  4. RPI2 Adapter kann nicht installiert werden
    6.4k
167 Beiträge 11 Kommentatoren 13.2k Aufrufe 10 Beobachtet
  • G Gonzokalle
    @Thomas-Braun
    martin@RaspberryPi-Iobroker:/opt/iobroker $ npm i
    npm warn deprecated npmlog@4.1.2: This package is no longer supported.
    npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supported
    npm warn deprecated are-we-there-yet@1.1.7: This package is no longer supported.
    npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
    npm warn deprecated gauge@2.7.4: This package is no longer supported.
    up to date in 4s
    213 packages are looking for funding
      run `npm fund` for details
    martin@RaspberryPi-Iobroker:/opt/iobroker $ ^C
    martin@RaspberryPi-Iobroker:/opt/iobroker $ iob add rpi2 --debug
    NPM version: 10.9.4
    Installing iobroker.rpi2@2.4.0... (System call)
    > iobroker.rpi2@2.4.0 preinstall
    > sudo apt-get install -y libgpiod-dev || exit 0
    Paketlisten werden gelesen…
    Abhängigkeitsbaum wird aufgebaut…
    Statusinformationen werden eingelesen…
    libgpiod-dev ist schon die neueste Version (2.2.1-2+deb13u1).
    0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
    > @stoprocent/noble@1.19.1 install
    > node-gyp-build
    gyp info it worked if it ends with ok
    gyp info using node-gyp@7.1.2
    gyp info using node@22.21.0 | linux | arm64
    (node:81620) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
    (Use `node --trace-deprecation ...` to show where the warning was created)
    gyp info find Python using Python version 3.13.5 found at "/usr/bin/python3"
    gyp ERR! UNCAUGHT EXCEPTION
    gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#<Object>'
    gyp ERR! stack     at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)
    gyp ERR! stack     at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9
    gyp ERR! stack     at FSReqCallback.oncomplete (node:fs:187:23)
    gyp ERR! System Linux 6.12.47+rpt-rpi-2712
    gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/@stoprocent/noble
    gyp ERR! node -v v22.21.0
    gyp ERR! node-gyp -v v7.1.2
    gyp ERR! Node-gyp failed to build your package.
    gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.
    > authenticate-pam@1.0.5 install
    > node-gyp rebuild
    (node:81634) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
    gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pam
    > cpu-features@0.0.10 install
    > node buildcheck.js > buildcheck.gypi && node-gyp rebuild
    (node:81667) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
    gyp ERR! cwd /opt/iobroker/node_modules/cpu-features
    > diskusage@1.2.0 install
    > node-gyp rebuild
    (node:81681) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
    gyp ERR! cwd /opt/iobroker/node_modules/diskusage
    > node-dht-sensor@0.4.5 install
    > node-gyp configure
    (node:81696) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
    gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "configure"
    gyp ERR! cwd /opt/iobroker/node_modules/node-dht-sensor
    > opengpio@1.0.18 install
    > node-gyp rebuild
    (node:81710) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
    gyp ERR! cwd /opt/iobroker/node_modules/opengpio
    npm error code 7
    npm error path /opt/iobroker/node_modules/opengpio
    npm error command failed
    npm error command sh -c node-gyp rebuild
    npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-12-27T09_52_54_865Z-debug-0.log
    npm error code 7
    host.RaspberryPi-Iobroker Cannot install iobroker.rpi2@2.4.0: 7
    #72
    @Gonzokalle
    cd /opt/iobroker/ && npm i iobroker.rpi2@3.0.2 --debug
    G 1 Antwort Letzte Antwort
      @Gonzokalle
      Gonzokalle
      #73
      @Thomas-Braun
      martin@RaspberryPi-Iobroker:/opt/iobroker $ cd /opt/iobroker/ && npm -i iobroker.rpi2@3.0.2 --debug
      Unknown command: "iobroker.rpi2@3.0.2"
      To see a list of supported npm commands, run:
        npm help
      • G Gonzokalle
        @Thomas-Braun
          npm help
        #74
        @Gonzokalle
        Hatte ich zuerst falsch. Ich meine das wird ohne Bindestrich gemacht. Siehe oben.
          @Gonzokalle
          Gonzokalle
          #75
          @Thomas-Braun
          Jetzt ist etwas passiert.
          martin@RaspberryPi-Iobroker:/opt/iobroker $ cd /opt/iobroker/ && npm i iobroker.rpi2@3.0.2 --debug
          npm error code 7
          npm error gyp info it worked if it ends with ok
          npm error gyp info using node-gyp@7.1.2
          npm error gyp info using node@22.21.0 | linux | arm64
          npm error (node:92813) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
          npm error (Use `node --trace-deprecation ...` to show where the warning was created)
          npm error gyp info find Python using Python version 3.13.5 found at "/usr/bin/python3"
          npm error gyp ERR! UNCAUGHT EXCEPTION
          npm error gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#<Object>'
          npm error gyp ERR! stack     at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)
          npm error gyp ERR! stack     at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9
          npm error gyp ERR! stack     at FSReqCallback.oncomplete (node:fs:187:23)
          npm error gyp ERR! System Linux 6.12.47+rpt-rpi-2712
          npm error gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"
          npm error gyp ERR! cwd /opt/iobroker/node_modules/opengpio
          npm error gyp ERR! node -v v22.21.0
          npm error gyp ERR! node-gyp -v v7.1.2
          npm error gyp ERR! Node-gyp failed to build your package.
          npm error gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.
          npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-12-27T12_42_56_742Z-debug-0.log
          • G Gonzokalle
            @Thomas-Braun
            npm error code 7
            #76
            @Gonzokalle
            Irgendwas stimmt nicht mit den Versionen, denke ich.
