticate-pam 1.0.5
    add are-we-there-yet 1.1.7
    add string_decoder 1.1.1
    add safe-buffer 5.1.2
    add readable-stream 2.3.8
    add @stoprocent/noble 1.19.1
    added 32 packages in 2s
    219 packages are looking for funding
      run `npm fund` for details
    We tried our best to fix your nodejs. Please run iob diag again to verify.
    *** RESTARTING ioBroker NOW! ***
     Please refresh or restart your browser in a few moments.
    martin@RaspberryPi-Iobroker:/opt/iobroker $ sudo reboot
    #81
    @Gonzokalle sagte in RPI2 Adapter kann nicht installiert werden:
    ohne vorher die node Version zu ändern?
    Das bringt nichts
    G 1 Antwort Letzte Antwort
      Das bringt nichts
      Gonzokalle
      #82
      @Homoran
      Ist das hier noch gültig um die nodejs auf Version 24 zu bringen?
      https://forum.iobroker.net/search?term=Update+NodeJS+best+practise&in=titles
      • G Gonzokalle
        @Homoran
        #83
        @Gonzokalle
        Mach es so:
        iob nodejs-update 24
          @Gonzokalle
          Mach es so:
          Gonzokalle
          #84
          @Thomas-Braun
          Den iobroker vorher stoppen?
          • G Gonzokalle
            @Thomas-Braun
            #85
            @Gonzokalle
            Kannste machen, macht der Befehl aber ohnehin selber.
              @Gonzokalle
              Gonzokalle
              schrieb am zuletzt editiert von Gonzokalle
              #86
              @Thomas-Braun
              Gut
              Ist scheinbar ohne Fehler durchgelaufen.
              Kann ich jetzt
              cd /opt/iobroker/ && npm i iobroker.rpi2@3.0.2 --debug
              probieren?
              You requested to install latest version from nodejs v24 tree.
              /usr/bin/npm            10.9.4
              /usr/bin/npx            10.9.4
              nodejs:
                Version table:
                   20.19.2+dfsg-1 500
              You are running nodejs v22.21.0. Do you want to install latest version from nodejs v.24 tree?
              Get:3 http://deb.debian.org/debian trixie-updates InRelease [47.3 kB]
              Fetched 47.3 kB in 0s (332 kB/s)
              deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_24.x nodistro main
              Package: nodejs
              Pin-Priority: 1001
              Get:5 https://deb.nodesource.com/node_24.x nodistro InRelease [12.1 kB]
              Get:6 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages [4879 B]
              Get:7 https://deb.nodesource.com/node_24.x nodistro/main armhf Packages [1369 B]
              Fetched 18.4 kB in 1s (33.1 kB/s)
              W: https://deb.nodesource.com/node_24.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
              Installing latest nodejs v24 release
              (Reading database ... 134042 files and directories currently installed.)
              Preparing to unpack .../nodejs_24.12.0-1nodesource1_arm64.deb ...
              Detected old npm client, removing...
              Unpacking nodejs (24.12.0-1nodesource1) over (22.21.0-1nodesource1) ...
              Setting up nodejs (24.12.0-1nodesource1) ...
              Processing triggers for man-db (2.13.1-1) ...
              SUCCESS!
              v24.12.0 has been installed! You are using the latest nodejs@24 release now!
              add usocket 0.3.0
              add nan 2.19.0
              add npmlog 4.1.2
              add node-gyp 7.1.2
              add rimraf 3.0.2
              add minimatch 3.1.2
              add glob 7.2.3
              add net-ping 1.2.4
              add gauge 2.7.4
              add env-paths 2.2.1
              add diskusage 1.2.0
              remove @csstools/css-tokenizer 3.0.4
              remove @csstools/css-parser-algorithms 3.0.5
              remove canvas 2.11.2
              added 31 packages, and removed 3 packages in 2s
              214 packages are looking for funding
              martin@RaspberryPi-Iobroker:~ $
              • G Gonzokalle
                @Thomas-Braun
                Gut
                Kann ich jetzt
                probieren?
                /usr/bin/npm            10.9.4
                /usr/bin/npx            10.9.4
                nodejs:
                  Version table:
                     20.19.2+dfsg-1 500
                Package: nodejs
                Pin-Priority: 1001
                SUCCESS!
                add usocket 0.3.0
                add nan 2.19.0
                add npmlog 4.1.2
                add node-gyp 7.1.2
                add rimraf 3.0.2
                add minimatch 3.1.2
                add glob 7.2.3
                add net-ping 1.2.4
                add gauge 2.7.4
                add env-paths 2.2.1
                add diskusage 1.2.0
                #87
                • G Gonzokalle
                  @Thomas-Braun
                  Gut
                  Kann ich jetzt
                  probieren?
                  /usr/bin/npm            10.9.4
                  /usr/bin/npx            10.9.4
                  nodejs:
                    Version table:
                       20.19.2+dfsg-1 500
                  Package: nodejs
                  Pin-Priority: 1001
                  SUCCESS!
                  add usocket 0.3.0
                  add nan 2.19.0
                  add npmlog 4.1.2
                  add node-gyp 7.1.2
                  add rimraf 3.0.2
                  add minimatch 3.1.2
                  add glob 7.2.3
                  add net-ping 1.2.4
                  add gauge 2.7.4
                  add env-paths 2.2.1
                  add diskusage 1.2.0
                  #88
                  cd /opt/iobroker/
                  npm i
                  iob status
                  Irgendein Adapter ist da auf einem alten Stand.
                  canvas fliegt raus. Schau mit
                  npm explain canvas
                  nach warum
                    Gonzokalle
                    #89
                    @Homoran
                    Sieht doch ganz gut aus.
