  4. RPI2 Adapter kann nicht installiert werden
    6.4k
167 Beiträge 11 Kommentatoren 13.2k Aufrufe 10 Beobachtet
  • G Gonzokalle
    @Thomas-Braun
    Jetzt ist etwas passiert.
    martin@RaspberryPi-Iobroker:/opt/iobroker $ cd /opt/iobroker/ && npm i iobroker.rpi2@3.0.2 --debug
    npm warn deprecated npmlog@4.1.2: This package is no longer supported.
    npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supported
    npm warn deprecated are-we-there-yet@1.1.7: This package is no longer supported.
    npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
    npm warn deprecated gauge@2.7.4: This package is no longer supported.
    npm error code 7
    npm error path /opt/iobroker/node_modules/opengpio
    npm error command failed
    npm error command sh -c node-gyp rebuild
    npm error gyp info it worked if it ends with ok
    npm error gyp info using node-gyp@7.1.2
    npm error gyp info using node@22.21.0 | linux | arm64
    npm error (node:92813) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
    npm error (Use `node --trace-deprecation ...` to show where the warning was created)
    npm error gyp info find Python using Python version 3.13.5 found at "/usr/bin/python3"
    npm error gyp ERR! UNCAUGHT EXCEPTION
    npm error gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#<Object>'
    npm error gyp ERR! stack     at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)
    npm error gyp ERR! stack     at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9
    npm error gyp ERR! stack     at FSReqCallback.oncomplete (node:fs:187:23)
    npm error gyp ERR! System Linux 6.12.47+rpt-rpi-2712
    npm error gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"
    npm error gyp ERR! cwd /opt/iobroker/node_modules/opengpio
    npm error gyp ERR! node -v v22.21.0
    npm error gyp ERR! node-gyp -v v7.1.2
    npm error gyp ERR! Node-gyp failed to build your package.
    npm error gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.
    npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-12-27T12_42_56_742Z-debug-0.log
    #76
    @Gonzokalle
    Irgendwas stimmt nicht mit den Versionen, denke ich.
    Vielleicht versuchst du dein Glück mal mit nodejs@24
    iob nodejs-update 24
    G 1 Antwort Letzte Antwort
      @Gonzokalle
      Gonzokalle
      #77
      @Thomas-Braun
      24 wird ja noch gar nicht empfohlen.
      Gibt es einen Befehl um nodejs 22 neu zu installieren?
      • G Gonzokalle
        @Thomas-Braun
        #78
        @Gonzokalle sagte in RPI2 Adapter kann nicht installiert werden:
        hast du es denn probiert?
        es geht doch darum dass die Pakete neu gebaut werden.
        dito mit 22
          dito mit 22
          Gonzokalle
          #79
          @Homoran
          Habe es mal mit nodejs 22 probiert und neu gestartet.
          ioBroker nodejs fixer 2025-08-09
          You requested to install latest version from nodejs v22 tree.
          Your current setup is:
          /usr/bin/nodejs         v22.21.0
          /usr/bin/node           v22.21.0
          /usr/bin/npm            10.9.4
          /usr/bin/npx            10.9.4
          /usr/bin/corepack       0.34.0
          We found these nodejs versions available for installation:
          nodejs:
            Installed: 22.21.0-1nodesource1
            Candidate: 22.21.0-1nodesource1
            Version table:
           *** 22.21.0-1nodesource1 1001
                  500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
               22.20.0-1nodesource1 1001
               22.19.0-1nodesource1 1001
               22.18.0-1nodesource1 1001
               22.17.1-1nodesource1 1001
               22.17.0-1nodesource1 1001
               22.16.0-1nodesource1 1001
               22.15.1-1nodesource1 1001
               22.15.0-1nodesource1 1001
               22.14.0-1nodesource1 1001
               22.13.1-1nodesource1 1001
               22.13.0-1nodesource1 1001
               22.12.0-1nodesource1 1001
               22.11.0-1nodesource1 1001
               22.10.0-1nodesource1 1001
               22.9.0-1nodesource1 1001
               22.8.0-1nodesource1 1001
               22.7.0-1nodesource1 1001
               22.6.0-1nodesource1 1001
               22.5.1-1nodesource1 1001
               22.5.0-1nodesource1 1001
               22.4.1-1nodesource1 1001
               22.4.0-1nodesource1 1001
               22.3.0-1nodesource1 1001
               22.2.0-1nodesource1 1001
               22.1.0-1nodesource1 1001
               22.0.0-1nodesource1 1001
               20.19.2+dfsg-1 500
                  500 http://deb.debian.org/debian trixie/main arm64 Packages
          Nothing to do - Your installation is using the correct paths.
          You are running nodejs v22.21.0. Do you want to install latest version from nodejs v.22 tree?
          Press <y> to continue or any other key to quit
          Trying to fix your installation now. Please be patient.
          find: '/run/user/1000/doc': Permission denied
          find: '/run/user/1000/gvfs': Permission denied
          Stopping ioBroker now
          ioBroker has been stopped
          Removing dfsg-nodejs
          *** These repos are active on your system:
          Hit:1 http://deb.debian.org/debian trixie InRelease
          Hit:2 http://archive.raspberrypi.com/debian trixie InRelease
          Hit:3 http://deb.debian.org/debian trixie-updates InRelease
          Hit:4 http://deb.debian.org/debian-security trixie-security InRelease
          Reading package lists... Done
          *** Installing ca-certificates, curl and gnupg, just in case they are missing.
          *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
          deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_22.x nodistro main
          Package: nodejs
          Pin: origin deb.nodesource.com
          Pin-Priority: 1001
          *** These repos are active after the adjustments:
          Hit:1 http://archive.raspberrypi.com/debian trixie InRelease
          Hit:2 http://deb.debian.org/debian trixie InRelease
          Get:5 https://deb.nodesource.com/node_22.x nodistro InRelease [12.1 kB]
          Get:6 https://deb.nodesource.com/node_22.x nodistro/main armhf Packages [7375 B]
          Get:7 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages [8572 B]
          Fetched 28.1 kB in 0s (140 kB/s)
          W: https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
          Installing nodejs now!
          Installing latest nodejs v22 release
          SUCCESS!
          v22.21.0 has been installed! You are using the latest nodejs@22 release now!