            Vielleicht versuchst du dein Glück mal mit nodejs@24
            iob nodejs-update 24
              @Gonzokalle
              Gonzokalle
              #77
              @Thomas-Braun
              24 wird ja noch gar nicht empfohlen.
              Gibt es einen Befehl um nodejs 22 neu zu installieren?
              • G Gonzokalle
                @Thomas-Braun
                #78
                @Gonzokalle sagte in RPI2 Adapter kann nicht installiert werden:
                hast du es denn probiert?
                es geht doch darum dass die Pakete neu gebaut werden.
                dito mit 22
                  dito mit 22
                  Gonzokalle
                  #79
                  @Homoran
                  Habe es mal mit nodejs 22 probiert und neu gestartet.
                  ioBroker nodejs fixer 2025-08-09
                  You requested to install latest version from nodejs v22 tree.
                  Your current setup is:
                  /usr/bin/nodejs         v22.21.0
                  /usr/bin/node           v22.21.0
                  /usr/bin/npm            10.9.4
                  /usr/bin/npx            10.9.4
                  /usr/bin/corepack       0.34.0
                  We found these nodejs versions available for installation:
                  nodejs:
                    Installed: 22.21.0-1nodesource1
                    Candidate: 22.21.0-1nodesource1
                    Version table:
                   *** 22.21.0-1nodesource1 1001
                          500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
                       22.20.0-1nodesource1 1001
                       22.19.0-1nodesource1 1001
                       22.18.0-1nodesource1 1001
                       22.17.1-1nodesource1 1001
                       22.17.0-1nodesource1 1001
                       22.16.0-1nodesource1 1001
                       22.15.1-1nodesource1 1001
                       22.15.0-1nodesource1 1001
                       22.14.0-1nodesource1 1001
                       22.13.1-1nodesource1 1001
                       22.13.0-1nodesource1 1001
                       22.12.0-1nodesource1 1001
                       22.11.0-1nodesource1 1001
                       22.10.0-1nodesource1 1001
                       22.9.0-1nodesource1 1001
                       22.8.0-1nodesource1 1001
                       22.7.0-1nodesource1 1001
                       22.6.0-1nodesource1 1001
                       22.5.1-1nodesource1 1001
                       22.5.0-1nodesource1 1001
                       22.4.1-1nodesource1 1001
                       22.4.0-1nodesource1 1001
                       22.3.0-1nodesource1 1001
                       22.2.0-1nodesource1 1001
                       22.1.0-1nodesource1 1001
                       22.0.0-1nodesource1 1001
                       20.19.2+dfsg-1 500
                          500 http://deb.debian.org/debian trixie/main arm64 Packages
                  Nothing to do - Your installation is using the correct paths.
                  You are running nodejs v22.21.0. Do you want to install latest version from nodejs v.22 tree?
                  Press <y> to continue or any other key to quit
                  Trying to fix your installation now. Please be patient.
                  find: '/run/user/1000/doc': Permission denied
                  find: '/run/user/1000/gvfs': Permission denied
                  Stopping ioBroker now
                  ioBroker has been stopped
                  Removing dfsg-nodejs
                  *** These repos are active on your system:
                  Hit:1 http://deb.debian.org/debian trixie InRelease
                  Hit:2 http://archive.raspberrypi.com/debian trixie InRelease
                  Hit:3 http://deb.debian.org/debian trixie-updates InRelease
                  Hit:4 http://deb.debian.org/debian-security trixie-security InRelease
                  Reading package lists... Done
                  *** Installing ca-certificates, curl and gnupg, just in case they are missing.
                  *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
                  deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_22.x nodistro main
                  Package: nodejs
                  Pin: origin deb.nodesource.com
                  Pin-Priority: 1001
                  *** These repos are active after the adjustments:
                  Hit:1 http://archive.raspberrypi.com/debian trixie InRelease
                  Hit:2 http://deb.debian.org/debian trixie InRelease
                  Get:5 https://deb.nodesource.com/node_22.x nodistro InRelease [12.1 kB]
                  Get:6 https://deb.nodesource.com/node_22.x nodistro/main armhf Packages [7375 B]
                  Get:7 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages [8572 B]
                  Fetched 28.1 kB in 0s (140 kB/s)
                  W: https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
                  Installing nodejs now!
                  Installing latest nodejs v22 release
                  SUCCESS!
                  v22.21.0 has been installed! You are using the latest nodejs@22 release now!