                    ```bash
                    Script v.2025-08-09
                    *** BASE SYSTEM ***
                    Operating System: Debian GNU/Linux 13 (trixie)
                     Static hostname: RaspberryPi-Iobroker
                           Icon name: computer
                              Kernel: Linux 6.12.47+rpt-rpi-2712
                        Architecture: arm64
                    OS is similar to:
                    Model           : Raspberry Pi 5 Model B Rev 1.0
                    Docker          : false
                    Virtualization  : none
                    Kernel          : aarch64
                    Userland        : 64 bit
                    Systemuptime and Load:
                     15:20:50 up 22:21,  3 users,  load average: 0.53, 0.59, 0.53
                    CPU threads: 4
                    *** LIFE CYCLE STATUS ***
                    Operating System is the current Debian stable version codenamed 'trixie'!
                    *** RASPBERRY THROTTLING ***
                    Current issues:
                    Previously detected issues:
                    *** TIME AND TIMEZONES ***
                                   Local time: Sun 2025-12-28 15:20:50 CET
                               Universal time: Sun 2025-12-28 14:20:50 UTC
                                     RTC time: Sun 2025-12-28 14:20:50
                                  NTP service: active
                              RTC in local TZ: no
                    *** Users and Groups ***
                    User that called 'iob diag':
                    martin
                    HOME=/home/martin
                    GROUPS=martin adm dialout cdrom sudo audio video plugdev games users netdev gpio i2c spi render input iobroker
                    iobroker
                    HOME=/home/iobroker
                    SUDO_HOME=/home/martin
                    *** DISPLAY-SERVER SETUP ***
                    Display-Server:         true
                    Display-Manager:        * lightdm.service - Light Display Manager
                    Desktop:
                    Session:                tty
                    System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
                    *** MEMORY ***
                    Mem:            8.5G        3.5G        2.1G         57M        3.0G        4.9G
                    Swap:           2.1G          0B        2.1G
                    Total:           10G        3.5G        4.3G
                    Active iob-Instances:   30
                             8063 M total memory
                             3358 M used memory
                             3263 M active memory
                             2224 M inactive memory
                             2028 M free memory
                              305 M buffer memory
                             2511 M swap cache
                             2047 M total swap
                                0 M used swap
                             2047 M free swap
                    top - 15:20:51 up 22:21,  3 users,  load average: 0.53, 0.59, 0.53
                    Tasks: 248 total,   1 running, 247 sleeping,   0 stopped,   0 zombie
                    %Cpu(s): 11.9 us,  2.4 sy,  0.0 ni, 85.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                    MiB Mem :   8063.0 total,   2023.0 free,   3364.2 used,   2817.4 buff/cache
                    MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.   4698.9 avail Mem
                    *** FAILED SERVICES ***
                    0 loaded units listed.
                    *** DMESG CRITICAL ERRORS ***
                    No critical errors detected
                    *** FILESYSTEM ***
                    udev           devtmpfs  3.9G     0  3.9G   0% /dev
                    tmpfs          tmpfs     1.6G   15M  1.6G   1% /run
                    /dev/nvme0n1p2 ext4      917G   11G  869G   2% /
                    tmpfs          tmpfs     4.0G  368K  4.0G   1% /dev/shm
                    tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
                    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
                    tmpfs          tmpfs     4.0G   19M  4.0G   1% /tmp
                    /dev/nvme0n1p1 vfat      510M   86M  425M  17% /boot/firmware
                    tmpfs          tmpfs     807M  256K  807M   1% /run/user/1000
                    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
                    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/serial-getty@ttyAMA10.service
                    [Sat Dec 27 16:58:55 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0  numa=fake=8 system_heap.max_order=0 iommu_dma_numa_policy=interleave smsc95xx.macaddr=2C:CF:67:82:17:A3 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=e4c2f3ef-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
                    [Sat Dec 27 16:58:56 2025] EXT4-fs (nvme0n1p2): orphan cleanup on readonly fs
                    [Sat Dec 27 16:58:56 2025] EXT4-fs (nvme0n1p2): mounted filesystem d6944274-f2f7-4644-96a4-213c3b367f5c ro with ordered data mode. Quota mode: none.
                    [Sat Dec 27 16:58:57 2025] EXT4-fs (nvme0n1p2): re-mounted d6944274-f2f7-4644-96a4-213c3b367f5c r/w.
                    Show mounted filesystems:
                    TARGET           SOURCE         FSTYPE OPTIONS
                    /                /dev/nvme0n1p2 ext4   rw,noatime
                    `-/boot/firmware /dev/nvme0n1p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                    /var:
                    2.5G    /var/
                    251M    /var/cache
                    238M    /var/cache/apt
                    221M    /var/lib
                    154M    /var/lib/apt
                    Archived and active journals take up 8M in the file system.