          COMPATIBILITY CHECK IN PROGRESS (Only a --dry-run! No modules are really changed or added!)
          add usocket 0.3.0
          add unix-dgram 2.0.6
          add raw-socket 1.8.1
          add nan 2.19.0
          add number-is-nan 1.0.1
          add npmlog 4.1.2
          add node-gyp 7.1.2
          add rimraf 3.0.2
          add minimatch 3.1.2
          add glob 7.2.3
          add brace-expansion 1.1.12
          add net-ping 1.2.4
          add napi-thread-safe-callback 0.0.6
          add gauge 2.7.4
          add strip-ansi 3.0.1
          add string-width 1.0.2
          add signal-exit 3.0.7
          add is-fullwidth-code-point 1.0.0
          add ansi-regex 2.1.1
          add fsevents 2.3.3
          add es6-promise 4.2.8
          add env-paths 2.2.1
          add diskusage 1.2.0
          add cpu-features 0.0.10
          add code-point-at 1.1.0
          add buildcheck 0.0.7
          add authenticate-pam 1.0.5
          add are-we-there-yet 1.1.7
          add string_decoder 1.1.1
          add safe-buffer 5.1.2
          add readable-stream 2.3.8
          add @stoprocent/noble 1.19.1
          added 32 packages in 2s
          219 packages are looking for funding
            run `npm fund` for details
          We tried our best to fix your nodejs. Please run iob diag again to verify.
          *** RESTARTING ioBroker NOW! ***
           Please refresh or restart your browser in a few moments.
          martin@RaspberryPi-Iobroker:/opt/iobroker $ sudo reboot
          G HomoranH 2 Antworten Letzte Antwort
          • G Gonzokalle
            @Homoran
            /usr/bin/npm            10.9.4
            /usr/bin/npx            10.9.4
            nodejs:
              Version table:
                 20.19.2+dfsg-1 500
            Package: nodejs
            Pin-Priority: 1001
            SUCCESS!
            add usocket 0.3.0
            add nan 2.19.0
            add npmlog 4.1.2
            add node-gyp 7.1.2
            add rimraf 3.0.2
            add minimatch 3.1.2
            add glob 7.2.3
            add net-ping 1.2.4
            add gauge 2.7.4
            add fsevents 2.3.3
            add env-paths 2.2.1
            add diskusage 1.2.0
            Gonzokalle
            #80
            Mit nodesjs 22 versucht den rpi2@3.0.2 zu installieren.
            login as: martin
            martin@192.168.10.12's password:
            Linux RaspberryPi-Iobroker 6.12.47+rpt-rpi-2712 #1 SMP PREEMPT Debian 1:6.12.47-        1+rpt1 (2025-09-16) aarch64
            permitted by applicable law.
            Last login: Sat Dec 27 16:54:46 2025 from 192.168.10.11
            martin@RaspberryPi-Iobroker:~ $ cd /opt/iobroker/ && npm i iobroker.rpi2@3.0.2 --debug
            npm error code 7
            npm error (node:2692) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
            npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-12-27T16_02_02_683Z-debug-0.log
            • G Gonzokalle
              @Homoran
              /usr/bin/npm            10.9.4
              /usr/bin/npx            10.9.4
              nodejs:
                Version table:
                   20.19.2+dfsg-1 500
              Package: nodejs
              Pin-Priority: 1001
              SUCCESS!
              add usocket 0.3.0
              add nan 2.19.0
              add npmlog 4.1.2
              add node-gyp 7.1.2
              add rimraf 3.0.2
              add minimatch 3.1.2
              add glob 7.2.3
              add net-ping 1.2.4
              add gauge 2.7.4
              add fsevents 2.3.3
              add env-paths 2.2.1
              add diskusage 1.2.0
              #81
              ohne vorher die node Version zu ändern?
              Das bringt nichts
                Das bringt nichts
                Gonzokalle
                #82
                @Homoran
                Ist das hier noch gültig um die nodejs auf Version 24 zu bringen?
                https://forum.iobroker.net/search?term=Update+NodeJS+best+practise&in=titles
                • G Gonzokalle
                  @Homoran
                  #83
                  @Gonzokalle
                  Mach es so:
                    @Gonzokalle
                    Mach es so:
                    Gonzokalle
                    #84
                    @Thomas-Braun
                    Den iobroker vorher stoppen?
                    • G Gonzokalle
                      @Thomas-Braun
                      #85
                      @Gonzokalle
                      Kannste machen, macht der Befehl aber ohnehin selber.
                        @Gonzokalle
                        Gonzokalle
                        schrieb am zuletzt editiert von Gonzokalle
                        #86
                        @Thomas-Braun
                        Gut
                        Ist scheinbar ohne Fehler durchgelaufen.
                        Kann ich jetzt
                        probieren?
                        You requested to install latest version from nodejs v24 tree.
                        /usr/bin/npm            10.9.4
                        /usr/bin/npx            10.9.4
                        nodejs:
                          Version table:
                             20.19.2+dfsg-1 500
                        You are running nodejs v22.21.0. Do you want to install latest version from nodejs v.24 tree?
                        Get:3 http://deb.debian.org/debian trixie-updates InRelease [47.3 kB]
                        Fetched 47.3 kB in 0s (332 kB/s)
                        deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_24.x nodistro main
                        Package: nodejs
                        Pin-Priority: 1001
                        Get:5 https://deb.nodesource.com/node_24.x nodistro InRelease [12.1 kB]
                        Get:6 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages [4879 B]
                        Get:7 https://deb.nodesource.com/node_24.x nodistro/main armhf Packages [1369 B]
                        Fetched 18.4 kB in 1s (33.1 kB/s)
                        W: https://deb.nodesource.com/node_24.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
                        Installing latest nodejs v24 release
                        (Reading database ... 134042 files and directories currently installed.)
                        Preparing to unpack .../nodejs_24.12.0-1nodesource1_arm64.deb ...
                        Detected old npm client, removing...
                        Unpacking nodejs (24.12.0-1nodesource1) over (22.21.0-1nodesource1) ...
                        Setting up nodejs (24.12.0-1nodesource1) ...
                        Processing triggers for man-db (2.13.1-1) ...
                        SUCCESS!
                        v24.12.0 has been installed! You are using the latest nodejs@24 release now!
                        add usocket 0.3.0
                        add nan 2.19.0
                        add npmlog 4.1.2
                        add node-gyp 7.1.2
                        add rimraf 3.0.2
                        add minimatch 3.1.2
                        add glob 7.2.3
                        add net-ping 1.2.4
                        add gauge 2.7.4
                        add env-paths 2.2.1
                        add diskusage 1.2.0
                        remove @csstools/css-tokenizer 3.0.4
                        remove @csstools/css-parser-algorithms 3.0.5
                        remove canvas 2.11.2
                        added 31 packages, and removed 3 packages in 2s
                        214 packages are looking for funding
                        • G Gonzokalle
                          @Thomas-Braun
                          Gut
                          Kann ich jetzt
                          probieren?
                          /usr/bin/npm            10.9.4
                          /usr/bin/npx            10.9.4
                          nodejs:
                            Version table:
                               20.19.2+dfsg-1 500
                          Package: nodejs
                          Pin-Priority: 1001
                          SUCCESS!