                  COMPATIBILITY CHECK IN PROGRESS (Only a --dry-run! No modules are really changed or added!)
                  add usocket 0.3.0
                  add unix-dgram 2.0.6
                  add raw-socket 1.8.1
                  add nan 2.19.0
                  add number-is-nan 1.0.1
                  add npmlog 4.1.2
                  add node-gyp 7.1.2
                  add rimraf 3.0.2
                  add minimatch 3.1.2
                  add glob 7.2.3
                  add brace-expansion 1.1.12
                  add net-ping 1.2.4
                  add napi-thread-safe-callback 0.0.6
                  add gauge 2.7.4
                  add strip-ansi 3.0.1
                  add string-width 1.0.2
                  add signal-exit 3.0.7
                  add is-fullwidth-code-point 1.0.0
                  add ansi-regex 2.1.1
                  add fsevents 2.3.3
                  add es6-promise 4.2.8
                  add env-paths 2.2.1
                  add diskusage 1.2.0
                  add cpu-features 0.0.10
                  add code-point-at 1.1.0
                  add buildcheck 0.0.7
                  add authenticate-pam 1.0.5
                  add are-we-there-yet 1.1.7
                  add string_decoder 1.1.1
                  add safe-buffer 5.1.2
                  add readable-stream 2.3.8
                  add @stoprocent/noble 1.19.1
                  added 32 packages in 2s
                  219 packages are looking for funding
                  We tried our best to fix your nodejs. Please run iob diag again to verify.
                  *** RESTARTING ioBroker NOW! ***
                   Please refresh or restart your browser in a few moments.
                  martin@RaspberryPi-Iobroker:/opt/iobroker $ sudo reboot
                  G HomoranH 2 Antworten Letzte Antwort
                  • G Gonzokalle
                    @Homoran
                    /usr/bin/npm            10.9.4
                    /usr/bin/npx            10.9.4
                    nodejs:
                      Version table:
                         20.19.2+dfsg-1 500
                    Package: nodejs
                    Pin-Priority: 1001
                    SUCCESS!
                    add usocket 0.3.0
                    add nan 2.19.0
                    add npmlog 4.1.2
                    add node-gyp 7.1.2
                    add rimraf 3.0.2
                    add minimatch 3.1.2
                    add glob 7.2.3
                    add net-ping 1.2.4
                    add gauge 2.7.4
                    add fsevents 2.3.3
                    add env-paths 2.2.1
                    add diskusage 1.2.0
                    Gonzokalle
                    #80
                    Mit nodesjs 22 versucht den rpi2@3.0.2 zu installieren.
                    login as: martin
                    martin@192.168.10.12's password:
                    Linux RaspberryPi-Iobroker 6.12.47+rpt-rpi-2712 #1 SMP PREEMPT Debian 1:6.12.47-        1+rpt1 (2025-09-16) aarch64
                    permitted by applicable law.
                    Last login: Sat Dec 27 16:54:46 2025 from 192.168.10.11
                    martin@RaspberryPi-Iobroker:~ $ cd /opt/iobroker/ && npm i iobroker.rpi2@3.0.2 --debug
                    npm error code 7
                    npm error (node:2692) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
                    npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-12-27T16_02_02_683Z-debug-0.log
                    • G Gonzokalle
                      @Homoran
                      /usr/bin/npm            10.9.4
                      /usr/bin/npx            10.9.4
                      nodejs:
                        Version table:
                           20.19.2+dfsg-1 500
                      Package: nodejs
                      Pin-Priority: 1001
                      SUCCESS!
                      add usocket 0.3.0
                      add nan 2.19.0
                      add npmlog 4.1.2
                      add node-gyp 7.1.2
                      add rimraf 3.0.2
                      add minimatch 3.1.2
                      add glob 7.2.3
                      add net-ping 1.2.4
                      add gauge 2.7.4
                      add fsevents 2.3.3
                      add env-paths 2.2.1
                      add diskusage 1.2.0
                      #81
                      ohne vorher die node Version zu ändern?
                      Das bringt nichts
                        Das bringt nichts
                        Gonzokalle
                        #82
                        @Homoran
                        Ist das hier noch gültig um die nodejs auf Version 24 zu bringen?
                        https://forum.iobroker.net/search?term=Update+NodeJS+best+practise&in=titles
                        • G Gonzokalle
                          @Homoran
                          #83
                          @Gonzokalle
                          Mach es so:
                            @Gonzokalle
                            Mach es so:
                            Gonzokalle
                            #84
                            @Thomas-Braun
                            Den iobroker vorher stoppen?
                            • G Gonzokalle
                              @Thomas-Braun
                              #85
                              @Gonzokalle
                              Kannste machen, macht der Befehl aber ohnehin selber.
                                @Gonzokalle
                                Gonzokalle
                                schrieb am zuletzt editiert von Gonzokalle
                                #86
                                @Thomas-Braun
                                Gut
                                Ist scheinbar ohne Fehler durchgelaufen.
                                Kann ich jetzt
                                probieren?
                                You requested to install latest version from nodejs v24 tree.
                                /usr/bin/npm            10.9.4
                                /usr/bin/npx            10.9.4
                                nodejs:
                                  Version table:
                                     20.19.2+dfsg-1 500
                                You are running nodejs v22.21.0. Do you want to install latest version from nodejs v.24 tree?