                    /opt/iobroker/backups:
                    98M     /opt/iobroker/backups/
                    /opt/iobroker/iobroker-data:
                    988M    /opt/iobroker/iobroker-data/
                    496M    /opt/iobroker/iobroker-data/history
                    319M    /opt/iobroker/iobroker-data/files
                    124M    /opt/iobroker/iobroker-data/backup-objects
                    67M     /opt/iobroker/iobroker-data/files/echarts.admin
                    42M     /opt/iobroker/iobroker-data/objects.jsonl
                    26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
                    26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
                    24M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.70a15e1f.js.map
                    18M     /opt/iobroker/iobroker-data/files/echarts/preview/static/js/main.5fe9c7da.js.map
                    USB-Devices by-id:
                    /dev/serial/by-id/usb-SHK_JeeLink_LaCrosse-if00-port0
                    /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2469419-if00
                    *** ZigBee Settings ***
                    HINT:
                    Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                    zigbee.X
                    Extended Pan ID:
                    *** MASKED ***
                    Pan ID:
                    *** MASKED ***
                    Channel:
                    *** MASKED ***
                    Network Key:
                    *** MASKED ***
                    *** NodeJS-Installation ***
                    /usr/bin/nodejs         v24.12.0
                    /usr/bin/node           v24.12.0
                    /usr/bin/npm            11.6.2
                    /usr/bin/npx            11.6.2
                    /usr/bin/corepack       0.34.5
                    nodejs:
                      Installed: 24.12.0-1nodesource1
                      Candidate: 24.12.0-1nodesource1
                      Version table:
                     *** 24.12.0-1nodesource1 1001
                            500 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages
                         24.11.1-1nodesource1 1001
                         24.11.0-1nodesource1 1001
                         24.10.0-1nodesource1 1001
                         24.9.0-1nodesource1 1001
                         24.8.0-1nodesource1 1001
                         24.7.0-1nodesource1 1001
                         24.6.0-1nodesource1 1001
                         24.5.0-1nodesource1 1001
                         24.4.1-1nodesource1 1001
                         24.4.0-1nodesource1 1001
                         24.3.0-1nodesource1 1001
                         24.1.0-1nodesource1 1001
                         24.0.2-1nodesource1 1001
                         24.0.1-1nodesource1 1001
                         24.0.0-1nodesource1 1001
                         20.19.2+dfsg-1 500
                    No problems detected
                    Errors in npm tree: 0
                    *** ioBroker-Installation ***
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    Hosts:
                    RaspberryPi-Iobroker RaspberryPi-Iobroker (version: 7.0.7, hostname: RaspberryPi-Iobroker, alive, uptime: 7712)
                    Core adapters versions
                    js-controller:  7.0.7
                    admin:          7.7.19
                    javascript:     9.0.11
                    nodejs modules from github:     1
                    +-- iobroker.eusec@2.0.3 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.eusec.git#f625cbb12aea40dcf6faf11a17d93328f069b753)
                    Adapter State
                    + system.adapter.admin.0                  : admin                 : RaspberryPi-Iobroker                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                    + system.adapter.alexa2.0                 : alexa2                : RaspberryPi-Iobroker                     -  enabled
                    + system.adapter.backitup.0               : backitup              : RaspberryPi-Iobroker                     -  enabled
                    + system.adapter.device-watcher.0         : device-watcher        : RaspberryPi-Iobroker                     -  enabled
                      system.adapter.devices.0                : devices               : RaspberryPi-Iobroker                     - disabled
                    + system.adapter.echarts.0                : echarts               : RaspberryPi-Iobroker                     -  enabled
                    + system.adapter.energiefluss.0           : energiefluss          : RaspberryPi-Iobroker                     -  enabled
                    + system.adapter.eusec.0                  : eusec                 : RaspberryPi-Iobroker                     -  enabled
                      system.adapter.flot.0                   : flot                  : RaspberryPi-Iobroker                     - disabled
                    + system.adapter.fullybrowser.0           : fullybrowser          : RaspberryPi-Iobroker                     -  enabled
                    + system.adapter.history.0                : history               : RaspberryPi-Iobroker                     -  enabled
                      system.adapter.icons-icons8.0           : icons-icons8          : RaspberryPi-Iobroker                     - disabled
                    + system.adapter.iot.0                    : iot                   : RaspberryPi-Iobroker                     -  enabled
                    + system.adapter.iqontrol.0               : iqontrol              : RaspberryPi-Iobroker                     -  enabled
                    + system.adapter.iqontrol.1               : iqontrol              : RaspberryPi-Iobroker                     -  enabled
                    + system.adapter.javascript.0             : javascript            : RaspberryPi-Iobroker                     -  enabled
                    + system.adapter.jeelink.0                : jeelink               : RaspberryPi-Iobroker                     -  enabled
                    + system.adapter.mqtt.0                   : mqtt                  : RaspberryPi-Iobroker                     -  enabled, port: 1884, bind: 0.0.0.0
                      system.adapter.netatmo-crawler.0        : netatmo-crawler       : RaspberryPi-Iobroker                     -  enabled
                    + system.adapter.opendtu.0                : opendtu               : RaspberryPi-Iobroker                     -  enabled
                    + system.adapter.opendtu.1                : opendtu               : RaspberryPi-Iobroker                     -  enabled
                    + system.adapter.radar2.0                 : radar2                : RaspberryPi-Iobroker                     -  enabled
                    + system.adapter.reolink.0                : reolink               : RaspberryPi-Iobroker                     -  enabled
                    + system.adapter.reolink.1                : reolink               : RaspberryPi-Iobroker                     -  enabled
                      system.adapter.reolink.2                : reolink               : RaspberryPi-Iobroker                     - disabled
                    + system.adapter.reolink.3                : reolink               : RaspberryPi-Iobroker                     -  enabled
                    + system.adapter.shelly.0                 : shelly                : RaspberryPi-Iobroker                     -  enabled, port: 1882, bind: 0.0.0.0
                    + system.adapter.smartgarden.0            : smartgarden           : RaspberryPi-Iobroker                     -  enabled
                    + system.adapter.sonoff.0                 : sonoff                : RaspberryPi-Iobroker                     -  enabled, port: 1883, bind: 0.0.0.0
                    + system.adapter.telegram.0               : telegram              : RaspberryPi-Iobroker                     -  enabled, port: 8443, bind: 0.0.0.0
                    + system.adapter.terminal.0               : terminal              : RaspberryPi-Iobroker                     -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
                    + system.adapter.web.0                    : web                   : RaspberryPi-Iobroker                     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                    + system.adapter.wled.0                   : wled                  : RaspberryPi-Iobroker                     -  enabled
                    + system.adapter.zigbee.0                 : zigbee                : RaspberryPi-Iobroker                     -  enabled, port: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2469419-if00
                    + instance is alive
                    ioBroker-Repositories
                    Active repo(s): stable
                    Upgrade policy: none
                    Installed ioBroker-Adapters
                    Used repository: stable
                    Adapter    "admin"        : 7.7.19   , installed 7.7.19
                    Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