                          add usocket 0.3.0
                          add nan 2.19.0
                          add npmlog 4.1.2
                          add node-gyp 7.1.2
                          add rimraf 3.0.2
                          add minimatch 3.1.2
                          add glob 7.2.3
                          add net-ping 1.2.4
                          add gauge 2.7.4
                          add env-paths 2.2.1
                          add diskusage 1.2.0
                          #87
                          • G Gonzokalle
                            @Thomas-Braun
                            Gut
                            Kann ich jetzt
                            probieren?
                            /usr/bin/npm            10.9.4
                            /usr/bin/npx            10.9.4
                            nodejs:
                              Version table:
                                 20.19.2+dfsg-1 500
                            Package: nodejs
                            Pin-Priority: 1001
                            SUCCESS!
                            add usocket 0.3.0
                            add nan 2.19.0
                            add npmlog 4.1.2
                            add node-gyp 7.1.2
                            add rimraf 3.0.2
                            add minimatch 3.1.2
                            add glob 7.2.3
                            add net-ping 1.2.4
                            add gauge 2.7.4
                            add env-paths 2.2.1
                            add diskusage 1.2.0
                            #88
                            cd /opt/iobroker/
                            npm i
                            iob status
                            Irgendein Adapter ist da auf einem alten Stand.
                            canvas fliegt raus. Schau mit
                            npm explain canvas
                            nach warum
                              Gonzokalle
                              #89
                              @Homoran
                              Sieht doch ganz gut aus.
                              ```bash
                              Script v.2025-08-09
                              *** BASE SYSTEM ***
                              Operating System: Debian GNU/Linux 13 (trixie)
                               Static hostname: RaspberryPi-Iobroker
                                     Icon name: computer
                                        Kernel: Linux 6.12.47+rpt-rpi-2712
                                  Architecture: arm64
                              OS is similar to:
                              Model           : Raspberry Pi 5 Model B Rev 1.0
                              Docker          : false
                              Virtualization  : none
                              Kernel          : aarch64
                              Userland        : 64 bit
                              Systemuptime and Load:
                               15:20:50 up 22:21,  3 users,  load average: 0.53, 0.59, 0.53
                              CPU threads: 4
                              *** LIFE CYCLE STATUS ***
                              Operating System is the current Debian stable version codenamed 'trixie'!
                              *** RASPBERRY THROTTLING ***
                              Current issues:
                              Previously detected issues:
                              *** TIME AND TIMEZONES ***
                                             Local time: Sun 2025-12-28 15:20:50 CET
                                         Universal time: Sun 2025-12-28 14:20:50 UTC
                                               RTC time: Sun 2025-12-28 14:20:50
                                            NTP service: active
                                        RTC in local TZ: no
                              *** Users and Groups ***
                              User that called 'iob diag':
                              martin
                              HOME=/home/martin
                              GROUPS=martin adm dialout cdrom sudo audio video plugdev games users netdev gpio i2c spi render input iobroker
                              iobroker
                              HOME=/home/iobroker
                              SUDO_HOME=/home/martin
                              *** DISPLAY-SERVER SETUP ***
                              Display-Server:         true
                              Display-Manager:        * lightdm.service - Light Display Manager
                              Desktop:
                              Session:                tty
                              System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
                              *** MEMORY ***
                              Mem:            8.5G        3.5G        2.1G         57M        3.0G        4.9G
                              Swap:           2.1G          0B        2.1G
                              Total:           10G        3.5G        4.3G
                              Active iob-Instances:   30
                                       8063 M total memory
                                       3358 M used memory
                                       3263 M active memory
                                       2224 M inactive memory
                                       2028 M free memory
                                        305 M buffer memory
                                       2511 M swap cache
                                       2047 M total swap
                                          0 M used swap
                                       2047 M free swap
                              top - 15:20:51 up 22:21,  3 users,  load average: 0.53, 0.59, 0.53
                              Tasks: 248 total,   1 running, 247 sleeping,   0 stopped,   0 zombie
                              %Cpu(s): 11.9 us,  2.4 sy,  0.0 ni, 85.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                              MiB Mem :   8063.0 total,   2023.0 free,   3364.2 used,   2817.4 buff/cache
                              MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.   4698.9 avail Mem
                              *** FAILED SERVICES ***
                              0 loaded units listed.
                              *** DMESG CRITICAL ERRORS ***
                              No critical errors detected
                              *** FILESYSTEM ***
                              udev           devtmpfs  3.9G     0  3.9G   0% /dev
                              tmpfs          tmpfs     1.6G   15M  1.6G   1% /run
                              /dev/nvme0n1p2 ext4      917G   11G  869G   2% /
                              tmpfs          tmpfs     4.0G  368K  4.0G   1% /dev/shm
                              tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
                              tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
                              tmpfs          tmpfs     4.0G   19M  4.0G   1% /tmp
                              /dev/nvme0n1p1 vfat      510M   86M  425M  17% /boot/firmware
                              tmpfs          tmpfs     807M  256K  807M   1% /run/user/1000
                              tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
                              tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/serial-getty@ttyAMA10.service
                              [Sat Dec 27 16:58:55 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0  numa=fake=8 system_heap.max_order=0 iommu_dma_numa_policy=interleave smsc95xx.macaddr=2C:CF:67:82:17:A3 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=e4c2f3ef-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
                              [Sat Dec 27 16:58:56 2025] EXT4-fs (nvme0n1p2): orphan cleanup on readonly fs
                              [Sat Dec 27 16:58:56 2025] EXT4-fs (nvme0n1p2): mounted filesystem d6944274-f2f7-4644-96a4-213c3b367f5c ro with ordered data mode. Quota mode: none.
                              [Sat Dec 27 16:58:57 2025] EXT4-fs (nvme0n1p2): re-mounted d6944274-f2f7-4644-96a4-213c3b367f5c r/w.
                              Show mounted filesystems:
                              TARGET           SOURCE         FSTYPE OPTIONS
                              /                /dev/nvme0n1p2 ext4   rw,noatime
                              `-/boot/firmware /dev/nvme0n1p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                              /var:
                              2.5G    /var/
                              251M    /var/cache
                              238M    /var/cache/apt
                              221M    /var/lib
                              154M    /var/lib/apt
                              Archived and active journals take up 8M in the file system.