                                Get:3 http://deb.debian.org/debian trixie-updates InRelease [47.3 kB]
                                Fetched 47.3 kB in 0s (332 kB/s)
                                deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_24.x nodistro main
                                Package: nodejs
                                Pin-Priority: 1001
                                Get:5 https://deb.nodesource.com/node_24.x nodistro InRelease [12.1 kB]
                                Get:6 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages [4879 B]
                                Get:7 https://deb.nodesource.com/node_24.x nodistro/main armhf Packages [1369 B]
                                Fetched 18.4 kB in 1s (33.1 kB/s)
                                W: https://deb.nodesource.com/node_24.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
                                Installing latest nodejs v24 release
                                (Reading database ... 134042 files and directories currently installed.)
                                Preparing to unpack .../nodejs_24.12.0-1nodesource1_arm64.deb ...
                                Detected old npm client, removing...
                                Unpacking nodejs (24.12.0-1nodesource1) over (22.21.0-1nodesource1) ...
                                Setting up nodejs (24.12.0-1nodesource1) ...
                                Processing triggers for man-db (2.13.1-1) ...
                                SUCCESS!
                                v24.12.0 has been installed! You are using the latest nodejs@24 release now!
                                add usocket 0.3.0
                                add nan 2.19.0
                                add npmlog 4.1.2
                                add node-gyp 7.1.2
                                add rimraf 3.0.2
                                add minimatch 3.1.2
                                add glob 7.2.3
                                add net-ping 1.2.4
                                add gauge 2.7.4
                                add env-paths 2.2.1
                                add diskusage 1.2.0
                                remove @csstools/css-tokenizer 3.0.4
                                remove @csstools/css-parser-algorithms 3.0.5
                                remove canvas 2.11.2
                                added 31 packages, and removed 3 packages in 2s
                                214 packages are looking for funding
                                • G Gonzokalle
                                  @Thomas-Braun
                                  Gut
                                  Kann ich jetzt
                                  probieren?
                                  /usr/bin/npm            10.9.4
                                  /usr/bin/npx            10.9.4
                                  nodejs:
                                    Version table:
                                       20.19.2+dfsg-1 500
                                  Package: nodejs
                                  Pin-Priority: 1001
                                  SUCCESS!
                                  add usocket 0.3.0
                                  add nan 2.19.0
                                  add npmlog 4.1.2
                                  add node-gyp 7.1.2
                                  add rimraf 3.0.2
                                  add minimatch 3.1.2
                                  add glob 7.2.3
                                  add net-ping 1.2.4
                                  add gauge 2.7.4
                                  add env-paths 2.2.1
                                  add diskusage 1.2.0
                                  #87
                                  • G Gonzokalle
                                    @Thomas-Braun
                                    Gut
                                    Kann ich jetzt
                                    probieren?
                                    /usr/bin/npm            10.9.4
                                    /usr/bin/npx            10.9.4
                                    nodejs:
                                      Version table:
                                         20.19.2+dfsg-1 500
                                    Package: nodejs
                                    Pin-Priority: 1001
                                    SUCCESS!
                                    add usocket 0.3.0
                                    add nan 2.19.0
                                    add npmlog 4.1.2
                                    add node-gyp 7.1.2
                                    add rimraf 3.0.2
                                    add minimatch 3.1.2
                                    add glob 7.2.3
                                    add net-ping 1.2.4
                                    add gauge 2.7.4
                                    add env-paths 2.2.1
                                    add diskusage 1.2.0
                                    #88
                                    cd /opt/iobroker/
                                    npm i
                                    iob status
                                    Irgendein Adapter ist da auf einem alten Stand.
                                    canvas fliegt raus. Schau mit
                                    npm explain canvas
                                    nach warum
                                      Gonzokalle
                                      #89
                                      @Homoran
                                      Sieht doch ganz gut aus.
                                      ```bash
                                      Script v.2025-08-09
                                      *** BASE SYSTEM ***
                                      Operating System: Debian GNU/Linux 13 (trixie)
                                       Static hostname: RaspberryPi-Iobroker
                                             Icon name: computer
                                                Kernel: Linux 6.12.47+rpt-rpi-2712
                                          Architecture: arm64
                                      OS is similar to:
                                      Model           : Raspberry Pi 5 Model B Rev 1.0
                                      Docker          : false
                                      Virtualization  : none
                                      Kernel          : aarch64
                                      Userland        : 64 bit
                                      Systemuptime and Load:
                                       15:20:50 up 22:21,  3 users,  load average: 0.53, 0.59, 0.53
                                      CPU threads: 4
                                      *** LIFE CYCLE STATUS ***
                                      Operating System is the current Debian stable version codenamed 'trixie'!