                    Adapter    "backitup"     : 3.3.10   , installed 3.3.10
                    Adapter    "device-watcher": 2.13.1  , installed 2.13.1
                    Adapter    "devices"      : 1.2.8    , installed 1.2.8
                    Adapter    "echarts"      : 1.9.2    , installed 1.9.2
                    Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
                    Adapter    "eusec"        : 2.0.3    , installed 2.0.3
                    Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
                    Adapter    "iot"          : 5.0.7    , installed 5.0.7
                    Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
                    Adapter    "javascript"   : 9.0.11   , installed 9.0.11
                    Adapter    "jeelink"      : 1.2.5    , installed 1.2.5
                    Controller "js-controller": 7.0.7    , installed 7.0.7
                    Adapter    "mqtt"         : 6.1.4    , installed 6.1.4
                    Adapter    "netatmo-crawler": 1.1.0  , installed 1.1.0
                    Adapter    "opendtu"      : 3.1.0    , installed 3.1.0
                    Adapter    "radar2"       : 2.4.0    , installed 2.4.0
                    Adapter    "reolink"      : 1.2.3    , installed 1.2.3
                    Adapter    "shelly"       : 10.4.1   , installed 10.4.1
                    Adapter    "smartgarden"  : 2.0.1    , installed 2.0.1
                    Adapter    "socketio"     : 6.7.1    , installed 7.0.8
                    Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
                    Adapter    "terminal"     : 1.0.0    , installed 1.0.0
                    Adapter    "web"          : 7.0.8    , installed 7.0.8
                    Adapter    "wled"         : 0.7.2    , installed 0.7.2
                    Adapter    "ws"           : 2.6.2    , installed 3.0.19
                    Adapter    "zigbee"       : 3.1.5    , installed 3.2.5
                    Objects and States
                    Objects:        6945
                    States:         5883
                    Hit:5 https://deb.nodesource.com/node_24.x nodistro InRelease
                    Pending Updates: 0
                    *** Listening Ports ***
                    tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       1679096    51906/io.mqtt.0
                    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       1679168    51999/io.shelly.0
                    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       1681214    52018/io.sonoff.0
                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       1679520    51393/iobroker.js-c
                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       1679525    51393/iobroker.js-c
                    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          589619     18907/cupsd
                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          10440      1000/sshd: /usr/sbi
                    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          4716       1/init
                    tcp6       0      0 :::1984                 :::*                    LISTEN      1001       1681677    51883/go2rtc
                    tcp6       0      0 :::5900                 :::*                    LISTEN      985        8967       1014/wayvnc
                    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          589618     18907/cupsd
                    tcp6       0      0 :::8554                 :::*                    LISTEN      1001       1679923    51883/go2rtc
                    tcp6       0      0 :::8555                 :::*                    LISTEN      1001       1681679    51883/go2rtc
                    tcp6       0      0 :::21                   :::*                    LISTEN      0          8913       1001/vsftpd
                    tcp6       0      0 :::22                   :::*                    LISTEN      0          10442      1000/sshd: /usr/sbi
                    tcp6       0      0 :::111                  :::*                    LISTEN      0          138        1/init
                    tcp6       0      0 :::8088                 :::*                    LISTEN      1001       1682622    52264/io.terminal.0
                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       1679579    51415/io.admin.0
                    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       1683698    52283/io.web.0
                    tcp6       0      0 :::3000                 :::*                    LISTEN      1001       1681715    51891/io.fullybrows
                    udp        0      0 0.0.0.0:49674           0.0.0.0:*                           101        769        710/avahi-daemon: r
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       1682326    52303/io.wled.0
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           101        767        710/avahi-daemon: r
                    udp        0      0 0.0.0.0:35232           0.0.0.0:*                           1001       1681024    51868/io.eusec.0
                    udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       1681089    51951/io.radar2.0
                    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          137        1/init
                    udp6       0      0 :::5353                 :::*                                101        768        710/avahi-daemon: r
                    udp6       0      0 :::48540                :::*                                101        770        710/avahi-daemon: r
                    udp6       0      0 :::111                  :::*                                0          4717       1/init
                    udp6       0      0 :::8555                 :::*                                1001       1681680    51883/go2rtc
                    2025-12-28 15:19:31.127  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: WR2000 ist noch gesperrt
                    2025-12-28 15:19:41.213  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: 14 ▫ 13<>15 ▫ 14
                    2025-12-28 15:19:41.213  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: keine Änderung, Limit WR2000 bleibt gleich
                    2025-12-28 15:19:51.098  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: WR600 auf 34% (200W)
                    2025-12-28 15:19:51.098  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: 14 ▫ 13<>15 ▫ 15
                    2025-12-28 15:19:51.098  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: keine Änderung, Limit WR2000 bleibt gleich
                    2025-12-28 15:20:01.124  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: 15 ▫ 14<>17 ▫ 14
                    2025-12-28 15:20:01.124  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: keine Änderung, Limit WR2000 bleibt gleich
                    2025-12-28 15:20:11.163  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: 14 ▫ 13<>15 ▫ 15
                    2025-12-28 15:20:11.163  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: keine Änderung, Limit WR2000 bleibt gleich
                    2025-12-28 15:20:21.095  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: 14 ▫ 13<>15 ▫ 16
                    2025-12-28 15:20:31.167  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: 16 ▫ 14<>18 ▫ 16
                    2025-12-28 15:20:31.167  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: keine Änderung, Limit WR2000 bleibt gleich
                    2025-12-28 15:20:41.125  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: 16 ▫ 14<>18 ▫ 14
                    2025-12-28 15:20:41.125  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: keine Änderung, Limit WR2000 bleibt gleich
                    2025-12-28 15:20:49.009  - info: host.RaspberryPi-Iobroker instance system.adapter.netatmo-crawler.0 in version "1.1.0" started with pid 57839
                    2025-12-28 15:20:51.177  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: 16 ▫ 14<>18 ▫ 14
                    2025-12-28 15:20:51.178  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: keine Änderung, Limit WR2000 bleibt gleich
                    2025-12-28 15:21:01.159  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: 16 ▫ 14<>18 ▫ 14
                    2025-12-28 15:21:01.159  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: keine Änderung, Limit WR2000 bleibt gleich
                    2025-12-28 15:21:01.601  - info: host.RaspberryPi-Iobroker instance system.adapter.netatmo-crawler.0 having pid 57839 terminated with code 0 (NO_ERROR)
                    2025-12-28 15:21:11.348  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: 16 ▫ 14<>18 ▫ 14
                    2025-12-28 15:21:11.348  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: keine Änderung, Limit WR2000 bleibt gleich
                    2025-12-28 15:21:21.491  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: 16 ▫ 14<>18 ▫ 15
                    2025-12-28 15:21:21.491  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: keine Änderung, Limit WR2000 bleibt gleich
                    iob diag has finished.