                              /opt/iobroker/backups:
                              98M     /opt/iobroker/backups/
                              /opt/iobroker/iobroker-data:
                              988M    /opt/iobroker/iobroker-data/
                              496M    /opt/iobroker/iobroker-data/history
                              319M    /opt/iobroker/iobroker-data/files
                              124M    /opt/iobroker/iobroker-data/backup-objects
                              67M     /opt/iobroker/iobroker-data/files/echarts.admin
                              42M     /opt/iobroker/iobroker-data/objects.jsonl
                              26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
                              26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
                              24M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.70a15e1f.js.map
                              18M     /opt/iobroker/iobroker-data/files/echarts/preview/static/js/main.5fe9c7da.js.map
                              USB-Devices by-id:
                              /dev/serial/by-id/usb-SHK_JeeLink_LaCrosse-if00-port0
                              /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2469419-if00
                              *** ZigBee Settings ***
                              HINT:
                              Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                              zigbee.X
                              Extended Pan ID:
                              *** MASKED ***
                              Pan ID:
                              *** MASKED ***
                              Channel:
                              *** MASKED ***
                              Network Key:
                              *** MASKED ***
                              *** NodeJS-Installation ***
                              /usr/bin/nodejs         v24.12.0
                              /usr/bin/node           v24.12.0
                              /usr/bin/npm            11.6.2
                              /usr/bin/npx            11.6.2
                              /usr/bin/corepack       0.34.5
                              nodejs:
                                Installed: 24.12.0-1nodesource1
                                Candidate: 24.12.0-1nodesource1
                                Version table:
                               *** 24.12.0-1nodesource1 1001
                                      500 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages
                                   24.11.1-1nodesource1 1001
                                   24.11.0-1nodesource1 1001
                                   24.10.0-1nodesource1 1001
                                   24.9.0-1nodesource1 1001
                                   24.8.0-1nodesource1 1001
                                   24.7.0-1nodesource1 1001
                                   24.6.0-1nodesource1 1001
                                   24.5.0-1nodesource1 1001
                                   24.4.1-1nodesource1 1001
                                   24.4.0-1nodesource1 1001
                                   24.3.0-1nodesource1 1001
                                   24.1.0-1nodesource1 1001
                                   24.0.2-1nodesource1 1001
                                   24.0.1-1nodesource1 1001
                                   24.0.0-1nodesource1 1001
                                   20.19.2+dfsg-1 500
                              No problems detected
                              Errors in npm tree: 0
                              *** ioBroker-Installation ***
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              Hosts:
                              RaspberryPi-Iobroker RaspberryPi-Iobroker (version: 7.0.7, hostname: RaspberryPi-Iobroker, alive, uptime: 7712)
                              Core adapters versions
                              js-controller:  7.0.7
                              admin:          7.7.19
                              javascript:     9.0.11
                              nodejs modules from github:     1
                              +-- iobroker.eusec@2.0.3 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.eusec.git#f625cbb12aea40dcf6faf11a17d93328f069b753)
                              Adapter State
                              + system.adapter.admin.0                  : admin                 : RaspberryPi-Iobroker                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                              + system.adapter.alexa2.0                 : alexa2                : RaspberryPi-Iobroker                     -  enabled
                              + system.adapter.backitup.0               : backitup              : RaspberryPi-Iobroker                     -  enabled
                              + system.adapter.device-watcher.0         : device-watcher        : RaspberryPi-Iobroker                     -  enabled
                                system.adapter.devices.0                : devices               : RaspberryPi-Iobroker                     - disabled
                              + system.adapter.echarts.0                : echarts               : RaspberryPi-Iobroker                     -  enabled
                              + system.adapter.energiefluss.0           : energiefluss          : RaspberryPi-Iobroker                     -  enabled
                              + system.adapter.eusec.0                  : eusec                 : RaspberryPi-Iobroker                     -  enabled
                                system.adapter.flot.0                   : flot                  : RaspberryPi-Iobroker                     - disabled
                              + system.adapter.fullybrowser.0           : fullybrowser          : RaspberryPi-Iobroker                     -  enabled
                              + system.adapter.history.0                : history               : RaspberryPi-Iobroker                     -  enabled
                                system.adapter.icons-icons8.0           : icons-icons8          : RaspberryPi-Iobroker                     - disabled
                              + system.adapter.iot.0                    : iot                   : RaspberryPi-Iobroker                     -  enabled
                              + system.adapter.iqontrol.0               : iqontrol              : RaspberryPi-Iobroker                     -  enabled
                              + system.adapter.iqontrol.1               : iqontrol              : RaspberryPi-Iobroker                     -  enabled
                              + system.adapter.javascript.0             : javascript            : RaspberryPi-Iobroker                     -  enabled
                              + system.adapter.jeelink.0                : jeelink               : RaspberryPi-Iobroker                     -  enabled
                              + system.adapter.mqtt.0                   : mqtt                  : RaspberryPi-Iobroker                     -  enabled, port: 1884, bind: 0.0.0.0
                                system.adapter.netatmo-crawler.0        : netatmo-crawler       : RaspberryPi-Iobroker                     -  enabled
                              + system.adapter.opendtu.0                : opendtu               : RaspberryPi-Iobroker                     -  enabled
                              + system.adapter.opendtu.1                : opendtu               : RaspberryPi-Iobroker                     -  enabled
                              + system.adapter.radar2.0                 : radar2                : RaspberryPi-Iobroker                     -  enabled
                              + system.adapter.reolink.0                : reolink               : RaspberryPi-Iobroker                     -  enabled
                              + system.adapter.reolink.1                : reolink               : RaspberryPi-Iobroker                     -  enabled
                                system.adapter.reolink.2                : reolink               : RaspberryPi-Iobroker                     - disabled
                              + system.adapter.reolink.3                : reolink               : RaspberryPi-Iobroker                     -  enabled
                              + system.adapter.shelly.0                 : shelly                : RaspberryPi-Iobroker                     -  enabled, port: 1882, bind: 0.0.0.0
                              + system.adapter.smartgarden.0            : smartgarden           : RaspberryPi-Iobroker                     -  enabled
                              + system.adapter.sonoff.0                 : sonoff                : RaspberryPi-Iobroker                     -  enabled, port: 1883, bind: 0.0.0.0
                              + system.adapter.telegram.0               : telegram              : RaspberryPi-Iobroker                     -  enabled, port: 8443, bind: 0.0.0.0
                              + system.adapter.terminal.0               : terminal              : RaspberryPi-Iobroker                     -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
                              + system.adapter.web.0                    : web                   : RaspberryPi-Iobroker                     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                              + system.adapter.wled.0                   : wled                  : RaspberryPi-Iobroker                     -  enabled
                              + system.adapter.zigbee.0                 : zigbee                : RaspberryPi-Iobroker                     -  enabled, port: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2469419-if00
                              + instance is alive
                              ioBroker-Repositories
                              Active repo(s): stable
                              Upgrade policy: none
                              Installed ioBroker-Adapters
                              Used repository: stable
                              Adapter    "admin"        : 7.7.19   , installed 7.7.19