                                      *** RASPBERRY THROTTLING ***
                                      Current issues:
                                      Previously detected issues:
                                      *** TIME AND TIMEZONES ***
                                                     Local time: Sun 2025-12-28 15:20:50 CET
                                                 Universal time: Sun 2025-12-28 14:20:50 UTC
                                                       RTC time: Sun 2025-12-28 14:20:50
                                                    NTP service: active
                                                RTC in local TZ: no
                                      *** Users and Groups ***
                                      User that called 'iob diag':
                                      martin
                                      HOME=/home/martin
                                      GROUPS=martin adm dialout cdrom sudo audio video plugdev games users netdev gpio i2c spi render input iobroker
                                      iobroker
                                      HOME=/home/iobroker
                                      SUDO_HOME=/home/martin
                                      *** DISPLAY-SERVER SETUP ***
                                      Display-Server:         true
                                      Display-Manager:        * lightdm.service - Light Display Manager
                                      Desktop:
                                      Session:                tty
                                      System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
                                      *** MEMORY ***
                                      Mem:            8.5G        3.5G        2.1G         57M        3.0G        4.9G
                                      Swap:           2.1G          0B        2.1G
                                      Total:           10G        3.5G        4.3G
                                      Active iob-Instances:   30
                                               8063 M total memory
                                               3358 M used memory
                                               3263 M active memory
                                               2224 M inactive memory
                                               2028 M free memory
                                                305 M buffer memory
                                               2511 M swap cache
                                               2047 M total swap
                                                  0 M used swap
                                               2047 M free swap
                                      top - 15:20:51 up 22:21,  3 users,  load average: 0.53, 0.59, 0.53
                                      Tasks: 248 total,   1 running, 247 sleeping,   0 stopped,   0 zombie
                                      %Cpu(s): 11.9 us,  2.4 sy,  0.0 ni, 85.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                      MiB Mem :   8063.0 total,   2023.0 free,   3364.2 used,   2817.4 buff/cache
                                      MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.   4698.9 avail Mem
                                      *** FAILED SERVICES ***
                                      0 loaded units listed.
                                      *** DMESG CRITICAL ERRORS ***
                                      No critical errors detected
                                      *** FILESYSTEM ***
                                      udev           devtmpfs  3.9G     0  3.9G   0% /dev
                                      tmpfs          tmpfs     1.6G   15M  1.6G   1% /run
                                      /dev/nvme0n1p2 ext4      917G   11G  869G   2% /
                                      tmpfs          tmpfs     4.0G  368K  4.0G   1% /dev/shm
                                      tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
                                      tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
                                      tmpfs          tmpfs     4.0G   19M  4.0G   1% /tmp
                                      /dev/nvme0n1p1 vfat      510M   86M  425M  17% /boot/firmware
                                      tmpfs          tmpfs     807M  256K  807M   1% /run/user/1000
                                      tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
                                      tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/serial-getty@ttyAMA10.service
                                      [Sat Dec 27 16:58:55 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0  numa=fake=8 system_heap.max_order=0 iommu_dma_numa_policy=interleave smsc95xx.macaddr=2C:CF:67:82:17:A3 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=e4c2f3ef-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
                                      [Sat Dec 27 16:58:56 2025] EXT4-fs (nvme0n1p2): orphan cleanup on readonly fs
                                      [Sat Dec 27 16:58:56 2025] EXT4-fs (nvme0n1p2): mounted filesystem d6944274-f2f7-4644-96a4-213c3b367f5c ro with ordered data mode. Quota mode: none.
                                      [Sat Dec 27 16:58:57 2025] EXT4-fs (nvme0n1p2): re-mounted d6944274-f2f7-4644-96a4-213c3b367f5c r/w.
                                      Show mounted filesystems:
                                      TARGET           SOURCE         FSTYPE OPTIONS
                                      /                /dev/nvme0n1p2 ext4   rw,noatime
                                      `-/boot/firmware /dev/nvme0n1p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                      /var:
                                      2.5G    /var/
                                      251M    /var/cache
                                      238M    /var/cache/apt
                                      221M    /var/lib
                                      154M    /var/lib/apt
                                      Archived and active journals take up 8M in the file system.
                                      /opt/iobroker/backups:
                                      98M     /opt/iobroker/backups/
                                      /opt/iobroker/iobroker-data:
                                      988M    /opt/iobroker/iobroker-data/
                                      496M    /opt/iobroker/iobroker-data/history
                                      319M    /opt/iobroker/iobroker-data/files
                                      124M    /opt/iobroker/iobroker-data/backup-objects
                                      67M     /opt/iobroker/iobroker-data/files/echarts.admin
                                      42M     /opt/iobroker/iobroker-data/objects.jsonl
                                      26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
                                      26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
                                      24M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.70a15e1f.js.map
                                      18M     /opt/iobroker/iobroker-data/files/echarts/preview/static/js/main.5fe9c7da.js.map
                                      USB-Devices by-id:
                                      /dev/serial/by-id/usb-SHK_JeeLink_LaCrosse-if00-port0
                                      /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2469419-if00
                                      *** ZigBee Settings ***
                                      HINT:
                                      Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                                      zigbee.X
                                      Extended Pan ID:
                                      *** MASKED ***
                                      Pan ID:
                                      *** MASKED ***
                                      Channel:
                                      *** MASKED ***
                                      Network Key:
                                      *** MASKED ***
                                      *** NodeJS-Installation ***