                      cd /opt/iobroker/
                      npm i
                      iob status
                      npm explain canvas
                      nach warum
                      Gonzokalle
                      #90
                      @Thomas-Braun
                      martin@RaspberryPi-Iobroker:/opt/iobroker $ npm explain canvas
                      npm error No dependencies found matching canvas
                      npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-12-28T14_23_22_531Z-debug-0.log
                      • G Gonzokalle
                        @Homoran
                        ```bash
                        Script v.2025-08-09
                        *** BASE SYSTEM ***
                               Icon name: computer
                            Architecture: arm64
                        OS is similar to:
                        Docker          : false
                        Kernel          : aarch64
                        Userland        : 64 bit
                        CPU threads: 4
                        Current issues:
                                      NTP service: active
                                  RTC in local TZ: no
                        martin
                        HOME=/home/martin
                        iobroker
                        HOME=/home/iobroker
                        Desktop:
                        Session:                tty
                        *** MEMORY ***
                        Swap:           2.1G          0B        2.1G
                                 8063 M total memory
                                 3358 M used memory
                                 2028 M free memory
                                  305 M buffer memory
                                 2511 M swap cache
                                 2047 M total swap
                                    0 M used swap
                                 2047 M free swap
                        *** FILESYSTEM ***
                        /var:
                        2.5G    /var/
                        251M    /var/cache
                        238M    /var/cache/apt
                        221M    /var/lib
                        154M    /var/lib/apt
                        USB-Devices by-id:
                        HINT:
                        zigbee.X
                        Extended Pan ID:
                        *** MASKED ***
                        Pan ID:
                        *** MASKED ***
                        Channel:
                        *** MASKED ***
                        Network Key:
                        *** MASKED ***
                        /usr/bin/npm            11.6.2
                        /usr/bin/npx            11.6.2
                        nodejs:
                          Version table:
                             20.19.2+dfsg-1 500
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Hosts:
                        admin:          7.7.19
                        javascript:     9.0.11
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects:        6945
                        States:         5883
                        Pending Updates: 0
                        #91
                        Stell das auf Kommandozeilenbetrieb (multi-user) um.
                        Mit dem Dateisystem stimmt was nicht. Es sollten keine orphans beseitigt werden müssen. Nicht bei einem sauberen Bootvorgang.
                        Installier den eusec-Adapter nochmal aus dem Repo, nicht aus dem GitHub.
                        Mach das Null_2_WR_autoSperre-Skript weniger geschwätzig. Das kübelt dir ja das komplette Log dicht.
                        • G Gonzokalle
                          @Homoran
                          ```bash
                          Script v.2025-08-09
                          *** BASE SYSTEM ***
                                 Icon name: computer
                              Architecture: arm64
                          OS is similar to:
                          Docker          : false
                          Kernel          : aarch64
                          Userland        : 64 bit
                          CPU threads: 4
                          Current issues:
                                        NTP service: active
                                    RTC in local TZ: no
                          martin
                          HOME=/home/martin
                          iobroker
                          HOME=/home/iobroker
                          Desktop:
                          Session:                tty
                          *** MEMORY ***
                          Swap:           2.1G          0B        2.1G
                                   8063 M total memory
                                   3358 M used memory
                                   2028 M free memory
                                    305 M buffer memory
                                   2511 M swap cache
                                   2047 M total swap
                                      0 M used swap
                                   2047 M free swap
                          *** FILESYSTEM ***
                          /var:
                          2.5G    /var/
                          251M    /var/cache
                          238M    /var/cache/apt
                          221M    /var/lib
                          154M    /var/lib/apt
                          USB-Devices by-id:
                          HINT:
                          zigbee.X
                          Extended Pan ID:
                          *** MASKED ***
                          Pan ID:
                          *** MASKED ***
                          Channel:
                          *** MASKED ***
                          Network Key:
                          *** MASKED ***
                          /usr/bin/npm            11.6.2
                          /usr/bin/npx            11.6.2
                          nodejs:
                            Version table:
                               20.19.2+dfsg-1 500
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          Hosts:
                          admin:          7.7.19
                          javascript:     9.0.11
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        6945
                          States:         5883
                          Pending Updates: 0
                          #92
                          was nodejs v24 angeht, ja!
                          aber
                          den brauchst du nur, wenn daran eine visu direkt am Server gezeigt werden soll
                          stell das um, das verhindert mögliche Probleme.
                          und am schlimmsten
                          De7n Dateisystem hat einen Schuss!