                              Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
                              Adapter    "backitup"     : 3.3.10   , installed 3.3.10
                              Adapter    "device-watcher": 2.13.1  , installed 2.13.1
                              Adapter    "devices"      : 1.2.8    , installed 1.2.8
                              Adapter    "echarts"      : 1.9.2    , installed 1.9.2
                              Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
                              Adapter    "eusec"        : 2.0.3    , installed 2.0.3
                              Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
                              Adapter    "iot"          : 5.0.7    , installed 5.0.7
                              Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
                              Adapter    "javascript"   : 9.0.11   , installed 9.0.11
                              Adapter    "jeelink"      : 1.2.5    , installed 1.2.5
                              Controller "js-controller": 7.0.7    , installed 7.0.7
                              Adapter    "netatmo-crawler": 1.1.0  , installed 1.1.0
                              Adapter    "opendtu"      : 3.1.0    , installed 3.1.0
                              Adapter    "radar2"       : 2.4.0    , installed 2.4.0
                              Adapter    "reolink"      : 1.2.3    , installed 1.2.3
                              Adapter    "shelly"       : 10.4.1   , installed 10.4.1
                              Adapter    "smartgarden"  : 2.0.1    , installed 2.0.1
                              Adapter    "socketio"     : 6.7.1    , installed 7.0.8
                              Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
                              Adapter    "terminal"     : 1.0.0    , installed 1.0.0
                              Adapter    "web"          : 7.0.8    , installed 7.0.8
                              Adapter    "wled"         : 0.7.2    , installed 0.7.2
                              Adapter    "ws"           : 2.6.2    , installed 3.0.19
                              Adapter    "zigbee"       : 3.1.5    , installed 3.2.5
                              Objects and States
                              Objects:        6945
                              States:         5883
                              Hit:5 https://deb.nodesource.com/node_24.x nodistro InRelease
                              Pending Updates: 0
                              *** Listening Ports ***
                              tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       1679096    51906/io.mqtt.0
                              tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       1679168    51999/io.shelly.0
                              tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       1681214    52018/io.sonoff.0
                              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       1679520    51393/iobroker.js-c
                              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       1679525    51393/iobroker.js-c
                              tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          589619     18907/cupsd
                              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          10440      1000/sshd: /usr/sbi
                              tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          4716       1/init
                              tcp6       0      0 :::1984                 :::*                    LISTEN      1001       1681677    51883/go2rtc
                              tcp6       0      0 :::5900                 :::*                    LISTEN      985        8967       1014/wayvnc
                              tcp6       0      0 ::1:631                 :::*                    LISTEN      0          589618     18907/cupsd
                              tcp6       0      0 :::8554                 :::*                    LISTEN      1001       1679923    51883/go2rtc
                              tcp6       0      0 :::8555                 :::*                    LISTEN      1001       1681679    51883/go2rtc
                              tcp6       0      0 :::21                   :::*                    LISTEN      0          8913       1001/vsftpd
                              tcp6       0      0 :::22                   :::*                    LISTEN      0          10442      1000/sshd: /usr/sbi
                              tcp6       0      0 :::111                  :::*                    LISTEN      0          138        1/init
                              tcp6       0      0 :::8088                 :::*                    LISTEN      1001       1682622    52264/io.terminal.0
                              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       1679579    51415/io.admin.0
                              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       1683698    52283/io.web.0
                              tcp6       0      0 :::3000                 :::*                    LISTEN      1001       1681715    51891/io.fullybrows
                              udp        0      0 0.0.0.0:49674           0.0.0.0:*                           101        769        710/avahi-daemon: r
                              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       1682326    52303/io.wled.0
                              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           101        767        710/avahi-daemon: r
                              udp        0      0 0.0.0.0:35232           0.0.0.0:*                           1001       1681024    51868/io.eusec.0
                              udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       1681089    51951/io.radar2.0
                              udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          137        1/init
                              udp6       0      0 :::5353                 :::*                                101        768        710/avahi-daemon: r
                              udp6       0      0 :::48540                :::*                                101        770        710/avahi-daemon: r
                              udp6       0      0 :::111                  :::*                                0          4717       1/init
                              udp6       0      0 :::8555                 :::*                                1001       1681680    51883/go2rtc
                              2025-12-28 15:19:31.127  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: WR2000 ist noch gesperrt
                              2025-12-28 15:19:41.213  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: 14 ▫ 13<>15 ▫ 14
                              2025-12-28 15:19:41.213  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: keine Änderung, Limit WR2000 bleibt gleich
                              2025-12-28 15:19:51.098  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: WR600 auf 34% (200W)
                              2025-12-28 15:19:51.098  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: 14 ▫ 13<>15 ▫ 15
                              2025-12-28 15:19:51.098  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: keine Änderung, Limit WR2000 bleibt gleich
                              2025-12-28 15:20:01.124  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: 15 ▫ 14<>17 ▫ 14
                              2025-12-28 15:20:01.124  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: keine Änderung, Limit WR2000 bleibt gleich
                              2025-12-28 15:20:11.163  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: 14 ▫ 13<>15 ▫ 15
                              2025-12-28 15:20:11.163  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: keine Änderung, Limit WR2000 bleibt gleich
                              2025-12-28 15:20:21.095  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: 14 ▫ 13<>15 ▫ 16
                              2025-12-28 15:20:31.167  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: 16 ▫ 14<>18 ▫ 16
                              2025-12-28 15:20:31.167  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: keine Änderung, Limit WR2000 bleibt gleich
                              2025-12-28 15:20:41.125  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: 16 ▫ 14<>18 ▫ 14
                              2025-12-28 15:20:41.125  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: keine Änderung, Limit WR2000 bleibt gleich
                              2025-12-28 15:20:49.009  - info: host.RaspberryPi-Iobroker instance system.adapter.netatmo-crawler.0 in version "1.1.0" started with pid 57839
                              2025-12-28 15:20:51.177  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: 16 ▫ 14<>18 ▫ 14
                              2025-12-28 15:20:51.178  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: keine Änderung, Limit WR2000 bleibt gleich
                              2025-12-28 15:21:01.159  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: 16 ▫ 14<>18 ▫ 14
                              2025-12-28 15:21:01.159  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: keine Änderung, Limit WR2000 bleibt gleich
                              2025-12-28 15:21:01.601  - info: host.RaspberryPi-Iobroker instance system.adapter.netatmo-crawler.0 having pid 57839 terminated with code 0 (NO_ERROR)
                              2025-12-28 15:21:11.348  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: 16 ▫ 14<>18 ▫ 14
                              2025-12-28 15:21:11.348  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: keine Änderung, Limit WR2000 bleibt gleich
                              2025-12-28 15:21:21.491  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: 16 ▫ 14<>18 ▫ 15
                              2025-12-28 15:21:21.491  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: keine Änderung, Limit WR2000 bleibt gleich
                              iob diag has finished.