                                      /usr/bin/nodejs         v24.12.0
                                      /usr/bin/node           v24.12.0
                                      /usr/bin/npm            11.6.2
                                      /usr/bin/npx            11.6.2
                                      /usr/bin/corepack       0.34.5
                                      nodejs:
                                        Installed: 24.12.0-1nodesource1
                                        Candidate: 24.12.0-1nodesource1
                                        Version table:
                                       *** 24.12.0-1nodesource1 1001
                                              500 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages
                                           24.11.1-1nodesource1 1001
                                           24.11.0-1nodesource1 1001
                                           24.10.0-1nodesource1 1001
                                           24.9.0-1nodesource1 1001
                                           24.8.0-1nodesource1 1001
                                           24.7.0-1nodesource1 1001
                                           24.6.0-1nodesource1 1001
                                           24.5.0-1nodesource1 1001
                                           24.4.1-1nodesource1 1001
                                           24.4.0-1nodesource1 1001
                                           24.3.0-1nodesource1 1001
                                           24.1.0-1nodesource1 1001
                                           24.0.2-1nodesource1 1001
                                           24.0.1-1nodesource1 1001
                                           24.0.0-1nodesource1 1001
                                           20.19.2+dfsg-1 500
                                      No problems detected
                                      Errors in npm tree: 0
                                      *** ioBroker-Installation ***
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      Hosts:
                                      RaspberryPi-Iobroker RaspberryPi-Iobroker (version: 7.0.7, hostname: RaspberryPi-Iobroker, alive, uptime: 7712)
                                      Core adapters versions
                                      js-controller:  7.0.7
                                      admin:          7.7.19
                                      javascript:     9.0.11
                                      nodejs modules from github:     1
                                      +-- iobroker.eusec@2.0.3 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.eusec.git#f625cbb12aea40dcf6faf11a17d93328f069b753)
                                      Adapter State
                                      + system.adapter.admin.0                  : admin                 : RaspberryPi-Iobroker                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                      + system.adapter.alexa2.0                 : alexa2                : RaspberryPi-Iobroker                     -  enabled
                                      + system.adapter.backitup.0               : backitup              : RaspberryPi-Iobroker                     -  enabled
                                      + system.adapter.device-watcher.0         : device-watcher        : RaspberryPi-Iobroker                     -  enabled
                                        system.adapter.devices.0                : devices               : RaspberryPi-Iobroker                     - disabled
                                      + system.adapter.echarts.0                : echarts               : RaspberryPi-Iobroker                     -  enabled
                                      + system.adapter.energiefluss.0           : energiefluss          : RaspberryPi-Iobroker                     -  enabled
                                      + system.adapter.eusec.0                  : eusec                 : RaspberryPi-Iobroker                     -  enabled
                                        system.adapter.flot.0                   : flot                  : RaspberryPi-Iobroker                     - disabled
                                      + system.adapter.fullybrowser.0           : fullybrowser          : RaspberryPi-Iobroker                     -  enabled
                                      + system.adapter.history.0                : history               : RaspberryPi-Iobroker                     -  enabled
                                        system.adapter.icons-icons8.0           : icons-icons8          : RaspberryPi-Iobroker                     - disabled
                                      + system.adapter.iot.0                    : iot                   : RaspberryPi-Iobroker                     -  enabled
                                      + system.adapter.iqontrol.0               : iqontrol              : RaspberryPi-Iobroker                     -  enabled
                                      + system.adapter.iqontrol.1               : iqontrol              : RaspberryPi-Iobroker                     -  enabled
                                      + system.adapter.javascript.0             : javascript            : RaspberryPi-Iobroker                     -  enabled
                                      + system.adapter.jeelink.0                : jeelink               : RaspberryPi-Iobroker                     -  enabled
                                      + system.adapter.mqtt.0                   : mqtt                  : RaspberryPi-Iobroker                     -  enabled, port: 1884, bind: 0.0.0.0
                                        system.adapter.netatmo-crawler.0        : netatmo-crawler       : RaspberryPi-Iobroker                     -  enabled
                                      + system.adapter.opendtu.0                : opendtu               : RaspberryPi-Iobroker                     -  enabled
                                      + system.adapter.opendtu.1                : opendtu               : RaspberryPi-Iobroker                     -  enabled
                                      + system.adapter.radar2.0                 : radar2                : RaspberryPi-Iobroker                     -  enabled
                                      + system.adapter.reolink.0                : reolink               : RaspberryPi-Iobroker                     -  enabled
                                      + system.adapter.reolink.1                : reolink               : RaspberryPi-Iobroker                     -  enabled
                                        system.adapter.reolink.2                : reolink               : RaspberryPi-Iobroker                     - disabled
                                      + system.adapter.reolink.3                : reolink               : RaspberryPi-Iobroker                     -  enabled
                                      + system.adapter.shelly.0                 : shelly                : RaspberryPi-Iobroker                     -  enabled, port: 1882, bind: 0.0.0.0
                                      + system.adapter.smartgarden.0            : smartgarden           : RaspberryPi-Iobroker                     -  enabled
                                      + system.adapter.sonoff.0                 : sonoff                : RaspberryPi-Iobroker                     -  enabled, port: 1883, bind: 0.0.0.0
                                      + system.adapter.telegram.0               : telegram              : RaspberryPi-Iobroker                     -  enabled, port: 8443, bind: 0.0.0.0
                                      + system.adapter.terminal.0               : terminal              : RaspberryPi-Iobroker                     -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
                                      + system.adapter.web.0                    : web                   : RaspberryPi-Iobroker                     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                      + system.adapter.wled.0                   : wled                  : RaspberryPi-Iobroker                     -  enabled