                          womöglich kommen deine Probleme daher
                            Gonzokalle
                            #93
                            @Thomas-Braun
                            Desktop ist aus
                            Eusec ist aus dem Repo
                            Log ausgeschaltet
                            ```bash
                            Script v.2025-08-09
                            *** BASE SYSTEM ***
                                   Icon name: computer
                                Architecture: arm64
                            OS is similar to:
                            Docker          : false
                            Kernel          : aarch64
                            Userland        : 64 bit
                             16:31:10 up 15 min,  2 users,  load average: 1.62, 0.64, 0.33
                            CPU threads: 4
                            Current issues:
                                           Local time: Sun 2025-12-28 16:31:10 CET
                                       Universal time: Sun 2025-12-28 15:31:10 UTC
                                             RTC time: Sun 2025-12-28 15:31:10
                                          NTP service: active
                                      RTC in local TZ: no
                            martin
                            HOME=/home/martin
                            iobroker
                            HOME=/home/iobroker
                            Display-Server:         false
                            Desktop:
                            Session:                tty
                            *** MEMORY ***
                            Mem:            8.5G        3.2G        4.2G         26M        1.2G        5.3G
                            Swap:           2.1G          0B        2.1G
                            Total:           10G        3.2G        6.3G
                                     8063 M total memory
                                     3021 M used memory
                                     2865 M active memory
                                      758 M inactive memory
                                     3985 M free memory
                                      131 M buffer memory
                                     1035 M swap cache
                                     2047 M total swap
                                        0 M used swap
                                     2047 M free swap
                            top - 16:31:10 up 15 min,  2 users,  load average: 1.62, 0.64, 0.33
                            Tasks: 221 total,   2 running, 219 sleeping,   0 stopped,   0 zombie
                            %Cpu(s): 25.0 us,  6.8 sy,  0.0 ni, 65.9 id,  0.0 wa,  0.0 hi,  2.3 si,  0.0 st
                            MiB Mem :   8063.0 total,   3984.8 free,   3022.7 used,   1167.7 buff/cache
                            MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.   5040.3 avail Mem
                            *** FILESYSTEM ***
                            tmpfs          tmpfs     1.6G   16M  1.6G   1% /run
                            tmpfs          tmpfs     4.0G   32K  4.0G   1% /dev/shm
                            tmpfs          tmpfs     4.0G  9.3M  4.0G   1% /tmp
                            tmpfs          tmpfs     807M  240K  807M   1% /run/user/1000
                            [Sun Dec 28 16:16:07 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0  numa=fake=8 system_heap.max_order=0 iommu_dma_numa_policy=interleave smsc95xx.macaddr=2C:CF:67:82:17:A3 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=e4c2f3ef-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
                            [Sun Dec 28 16:16:09 2025] EXT4-fs (nvme0n1p2): orphan cleanup on readonly fs
                            [Sun Dec 28 16:16:09 2025] EXT4-fs (nvme0n1p2): mounted filesystem d6944274-f2f7-4644-96a4-213c3b367f5c ro with ordered data mode. Quota mode: none.
                            [Sun Dec 28 16:16:09 2025] EXT4-fs (nvme0n1p2): re-mounted d6944274-f2f7-4644-96a4-213c3b367f5c r/w.
                            /var:
                            2.5G    /var/
                            251M    /var/cache
                            238M    /var/cache/apt
                            221M    /var/lib
                            154M    /var/lib/apt
                            Archived and active journals take up 9.3M in the file system.
                            982M    /opt/iobroker/iobroker-data/
                            35M     /opt/iobroker/iobroker-data/objects.jsonl
                            USB-Devices by-id:
                            HINT:
                            zigbee.X
                            Extended Pan ID:
                            *** MASKED ***
                            Pan ID:
                            *** MASKED ***
                            Channel:
                            *** MASKED ***
                            Network Key:
                            *** MASKED ***
                            /usr/bin/npm            11.6.2
                            /usr/bin/npx            11.6.2
                            nodejs:
                              Version table:
                                 20.19.2+dfsg-1 500
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            Hosts:
                            RaspberryPi-Iobroker RaspberryPi-Iobroker (version: 7.0.7, hostname: RaspberryPi-Iobroker, alive, uptime: 902)
                            admin:          7.7.19
                            javascript:     9.0.11
                            nodejs modules from github:     0
                            Adapter State
                            + instance is alive
                            Objects and States
                            Objects:        6930
                            States:         5930
                            Pending Updates: 0
                            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       10519      958/iobroker.js-con
                            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       10514      958/iobroker.js-con
                            tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          9375       957/cupsd
                            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          4355       1/init
                            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11285      980/sshd: /usr/sbin
                            tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       12414      1705/io.shelly.0
                            tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       14349      1725/io.sonoff.0
                            tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       11224      1613/io.mqtt.0
                            tcp6       0      0 :::3000                 :::*                    LISTEN      1001       11205      1598/io.fullybrowse
                            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       12958      1993/io.web.0
                            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       11398      1033/io.admin.0
                            tcp6       0      0 :::8088                 :::*                    LISTEN      1001       12911      1973/io.terminal.0
                            tcp6       0      0 :::111                  :::*                    LISTEN      0          4356       1/init
                            tcp6       0      0 :::22                   :::*                    LISTEN      0          11293      980/sshd: /usr/sbin
                            tcp6       0      0 :::21                   :::*                    LISTEN      0          9142       968/vsftpd
                            tcp6       0      0 :::8554                 :::*                    LISTEN      1001       11179      1589/go2rtc
                            tcp6       0      0 :::8555                 :::*                    LISTEN      1001       11180      1589/go2rtc
                            tcp6       0      0 :::5900                 :::*                    LISTEN      985        7569       1001/wayvnc
                            tcp6       0      0 :::1984                 :::*                    LISTEN      1001       8133       1589/go2rtc
                            tcp6       0      0 ::1:631                 :::*                    LISTEN      0          9374       957/cupsd
                            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       12986      2011/io.wled.0
                            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           101        7190       712/avahi-daemon: r
                            udp        0      0 0.0.0.0:36000           0.0.0.0:*                           101        7192       712/avahi-daemon: r
                            udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       11994      1662/io.radar2.0
                            udp        0      0 0.0.0.0:32838           0.0.0.0:*                           1001       11176      1574/io.eusec.0
                            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          444        1/init
                            udp6       0      0 :::5353                 :::*                                101        7191       712/avahi-daemon: r
                            udp6       0      0 :::111                  :::*                                0          445        1/init
                            udp6       0      0 :::8555                 :::*                                1001       11181      1589/go2rtc
                            udp6       0      0 :::41681                :::*                                101        7193       712/avahi-daemon: r
                            2025-12-28 16:20:49.009  - info: host.RaspberryPi-Iobroker instance system.adapter.netatmo-crawler.0 in version "1.1.0" started with pid 2171
                            2025-12-28 16:20:53.255  - info: javascript.0 (1169) script.js.Temperaturen_&_Luftfeuchtigkeit.Temp_Terrasse_Status_an_Telegram: telegram: 🌡️ Terrasse unter 5°C
                            2025-12-28 16:20:59.220  - info: host.RaspberryPi-Iobroker instance system.adapter.netatmo-crawler.0 having pid 2171 terminated with code 0 (NO_ERROR)
                            2025-12-28 16:21:55.020  - warn: radar2.0 (1662) scanDelay increased to 116.421 seconds, delayAway to 5 minutes!