                                cd /opt/iobroker/
                                npm i
                                iob status
                                npm explain canvas
                                nach warum
                                Gonzokalle
                                #90
                                @Thomas-Braun
                                martin@RaspberryPi-Iobroker:/opt/iobroker $ npm explain canvas
                                npm error No dependencies found matching canvas
                                npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-12-28T14_23_22_531Z-debug-0.log
                                • G Gonzokalle
                                  @Homoran
                                  ```bash
                                  Script v.2025-08-09
                                  *** BASE SYSTEM ***
                                         Icon name: computer
                                      Architecture: arm64
                                  OS is similar to:
                                  Docker          : false
                                  Kernel          : aarch64
                                  Userland        : 64 bit
                                  CPU threads: 4
                                  Current issues:
                                                NTP service: active
                                            RTC in local TZ: no
                                  martin
                                  HOME=/home/martin
                                  iobroker
                                  HOME=/home/iobroker
                                  Desktop:
                                  Session:                tty
                                  *** MEMORY ***
                                  Swap:           2.1G          0B        2.1G
                                           8063 M total memory
                                           3358 M used memory
                                           2028 M free memory
                                            305 M buffer memory
                                           2511 M swap cache
                                           2047 M total swap
                                              0 M used swap
                                           2047 M free swap
                                  *** FILESYSTEM ***
                                  /var:
                                  2.5G    /var/
                                  251M    /var/cache
                                  238M    /var/cache/apt
                                  221M    /var/lib
                                  154M    /var/lib/apt
                                  USB-Devices by-id:
                                  HINT:
                                  zigbee.X
                                  Extended Pan ID:
                                  *** MASKED ***
                                  Pan ID:
                                  *** MASKED ***
                                  Channel:
                                  *** MASKED ***
                                  Network Key:
                                  *** MASKED ***
                                  /usr/bin/npm            11.6.2
                                  /usr/bin/npx            11.6.2
                                  nodejs:
                                    Version table:
                                       20.19.2+dfsg-1 500
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  Hosts:
                                  admin:          7.7.19
                                  javascript:     9.0.11
                                  Adapter State
                                  + instance is alive
                                  Objects and States
                                  Objects:        6945
                                  States:         5883
                                  Pending Updates: 0
                                  #91
                                  Stell das auf Kommandozeilenbetrieb (multi-user) um.
                                  Mit dem Dateisystem stimmt was nicht. Es sollten keine orphans beseitigt werden müssen. Nicht bei einem sauberen Bootvorgang.
                                  Installier den eusec-Adapter nochmal aus dem Repo, nicht aus dem GitHub.
                                  Mach das Null_2_WR_autoSperre-Skript weniger geschwätzig. Das kübelt dir ja das komplette Log dicht.
                                  • G Gonzokalle
                                    @Homoran
                                    ```bash
                                    Script v.2025-08-09
                                    *** BASE SYSTEM ***
                                           Icon name: computer
                                        Architecture: arm64
                                    OS is similar to:
                                    Docker          : false
                                    Kernel          : aarch64
                                    Userland        : 64 bit
                                    CPU threads: 4
                                    Current issues:
                                                  NTP service: active
                                              RTC in local TZ: no
                                    martin
                                    HOME=/home/martin
                                    iobroker
                                    HOME=/home/iobroker
                                    Desktop:
                                    Session:                tty
                                    *** MEMORY ***
                                    Swap:           2.1G          0B        2.1G
                                             8063 M total memory
                                             3358 M used memory
                                             2028 M free memory
                                              305 M buffer memory
                                             2511 M swap cache
                                             2047 M total swap
                                                0 M used swap
                                             2047 M free swap
                                    *** FILESYSTEM ***
                                    /var:
                                    2.5G    /var/
                                    251M    /var/cache
                                    238M    /var/cache/apt
                                    221M    /var/lib
                                    154M    /var/lib/apt
                                    USB-Devices by-id:
                                    HINT:
                                    zigbee.X
                                    Extended Pan ID:
                                    *** MASKED ***
                                    Pan ID:
                                    *** MASKED ***
                                    Channel:
                                    *** MASKED ***
                                    Network Key:
                                    *** MASKED ***
                                    /usr/bin/npm            11.6.2
                                    /usr/bin/npx            11.6.2
                                    nodejs:
                                      Version table:
                                         20.19.2+dfsg-1 500
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    Hosts:
                                    admin:          7.7.19
                                    javascript:     9.0.11
                                    Adapter State
                                    + instance is alive
                                    Objects and States
                                    Objects:        6945
                                    States:         5883
                                    Pending Updates: 0
                                    #92
                                    was nodejs v24 angeht, ja!
                                    aber
                                    den brauchst du nur, wenn daran eine visu direkt am Server gezeigt werden soll
                                    stell das um, das verhindert mögliche Probleme.
                                    und am schlimmsten
                                    De7n Dateisystem hat einen Schuss!
                                    womöglich kommen deine Probleme daher
                                      Gonzokalle
                                      #93
                                      @Thomas-Braun
                                      Desktop ist aus
                                      Eusec ist aus dem Repo
                                      Log ausgeschaltet
                                      ```bash
                                      Script v.2025-08-09
                                      *** BASE SYSTEM ***
                                             Icon name: computer
                                          Architecture: arm64
                                      OS is similar to:
                                      Docker          : false
                                      Kernel          : aarch64
                                      Userland        : 64 bit
                                       16:31:10 up 15 min,  2 users,  load average: 1.62, 0.64, 0.33
                                      CPU threads: 4
                                      Current issues:
                                                     Local time: Sun 2025-12-28 16:31:10 CET
                                                 Universal time: Sun 2025-12-28 15:31:10 UTC
                                                       RTC time: Sun 2025-12-28 15:31:10
                                                    NTP service: active
                                                RTC in local TZ: no
                                      martin
                                      HOME=/home/martin
                                      iobroker
                                      HOME=/home/iobroker
                                      Display-Server:         false
                                      Desktop:
                                      Session:                tty
                                      *** MEMORY ***
                                      Mem:            8.5G        3.2G        4.2G         26M        1.2G        5.3G
                                      Swap:           2.1G          0B        2.1G
                                      Total:           10G        3.2G        6.3G
                                               8063 M total memory
                                               3021 M used memory
                                               2865 M active memory
                                                758 M inactive memory
                                               3985 M free memory
                                                131 M buffer memory
                                               1035 M swap cache
                                               2047 M total swap
                                                  0 M used swap
                                               2047 M free swap
                                      top - 16:31:10 up 15 min,  2 users,  load average: 1.62, 0.64, 0.33
                                      Tasks: 221 total,   2 running, 219 sleeping,   0 stopped,   0 zombie
                                      %Cpu(s): 25.0 us,  6.8 sy,  0.0 ni, 65.9 id,  0.0 wa,  0.0 hi,  2.3 si,  0.0 st
                                      MiB Mem :   8063.0 total,   3984.8 free,   3022.7 used,   1167.7 buff/cache
                                      MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.   5040.3 avail Mem
                                      *** FILESYSTEM ***
                                      tmpfs          tmpfs     1.6G   16M  1.6G   1% /run
                                      tmpfs          tmpfs     4.0G   32K  4.0G   1% /dev/shm
                                      tmpfs          tmpfs     4.0G  9.3M  4.0G   1% /tmp
                                      tmpfs          tmpfs     807M  240K  807M   1% /run/user/1000
                                      [Sun Dec 28 16:16:07 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0  numa=fake=8 system_heap.max_order=0 iommu_dma_numa_policy=interleave smsc95xx.macaddr=2C:CF:67:82:17:A3 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=e4c2f3ef-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
                                      [Sun Dec 28 16:16:09 2025] EXT4-fs (nvme0n1p2): orphan cleanup on readonly fs
                                      [Sun Dec 28 16:16:09 2025] EXT4-fs (nvme0n1p2): mounted filesystem d6944274-f2f7-4644-96a4-213c3b367f5c ro with ordered data mode. Quota mode: none.