                                      + system.adapter.zigbee.0                 : zigbee                : RaspberryPi-Iobroker                     -  enabled, port: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2469419-if00
                                      + instance is alive
                                      ioBroker-Repositories
                                      Active repo(s): stable
                                      Upgrade policy: none
                                      Installed ioBroker-Adapters
                                      Used repository: stable
                                      Adapter    "admin"        : 7.7.19   , installed 7.7.19
                                      Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
                                      Adapter    "backitup"     : 3.3.10   , installed 3.3.10
                                      Adapter    "device-watcher": 2.13.1  , installed 2.13.1
                                      Adapter    "devices"      : 1.2.8    , installed 1.2.8
                                      Adapter    "echarts"      : 1.9.2    , installed 1.9.2
                                      Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
                                      Adapter    "eusec"        : 2.0.3    , installed 2.0.3
                                      Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
                                      Adapter    "iot"          : 5.0.7    , installed 5.0.7
                                      Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
                                      Adapter    "javascript"   : 9.0.11   , installed 9.0.11
                                      Adapter    "jeelink"      : 1.2.5    , installed 1.2.5
                                      Controller "js-controller": 7.0.7    , installed 7.0.7
                                      Adapter    "netatmo-crawler": 1.1.0  , installed 1.1.0
                                      Adapter    "opendtu"      : 3.1.0    , installed 3.1.0
                                      Adapter    "radar2"       : 2.4.0    , installed 2.4.0
                                      Adapter    "reolink"      : 1.2.3    , installed 1.2.3
                                      Adapter    "shelly"       : 10.4.1   , installed 10.4.1
                                      Adapter    "smartgarden"  : 2.0.1    , installed 2.0.1
                                      Adapter    "socketio"     : 6.7.1    , installed 7.0.8
                                      Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
                                      Adapter    "terminal"     : 1.0.0    , installed 1.0.0
                                      Adapter    "web"          : 7.0.8    , installed 7.0.8
                                      Adapter    "wled"         : 0.7.2    , installed 0.7.2
                                      Adapter    "ws"           : 2.6.2    , installed 3.0.19
                                      Adapter    "zigbee"       : 3.1.5    , installed 3.2.5
                                      Objects and States
                                      Objects:        6945
                                      States:         5883
                                      Hit:5 https://deb.nodesource.com/node_24.x nodistro InRelease
                                      Pending Updates: 0
                                      *** Listening Ports ***
                                      tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       1679096    51906/io.mqtt.0
                                      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       1679168    51999/io.shelly.0
                                      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       1681214    52018/io.sonoff.0
                                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       1679520    51393/iobroker.js-c
                                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       1679525    51393/iobroker.js-c
                                      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          589619     18907/cupsd
                                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          10440      1000/sshd: /usr/sbi
                                      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          4716       1/init
                                      tcp6       0      0 :::1984                 :::*                    LISTEN      1001       1681677    51883/go2rtc
                                      tcp6       0      0 :::5900                 :::*                    LISTEN      985        8967       1014/wayvnc
                                      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          589618     18907/cupsd
                                      tcp6       0      0 :::8554                 :::*                    LISTEN      1001       1679923    51883/go2rtc
                                      tcp6       0      0 :::8555                 :::*                    LISTEN      1001       1681679    51883/go2rtc
                                      tcp6       0      0 :::21                   :::*                    LISTEN      0          8913       1001/vsftpd
                                      tcp6       0      0 :::22                   :::*                    LISTEN      0          10442      1000/sshd: /usr/sbi
                                      tcp6       0      0 :::111                  :::*                    LISTEN      0          138        1/init
                                      tcp6       0      0 :::8088                 :::*                    LISTEN      1001       1682622    52264/io.terminal.0
                                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       1679579    51415/io.admin.0
                                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       1683698    52283/io.web.0
                                      tcp6       0      0 :::3000                 :::*                    LISTEN      1001       1681715    51891/io.fullybrows
                                      udp        0      0 0.0.0.0:49674           0.0.0.0:*                           101        769        710/avahi-daemon: r
                                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       1682326    52303/io.wled.0
                                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           101        767        710/avahi-daemon: r
                                      udp        0      0 0.0.0.0:35232           0.0.0.0:*                           1001       1681024    51868/io.eusec.0
                                      udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       1681089    51951/io.radar2.0
                                      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          137        1/init
                                      udp6       0      0 :::5353                 :::*                                101        768        710/avahi-daemon: r
                                      udp6       0      0 :::48540                :::*                                101        770        710/avahi-daemon: r
                                      udp6       0      0 :::111                  :::*                                0          4717       1/init
                                      udp6       0      0 :::8555                 :::*                                1001       1681680    51883/go2rtc
                                      2025-12-28 15:19:31.127  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: WR2000 ist noch gesperrt
                                      2025-12-28 15:19:41.213  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: 14 ▫ 13<>15 ▫ 14
                                      2025-12-28 15:19:41.213  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: keine Änderung, Limit WR2000 bleibt gleich
                                      2025-12-28 15:19:51.098  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: WR600 auf 34% (200W)
                                      2025-12-28 15:19:51.098  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: 14 ▫ 13<>15 ▫ 15