                            2025-12-28 16:25:49.009  - info: host.RaspberryPi-Iobroker instance system.adapter.netatmo-crawler.0 in version "1.1.0" started with pid 2871
                            2025-12-28 16:25:55.257  - info: host.RaspberryPi-Iobroker instance system.adapter.netatmo-crawler.0 having pid 2871 terminated with code 0 (NO_ERROR)
                            2025-12-28 16:28:21.781  - info: device-watcher.0 (1554) Das folgende Gerät ist nicht mehr erreichbar:
                            Zigbee:  Licht Terrasse (16:17)
                            2025-12-28 16:30:01.968  - info: device-watcher.0 (1554) Das folgende Gerät ist nicht mehr erreichbar:
                            WLED:  WLED-Matrix-2 (16:18)
                            2025-12-28 16:30:02.060  - info: device-watcher.0 (1554) Das folgende Gerät ist nicht mehr erreichbar:
                            WLED:  WLED-Stab-1 (330 Tage)
                            2025-12-28 16:30:02.120  - info: device-watcher.0 (1554) Das folgende Gerät ist nicht mehr erreichbar:
                            WLED:  WLED-Dachrinne (16:18)
                            2025-12-28 16:30:02.173  - info: device-watcher.0 (1554) Das folgende Gerät ist nicht mehr erreichbar:
                            WLED:  WLED-Hütte (169 Tage)
                            2025-12-28 16:30:02.229  - info: device-watcher.0 (1554) Das folgende Gerät ist nicht mehr erreichbar:
                            WLED:  WLED-Matrix-1 (16:18)
                            2025-12-28 16:30:02.283  - info: device-watcher.0 (1554) Das folgende Gerät ist nicht mehr erreichbar:
                            WLED:  WLED-Stab-2 (330 Tage)
                            2025-12-28 16:30:07.398  - info: device-watcher.0 (1554) Das folgende Gerät ist nicht mehr erreichbar:
                            WLED:  WLED-SoundReactive (528 Tage)
                            2025-12-28 16:30:49.009  - info: host.RaspberryPi-Iobroker instance system.adapter.netatmo-crawler.0 in version "1.1.0" started with pid 3660
                            2025-12-28 16:30:52.090  - info: javascript.0 (1169) script.js.Temperaturen_&_Luftfeuchtigkeit.Temp_Terrasse_Status_an_Telegram: telegram: 🌡️ Terrasse unter 0°C
                            2025-12-28 16:31:00.387  - info: host.RaspberryPi-Iobroker instance system.adapter.netatmo-crawler.0 having pid 3660 terminated with code 0 (NO_ERROR)
                            • G Gonzokalle
                              @Thomas-Braun
                              Desktop ist aus
                              Log ausgeschaltet
                              ```bash
                              Script v.2025-08-09
                              *** BASE SYSTEM ***
                                     Icon name: computer
                                  Architecture: arm64
                              OS is similar to:
                              Docker          : false
                              Kernel          : aarch64
                              Userland        : 64 bit
                              CPU threads: 4
                              Current issues:
                                            NTP service: active
                                        RTC in local TZ: no
                              martin
                              HOME=/home/martin
                              iobroker
                              HOME=/home/iobroker
                              Desktop:
                              Session:                tty
                              *** MEMORY ***
                              Swap:           2.1G          0B        2.1G
                                       8063 M total memory
                                       3021 M used memory
                                       3985 M free memory
                                        131 M buffer memory
                                       1035 M swap cache
                                       2047 M total swap
                                          0 M used swap
                                       2047 M free swap
                              *** FILESYSTEM ***
                              /var:
                              2.5G    /var/
                              251M    /var/cache
                              238M    /var/cache/apt
                              221M    /var/lib
                              154M    /var/lib/apt
                              USB-Devices by-id:
                              HINT:
                              zigbee.X
                              Extended Pan ID:
                              *** MASKED ***
                              Pan ID:
                              *** MASKED ***
                              Channel:
                              *** MASKED ***
                              Network Key:
                              *** MASKED ***
                              /usr/bin/npm            11.6.2
                              /usr/bin/npx            11.6.2
                              nodejs:
                                Version table:
                                   20.19.2+dfsg-1 500
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              Hosts:
                              admin:          7.7.19
                              javascript:     9.0.11
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects:        6930
                              States:         5930
                              Pending Updates: 0
                              #94
                              Ganz frischer Eintrag. Wenn du sauber gebootet hast, dann darf diese Meldung auf einem gesunden Datenträger nicht erscheinen.
                              Das ist dann ein starker Hinweis auf einen Defekt.
                              HINT:
                              Wird ein 'false positive' sein, ich sehe nur nicht warum. Den Code habe ich aber in einer kommenden Version von iob diag an der Stelle geändert.
                              Jetzt installier den rpi2 mal:
                               iobroker url iobroker.rpi2@latest  --debug
                              Edit: Sollte dann so aussehen:
                              echad@chet:/opt/iobroker $ iobroker url iobroker.rpi2@latest --debug
                              install iobroker.rpi2@latest
                              NPM version: 11.6.2
                              Installing iobroker.rpi2@latest... (System call)
                              up to date in 9s
                              254 packages are looking for funding
                              upload [13] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/de/translations.json i18n/de/translations.json application/json
                              upload [12] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/en/translations.json i18n/en/translations.json application/json
                              upload [11] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/es/translations.json i18n/es/translations.json application/json
                              upload [10] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                              upload [9] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/it/translations.json i18n/it/translations.json application/json
                              upload [8] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                              upload [7] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                              upload [6] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                              upload [5] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                              upload [4] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                              upload [3] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                              upload [2] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/jsonConfig.json jsonConfig.json application/json
                              upload [1] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/rpi2.png rpi2.png image/png
                              upload [0] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/words.js words.js application/javascript
                              Updating objects from io-package.json for adapter "rpi2" with version "3.0.2"
                                HINT:
                                NPM version: 11.6.2
                                up to date in 9s
                                Gonzokalle
                                #95
                                @Thomas-Braun sagte in RPI2 Adapter kann nicht installiert werden:
                                Ich hatte mit sudo reboot neu gestartet. Kann daher der Eintrag kommen?