                                      [Sun Dec 28 16:16:09 2025] EXT4-fs (nvme0n1p2): re-mounted d6944274-f2f7-4644-96a4-213c3b367f5c r/w.
                                      /var:
                                      2.5G    /var/
                                      251M    /var/cache
                                      238M    /var/cache/apt
                                      221M    /var/lib
                                      154M    /var/lib/apt
                                      Archived and active journals take up 9.3M in the file system.
                                      982M    /opt/iobroker/iobroker-data/
                                      35M     /opt/iobroker/iobroker-data/objects.jsonl
                                      USB-Devices by-id:
                                      HINT:
                                      zigbee.X
                                      Extended Pan ID:
                                      *** MASKED ***
                                      Pan ID:
                                      *** MASKED ***
                                      Channel:
                                      *** MASKED ***
                                      Network Key:
                                      *** MASKED ***
                                      /usr/bin/npm            11.6.2
                                      /usr/bin/npx            11.6.2
                                      nodejs:
                                        Version table:
                                           20.19.2+dfsg-1 500
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      Hosts:
                                      RaspberryPi-Iobroker RaspberryPi-Iobroker (version: 7.0.7, hostname: RaspberryPi-Iobroker, alive, uptime: 902)
                                      admin:          7.7.19
                                      javascript:     9.0.11
                                      nodejs modules from github:     0
                                      Adapter State
                                      + instance is alive
                                      Objects and States
                                      Objects:        6930
                                      States:         5930
                                      Pending Updates: 0
                                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       10519      958/iobroker.js-con
                                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       10514      958/iobroker.js-con
                                      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          9375       957/cupsd
                                      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          4355       1/init
                                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11285      980/sshd: /usr/sbin
                                      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       12414      1705/io.shelly.0
                                      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       14349      1725/io.sonoff.0
                                      tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       11224      1613/io.mqtt.0
                                      tcp6       0      0 :::3000                 :::*                    LISTEN      1001       11205      1598/io.fullybrowse
                                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       12958      1993/io.web.0
                                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       11398      1033/io.admin.0
                                      tcp6       0      0 :::8088                 :::*                    LISTEN      1001       12911      1973/io.terminal.0
                                      tcp6       0      0 :::111                  :::*                    LISTEN      0          4356       1/init
                                      tcp6       0      0 :::22                   :::*                    LISTEN      0          11293      980/sshd: /usr/sbin
                                      tcp6       0      0 :::21                   :::*                    LISTEN      0          9142       968/vsftpd
                                      tcp6       0      0 :::8554                 :::*                    LISTEN      1001       11179      1589/go2rtc
                                      tcp6       0      0 :::8555                 :::*                    LISTEN      1001       11180      1589/go2rtc
                                      tcp6       0      0 :::5900                 :::*                    LISTEN      985        7569       1001/wayvnc
                                      tcp6       0      0 :::1984                 :::*                    LISTEN      1001       8133       1589/go2rtc
                                      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          9374       957/cupsd
                                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       12986      2011/io.wled.0
                                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           101        7190       712/avahi-daemon: r
                                      udp        0      0 0.0.0.0:36000           0.0.0.0:*                           101        7192       712/avahi-daemon: r
                                      udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       11994      1662/io.radar2.0
                                      udp        0      0 0.0.0.0:32838           0.0.0.0:*                           1001       11176      1574/io.eusec.0
                                      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          444        1/init
                                      udp6       0      0 :::5353                 :::*                                101        7191       712/avahi-daemon: r
                                      udp6       0      0 :::111                  :::*                                0          445        1/init
                                      udp6       0      0 :::8555                 :::*                                1001       11181      1589/go2rtc
                                      udp6       0      0 :::41681                :::*                                101        7193       712/avahi-daemon: r
                                      2025-12-28 16:20:49.009  - info: host.RaspberryPi-Iobroker instance system.adapter.netatmo-crawler.0 in version "1.1.0" started with pid 2171
                                      2025-12-28 16:20:53.255  - info: javascript.0 (1169) script.js.Temperaturen_&_Luftfeuchtigkeit.Temp_Terrasse_Status_an_Telegram: telegram: 🌡️ Terrasse unter 5°C
                                      2025-12-28 16:20:59.220  - info: host.RaspberryPi-Iobroker instance system.adapter.netatmo-crawler.0 having pid 2171 terminated with code 0 (NO_ERROR)
                                      2025-12-28 16:21:55.020  - warn: radar2.0 (1662) scanDelay increased to 116.421 seconds, delayAway to 5 minutes!