                                      2025-12-28 15:19:51.098  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: keine Änderung, Limit WR2000 bleibt gleich
                                      2025-12-28 15:20:01.124  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: 15 ▫ 14<>17 ▫ 14
                                      2025-12-28 15:20:01.124  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: keine Änderung, Limit WR2000 bleibt gleich
                                      2025-12-28 15:20:11.163  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: 14 ▫ 13<>15 ▫ 15
                                      2025-12-28 15:20:11.163  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: keine Änderung, Limit WR2000 bleibt gleich
                                      2025-12-28 15:20:21.095  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: 14 ▫ 13<>15 ▫ 16
                                      2025-12-28 15:20:31.167  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: 16 ▫ 14<>18 ▫ 16
                                      2025-12-28 15:20:31.167  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: keine Änderung, Limit WR2000 bleibt gleich
                                      2025-12-28 15:20:41.125  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: 16 ▫ 14<>18 ▫ 14
                                      2025-12-28 15:20:41.125  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: keine Änderung, Limit WR2000 bleibt gleich
                                      2025-12-28 15:20:49.009  - info: host.RaspberryPi-Iobroker instance system.adapter.netatmo-crawler.0 in version "1.1.0" started with pid 57839
                                      2025-12-28 15:20:51.177  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: 16 ▫ 14<>18 ▫ 14
                                      2025-12-28 15:20:51.178  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: keine Änderung, Limit WR2000 bleibt gleich
                                      2025-12-28 15:21:01.159  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: 16 ▫ 14<>18 ▫ 14
                                      2025-12-28 15:21:01.159  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: keine Änderung, Limit WR2000 bleibt gleich
                                      2025-12-28 15:21:01.601  - info: host.RaspberryPi-Iobroker instance system.adapter.netatmo-crawler.0 having pid 57839 terminated with code 0 (NO_ERROR)
                                      2025-12-28 15:21:11.348  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: 16 ▫ 14<>18 ▫ 14
                                      2025-12-28 15:21:11.348  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: keine Änderung, Limit WR2000 bleibt gleich
                                      2025-12-28 15:21:21.491  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: 16 ▫ 14<>18 ▫ 15
                                      2025-12-28 15:21:21.491  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: keine Änderung, Limit WR2000 bleibt gleich
                                      iob diag has finished.
                                        cd /opt/iobroker/
                                        npm i
                                        iob status
                                        npm explain canvas
                                        nach warum
                                        Gonzokalle
                                        #90
                                        @Thomas-Braun
                                        martin@RaspberryPi-Iobroker:/opt/iobroker $ npm explain canvas
                                        npm error No dependencies found matching canvas
                                        npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-12-28T14_23_22_531Z-debug-0.log
                                        • G Gonzokalle
                                          @Homoran
                                          ```bash
                                          Script v.2025-08-09
                                          *** BASE SYSTEM ***
                                                 Icon name: computer
                                              Architecture: arm64
                                          OS is similar to:
                                          Docker          : false
                                          Kernel          : aarch64
                                          Userland        : 64 bit
                                          CPU threads: 4
                                          Current issues:
                                                        NTP service: active
                                                    RTC in local TZ: no
                                          martin
                                          HOME=/home/martin
                                          iobroker
                                          HOME=/home/iobroker
                                          Desktop:
                                          Session:                tty
                                          *** MEMORY ***
                                          Swap:           2.1G          0B        2.1G
                                                   8063 M total memory
                                                   3358 M used memory
                                                   2028 M free memory
                                                    305 M buffer memory
                                                   2511 M swap cache
                                                   2047 M total swap
                                                      0 M used swap
                                                   2047 M free swap
                                          *** FILESYSTEM ***
                                          /var:
                                          2.5G    /var/
                                          251M    /var/cache
                                          238M    /var/cache/apt
                                          221M    /var/lib
                                          154M    /var/lib/apt
                                          USB-Devices by-id:
                                          HINT:
                                          zigbee.X
                                          Extended Pan ID:
                                          *** MASKED ***
                                          Pan ID:
                                          *** MASKED ***
                                          Channel:
                                          *** MASKED ***
                                          Network Key:
                                          *** MASKED ***
                                          /usr/bin/npm            11.6.2
                                          /usr/bin/npx            11.6.2
                                          nodejs:
                                            Version table:
                                               20.19.2+dfsg-1 500
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          Hosts:
                                          admin:          7.7.19
                                          javascript:     9.0.11
                                          Adapter State
                                          + instance is alive
                                          Objects and States
                                          Objects:        6945
                                          States:         5883
                                          Pending Updates: 0
                                          #91
                                          Stell das auf Kommandozeilenbetrieb (multi-user) um.
                                          Mit dem Dateisystem stimmt was nicht. Es sollten keine orphans beseitigt werden müssen. Nicht bei einem sauberen Bootvorgang.
                                          Installier den eusec-Adapter nochmal aus dem Repo, nicht aus dem GitHub.
                                          Mach das Null_2_WR_autoSperre-Skript weniger geschwätzig. Das kübelt dir ja das komplette Log dicht.