                                Das sieht wieder schlecht aus.
                                Vielleicht sollte ich Trixie einfach nochmal neu aufspielen.
                                martin@RaspberryPi-Iobroker:~ $  iobroker url iobroker.rpi2@latest  --debug
                                NPM version: 11.6.2
                                npm warn deprecated npmlog@4.1.2: This package is no longer supported.
                                npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supported
                                npm warn deprecated are-we-there-yet@1.1.7: This package is no longer supported.
                                npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
                                npm warn deprecated gauge@2.7.4: This package is no longer supported.
                                > iobroker.rpi2@3.0.2 preinstall
                                > bash ./preinstall-check.sh
                                Checking package: libgpiod-dev >= 2.2
                                libgpiod-dev version OK: 2.2.1-2+deb13u1
                                > @stoprocent/bluetooth-hci-socket@1.5.2 install
                                > node-gyp-build
                                > @stoprocent/noble@1.19.1 install
                                > node-gyp-build
                                gyp info it worked if it ends with ok
                                gyp info using node-gyp@7.1.2
                                gyp info using node@24.12.0 | linux | arm64
                                (node:5501) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
                                (Use `node --trace-deprecation ...` to show where the warning was created)
                                gyp info find Python using Python version 3.13.5 found at "/usr/bin/python3"
                                gyp ERR! Completion callback never invoked!
                                gyp ERR! System Linux 6.12.47+rpt-rpi-2712
                                gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                                gyp ERR! cwd /opt/iobroker/node_modules/@stoprocent/noble
                                gyp ERR! node -v v24.12.0
                                gyp ERR! node-gyp -v v7.1.2
                                gyp ERR! Node-gyp failed to build your package.
                                gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.
                                > authenticate-pam@1.0.5 install
                                > node-gyp rebuild
                                (node:5517) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
                                gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"
                                gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pam
                                > cpu-features@0.0.10 install
                                > node buildcheck.js > buildcheck.gypi && node-gyp rebuild
                                (node:5550) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
                                gyp ERR! cwd /opt/iobroker/node_modules/cpu-features
                                > diskusage@1.2.0 install
                                > node-gyp rebuild
                                (node:5564) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
                                gyp ERR! cwd /opt/iobroker/node_modules/diskusage
                                > node-dht-sensor@0.4.5 install
                                > node-gyp configure
                                (node:5580) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
                                gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "configure"
                                gyp ERR! cwd /opt/iobroker/node_modules/node-dht-sensor
                                > opengpio@2.0.2 install
                                > node-gyp rebuild
                                (node:5594) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
                                gyp ERR! cwd /opt/iobroker/node_modules/opengpio
                                npm error code 6
                                npm error path /opt/iobroker/node_modules/opengpio
                                npm error command failed
                                npm error command sh -c node-gyp rebuild
                                npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-12-28T16_00_16_769Z-debug-0.log
                                npm error code 6
                                host.RaspberryPi-Iobroker Cannot install iobroker.rpi2@latest: 6
                                martin@RaspberryPi-Iobroker:~ $ ^C
                                • G Gonzokalle
                                  NPM version: 11.6.2
                                  > node-gyp-build
                                  > node-gyp-build
                                  > node-gyp rebuild
                                  > node-gyp rebuild
                                  > node-gyp configure
                                  > node-gyp rebuild
                                  npm error code 6
                                  npm error code 6
                                  #96
                                  Grundsätzlich nicht. Dann hat der Datenträger wohl 'nen Schuß.
                                  Tausch den baldmöglichst aus.
                                  Auf einem fitten Datenträger.
                                  Die Meldungen kommen aber nicht vom OS, sondern von npm bzw. node-gyp.
                                  Keine Ahnung, was da bei dir schief ist.
                                  Das buildenvironment ist aber okay?
                                  sudo apt install build-essential python3-dev python3-pip
                                  versuchen.
                                  • G Gonzokalle
                                    NPM version: 11.6.2
                                    > node-gyp-build
                                    > node-gyp-build
                                    > node-gyp rebuild
                                    > node-gyp rebuild
                                    > node-gyp configure
                                    > node-gyp rebuild
                                    npm error code 6
                                    npm error code 6
                                    #97
                                    nein!
                                    Da gibt es defekte Dateien, und verwa7ste Reste, die nicht mehr zugeordnet werden können.
                                    aber nur auf eine neue Speicherkarte
                                      versuchen.
                                      Gonzokalle
                                      #98
                                      @Thomas-Braun
                                      martin@RaspberryPi-Iobroker:~ $ sudo apt install build-essential python3-dev python3-pip
                                      build-essential ist schon die neueste Version (12.12).
                                      python3-dev ist schon die neueste Version (3.13.5-1).
                                      python3-dev wurde als manuell installiert festgelegt.
                                      python3-pip ist schon die neueste Version (25.1.1+dfsg-1+rpt1).
                                      python3-pip wurde als manuell installiert festgelegt.
                                      Zusammenfassung:
                                        Aktualisiere: 0, Installiere: 0, Entferne: 0, Aktualisiere nicht: 0
                                      • G Gonzokalle
                                        @Thomas-Braun
                                        Zusammenfassung:
                                        #99
                                        @Gonzokalle
                                        Und schmeiß den
                                        raus. Der funktioniert seit Jahren nicht mehr richtig.
                                        iob del terminal --debug
                                          nein!
                                          Gonzokalle
                                          #100
                                          @Homoran
                                          Ist ne NVME SSD 1TB von Samsung.
                                          Erst ein Jahr alt.