                                      2025-12-28 16:25:49.009  - info: host.RaspberryPi-Iobroker instance system.adapter.netatmo-crawler.0 in version "1.1.0" started with pid 2871
                                      2025-12-28 16:25:55.257  - info: host.RaspberryPi-Iobroker instance system.adapter.netatmo-crawler.0 having pid 2871 terminated with code 0 (NO_ERROR)
                                      2025-12-28 16:28:21.781  - info: device-watcher.0 (1554) Das folgende Gerät ist nicht mehr erreichbar:
                                      Zigbee:  Licht Terrasse (16:17)
                                      2025-12-28 16:30:01.968  - info: device-watcher.0 (1554) Das folgende Gerät ist nicht mehr erreichbar:
                                      WLED:  WLED-Matrix-2 (16:18)
                                      2025-12-28 16:30:02.060  - info: device-watcher.0 (1554) Das folgende Gerät ist nicht mehr erreichbar:
                                      WLED:  WLED-Stab-1 (330 Tage)
                                      2025-12-28 16:30:02.120  - info: device-watcher.0 (1554) Das folgende Gerät ist nicht mehr erreichbar:
                                      WLED:  WLED-Dachrinne (16:18)
                                      2025-12-28 16:30:02.173  - info: device-watcher.0 (1554) Das folgende Gerät ist nicht mehr erreichbar:
                                      WLED:  WLED-Hütte (169 Tage)
                                      2025-12-28 16:30:02.229  - info: device-watcher.0 (1554) Das folgende Gerät ist nicht mehr erreichbar:
                                      WLED:  WLED-Matrix-1 (16:18)
                                      2025-12-28 16:30:02.283  - info: device-watcher.0 (1554) Das folgende Gerät ist nicht mehr erreichbar:
                                      WLED:  WLED-Stab-2 (330 Tage)
                                      2025-12-28 16:30:07.398  - info: device-watcher.0 (1554) Das folgende Gerät ist nicht mehr erreichbar:
                                      WLED:  WLED-SoundReactive (528 Tage)
                                      2025-12-28 16:30:49.009  - info: host.RaspberryPi-Iobroker instance system.adapter.netatmo-crawler.0 in version "1.1.0" started with pid 3660
                                      2025-12-28 16:30:52.090  - info: javascript.0 (1169) script.js.Temperaturen_&_Luftfeuchtigkeit.Temp_Terrasse_Status_an_Telegram: telegram: 🌡️ Terrasse unter 0°C
                                      2025-12-28 16:31:00.387  - info: host.RaspberryPi-Iobroker instance system.adapter.netatmo-crawler.0 having pid 3660 terminated with code 0 (NO_ERROR)
                                      • G Gonzokalle
                                        @Thomas-Braun
                                        Desktop ist aus
                                        Log ausgeschaltet
                                        ```bash
                                        Script v.2025-08-09
                                        *** BASE SYSTEM ***
                                               Icon name: computer
                                            Architecture: arm64
                                        OS is similar to:
                                        Docker          : false
                                        Kernel          : aarch64
                                        Userland        : 64 bit
                                        CPU threads: 4
                                        Current issues:
                                                      NTP service: active
                                                  RTC in local TZ: no
                                        martin
                                        HOME=/home/martin
                                        iobroker
                                        HOME=/home/iobroker
                                        Desktop:
                                        Session:                tty
                                        *** MEMORY ***
                                        Swap:           2.1G          0B        2.1G
                                                 8063 M total memory
                                                 3021 M used memory
                                                 3985 M free memory
                                                  131 M buffer memory
                                                 1035 M swap cache
                                                 2047 M total swap
                                                    0 M used swap
                                                 2047 M free swap
                                        *** FILESYSTEM ***
                                        /var:
                                        2.5G    /var/
                                        251M    /var/cache
                                        238M    /var/cache/apt
                                        221M    /var/lib
                                        154M    /var/lib/apt
                                        USB-Devices by-id:
                                        HINT:
                                        zigbee.X
                                        Extended Pan ID:
                                        *** MASKED ***
                                        Pan ID:
                                        *** MASKED ***
                                        Channel:
                                        *** MASKED ***
                                        Network Key:
                                        *** MASKED ***
                                        /usr/bin/npm            11.6.2
                                        /usr/bin/npx            11.6.2
                                        nodejs:
                                          Version table:
                                             20.19.2+dfsg-1 500
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        Hosts:
                                        admin:          7.7.19
                                        javascript:     9.0.11
                                        Adapter State
                                        + instance is alive
                                        Objects and States
                                        Objects:        6930
                                        States:         5930
                                        Pending Updates: 0
                                        #94
                                        Ganz frischer Eintrag. Wenn du sauber gebootet hast, dann darf diese Meldung auf einem gesunden Datenträger nicht erscheinen.
                                        Das ist dann ein starker Hinweis auf einen Defekt.
                                        HINT:
                                        Wird ein 'false positive' sein, ich sehe nur nicht warum. Den Code habe ich aber in einer kommenden Version von iob diag an der Stelle geändert.
                                        Jetzt installier den rpi2 mal:
                                         iobroker url iobroker.rpi2@latest  --debug
                                        Edit: Sollte dann so aussehen:
                                        echad@chet:/opt/iobroker $ iobroker url iobroker.rpi2@latest --debug
                                        install iobroker.rpi2@latest
                                        NPM version: 11.6.2
                                        Installing iobroker.rpi2@latest... (System call)
                                        up to date in 9s
                                        254 packages are looking for funding
                                        upload [13] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                        upload [12] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                        upload [11] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                        upload [10] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                        upload [9] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                        upload [8] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                        upload [7] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                        upload [6] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                        upload [5] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                        upload [4] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                                        upload [3] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                        upload [2] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/jsonConfig.json jsonConfig.json application/json
                                        upload [1] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/rpi2.png rpi2.png image/png
                                        upload [0] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/words.js words.js application/javascript
                                        Updating objects from io-package.json for adapter "rpi2" with version "3.0.2"
                                          HINT:
                                          NPM version: 11.6.2
                                          up to date in 9s
                                          Gonzokalle
                                          #95
                                          @Thomas-Braun sagte in RPI2 Adapter kann nicht installiert werden:
                                          Ich hatte mit sudo reboot neu gestartet. Kann daher der Eintrag kommen?
                                          Das sieht wieder schlecht aus.
                                          Vielleicht sollte ich Trixie einfach nochmal neu aufspielen.
                                          martin@RaspberryPi-Iobroker:~ $  iobroker url iobroker.rpi2@latest  --debug
                                          NPM version: 11.6.2
                                          > iobroker.rpi2@3.0.2 preinstall
                                          > bash ./preinstall-check.sh
                                          Checking package: libgpiod-dev >= 2.2
                                          libgpiod-dev version OK: 2.2.1-2+deb13u1
                                          > @stoprocent/bluetooth-hci-socket@1.5.2 install
                                          > node-gyp-build
                                          > @stoprocent/noble@1.19.1 install
                                          > node-gyp-build
                                          gyp info using node@24.12.0 | linux | arm64
                                          (node:5501) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
                                          gyp ERR! Completion callback never invoked!
                                          gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                                          gyp ERR! cwd /opt/iobroker/node_modules/@stoprocent/noble
                                          gyp ERR! node -v v24.12.0
                                          > authenticate-pam@1.0.5 install
                                          > node-gyp rebuild
                                          (node:5517) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
                                          gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pam
                                          > cpu-features@0.0.10 install
                                          > node buildcheck.js > buildcheck.gypi && node-gyp rebuild
                                          (node:5550) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
                                          gyp ERR! cwd /opt/iobroker/node_modules/cpu-features
                                          > diskusage@1.2.0 install
                                          > node-gyp rebuild
                                          (node:5564) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
                                          gyp ERR! cwd /opt/iobroker/node_modules/diskusage
                                          > node-dht-sensor@0.4.5 install
                                          > node-gyp configure
                                          (node:5580) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
                                          gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "configure"
                                          gyp ERR! cwd /opt/iobroker/node_modules/node-dht-sensor
                                          > opengpio@2.0.2 install
                                          > node-gyp rebuild
                                          (node:5594) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
                                          npm error code 6
                                          npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-12-28T16_00_16_769Z-debug-0.log
                                          npm error code 6
                                          host.RaspberryPi-Iobroker Cannot install iobroker.rpi2@latest: 6
                                          martin@RaspberryPi-Iobroker:~ $ ^C
